wa5300 瘦切胖
2021-11-16提问
  • 2收藏,649浏览
粉丝: 关注:
通过boot菜单修改ip得知后,电脑和ap ping不通,文件无法上传怎么办?
粉丝:8人 关注:4人
使用TFTP传输的方式,Server IP Address 和Local IP Address设置成同网段的地址,另外3cd软件打开,使用TFTP模式。如果传输文件失败,请确认一下是否文件位置指定的是否正确,最好放到桌面,不要放到文件夹里面
例如:
Server IP Address      :192.168.1.10
Local IP Address       :192.168.1.1
粉丝:38人 关注:3人
直接上传试试 上传后看下电脑的3CD是否在传输文件 如果是说明正常
重启时看到提示ctrl+b然后ctrl+y切换AP模式,选择对应编号即可;
  • ###方法二:如果AP包含fat文件,可以采用一下步骤####
System is starting...
Press Ctrl+D to access BASIC-BOOTWARE MENU
Booting Normal Extended BootWare
The Extended BootWare is self-decompressing.................................
.Done.
*                   H3C WA5320i BootWare, Version 7.18                     *
Copyright (c) 2004-2019 New H3C Technologies Co., Ltd.
Compiled Date       : Mar  8 2019
CPU Type            : ARM
CPU L1 Cache        : 32KB
CPU L2 Cache        : 256KB
CPU Clock Speed     : 710MHz
Memory Type         : DDR3 SDRAM
Memory Size         : 512MB
Memory Speed        : 667MHz
Flash Size          : 128MB
CPLD Version        : 001
PCB Version         : Ver.B
BootWare Validating...
Normal Extended BootWare Version is newer than Backup Extended BootWare!
Begin to Update the Backup Extended BootWare.........Done.
Press Ctrl+B to access EXTENDED-BOOTWARE MENU...
###重启过程中看时看到Ctrl+B Ctrl+B 进入
Password recovery capability is enabled.
Note: The current operating device is flash
Enter < Storage Device Operation > to select device.
==========================<EXTENDED-BOOTWARE MENU>==========================
|<1> Boot System                                                           |
|<2> Enter Serial SubMenu                                                  |
|<3> Enter Ethernet SubMenu                                                |
|<4> File Control                                                          |
|<5> Restore to Factory Default Configuration                              |
|<6> Skip Current System Configuration                                     |
|<7> BootWare Operation Menu                                               |
|<8> Skip Authentication for Console Login                                 |
|<9> Storage Device Operation                                              |
|<0> Reboot        |
Ctrl+Z: Access EXTENDED ASSISTANT MENU
Ctrl+F: Format File System
Ctrl+C: Display Copyright
Ctrl+Y: Change AP Mode####Ctrl+Y 进入
Enter your choice(0-9):
Please select the new mode
Current mode is FIT Mode
|NO.  Mode        |
|1    Fat Mode                                                             |
|2    Fit Mode                                                             |
|3    Anchor-AC   (Virtual AC Mode)                                        |
|4    Anchor-Fit                                                           |
|0    Exit        |
Enter your choice(0-4):1#选择1
Changed to fat mode successfully!
|<1> Boot System                                                           |
|<4> File Control                                                          |
|<0> Reboot        |
Enter your choice(0-9): 0
等待重启进入系统
