H3C s5560 三层交换机不同VLAN无法通信
2021-11-18提问
  • 1收藏,2127浏览
@me 零段
设置列表
  • 有序列表
  • 无序列表
对齐方式
  • 靠左
  • 居中
  • 靠右
H3C s5560   配置了四个VLAN 30  31  32  33  每个VLAN 都配置IP地址 ,测试书   VLAN30的用户无法ping通VLAN32的用户(俩台终端放入同一VLAN中,配置同网段的地址可以ping通)
配置:
[safevast]dis cu
# version 7.1.045, Release 1109
# sysname safevast
# irf mac-address persistent timer irf auto-update enable undo irf link-delay irf member 1 priority 1
# dhcp enable dhcp server forbidden-ip 172.16.31.1
# lldp global enable
# password-recovery enable
# vlan 1
# vlan 30 to 33
# stp global enable
 # dhcp server ip-pool vlan31 gateway-list 172.16.31.1 network 172.16.31.0 mask 255.255.255.0 dns-list 218.30.19.50 223.6.6.6 domain-name ***.*** expired day 0 hour 2
# interface NULL0
 # interface Vlan-interface30 ip address 172.16.30.2 255.255.255.0
 # interface Vlan-interface31 ip address 172.16.31.1 255.255.255.0
# interface Vlan-interface32 ip address 172.16.32.1 255.255.255.0
# interface Vlan-interface33 ip address 172.16.33.1 255.255.255.0
# interface FortyGigE1/0/29 port link-mode bridge
 # interface FortyGigE1/0/30 port link-mode bridge
# interface GigabitEthernet1/0/1 port link-mode bridge port access vlan 30
# interface GigabitEthernet1/0/2 port link-mode bridge port access vlan 30
# interface GigabitEthernet1/0/3 port link-mode bridge port access vlan 30
# interface GigabitEthernet1/0/4 port link-mode bridge port access vlan 30
# interface GigabitEthernet1/0/5 port link-mode bridge port access vlan 30
# interface GigabitEthernet1/0/6 port link-mode bridge port access vlan 30
# interface GigabitEthernet1/0/7 port link-mode bridge port access vlan 30
# interface GigabitEthernet1/0/8 port link-mode bridge port access vlan 30
# interface GigabitEthernet1/0/9 port link-mode bridge port access vlan 30
# interface GigabitEthernet1/0/10 port link-mode bridge port access vlan 30
# interface GigabitEthernet1/0/11 port link-mode bridge port access vlan 30
# interface GigabitEthernet1/0/12 port link-mode bridge port access vlan 30
# interface GigabitEthernet1/0/13 port link-mode bridge port access vlan 31
# interface GigabitEthernet1/0/14 port link-mode bridge port access vlan 31
# interface GigabitEthernet1/0/15 port link-mode bridge port access vlan 31
# interface GigabitEthernet1/0/16 port link-mode bridge port access vlan 31
# interface GigabitEthernet1/0/17 port link-mode bridge port access vlan 32
# interface GigabitEthernet1/0/18 port link-mode bridge port access vlan 32
# interface GigabitEthernet1/0/19 port link-mode bridge port access vlan 32
# interface GigabitEthernet1/0/20 port link-mode bridge port access vlan 32
# interface GigabitEthernet1/0/21 port link-mode bridge port access vlan 33
# interface GigabitEthernet1/0/22 port link-mode bridge port access vlan 33
# interface GigabitEthernet1/0/23 port link-mode bridge port access vlan 33
# interface GigabitEthernet1/0/24 port link-mode bridge port access vlan 33
# interface M-GigabitEthernet0/0/0
# interface M-GigabitEthernet0/0/1
# interface Ten-GigabitEthernet1/0/25 port link-mode bridge
# interface Ten-GigabitEthernet1/0/26 port link-mode bridge
# interface Ten-GigabitEthernet1/0/27 port link-mode bridge
 # interface Ten-GigabitEthernet1/0/28 port link-mode bridge
# scheduler logfile size 16
# line class aux user-role network-admin
# line class vty user-role network-operator
# line aux 0 user-role network-admin
# line vty 0 63 user-role network-operator
# ip route-static 0.0.0.0 0 172.16.30.1
# radius scheme system user-name-format without-domain
# domain system
 # domain default enable system
# role name level-0 description Predefined level-0 role
 # role name level-1 description Predefined level-1 role
 # role name level-2 description Predefined level-2 role
# role name level-3 description Predefined level-3 role
# role name level-4 description Predefined level-4 role
# role name level-5 description Predefined level-5 role
# role name level-6 description Predefined level-6 role
 # role name level-7 description Predefined level-7 role
# role name level-8 description Predefined level-8 role
# role name level-9 description Predefined level-9 role
# role name level-10 description Predefined level-10 role
 # role name level-11 description Predefined level-11 role
# role name level-12 description Predefined level-12 role
# role name level-13 description Predefined level-13 role
# role name level-14 description Predefined level-14 role
# user-group system
# return
bei 九段
粉丝:23人 关注:7人
终端需要配置网关
网关配了,终端都可以上网,问题应该在设备
@me 发表时间:2021-11-18
那不至于有这种问题,可以联系400看下,如果过保了,可以升级到最新版本
bei 发表时间:2021-11-18
粉丝:6人 关注:0人
终端的网关都配了吗?
终端网关都配置了,都可以上网
@me 发表时间:2021-11-18
VLAN30终端的网关是多少。上层应该还有个路由器把,有写到vlan32的回指路由吗
返璞归真 发表时间:2021-11-18
回复@me:
如果vlan 30终端网关是30.1,还要看下30.1的设备有没有做策略拒绝网段互访
没有作过任何策略,其他设备的网段的用户是可以ping通的
@me 发表时间:2021-11-18
要么就是路由有问题,你看下上层设备的回指路由
对,只有本交换机的其他VLAN的用户无法ping 通
@me 发表时间:2021-11-18
上层设备到本交换机的回指路由是 172.16.30.2
@me 发表时间:2021-11-18
粉丝:11人 关注:0人
vlan30的网关配置错了吧?
配置了,VLAN30的用户都可上网
@me 发表时间:2021-11-18
回复@me:
你30网段的网关都切换成30.2应该就没问题了。
红烧牛肉面 发表时间:2021-11-18
@me 知了小白
VLAN 30 是作为与上层设备连接网段,和部分客户使用网段
上层设备得IP是  172.16.30.1  本交换机该VLAN的IP是172.16.30.2
这个配置不会错
