H3C wa4320-acn-e-fit转胖ap
2021-11-18提问
  • 1收藏,596浏览
如题,需要一个步骤教程,之前瘦AP是v7版本
粉丝:8人 关注:4人
https://www.h3c.com/cn/d_202108/1436709_30005_0.htm,AP胖瘦切换教程
lilili 九段
粉丝:15人 关注:1人
第一步:进入V7boot Ctrl+F
第二步:进入V7boot 通过网卡口,传入V5 AP bin文件,提示更新boot版本的时候选择Y
第三步:再次Crtl+F格式化AP flash
第四步:导入V5 AP版本(从AC V5版本中获取,建议使用最新版本)
第五步:重启,降级完成
详细示例如下:
第一步:进入V7boot Ctrl+F
Copyright (c) 2004-2015 Hangzhou H3C Technologies Co., Ltd.
Compiled Date : Aug 17 2015
CPU Type : ATHEROS AR9563
CPU L1 Cache : 32KB
CPU Clock Speed : 775MHz
Memory Type : SDRAM
Memory Size : 128MB
Memory Speed : 560MHz
BootWare Size : 512KB
Flash Size : 16MB
PCB Version : Ver.A
BootWare Validating...
Press Ctrl+B to access EXTENDED-BOOTWARE MENU...
Password recovery capability is enabled.
Note: The current operating device is flash
Enter < Storage Device Operation > to select device.
==========================<EXTENDED-BOOTWARE MENU>==========================
|<1> Boot System |
|<2> Enter Serial SubMenu |
|<3> Enter Ethernet SubMenu |
|<4> File Control |
|<5> Restore to Factory Default Configuration |
|<6> Skip Current System Configuration |
|<7> BootWare Operation Menu |
|<8> Skip Authentication for Console Login |
|<9> Storage Device Operation |
|<0> Reboot |
Ctrl+Z: Access EXTENDED ASSISTANT MENU
Ctrl+F: Format File System
Ctrl+C: Display Copyright
Enter your choice(0-9):
Enter your choice(0-5): 5
==========================<ETHERNET PARAMETER SET>==========================
|Note: '.' = Clear field. |
| '-' = Go to previous field. |
| Ctrl+D = Quit. |
Protocol (FTP or TFTP) :tftp
Load File Name :wa4300_fit.bin
Target File Name :wa4300_fit.bin
Server IP Address :192.168.21.1
Local IP Address :192.168.21.2
Subnet Mask :255.255.255.0
Gateway IP Address :0.0.0.0
==========================<Enter Ethernet SubMenu>==========================
|Note:the operating device is flash |
|<1> Download Image Program To SDRAM And Run |
|<2> Update Main Image File |
|<3> Update Backup Image File |
|<4> Download Files(*.*) |
|<5> Modify Ethernet Parameter |
|<0> Exit To Main Menu |
|<Ensure The Parameter Be Modified Before Downloading!> |
Enter your choice(0-5): 1
Loading.....................................................................
........Done.
7715840 bytes downloaded!
The image is self-decompressing.............................................
Done.
Extended BootWare Version is not equal,updating? [Y/N]
Updating Extended BootWare..........Done.
BootWare updated,System is rebooting now.
System is starting...
Press Ctrl+D to access BASIC-BOOTWARE MENU
Booting Normal Extend BootWare
The Extend BootWare is self-decompressing..............................Done!
|<1> Download Application Program To SDRAM And Run |
|<2> Update Main Application File |
|<3> Modify Ethernet Parameter |
Enter your choice(0-3): 3
| Ctrl+D = Quit. |
Load File Name :host
:wa4300_fit.bin
Target File Name :target
:wa4300_fit.bin
Server IP Address :192.168.1.1 192.168.21.1
Local IP Address :192.168.1.253 192.168.21.2
Enter your choice(0-3): 2
........Done!
Updating File flash:/wa4300_fit.bin.........................................
..Done!
第五步:重启,降级完成
珍时 知了小白
干嘛搞得那么复杂
有什么便捷的办法
轻淡笑 发表时间:2021-11-18
轻淡笑 知了小白
我格式化,并且上传了FAT.bin 重启还是在找AC获取固件
你上传fat文件后得指定一下启动文件。
不吃鱼的猫 发表时间:2021-11-19
