irf 加vlan的bfd
2021-11-23提问
  • 1收藏,963浏览
bfd 是怎么玩? int vlan-in 4000 mad bfd en mad ip add 1.1.1.1 28 me1 mad ip add 1.1.1.2 28 me2 然后应用在接口 这是什么情况
详细解释下,谢谢
https://www.h3c.com/cn/d_202103/1390248_30005_0.htm
可以参考下这个
粉丝:22人 关注:1人
聚合口与你这个原理是一样的,快速检测IRF是否分裂,参考如下:
interface Route-Aggregation1
 mad bfd enable
 mad ip address 192.168.2.1 255.255.255.0 member 1
 mad ip address 192.168.2.2 255.255.255.0 member 2
[Device A]dis mad verbose
Multi-active recovery state: No
Excluded ports (user-configured):
Excluded ports (system-configured):
  GigabitEthernet1/5/0
  GigabitEthernet2/5/0
MAD ARP disabled.
MAD ND disabled.
MAD LACP disabled.
MAD BFD enabled interface: Route-Aggregation1
  MAD status                 : Normal
  Member ID   MAD IP address       Neighbor   MAD status
  1           192.168.2.1/24       2          Normal
  2           192.168.2.2/24       1          Normal
IRF正常的情况下,接口IP只有一个生效(只显示主机的IP),故该BFDdown的:
[Device A]dis ip int b
*down: administratively down
(s): spoofing  (l): loopback
Interface           Physical Protocol IP address/Mask    VPN instance Description
GE1/0/0             up       up       172.16.0.2/24      --           --
GE1/5/1             up       up       --                 --           --
GE1/6/0             down     down     --                 --           --
GE1/6/1             down     down     --                 --           --
GE2/0/0             up       up       172.16.1.2/24      --           --
GE2/5/1             up       up       --                 --           --
GE2/6/0             down     down     --                 --           --
GE2/6/1             down     down     --                 --           --
RAGG1               up       up       192.168.2.1/24     --           --
Ser1/1/0            down     down     --                 --           --
<Device A>dis bfd s
 Total sessions: 1        Up sessions: 0        Init mode: Active
 LD/RD           SourceIP        DestinationIP   State   Holdtime    Interface
 33793/0         192.168.2.1     192.168.2.2     Down    0ms         RAGG1
如果IRF分裂,备机临时认为自己是主设备,接口保持UpBFD会出现up的情况:
[Device A]%Aug 13 17:03:23:333 2021 Device A LAGG/6/LAGG_ACTIVE: Member port GE1/5/1 of aggregation group RAGG1 changed to the active state.
%Aug 13 17:03:23:334 2021 Device A IFNET/3/PHY_UPDOWN: Physical state on the interface GigabitEthernet1/5/1 changed to up.
%Aug 13 17:03:23:335 2021 Device A IFNET/5/LINK_UPDOWN: Line protocol state on the interface GigabitEthernet1/5/1 changed to up.
%Aug 13 17:03:23:335 2021 Device A IFNET/3/PHY_UPDOWN: Physical state on the interface Route-Aggregation1 changed to up.
%Aug 13 17:03:23:335 2021 Device A IFNET/5/LINK_UPDOWN: Line protocol state on the interface Route-Aggregation1 changed to up.
d%Aug 13 17:03:23:380 2021 Device A BFD/5/BFD_CHANGE_FSM: Sess[192.168.2.1/192.168.2.2, LD/RD:33793/33793, Interface:RAGG1, SessType:Ctrl, LinkType:INET], Ver:1, Sta: DOWN->UP, Diag: 0 (NoDiagnostic)
%Aug 13 17:03:23:433 2021 Device A LAGG/6/LAGG_INACTIVE_PHYSTATE: Member port GE1/5/1 of aggregation group RAGG1 changed to the inactive state, because the physical state of the port is don.
%Aug 13 17:03:23:434 2021 Device A IFNET/3/PHY_UPDOWN: Physical state on the interface GigabitEthernet1/5/1 changed to down.
%Aug 13 17:03:23:434 2021 Device A IFNET/5/LINK_UPDOWN: Line protocol state on the interface GigabitEthernet1/5/1 changed to down.
%Aug 13 17:03:23:435 2021 Device A IFNET/3/PHY_UPDOWN: Physical state on the interface Route-Aggregation1 changed to down.
%Aug 13 17:03:23:435 2021 Device A IFNET/5/LINK_UPDOWN: Line protocol state on the interface Route-Aggregation1 changed to down.
备机检测到IRF冲突,MAD down接口后,BFD再次down
[Device A]%Aug 13 17:03:28:385 2021 Device A BFD/5/BFD_CHANGE_FSM: Sess[192.168.2.1/192.168.2.2, LD/RD:33793/33793, Interface:RAGG1, SessType:Ctrl, LinkType:INET], Ver:1, Sta: UP->DOWN, Dig: 1 (Control Detection Time Expired)
