MSR2600-10-WiNet无法跑满带宽,求方法!
2018-07-14提问
  • 1收藏,1361浏览
MSR2600-10-WiNet为什么跑不满百兆带宽?
中国电信百兆带宽,接到G0/0接口,G0/0接口强制百兆全双工,结果跑下来Speedtest测速只有二三十兆,跑迅雷能到七十几兆,我换用其它路由器都能跑出来九十几Mbps的数据,换了多个测速方式均如此。所有测试路由器均开启了NAT功能,但是也不至于跑不满百兆啊!损失了二十兆去哪儿了?
我并没有做带宽限制,换了另一个WAN口也是这样。
我按照前一个回答将wan口mtu改为1200,tcp mss改为1024还是不行。
以下是我收集到的上网信息:
 version 5.20, Release 2516P19
 sysname H3C
 password-control enable
 undo password-control aging enable
 undo password-control history enable
 password-control length 6
 password-control login-attempt 3 exceed lock-time 10
 password-control password update interval 0
 password-control login idle-time 0
 password-control complexity user-name check
 domain default enable system
 dns proxy enable
 dar p2p signature-file flash:/p2p_default.mtd
 ndp enable
 ntdp enable
 cluster enable
 port-security enable
 password-recovery enable
vlan 1
domain system
 access-limit disable
 state active
 idle-cut disable
 self-service-url disable
dhcp server ip-pool vlan1 extended
 network ip range 192.168.1.2 192.168.1.254
 network mask 255.255.255.0
 gateway-list 192.168.1.1
 dns-list 192.168.1.1
user-group system
 group-attribute allow-guest
local-user admin
 authorization-attribute level 3
 service-type telnet
 service-type web
cwmp
 undo cwmp enable
interface Aux0
 async mode flow
 link-protocol ppp
interface Cellular0/0
 async mode protocol
 link-protocol ppp
 tcp mss 1024
interface NULL0
interface Vlan-interface1
 tcp mss 1024
 dhcp server apply ip-pool vlan1
interface GigabitEthernet0/0
 port link-mode route
 nat outbound
 duplex full
 speed 100
 ip address dhcp-alloc
interface GigabitEthernet0/1
 tcp mss 1024
interface GigabitEthernet0/2
 port link-mode bridge
interface GigabitEthernet0/3
interface GigabitEthernet0/4
interface GigabitEthernet0/5
interface GigabitEthernet0/6
interface GigabitEthernet0/7
interface GigabitEthernet0/8
interface GigabitEthernet0/9
 dhcp enable
 nms primary monitor-interface GigabitEthernet0/0
 load xml-configuration
 load tr069-configuration
user-interface tty 12
user-interface aux 0
user-interface vty 0 4
 authentication-mode scheme
粉丝:14人 关注:0人
单机直连路由器测速能测出多少?G0/0号口改为自动协商或强制成1000M全双工测试下。宽带直接插在电脑上看下电脑获取的dns是多少,然后把我们路由器dhcp分配的dns地址改为这个值。在您的配置里没有把mtu改为1200,tcp mss改为1024,建议改一下
我强制全双工1000M,结果端口直接down了,又改回了全双工100M,我把LAN口和WAN口的mtu都改为1200,tcp mss都改为1024,结果网速还是不达标。改了DNS后网速反而下降了!
zhiliao_D2V2e 发表时间:2018-07-14
