交换机某个端口频繁断开及连接
  • 1收藏,2206浏览
%Jun 3 11:54:55:784 2014 s115 IFNET/5/LINK_UPDOWN: Line protocol state on the interface GigabitEthernet1/0/9 changed to up.
%Jun 3 11:54:55:783 2014 s115 IFNET/3/PHY_UPDOWN: Physical state on the interface GigabitEthernet1/0/9 changed to up.
%Jun 3 11:54:52:476 2014 s115 IFNET/5/LINK_UPDOWN: Line protocol state on the interface GigabitEthernet1/0/9 changed to down.
%Jun 3 11:54:52:475 2014 s115 IFNET/3/PHY_UPDOWN: Physical state on the interface GigabitEthernet1/0/9 changed to down.
%Jun 3 11:54:28:631 2014 s115 STP/6/STP_DETECTED_TC: Instance 0's port GigabitEthernet1/0/9 detected a topology change.
这一般是什么问题呀?有大神知道吗?
粉丝:154人 关注:1人
接口up down,可以检查线缆是否被拔掉或者松动
这样会导致CPU过高,从而导致重启吗
zhiliao_vJDVGe 发表时间:2021-11-26
不会
叫我靓仔 发表时间:2021-11-29
粉丝:11人 关注:0人
物理线路问题,测下网络8芯是否都正常。如果是光纤,看下光衰是否正常
