要疯了,MSR 36-20+300M电信宽带网络奇慢无比
2018-07-16提问
  • 1收藏,1485浏览
有时候解析奇慢无比,路由器MTU是1500 之前无法上网把dialer的tcp mss值改为1024就可以上网,现在改为1452也可以上网,就是间歇性慢
* Copyright (c) 2004-2017 Hangzhou H3C Tech. Co., Ltd. All rights reserved.  *
login: admin
Password:
<H3C>sys
[H3C]di cu
 version 7.1.064, Release 0415
 sysname H3C
 clock timezone Beijing add 08:00:00
 clock protocol none
 telnet server enable
 dialer-group 2 rule ip permit
 dhcp enable
 dns proxy enable
 dns server 202.96.134.133
 dns server 114.114.114.114
 password-recovery enable
vlan 1
object-group ip address 10
controller Cellular0/0
controller Cellular0/1
interface Aux0
interface Dialer0
 bandwidth 64
 ppp chap password cipher $c$3$soQruqahWmzVnlRdSpJf3DQRkVb7fwtsuxo9
 ppp chap user 075508117001@163.gd
 ppp ipcp dns admit-any
 ppp pap local-user 075508117001@163.gd password cipher $c$3$ARZdWCfqJvkTmfmBdRA
POHSnKuvBoih2z8rg
 dialer bundle enable
 dialer-group 2
 dialer timer idle 0
 dialer timer autodial 5
 ip address ppp-negotiate
 tcp mss 1452
 nat outbound 2000
interface NULL0
interface Vlan-interface1
 ip address 192.168.0.1 255.255.255.0
 undo dhcp select server
interface GigabitEthernet0/0
 port link-mode route
 description Multiple_Line
 combo enable copper
 dhcp server apply ip-pool defaultpool
 pppoe-client dial-bundle-number 0
interface GigabitEthernet0/1
interface GigabitEthernet0/2
 port link-mode bridge
interface GigabitEthernet5/0
 port link-type trunk
 port trunk permit vlan 1 10 20 50
interface GigabitEthernet5/1
interface GigabitEthernet5/2
interface GigabitEthernet5/3
interface GigabitEthernet5/4
interface GigabitEthernet5/5
interface GigabitEthernet5/6
 combo enable copper
interface GigabitEthernet5/7
 combo enable copper
object-policy ip Any-Any
 rule 0 pass source-ip 10 app-group P2P_13 logging time-range work
 rule 1 inspect P2P source-ip 10 time-range work
 rule 65534 pass
security-zone name Local
security-zone name Trust
security-zone name DMZ
security-zone name Untrust
security-zone name Management
zone-pair security source Any destination Any
 object-policy apply ip Any-Any
 scheduler logfile size 16
line class aux
 user-role network-admin
line class tty
 user-role network-operator
line class vty
line aux 0
line vty 0 15
 authentication-mode scheme
line vty 16 63
 ip route-static 0.0.0.0 0 Dialer0
 ip route-static 192.168.2.0 24 192.168.0.2
 ip route-static 192.168.6.0 24 192.168.0.2
 ip route-static 192.168.10.0 24 192.168.0.2
 ip route-static 192.168.20.0 24 192.168.0.2
 ip route-static 192.168.50.0 24 192.168.0.2
 arp static 192.168.0.11 50da-00aa-cda0
 arp static 192.168.10.163 fa01-fb01-fc01
 time-range work 08:30 to 22:00 working-day
acl basic 2000
 rule 1 permit source 192.168.10.0 0.0.0.255
 rule 2 deny source 192.168.20.71 0
 rule 3 permit source 192.168.6.0 0.0.0.255
 rule 4 permit source 192.168.7.0 0.0.0.255
 rule 5 permit source 192.168.2.0 0.0.0.255
 rule 600 permit source 192.168.20.0 0.0.0.255
粉丝:11人 关注:3人
DNS解析很慢,可以ping一下DNS服务器看一下慢不慢,同时打开debug icmp看一下来回时间
粉丝:4人 关注:0人
dns服务器最好用运营商给的dns地址。一般通用的会比运营商直接给的慢一点。
