再次提问:MSR2600跑不满百兆带宽。
2018-07-16提问
  • 1收藏,2314浏览
MSR2600跑不满百兆带宽。
中国电信百兆带宽,接到G0/0接口,G0/0接口强制百兆全双工(如果不强制百兆全双工,无论是处于auto状态还是强制千兆状态G0/0口都无法up),结果跑下来Speedtest测速只有二三十兆,跑迅雷能到七十几兆,我换用其它路由器都能跑出来九十几Mbps的数据,换了多个测速方式均如此。所有测试路由器均开启了NAT功能,但是也不至于跑不满百兆啊!损失了二十兆去哪儿了?
我并没有做带宽限制,换了另一个WAN口也是这样。
按照前面提问的解释,我将WAN口和LAN口的mtu都改成1200,mss都改为1024,同时又换了成品网线(换了两种不同的成品网线),将LAN口(G0/6)也强制百兆全双工,还是最高只能跑到七十多兆。
这究竟是什么原因造成的?
同时测试了WAN口和LAN口的错误,发现WAN口上行有大量错误,网线都换了,为什么还会有大量不断增长的错误?为什么别的几个路由器(两个华为的,一个TP的)都可以跑满100M而MSR2600就不行?
以下是LAN口和WAN口信息:
<H3C>dis cu
 version 5.20, Release 2516P19
 sysname H3C
 password-control enable
 undo password-control aging enable
 undo password-control history enable
 password-control length 6
 password-control login-attempt 3 exceed lock-time 10
 password-control password update interval 0
 password-control login idle-time 0
 password-control complexity user-name check
 domain default enable system
 dns proxy enable
 dar p2p signature-file flash:/p2p_default.mtd
 ndp enable
 ntdp enable
 cluster enable
 port-security enable
 password-recovery enable
vlan 1
domain system
 access-limit disable
 state active
 idle-cut disable
 self-service-url disable
dhcp server ip-pool vlan1 extended
 network ip range 192.168.1.2 192.168.1.254
 network mask 255.255.255.0
 gateway-list 192.168.1.1
 dns-list 192.168.1.1
user-group system
 group-attribute allow-guest
local-user admin
 authorization-attribute level 3
 service-type telnet
 service-type web
cwmp
 undo cwmp enable
interface Aux0
 async mode flow
 link-protocol ppp
interface Cellular0/0
 async mode protocol
 link-protocol ppp
 tcp mss 1024
interface NULL0
interface Vlan-interface1
 mtu 1200
 tcp mss 1024
 dhcp server apply ip-pool vlan1
 ip flow-ordering internal
interface GigabitEthernet0/0
 port link-mode route
 nat outbound
 mtu 1200
 duplex full
 speed 100
 tcp mss 1024
 ip address dhcp-alloc
 arp send-gratuitous-arp interval 2000
interface GigabitEthernet0/1
 tcp mss 1024
interface GigabitEthernet0/2
 port link-mode bridge
interface GigabitEthernet0/3
interface GigabitEthernet0/4
interface GigabitEthernet0/5
interface GigabitEthernet0/6
 speed 100
 duplex full
interface GigabitEthernet0/7
interface GigabitEthernet0/8
interface GigabitEthernet0/9
 dhcp enable
 nms primary monitor-interface GigabitEthernet0/0
 load xml-configuration
 load tr069-configuration
user-interface tty 12
user-interface aux 0
user-interface vty 0 4
 authentication-mode scheme
return
<H3C>display interface g0/0
GigabitEthernet0/0 current state: UP
Description: GigabitEthernet0/0 Interface
The Maximum Transmit Unit is 1200
Internet Address is ***.***.***.***/20, acquired via DHCP
IP Packet Frame Type: PKTFMT_ETHNT_2,
IPv6 Packet Frame Type: PKTFMT_ETHNT_2,
Media type is twisted pair, loopback not set, promiscuous mode not set
100Mb/s, Full-duplex, link type is force link
Output flow-control is disabled, input flow-control is disabled
Output queue : (Urgent queuing : Size/Length/Discards)  0/100/0
Output queue : (Protocol queuing : Size/Length/Discards)  0/500/0
Output queue : (FIFO queuing : Size/Length/Discards)  0/75/0
Last clearing of counters: 00:03:47  Tue 01/01/2013
   Last 300 seconds input rate 5001376.00 bytes/sec, 40011008 bits/sec, 4853.38
packets/sec
   Last 300 seconds output rate 214890.04 bytes/sec, 1719120 bits/sec, 3181.73 p
ackets/sec
    Input: 1767895 packets, 1810281963 bytes, 1767895 buffers
           126 broadcasts, 564 multicasts, 0 pauses
           139019 errors, 104526 runts, 0 giants
           34493 crc, 0 align errors, 0 overruns
           0 dribbles, 0 drops, 0 no buffers
    Output:1172016 packets, 79999012 bytes, 1172016 buffers
           426 broadcasts, 0 multicasts, 0 pauses
           0 errors, 0 underruns, 0 collisions
           0 deferred, 0 lost carriers
<H3C>display interface g0/6
 GigabitEthernet0/6 current state: UP
 Description: GigabitEthernet0/6 Interface
 Loopback is not set
 Media type is twisted pair, port hardware type is 1000_BASE_T
 100Mbps-speed mode, full-duplex mode
 Link speed type is force link, link duplex type is force link
 Flow-control is not enabled
 The Maximum Frame Length is 10240
 Broadcast MAX-ratio: 100%
 Unicast MAX-ratio: 100%
 Multicast MAX-ratio: 100%
 PVID: 1
 Mdi type: auto
 Port link-type: access
  Tagged   VLAN ID : none
  Untagged VLAN ID : 1
 Port priority: 0
 Last clearing of counters:  00:03:50 Tue 01/01/2013
 Last 300 seconds input:  3237 packets/sec 229491 bytes/sec 2%
 Last 300 seconds output:  4878 packets/sec 5021633 bytes/sec 41%
 Input (total):  1194263 packets, 85470115 bytes
         - unicasts, - broadcasts, - multicasts, - pauses
 Input (normal):  1172854 packets, 84757466 bytes
         1172718 unicasts, 118 broadcasts, 18 multicasts, 0 pauses
 Input:  21409 input errors, 18407 runts, 0 giants, - throttles
         3002 CRC, - frame, - overruns, 0 aborts
         - ignored, - parity errors
 Output (total): - packets, 1817443720 bytes
 Output (normal): 1775053 packets, - bytes
         1775039 unicasts, 0 broadcasts, 14 multicasts, 0 pauses
         - lost carrier, - no carrier
粉丝:110人 关注:0人
正常情况下MTU值默认值是1500,而 tcp mss是有MTU值协商过来的。
过低将MTU值和TCP mss值写小容易造成报文过于频繁分配,降低报文的传输效率,特别在大包传输过程更加明显,建议您先将mtu值配置先删除(undo mtu),然后将TCP Mss值修改为1440(推荐),然后关闭接口下的流浪统计再试一下。
runts 表示接收到的超小帧个数。超小帧即接收到的报文小于64字节,且包括有效的CRC字段;
CRC 校验错误
这些都是异常情况,除了线路问题也有可能是设备间的协商问题所致。可以建议替换设备测试。
我按照您说的修改了,最高只能跑到10MB,也就是80Mbps,差距还是比较大。我想问一下,您说的替换设备是指替换路由器吗?我没法把电信那边的设备替换了啊。
zhiliao_D2V2e 发表时间:2018-07-17
