交换机已经发现了邻里关系但是在配置的trunk端口下用一台交换机ping另一台无法通信。
2021-12-03提问
  • 1收藏,1116浏览
粉丝:0人 关注:4人
各位大神:
             我配置了两台交换机,我用交换机A的27端口去ping交换机B的51端口结果无法ping通,我又用终端关闭了防火墙去ping网管结果也是无法通信请各位看看我的配置信息。是否有问题小白在此跪谢。
设置列表
  • 有序列表
  • 无序列表
对齐方式
  • 靠左
  • 居中
  • 靠右
粉丝:9人 关注:1人
邻居关系,只要互联口起来都可以看到,你这个不能通信的问题两边是trunk互联?把两台交换机创建vlan的配置 两台交换机互联的端口配置  以及两台交换机接终端的配置贴出来看一下,附件下载不了。比如在B交换机创建一下vlan虚接口地址,用A交换机主机去ping是否可以通信。
# version 5.20, Release 2112 # sysname 10-Lshx-01 # irf mac-address persistent timer irf auto-update enable undo irf link-delay # domain default enable system # telnet server enable # undo ip http enable # mac-address timer aging 150 # multicast routing-enable # password-recovery enable # igmp-snooping # vlan 1 # vlan 20 # vlan 101 to 102 # radius scheme system server-type extended primary authentication 127.0.0.1 1645 primary accounting 127.0.0.1 1646 # domain system access-limit disable state active idle-cut disable self-service-url disable # user-group system group-attribute allow-guest # local-user admin password cipher $c$3$lxb79Mx4LzLsLK9JLCFCPLoyBsBfe/e0 service-type telnet # stp instance 0 root primary stp enable # interface NULL0 # interface LoopBack0 # interface Vlan-interface1 ip address dhcp-alloc client-identifier mac Vlan-interface1 # interface Vlan-interface20 ip address 20.10.100.10 255.255.0.0 vrrp vrid 20 virtual-ip 20.10.0.1 vrrp vrid 20 priority 120 vrrp vrid 20 timer advertise 5 vrrp vrid 20 authentication-mode simple cipher $c$3$8A2v9NewBTCgUAQCCa6VCGfHj2jeAflk igmp enable pim sm # interface Ethernet1/0/1 port link-mode bridge description ATS port access vlan 20 # interface Ethernet1/0/2 port link-mode bridge description BGCM port access vlan 20 # interface Ethernet1/0/3 port link-mode bridge description TCC port access vlan 20 # interface Ethernet1/0/4 port link-mode bridge port access vlan 20 # interface Ethernet1/0/5 port link-mode bridge port access vlan 20 # interface Ethernet1/0/6 port link-mode bridge port access vlan 20 # interface Ethernet1/0/7 port link-mode bridge port access vlan 20 # interface Ethernet1/0/8 port link-mode bridge port access vlan 20 # interface Ethernet1/0/9 port link-mode bridge port access vlan 20 # interface Ethernet1/0/10 port link-mode bridge port access vlan 20 # interface Ethernet1/0/11 port link-mode bridge # interface Ethernet1/0/12 port link-mode bridge # interface Ethernet1/0/13 port link-mode bridge # interface Ethernet1/0/14 port link-mode bridge # interface Ethernet1/0/15 port link-mode bridge # interface Ethernet1/0/16 port link-mode bridge # interface Ethernet1/0/17 port link-mode bridge # interface Ethernet1/0/18 port link-mode bridge # interface Ethernet1/0/19 port link-mode bridge # interface Ethernet1/0/20 port link-mode bridge # interface Ethernet1/0/21 port link-mode bridge # interface Ethernet1/0/22 port link-mode bridge # interface Ethernet1/0/23 port link-mode bridge # interface Ethernet1/0/24 port link-mode bridge # interface Ethernet1/0/25 port link-mode bridge # interface Ethernet1/0/26 port link-mode bridge # interface Ethernet1/0/27 port link-mode bridge # interface Ethernet1/0/28 port link-mode bridge # interface Ethernet1/0/29 port link-mode bridge # interface Ethernet1/0/30 port link-mode bridge # interface Ethernet1/0/31 port link-mode bridge # interface Ethernet1/0/32 port link-mode bridge # interface Ethernet1/0/33 port link-mode bridge # interface Ethernet1/0/34 port link-mode bridge # interface Ethernet1/0/35 port link-mode bridge # interface Ethernet1/0/36 port link-mode bridge # interface Ethernet1/0/37 port link-mode bridge # interface Ethernet1/0/38 port link-mode bridge # interface Ethernet1/0/39 port link-mode bridge # interface Ethernet1/0/40 port link-mode bridge # interface Ethernet1/0/41 port link-mode bridge # interface Ethernet1/0/42 port link-mode bridge # interface Ethernet1/0/43 port link-mode bridge # interface Ethernet1/0/44 port link-mode bridge # interface Ethernet1/0/45 port link-mode bridge # interface Ethernet1/0/46 port link-mode bridge # interface Ethernet1/0/47 port link-mode bridge # interface Ethernet1/0/48 port link-mode bridge # interface GigabitEthernet1/0/49 port link-mode bridge port link-type trunk port trunk permit vlan 1 20 101 to 102 # interface GigabitEthernet1/0/50 port link-mode bridge port link-type trunk port trunk permit vlan 1 20 101 to 102 # interface GigabitEthernet1/0/51 port link-mode bridge description SYQ port link-type trunk port trunk permit vlan 1 20 101 to 102 # interface GigabitEthernet1/0/52 port link-mode bridge description BG port link-type trunk port trunk permit vlan 1 20 101 to 102 # pim # ip route-static 0.0.0.0 0.0.0.0 172.16.128.15 ip route-static 10.110.0.0 255.255.0.0 172.16.128.15 ip route-static 20.0.10.0 255.255.255.0 99.99.10.1 # info-center loghost 172.16.129.5 info-center logbuffer channel 7 # snmp-agent snmp-agent local-engineid 800007DB000FE25B24546877 snmp-agent community write BjL10Pri snmp-agent community read BjL10Pub snmp-agent sys-info contact kzzx-01 snmp-agent sys-info location kzzx-01 snmp-agent sys-info version all snmp-agent group v3 managerv3group write-view internet snmp-agent target-host trap address udp-domain 172.16.129.5 udp-port 5000 params securityname public snmp-agent usm-user v3 managerv3user managerv3group # load xml-configuration # load tr069-configuration # user-interface aux 0 user-interface vty 0 4 user privilege level 3 user-interface vty 5 15 # return
zhiliao_5gcO2 发表时间:2021-12-03
主要是这样贴出来您看着也太不方便了
version 7.1.070, Release 6318P01 # sysname HXNK-SS-01 # telnet server enable # irf mac-address persistent timer irf auto-update enable undo irf link-delay irf member 1 priority 1 # igmp-snooping # mac-address timer aging 15 # lldp global enable # password-recovery enable # vlan 1 # vlan 20 igmp-snooping enable # stp mode rstp stp global enable # interface NULL0 # interface Vlan-interface20 ip address 20.10.101.10 255.255.0.0 # interface GigabitEthernet1/0/28 port link-mode route # interface GigabitEthernet1/0/1 port link-mode bridge port access vlan 20 # interface GigabitEthernet1/0/2 port link-mode bridge port access vlan 20 # interface GigabitEthernet1/0/3 port link-mode bridge port access vlan 20 # interface GigabitEthernet1/0/4 port link-mode bridge port access vlan 20 # interface GigabitEthernet1/0/5 port link-mode bridge port access vlan 20 # interface GigabitEthernet1/0/6 port link-mode bridge port access vlan 20 # interface GigabitEthernet1/0/7 port link-mode bridge port access vlan 20 # interface GigabitEthernet1/0/8 port link-mode bridge port access vlan 20 # interface GigabitEthernet1/0/9 port link-mode bridge port access vlan 20 # interface GigabitEthernet1/0/10 port link-mode bridge port access vlan 20 # interface GigabitEthernet1/0/11 port link-mode bridge port access vlan 20 # interface GigabitEthernet1/0/12 port link-mode bridge port access vlan 20 # interface GigabitEthernet1/0/13 port link-mode bridge port access vlan 20 # interface GigabitEthernet1/0/14 port link-mode bridge port access vlan 20 # interface GigabitEthernet1/0/15 port link-mode bridge port access vlan 20 # interface GigabitEthernet1/0/16 port link-mode bridge port access vlan 20 # interface GigabitEthernet1/0/17 port link-mode bridge port access vlan 20 combo enable auto # interface GigabitEthernet1/0/18 port link-mode bridge port access vlan 20 combo enable auto # interface GigabitEthernet1/0/19 port link-mode bridge port access vlan 20 combo enable auto # interface GigabitEthernet1/0/20 port link-mode bridge port access vlan 20 combo enable auto # interface GigabitEthernet1/0/21 port link-mode bridge port access vlan 20 combo enable auto # interface GigabitEthernet1/0/22 port link-mode bridge port access vlan 20 combo enable auto # interface GigabitEthernet1/0/23 port link-mode bridge port access vlan 20 combo enable auto # interface GigabitEthernet1/0/24 port link-mode bridge port access vlan 20 combo enable auto # interface GigabitEthernet1/0/25 port link-mode bridge port link-type trunk port trunk permit vlan 1 20 101 to 102 # interface GigabitEthernet1/0/26 port link-mode bridge port link-type trunk port trunk permit vlan 1 20 101 to 102 # interface GigabitEthernet1/0/27 port link-mode bridge port link-type trunk port trunk permit vlan 1 20 101 to 102 # interface M-GigabitEthernet0/0/0 # scheduler logfile size 16 # line class aux user-role network-admin # line class usb user-role network-admin # line class vty user-role network-operator # line aux 0 user-role network-admin # line vty 0 4 user-role network-operator set authentication password hash $h$6$LO5tdjmB79gGRSO3$DxjOW8LoPGFU9fofvzNKXmsU3HvIwB1fPmT9wgiB1TDNsD92gpLH0WHWM9NIzzX/yEnPlCUSjSdJW/BgdpZqCw== # line vty 5 63 user-role network-operator # info-center logbuffer size 7 info-center loghost 172.16.129.5 # snmp-agent snmp-agent local-engineid 800063A2803CD2E5D9F85B00000001 snmp-agent sys-info version v3 snmp-agent group v3 managev3group privacy read-view test write-view test snmp-agent target-host trap address udp-domain 172.16.129.5 udp-port 5000 params securityname public snmp-agent mib-view included test system snmp-agent mib-view included test interfaces snmp-agent mib-view included test snmpMIB snmp-agent usm-user v3 ****** managev3group cipher authentication-mode sha $c$3$yPN+D9/whJUm46vci8ADcQzxBIZs933AbGb43jQmweYW/IR3bHo= privacy-mode aes128 $c$3$bX665waJPPuTAk9k1M0EiJKb7qInKqISV7s1p7VrWF6PzQ== snmp-agent trap enable arp snmp-agent trap enable radius snmp-agent trap enable stp snmp-agent trap enable syslog # ntp-service unicast-server 172.16.128.2 ntp-service unicast-server 172.16.128.4 # radius scheme system user-name-format without-domain # domain system # domain default enable system # role name level-0 description Predefined level-0 role # role name level-1 description Predefined level-1 role # role name level-2 description Predefined level-2 role # role name level-3 description Predefined level-3 role # role name level-4 description Predefined level-4 role # role name level-5 description Predefined level-5 role # role name level-6 description Predefined level-6 role # role name level-7 description Predefined level-7 role # role name level-8 description Predefined level-8 role # role name level-9 description Predefined level-9 role # role name level-10 description Predefined level-10 role # role name level-11 description Predefined level-11 role # role name level-12 description Predefined level-12 role # role name level-13 description Predefined level-13 role # role name level-14 description Predefined level-14 role # user-group system # return [HXNK-SS-01]
私聊截图发我吧
人间清醒 发表时间:2021-12-03
好的已经发给您了感谢您的帮助
