交换机报错、导致无法上网
2021-12-03提问
  • 1收藏,2688浏览
加油 一段
交换机一直报这个日志、这是BPDU导致的吧,开启stp边缘端口可用解决吗
ng or learning state. %Dec 3 18:25:00:781 2021 ZMT-CORE STP/4/STP_DISPUTE: Instance 0's port Bridge-Aggregation1 received an inferior BPDU from a designated port which is in forwarding or learning state. %Dec 3 18:25:02:820 2021 ZMT-CORE STP/4/STP_DISPUTE: Instance 0's port Bridge-Aggregation1 received an inferior BPDU from a designated port which is in forwarding or learning state. %Dec 3 18:25:04:808 2021 ZMT-CORE STP/4/STP_DISPUTE: Instance 0's port Bridge-Aggregation1 received an inferior BPDU from a designated port which is in forwarding or learning state. %Dec 3 18:25:06:817 2021 ZMT-CORE STP/4/STP_DISPUTE: Instance 0's port Bridge-Aggregation1 received an inferior BPDU from a designated port which is in forwarding or learning state. %Dec 3 18:25:08:815 2021 ZMT-CORE STP/4/STP_DISPUTE: Instance 0's port Bridge-Aggregation1 received an inferior BPDU from a designated port which is in forwarding or learning state. %Dec 3 18:25:10:861 2021 ZMT-CORE STP/4/STP_DISPUTE: Instance 0's port Bridge-Aggregation1 received an inferior BPDU from a designated port which is in forwarding or learning state. %Dec 3 18:25:12:808 2021 ZMT-CORE STP/4/STP_DISPUTE: Instance 0's port Bridge-Aggregation1 received an inferior BPDU from a designated port which is in forwarding or learning state. %Dec 3 18:25:14:860 2021 ZMT-CORE STP/4/STP_DISPUTE: Instance 0's port Bridge-Aggregation1 received an inferior BPDU from a designated port which is in forwarding or learning state. %Dec 3 18:25:16:858 2021 ZMT-CORE STP/4/STP_DISPUTE: Instance 0's port Bridge-Aggregation1 received an inferior BPDU from a designated port which is in forwarding or learning state. %Dec 3 18:25:18:860 2021 ZMT-CORE STP/4/STP_DISPUTE: Instance 0's port Bridge-Aggregation1 received an inferior BPDU from a designated port which is in forwarding or learning state. %Dec 3 18:25:20:857 2021 ZMT-CORE STP/4/STP_DISPUTE: Instance 0's port Bridge-Aggregation1 received an inferior BPDU from a designated port which is in forwarding or learning state. %D
lmm 八段
粉丝:5人 关注:2人
接口被dispute了,网络可能单通了
着急恢复的话,可以先关闭dispute保护,后面还是建议检查是否单通
(2)     关闭Dispute保护功能。
undo stp dispute-protection
缺省情况下,Dispute保护功能处于开启状态。
粉丝:22人 关注:11人
收到低优先级bpdu了,现场是不是环路了
粉丝:15人 关注:2人
dis int brief 看看哪些接口被阻塞了。
