S9505E :业务板卡自动重启
2021-12-07提问
  • 1收藏,943浏览
DSTM/1/DRV_DSTM: OAM, IRF member port Ten-GigabitEthernet1/2/0/1 does not work in receive direction.
DEVD/3/BOARD REBOOT: Chassis 1 slot 2 need to be rebooted automatically!
诊断重启原因hot-rebooted by BOARDSTATE     reason:BRD-STAT
请问是什么原因导致的呢?
粉丝:144人 关注:0人
您好, 确认日志中重启时有无出现“Slot X need to be rebooted automatically! Note:the operating device is sda0,it's not online ”提示信息,这种情况是不正常的。请更换单板并搜集故障信息并发送H3C技术支持人员分析
日志中有DEVM/2/BOARD_STATE_FAULT: Board state changes to FAULT on Chassis 1 Slot 2, type is LSR1XP16REB1. 但没有你说的那条, 之后就重启恢复了
zhiliao_7pvOk3 发表时间:2021-12-07
