Msr830 v5 设备无法多个连续端口映射
2021-12-07提问
  • 1收藏,690浏览
粉丝:1人 关注:9人
想做路由器15000-19000的端口映射
粉丝:232人 关注:0人
您好,参考
#进入设备公网接口
<H3C>system-view
[H3C]interface GigabitEthernet 0/0
#配置将内网服务器(IP地址为192.168.1.100)的15000-19000服务映射到公网接口,映射后的端口为15000-19000
[H3C-GigabitEthernet0/0]nat server protocol tcp global current-interface 15000 19000 inside 192.168.1.100 15000 19000
不让这么写啊
正在重新连接0 发表时间:2021-12-07
看我截图,写完内网地址后,还让着内网地址,不让多个端口啊
粉丝:111人 关注:1人
  进入系统视图。
(2)     进入接口视图。
interface interface-type interface-number
(3)     配置普通内部服务器。请至少选择其中一项进行配置。
¡     外网地址单一,未使用外网端口或外网端口单一。
nat server [ protocol pro-type ] global { global-address | current-interface | interface interface-type interface-number } [ global-port ] [ vpn-instance global-vpn-instance-name ] inside local-address [ local-port ] [ vpn-instance local-vpn-instance-name ] [ acl { ipv4-acl-number | name ipv4-acl-name } ] [ reversible ] [ vrrp virtual-router-id ] [ rule rule-name ] [ disable ] [ counting ] [ description text ]
¡     外网地址单一,外网端口连续。
nat server protocol pro-type global { global-address | current-interface | interface interface-type interface-number } global-port1 global-port2 [ vpn-instance global-vpn-instance-name ] inside { { local-address | local-address1 local-address2 } local-port | local-address local-port1 local-port2 } [ vpn-instance local-vpn-instance-name ] [ acl { ipv4-acl-number | name ipv4-acl-name } ] [ vrrp virtual-router-id ] [ rule rule-name ] [ disable ] [ counting ] [ description text ]
¡     外网地址连续,未使用外网端口。
nat server protocol pro-type global global-address1 global-address2  [ vpn-instance global-vpn-instance-name ] inside { local-address | local-address1 local-address2 } [ local-port ] [ vpn-instance local-vpn-instance-name ] [ acl { ipv4-acl-number | name ipv4-acl-name } ] [ vrrp virtual-router-id ] [ rule rule-name ] [ disable ] [ counting ] [ description text ]
¡     外网地址连续,外网端口单一。
nat server protocol pro-type global global-address1 global-address2 global-port [ vpn-instance global-vpn-instance-name ] inside { local-address [ local-port1 local-port2 ] | [ local-address | local-address1 local-address2 ] [ local-port ] } [ vpn-instance local-vpn-instance-name ] [ acl { ipv4-acl-number | name ipv4-acl-name } ] [ vrrp virtual-router-id ] [ rule rule-name ] [ disable ] [ counting ] [ description text ]
一个接口下可以配置多个普通内部服务器。
