h3c wa2610i-gn怎么刷胖AP,麻烦详细一点,我是新手
2018-07-20提问
  • 1收藏,2224浏览
请问一下,我想把fit刷成fat我该怎么去做,怎么操作。 新手小白一个,求大神指点
粉丝:13人 关注:11人
1.先准备好刷机线
2.给AP配置一个地址(瘦AP一般没有配地址)。同时给电脑配置一个和AP同网段的地址。确保电脑能够pingAP地址(保证电脑和AP处于同一网段)
3.下载tftpd32软件.把刷机文件放入tftpd32文件夹内
4.打开电脑上自带附件`通讯`超级终端(不会设置请百度)
以下是启动信息
* Copyright (c) 2004-2015 Hangzhou H3C Tech. Co., Ltd. All rights reserved.  *
* no decompiling or reverse-engineering shall be allowed.                    *
User interface con0 is available.
Please press ENTER.
System is starting...
Press Ctrl+D to access BASIC-BOOTWARE MENU
Booting Normal Extend BootWare....
The Extend BootWare is self-decompressing.........................Done!
*                 H3C WA2610E-GNP BootWare, Version 2.03                   *
Copyright (c) 2004-2013 Hangzhou H3C Technologies Co., Ltd.
Compiled Date       : Mar  5 2013
CPU Type            : AR9350   型号
CPU L1 Cache        : 32KB     还有L1缓存
CPU Clock Speed     : 560MHz    频率
Memory Type         : SDRAM
Memory Size         : 128MB     内存
BootWare Size       : 512KB
Flash Size          : 32MB     F闪存
CPLD Version        : 002
PCB Version         : Ver.F
BootWare Validating...
Press Ctrl+B to enter extended boot menu...     启动时按Ctrl+B
BootWare password: Not required. Please press Enter to continue.
Password recovery capability is enabled.
Note: The current operating device is flash
Enter < Storage Device Operation > to select device.
===========================<EXTEND-BOOTWARE MENU>===========================
|<1> Boot System                                                           |
|<2> Enter Serial SubMenu                                                  |
|<3> Enter Ethernet SubMenu                                                |
|<4> File Control                                                          |
|<5> Restore to Factory Default Configuration                              |
|<6> Skip Current System Configuration                                     |
|<7> BootWare Operation Menu                                               |
|<8> Clear Super Password                                                  |
|<9> Storage Device Operation                                              |
|<0> Reboot        |
Ctrl+C: Display Copyright
Ctrl+F: Format File System         按Ctrl+F删除原flash中文件
Enter your choice(0-9):
Warning:All files on flash will be lost! Are you sure to format? [Y/N]Y.....          按Y
Format success.
|<1> Boot System                                                           |
|<4> File Control                                                          |
|<0> Reboot        |
Enter your choice(0-9): 3         按3
==========================<Enter Ethernet SubMenu>==========================
|Note:the operating device is flash                                        |
|<1> Download Application Program To SDRAM And Run                         |
|<2> Update Main Application File                                          |
|<3> Update Backup Application File                                        |
|<4> Update Secure Application File                                        |
|<5> Modify Ethernet Parameter                                             |
|<0> Exit To Main Menu                                                     |
|<Ensure The Parameter Be Modified Before Downloading!>                    |
Enter your choice(0-5): 5      按5
==========================<ETHERNET PARAMETER SET>==========================
|Note:       '.' = Clear field.                                            |
|            '-' = Go to previous field.                                   |
|          Ctrl+D = Quit.                                                  |
Protocol (FTP or TFTP) :TFTP       检查以下IP和文件名是否正确,如果不正确请
Load File Name         :wa2600test.bin .    更改.使用命令'.'或'-' 更改后回车
Load File Name         : wa2600a_fat.bin
Target File Name       :wa2600test.bin .     文件名必须是wa2600a_fat.bin
Target File Name       : wa2600a_fat.bin
Server IP Address      :192.168.0.5     电脑IP地址
Local IP Address       :192.168.0.4      AP地址
Gateway IP Address     :0.0.0.0
Enter your choice(0-5): 2      按2  更新主应用程序文件
Loading.....................................................................
...................................Done!
9091072 bytes downloaded!
Updating File flash:/wa2600a_fat.bin........................................
Enter your choice(0-5): 0     按0  退出主菜单
|<1> Boot System                                                           |
|<4> File Control                                                          |
|<0> Reboot        |
Enter your choice(0-9): 4      按4  文件控制
===============================<File CONTROL>===============================
|<1> Display All File(s)                                                   |
|<2> Set Application File type                                             |
|<3> Delete File                                                           |
Enter your choice(0-3): 1     按1  检查有没有wa2600a_fat.bin文件
Display all file(s) in flash:
'M' = MAIN      'B' = BACKUP      'S' = SECURE      'N/A' = NOT ASSIGNED
|NO. Size(B)   Time                 Type   Name                            |
|1   9091072   Aug/08/2008 20:00:00 M      wa2600a_fat.bin                 |
|<3> Delete File                                                           |
Enter your choice(0-3): 0     按0
|<1> Boot System                                                           |
|<4> File Control                                                          |
|<0> Reboot        |
Enter your choice(0-9): 0    按0  重启
CPU Type            : AR9350
CPU L1 Cache        : 32KB
Memory Type         : SDRAM
Memory Size         : 128MB
Flash Size          : 32MB
CPLD Version        : 002
PCB Version         : Ver.F
         以下正在安装不要动它,抽枝寂莫等会...
Starting to get the main application file--flash:/wa2600a_fat.bin!..........
The main application file is self-decompressing.............................
Done!
Extend BootWare Version is not equal,updating? [Y/N]
Updating Extend BootWare............Done!
Basic BootWare Version is not equal,updating? [Y/N]
Updating Basic BootWare..............Done!
BootWare updated,System is rebooting now.
*                 H3C WA2610E-GNP BootWare, Version 3.03                   *
Copyright (c) 2004-2014 Hangzhou H3C Technologies Co., Ltd.
Compiled Date       : Sep  1 2014
CPU Type            : AR9350
CPU L1 Cache        : 32KB
Memory Type         : SDRAM
Memory Size         : 128MB
Memory Speed        : 480MHz
Flash Size          : 32MB
CPLD Version        : 002
PCB Version         : Ver.F
Check net params crc error, use the default value
Normal Extend BootWare Version is newer than Backup Extend BootWare!
Begin to Update the Backup Extend BootWare...............Done!
Done!
System application is starting...
Startup configuration file does not exist.
                启动成功了,可以进入WEB管理
              用户名:admin  密码:h3capadmin
Press ENTER to get started.
<WA2610E-GNP>
#Nov 16 13:35:09:730 2011 WA2610E-GNP SHELL/4/LOGIN:
Trap 1.3.6.1.4.1.2011.10.2.2.1.1.3.0.1<h3cLogIn>: login from Console
%Nov 16 13:35:09:730 2011 WA2610E-GNP SHELL/5/SHELL_LOGIN: Console logged in from con0.
<WA2610E-GNP>sys
[WA2610E-GNP]
[WA2610E-GNP]sys
% Ambiguous command found at '^' position.
[WA2610E-GNP]
[WA2610E-GNP]
#Nov 16 13:37:02:403 2011 WA2610E-GNP SHELL/4/LOGIN:
Trap 1.3.6.1.4.1.2011.10.2.2.1.1.3.0.1<h3cLogIn>:admin login from Web
请问一下,那个刷机的文件我去哪里下啊
zhiliao_OFKCe 发表时间:2018-07-20
刷机的文件在官网可以下载。这里搜索:http://www.h3c.com/cn/Service/Document_Software/Software_Download/
颠倒梦想 发表时间:2018-07-20
粉丝:28人 关注:15人
那个bin的文件我去哪里下啊
官网就有,找不到问问400
王老二 发表时间:2018-07-20
