v7本地转发加集中认证Portal问题
2018-07-20提问
  • 1收藏,2122浏览
WX5510E升级为V7做本地转发加集中认证,现在可以弹出认证页面,但显示向设备发送请求超时,控制器去掉portal认证可以正常上网,麻烦大侠们帮忙看看配置,另外我想一个SSID多个VLAN是不是在控制器AP中进行绑定就可以,另外如何做HTTPS重定向。
控制器配置:
[AC]disp cur
 version 7.1.064, Release 5221
 sysname AC
 telnet server enable
 irf mac-address persistent timer
 irf auto-update enable
 irf auto-merge enable
 irf member 1 priority 1
 password-recovery enable
vlan 1
vlan 182
irf-port 1
wlan service-template 1
 ssid h3c
 vlan 182
 client forwarding-location ap
 portal enable method direct
 portal domain dm1
 portal bas-ip 192.168.82.200
 portal apply web-server newpt
 service-template enable
wlan service-template 2
 ssid ceshi
 vlan 70
interface Bridge-Aggregation1
 port link-type trunk
 port trunk permit vlan all
interface NULL0
interface Vlan-interface1
 ip address 192.168.1.252 255.255.255.0
interface Vlan-interface182
 ip address 192.168.82.200 255.255.255.0
 port link-aggregation group 1
 ip route-static 0.0.0.0 0 192.168.1.254
 undo info-center logfile enable
 snmp-agent
 snmp-agent local-engineid 800063A28094282E0001D000000001
 snmp-agent community read rzgrea
 snmp-agent community write rzgwr
 snmp-agent sys-info version all
 snmp-agent target-host trap address udp-domain 192.168.1.251 params securityname rzgrea v2c
 radius session-control enable
radius scheme rs1
 primary authentication 192.168.1.251
 primary accounting 192.168.1.251
 key authentication cipher $c$3$m7hLCu9ujJs41d94AV3aanjSqMRpiw==
 key accounting cipher $c$3$2r5wtRWd+cAZ9Yt2iuylEh2D7BC+bg==
 user-name-format without-domain
domain dm1
 authorization-attribute idle-cut 15 1024
 authentication portal radius-scheme rs1
 authorization portal radius-scheme rs1
 accounting portal radius-scheme rs1
domain system
 domain default enable system
role name level-0
 description Predefined level-0 role
user-group system
 ftp server enable
 portal host-check enable
 portal free-rule 1 source ip any destination ip 192.168.0.0 255.255.0.0
 portal free-rule 2 source ip any destination ip 129.0.0.0 255.255.255.0
 portal free-rule 3 source ip any destination ip 202.102.152.3 255.255.255.255
 portal free-rule 6 source interface Bridge-Aggregation1
portal web-server newpt
 url http://192.168.1.251:8080/portal
 server-type cmcc
 url-parameter ssid ssid
 url-parameter wlanacname value ac
 url-parameter wlanuserip source-address
portal server newpt
 ip 192.168.1.251 key cipher $c$3$uy+/Inv2RP5Vr79J76LS/gKlKXefxg==
 server-type cmcc
 ip http enable
 ip https enable
wlan global-configuration
wlan ap-group default-group
 vlan 1
wlan ap ceshi-1 model WA2620-AGN-S
 serial-id 219801A0H6914AQ02283
 map-configuration cfa0:/apcfg.txt
 radio 1
  radio enable
  service-template 1 vlan 182
 radio 2
  radio enable
return
核心配置:
int VLAN 182
ip add 192.168.82.254 24
然后这个VLAN 起DHCP分配客户端地址
int vlan 181
ip add 192.168.81.254
这个VLAN起dhcp利用OPTION43注册到控制器
int vlan 1
ip add 192.168.1.254 24
IMC配置:​
粉丝:148人 关注:3人
我觉得你在radius scheme里面加个nas ip就可以了;V7 AC默认支持https重定向不需要特殊配置,配置参考如下:
http://download.h3c.com.cn/download.do?id=3475738
加上也不行呢
古道飘零 发表时间:2018-07-20
nas ip应该写哪个地址?82.100 还是1.252
这两个加上都不行
回复古道飘零:
看你配置的 IMC上添加的接入设备是80.200这个地址啊,radius 的nas ip必须是和iMC写的接入设备IP地址要一样才可以
肉夹馍再了解一下 发表时间:2018-07-20
粉丝:28人 关注:15人
加上去看看
配置里有这个命令
