刷机包下载完了,放到tftpd32文件夹内(wa2600a_fat.bin),目录选择的就是tftpd32文件夹,地址是本机服务器地址,别的都没有设置,然后按操作一步一步的操作,在查看有没有文件镜像的时候 就是空。 我是哪里配置错误了吗。
(0)
是boot下面操作吗?默认是ftp,要改成tftp
最好能有相关记录才能判断问题。
(0)
日志里面报错是Connection received from 192.168.0.253 on port 3992 [20/07 14:07:22.217] Read request for file <wa2600a_fat.bin>. Mode octet [20/07 14:07:22.232] OACK: <timeout=3,> [20/07 14:07:22.232] Using local port 57242 [20/07 14:07:22.232] File <wa2600a_fat.bin> : error 10054 in system call recv 远程主机强迫关闭了一个现有的连接。 [20/07 14:07:22.310] Connection received from 192.168.0.253 on port 3992 [20/07 14:07:25.222] Read request for file <wa2600a_fat.bin>. Mode octet [20/07 14:07:25.222] OACK: <timeout=3,> [20/07 14:07:25.222] Using local port 57244 [20/07 14:07:25.222] File <wa2600a_fat.bin> : error 10054 in system call recv 远程主机强迫关闭了一个现有的连接。 [20/07 14:07:25.346] Connection received from 192.168.0.253 on port 3992 [20/07 14:07:28.226] Read request for file <wa2600a_fat.bin>. Mode octet [20/07 14:07:28.226] OACK: <timeout=3,> [20/07 14:07:28.226] Using local port 57245 [20/07 14:07:28.226] File <wa2600a_fat.bin> : error 10054 in system call recv 远程主机强迫关闭了一个现有的连接。 [20/07 14:07:28.288] Connection received from 192.168.0.253 on port 3992 [20/07 14:07:31.224] Read request for file <wa2600a_fat.bin>. Mode octet [20/07 14:07:31.224] OACK: <timeout=3,> [20/07 14:07:31.224] Using local port 57246 [20/07 14:07:31.224] File <wa2600a_fat.bin> : error 10054 in system call recv 远程主机强迫关闭了一个现有的连接。 [20/07 14:07:31.287] Connection received from 192.168.0.253 on port 3992 [20/07 14:07:34.217] Read request for file <wa2600a_fat.bin>. Mode octet [20/07 14:07:34.233] OACK: <timeout=3,> [20/07 14:07:34.233] Using local port 57247 [20/07 14:07:34.233] File <wa2600a_fat.bin> : error 10054 in system call recv 远程主机强迫关闭了一个现有的连接。 [20/07 14:07:34.295] Connection received from 192.168.0.253 on port 3992 [20/07 14:07:37.232] Read request for file <wa2600a_fat.bin>. Mode octet [20/07 14:07:37.234] OACK: <timeout=3,> [20/07 14:07:37.234] Using local port 57248 [20/07 14:07:37.235] File <wa2600a_fat.bin> : error 10054 in system call recv 远程主机强迫关闭了一个现有的连接。 [20/07 14:07:37.286] Connection received from 192.168.0.253 on port 3992 [20/07 14:07:40.222] Read request for file <wa2600a_fat.bin>. Mode octet [20/07 14:07:40.222] OACK: <timeout=3,> [20/07 14:07:40.222] Using local port 63440 [20/07 14:07:40.222] File <wa2600a_fat.bin> : error 10054 in system call recv 远程主机强迫关闭了一个现有的连接。 [20/07 14:07:40.290] Connection received from 192.168.0.253 on port 3992 [20/07 14:07:43.233] Read request for file <wa2600a_fat.bin>. Mode octet [20/07 14:07:43.235] OACK: <timeout=3,> [20/07 14:07:43.235] Using local port 63442 [20/07 14:07:43.235] File <wa2600a_fat.bin> : error 10054 in system call recv 远程主机强迫关闭了一个现有的连接。 [20/07 14:07:43.335] 这样的
问题是我这个过保了, 打也没有用吧
网线插好了吗,tftp配置好。
(0)
网线插了啊,在update main application file的时候 在tftp上面能看到下载,但是没有进度
确定你的邮箱还未认证,请认证邮箱或绑定手机后进行当前操作
我这都已经试过了 还是一样。 哎
