TFTP客服端和服务端都需要怎么配置,为什么我连接的始终是不成功!
2018-07-20提问
  • 1收藏,1842浏览
 **************************************************************************** * * * H3C WA2610i-GN BootWare, Version 3.04 * * * **************************************************************************** Copyright (c) 2004-2014 Hangzhou H3C Technologies Co., Ltd. Compiled Date : Sep 15 2014 CPU Type : AR9350 CPU L1 Cache : 32KB CPU Clock Speed : 560MHz Memory Type : SDRAM Memory Size : 128MB Memory Speed : 480MHz BootWare Size : 512KB Flash Size : 32MB CPLD Version : 004 PCB Version : Ver.E BootWare Validating... Press Ctrl+B to enter extended boot menu... BootWare password: Not required. Please press Enter to continue. Password recovery capability is enabled. Note: The current operating device is flash Enter < Storage Device Operation > to select device. ===========================<EXTEND-BOOTWARE MENU>=========================== |<1> Boot System | |<2> Enter Serial SubMenu | |<3> Enter Ethernet SubMenu | |<4> File Control | |<5> Restore to Factory Default Configuration | |<6> Skip Current System Configuration | |<7> BootWare Operation Menu | |<8> Clear Super Password | |<9> Storage Device Operation | |<0> Reboot | ============================================================================ Ctrl+C: Display Copyright Ctrl+F: Format File System Enter your choice(0-9): Warning:All files on flash will be lost! Are you sure to format? [Y/N]Y..... ............................................................................ ............................................................................ ............................................................................ .......................... Format success. ===========================<EXTEND-BOOTWARE MENU>=========================== |<1> Boot System | |<2> Enter Serial SubMenu | |<3> Enter Ethernet SubMenu | |<4> File Control | |<5> Restore to Factory Default Configuration | |<6> Skip Current System Configuration | |<7> BootWare Operation Menu | |<8> Clear Super Password | |<9> Storage Device Operation | |<0> Reboot | ============================================================================ Ctrl+C: Display Copyright Ctrl+F: Format File System Enter your choice(0-9): 3 ==========================<Enter Ethernet SubMenu>========================== |Note:the operating device is flash | |<1> Download Application Program To SDRAM And Run | |<2> Update Main Application File | |<3> Update Backup Application File | |<4> Update Secure Application File | |<5> Modify Ethernet Parameter | |<0> Exit To Main Menu | |<Ensure The Parameter Be Modified Before Downloading!> | ============================================================================ Enter your choice(0-5): 5 ==========================<ETHERNET PARAMETER SET>========================== |Note: '.' = Clear field. | | '-' = Go to previous field. | | Ctrl+D = Quit. | ============================================================================ Protocol (FTP or TFTP) :tftp Load File Name :'.' = WA2600A-FAT.bin :wa2600a_fat.bin Target File Name :'.' = wa2600a-fat.bin :wa2600a_fat.bin Server IP Address :'.' = 192.168.0.246 192.168.0.246 Local IP Address :'.' = 192.168.0.253 192.168.0.253 Gateway IP Address :0.0.0.0 ==========================<Enter Ethernet SubMenu>========================== |Note:the operating device is flash | |<1> Download Application Program To SDRAM And Run | |<2> Update Main Application File | |<3> Update Backup Application File | |<4> Update Secure Application File | |<5> Modify Ethernet Parameter | |<0> Exit To Main Menu | |<Ensure The Parameter Be Modified Before Downloading!> | ============================================================================ Enter your choice(0-5): 2 Loading...Failed! ==========================<Enter Ethernet SubMenu>========================== |Note:the operating device is flash | |<1> Download Application Program To SDRAM And Run | |<2> Update Main Application File | |<3> Update Backup Application File | |<4> Update Secure Application File | |<5> Modify Ethernet Parameter | |<0> Exit To Main Menu | |<Ensure The Parameter Be Modified Before Downloading!> | ============================================================================ Enter your choice(0-5): 0 ===========================<EXTEND-BOOTWARE MENU>=========================== |<1> Boot System | |<2> Enter Serial SubMenu | |<3> Enter Ethernet SubMenu | |<4> File Control | |<5> Restore to Factory Default Configuration | |<6> Skip Current System Configuration | |<7> BootWare Operation Menu | |<8> Clear Super Password | |<9> Storage Device Operation | |<0> Reboot | ============================================================================ Ctrl+C: Display Copyright Ctrl+F: Format File System Enter your choice(0-9): 4 ===============================<File CONTROL>=============================== |Note:the operating device is flash | |<1> Display All File(s) | |<2> Set Application File type | |<3> Delete File | |<0> Exit To Main Menu | ============================================================================ Enter your choice(0-3): 1 Display all file(s) in flash: 'M' = MAIN 'B' = BACKUP 'S' = SECURE 'N/A' = NOT ASSIGNED ============================================================================ |NO. Size(B) Time Type Name | ============================================================================ ===============================<File CONTROL>=============================== |Note:the operating device is flash | |<1> Display All File(s) | |<2> Set Application File type | |<3> Delete File | |<0> Exit To Main Menu | ============================================================================ Enter your choice(0-3): 1 Display all file(s) in flash: 'M' = MAIN 'B' = BACKUP 'S' = SECURE 'N/A' = NOT ASSIGNED ============================================================================ |NO. Size(B) Time Type Name | ============================================================================ ===============================<File CONTROL>=============================== |Note:the operating device is flash | |<1> Display All File(s) | |<2> Set Application File type | |<3> Delete File | |<0> Exit To Main Menu | ============================================================================ Enter your choice(0-3): 0 ===========================<EXTEND-BOOTWARE MENU>=========================== |<1> Boot System | |<2> Enter Serial SubMenu | |<3> Enter Ethernet SubMenu | |<4> File Control | |<5> Restore to Factory Default Configuration | |<6> Skip Current System Configuration | |<7> BootWare Operation Menu | |<8> Clear Super Password | |<9> Storage Device Operation | |<0> Reboot | ============================================================================ Ctrl+C: Display Copyright Ctrl+F: Format File System Enter your choice(0-9): 3 ==========================<Enter Ethernet SubMenu>========================== |Note:the operating device is flash | |<1> Download Application Program To SDRAM And Run | |<2> Update Main Application File | |<3> Update Backup Application File | |<4> Update Secure Application File | |<5> Modify Ethernet Parameter | |<0> Exit To Main Menu | |<Ensure The Parameter Be Modified Before Downloading!> | ============================================================================ Enter your choice(0-5): 5 ==========================<ETHERNET PARAMETER SET>========================== |Note: '.' = Clear field. | | '-' = Go to previous field. | | Ctrl+D = Quit. | ============================================================================ Protocol (FTP or TFTP) :tftp Load File Name :wa2600a_fat.bin : Target File Name :wa2600a_fat.bin : Server IP Address :192.168.0.246 Local IP Address :192.168.0.253 Gateway IP Address :0.0.0.0 ==========================<Enter Ethernet SubMenu>========================== |Note:the operating device is flash | |<1> Download Application Program To SDRAM And Run | |<2> Update Main Application File | |<3> Update Backup Application File | |<4> Update Secure Application File | |<5> Modify Ethernet Parameter | |<0> Exit To Main Menu | |<Ensure The Parameter Be Modified Before Downloading!> | ============================================================================ Enter your choice(0-5): 2 Loading...Failed! ==========================<Enter Ethernet SubMenu>========================== |Note:the operating device is flash | |<1> Download Application Program To SDRAM And Run | |<2> Update Main Application File | |<3> Update Backup Application File | |<4> Update Secure Application File | |<5> Modify Ethernet Parameter | |<0> Exit To Main Menu | |<Ensure The Parameter Be Modified Before Downloading!> | ============================================================================ Enter your choice(0-5): 2 Loading...Failed! ==========================<Enter Ethernet SubMenu>========================== |Note:the operating device is flash | |<1> Download Application Program To SDRAM And Run | |<2> Update Main Application File | |<3> Update Backup Application File | |<4> Update Secure Application File | |<5> Modify Ethernet Parameter | |<0> Exit To Main Menu | |<Ensure The Parameter Be Modified Before Downloading!> | ============================================================================ Enter your choice(0-5): 2 Loading...Failed! ==========================<Enter Ethernet SubMenu>========================== |Note:the operating device is flash | |<1> Download Application Program To SDRAM And Run | |<2> Update Main Application File | |<3> Update Backup Application File | |<4> Update Secure Application File | |<5> Modify Ethernet Parameter | |<0> Exit To Main Menu | |<Ensure The Parameter Be Modified Before Downloading!> | ============================================================================ Enter your choice(0-5): 2 Loading...Failed! ==========================<Enter Ethernet SubMenu>========================== |Note:the operating device is flash | |<1> Download Application Program To SDRAM And Run | |<2> Update Main Application File | |<3> Update Backup Application File | |<4> Update Secure Application File | |<5> Modify Ethernet Parameter | |<0> Exit To Main Menu | |<Ensure The Parameter Be Modified Before Downloading!> | ============================================================================ Enter your choice(0-5): 2 Loading...Failed! ==========================<Enter Ethernet SubMenu>========================== |Note:the operating device is flash | |<1> Download Application Program To SDRAM And Run | |<2> Update Main Application File | |<3> Update Backup Application File | |<4> Update Secure Application File | |<5> Modify Ethernet Parameter | |<0> Exit To Main Menu | |<Ensure The Parameter Be Modified Before Downloading!> | ============================================================================ Enter your choice(0-5): 2 Loading...Failed! ==========================<Enter Ethernet SubMenu>========================== |Note:the operating device is flash | |<1> Download Application Program To SDRAM And Run | |<2> Update Main Application File | |<3> Update Backup Application File | |<4> Update Secure Application File | |<5> Modify Ethernet Parameter | |<0> Exit To Main Menu | |<Ensure The Parameter Be Modified Before Downloading!> | ============================================================================ Enter your choice(0-5): 2 Loading...Failed! ==========================<Enter Ethernet SubMenu>========================== |Note:the operating device is flash | |<1> Download Application Program To SDRAM And Run | |<2> Update Main Application File | |<3> Update Backup Application File | |<4> Update Secure Application File | |<5> Modify Ethernet Parameter | |<0> Exit To Main Menu | |<Ensure The Parameter Be Modified Before Downloading!> | ============================================================================ Enter your choice(0-5): 2 Loading...Failed! ==========================<Enter Ethernet SubMenu>========================== |Note:the operating device is flash | |<1> Download Application Program To SDRAM And Run | |<2> Update Main Application File | |<3> Update Backup Application File | |<4> Update Secure Application File | |<5> Modify Ethernet Parameter | |<0> Exit To Main Menu | |<Ensure The Parameter Be Modified Before Downloading!> | ============================================================================ Enter your choice(0-5): 2 Loading...Failed! ==========================<Enter Ethernet SubMenu>========================== |Note:the operating device is flash | |<1> Download Application Program To SDRAM And Run | |<2> Update Main Application File | |<3> Update Backup Application File | |<4> Update Secure Application File | |<5> Modify Ethernet Parameter | |<0> Exit To Main Menu | |<Ensure The Parameter Be Modified Before Downloading!> | ============================================================================ Enter your choice(0-5): 2 Loading...Failed! ==========================<Enter Ethernet SubMenu>========================== |Note:the operating device is flash | |<1> Download Application Program To SDRAM And Run | |<2> Update Main Application File | |<3> Update Backup Application File | |<4> Update Secure Application File | |<5> Modify Ethernet Parameter | |<0> Exit To Main Menu | |<Ensure The Parameter Be Modified Before Downloading!> | ============================================================================ Enter your choice(0-5): 2 Loading...Failed! ==========================<Enter Ethernet SubMenu>========================== |Note:the operating device is flash | |<1> Download Application Program To SDRAM And Run | |<2> Update Main Application File | |<3> Update Backup Application File | |<4> Update Secure Application File | |<5> Modify Ethernet Parameter | |<0> Exit To Main Menu | |<Ensure The Parameter Be Modified Before Downloading!> | ============================================================================ Enter your choice(0-5): ==========================<Enter Ethernet SubMenu>========================== |Note:the operating device is flash | |<1> Download Application Program To SDRAM And Run | |<2> Update Main Application File | |<3> Update Backup Application File | |<4> Update Secure Application File | |<5> Modify Ethernet Parameter | |<0> Exit To Main Menu | |<Ensure The Parameter Be Modified Before Downloading!> | ============================================================================ Enter your choice(0-5): 2 Loading...Failed! ==========================<Enter Ethernet SubMenu>========================== |Note:the operating device is flash | |<1> Download Application Program To SDRAM And Run | |<2> Update Main Application File | |<3> Update Backup Application File | |<4> Update Secure Application File | |<5> Modify Ethernet Parameter | |<0> Exit To Main Menu | |<Ensure The Parameter Be Modified Before Downloading!> | ============================================================================ Enter your choice(0-5): 2 Loading...Failed! ==========================<Enter Ethernet SubMenu>========================== |Note:the operating device is flash | |<1> Download Application Program To SDRAM And Run | |<2> Update Main Application File | |<3> Update Backup Application File | |<4> Update Secure Application File | |<5> Modify Ethernet Parameter | |<0> Exit To Main Menu | |<Ensure The Parameter Be Modified Before Downloading!> | ============================================================================ Enter your choice(0-5): 2 Loading...Failed! ==========================<Enter Ethernet SubMenu>========================== |Note:the operating device is flash | |<1> Download Application Program To SDRAM And Run | |<2> Update Main Application File | |<3> Update Backup Application File | |<4> Update Secure Application File | |<5> Modify Ethernet Parameter | |<0> Exit To Main Menu | |<Ensure The Parameter Be Modified Before Downloading!> | ============================================================================ Enter your choice(0-5): 2 Loading...Failed! ==========================<Enter Ethernet SubMenu>========================== |Note:the operating device is flash | |<1> Download Application Program To SDRAM And Run | |<2> Update Main Application File | |<3> Update Backup Application File | |<4> Update Secure Application File | |<5> Modify Ethernet Parameter | |<0> Exit To Main Menu | |<Ensure The Parameter Be Modified Before Downloading!> | ============================================================================ Enter your choice(0-5): 2 Loading...Failed! ==========================<Enter Ethernet SubMenu>========================== |Note:the operating device is flash | |<1> Download Application Program To SDRAM And Run | |<2> Update Main Application File | |<3> Update Backup Application File | |<4> Update Secure Application File | |<5> Modify Ethernet Parameter | |<0> Exit To Main Menu | |<Ensure The Parameter Be Modified Before Downloading!> | ============================================================================ Enter your choice(0-5):
以上这是我的AP日志,麻烦帮我看看,我是哪里弄错了嘛
粉丝:10人 关注:0人
换行是多么重要!!!
提示:Enter your choice(0-5): 2 Loading...Failed!
1、AP和AC之间网线没有连接
2、电脑防火墙\杀毒软件是否关闭?主要对TFTP软件有限制,建议关闭
我不连接AC 不可以刷软件嘛? 我现在就是2台电脑一个H3C AP一起刷的,没用到AP
zhiliao_OFKCe 发表时间:2018-07-20
没用到ac控制器啊
原意是表达电脑和AP有没有连接,码字码错了。但是你这个反应过激了吧?
巡山的大王 发表时间:2018-07-23
zhiliao_OFKCe 知了小白
Connection received from 192.168.0.253 on port 3843 [20/07 15:58:17.279] Read request for file <wa2600a_fat.bin>. Mode octet [20/07 15:58:17.279] OACK: <timeout=3,> [20/07 15:58:17.279] Using local port 60446 [20/07 15:58:17.279] File <wa2600a_fat.bin> : error 10054 in system call recv 远程主机强迫关闭了一个现有的连接。 [20/07 15:58:17.341] Connection received from 192.168.0.253 on port 3843 [20/07 15:58:20.278] Read request for file <wa2600a_fat.bin>. Mode octet [20/07 15:58:20.278] OACK: <timeout=3,> [20/07 15:58:20.278] Using local port 60448 [20/07 15:58:20.278] File <wa2600a_fat.bin> : error 10054 in system call recv 远程主机强迫关闭了一个现有的连接。 [20/07 15:58:20.341] Connection received from 192.168.0.253 on port 3843 [20/07 15:58:23.280] Read request for file <wa2600a_fat.bin>. Mode octet [20/07 15:58:23.280] OACK: <timeout=3,> [20/07 15:58:23.280] Using local port 60450 [20/07 15:58:23.280] File <wa2600a_fat.bin> : error 10054 in system call recv 远程主机强迫关闭了一个现有的连接。 [20/07 15:58:23.343] Connection received from 192.168.0.253 on port 3843 [20/07 15:58:26.280] Read request for file <wa2600a_fat.bin>. Mode octet [20/07 15:58:26.280] OACK: <timeout=3,> [20/07 15:58:26.280] Using local port 60451 [20/07 15:58:26.280] File <wa2600a_fat.bin> : error 10054 in system call recv 远程主机强迫关闭了一个现有的连接。 [20/07 15:58:26.343] Connection received from 192.168.0.253 on port 3843 [20/07 15:58:29.279] Read request for file <wa2600a_fat.bin>. Mode octet [20/07 15:58:29.279] OACK: <timeout=3,> [20/07 15:58:29.279] Using local port 60452 [20/07 15:58:29.279] File <wa2600a_fat.bin> : error 10054 in system call recv 远程主机强迫关闭了一个现有的连接。 [20/07 15:58:29.342] Connection received from 192.168.0.253 on port 3843 [20/07 15:58:32.284] Read request for file <wa2600a_fat.bin>. Mode octet [20/07 15:58:32.284] OACK: <timeout=3,> [20/07 15:58:32.284] Using local port 60453 [20/07 15:58:32.284] File <wa2600a_fat.bin> : error 10054 in system call recv 远程主机强迫关闭了一个现有的连接。 [20/07 15:58:32.347] Connection received from 192.168.0.253 on port 3843 [20/07 15:58:35.283] Read request for file <wa2600a_fat.bin>. Mode octet [20/07 15:58:35.283] OACK: <timeout=3,> [20/07 15:58:35.283] Using local port 60454 [20/07 15:58:35.283] File <wa2600a_fat.bin> : error 10054 in system call recv 远程主机强迫关闭了一个现有的连接。 [20/07 15:58:35.345] Connection received from 192.168.0.253 on port 3843 [20/07 15:58:38.287] Read request for file <wa2600a_fat.bin>. Mode octet [20/07 15:58:38.287] OACK: <timeout=3,> [20/07 15:58:38.287] Using local port 60455 [20/07 15:58:38.287] File <wa2600a_fat.bin> : error 10054 in system call recv 远程主机强迫关闭了一个现有的连接。 [20/07 15:58:38.349] Connection received from 192.168.0.253 on port 3843 [20/07 15:58:41.277] Read request for file <wa2600a_fat.bin>. Mode octet [20/07 15:58:41.293] OACK: <timeout=3,> [20/07 15:58:41.293] Using local port 60456 [20/07 15:58:41.293] File <wa2600a_fat.bin> : error 10054 in system call recv 远程主机强迫关闭了一个现有的连接。 [20/07 15:58:41.355] Connection received from 192.168.0.253 on port 3843 [20/07 15:58:44.282] Read request for file <wa2600a_fat.bin>. Mode octet [20/07 15:58:44.282] OACK: <timeout=3,> [20/07 15:58:44.282] Using local port 60457 [20/07 15:58:44.282] File <wa2600a_fat.bin> : error 10054 in system call recv 远程主机强迫关闭了一个现有的连接。 [20/07 15:58:44.344] Connection received from 192.168.0.253 on port 3843 [20/07 15:58:47.286] Read request for file <wa2600a_fat.bin>. Mode octet [20/07 15:58:47.286] OACK: <timeout=3,> [20/07 15:58:47.286] Using local port 60458 [20/07 15:58:47.286] File <wa2600a_fat.bin> : error 10054 in system call recv 远程主机强迫关闭了一个现有的连接。 [20/07 15:58:47.348] Connection received from 192.168.0.253 on port 1602 [20/07 15:59:08.639] Read request for file <wa2600a_fat.bin>. Mode octet [20/07 15:59:08.639] OACK: <timeout=3,> [20/07 15:59:08.639] Using local port 57106 [20/07 15:59:08.639] File <wa2600a_fat.bin> : error 10054 in system call recv 远程主机强迫关闭了一个现有的连接。 [20/07 15:59:08.701] Connection received from 192.168.0.253 on port 1602 [20/07 15:59:11.633] Read request for file <wa2600a_fat.bin>. Mode octet [20/07 15:59:11.633] OACK: <timeout=3,> [20/07 15:59:11.633] Using local port 57107 [20/07 15:59:11.633] File <wa2600a_fat.bin> : error 10054 in system call recv 远程主机强迫关闭了一个现有的连接。 [20/07 15:59:11.696] Connection received from 192.168.0.253 on port 1602 [20/07 15:59:14.639] Read request for file <wa2600a_fat.bin>. Mode octet [20/07 15:59:14.639] OACK: <timeout=3,> [20/07 15:59:14.639] Using local port 57108 [20/07 15:59:14.639] File <wa2600a_fat.bin> : error 10054 in system call recv 远程主机强迫关闭了一个现有的连接。 [20/07 15:59:14.701] Connection received from 192.168.0.253 on port 1602 [20/07 15:59:17.644] Read request for file <wa2600a_fat.bin>. Mode octet [20/07 15:59:17.644] OACK: <timeout=3,> [20/07 15:59:17.644] Using local port 57109 [20/07 15:59:17.644] File <wa2600a_fat.bin> : error 10054 in system call recv 远程主机强迫关闭了一个现有的连接。 [20/07 15:59:17.706] Connection received from 192.168.0.253 on port 1602 [20/07 15:59:20.642] Read request for file <wa2600a_fat.bin>. Mode octet [20/07 15:59:20.642] OACK: <timeout=3,> [20/07 15:59:20.642] Using local port 57110 [20/07 15:59:20.642] File <wa2600a_fat.bin> : error 10054 in system call recv 远程主机强迫关闭了一个现有的连接。 [20/07 15:59:20.705] Connection received from 192.168.0.253 on port 1602 [20/07 15:59:23.632] Read request for file <wa2600a_fat.bin>. Mode octet [20/07 15:59:23.632] OACK: <timeout=3,> [20/07 15:59:23.632] Using local port 57111 [20/07 15:59:23.632] File <wa2600a_fat.bin> : error 10054 in system call recv 远程主机强迫关闭了一个现有的连接。 [20/07 15:59:23.694] Connection received from 192.168.0.253 on port 1602 [20/07 15:59:26.638] Read request for file <wa2600a_fat.bin>. Mode octet [20/07 15:59:26.638] OACK: <timeout=3,> [20/07 15:59:26.638] Using local port 57112 [20/07 15:59:26.638] File <wa2600a_fat.bin> : error 10054 in system call recv 远程主机强迫关闭了一个现有的连接。 [20/07 15:59:26.700] Connection received from 192.168.0.253 on port 1602 [20/07 15:59:29.644] Read request for file <wa2600a_fat.bin>. Mode octet [20/07 15:59:29.644] OACK: <timeout=3,> [20/07 15:59:29.644] Using local port 57113 [20/07 15:59:29.644] File <wa2600a_fat.bin> : error 10054 in system call recv 远程主机强迫关闭了一个现有的连接。 [20/07 15:59:29.707] Connection received from 192.168.0.253 on port 1602 [20/07 15:59:32.631] Read request for file <wa2600a_fat.bin>. Mode octet [20/07 15:59:32.647] OACK: <timeout=3,> [20/07 15:59:32.647] Using local port 57114 [20/07 15:59:32.647] File <wa2600a_fat.bin> : error 10054 in system call recv 远程主机强迫关闭了一个现有的连接。 [20/07 15:59:32.709] Connection received from 192.168.0.253 on port 1602 [20/07 15:59:35.637] Read request for file <wa2600a_fat.bin>. Mode octet [20/07 15:59:35.637] OACK: <timeout=3,> [20/07 15:59:35.637] Using local port 57115 [20/07 15:59:35.637] File <wa2600a_fat.bin> : error 10054 in system call recv 远程主机强迫关闭了一个现有的连接。 [20/07 15:59:35.700] Connection received from 192.168.0.253 on port 1602 [20/07 15:59:38.638] Read request for file <wa2600a_fat.bin>. Mode octet [20/07 15:59:38.638] OACK: <timeout=3,> [20/07 15:59:38.638] Using local port 57510 [20/07 15:59:38.638] File <wa2600a_fat.bin> : error 10054 in system call recv 远程主机强迫关闭了一个现有的连接。 [20/07 15:59:38.700] Connection received from 192.168.0.253 on port 2877 [20/07 16:06:47.736] Read request for file <wa2600a_fat.bin>. Mode octet [20/07 16:06:47.738] OACK: <timeout=3,> [20/07 16:06:47.738] Using local port 49525 [20/07 16:06:47.738] File <wa2600a_fat.bin> : error 10054 in system call recv 远程主机强迫关闭了一个现有的连接。 [20/07 16:06:47.789] Connection received from 192.168.0.253 on port 2877 [20/07 16:06:50.732] Read request for file <wa2600a_fat.bin>. Mode octet [20/07 16:06:50.732] OACK: <timeout=3,> [20/07 16:06:50.732] Using local port 49526 [20/07 16:06:50.732] File <wa2600a_fat.bin> : error 10054 in system call recv 远程主机强迫关闭了一个现有的连接。 [20/07 16:06:50.794] Connection received from 192.168.0.253 on port 2877 [20/07 16:06:53.735] Read request for file <wa2600a_fat.bin>. Mode octet [20/07 16:06:53.737] OACK: <timeout=3,> [20/07 16:06:53.737] Using local port 49527 [20/07 16:06:53.737] File <wa2600a_fat.bin> : error 10054 in system call recv 远程主机强迫关闭了一个现有的连接。 [20/07 16:06:53.788] Connection received from 192.168.0.253 on port 2877 [20/07 16:06:56.736] Read request for file <wa2600a_fat.bin>. Mode octet [20/07 16:06:56.738] OACK: <timeout=3,> [20/07 16:06:56.738] Using local port 49529 [20/07 16:06:56.738] File <wa2600a_fat.bin> : error 10054 in system call recv 远程主机强迫关闭了一个现有的连接。 [20/07 16:06:56.789] Connection received from 192.168.0.253 on port 2877 [20/07 16:06:59.731] Read request for file <wa2600a_fat.bin>. Mode octet [20/07 16:06:59.731] OACK: <timeout=3,> [20/07 16:06:59.731] Using local port 49532 [20/07 16:06:59.731] File <wa2600a_fat.bin> : error 10054 in system call recv 远程主机强迫关闭了一个现有的连接。 [20/07 16:06:59.794] Connection received from 192.168.0.253 on port 2877 [20/07 16:07:02.728] Read request for file <wa2600a_fat.bin>. Mode octet [20/07 16:07:02.728] OACK: <timeout=3,> [20/07 16:07:02.728] Using local port 49533 [20/07 16:07:02.728] File <wa2600a_fat.bin> : error 10054 in system call recv 远程主机强迫关闭了一个现有的连接。 [20/07 16:07:02.790] Connection received from 192.168.0.253 on port 2877 [20/07 16:07:05.727] Read request for file <wa2600a_fat.bin>. Mode octet [20/07 16:07:05.727] OACK: <timeout=3,> [20/07 16:07:05.727] Using local port 49534 [20/07 16:07:05.727] File <wa2600a_fat.bin> : error 10054 in system call recv 远程主机强迫关闭了一个现有的连接。 [20/07 16:07:05.789] Connection received from 192.168.0.253 on port 2877 [20/07 16:07:08.724] Read request for file <wa2600a_fat.bin>. Mode octet [20/07 16:07:08.724] OACK: <timeout=3,> [20/07 16:07:08.724] Using local port 49535 [20/07 16:07:08.724] File <wa2600a_fat.bin> : error 10054 in system call recv 远程主机强迫关闭了一个现有的连接。 [20/07 16:07:08.786] Connection received from 192.168.0.253 on port 2877 [20/07 16:07:11.736] Read request for file <wa2600a_fat.bin>. Mode octet [20/07 16:07:11.736] OACK: <timeout=3,> [20/07 16:07:11.736] Using local port 50490 [20/07 16:07:11.736] File <wa2600a_fat.bin> : error 10054 in system call recv 远程主机强迫关闭了一个现有的连接。 [20/07 16:07:11.798] Connection received from 192.168.0.253 on port 2877 [20/07 16:07:14.737] Read request for file <wa2600a_fat.bin>. Mode octet [20/07 16:07:14.739] OACK: <timeout=3,> [20/07 16:07:14.739] Using local port 58394 [20/07 16:07:14.739] File <wa2600a_fat.bin> : error 10054 in system call recv 远程主机强迫关闭了一个现有的连接。 [20/07 16:07:14.790] Connection received from 192.168.0.253 on port 2877 [20/07 16:07:17.738] Read request for file <wa2600a_fat.bin>. Mode octet [20/07 16:07:17.738] OACK: <timeout=3,> [20/07 16:07:17.738] Using local port 58395 [20/07 16:07:17.738] File <wa2600a_fat.bin> : error 10054 in system call recv 远程主机强迫关闭了一个现有的连接。 [20/07 16:07:17.800]
