MSR系列路由器IPSEC VPN主模式配置
2022-01-04提问
  • 1收藏,941浏览
如图,两台路由器配置ipsec vpn,接口及相关配置后,发现ike sa都无法起来,如下为两台设备关键配置:
MSR36-20_1:
int g0/0
ip add 100.1.1.1 24
int g0/1
ip add 192.168.10.254 24
acl adv name ipsec_ip
rule permit ip source 192.168.10.0 0.0.0.255 dest 192.168.20.0 0.0.0.255
acl adv name ipsec_ip_nonat
rule deny ip source 192.168.10.0 0.0.0.255 dest 192.168.20.0 0.0.0.255
ike proso 1
ike ikechain
pre address 100.1.1.2 key simple 123456
ike profile 1
keychain 1
proso  1
exchange main
match remote ident  address  100.1.1.2
local-ident  address 100.1.1.1
ipsec trans  1
esp auth  sha1
esp en  aes-cbc-128
ipsec policy ipsec 1 isakm
trans 1
ike profi  1
sec  acl ipsec_ip
local-address  100.1.1.1
remote-address 100.1.1.2
int g0/0
ipsec apply policy ipsec_ip
nat outbound ipsec_ip_nonat
MSR36-20_2:
int g0/0
ip add 100.1.1.2 24
int g0/1
ip add 192.168.20.254 24
ike proso 1
ike keychain  1
pre address 100.1.1.1  key simple 123456
ike profile 1
keychain 1
prosol 1
exchan  main
match remote iden  address 100.1.1.1
local-ident  address 100.1.1.2
ipsec trans   1
esp  auth  sha1
esp en aes-cbc-128
ipsec policy ipsec isakm
ike profil 1
sec acl ipse_ip
trans 1
local-address 100.1.1.2
remote-address 100.1.1.1
int g0/0
粉丝:111人 关注:1人
RT1的ipsec policy绑定关系错误
int g0/0
是写错了,实际是策略名称是ipsec
zhiliao_RBXodU 发表时间:2022-01-04
粉丝:25人 关注:7人
路由写了吗?
就是ip route-static 192.168.20.0 24 100.1.1.2,对端同理。没有路由的话流量不会引到g0/0口上,也就不会触发IPSEC。
我的配置:
<R1>dis cur
 version 7.1.064, Release 0821P11
 sysname R1
 system-working-mode standard
 xbar load-single
 password-recovery enable
 lpu-type f-series
vlan 1
interface Serial1/0
interface Serial2/0
interface Serial3/0
interface Serial4/0
interface NULL0
interface GigabitEthernet0/0
 port link-mode route
 combo enable copper
 ip address 100.1.1.1 255.255.255.0
 nat outbound name ipsec_ip_nonat
interface GigabitEthernet0/1
 combo enable copper
 ip address 192.168.10.254 255.255.255.0
interface GigabitEthernet0/2
 combo enable copper
interface GigabitEthernet5/0
 combo enable copper
interface GigabitEthernet5/1
 combo enable copper
interface GigabitEthernet6/0
 combo enable copper
interface GigabitEthernet6/1
 combo enable copper
 scheduler logfile size 16
line class aux
 user-role network-operator
line class console
 user-role network-admin
line class tty
line class vty
line aux 0
line con 0
line vty 0 63
acl advanced name ipsec_ip
 rule 0 permit ip source 192.168.10.0 0.0.0.255 destination 192.168.20.0 0.0.0.255
acl advanced name ipsec_ip_nonat
 rule 0 deny ip source 192.168.10.0 0.0.0.255 destination 192.168.20.0 0.0.0.255
domain system
 domain default enable system
role name level-0
 description Predefined level-0 role
role name level-1
 description Predefined level-1 role
role name level-2
 description Predefined level-2 role
role name level-3
 description Predefined level-3 role
role name level-4
 description Predefined level-4 role
role name level-5
 description Predefined level-5 role
role name level-6
 description Predefined level-6 role
role name level-7
 description Predefined level-7 role
role name level-8
 description Predefined level-8 role
role name level-9
 description Predefined level-9 role
role name level-10
 description Predefined level-10 role
role name level-11
 description Predefined level-11 role
role name level-12
 description Predefined level-12 role
role name level-13
 description Predefined level-13 role
role name level-14
 description Predefined level-14 role
user-group system
ipsec transform-set 1
 esp encryption-algorithm aes-cbc-128
 esp authentication-algorithm sha1
ipsec policy ipsec_ip 1 isakmp
 transform-set 1
 security acl name ipsec_ip
 ike-profile 1
ike profile 1
 keychain 1
 local-identity address 100.1.1.1
 match remote identity address 100.1.1.2 255.255.255.255
 proposal 1
ike proposal 1
ike keychain 1
 pre-shared-key address 100.1.1.2 255.255.255.255 key cipher $c$3$a6koxtNTlbJO2YI4f1peqpunVoLiFSqVWQ==
return
<R2>display current-configuration
 sysname R2
 xbar load-single
 lpu-type f-series
vlan 1
interface Serial1/0
interface Serial2/0
interface Serial3/0
interface Serial4/0
interface NULL0
 combo enable copper
 ip address 100.1.1.2 255.255.255.0
 combo enable copper
 ip address 192.168.20.254 255.255.255.0
 combo enable copper
 combo enable copper
 combo enable copper
 combo enable copper
 combo enable copper
line class aux
line class console
line class tty
line class vty
line aux 0
line con 0
line vty 0 63
 ip route-static 192.168.10.0 24 100.1.1.1
 rule 0 permit ip source 192.168.20.0 0.0.0.255 destination 192.168.10.0 0.0.0.255
 rule 0 deny ip source 192.168.20.0 0.0.0.255 destination 192.168.10.0 0.0.0.255
domain system
role name level-0
role name level-1
role name level-2
role name level-3
role name level-4
role name level-5
role name level-6
role name level-7
role name level-8
role name level-9
role name level-10
role name level-11
role name level-12
role name level-13
role name level-14
user-group system
 transform-set 1
 ike-profile 1
ike profile 1
 keychain 1
 local-identity address 100.1.1.2
 match remote identity address 100.1.1.1 255.255.255.255
 proposal 1
ike proposal 1
ike keychain 1
 pre-shared-key address 100.1.1.1 255.255.255.255 key cipher $c$3$g1KcjNgswvhbd+WAqzeWWHLy2zR6KigPlQ==
return
重新配置了,也试着做了路由,还是不行
zhiliao_RBXodU 发表时间:2022-01-05
有哪位大佬实际在模拟器上配置成功过嘛
这个原理很简单,主要是仔细,你那个配置抄得让人想吐血。。。。。。
奇怪的流量 发表时间:2022-01-05
我上面答案改了,就是你的配置参数,你自己核对吧。
粉丝:226人 关注:0人
您好,参考这个案例
MSR V5平台和MSR V7平台路由器IPSec VPN对接典型配置(主模式)
1 配置需求或说明
1.1 适用产品系列
本案例提到MSR V5平台路由器是指Comware V5 软件平台MSR WiNet系列路由器,如MSR830-WiNet MSR 830-10-WiNet MSR 930-WiNet MSR 930-10-WiNet MSR 930-WiNet-W MSR 2600-10-WiNet
本案例提到MSR V7平台路由器是指Comware V7平台的MSR830-WiNet系列路由器,如MSR830-10BEI-WiNet MSR830-6EI-WiNet MSR830-5BEI-WiNet MSR830-6BHI-WiNet MSR830-10BHI-WiNet
1.2 配置需求及实现效果
MSR V5路由器外网G0/1地址1.1.1.1(模拟运营商公网固定地址环境MSR V7路由器外网G0/1地址2.2.2.2(模拟运营商公网固定地址环境,两个路由器外网口地址之间路由可达可以互相ping通。要实现MSR V5所在的内网(192.168.1.0/24)与MSR V7路由器所在的内网(172.16.1.0/24)之间的数据流进行安全保护,实现两端网终端通过IPsec VPN 隧道进行互访。
2 组网图
3 配置步骤
3.1 配置路由器基本上网
#路由器基本上网配置省略,MSR V5路由器上网具体设置步骤请参考“2.1.2 路由器外网使用固定IP地址上网配置方法章节中“MSR830[930][2600]系列路由器基本上网(静态IP)命令行配置(V5)案例,MSR V7路由器上网具体设置步骤请参考“2.1.2 路由器外网使用固定IP地址上网配置方法章节中“MSR830-WiNet系列路由器基本上网(静态IP)命令行配置(V7)案例
3.2 设置MSR V5路由器IPSEC VPN
# 配置一个访问控制列表3000,定义由子网192.168.1.0/24去子网172.16.1.0/24的数据流。
<H3C>system-view
[H3C]acl number 3000
[H3C-acl-adv-3000]rule 0 permit ip source 192.168.1.0 0.0.0.255 destination 172.16.1.0 0.0.0.255
[H3C-acl-adv-3000]quit
#配置公网口NAT要关联的ACl 3001,作用IPSec感兴趣流从NAT转换的数据deny掉,防止IPSec数据流被NAT优先转换
[H3C]acl number 3001
[H3C-acl-adv-3001]rule 0 deny ip source 192.168.1.0 0.0.0.255 destination 172.16.1.0 0.0.0.255
[H3C-acl-adv-3001]rule 1 permit ip
[H3C-acl-adv-3001]quit
创建一条IKE提议1,指定IKE提议使用的认证算法为MD5,加密算法为3des-cbc
[H3C]ike proposal 1
[H3C-ike-proposal-1]authentication-algorithm md5
[H3C-ike-proposal-1]encryption-algorithm 3des-cbc
[H3C-ike-proposal-1]quit
配置IPSec安全提议v5,配置ESP协议采用的加密算法为3des,采用的认证算法md5
[H3C]ipsec transform-set v5
[H3C-ipsec-transform-set-v5]encapsulation-mode tunnel
[H3C-ipsec-transform-set-v5]transform esp
[H3C-ipsec-transform-set-v5]esp encryption-algorithm 3des
[H3C-ipsec-transform-set-v5]esp authentication-algorithm md5
[H3C-ipsec-transform-set-v5]quit
# 创建IKE对等体v5,预共享密钥为123456,引用之前创建的IKE安全提议1,配置对端地址为对端公网接口地址2.2.2.2,本地地址为本端的公网接口地址1.1.1.1
[H3C]ike peer v5
[H3C-ike-peer-v5]pre-shared-key 123456
[H3C-ike-peer-v5]proposal 1
[H3C-ike-peer-v5]remote-address 1.1.1.
[H3C-ike-peer-v5]local-address  2.2.2.2
[H3C-ike-peer-v5]quit
创建一条IPSec安全策略v5,协商方式为isakmp。引用之前创建的感兴趣数据流ACL3000,引用之前创建的对等体v5,引用之前的IPSec安全提议v5
[H3C]ipsec policy v5 1 isakmp
[H3C-ipsec-policy-isakmp-v5-1]security acl 3000
[H3C-ipsec-policy-isakmp-v5-1]ike-peer v5
[H3C-ipsec-policy-isakmp-v5-1]transform-set v5
[H3C-ipsec-policy-isakmp-v5-1]quit
#设置外网口NAT转换的时候关联ACL 3001 (如果之前已经在外网口配置了 nat outbound,需要先undo掉)IPSec安全策略v5应用在外网接口
[H3C]interface GigabitEthernet 0/1
 [H3C-GigabitEthernet0/1]undo natbound
[H3C-GigabitEthernet0/1]nat outbound 3001
[H3C-GigabitEthernet0/1]ipsec policy v5
[H3C-GigabitEthernet0/1]quit
3.3 设置MSR V7路由器IPSEC VPN
# 配置一个访问控制列表,定义由子网172.16.1.0/24去子网192.168.1.0/24的数据流。
<H3C>system-view
[H3C]acl advanced 3000
[H3C-acl-ipv4-adv-3000]rule 0 permit ip source 172.16.1.0 0.0.0.255 destination 192.168.1.0 0.0.0.255
[H3C-acl-ipv4-adv-3000]quit
[H3C]acl advanced 3001
[H3C-acl-ipv4-adv-3001]rule 0 deny ip source 172.16.1.0 0.0.0.255 destination 192.168.1.0 0.0.0.255
[H3C-acl-ipv4-adv-3001]rule 1 permit ip
 [H3C]ike proposal 1
#创建并配置IKE keychain,名称为v7。
[H3C]ike keychain v7
#配置对端IP地址为1.1.1.1,使用的预共享密钥为明文123456
[H3C-ike-keychain-v7]pre-shared-key address 1.1.1.1 255.255.255.0 key simple 123456
[H3C-ike-keychain-v7]quit
创建并配置IKE profile,名称为v7,引用上面配置的keychain v7配置本地地址为本端的公网接口地址2.2.2.2,对端地址为对端公网接口地址1.1.1.1,引用之前配置IKE提议1
[H3C]ike profile v7
[H3C-ike-profile-v7]keychain v7
[H3C-ike-profile-v7]local-identity address 2.2.2.2
[H3C-ike-profile-v7]match remote identity address 1.1.1.255.255.255.0
[H3C-ike-profile-v7]proposal 1
[H3C-ike-profile-v7]quit
配置IPsec安全提议v7,ESP协议采用的加密算法为3des-cbc,认证算法为md5
[H3C]ipsec transform-set v7
[H3C-ipsec-transform-set-v7]encapsulation-mode tunnel
[H3C-ipsec-transform-set-v7]esp encryption-algorithm 3des-cbc
[H3C-ipsec-transform-set-v7]esp authentication-algorithm md5
#创建IPsec安全策略,名称为v7,序列号为1,设置对端地址为对端公网地址1.1.1.1,引用之前创建的ACL3000,引用之前创建的IKE profile v7,引用之前的IPSec安全提议v7
[H3C]ipsec policy v7 1 isakmp
[H3C-ipsec-policy-isakmp-v7-1]remote-address 1.1.1.1
[H3C-ipsec-policy-isakmp-v7-1]security acl 3000
[H3C-ipsec-policy-isakmp-v7-1]transform-set v7
[H3C-ipsec-policy-isakmp-v7-1]ike-profile v7
[H3C-ipsec-policy-isakmp-v7-1]quit
#设置外网口NAT转换的时候关联ACL 3001 (如果之前已经在外网口配置了 nat outbound,需要先undo掉)IPSec安全策略v7应用在外网接口
[H3C-GigabitEthernet0/1]undo nat outbound
[H3C-GigabitEthernet0/1]ipsec apply policy v7
3.4 验证配置结果
#MSR V7路由器上带源ping MSR V5路由器内网网关地址
第一阶段ike sa还是无法起来,开启debug ike 也没看到相关日志,就好像没任何流量一样,手动rest ike sa也试过不行
可以了,谢了老哥
