查看交换机端口实时流量是什么命令
2022-01-06提问
  • 2收藏,8239浏览
粉丝:0人 关注:2人
查看交换机端口实时流量是什么命令
查看交换机端口实时流量是什么命令
5 个回答
粉丝:3人 关注:1人
display interface g1/0/X里面可以查看接口的最近五分钟的流量情况
1.1.10  display interface
display interface命令用来显示接口的运行状态和相关信息。
display interface [ interface-type [ interface-number ] ] [ brief [ description | down ] ]
interface-type:指定接口类型。
interface-number:指定接口编号。
description:用来显示用户配置的接口的全部描述信息。如果某接口的描述信息超过27个字符,不指定该参数时,只显示描述信息中的前27个字符,超出部分不显示。
如果不指定接口类型和接口编号,则显示所有接口的信息。
如果仅指定接口类型,则显示所有该类型接口的信息。
# 查看二层以太网接口GigabitEthernet1/0/1的运行状态和相关信息。
<Sysname> display interface gigabitethernet 1/0/1
Current state: DOWN
Line protocol state: DOWN
IP packet frame type: Ethernet II, hardware address: 000c-2963-b767
Description: GigabitEthernet1/0/1 Interface
Bandwidth: 100000 kbps
Loopback is not set
Media type is twisted pair, port hardware type is 1000_BASE_T_AN_SFP
Flow-control is not enabled
Maximum frame length: 9216
Allow jumbo frame to pass
Broadcast max-ratio: 100%
Multicast max-ratio: 100%
Unicast max-ratio: 100%
PVID: 1
MDI type: Automdix
Port link-type: Access
 Tagged VLANs:   None
 UnTagged VLANs: 1
Port priority: 2
Last link flapping: 6 hours 39 minutes 25 seconds
Last clearing of counters:  14:34:09 Tue 11/01/2011
Current system time:2018-08-10 14:58:27
Last time when physical state changed to up:-
Last time when physical state changed to down:2018-08-10 14:57:58
 Peak input rate: 0 bytes/sec, at 2013-07-17 22:06:19
 Peak output rate: 0 bytes/sec, at 2013-07-17 22:06:19
 Last 300 seconds input:  0 packets/sec 0 bytes/sec -%
 Last 300 seconds output:  0 packets/sec 0 bytes/sec -%
 Input (total):  0 packets, 0 bytes
 Input (normal):  0 packets, 0 bytes
          0 CRC, 0 frame, 0 overruns, 0 aborts
          0 ignored, 0 parity errors
 Output (normal): 0 packets, 0 bytes
 Output: 0 output errors, 0 underruns, 0 buffer failures
          0 lost carrier, 0 no carrier
zhiliao_EfXDcz 知了小白
粉丝:1人 关注:1人
dis counters rate inbound interface GigabitEthernet 0/1
粉丝:22人 关注:11人
没有查看实时,能看到都是一定统计时间内的
二段
display counter rate inboud/Outbound interface
z6Kl9 九段
粉丝:67人 关注:2人
dis counters rate inbound interface g1/0/1
dis counters rate o interface g1/0/1
