H3C S3100V2-26TP-EI交换机异常断电后进不去系统
2018-07-26提问
  • 1收藏,1358浏览
H3C S3100V2-26TP-EI交换机异常断电后进不去系统,用超级终端连接后显示
Password recovery capability is enabled.
 BOOT MENU
 1. Download application file to flash
2. Select application file to boot
 3. Display all files in flash
4. Delete file from flash
5. Restore to factory default configuration
6. Enter BootRom upgrade menu
7. Skip current system configuration
8. Reserved 9. Set switch startup mode
 0. Reboot Ctrl+F: Format File System Ctrl+P: Skip Super Password Ctrl+R: Download application to SDRAM and Run Ctrl+Z: Access EXTEND-ASSISTANT MENU Ctrl+C: Display Copyright
请问怎么处理 谢谢
断电重启后,还不行的话,打一下售后电话吧。
