设备重启,板卡报错?EVB_NO_LICENSE?麻烦给看下这什么问题
%Jan 19 14:00:50:529 2022 GA_S7506E-2 SYSLOG/6/SYSLOG_RESTART: System restarted -- H3C Comware Software.
%Jan 19 14:13:13:485 2022 GA_S7506E-2 DEV/2/BOARD_STATE_FAULT: Board state changed to Fault on chassis 1 slot 0, type is unknown.
%Jan 19 14:13:13:488 2022 GA_S7506E-2 DEV/2/BOARD_STATE_FAULT: Board state changed to Fault on chassis 1 slot 1, type is unknown.
%Jan 19 14:13:13:490 2022 GA_S7506E-2 DEV/2/BOARD_STATE_FAULT: Board state changed to Fault on chassis 1 slot 7, type is unknown.
%Jan 19 14:13:13:493 2022 GA_S7506E-2 DEV/2/BOARD_STATE_FAULT: Board state changed to Fault on chassis 1 slot 8, type is unknown. %Jan 19 14:13:13:496 2022 GA_S7506E-2 DEV/2/BOARD_STATE_FAULT: Board state changed to Fault on chassis 2 slot 0, type is unknown.
%Jan 19 14:13:13:498 2022 GA_S7506E-2 DEV/2/BOARD_STATE_FAULT: Board state changed to Fault on chassis 2 slot 1, type is unknown. %Jan 19 14:13:13:501 2022 GA_S7506E-2 DEV/2/BOARD_STATE_FAULT: Board state changed to Fault on chassis 2 slot 6, type is unknown.
%Jan 19 14:13:13:505 2022 GA_S7506E-2 DEV/2/BOARD_STATE_FAULT: Board state changed to Fault on chassis 2 slot 7, type is unknown.
%Jan 19 14:13:13:508 2022 GA_S7506E-2 DEV/2/BOARD_STATE_FAULT: Board state changed to Fault on chassis 2 slot 8, type is unknown.
%Jan 19 14:14:06:536 2022 GA_S7506E-2 EVB/4/EVB_NO_LICENSE: The feature EVB has no available license.
%Jan 19 14:14:06:664 2022 GA_S7506E-2 DEV/5/BOARD_STATE_NORMAL: Board state changed to Normal on chassis 1 slot 8, type is LSQM1FAB06C0.
%Jan 19 14:14:07:011 2022 GA_S7506E-2 DEV/5/BOARD_STATE_NORMAL: Board state changed to Normal on chassis 2 slot 0, type is LSQM2GT24PTSSC0.
%Jan 19 14:14:07:186 2022 GA_S7506E-2 DEV/5/BOARD_STATE_NORMAL: Board state changed to Normal on chassis 2 slot 8, type is LSQM1FAB06C0.
%Jan 19 14:14:07:308 2022 GA_S7506E-2 DEV/5/BOARD_STATE_NORMAL: Board state changed to Normal on chassis 1 slot 1, type is LSQM2GT24PTSSC0.
%Jan 19 14:14:07:551 2022 GA_S7506E-2 DEV/5/BOARD_STATE_NORMAL: Board state changed to Normal on chassis 2 slot 1, type is LSQM2GT24PTSSC0.
%Jan 19 14:14:07:624 2022 GA_S7506E-2 DEV/5/BOARD_STATE_NORMAL: Board state changed to Normal on chassis 1 slot 0, type is LSQM2GT24PTSSC0.
%Jan 19 14:14:08:945 2022 GA_S7506E-2 BFD/4/BFD_MAD_INTERFACE_CHANGE_STATE: BFD MAD function enabled on Vlan-interface4000 changed to the faulty state.
%Jan 19 14:14:11:785 2022 GA_S7506E-2 DEV/5/BOARD_STATE_NORMAL: Board state changed to Normal on chassis 1 slot 7, type is LSQM1MPU06B0.
%Jan 19 14:14:11:895 2022 GA_S7506E-2 DEV/5/BOARD_STATE_NORMAL: Board state changed to Normal on chassis 2 slot 7, type is LSQM1MPU06B0.
%Jan 19 14:14:12:108 2022 GA_S7506E-2 DEV/5/BOARD_STATE_NORMAL: Board state changed to Normal on chassis 2 slot 6, type is LSQM1MPU06B0.
设备重启,板卡报错?EVB_NO_LICENSE?麻烦给看下这什么问题 %Jan 19 14:00:50:529 2022 GA_S7506E-2 SYSLOG/6/SYSLOG_RESTART: System restarted -- H3C Comware Software. %Jan 19 14:13:13:485 2022 GA_S7506E-2 DEV/2/BOARD_STATE_FAULT: Board state changed to Fault on chassis 1 slot 0, type is unknown. %Jan 19 14:13:13:488 2022 GA_S7506E-2 DEV/2/BOARD_STATE_FAULT: Board state changed to Fault on chassis 1 slot 1, type is unknown. %Jan 19 14:13:13:490 2022 GA_S7506E-2 DEV/2/BOARD_STATE_FAULT: Board state changed to Fault on chassis 1 slot 7, type is unknown. %Jan 19 14:13:13:493 2022 GA_S7506E-2 DEV/2/BOARD_STATE_FAULT: Board state changed to Fault on chassis 1 slot 8, type is unknown. %Jan 19 14:13:13:496 2022 GA_S7506E-2 DEV/2/BOARD_STATE_FAULT: Board state changed to Fault on chassis 2 slot 0, type is unknown. %Jan 19 14:13:13:498 2022 GA_S7506E-2 DEV/2/BOARD_STATE_FAULT: Board state changed to Fault on chassis 2 slot 1, type is unknown. %Jan 19 14:13:13:501 2022 GA_S7506E-2 DEV/2/BOARD_STATE_FAULT: Board state changed to Fault on chassis 2 slot 6, type is unknown. %Jan 19 14:13:13:505 2022 GA_S7506E-2 DEV/2/BOARD_STATE_FAULT: Board state changed to Fault on chassis 2 slot 7, type is unknown. %Jan 19 14:13:13:508 2022 GA_S7506E-2 DEV/2/BOARD_STATE_FAULT: Board state changed to Fault on chassis 2 slot 8, type is unknown. %Jan 19 14:14:06:536 2022 GA_S7506E-2 EVB/4/EVB_NO_LICENSE: The feature EVB has no available license. %Jan 19 14:14:06:664 2022 GA_S7506E-2 DEV/5/BOARD_STATE_NORMAL: Board state changed to Normal on chassis 1 slot 8, type is LSQM1FAB06C0. %Jan 19 14:14:07:011 2022 GA_S7506E-2 DEV/5/BOARD_STATE_NORMAL: Board state changed to Normal on chassis 2 slot 0, type is LSQM2GT24PTSSC0. %Jan 19 14:14:07:186 2022 GA_S7506E-2 DEV/5/BOARD_STATE_NORMAL: Board state changed to Normal on chassis 2 slot 8, type is LSQM1FAB06C0. %Jan 19 14:14:07:308 2022 GA_S7506E-2 DEV/5/BOARD_STATE_NORMAL: Board state changed to Normal on chassis 1 slot 1, type is LSQM2GT24PTSSC0. %Jan 19 14:14:07:551 2022 GA_S7506E-2 DEV/5/BOARD_STATE_NORMAL: Board state changed to Normal on chassis 2 slot 1, type is LSQM2GT24PTSSC0. %Jan 19 14:14:07:624 2022 GA_S7506E-2 DEV/5/BOARD_STATE_NORMAL: Board state changed to Normal on chassis 1 slot 0, type is LSQM2GT24PTSSC0. %Jan 19 14:14:08:945 2022 GA_S7506E-2 BFD/4/BFD_MAD_INTERFACE_CHANGE_STATE: BFD MAD function enabled on Vlan-interface4000 changed to the faulty state. %Jan 19 14:14:11:785 2022 GA_S7506E-2 DEV/5/BOARD_STATE_NORMAL: Board state changed to Normal on chassis 1 slot 7, type is LSQM1MPU06B0. %Jan 19 14:14:11:895 2022 GA_S7506E-2 DEV/5/BOARD_STATE_NORMAL: Board state changed to Normal on chassis 2 slot 7, type is LSQM1MPU06B0. %Jan 19 14:14:12:108 2022 GA_S7506E-2 DEV/5/BOARD_STATE_NORMAL: Board state changed to Normal on chassis 2 slot 6, type is LSQM1MPU06B0.
你这是设备重启了
这句呢?未知错误。。。 DEV/2/BOARD_STATE_FAULT: Board state changed to Fault on chassis 1 slot 0, type is unknown.
重启需要时间板卡才能起来
冗余电源,有一组电源坏了,设备重启。。。比较奇怪
