IPSEC VPN建立不成功
2022-01-20提问
  • 2收藏,1820浏览
F1000-C8150的防火墙和对端建IPSEC VPN,两边都是固定IP的,一直建立不起来,打开DEBUG信息,发现一直只有出去的加密数据,收不到inbound方向的解密数据,是不是对端没有问应,导致IPSEC VPN建 立不起来
粉丝:45人 关注:5人
(1)IPSEC的建立第一步首先是公网能通;
(2)然后两边的配置需要高度的镜像。
看你的配置没啥问题,公网通了以后,debug ike all renote 139.159.222.86,对端出发我们一下,看看这个信息。
4 个回答
粉丝:5人 关注:1人
有可能,协商是两端的事情,需要对端也看下
粉丝:22人 关注:11人
估计对端没有回
粉丝:154人 关注:1人
参考官网IPSEC排错点穴神功
http://www.h3c.com/cn/d_201411/921533_30005_0.htm
对端公网iP139.159.222.86是通的,下面是debug ike all renote 139.159.222.86内容和IKE SA、IPSEC SA两个阶段都有
<FW>debug ike all remote-address 139.159.222.86
This command is CPU intensive and might affect ongoing services. Are you sure you want to continue? [Y/N]:y
<FW>t d
The current terminal is enabled to display debugging logs.
<FW>t m
<FW>sys
[FW]in en
[FW]
[FW]
[FW]*Jan 20 12:56:13:557 2022 FW IPSEC/7/PACKET:
--- Sent IPsec packet, pkt len : 60 ---
Attent to match Mqc(0), ifIndex is 3, digest is 0, no result.
Attent to match Mqc(1), ifIndex is 3, digest is 0, no result.
Last dest lip is NULL.
Outbound IPsec processing: src IP = 192.168.76.1, dst IP = 10.34.26.39, SPI = 189012751.
Alloc IPsec cache: Global fs seq : 38, Private index : 0, Private seq : 5.
*Jan 20 12:56:13:557 2022 FW IPSEC/7/EVENT:
Add ip fastforward cache : ulDirtection = 2, ifIndexOut = 4
Added IP fast forwarding entry.
Outbound IPsec processing: ESP auth algorithm: SHA1, ESP encp algorithm: AES-CBC-128.
Packet will be sent to CCF for sync-encryption.
Outbound IPsec ESP processing: Encryption succeeded, anti-replay SN is 1.
Outbound IPsec processing: Packet encapsulated successfully.
Start to fill reply cache key, SrcAddr : 121.15.132.153, DstAddr : 139.159.222.86, SPI :189012751, SrcPort : 2884, DstPort : 6927.
Fill output IPsec packet reply cache key.
Find another sa, spi : 0x811eab44, SrcPort : 33054, DstPort : 43844.
*Jan 20 12:56:18:317 2022 FW IPSEC/7/PACKET:
FS Check : fs sequence num in IPsec fast cache is 38, current fs sequence num is 38
FS Check : No Change. Tunnel index = 0, Tunnel seq = 5.
--- Sent packet by IPsec fast forwarding ---
Outbound IPsec ESP processing: Encryption succeeded, anti-replay SN is 2.
*Jan 20 12:56:23:319 2022 FW IPSEC/7/PACKET:
Outbound IPsec ESP processing: Encryption succeeded, anti-replay SN is 3.
*Jan 20 12:56:34:899 2022 FW IKE/7/PACKET: vrf = 0, local = 121.15.132.153, remote = 139.159.222.86/500
Received packet from 139.159.222.86 source port 500 destination port 500.
I-COOKIE: aa48ab8ffa1876b8
R-COOKIE: 6bbaf0edf8b1830e
next payload: HASH
version: ISAKMP Version 1.0
exchange mode: Info
flags: ENCRYPT
message ID: 6f189c47
length: 92
*Jan 20 12:56:34:900 2022 FW IKE/7/PACKET: vrf = 0, local = 121.15.132.153, remote = 139.159.222.86/500
Decrypt the packet.
Received ISAKMP Hash Payload.
Received ISAKMP Notification Payload.
Parse informational exchange packet successfully.
*Jan 20 12:56:34:900 2022 FW IKE/7/EVENT: vrf = 0, local = 121.15.132.153, remote = 139.159.222.86/500
Notification R_U_THERE is received.
*Jan 20 12:56:34:900 2022 FW IKE/7/DPD: vrf = 0, local = 121.15.132.153, remote = 139.159.222.86/500
DPD packet with sequence number 566213461 is received, COOKIEs(i/r) aa48ab8ffa1876b8/6bbaf0edf8b1830e.
Encrypt the packet.
Construct notification packet: R_U_THERE_ACK.
Sending packet to 139.159.222.86 remote port 500, local port 500.
next payload: HASH
exchange mode: Info
flags: ENCRYPT
message ID: 472bf303
length: 92
Sending an IPv4 packet.
*Jan 20 12:56:34:901 2022 FW IKE/7/EVENT: vrf = 0, local = 121.15.132.153, remote = 139.159.222.86/500
Sent data to socket successfully.
*Jan 20 12:56:42:891 2022 FW IPSEC/7/PACKET:
Outbound IPsec ESP processing: Encryption succeeded, anti-replay SN is 4.
*Jan 20 12:56:52:899 2022 FW IKE/7/PACKET: vrf = 0, local = 121.15.132.153, remote = 139.159.222.86/500
next payload: HASH
exchange mode: Info
flags: ENCRYPT
message ID: b7834f1b
length: 92
Decrypt the packet.
*Jan 20 12:56:52:899 2022 FW IKE/7/EVENT: vrf = 0, local = 121.15.132.153, remote = 139.159.222.86/500
*Jan 20 12:56:52:899 2022 FW IKE/7/DPD: vrf = 0, local = 121.15.132.153, remote = 139.159.222.86/500
DPD packet with sequence number 566213462 is received, COOKIEs(i/r) aa48ab8ffa1876b8/6bbaf0edf8b1830e.
*Jan 20 12:56:52:900 2022 FW IKE/7/PACKET: vrf = 0, local = 121.15.132.153, remote = 139.159.222.86/500
Encrypt the packet.
next payload: HASH
exchange mode: Info
flags: ENCRYPT
message ID: 1e58e5e
length: 92
*Jan 20 12:56:52:900 2022 FW IKE/7/EVENT: vrf = 0, local = 121.15.132.153, remote = 139.159.222.86/500
*Jan 20 12:57:01:899 2022 FW IKE/7/PACKET: vrf = 0, local = 121.15.132.153, remote = 139.159.222.86/500
next payload: HASH
exchange mode: Info
flags: ENCRYPT
message ID: 95c79343
length: 92
Decrypt the packet.
*Jan 20 12:57:01:899 2022 FW IKE/7/EVENT: vrf = 0, local = 121.15.132.153, remote = 139.159.222.86/500
*Jan 20 12:57:01:899 2022 FW IKE/7/DPD: vrf = 0, local = 121.15.132.153, remote = 139.159.222.86/500
DPD packet with sequence number 566213463 is received, COOKIEs(i/r) aa48ab8ffa1876b8/6bbaf0edf8b1830e.
*Jan 20 12:57:01:900 2022 FW IKE/7/PACKET: vrf = 0, local = 121.15.132.153, remote = 139.159.222.86/500
Encrypt the packet.
next payload: HASH
exchange mode: Info
flags: ENCRYPT
message ID: c441337c
length: 92
*Jan 20 12:57:01:900 2022 FW IKE/7/EVENT: vrf = 0, local = 121.15.132.153, remote = 139.159.222.86/500
*Jan 20 12:57:10:899 2022 FW IKE/7/PACKET: vrf = 0, local = 121.15.132.153, remote = 139.159.222.86/500
next payload: HASH
exchange mode: Info
flags: ENCRYPT
message ID: b5f74967
length: 92
Decrypt the packet.
*Jan 20 12:57:10:899 2022 FW IKE/7/EVENT: vrf = 0, local = 121.15.132.153, remote = 139.159.222.86/500
*Jan 20 12:57:10:899 2022 FW IKE/7/DPD: vrf = 0, local = 121.15.132.153, remote = 139.159.222.86/500
DPD packet with sequence number 566213464 is received, COOKIEs(i/r) aa48ab8ffa1876b8/6bbaf0edf8b1830e.
*Jan 20 12:57:10:900 2022 FW IKE/7/PACKET: vrf = 0, local = 121.15.132.153, remote = 139.159.222.86/500
Encrypt the packet.
next payload: HASH
exchange mode: Info
flags: ENCRYPT
message ID: 8161d5e3
length: 92
*Jan 20 12:57:10:900 2022 FW IKE/7/EVENT: vrf = 0, local = 121.15.132.153, remote = 139.159.222.86/500
[FW]dis ike sa
Connection-ID Remote Flag DOI
5 139.159.222.86 RD IPsec
Flags:
RD--READY RL--REPLACED FD-FADING RK-REKEY
[FW] dis ips sa
% Unrecognized command found at '^' position.
[FW] dis ipsec sa
Interface: GigabitEthernet1/0/3
IPsec policy: policy
Sequence number: 10
Mode: ISAKMP
Tunnel id: 0
Encapsulation mode: tunnel
Perfect Forward Secrecy: dh-group5
Inside VPN:
Extended Sequence Numbers enable: N
Traffic Flow Confidentiality enable: N
Path MTU: 1428
Tunnel:
local address: 121.15.132.153
remote address: 139.159.222.86
Flow:
sour addr: 192.168.76.0/255.255.255.0 port: 0 protocol: ip
dest addr: 10.34.24.0/255.255.248.0 port: 0 protocol: ip
[Inbound ESP SAs]
SPI: 2166270788 (0x811eab44)
Connection ID: 73014444032
Transform set: ESP-ENCRYPT-AES-CBC-128 ESP-AUTH-SHA1
SA idle time: 3600
SA duration (kilobytes/sec): 1843200/3600
SA remaining duration (kilobytes/sec): 1843200/1394
Max received sequence-number: 0
Anti-replay check enable: Y
Anti-replay window size: 64
UDP encapsulation used for NAT traversal: N
Status: Active
[Outbound ESP SAs]
SPI: 189012751 (0x0b441b0f)
Connection ID: 73014444033
SA idle time: 3600
SA remaining duration (kilobytes/sec): 1843199/1394
Max sent sequence-number: 4
Status: ActiveZ.
[FW]in en
[FW]
[FW]
next payload: HASH
exchange mode: Info
flags: ENCRYPT
length: 92
Decrypt the packet.
Encrypt the packet.
next payload: HASH
exchange mode: Info
flags: ENCRYPT
length: 92
next payload: HASH
exchange mode: Info
flags: ENCRYPT
length: 92
Decrypt the packet.
Encrypt the packet.
next payload: HASH
exchange mode: Info
flags: ENCRYPT
message ID: 1e58e5e
length: 92
next payload: HASH
exchange mode: Info
flags: ENCRYPT
length: 92
Decrypt the packet.
Encrypt the packet.
next payload: HASH
exchange mode: Info
flags: ENCRYPT
length: 92
next payload: HASH
exchange mode: Info
flags: ENCRYPT
length: 92
Decrypt the packet.
Encrypt the packet.
next payload: HASH
exchange mode: Info
flags: ENCRYPT
length: 92
两阶段的都有的话,就不是ipsec的问题了。对端触发一下我们,我们这边看内层的会话,看看收到没有,没收到那就是对端问题,收到的话,看我们的内端有没有回ping,再看看ipsec的计数。这个过程其实很好排查,但是打字数不清楚,建议400
远行的人 发表时间:2022-01-20
