s5024Pv5-ei-hpwr,复位方法
2022-01-21提问
  • 1收藏,792浏览
s5024Pv5-ei-hpwr,复位方法,现在进入不了管理页面了
粉丝:111人 关注:1人
您好,参考
<H3C>reset saved-configuration
 The saved configuration file will be erased. Are you sure? [Y/N]:y
选择Y
<H3C>reboot
 Start to check configuration with next startup configuration file, please wait.........DONE! Current configuration may be lost after the reboot, save current configuration? [Y/N]:n
N选择不保存
Y确认重启
