两台h3c s5560 -30f交换机,如何配置虚拟化(堆叠)
2022-01-24提问
  • 1收藏,3244浏览
两台h3c s5560 -30f交换机,如何配置虚拟化(堆叠)。
请教一个过程怎么做?
粉丝:15人 关注:2人
1、配置IRF堆叠
1号设备关键配置如下:
[H3C]irf member 1 renumber 1 //将1号设备设定为成员1
[H3C]irf member 1 priority 32 //配置优先级32,值大优先,范围(1-32)
[H3C]int range Ten-GigabitEthernet 1/0/50 to Ten-GigabitEthernet 1/0/51
[H3C-if-range]shutdown
[H3C-if-range]quit
[H3C]irf-port 1/2 //将物理端口绑定到IRF端口
[H3C-irf-port1/2]port group interface Ten-GigabitEthernet 1/0/50
[H3C-irf-port1/2]port group interface Ten-GigabitEthernet 1/0/51
[H3C-irf-port1/2]quit
[H3C-if-range]undo shutdown
[H3C-if-range]quit
[H3C]irf-port-configuration active //激活IRF
[H3C]save
2号设备关键配置点如下:
[H3C]irf member 1 renumber 2 //将2号设备设定为成员2
[H3C]irf member 1 priority 1 //配置优先级1
[H3C]int range Ten-GigabitEthernet 2/0/50 to Ten-GigabitEthernet 2/0/51
[H3C-if-range]quit
[H3C]irf-port 2/1 //将物理端口绑定到IRF端口
[H3C-irf-port2/1]port group interface Ten-GigabitEthernet 2/0/50
[H3C-irf-port2/1]port group interface Ten-GigabitEthernet 2/0/51
[H3C-irf-port2/1]quit
[H3C-if-range]quit
[H3C]save
3、配置BFD MAD检测
irf link-delay 0 #修改IRF链路down延迟上报时间为0。
# 创建VLAN 3,并将端口GigabitEthernet1/0/1、GigabitEthernet2/0/1加入VLAN 3中。
vlan 3
port gigabitethernet 1/0/1 gigabitethernet 2/0/1
# 创建VLAN接口3,并配置MAD IP地址。
interface vlan-interface 3
mad bfd enable
mad ip address 192.168.2.1 24 member 1
mad ip address 192.168.2.2 24 member 2
# 因为BFD MAD和生成树功能互斥,所以在GigabitEthernet1/0/1、GigabitEthernet2/0/1端口上关闭生成树协议。
interface range gigabitethernet 1/0/1 gigabitethernet 2/0/1
undo stp enable
谢谢
0101@ABC 发表时间:2022-01-25
粉丝:111人 关注:1人
参考虚拟化配置:
https://www.h3c.com/cn/d_201912/1252409_30005_0.htm
zhiliao_N88OqT 知了小白
还是不要多说什么了
了解新华三(h3c)的产品先看下这个吧。
https://zhiliao.h3c.com/questions/dispcont/254273
