本地有一台MSR36-20设备和总部做ipsec vpn,一直用的没问题,本地配置没有动过,现在今天vpn不能使用了,在设备上打开debugging ipsec all
信息如下:我改如何排错,有没有具体命令?
*Jul 27 14:29:04:384 2018 qdccb-jn-3620-waiwang01 IPSEC/7/EVENT: Can't find block-flow node. *Jul 27 14:29:04:384 2018 qdccb-jn-3620-waiwang01 IPSEC/7/PACKET: Failed to find SA by SP, SP mode is 2. *Jul 27 14:29:04:384 2018 qdccb-jn-3620-waiwang01 IPSEC/7/ERROR: The reason of dropping packet is no available IPsec tunnel. *Jul 27 14:29:04:384 2018 qdccb-jn-3620-waiwang01 IPSEC/7/EVENT: Sent SA-Acquire message : SP ID = 0 *Jul 27 14:29:04:384 2018 qdccb-jn-3620-waiwang01 IPSEC/7/EVENT: Received negotiatiate SA message from IPsec kernel. *Jul 27 14:29:04:387 2018 qdccb-jn-3620-waiwang01 IPSEC/7/PACKET: Enter IPsec output process, Flag : 0x0, Data length : 60 *Jul 27 14:29:04:387 2018 qdccb-jn-3620-waiwang01 IPSEC/7/EVENT: Can't find block-flow node. *Jul 27 14:29:04:387 2018 qdccb-jn-3620-waiwang01 IPSEC/7/PACKET: Failed to find SA by SP, SP mode is 2. *Jul 27 14:29:04:387 2018 qdccb-jn-3620-waiwang01 IPSEC/7/ERROR: The reason of dropping packet is no available IPsec tunnel. *Jul 27 14:29:04:388 2018 qdccb-jn-3620-waiwang01 IPSEC/7/EVENT: Sent SA-Acquire message : SP ID = 0 *Jul 27 14:29:04:388 2018 qdccb-jn-3620-waiwang01 IPSEC/7/PACKET: Enter IPsec output process, Flag : 0x0, Data length : 60 *Jul 27 14:29:04:388 2018 qdccb-jn-3620-waiwang01 IPSEC/7/EVENT: Can't find block-flow node. *Jul 27 14:29:04:388 2018 qdccb-jn-3620-waiwang01 IPSEC/7/PACKET: Failed to find SA by SP, SP mode is 2. *Jul 27 14:29:04:388 2018 qdccb-jn-3620-waiwang01 IPSEC/7/ERROR: The reason of dropping packet is no available IPsec tunnel. *Jul 27 14:29:04:388 2018 qdccb-jn-3620-waiwang01 IPSEC/7/EVENT: Sent SA-Acquire message : SP ID = 0 *Jul 27 14:29:04:388 2018 qdccb-jn-3620-waiwang01 IPSEC/7/EVENT: Received negotiatiate SA message from IPsec kernel. *Jul 27 14:29:04:388 2018 qdccb-jn-3620-waiwang01 IPSEC/7/EVENT: Received negotiatiate SA message from IPsec kernel. *Jul 27 14:29:04:397 2018 qdccb-jn-3620-waiwang01 IPSEC/7/PACKET: Enter IPsec output process, Flag : 0x0, Data length : 60 *Jul 27 14:29:04:397 2018 qdccb-jn-3620-waiwang01 IPSEC/7/EVENT: Can't find block-flow node. *Jul 27 14:29:04:397 2018 qdccb-jn-3620-waiwang01 IPSEC/7/PACKET: Failed to find SA by SP, SP mode is 2. *Jul 27 14:29:04:397 2018 qdccb-jn-3620-waiwang01 IPSEC/7/ERROR: The reason of dropping packet is no available IPsec tunnel. *Jul 27 14:29:04:397 2018 qdccb-jn-3620-waiwang01 IPSEC/7/EVENT: Sent SA-Acquire message : SP ID = 0 *Jul 27 14:29:04:397 2018 qdccb-jn-3620-waiwang01 IPSEC/7/PACKET: Enter IPsec output process, Flag : 0x0, Data length : 60 *Jul 27 14:29:04:397 2018 qdccb-jn-3620-waiwang01 IPSEC/7/EVENT: Can't find block-flow node. *Jul 27 14:29:04:397 2018 qdccb-jn-3620-waiwang01 IPSEC/7/PACKET: Failed to find SA by SP, SP mode is 2. *Jul 27 14:29:04:397 2018 qdccb-jn-3620-waiwang01 IPSEC/7/ERROR: The reason of dropping packet is no available IPsec tunnel. *Jul 27 14:29:04:397 2018 qdccb-jn-3620-waiwang01 IPSEC/7/EVENT: Sent SA-Acquire message : SP ID = 0 *Jul 27 14:29:04:397 2018 qdccb-jn-3620-waiwang01 IPSEC/7/EVENT: Received negotiatiate SA message from IPsec kernel. *Jul 27 14:29:04:398 2018 qdccb-jn-3620-waiwang01 IPSEC/7/EVENT: Received negotiatiate SA message from IPsec kernel.
(0)
确定你的邮箱还未认证,请认证邮箱或绑定手机后进行当前操作
这是debuging看到的会不会有问题*Jul 27 15:13:05:833 2018 qdccb-jn-3620-waiwang01 IKE/7/PACKET: Sending packet to 221.0.173.245 remote port 500, local port 500. Jul 27 15:13:13:908 2018 qdccb-jn-3620-waiwang01 IKE/7/PACKET: Received packet from 144.123.42.242 source port 500 destination port 500
