手机APN L2TP
2022-02-11提问
  • 1收藏,1789浏览
运营商设备做LAC,客户紫光恒越R5900路由器做LNS,一直连接不通,求助
  Current State null, code ConfReq(01), id 0, len 22
      IP Address(3), len 6, val 00 00 00 00
      Primary DNS Server Address(81), len 6, val 00 00 00 00
      Secondary DNS Server Address(83), len 6, val 00 00 00 00
*Feb 11 10:58:35:292 2022 LNS PPP/7/EXTERNAL_EVENT:
  PPP External Event:
      Virtual-Access0 deliver packet to user space success
*Feb 11 10:58:35:453 2022 LNS L2TPV2/7/KDATA-PKT: -Slot=2;
 Received an L2TP data packet:
  Source IP: 192.50.0.21
  Destination IP: 192.50.10.178
  Source port: 1701
  Destination port: 1701
 Successfully parsed the L2TP header (L2TP header length=6):TunnelID:39338,SessionID:40280,Type:0,Length:0,Sequence:0,Offset: 0,Priority:0
 Processed an L2TP data packet. TunnelID=39338, SessiOnID=40280.
 No FlowCtrl: Received an L2TP Data Packet. TunnelID=39338, SessiOnID=40280.
*Feb 11 10:58:35:453 2022 LNS L2TPV2/7/KDUMP: -Slot=2;
 Sent a packet to PPP on interface Virtual-Access0 (length=6):
 c0 21 06 02 00 04
*Feb 11 10:58:35:453 2022 LNS PPP/7/EXTERNAL_EVENT: -Slot=2;
  PPP External Event:
      Virtual-Access0 Send negotiate packet to service board succeeded
*Feb 11 10:58:35:292 2022 LNS PPP/7/FSM_PACKET_0:
  PPP Packet:
      Virtual-Access0 Input LCP(c021) Packet, PktLen 8
      Current State closing, code TermAck(06), id 2, len 4
*Feb 11 10:58:35:293 2022 LNS PPP/7/FSM_EVENT_0:
  PPP Event:
      Virtual-Access0 LCP RTA(Receive Terminate Ack) Event
      State closing
*Feb 11 10:58:35:293 2022 LNS PPP/7/FSM_STATE_0:
  PPP State Change:
      Virtual-Access0 LCP: closing --> closed
*Feb 11 10:58:35:293 2022 LNS L2TPV2/7/CONTROL-PKT:
 Received CDN packet from port 1701 (TunnelID=39338, length=38, Ns=4, Nr=2). Packet content:
 c8 02 00 26  99 aa 9d 58  00 04 00 02  80 08 00 00
 00 00 00 0e  80 0a 00 00  00 01 00 01  00 00 80 08
 00 00 00 0e  00 01
*Feb 11 10:58:35:294 2022 LNS L2TPV2/7/EVENT:
 Parsed Message-Type AVP: 14.
 Parsed Result-Code AVP. Result-Code=1, Error-Code=0, Error-Message="".
 Parsed Assigned-Session-ID AVP: 1.
*Feb 11 10:58:35:295 2022 LNS PPP/7/EXTERNAL_EVENT_0:
  PPP External Event:
      Virtual-Access0: PPP daemon receive interface down event!
*Feb 11 10:58:35:295 2022 LNS PPP/7/FSM_EVENT_0:
  PPP Event:
      Virtual-Access0 LCP Lower Down Event
      State closed
*Feb 11 10:58:35:295 2022 LNS PPP/7/FSM_STATE_0:
  PPP State Change:
      Virtual-Access0 LCP: closed --> initial
  PPP Event:
      Virtual-Access0 LCP Close Event
      State initial
%Feb 11 10:58:35:297 2022 LNS IFNET/3/PHY_UPDOWN: Physical state on the interface Virtual-Access0 changed to down.
*Feb 11 10:58:35:309 2022 LNS PPP/7/EXTERNAL_EVENT_0:
  PPP External Event:
*Feb 11 10:58:35:312 2022 LNS PPP/7/FSM_EVENT_0:
  PPP Event:
      State initial
*Feb 11 10:58:35:313 2022 LNS PPP/7/FSM_ERROR_0:
  PPP Error:
      Virtual-Access0 LCP: FSM Illegal Event!
*Feb 11 10:58:35:313 2022 LNS PPP/7/FSM_EVENT_0:
  PPP Event:
      State initial
*Feb 11 10:58:35:478 2022 LNS L2TPV2/7/KEVENT: -Slot=2;
 Interface Virtual-Access0 deleted.
*Feb 11 10:58:35:961 2022 LNS L2TPV2/7/KEVENT: -Slot=1;
*Feb 11 10:58:35:320 2022 LNS L2TPV2/7/KEVENT:
*Feb 11 10:58:35:325 2022 LNS PPP/7/EXTERNAL_EVENT_0:
  PPP External Event:
      Virtual-Access0: Successfully freed the User ID 671088642.
*Feb 11 10:58:35:498 2022 LNS L2TPV2/7/EVENT:
 TunnelID=39338: Delay-ACK timer expired, received duplicate Hello packet for 0 times and sent ZLB-ACK packet for 1 times. Ns=2, Nr=5.
*Feb 11 10:58:40:198 2022 LNS L2TPV2/7/EVENT:
 TunnelID=47092: Delay-Cleanup timer expired and deleted the local tunnel.
*Feb 11 10:58:45:979 2022 LNS L2TPV2/7/CONTROL-PKT:
 Received SCCRQ packet from port 1701 (length=103, Ns=0, Nr=0). Packet content:
 c8 02 00 67  00 00 00 00  00 00 00 00  80 08 00 00
 00 00 00 01  80 08 00 00  00 02 01 00  80 0f 00 00
 00 07 67 7a  6d 32 6d 6c  32 74 70 00  0c 00 00 00
 08 48 55 41  57 45 49 80  0a 00 00 00  03 00 00 00
 03 80 08 00  00 00 09 00  01 80 08 00  00 00 0a 00
 40 80 16 00  00 00 0b d4  50 c8 f8 33  0f 44 a0 41
 8e d0 51 7d  0c de 0c
*Feb 11 10:58:45:980 2022 LNS L2TPV2/7/EVENT:
 Parsed Message-Type AVP: 1.
 Parsed Protocol-Version AVP. Version=1, Revision=0.
 Parsed Host-Name AVP: gzm2ml2tp.
 Parsed Vendor-Name AVP: HUAWEI.
 Parsed Framing-Capabilities AVP: 3.
 Parsed Assigned-Tunnel-ID AVP: 1.
 Parsed Receive-Window-Size AVP: 64.
 Parsed Challenge AVP: d4 50 c8 f8 33 0f 44 a0 41 8e d0 51 7d 0c de 0c
*Feb 11 10:58:45:980 2022 LNS L2TPV2/7/CONTROL-PKT:
 Encapsulated Message-Type AVP:
 80 08 00 00  00 00 00 02
 Encapsulated Protocol-Version AVP:
 Encapsulated Host-Name AVP:
 80 09 00 00  00 07 4c 4e  53
*Feb 11 10:58:45:981 2022 LNS L2TPV2/7/CONTROL-PKT:
 Encapsulated Framing-Capabilities AVP:
 80 0a 00 00  00 03 00 00  00 00
 Encapsulated Assigned-Tunnel-ID AVP:
 80 08 00 00  00 09 12 0d
 Encapsulated Bearer-Capabilities AVP:
 80 0a 00 00  00 04 00 00  00 03
 Encapsulated Receive-Window-Size AVP:
 80 08 00 00  00 0a 04 00
 Encapsulated Challenge AVP:
 80 16 00 00  00 0b ad 4e  40 75 22 ac  37 2b 27 ac
 f9 2a 1f c9  48 d6
 Encapsulated Challenge-Response AVP:
 80 16 00 00  00 0d bb 69  d6 e9 91 eb  04 5b 49 5f
 e0 7a 27 28  52 96
*Feb 11 10:58:45:982 2022 LNS L2TPV2/7/EVENT:
 TunnelID=4621: Processed SCCRQ packet in Idle state, sent SCCRP packet and changed the tunnel state to Wait-connect.
*Feb 11 10:58:45:992 2022 LNS L2TPV2/7/CONTROL-PKT:
 Received SCCCN packet from port 1701 (TunnelID=4621, length=42, Ns=1, Nr=1). Packet content:
 c8 02 00 2a  12 0d 00 00  00 01 00 01  80 08 00 00
 00 00 00 03  80 16 00 00  00 0d e5 33  4a b4 b8 e8
 20 34 81 dd  42 f8 ba 15  e5 29
*Feb 11 10:58:45:993 2022 LNS L2TPV2/7/EVENT:
 Parsed Message-Type AVP: 3.
 Parsed Challenge-Response AVP: e5 33 4a b4 b8 e8 20 34 81 dd 42 f8 ba 15 e5 29
*Feb 11 10:58:45:993 2022 LNS L2TPV2/7/KEVENT:
cioctl add tunnel vrf 0 lip 192.50.10.178 rip 192.50.0.20 lport 1701 rport 1701 ltid 4621 rtid 1 type 1
result drv add tunnel 0
 TunnelID=4621: Processed SCCCN packet in Wait-connect state, and changed the tunnel state to Established.
*Feb 11 10:58:46:155 2022 LNS L2TPV2/7/KEVENT: -Slot=2;
*Feb 11 10:58:46:637 2022 LNS L2TPV2/7/KEVENT: -Slot=1;
*Feb 11 10:58:45:994 2022 LNS L2TPV2/7/CONTROL-PKT:
 Received ICRQ packet from port 1701 (TunnelID=4621, length=99, Ns=2, Nr=1). Packet content:
 c8 02 00 63  12 0d 00 00  00 02 00 01  80 08 00 00
 00 00 00 0a  80 08 00 00  00 0e 00 01  80 0a 00 00
 00 0f 00 00  08 ab 80 0a  00 00 00 12  00 00 00 03
 80 1e 00 00  00 15 67 64  67 7a 66 79  7a 77 66 77
 30 31 73 2e  35 67 67 64  2e 67 7a 69  6f 74 80 15
 00 00 00 16  38 36 31 34  30 30 31 39  38 36 30 37
 39 32 37
*Feb 11 10:58:45:994 2022 LNS L2TPV2/7/EVENT:
 Parsed Message-Type AVP: 10.
 Parsed Call-Serial-Number AVP: 2219.
 Parsed Bearer-Type AVP: 3.
 Parsed Called-Number AVP: gdgzfyzwfw01s.5ggd.gziot.
 Parsed Calling-Number AVP: 861400198607927.
 80 08 00 00  00 00 00 0b
*Feb 11 10:58:45:995 2022 LNS L2TPV2/7/CONTROL-PKT:
 Encapsulated Assigned-Session-ID AVP:
 80 08 00 00  00 0e a2 2a
*Feb 11 10:58:45:995 2022 LNS L2TPV2/7/EVENT:
 TunnelID=4621, SessiOnID=41514: Processed ICRQ packet in Idle state, sent ICRP packet and changed the session state to Wait-connect.
*Feb 11 10:58:46:005 2022 LNS L2TPV2/7/CONTROL-PKT:
 Received ICCN packet from port 1701 (TunnelID=4621, length=80, Ns=3, Nr=2). Packet content:
 c8 02 00 50  12 0d a2 2a  00 03 00 02  80 08 00 00
 00 00 00 0c  80 0a 00 00  00 18 00 00  00 00 80 0a
 00 00 00 13  00 00 00 01  00 0a 00 00  00 1a 01 04
 05 dc 00 0a  00 00 00 1b  01 04 05 dc  00 0a 00 00
 00 1c 01 04  05 dc 00 0a  00 00 00 25  00 00 00 00
*Feb 11 10:58:46:005 2022 LNS L2TPV2/7/EVENT:
 Parsed Message-Type AVP: 12.
 Parsed (Tx)Connect-Speed AVP: 0.
 Parsed Framing-Type AVP: 1.
 Parsed Initial-Received-LCP-CONFREQ AVP: 4.
 Parsed Last-Sent-LCP-CONFREQ AVP: 4.
*Feb 11 10:58:46:006 2022 LNS L2TPV2/7/EVENT:
 Parsed Last-Received-LCP-CONFREQ AVP: 4.
 Parsed Private-Group-ID AVP: .
*Feb 11 10:58:46:007 2022 LNS L2TPV2/7/EVENT:
 TunnelID=4621, SessiOnID=41514: Processed ICCN packet in Wait-connect state, and changed the session state to Established.
*Feb 11 10:58:46:007 2022 LNS L2TPV2/7/KEVENT:
 Interface Virtual-Access0 created.
*Feb 11 10:58:46:169 2022 LNS L2TPV2/7/KEVENT: -Slot=2;
*Feb 11 10:58:46:652 2022 LNS L2TPV2/7/KEVENT: -Slot=1;
*Feb 11 10:58:46:009 2022 LNS PPP/7/EXTERNAL_EVENT_0:
  PPP External Event:
      Virtual-Access0: Successfully distributed the User ID 671088642.
*Feb 11 10:58:46:021 2022 LNS L2TPV2/7/KEVENT:
 LNS Notify ppp up(IF_LINKUP_UP). (ifIndex = 17413)
*Feb 11 10:58:46:022 2022 LNS PPP/7/EXTERNAL_EVENT_0:
  PPP External Event:
      Virtual-Access0: PPP daemon receive interface up event!
*Feb 11 10:58:46:023 2022 LNS L2TPV2/7/KDUMP:
 Received a packet from PPP on interface Virtual-Access0 (length=18):
 ff 03 c0 21 01 00 00 0e 03 04 c0 23 05 06 7f b4
 3b 5a
*Feb 11 10:58:46:023 2022 LNS L2TPV2/7/KDATA-PKT:
 Encapsulated an L2TP data packet on interface Virtual-Access0 (length=54):
  Source IP: 192.50.10.178
  Destination IP: 192.50.0.20
  Source port: 1701
  Tunnel ID: 1
  Session ID: 1
  PPP External Event:
      Virtual-Access0: PPP l2tp prenego begin!
  PPP External Event:
      Virtual-Access0: mandatory-lcp, lcp establish begin!
*Feb 11 10:58:46:022 2022 LNS PPP/7/FSM_EVENT_0:
  PPP Event:
      Virtual-Access0 LCP Open Event
      State initial
*Feb 11 10:58:46:022 2022 LNS PPP/7/FSM_STATE_0:
  PPP State Change:
      Virtual-Access0 LCP: initial --> starting
  PPP Event:
      Virtual-Access0 LCP Lower Up Event
      State starting
*Feb 11 10:58:46:023 2022 LNS PPP/7/FSM_STATE_0:
  PPP State Change:
      Virtual-Access0 LCP: starting --> reqsent
*Feb 11 10:58:46:023 2022 LNS PPP/7/FSM_PACKET_0:
  PPP Packet:
      Virtual-Access0 Output LCP(c021) Packet, PktLen 18
      Current State reqsent, code ConfReq(01), id 0, len 14
      AuthProto(3), len 4, PAP c0 23
      MagicNumber(5), len 6, val 7f b4 3b 5a
*Feb 11 10:58:46:023 2022 LNS PPP/7/EXTERNAL_EVENT_0:
  PPP External Event:
      Virtual-Access0: PPP l2tp prenego end!
*Feb 11 10:58:46:023 2022 LNS L2TPV2/7/EVENT:
 TunnelID=4621, SessiOnID=41514: LNS in Established state notify PPP phy-up result = 0.
%Feb 11 10:58:46:024 2022 LNS IFNET/3/PHY_UPDOWN: Physical state on the interface Virtual-Access0 changed to up.
*Feb 11 10:58:46:031 2022 LNS PPP/7/EXTERNAL_EVENT:
  PPP External Event:
  PPP External Event:
*Feb 11 10:58:46:031 2022 LNS L2TPV2/7/KDUMP:
 Received a packet from PPP on interface Virtual-Access0 (length=12):
 ff 03 c0 21 02 00 00 08 01 04 05 dc
*Feb 11 10:58:46:031 2022 LNS L2TPV2/7/KDATA-PKT:
 Encapsulated an L2TP data packet on interface Virtual-Access0 (length=48):
  Source port: 1701
  Tunnel ID: 1
  Session ID: 1
*Feb 11 10:58:46:032 2022 LNS L2TPV2/7/KDUMP:
 Received a packet from PPP on interface Virtual-Access0 (length=8):
 ff 03 c0 21 01 01 00 04
*Feb 11 10:58:46:032 2022 LNS L2TPV2/7/KDATA-PKT:
 Encapsulated an L2TP data packet on interface Virtual-Access0 (length=44):
  Source port: 1701
  Tunnel ID: 1
  Session ID: 1
*Feb 11 10:58:46:192 2022 LNS L2TPV2/7/KDATA-PKT: -Slot=2;
  Source IP: 192.50.0.20
  Source port: 1701
 Successfully parsed the L2TP header (L2TP header length=6):TunnelID:4621,SessionID:41514,Type:0,Length:0,Sequence:0,Offset: 0,Priority:0
 Processed an L2TP data packet. TunnelID=4621, SessiOnID=41514.
 No FlowCtrl: Received an L2TP Data Packet. TunnelID=4621, SessiOnID=41514.
*Feb 11 10:58:46:192 2022 LNS L2TPV2/7/KDUMP: -Slot=2;
 Sent a packet to PPP on interface Virtual-Access0 (length=10):
 c0 21 01 00 00 08 01 04 05 dc
*Feb 11 10:58:46:192 2022 LNS PPP/7/EXTERNAL_EVENT: -Slot=2;
  PPP External Event:
  Source port: 1701
 Sent a packet to PPP on interface Virtual-Access0 (length=16):
 c0 21 04 00 00 0e 03 04 c0 23 05 06 7f b4 3b 5a
*Feb 11 10:58:46:031 2022 LNS PPP/7/FSM_PACKET_0:
  PPP Packet:
      Virtual-Access0 Input LCP(c021) Packet, PktLen 12
      Current State reqsent, code ConfReq(01), id 0, len 8
      MRU(1), len 4, val 05 dc
  PPP External Event:
*Feb 11 10:58:46:031 2022 LNS PPP/7/FSM_EVENT_0:
  PPP Event:
      Virtual-Access0 LCP RCR+(Receive Config Good Request) Event
      State reqsent
  PPP Packet:
      Virtual-Access0 Output LCP(c021) Packet, PktLen 12
      Current State reqsent, code ConfAck(02), id 0, len 8
*Feb 11 10:58:46:031 2022 LNS PPP/7/FSM_STATE_0:
  PPP State Change:
      Virtual-Access0 LCP: reqsent --> acksent
*Feb 11 10:58:46:032 2022 LNS PPP/7/FSM_PACKET_0:
  PPP Packet:
      Virtual-Access0 Input LCP(c021) Packet, PktLen 18
      Current State acksent, code ConfRej(04), id 0, len 14
*Feb 11 10:58:46:032 2022 LNS PPP/7/FSM_EVENT_0:
  PPP Event:
      Virtual-Access0 LCP RCN(Receive Config Nak/Reject) Event
      State acksent
  PPP Packet:
      Virtual-Access0 Output LCP(c021) Packet, PktLen 8
      Current State acksent, code ConfReq(01), id 1, len 4
*Feb 11 10:58:46:040 2022 LNS PPP/7/EXTERNAL_EVENT:
  PPP External Event:
  PPP External Event:
*Feb 11 10:58:46:040 2022 LNS L2TPV2/7/KDUMP:
 ff 03 c0 21 05 02 00 04
*Feb 11 10:58:46:040 2022 LNS L2TPV2/7/KDATA-PKT:
  Source port: 1701
  Tunnel ID: 1
  Session ID: 1
*Feb 11 10:58:46:201 2022 LNS L2TPV2/7/KDATA-PKT: -Slot=2;
  Source port: 1701
*Feb 11 10:58:46:201 2022 LNS L2TPV2/7/KDUMP: -Slot=2;
 c0 21 02 01 00 04
*Feb 11 10:58:46:201 2022 LNS PPP/7/EXTERNAL_EVENT: -Slot=2;
  PPP External Event:
  Source port: 1701
*Feb 11 10:58:46:040 2022 LNS PPP/7/FSM_PACKET_0:
  PPP Packet:
      Current State acksent, code ConfAck(02), id 1, len 4
 Sent a packet to PPP on interface Virtual-Access0 (length=24):
 80 21 01 00 00 16 03 06 00 00 00 00 81 06 00 00
 00 00 83 06 00 00 00 00
  PPP External Event:
*Feb 11 10:58:46:040 2022 LNS PPP/7/FSM_EVENT_0:
  PPP Event:
      Virtual-Access0 LCP RCA(Receive Config Ack) Event
      State acksent
  PPP Event:
      State acksent
*Feb 11 10:58:46:040 2022 LNS PPP/7/FSM_STATE_0:
  PPP State Change:
      Virtual-Access0 LCP: acksent --> closing
  PPP Packet:
      Current State closing, code TermReq(05), id 2, len 4
  PPP Packet:
      Virtual-Access0 Input IPCP(8021) Packet, PktLen 26
*Feb 11 10:58:46:048 2022 LNS PPP/7/EXTERNAL_EVENT:
  PPP External Event:
*Feb 11 10:58:46:209 2022 LNS L2TPV2/7/KDATA-PKT: -Slot=2;
  Source port: 1701
*Feb 11 10:58:46:209 2022 LNS L2TPV2/7/KDUMP: -Slot=2;
 c0 21 06 02 00 04
*Feb 11 10:58:46:209 2022 LNS PPP/7/EXTERNAL_EVENT: -Slot=2;
  PPP External Event:
*Feb 11 10:58:46:048 2022 LNS PPP/7/FSM_PACKET_0:
  PPP Packet:
*Feb 11 10:58:46:048 2022 LNS PPP/7/FSM_EVENT_0:
  PPP Event:
      State closing
*Feb 11 10:58:46:048 2022 LNS L2TPV2/7/CONTROL-PKT:
 Received CDN packet from port 1701 (TunnelID=4621, length=38, Ns=4, Nr=2). Packet content:
 c8 02 00 26  12 0d a2 2a  00 04 00 02  80 08 00 00
 00 00 00 0e  00 01
*Feb 11 10:58:46:049 2022 LNS L2TPV2/7/EVENT:
*Feb 11 10:58:46:049 2022 LNS PPP/7/FSM_STATE_0:
  PPP State Change:
*Feb 11 10:58:46:058 2022 LNS PPP/7/EXTERNAL_EVENT_0:
  PPP External Event:
*Feb 11 10:58:46:058 2022 LNS PPP/7/FSM_EVENT_0:
  PPP Event:
      State closed
*Feb 11 10:58:46:059 2022 LNS PPP/7/FSM_STATE_0:
  PPP State Change:
*Feb 11 10:58:46:059 2022 LNS PPP/7/FSM_EVENT_0:
  PPP Event:
      State initial
%Feb 11 10:58:46:068 2022 LNS IFNET/3/PHY_UPDOWN: Physical state on the interface Virtual-Access0 changed to down.
*Feb 11 10:58:46:085 2022 LNS PPP/7/EXTERNAL_EVENT_0:
  PPP External Event:
*Feb 11 10:58:46:086 2022 LNS PPP/7/FSM_EVENT_0:
  PPP Event:
      State initial
*Feb 11 10:58:46:086 2022 LNS PPP/7/FSM_ERROR_0:
  PPP Error:
  PPP Event:
      State initial
*Feb 11 10:58:46:256 2022 LNS L2TPV2/7/KEVENT: -Slot=2;
*Feb 11 10:58:46:739 2022 LNS L2TPV2/7/KEVENT: -Slot=1;
*Feb 11 10:58:46:098 2022 LNS L2TPV2/7/KEVENT:
*Feb 11 10:58:46:101 2022 LNS PPP/7/EXTERNAL_EVENT_0:
  PPP External Event:
*Feb 11 10:58:46:298 2022 LNS L2TPV2/7/EVENT:
 TunnelID=4621: Delay-ACK timer expired, received duplicate Hello packet for 0 times and sent ZLB-ACK packet for 1 times. Ns=2, Nr=5.
粉丝:1人 关注:1人
LNS侧收到了拆除VA口通知,然后拆除,请排查LAC侧为什么发送该报文
z6Kl9 九段
粉丝:66人 关注:2人
贴配置吧
[LNS]dis current-configuration
 version 7.1.064, Release 0809P29
 sysname LNS
 ip pool unicom-l2tp-user 10.40.0.1 10.40.3.200
 ip pool unicom-l2tp-user gateway 10.40.3.254
 dhcp enable
 lldp global enable
 password-recovery enable
vlan 1
 l2vpn enable
controller Cellular2/0/0
interface Virtual-Template1
 ppp authentication-mode pap chap
 remote address pool unicom-l2tp-user
 ip address 10.40.3.254 255.255.252.0
interface NULL0
interface GigabitEthernet2/0/0
 port link-mode route
 combo enable copper
interface GigabitEthernet2/0/1
 combo enable copper
interface GigabitEthernet2/0/2
 combo enable copper
interface GigabitEthernet2/0/3
 combo enable copper
interface GigabitEthernet2/0/4
 combo enable copper
interface GigabitEthernet2/0/5
 combo enable copper
interface GigabitEthernet2/0/6
 combo enable copper
interface GigabitEthernet2/0/7
 combo enable copper
interface GigabitEthernet2/0/8
 combo enable copper
interface GigabitEthernet2/0/9
 combo enable copper
interface GigabitEthernet2/1/0
interface GigabitEthernet2/1/1
interface GigabitEthernet2/1/2
interface GigabitEthernet2/1/3
interface GigabitEthernet2/2/0
 description 联通5G
 ip address 192.50.10.178 255.255.255.252
interface GigabitEthernet2/2/1
interface GigabitEthernet2/2/2
interface GigabitEthernet2/2/3
 description 区府内网
 ip address 10.160.245.6 255.255.255.252
interface M-GigabitEthernet0
interface Ten-GigabitEthernet2/0/10
interface Ten-GigabitEthernet2/0/11
interface Ten-GigabitEthernet2/0/12
interface Ten-GigabitEthernet2/0/13
 scheduler logfile size 16
line class console
 user-role network-admin
line class tty
 user-role network-operator
line class vty
line con 0 1
line vty 0 63
 authentication-mode scheme
 ip route-static 0.0.0.0 0 10.160.245.5
 ip route-static 10.160.0.0 16 10.160.245.5
 ip route-static 172.25.0.0 16 10.160.245.5
 ip route-static 192.50.0.0 24 192.50.10.177
 ip route-static 192.50.0.1 32 192.50.10.177
 ip route-static 192.50.0.3 32 192.50.10.177
 ip route-static 192.50.0.20 32 192.50.10.177
 ip route-static 192.50.0.21 32 192.50.10.177
 ip route-static 192.50.0.32 32 192.50.10.177
 snmp-agent
 snmp-agent local-engineid 8000291780DC2DCB3A285A00000001
 snmp-agent community read cipher $c$3$bf62+Dzlvpr4MkhR94bxVip6dFzJ2uhCDtNIErE=
 snmp-agent sys-info version all
 ssh server enable
 ssh user admin service-type stelnet authentication-type password
acl number 3177
 rule 0 permit ip destination 172.25.200.0 0.0.0.255
 rule 5 permit ip destination 10.160.20.20 0
 rule 2000 deny ip
radius scheme vpdn
 primary authentication 10.160.20.20 key cipher $c$3$zMGs1ZU98oCuSczQaMYpuSpcU0GEGAOB4Q==
 primary accounting 10.160.20.20 key cipher $c$3$aRbqzi4bg6EmnjRLmzBlU7PLVDdot2STkA==
 user-name-format without-domain
 nas-ip 10.160.245.6
domain system
 authentication ppp local
 accounting ppp local
domain vpdn
 domain default enable system
role name level-0
 description Predefined level-0 role
role name level-1
 description Predefined level-1 role
role name level-2
 description Predefined level-2 role
role name level-3
 description Predefined level-3 role
role name level-4
 description Predefined level-4 role
role name level-5
 description Predefined level-5 role
role name level-6
 description Predefined level-6 role
role name level-7
 description Predefined level-7 role
role name level-8
 description Predefined level-8 role
role name level-9
 description Predefined level-9 role
role name level-10
 description Predefined level-10 role
role name level-11
 description Predefined level-11 role
role name level-12
 description Predefined level-12 role
role name level-13
 description Predefined level-13 role
role name level-14
 description Predefined level-14 role
user-group system
local-user admin class manage
 password hash $h$6$pLAXNMqqTHZl50Cs$5ui2fO0zvKizbi/73L75hU/jQPRl/9O/OudvwFUCKRE0psM5rAUBYuUnvJVRUkPLwpfF5UDpYsWVnv+fAryyVA==
 service-type ssh https
local-user ceshi class network
 password cipher $c$3$pL5U35nKjDZRk9hLob+e55Hg3LK00+U1b7pi2eu0tg==
 service-type ppp
local-user l2tp class network
 password cipher $c$3$YhWAlhEwYnrMv9fX42G9cv7MoQ0t6VA=
 service-type advpn
 service-type ppp
l2tp-group 1 mode lns
 allow l2tp virtual-template 1 remote gzm2ml2tp
 tunnel name LNS
 tunnel password cipher $c$3$PxBU3Ygtw5QvjEayVWPvAah7wVvxYgljfLOvVQ==
 l2tp enable
 ip http enable
 ip https enable
