2610,4320AP分析下有什么问题?
2022-02-28提问
  • 1收藏,791浏览
粉丝:1人 关注:1人
[WX3510E]dis wlan client verbose
 Total Number of Clients           : 164
                              Client Information
 MAC Address                       : 009e-c8e1-e46c
 User Name                         : -NA-
 IP Address                        : 192.168.188.196
 IPv6 Address                      : -NA-
 AID                               : 3
 AP Name                           : 35l-ap1
 Radio Id                          : 2
 Antenna Id                        : 0
 Service Template Number           : 35
 SSID                              : TF-SSHGG
 BSSID                             : 487a-da4d-e230
 Port                              : WLAN-DBSS35:93
 VLAN                              : 184
 State                             : Running
 Power Save Mode                   : Active
 Wireless Mode                     : 11gn
 Channel Band-width                : 20MHz
 SM Power Save Enable              : Disabled
 Short GI for 20MHz                : Supported
 Short GI for 40MHz                : Supported
 LDPC                              : Not Supported
 STBC TX capability                : Supported
 STBC RX capability                : Supported
 Support MCS Set                   : 0,1,2,3,4,5,6,7,8,9,
                                     10,11,12,13,14,15
 BLOCK ACK-TID 0                   : BOTH
 BLOCK ACK-TID 1                   : OUT
 BLOCK ACK-TID 6                   : IN
 QoS Mode                          : WMM
 Listen Interval (Beacon Interval) : 1
 RSSI                              : 27
 Rx/Tx Rate                        : 52/19.5
 Client Type                       : PRE-RSNA
 Authentication Method             : Open System
 Authentication Mode               : Central
 AKM Method                        : None
 Key Derivation                    : -NA-
 4-Way Handshake State             : -NA-
 Group Key State                   : -NA-
 Encryption Cipher                 : Clear
 PMF Status                        : -NA-
 Roam Status                       : Intra-AC roam association
 Roam Count                        : 2
 Up Time (hh:mm:ss)                : 00:18:53
 Bonjour Records                   :
                              Client Information
 MAC Address                       : 00b0-6c17-7650
 User Name                         :
 IP Address                        : 128.28.7.244
 IPv6 Address                      : -NA-
 AID                               : 5
 AP Name                           : youyc_3
 Radio Id                          : 2
 Antenna Id                        : 0
 Service Template Number           : 7
 SSID                              : TF-JXBH
 BSSID                             : 487a-da4e-0690
 Port                              : WLAN-DBSS7:75
 VLAN                              : 7
 State                             : Running
 Short GI for 40MHz                : Not Supported
 STBC TX capability                : Not Supported
 QoS Mode                          : WMM
 Listen Interval (Beacon Interval) : 3
 RSSI                              : 43
 Rx/Tx Rate                        : 65/72.2
 Client Type                       : WPA2(RSN)
 AKM Method                        : PSK
 Key Derivation                    : SHA1
 4-Way Handshake State             : PTKINITDONE
 Group Key State                   : REKEYESTABLISHED
 Encryption Cipher                 : AES-CCMP
 PMF Status                        : -NA-
 Roam Status                       : Normal
 Roam Count                        : 0
 Up Time (hh:mm:ss)                : 2 Days, 18:21:23
 Bonjour Records                   :
                              Client Information
 MAC Address                       : 00be-3b28-72fb
 User Name                         :
 IP Address                        : 128.28.7.27
 IPv6 Address                      : -NA-
 AID                               : 1
 AP Name                           : wa4320h_8
 Radio Id                          : 1
 Antenna Id                        : 0
 SSID                              : TF-JXBH
 BSSID                             : d461-fe4e-8620
 Port                              : WLAN-DBSS7:439
 VLAN                              : 7
 State                             : Running
 Wireless Mode                     : 11ac
 Channel Band-width                : 20/40/80MHz
 Short GI for 80MHz                : Supported
 Short GI for 160/80+80MHz         : Not Supported
 LDPC RX capability                : Not Supported
 STBC RX capability                : Supported For 1 Nss
 Support VHT-MCS and Nss Set       : 2,3,3,3,3,3,3,3
 QoS Mode                          : WMM
 RSSI                              : 35
 Rx/Tx Rate                        : 6/6
 AKM Method                        : PSK
 Group Key State                   : IDLE
 PMF Status                        : -NA-
 Roam Count                        : 8
 Up Time (hh:mm:ss)                : 00:00:46
 Bonjour Records                   :
                              Client Information
 MAC Address                       : 02a6-ce46-f266
 User Name                         :
 IP Address                        : 128.28.7.7
 IPv6 Address                      : -NA-
 AID                               : 6
 AP Name                           : 36l-2f-x
 Radio Id                          : 2
 Antenna Id                        : 0
 SSID                              : TF-JXBH
 BSSID                             : 487a-da42-f5b0
 Port                              : WLAN-DBSS7:134
 VLAN                              : 7
 State                             : Running
 STBC RX capability                : Not Supported
                                     10,11,12,13,14,15
 BLOCK ACK-TID 1                   : IN
 BLOCK ACK-TID 5                   : IN
 QoS Mode                          : WMM
 Listen Interval (Beacon Interval) : 20
 RSSI                              : 26
 Rx/Tx Rate                        : 1/1
 AKM Method                        : PSK
 PMF Status                        : -NA-
 Roam Count                        : 6
 Up Time (hh:mm:ss)                : 00:00:01
 Bonjour Records                   :
粉丝:149人 关注:3人
这能看出啥问题来,明显故障现象呢?
粉丝:150人 关注:1人
协商速率有点低,可以关闭低速率
 Rx/Tx Rate                        : 6/6
