sslvpn结合ldap报错 拨不上
2022-03-01提问
  • 1收藏,998浏览
粉丝:2人 关注:0人
<HUC-FW>debug ldap all This command is CPU intensive and might affect ongoing services. Are you sure you want to continue? [Y/N]:y
<HUC-FW>*Mar 1 15:44:53:016 2022 HUC-FW SSLVPNK/7/SSLVPN_AAA: Online check: No session ID.
*Mar 1 15:44:53:047 2022 HUC-FW SSLVPNK/7/SSLVPN_AAA: Online check: No session ID.
*Mar 1 15:44:53:947 2022 HUC-FW SSLVPNK/7/SSLVPN_AAA: Online check: No session ID.
*Mar 1 15:44:53:947 2022 HUC-FW SSLVPNK/7/SSLVPN_AAA: Received a client login request. *Mar 1 15:44:53:947 2022 HUC-FW SSLVPNK/7/SSLVPN_AAA: Authentication request: result=0x0, client MAC=60f6-77c6-dc57, private info length=32.
*Mar 1 15:44:53:947 2022 HUC-FW SSLVPNK/7/SSLVPN_AAA: Received an authentication request from user 123456.
 *Mar 1 15:44:53:947 2022 HUC-FW SSLVPN/7/SSLVPN_AAA: Parsed private information in the authentication request: original length=32, decode length=22.
*Mar 1 15:44:53:947 2022 HUC-FW SSLVPN/7/SSLVPN_AAA: Began to process online request: cOntextID=0x1, requestID=0x1f000001.
*Mar 1 15:44:53:947 2022 HUC-FW SSLVPN/7/SSLVPN_AAA: Processed online request successfully: cOntextID=0x1, requestID=0x1f000001, username=123456.
*Mar 1 15:44:53:947 2022 HUC-FW SSLVPN/7/SSLVPN_AAA: Set user IPv4 180.107.210.117 in PAM. Result: 0.
*Mar 1 15:44:53:947 2022 HUC-FW SSLVPN/7/SSLVPN_AAA: Set user MAC address 60-f6-77-c6-dc-57 in PAM. Result: 0.
*Mar 1 15:44:53:947 2022 HUC-FW SSLVPN/7/SSLVPN_AAA: Set private information in PAM. Length=23, result=0.
*Mar 1 15:44:53:948 2022 HUC-FW LDAP/7/EVENT: PAM_LDAP:Processing LDAP authentication. *
Mar 1 15:44:53:948 2022 HUC-FW LDAP/7/EVENT: PAM_LDAP:Data of authentication request successfully sent.
*Mar 1 15:44:53:948 2022 HUC-FW LDAP/7/EVENT: PAM_LDAP:Processing AAA request data.
*Mar 1 15:44:53:948 2022 HUC-FW LDAP/7/EVENT: PAM_LDAP:LDAP server is: 10.100.120.1. *Mar 1 15:44:53:948 2022 HUC-FW LDAP/7/EVENT: PAM_LDAP:Current bind state is 4.
*Mar 1 15:44:53:948 2022 HUC-FW LDAP/7/EVENT: PAM_LDAP:Search user when authentication.
 *Mar 1 15:44:53:948 2022 HUC-FW LDAP/7/EVENT: PAM_LDAP:Username is 123456.
*Mar 1 15:44:53:948 2022 HUC-FW LDAP/7/EVENT: PAM_LDAP[Authen]:Search filter is (&(objectClass=person)(samaccountname=123456)). *Mar 1 15:44:53:948 2022 HUC-FW LDAP/7/EVENT: PAM_LDAP[Authen]:Search base DN is cn=123,dc=herrmannultrasonic,dc=cn.
*Mar 1 15:44:53:948 2022 HUC-FW LDAP/7/EVENT: PAM_LDAP:Response timeout timer successfully created.
*Mar 1 15:44:53:949 2022 HUC-FW SSLVPNK/7/SSLVPN_AAA: Authentication failed: cOntextID=0x1, requestID=0x1f000001.
 *Mar 1 15:44:53:949 2022 HUC-FW LDAP/7/EVENT: PAM_LDAP:Get result message errno = 32
 *Mar 1 15:44:53:949 2022 HUC-FW LDAP/7/EVENT: PAM_LDAP:User 123456 search done. *Mar 1 15:44:53:949 2022 HUC-FW LDAP/7/ERROR: PAM_LDAP:Failed to search users.
*Mar 1 15:44:53:949 2022 HUC-FW LDAP/7/EVENT: PAM_LDAP:Processing LDAP authentication.
*Mar 1 15:44:53:949 2022 HUC-FW LDAP/7/EVENT: PAM_LDAP:Data of authentication reply successfully obtained, resultCode: 1.
*Mar 1 15:44:53:949 2022 HUC-FW SSLVPN/7/SSLVPN_AAA: Processed asynchronous authentication response: cOntextID=0x1, requestID=0, result=26.
*Mar 1 15:44:53:949 2022 HUC-FW SSLVPN/7/SSLVPN_AAA: Deleted request online node: cOntextID=0x1, OnlineID=0.
# ldap server svpn login-dn cn=administrator,cn=users,dc=herrmannultrasonic,dc=cn
 search-base-dn cn=123,dc=herrmannultrasonic,dc=cn ip 10.100.120.1
 login-password cipher xxxxxxxxxxxxxxxxxx
 user-parameters user-name-attribute samaccountname #
粉丝:5人 关注:1人
没有找到该用户,建议ldap那边排查下用户情况
