WA4320-ACN-SI 胖AP WDS桥接后无法上网的问题
2022-03-07提问
  • 1收藏,1422浏览
用两台胖模式的WA4320-ACN-SI进行WDS桥接
1号AP做主路由器,配置好拨号,mesh,无线服务,DHCP SERVER等,无线终端上网正常。
只有一个VLAN,即VLAN1,2.4G射频口建立无线服务ABC,并绑定MESH-PROFILE 1,5G射频口也建立一个ABC-5G无线服务
2号AP配置2.4G下的WDS,MESH接口和配置方面与1号AP相同,二者均未绑定对方的MAC地址,现在在两个AP的命令行下都可以用display wlan mesh-link all查看到mesh-link已经建立,且无线终端连接2号AP也可以获得到由1号AP的DHCP SERVER分配的IP地址和网关及DNS,但是连接在2呺AP下的无线终端却不能正常上网,手机显示WLAN已经连接,无网络。
在1号AP上用TELNET登录2号AP正常,且ping一个外网的IP地址也正常。
问题会出现在哪里呢?2号AP还需要配置默认路由吗?两个AP是二层桥接的呀
AP1上的配置:
version 5.20, Release 1508P11
sysname WA4320_ZHU
domain default enable system
telnet server enable
port-security enable
password-recovery enable
undo attack-defense tcp fragment enable
vlan 1
domain system
access-limit disable
state active
idle-cut disable
self-service-url disable
dhcp server ip-pool vlan10 extended
network ip range 192.168.10.101 192.168.10.200
network mask 255.255.255.0
gateway-list 192.168.10.1
dns-list 202.96.64.68 180.76.76.76
user-group system
group-attribute allow-guest
local-user admin
password cipher $c$3$eUx7gBX8sHlgaxD1/H1p9KzswNz2JDSkUWqpnus=
authorization-attribute level 3
service-type telnet
service-type web
wlan mesh-profile 1
mesh-id bri
bind WLAN-MESH 1
mesh-profile enable
wlan rrm
dot11a mandatory-rate 6 12 24
dot11a supported-rate 9 18 36 48 54
dot11b mandatory-rate 1 2
dot11b supported-rate 5.5 11
dot11g mandatory-rate 1 2 5.5 11
dot11g supported-rate 6 9 12 18 24 36 48 54
wlan service-template 1 crypto
ssid ABC-5G
cipher-suite ccmp
security-ie rsn
service-template enable
wlan service-template 2 crypto
ssid ABC
cipher-suite ccmp
security-ie rsn
cwmp
undo cwmp enable
interface Dialer1
nat outbound
link-protocol ppp
ppp chap user 123456786
ppp chap password cipher $c$3$DmFoh63HbhgsRMMrUVlvfCXxSLn2Bwp8oA==
ppp pap local-user 12345678 password cipher $c$3$jdd4tJPXQ+735QP4n8KaCb+Xzy8NcNcGPg==
ppp ipcp dns request
mtu 1480
ip address ppp-negotiate
dialer user pppoeclient
dialer-group 1
dialer bundle 1
interface NULL0
interface Vlan-interface1
pppoe-client dial-bundle-number 1
ip address 192.168.10.1 255.255.255.0
dhcp server apply ip-pool vlan10
interface WLAN-MESH1
port-security port-mode psk
port-security tx-key-type 11key
port-security preshared-key pass-phrase cipher $c$3$vaJdmyoslTQvypjMpacZqEO6Paju2JMpw2VIrLLk5bg=
interface WLAN-BSS1
port-security preshared-key pass-phrase cipher $c$3$fvSjloZxjPSCHqZHfNG7jEvBhyQO04dep+TAv7HVcfM=
interface WLAN-BSS2
port-security preshared-key pass-phrase cipher $c$3$vfT1aaJbfMJFirxWHc8d9pkkBDNIWw2/TUKIRcYf3Po=
interface WLAN-Radio1/0/1
channel 40
service-template 1 interface wlan-bss 1
interface WLAN-Radio1/0/2
channel 11
service-template 2 interface wlan-bss 2
mesh-profile 1
ip route-static 0.0.0.0 0.0.0.0 Dialer1
dhcp enable
dialer-rule 1 ip permit
load xml-configuration
load tr069-configuration
user-interface con 0
user-interface vty 0 4
authentication-mode scheme
return
AP2上只做了无线MESH,无线服务,与AP1相同,只在5G射频接口下的工作信道不同,为157。VLAN1接口IP为为192.168.10.2/24。
 # version 5.20, Release 1508P11
# sysname WA4320_FU
# domain default enable system
 # telnet server enable
 # port-security enable
 # password-recovery enable
# undo attack-defense tcp fragment enable
# vlan 1
# domain system access-limit disable state active idle-cut disable self-service-url disable
 # user-group system
# local-user admin password cipher $c$3$eUx7gBX8sHlgaxD1/H1p9KzswNz2JDSkUWqpnus=
 service-type telnet
 service-type web
# wlan mesh-profile 1
 mesh-id bri
 bind WLAN-MESH 1
 mesh-profile enable
# wlan rrm dot11a
 dot11b
mandatory-rate 1 2
 dot11b
 # wlan service-template 1 crypto
 ssid ABC-5G
 cipher-suite ccmp
 security-ie rsn
# wlan service-template 2 crypto
 ssid ABC cipher-suite
ccmp security-ie rsn
# cwmp
 undo cwmp enable
# interface NULL0
# interface Vlan-interface1
 ip address 192.168.10.2 255.255.255.0
 # interface GigabitEthernet1/0/1
# interface WLAN-MESH1
# interface WLAN-BSS1
# interface WLAN-BSS2
# interface WLAN-Radio1/0/1
 channel 157
# interface WLAN-Radio1/0/2
 channel 11
 mesh-profile 1
# dhcp enable
 # load xml-configuration
 # load tr069-configuration
# user-interface
con 0
 # return
粉丝:4人 关注:0人
确保AP1上用vlan1到外网可达,修改加密方式不加密看是否加密有关,检查组网是否有对终端的限制,包过滤或者安全设备的限制等
AP1上访问外网正常,其下连的无线终端上网也正常
wufengfury 发表时间:2022-03-07
