S3100V2交换机MAC地址绑定
2018-08-05提问
  • 1收藏,1561浏览
# 进入Ethernet1/0/1端口视图。
[SwitchA] interface Ethernet 1/0/1
# 将Host 1的MAC地址绑定到Ethernet1/0/1端口。
[SwitchA-Ethernet1/0/1] am user-bind mac-addr 0001-0002-0003
进入后,看不到相关命令,如下:
<CQNA-DFSB.S1>dis  arp
      Type: S-Static    D-Dynamic    O-Openflow
IP Address       MAC Address     VLAN ID  Interface              Aging Type
55.110.32.126    d461-fe43-ca29  1        Eth1/0/1               17    D
55.110.32.1      0800-376e-2001  1        Eth1/0/2               18    D
55.110.32.2      0800-376e-2002  1        Eth1/0/3               20    D
55.110.32.3      0800-376e-2003  1        Eth1/0/4               18    D
55.110.32.4      0800-376e-2004  1        Eth1/0/5               20    D
<CQNA-DFSB.S1>sy
[CQNA-DFSB.S1]sys
 % Ambiguous command found at '^' position.
[CQNA-DFSB.S1] interface Ethernet 1/0/1
[CQNA-DFSB.S1-Ethernet1/0/1]am ?
 % Unrecognized command found at '^' position.
[CQNA-DFSB.S1-Ethernet1/0/1]am us
[CQNA-DFSB.S1-Ethernet1/0/1]am user
[CQNA-DFSB.S1-Ethernet1/0/1]?
Ethernet_l2 interface view commands:
  arp                    Configure ARP for the interface
  bpdu-drop              Drop BPDU packets.
  bpdu-tunnel            Specify BPDU tunnel function
  broadcast-suppression  Specify the broadcast storm control
  cfd                    Connectivity fault detection (IEEE 802.1ag)
  default                Restore the default settings
  description            Describe the interface
  dhcp-snooping          DHCP Snooping
  display                Display current system information
  dldp                   Specify configuration information of DLDP
  dot1x                  Specify 802.1X configuration information
  duplex                 Status of duplex
  enable                 Enable function
  flow-control           Flow control command
  flow-interval          Set interval of interface statistic
  garp                   Generic Attribute Registration Protocol
  gvrp                   GARP VLAN Registration Protocol
  igmp-snooping          Configure IGMP snooping characteristic
  ip                     Specify IP configurations for the system
  ipv6                   IPv6 status and configuration information
  lacp                   Configure LACP Protocol
  link-aggregation       Link aggregation group
  link-delay             Set the delay time of holding link-up and link-down
  lldp                   Link Layer Discovery Protocol(802.1ab)
  logfile                Specify log file configuration
  loopback               Specify loopback of current port
  loopback-detection     Detect if loopback exists
  mac-address            Configure MAC address
  mac-authentication     MAC authentication configuration
  mac-vlan               Specify MAC VLAN
  mdi                    Specify mdi type
  mirroring-group        Specify mirroring-group
  mirroring-port         Specify mirroring port
  mld-snooping           Configure MLD snooping characteristic
  monitor-port           Specify monitor port
  mrp                    Multiple Register Protocol
  multicast-suppression  Specify the multicast storm control
  mvrp                   Multiple VLAN Registration Protocol
  ndp                    Neighbor discovery protocol
  ntdp                   Specify NTDP configuration information
  oam                    OAM protocol
  packet-filter          Specify packet filter
  ping                   Ping function
  port                   Specify Port characteristics
  port-isolate           Specify port-isolate configuration information
  port-security          Specify port-security configuration information
  portal                 Portal protocol
  qinq                   Specify 802.1Q-in-Q VPN function
  qos                    Command of QoS(Quality of Service)
  quit                   Exit from current command view
  return                 Exit to User View
  rmon                   Specify RMON
  save                   Save current configuration
  shutdown               Shut down this interface
  smart-link             Configure smart link
  speed                  Specify speed of current port
  storm-constrain        Port storm-constrain
  stp                    Spanning tree protocol
  tracert                Trace route function
  undo                   Cancel current setting
  unicast-suppression    Specify the unicast storm control
  virtual-cable-test     Virtual cable test information
  voice                  Specify voice VLAN
寂东 九段
粉丝:225人 关注:3人
这款交换机支持端口 ip+mac 绑定,有静态和动态绑定两种方式,具体如下:
静态绑定: ip source binding
ip source binding { ip-address ip-address ip-address ip-address mac-address mac-address | mac-address mac-address} [ vlan vlan-id ]
undo ip source binding { ip-address ip-address ip-address ip-address mac-address mac-address | mac-address mac-address } [ vlan vlan-id ]
二层以太网端口视图
【缺省级别】
2:系统级
ip-address ip-address:指定静态绑定表项的IPv4地址。其中ip-address表示绑定的IPv4地址,必须为A、B、C三类地址之一,不能为127.x.x.x和0.0.0.0。
mac-address mac-address:指定静态绑定表项的MAC地址。其中mac-address表示绑定的MAC地址,格式为H-H-H,取值不能为全0、全F(广播MAC)和组播MAC。
vlan vlan-id:指定静态绑定表项的VLAN。其中vlan-id表示绑定的VLAN ID,取值范围为1~4094。
·     当IPv4静态绑定表项与IP Source Guard功能配合时,静态绑定表项中的VLAN参数不作为过滤报文的特征项,VLAN参数指定与否,不影响IP Source Guard功能对报文的过滤结果。
·     在IPv4静态绑定表项与ARP Detection功能配合时,静态绑定表项中必须指定VLAN参数,且该VLAN为使能ARP Detection功能的VLAN,否则ARP报文将无法通过IPv4静态绑定表项的检查。关于ARP Detection功能的相关配置请参见“安全配置指导”中的“ARP攻击防御”。
【描述】
ip source binding命令用来配置端口的IPv4静态绑定表项。undo ip source binding命令用来删除指定的端口IPv4静态绑定表项。
缺省情况下,端口上无IPv4静态绑定表项。
·     一个表项不能在同一个端口上重复绑定,但可以在不同端口上绑定。
·     端口如果加入聚合组,则不能配置静态绑定表项。
相关配置可参考命令display ip source binding static
# 在端口Ethernet1/0/1上配置一条IPv4静态绑定表项(绑定IP+MAC)。
[Sysname-Ethernet1/0/1] ip source binding ip-address 192.168.0.1 mac-address 0001-0001-0001
动态绑定  ip verify source
ip verify source { ip-address | ip-address mac-address | mac-address }
undo ip verify source
二层以太网端口视图/端口组视图
【缺省级别】
2:系统级
ip-address:表示绑定源IP地址。
ip-address mac-address:表示绑定源IP地址和MAC地址。
mac-address:表示绑定源MAC地址。
【描述】
ip verify source命令用来配置IPv4动态绑定功能。undo ip verify source命令用来恢复缺省情况。
缺省情况下,端口的IPv4动态绑定功能处于关闭状态。
·     本命令中指定的绑定参数,仅对动态生成的绑定表项有效,是端口使用动态绑定表项过滤报文时关心的报文特征项。如果仅使用静态绑定表项来过滤端口的报文,则本命令仅用于控制是否开启端口的报文过滤功能,端口依据配置的静态绑定表项参数来过滤报文,而不关心本命令中指定的参数。
·     端口如果加入聚合组,则不能配置端口的动态绑定功能。
# 在二层以太网端口Ethernet1/0/1上配置对报文的源IP和MAC地址的IPv4动态绑定功能,获取端口上动态生成的DHCP Snooping表项对端口转发的报文进行过滤。
[Sysname-Ethernet1/0/1] ip verify source ip-address mac-address
粉丝:57人 关注:0人
试试 ip source bind命令,如果也不支持,可能设备不支持这个功能
