华安小贝G340设备网络不稳,掉线找不到原因
2022-03-19提问
  • 1收藏,780浏览
网络经常断开,最近隔几天就会出现一次大断网,网络不稳,ping 路由和外网的话也是会偶尔超时,time偶尔也会很长
链路上面有没有丢包的情况,可以查看一下ap的掉线原因。
zhiliao_gifjmS 知了小白
| WinMTR statistics |
| Host - % | Sent | Recv | Best | Avrg | Wrst | Last |
| 192.168.1.1 - 1 | 146 | 145 | 0 | 5 | 404 | 0 |
| 10.12.1.1 - 0 | 150 | 150 | 0 | 4 | 338 | 0 |
|________________________________________________|______|______|______|______|______|______|
WinMTR v0.92 GPL V2 by Appnor MSP - Fully Managed Hosting & Cloud Provider
=============================================== ===============display clock=============== 10:40:52 Beijing Sat 03/19/2022 Time Zone : Beijing add 08:00:00 ================================================= ===============display version=============== H3C Comware Software, Version 7.1.064, Release 5272 Copyright (c) 2004-2019 New H3C Technologies Co., Ltd. All rights reserved. H3C MSG360-40 uptime is 0 weeks, 0 days, 1 hour, 2 minutes Last reboot reason : Power on Boot image: flash:/boot.bin Boot image version: 7.1.064, Release 5272 Compiled May 29 2019 16:00:00 System image: flash:/system.bin System image version: 7.1.064, Release 5272 Compiled May 29 2019 16:00:00 with 1 1000MHz Multi-core Processor 1024M bytes DDR3 16M bytes NorFlash Memory 1024M bytes NandFlash Memory Hardware Version is Ver.A CPLD Version is 003 Basic Bootrom Version is 1.07 Extend Bootrom Version is 1.12 [Subslot 0]MSG360-40 Hardware Version is Ver.A ===============display system internal version=============== H3C MSG360-40 V500R001B64D016SP72 Comware V700R001B64D016SP72 ================================================ ===============display device verbose=============== Slot No. Subslot No. Board Type Status Max Ports 1 0 MSG360-40 Normal 9 Slot 1 Status: Normal Type: MSG360-40 Hardware: A Driver: 1.12 CPLD CPLD: 003 =============================================================== ===============display device manuinfo=============== DEVICE_NAME:MSG360-40 DEVICE_SERIAL_NUMBER:219801A12R9203Q0001P MAC_ADDRESS:905D-7C18-DCF0 MANUFACTURING_DATE:2020-03-11 VENDOR_NAME:H3C =============================================================== ===============display device cf-card=============== =============================================================== ===============display device usb=============== =============================================================== ===============display fan=============== Fan 1 State: Normal =============================================================== ===============display envirOnment=============== System Temperature information (degree centigrade): ---------------------------------------------------- Slot Sensor Temperature LowerLimit WarningLimit AlarmLimit ShutdownLimit 1 inflow 1 36 5 65 75 N/A 1 hotspot 1(cpu)45 32 76 87 N/A =============================================================== ===============display power-supply verbose=============== =============================================================== ===============display history-command=============== =============================================================== ===============display system internal startup cache=============== Current startup configuration file: flash:/startup.mdb ============================================================= ===============dir /all /all-filesystems=============== Directory of flash: 0 drw- - Mar 19 2022 09:40:45 apimge 1 -rw- 261688 Aug 06 2020 08:42:35 background-logon.jpg 2 -rw- 98678784 Jan 01 2013 08:00:00 boot.bin 3 -rw- 261472 Mar 19 2022 09:39:22 defaultfile.zip 4 -rw- 0 Mar 19 2022 10:40:50 diag.gz 5 drw- - Aug 28 2020 17:25:18 diagfile 6 drw- - Aug 06 2020 00:46:51 dpi 7 -rw- 40581120 Mar 19 2022 10:40:28 drs.db 8 -rw- 26624 Aug 07 2020 12:39:43 drs6.db 9 -rw- 15559 Aug 07 2020 14:59:01 drvciu_backup_0f52.cfg 10 -rw- 81 Aug 07 2020 14:59:01 drvciu_update_0f52.cfg 11 -rw- 735 Mar 19 2022 10:40:43 hostkey 12 -rw- 428 Mar 19 2022 10:40:44 ifindex.dat 13 -rw- 0 Nov 08 2021 20:22:47 lauth.dat 14 drw- - Mar 11 2020 09:31:04 lbisp 15 drw- - Mar 11 2020 09:31:09 license 16 drw- - Mar 11 2020 09:31:07 logfile 17 drw- - Mar 18 2022 16:34:00 pdt_reserve 18 drw- - Mar 11 2020 09:32:20 pki 19 drw- - Mar 11 2020 09:31:07 seclog 20 -rw- 591 Mar 19 2022 10:40:43 serverkey 21 -rw- 25674 Mar 19 2022 10:40:44 startup.cfg 22 -rw- 642302 Mar 19 2022 10:40:45 startup.mdb 23 -rw- 71233536 Jan 01 2013 08:00:00 system.bin 24 drwh - Aug 07 2020 11:46:27 .trash 1048576 KB total (725256 KB free) =============================================================== ===============dir core ======================== The file or directory doesn"t exist. =============================================================== ===============display current-cOnfiguration=============== # version 7.1.064, Release 5272 # sysname XLL-R # clock timezone Beijing add 08:00:00 # telnet server enable # port-security enable # dialer-group 1 rule ip permit # ip redirects enable ip unreachables enable ip ttl-expires enable # nat alg h323 nat alg ils nat alg mgcp nat alg nbt nat alg rsh nat alg sccp nat alg sip nat alg sqlnet nat alg tftp nat alg xdmcp # dhcp enable # dns proxy enable ip host oauthindev.h3c.com 192.168.0.100 ip host www.spiritapp-wlan-ac.h3c.com 192.168.0.100 ip host XLL-R 192.168.0.100 # lldp global enable # module-proxy work-mode route module-proxy sample-description {"mode":"5","startTime":"10T00","endTime":"14T00","adjustTime":"2T00"} # password-recovery enable # vlan 1 # vlan 10 description HL-TP # vlan 100 # dhcp server ip-pool 1 gateway-list 192.168.0.100 network 192.168.0.0 mask 255.255.248.0 address range 192.168.0.0 192.168.0.254 dns-list 192.168.0.100 # dhcp server ip-pool 100 gateway-list 172.16.100.1 network 172.16.100.0 mask 255.255.252.0 dns-list 202.99.224.67 202.99.224.68 # nqa entry xiaobei test type http frequency 5000 history-record enable history-record number 1 probe timeout 500 url http://www.baidu.com # nqa schedule xiaobei test start-time now lifetime forever # wlan service-template st_182381246194939 description 1 ssid XLL vlan 100 client max-count 10 akm mode psk preshared-key pass-phrase cipher $c$3$1IcHKhJjn4P/ocMLLb5HNN9TicyCyCAAzdcZwYAO cipher-suite ccmp cipher-suite tkip security-ie rsn security-ie wpa service-template enable # controller Cellular1/0/9 # interface Dialer1 mtu 1492 ppp ipcp dns admit-any ppp ipcp dns request dialer bundle enable dialer-group 1 dialer timer idle 0 dialer timer autodial 60 ip address ppp-negotiate tcp mss 1452 nat outbound # interface Dialer2 mtu 1492 ppp ipcp dns admit-any ppp ipcp dns request dialer bundle enable dialer-group 1 dialer timer idle 0 dialer timer autodial 60 ip address ppp-negotiate tcp mss 1452 nat outbound # interface Dialer3 mtu 1492 ppp ipcp dns admit-any ppp ipcp dns request dialer bundle enable dialer-group 1 dialer timer idle 0 dialer timer autodial 60 ip address ppp-negotiate tcp mss 1452 nat outbound # interface Dialer4 mtu 1492 ppp ipcp dns admit-any ppp ipcp dns request dialer bundle enable dialer-group 1 dialer timer idle 0 dialer timer autodial 60 ip address ppp-negotiate tcp mss 1452 nat outbound # interface Dialer5 mtu 1492 ppp ipcp dns admit-any ppp ipcp dns request dialer bundle enable dialer-group 1 dialer timer idle 0 dialer timer autodial 60 ip address ppp-negotiate tcp mss 1452 nat outbound # interface Dialer6 mtu 1492 ppp ipcp dns admit-any ppp ipcp dns request dialer bundle enable dialer-group 1 dialer timer idle 0 dialer timer autodial 60 ip address ppp-negotiate tcp mss 1452 nat outbound # interface Dialer7 mtu 1492 ppp ipcp dns admit-any ppp ipcp dns request dialer bundle enable dialer-group 1 dialer timer idle 0 dialer timer autodial 60 ip address ppp-negotiate tcp mss 1452 nat outbound # interface Dialer8 mtu 1492 ppp ipcp dns admit-any ppp ipcp dns request dialer bundle enable dialer-group 1 dialer timer idle 0 dialer timer autodial 60 ip address ppp-negotiate tcp mss 1452 nat outbound # interface NULL0 # interface Vlan-interface1 ip address 192.168.0.100 255.255.248.0 # interface Vlan-interface10 description HL-TP ip address 10.12.1.1 255.255.255.252 # interface Vlan-interface100 description YW ip address 172.16.100.1 255.255.252.0 # interface GigabitEthernet1/0/7 port link-mode route description GigabitEthernet1/0/7 ip address 61.138.113.174 255.255.255.248 nat outbound undo dhcp select server # interface GigabitEthernet1/0/8 port link-mode route nat outbound undo dhcp select server # interface GigabitEthernet1/0/1 port link-mode bridge # interface GigabitEthernet1/0/2 port link-mode bridge port link-type trunk port trunk permit vlan all # interface GigabitEthernet1/0/3 port link-mode bridge port link-type trunk port trunk permit vlan all # interface GigabitEthernet1/0/4 port link-mode bridge port link-type trunk port trunk permit vlan all # interface GigabitEthernet1/0/5 port link-mode bridge port access vlan 10 # interface GigabitEthernet1/0/6 port link-mode bridge # scheduler logfile size 16 # scheduler job Job_adjust command 1 wlan calibrate-channel pronto ap all # scheduler schedule Schedule_adjust user-role network-admin job Job_adjust time repeating at 02:00 week-day Mon Tue Wed Thu Fri # line class console user-role network-admin # line class vty user-role network-operator # line con 0 authentication-mode scheme user-role network-admin # line vty 0 31 authentication-mode scheme user-role network-operator # ip route-static 0.0.0.0 0 GigabitEthernet1/0/7 61.138.113.169 # undo info-center logfile enable # ssh server enable sftp server enable scp server enable # nqa server enable # time-range TimeRange_sample 10:00 to 14:00 working-day # ntp-service enable ntp-service unicast-server ***.*** # domain cloud authentication portal none authorization portal none accounting portal none # domain extend-auth authentication portal none authorization portal none accounting portal none # domain system # domain default enable system # role name level-0 description Predefined level-0 role # role name level-1 description Predefined level-1 role # role name level-2 description Predefined level-2 role # role name level-3 description Predefined level-3 role # role name level-4 description Predefined level-4 role # role name level-5 description Predefined level-5 role # role name level-6 description Predefined level-6 role # role name level-7 description Predefined level-7 role # role name level-8 description Predefined level-8 role # role name level-9 description Predefined level-9 role # role name level-10 description Predefined level-10 role # role name level-11 description Predefined level-11 role # role name level-12 description Predefined level-12 role # role name level-13 description Predefined level-13 role # role name level-14 description Predefined level-14 role # user-group system # local-user admin class manage password hash $h$6$N15emMVjw80PuxB9$OAq5vHjdw/teGZmV9eMuYRvKOZmtLNyq4gsMYj5UeE3ZWROu+dft3Aife20X3JKtc49SFK/xenTGoKUd5zM+UQ== service-type ssh telnet terminal http https authorization-attribute user-role network-admin # session statistics enable # portal host-check enable portal free-rule 2 destination ip any udp 53 portal free-rule 3 destination ip any tcp 53 portal free-rule 4 destination short.weixin.qq.com portal free-rule 5 destination mp.weixin.qq.com portal free-rule 6 destination long.weixin.qq.com portal free-rule 7 destination dns.weixin.qq.com portal free-rule 8 destination minorshort.weixin.qq.com portal free-rule 9 destination extshort.weixin.qq.com portal free-rule 10 destination szshort.weixin.qq.com portal free-rule 11 destination szlong.weixin.qq.com portal free-rule 12 destination szextshort.weixin.qq.com portal free-rule 13 destination ***.*** portal free-rule 14 destination wifi.weixin.qq.com # portal web-server 1 url http://192.168.0.100 # portal web-server local-server url https://192.168.0.100/portal # portal web-server lvzhou-server url http://oasisauth.h3c.com/portal/protocol server-type oauth # portal local-web-server http # portal local-web-server https # portal extend-auth-server qq # portal extend-auth-server mail mail-protocol pop3 imap # ip http enable ip https enable # url-filter policy drs default-action permit # app-profile drs url-filter apply policy drs # wlan rrm calibration-power interval 30 # wlan auto-ap enable wlan auto-persistent enable # wlan global-configuration # wlan ap-group default-group vlan 1 ap-model SPM-X1-10 gigabitethernet 1 gigabitethernet 2 gigabitethernet 3 gigabitethernet 4 gigabitethernet 5 gigabitethernet 6 gigabitethernet 7 gigabitethernet 8 gigabitethernet 9 gigabitethernet 10 gigabitethernet 11 gigabitethernet 12 ap-model SPM-X1-24 gigabitethernet 1 gigabitethernet 2 gigabitethernet 3 gigabitethernet 4 gigabitethernet 5 gigabitethernet 6 gigabitethernet 7 gigabitethernet 8 gigabitethernet 9 gigabitethernet 10 gigabitethernet 11 gigabitethernet 12 gigabitethernet 13 gigabitethernet 14 gigabitethernet 15 gigabitethernet 16 gigabitethernet 17 gigabitethernet 18 gigabitethernet 19 gigabitethernet 20 gigabitethernet 21 gigabitethernet 22 gigabitethernet 23 gigabitethernet 24 ap-model WAP711H radio 1 radio enable service-template st_182381246194939 bandwidth-guarantee enable rrm calibrate-channel self-decisive enable calibrate-channel mode scheduled calibrate-channel monitoring time-range TimeRange_sample interference-threshold 10 crc-error-threshold 10 tolerance-level 15 calibrate-power self-decisive enable calibrate-power mode density ethernet 1 ethernet 2 ethernet 3 ap-model WAP712C radio 1 radio enable service-template st_182381246194939 bandwidth-guarantee enable rrm calibrate-channel self-decisive enable calibrate-channel mode scheduled calibrate-channel monitoring time-range TimeRange_sample interference-threshold 10 crc-error-threshold 10 tolerance-level 15 calibrate-power self-decisive enable calibrate-power mode density radio 2 radio enable service-template st_182381246194939 bandwidth-guarantee enable rrm calibrate-channel self-decisive enable calibrate-channel mode scheduled calibrate-channel monitoring time-range TimeRange_sample interference-threshold 10 crc-error-threshold 10 tolerance-level 15 calibrate-power self-decisive enable calibrate-power mode density gigabitethernet 1 ap-model WAP712C-HI radio 1 radio enable service-template st_182381246194939 bandwidth-guarantee enable rrm calibrate-channel self-decisive enable calibrate-channel mode scheduled calibrate-channel monitoring time-range TimeRange_sample interference-threshold 10 crc-error-threshold 10 tolerance-level 15 calibrate-power self-decisive enable calibrate-power mode density radio 2 radio enable service-template st_182381246194939 bandwidth-guarantee enable rrm calibrate-channel self-decisive enable calibrate-channel mode scheduled calibrate-channel monitoring time-range TimeRange_sample interference-threshold 10 crc-error-threshold 10 tolerance-level 15 calibrate-power self-decisive enable calibrate-power mode density gigabitethernet 1 ap-model WAP712C-LI radio 1 radio enable service-template st_182381246194939 bandwidth-guarantee enable rrm calibrate-channel self-decisive enable calibrate-channel mode scheduled calibrate-channel monitoring time-range TimeRange_sample interference-threshold 10 crc-error-threshold 10 tolerance-level 15 calibrate-power self-decisive enable calibrate-power mode density radio 2 radio enable service-template st_182381246194939 bandwidth-guarantee enable rrm calibrate-channel self-decisive enable calibrate-channel mode scheduled calibrate-channel monitoring time-range TimeRange_sample interference-threshold 10 crc-error-threshold 10 tolerance-level 15 calibrate-power self-decisive enable calibrate-power mode density gigabitethernet 1 ap-model WAP712E radio 1 radio enable service-template st_182381246194939 bandwidth-guarantee enable rrm calibrate-channel self-decisive enable calibrate-channel mode scheduled calibrate-channel monitoring time-range TimeRange_sample interference-threshold 10 crc-error-threshold 10 tolerance-level 15 calibrate-power self-decisive enable calibrate-power mode density radio 2 radio enable service-template st_182381246194939 bandwidth-guarantee enable rrm calibrate-channel self-decisive enable calibrate-channel mode scheduled calibrate-channel monitoring time-range TimeRange_sample interference-threshold 10 crc-error-threshold 10 tolerance-level 15 calibrate-power self-decisive enable calibrate-power mode density gigabitethernet 1 ap-model WAP712H radio 1 radio enable service-template st_182381246194939 bandwidth-guarantee enable rrm calibrate-channel self-decisive enable calibrate-channel mode scheduled calibrate-channel monitoring time-range TimeRange_sample interference-threshold 10 crc-error-threshold 10 tolerance-level 15 calibrate-power self-decisive enable calibrate-power mode density radio 2 radio enable service-template st_182381246194939 bandwidth-guarantee enable rrm calibrate-channel self-decisive enable calibrate-channel mode scheduled calibrate-channel monitoring time-range TimeRange_sample interference-threshold 10 crc-error-threshold 10 tolerance-level 15 calibrate-power self-decisive enable calibrate-power mode density ethernet 1 ethernet 2 ethernet 3 ap-model WAP722 radio 1 radio enable service-template st_182381246194939 bandwidth-guarantee enable rrm calibrate-channel self-decisive enable calibrate-channel mode scheduled calibrate-channel monitoring time-range TimeRange_sample interference-threshold 10 crc-error-threshold 10 tolerance-level 15 calibrate-power self-decisive enable calibrate-power mode density radio 2 radio enable service-template st_182381246194939 bandwidth-guarantee enable rrm calibrate-channel self-decisive enable calibrate-channel mode scheduled calibrate-channel monitoring time-range TimeRange_sample interference-threshold 10 crc-error-threshold 10 tolerance-level 15 calibrate-power self-decisive enable calibrate-power mode density gigabitethernet 1 gigabitethernet 2 ap-model WAP722E radio 1 radio enable service-template st_182381246194939 bandwidth-guarantee enable rrm calibrate-channel self-decisive enable calibrate-channel mode scheduled calibrate-channel monitoring time-range TimeRange_sample interference-threshold 10 crc-error-threshold 10 tolerance-level 15 calibrate-power self-decisive enable calibrate-power mode density radio 2 radio enable service-template st_182381246194939 bandwidth-guarantee enable rrm calibrate-channel self-decisive enable calibrate-channel mode scheduled calibrate-channel monitoring time-range TimeRange_sample interference-threshold 10 crc-error-threshold 10 tolerance-level 15 calibrate-power self-decisive enable calibrate-power mode density gigabitethernet 1 gigabitethernet 2 ap-model WAP722E-W2 radio 1 radio enable service-template st_182381246194939 bandwidth-guarantee enable rrm calibrate-channel self-decisive enable calibrate-channel mode scheduled calibrate-channel monitoring time-range TimeRange_sample interference-threshold 10 crc-error-threshold 10 tolerance-level 15 calibrate-power self-decisive enable calibrate-power mode density radio 2 radio enable service-template st_182381246194939 bandwidth-guarantee enable rrm calibrate-channel self-decisive enable calibrate-channel mode scheduled calibrate-channel monitoring time-range TimeRange_sample interference-threshold 10 crc-error-threshold 10 tolerance-level 15 calibrate-power self-decisive enable calibrate-power mode density gigabitethernet 1 gigabitethernet 2 ap-model WAP722H radio 1 radio enable service-template st_182381246194939 bandwidth-guarantee enable rrm calibrate-channel self-decisive enable calibrate-channel mode scheduled calibrate-channel monitoring time-range TimeRange_sample interference-threshold 10 crc-error-threshold 10 tolerance-level 15 calibrate-power self-decisive enable calibrate-power mode density radio 2 radio enable service-template st_182381246194939 bandwidth-guarantee enable rrm calibrate-channel self-decisive enable calibrate-channel mode scheduled calibrate-channel monitoring time-range TimeRange_sample interference-threshold 10 crc-error-threshold 10 tolerance-level 15 calibrate-power self-decisive enable calibrate-power mode density gigabitethernet 1 gigabitethernet 2 gigabitethernet 3 gigabitethernet 4 gigabitethernet 5 ap-model WAP722S radio 1 radio enable service-template st_182381246194939 bandwidth-guarantee enable rrm calibrate-channel self-decisive enable calibrate-channel mode scheduled calibrate-channel monitoring time-range TimeRange_sample interference-threshold 10 crc-error-threshold 10 tolerance-level 15 calibrate-power self-decisive enable calibrate-power mode density radio 2 radio enable service-template st_182381246194939 bandwidth-guarantee enable rrm calibrate-channel self-decisive enable calibrate-channel mode scheduled calibrate-channel monitoring time-range TimeRange_sample interference-threshold 10 crc-error-threshold 10 tolerance-level 15 calibrate-power self-decisive enable calibrate-power mode density gigabitethernet 1 ap-model WAP722S-W2 radio 1 radio enable service-template st_182381246194939 bandwidth-guarantee enable rrm calibrate-channel self-decisive enable calibrate-channel mode scheduled calibrate-channel monitoring time-range TimeRange_sample interference-threshold 10 crc-error-threshold 10 tolerance-level 15 calibrate-power self-decisive enable calibrate-power mode density radio 2 radio enable service-template st_182381246194939 bandwidth-guarantee enable rrm calibrate-channel self-decisive enable calibrate-channel mode scheduled calibrate-channel monitoring time-range TimeRange_sample interference-threshold 10 crc-error-threshold 10 tolerance-level 15 calibrate-power self-decisive enable calibrate-power mode density gigabitethernet 1 ap-model WAP722X-W2 radio 1 radio enable service-template st_182381246194939 bandwidth-guarantee enable rrm calibrate-channel self-decisive enable calibrate-channel mode scheduled calibrate-channel monitoring time-range TimeRange_sample interference-threshold 10 crc-error-threshold 10 tolerance-level 15 calibrate-power self-decisive enable calibrate-power mode density radio 2 radio enable service-template st_182381246194939 bandwidth-guarantee enable rrm calibrate-channel self-decisive enable calibrate-channel mode scheduled calibrate-channel monitoring time-range TimeRange_sample interference-threshold 10 crc-error-threshold 10 tolerance-level 15 calibrate-power self-decisive enable calibrate-power mode density gigabitethernet 1 gigabitethernet 2 gigabitethernet 3 ap-model WAP723-W2 radio 1 radio enable service-template st_182381246194939 bandwidth-guarantee enable rrm calibrate-channel self-decisive enable calibrate-channel mode scheduled calibrate-channel monitoring time-range TimeRange_sample interference-threshold 10 crc-error-threshold 10 tolerance-level 15 calibrate-power self-decisive enable calibrate-power mode density radio 2 radio enable service-template st_182381246194939 bandwidth-guarantee enable rrm calibrate-channel self-decisive enable calibrate-channel mode scheduled calibrate-channel monitoring time-range TimeRange_sample interference-threshold 10 crc-error-threshold 10 tolerance-level 15 calibrate-power self-decisive enable calibrate-power mode density radio 3 radio enable service-template st_182381246194939 bandwidth-guarantee enable rrm calibrate-channel self-decisive enable calibrate-channel mode scheduled calibrate-channel monitoring time-range TimeRange_sample interference-threshold 10 crc-error-threshold 10 tolerance-level 15 calibrate-power self-decisive enable calibrate-power mode density module 1 gigabitethernet 1 gigabitethernet 2 # wlan ap 00be-d5b3-9800 model WAP712H serial-id 219801A1B69206Q0030B vlan 1 radio 1 radio 2 ethernet 1 ethernet 2 ethernet 3 # wlan ap 00be-d5b3-9880 model WAP712H serial-id 219801A1B69206Q0030G vlan 1 radio 1 radio 2 ethernet 1 ethernet 2 ethernet 3 # wlan ap 00be-d5b3-9920 model WAP712H serial-id 219801A1B69206Q0030M vlan 1 radio 1 radio 2 ethernet 1 ethernet 2 ethernet 3 # wlan ap 00be-d5b3-98c0 model WAP712H serial-id 219801A1B69206Q0030J vlan 1 radio 1 radio 2 ethernet 1 ethernet 2 ethernet 3 # wlan ap 00be-d5b3-9ae0 model WAP712H serial-id 219801A1B69206Q00312 vlan 1 radio 1 radio 2 ethernet 1 ethernet 2 ethernet 3 # wlan ap 00be-d5b3-a480 model WAP712H serial-id 219801A1B69206Q0033K vlan 1 radio 1 radio 2 ethernet 1 ethernet 2 ethernet 3 # wlan ap 00be-d5b3-a640 model WAP712H serial-id 219801A1B69206Q00340 vlan 1 radio 1 radio 2 ethernet 1 ethernet 2 ethernet 3 # wlan ap 00be-d5b3-a1a0 model WAP712H serial-id 219801A1B69206Q0032T vlan 1 radio 1 radio 2 ethernet 1 ethernet 2 ethernet 3 # wlan ap 00be-d5b3-a4a0 model WAP712H serial-id 219801A1B69206Q0033L vlan 1 radio 1 radio 2 ethernet 1 ethernet 2 ethernet 3 # wlan ap 00be-d5b3-ab80 model WAP712H serial-id 219801A1B69206Q0035C vlan 1 radio 1 radio 2 ethernet 1 ethernet 2 ethernet 3 # wlan ap 00be-d5b3-ad40 model WAP712H serial-id 219801A1B69206Q0035T vlan 1 radio 1 radio 2 ethernet 1 ethernet 2 ethernet 3 # wlan ap 00be-d5b3-af40 model WAP712H serial-id 219801A1B69206Q0036B vlan 1 radio 1 radio 2 ethernet 1 ethernet 2 ethernet 3 # wlan ap 00be-d5b4-0000 model WAP712H serial-id 219801A1B69206Q003W5 vlan 1 radio 1 radio 2 ethernet 1 ethernet 2 ethernet 3 # wlan ap 00be-d5b4-0220 model WAP712H serial-id 219801A1B69206Q003WQ vlan 1 radio 1 radio 2 ethernet 1 ethernet 2 ethernet 3 # wlan ap 00be-d5b4-03c0 model WAP712H serial-id 219801A1B69206Q003X4 vlan 1 radio 1 radio 2 ethernet 1 ethernet 2 ethernet 3 # wlan ap 943b-b051-1740 model WAP712C-LI serial-id 219801A1Y78206P000GM vlan 1 radio 1 radio 2 gigabitethernet 1 # wlan ap 943b-b051-1750 model WAP712C-LI serial-id 219801A1Y78206P000GN vlan 1 radio 1 radio 2 gigabitethernet 1 # wlan ap 943b-b051-2320 model WAP712C-LI serial-id 219801A1Y78206P000NR vlan 1 radio 1 radio 2 gigabitethernet 1 # wlan ap 943b-b051-2370 model WAP712C-LI serial-id 219801A1Y78206P000NX vlan 1 radio 1 radio 2 gigabitethernet 1 # wlan ap 943b-b051-2420 model WAP712C-LI serial-id 219801A1Y78206P000P8 vlan 1 radio 1 radio 2 gigabitethernet 1 # wlan ap 943b-b051-2520 model WAP712C-LI serial-id 219801A1Y78206P000PS vlan 1 radio 1 radio 2 gigabitethernet 1 # wlan ap 943b-b051-5330 model WAP712C-LI serial-id 219801A1Y78206P001GK vlan 1 radio 1 radio 2 gigabitethernet 1 # wlan ap 943b-b051-18b0 model WAP712C-LI serial-id 219801A1Y78206P000HC vlan 1 radio 1 radio 2 gigabitethernet 1 # wlan ap 943b-b051-67f0 model WAP712C-LI serial-id 219801A1Y78206P001T8 vlan 1 radio 1 radio 2 gigabitethernet 1 # wlan ap 943b-b051-c490 model WAP712C-LI serial-id 219801A1Y78206P003C2 vlan 1 radio 1 radio 2 gigabitethernet 1 # wlan ap 943b-b051-ca80 model WAP712C-LI serial-id 219801A1Y78206P003G4 vlan 1 radio 1 radio 2 gigabitethernet 1 # wlan ap 943b-b051-ce20 model WAP712C-LI serial-id 219801A1Y78206P003J0 vlan 1 radio 1 radio 2 gigabitethernet 1 # wlan ap 943b-b051-d200 model WAP712C-LI serial-id 219801A1Y78206P003L0 vlan 1 radio 1 radio 2 gigabitethernet 1 # wlan ap 943b-b051-d340 model WAP712C-LI serial-id 219801A1Y78206P003LN vlan 1 radio 1 radio 2 gigabitethernet 1 # wlan ap 943b-b051-e670 model WAP712C-LI serial-id 219801A1Y78206P003XK vlan 1 radio 1 radio 2 gigabitethernet 1 # wlan ap 943b-b052-1190 model WAP712C-LI serial-id 219801A1Y78206P004MT vlan 1 radio 1 radio 2 gigabitethernet 1 # wlan drs enable # cloud-management server domain oasis.h3c.com # return ============================================================= ===============display saved-cOnfiguration=============== # version 7.1.064, Release 5272 # sysname XLL-R # clock timezone Beijing add 08:00:00 # telnet server enable # port-security enable # dialer-group 1 rule ip permit # ip redirects enable ip unreachables enable ip ttl-expires enable # nat alg h323 nat alg ils nat alg mgcp nat alg nbt nat alg rsh nat alg sccp nat alg sip nat alg sqlnet nat alg tftp nat alg xdmcp # dhcp enable # dns proxy enable ip host oauthindev.h3c.com 192.168.0.100 ip host www.spiritapp-wlan-ac.h3c.com 192.168.0.100 ip host XLL-R 192.168.0.100 # lldp global enable # module-proxy work-mode route module-proxy sample-description {"mode":"5","startTime":"10T00","endTime":"14T00","adjustTime":"2T00"} # password-recovery enable # vlan 1 # vlan 10 description HL-TP # vlan 100 # dhcp server ip-pool 1 gateway-list 192.168.0.100 network 192.168.0.0 mask 255.255.248.0 address range 192.168.0.0 192.168.0.254 dns-list 192.168.0.100 # dhcp server ip-pool 100 gateway-list 172.16.100.1 network 172.16.100.0 mask 255.255.252.0 dns-list 202.99.224.67 202.99.224.68 # nqa entry xiaobei test type http frequency 5000 history-record enable history-record number 1 probe timeout 500 url http://www.baidu.com # nqa schedule xiaobei test start-time now lifetime forever # wlan service-template st_182381246194939 description 1 ssid XLL vlan 100 client max-count 10 akm mode psk preshared-key pass-phrase cipher $c$3$1IcHKhJjn4P/ocMLLb5HNN9TicyCyCAAzdcZwYAO cipher-suite ccmp cipher-suite tkip security-ie rsn security-ie wpa service-template enable # controller Cellular1/0/9 # interface Dialer1 mtu 1492 ppp ipcp dns admit-any ppp ipcp dns request dialer bundle enable dialer-group 1 dialer timer idle 0 dialer timer autodial 60 ip address ppp-negotiate tcp mss 1452 nat outbound # interface Dialer2 mtu 1492 ppp ipcp dns admit-any ppp ipcp dns request dialer bundle enable dialer-group 1 dialer timer idle 0 dialer timer autodial 60 ip address ppp-negotiate tcp mss 1452 nat outbound # interface Dialer3 mtu 1492 ppp ipcp dns admit-any ppp ipcp dns request dialer bundle enable dialer-group 1 dialer timer idle 0 dialer timer autodial 60 ip address ppp-negotiate tcp mss 1452 nat outbound # interface Dialer4 mtu 1492 ppp ipcp dns admit-any ppp ipcp dns request dialer bundle enable dialer-group 1 dialer timer idle 0 dialer timer autodial 60 ip address ppp-negotiate tcp mss 1452 nat outbound # interface Dialer5 mtu 1492 ppp ipcp dns admit-any ppp ipcp dns request dialer bundle enable dialer-group 1 dialer timer idle 0 dialer timer autodial 60 ip address ppp-negotiate tcp mss 1452 nat outbound # interface Dialer6 mtu 1492 ppp ipcp dns admit-any ppp ipcp dns request dialer bundle enable dialer-group 1 dialer timer idle 0 dialer timer autodial 60 ip address ppp-negotiate tcp mss 1452 nat outbound # interface Dialer7 mtu 1492 ppp ipcp dns admit-any ppp ipcp dns request dialer bundle enable dialer-group 1 dialer timer idle 0 dialer timer autodial 60 ip address ppp-negotiate tcp mss 1452 nat outbound # interface Dialer8 mtu 1492 ppp ipcp dns admit-any ppp ipcp dns request dialer bundle enable dialer-group 1 dialer timer idle 0 dialer timer autodial 60 ip address ppp-negotiate tcp mss 1452 nat outbound # interface NULL0 # interface Vlan-interface1 ip address 192.168.0.100 255.255.248.0 # interface Vlan-interface10 description HL-TP ip address 10.12.1.1 255.255.255.252 # interface Vlan-interface100 description YW ip address 172.16.100.1 255.255.252.0 # interface GigabitEthernet1/0/7 port link-mode route description GigabitEthernet1/0/7 ip address 61.138.113.174 255.255.255.248 nat outbound undo dhcp select server # interface GigabitEthernet1/0/8 port link-mode route nat outbound undo dhcp select server # interface GigabitEthernet1/0/1 port link-mode bridge # interface GigabitEthernet1/0/2 port link-mode bridge port link-type trunk port trunk permit vlan all # interface GigabitEthernet1/0/3 port link-mode bridge port link-type trunk port trunk permit vlan all # interface GigabitEthernet1/0/4 port link-mode bridge port link-type trunk port trunk permit vlan all # interface GigabitEthernet1/0/5 port link-mode bridge port access vlan 10 # interface GigabitEthernet1/0/6 port link-mode bridge # scheduler logfile size 16 # scheduler job Job_adjust command 1 wlan calibrate-channel pronto ap all # scheduler schedule Schedule_adjust user-role network-admin job Job_adjust time repeating at 02:00 week-day Mon Tue Wed Thu Fri # line class console user-role network-admin # line class vty user-role network-operator # line con 0 authentication-mode scheme user-role network-admin # line vty 0 31 authentication-mode scheme user-role network-operator # ip route-static 0.0.0.0 0 GigabitEthernet1/0/7 61.138.113.169 # undo info-center logfile enable # ssh server enable sftp server enable scp server enable # nqa server enable # time-range TimeRange_sample 10:00 to 14:00 working-day # ntp-service enable ntp-service unicast-server ***.*** # domain cloud authentication portal none authorization portal none accounting portal none # domain extend-auth authentication portal none authorization portal none accounting portal none # domain system # domain default enable system # role name level-0 description Predefined level-0 role # role name level-1 description Predefined level-1 role # role name level-2 description Predefined level-2 role # role name level-3 description Predefined level-3 role # role name level-4 description Predefined level-4 role # role name level-5 description Predefined level-5 role # role name level-6 description Predefined level-6 role # role name level-7 description Predefined level-7 role # role name level-8 description Predefined level-8 role # role name level-9 description Predefined level-9 role # role name level-10 description Predefined level-10 role # role name level-11 description Predefined level-11 role # role name level-12 description Predefined level-12 role # role name level-13 description Predefined level-13 role # role name level-14 description Predefined level-14 role # user-group system # local-user admin class manage password hash $h$6$N15emMVjw80PuxB9$OAq5vHjdw/teGZmV9eMuYRvKOZmtLNyq4gsMYj5UeE3ZWROu+dft3Aife20X3JKtc49SFK/xenTGoKUd5zM+UQ== service-type ssh telnet terminal http https authorization-attribute user-role network-admin # session statistics enable # portal host-check enable portal free-rule 2 destination ip any udp 53 portal free-rule 3 destination ip any tcp 53 portal free-rule 4 destination short.weixin.qq.com portal free-rule 5 destination mp.weixin.qq.com portal free-rule 6 destination long.weixin.qq.com portal free-rule 7 destination dns.weixin.qq.com portal free-rule 8 destination minorshort.weixin.qq.com portal free-rule 9 destination extshort.weixin.qq.com portal free-rule 10 destination szshort.weixin.qq.com portal free-rule 11 destination szlong.weixin.qq.com portal free-rule 12 destination szextshort.weixin.qq.com portal free-rule 13 destination ***.*** portal free-rule 14 destination wifi.weixin.qq.com # portal web-server 1 url http://192.168.0.100 # portal web-server local-server url https://192.168.0.100/portal # portal web-server lvzhou-server url http://oasisauth.h3c.com/portal/protocol server-type oauth # portal local-web-server http # portal local-web-server https # portal extend-auth-server qq # portal extend-auth-server mail mail-protocol pop3 imap # ip http enable ip https enable # url-filter policy drs default-action permit # app-profile drs url-filter apply policy drs # wlan rrm calibration-power interval 30 # wlan auto-ap enable wlan auto-persistent enable # wlan global-configuration # wlan ap-group default-group vlan 1 ap-model SPM-X1-10 gigabitethernet 1 gigabitethernet 2 gigabitethernet 3 gigabitethernet 4 gigabitethernet 5 gigabitethernet 6 gigabitethernet 7 gigabitethernet 8 gigabitethernet 9 gigabitethernet 10 gigabitethernet 11 gigabitethernet 12 ap-model SPM-X1-24 gigabitethernet 1 gigabitethernet 2 gigabitethernet 3 gigabitethernet 4 gigabitethernet 5 gigabitethernet 6 gigabitethernet 7 gigabitethernet 8 gigabitethernet 9 gigabitethernet 10 gigabitethernet 11 gigabitethernet 12 gigabitethernet 13 gigabitethernet 14 gigabitethernet 15 gigabitethernet 16 gigabitethernet 17 gigabitethernet 18 gigabitethernet 19 gigabitethernet 20 gigabitethernet 21 gigabitethernet 22 gigabitethernet 23 gigabitethernet 24 ap-model WAP711H radio 1 radio enable service-template st_182381246194939 bandwidth-guarantee enable rrm calibrate-channel self-decisive enable calibrate-channel mode scheduled calibrate-channel monitoring time-range TimeRange_sample interference-threshold 10 crc-error-threshold 10 tolerance-level 15 calibrate-power self-decisive enable calibrate-power mode density ethernet 1 ethernet 2 ethernet 3 ap-model WAP712C radio 1 radio enable service-template st_182381246194939 bandwidth-guarantee enable rrm calibrate-channel self-decisive enable calibrate-channel mode scheduled calibrate-channel monitoring time-range TimeRange_sample interference-threshold 10 crc-error-threshold 10 tolerance-level 15 calibrate-power self-decisive enable calibrate-power mode density radio 2 radio enable service-template st_182381246194939 bandwidth-guarantee enable rrm calibrate-channel self-decisive enable calibrate-channel mode scheduled calibrate-channel monitoring time-range TimeRange_sample interference-threshold 10 crc-error-threshold 10 tolerance-level 15 calibrate-power self-decisive enable calibrate-power mode density gigabitethernet 1 ap-model WAP712C-HI radio 1 radio enable service-template st_182381246194939 bandwidth-guarantee enable rrm calibrate-channel self-decisive enable calibrate-channel mode scheduled calibrate-channel monitoring time-range TimeRange_sample interference-threshold 10 crc-error-threshold 10 tolerance-level 15 calibrate-power self-decisive enable calibrate-power mode density radio 2 radio enable service-template st_182381246194939 bandwidth-guarantee enable rrm calibrate-channel self-decisive enable calibrate-channel mode scheduled calibrate-channel monitoring time-range TimeRange_sample interference-threshold 10 crc-error-threshold 10 tolerance-level 15 calibrate-power self-decisive enable calibrate-power mode density gigabitethernet 1 ap-model WAP712C-LI radio 1 radio enable service-template st_182381246194939 bandwidth-guarantee enable rrm calibrate-channel self-decisive enable calibrate-channel mode scheduled calibrate-channel monitoring time-range TimeRange_sample interference-threshold 10 crc-error-threshold 10 tolerance-level 15 calibrate-power self-decisive enable calibrate-power mode density radio 2 radio enable service-template st_182381246194939 bandwidth-guarantee enable rrm calibrate-channel self-decisive enable calibrate-channel mode scheduled calibrate-channel monitoring time-range TimeRange_sample interference-threshold 10 crc-error-threshold 10 tolerance-level 15 calibrate-power self-decisive enable calibrate-power mode density gigabitethernet 1 ap-model WAP712E radio 1 radio enable service-template st_182381246194939 bandwidth-guarantee enable rrm calibrate-channel self-decisive enable calibrate-channel mode scheduled calibrate-channel monitoring time-range TimeRange_sample interference-threshold 10 crc-error-threshold 10 tolerance-level 15 calibrate-power self-decisive enable calibrate-power mode density radio 2 radio enable service-template st_182381246194939 bandwidth-guarantee enable rrm calibrate-channel self-decisive enable calibrate-channel mode scheduled calibrate-channel monitoring time-range TimeRange_sample interference-threshold 10 crc-error-threshold 10 tolerance-level 15 calibrate-power self-decisive enable calibrate-power mode density gigabitethernet 1 ap-model WAP712H radio 1 radio enable service-template st_182381246194939 bandwidth-guarantee enable rrm calibrate-channel self-decisive enable calibrate-channel mode scheduled calibrate-channel monitoring time-range TimeRange_sample interference-threshold 10 crc-error-threshold 10 tolerance-level 15 calibrate-power self-decisive enable calibrate-power mode density radio 2 radio enable service-template st_182381246194939 bandwidth-guarantee enable rrm calibrate-channel self-decisive enable calibrate-channel mode scheduled calibrate-channel monitoring time-range TimeRange_sample interference-threshold 10 crc-error-threshold 10 tolerance-level 15 calibrate-power self-decisive enable calibrate-power mode density ethernet 1 ethernet 2 ethernet 3 ap-model WAP722 radio 1 radio enable service-template st_182381246194939 bandwidth-guarantee enable rrm calibrate-channel self-decisive enable calibrate-channel mode scheduled calibrate-channel monitoring time-range TimeRange_sample interference-threshold 10 crc-error-threshold 10 tolerance-level 15 calibrate-power self-decisive enable calibrate-power mode density radio 2 radio enable service-template st_182381246194939 bandwidth-guarantee enable rrm calibrate-channel self-decisive enable calibrate-channel mode scheduled calibrate-channel monitoring time-range TimeRange_sample interference-threshold 10 crc-error-threshold 10 tolerance-level 15 calibrate-power self-decisive enable calibrate-power mode density gigabitethernet 1 gigabitethernet 2 ap-model WAP722E radio 1 radio enable service-template st_182381246194939 bandwidth-guarantee enable rrm calibrate-channel self-decisive enable calibrate-channel mode scheduled calibrate-channel monitoring time-range TimeRange_sample interference-threshold 10 crc-error-threshold 10 tolerance-level 15 calibrate-power self-decisive enable calibrate-power mode density radio 2 radio enable service-template st_182381246194939 bandwidth-guarantee enable rrm calibrate-channel self-decisive enable calibrate-channel mode scheduled calibrate-channel monitoring time-range TimeRange_sample interference-threshold 10 crc-error-threshold 10 tolerance-level 15 calibrate-power self-decisive enable calibrate-power mode density gigabitethernet 1 gigabitethernet 2 ap-model WAP722E-W2 radio 1 radio enable service-template st_182381246194939 bandwidth-guarantee enable rrm calibrate-channel self-decisive enable calibrate-channel mode scheduled calibrate-channel monitoring time-range TimeRange_sample interference-threshold 10 crc-error-threshold 10 tolerance-level 15 calibrate-power self-decisive enable calibrate-power mode density radio 2 radio enable service-template st_182381246194939 bandwidth-guarantee enable rrm calibrate-channel self-decisive enable calibrate-channel mode scheduled calibrate-channel monitoring time-range TimeRange_sample interference-threshold 10 crc-error-threshold 10 tolerance-level 15 calibrate-power self-decisive enable calibrate-power mode density gigabitethernet 1 gigabitethernet 2 ap-model WAP722H radio 1 radio enable service-template st_182381246194939 bandwidth-guarantee enable rrm calibrate-channel self-decisive enable calibrate-channel mode scheduled calibrate-channel monitoring time-range TimeRange_sample interference-threshold 10 crc-error-threshold 10 tolerance-level 15 calibrate-power self-decisive enable calibrate-power mode density radio 2 radio enable service-template st_182381246194939 bandwidth-guarantee enable rrm calibrate-channel self-decisive enable calibrate-channel mode scheduled calibrate-channel monitoring time-range TimeRange_sample interference-threshold 10 crc-error-threshold 10 tolerance-level 15 calibrate-power self-decisive enable calibrate-power mode density gigabitethernet 1 gigabitethernet 2 gigabitethernet 3 gigabitethernet 4 gigabitethernet 5 ap-model WAP722S radio 1 radio enable service-template st_182381246194939 bandwidth-guarantee enable rrm calibrate-channel self-decisive enable calibrate-channel mode scheduled calibrate-channel monitoring time-range TimeRange_sample interference-threshold 10 crc-error-threshold 10 tolerance-level 15 calibrate-power self-decisive enable calibrate-power mode density radio 2 radio enable service-template st_182381246194939 bandwidth-guarantee enable rrm calibrate-channel self-decisive enable calibrate-channel mode scheduled calibrate-channel monitoring time-range TimeRange_sample interference-threshold 10 crc-error-threshold 10 tolerance-level 15 calibrate-power self-decisive enable calibrate-power mode density gigabitethernet 1 ap-model WAP722S-W2 radio 1 radio enable service-template st_182381246194939 bandwidth-guarantee enable rrm calibrate-channel self-decisive enable calibrate-channel mode scheduled calibrate-channel monitoring time-range TimeRange_sample interference-threshold 10 crc-error-threshold 10 tolerance-level 15 calibrate-power self-decisive enable calibrate-power mode density radio 2 radio enable service-template st_182381246194939 bandwidth-guarantee enable rrm calibrate-channel self-decisive enable calibrate-channel mode scheduled calibrate-channel monitoring time-range TimeRange_sample interference-threshold 10 crc-error-threshold 10 tolerance-level 15 calibrate-power self-decisive enable calibrate-power mode density gigabitethernet 1 ap-model WAP722X-W2 radio 1 radio enable service-template st_182381246194939 bandwidth-guarantee enable rrm calibrate-channel self-decisive enable calibrate-channel mode scheduled calibrate-channel monitoring time-range TimeRange_sample interference-threshold 10 crc-error-threshold 10 tolerance-level 15 calibrate-power self-decisive enable calibrate-power mode density radio 2 radio enable service-template st_182381246194939 bandwidth-guarantee enable rrm calibrate-channel self-decisive enable calibrate-channel mode scheduled calibrate-channel monitoring time-range TimeRange_sample interference-threshold 10 crc-error-threshold 10 tolerance-level 15 calibrate-power self-decisive enable calibrate-power mode density gigabitethernet 1 gigabitethernet 2 gigabitethernet 3 ap-model WAP723-W2 radio 1 radio enable service-template st_182381246194939 bandwidth-guarantee enable rrm calibrate-channel self-decisive enable calibrate-channel mode scheduled calibrate-channel monitoring time-range TimeRange_sample interference-threshold 10 crc-error-threshold 10 tolerance-level 15 calibrate-power self-decisive enable calibrate-power mode density radio 2 radio enable service-template st_182381246194939 bandwidth-guarantee enable rrm calibrate-channel self-decisive enable calibrate-channel mode scheduled calibrate-channel monitoring time-range TimeRange_sample interference-threshold 10 crc-error-threshold 10 tolerance-level 15 calibrate-power self-decisive enable calibrate-power mode density radio 3 radio enable service-template st_182381246194939 bandwidth-guarantee enable rrm calibrate-channel self-decisive enable calibrate-channel mode scheduled calibrate-channel monitoring time-range TimeRange_sample interference-threshold 10 crc-error-threshold 10 tolerance-level 15 calibrate-power self-decisive enable calibrate-power mode density module 1 gigabitethernet 1 gigabitethernet 2 # wlan ap 00be-d5b3-9800 model WAP712H serial-id 219801A1B69206Q0030B vlan 1 radio 1 radio 2 ethernet 1 ethernet 2 ethernet 3 # wlan ap 00be-d5b3-9880 model WAP712H serial-id 219801A1B69206Q0030G vlan 1 radio 1 radio 2 ethernet 1 ethernet 2 ethernet 3 # wlan ap 00be-d5b3-9920 model WAP712H serial-id 219801A1B69206Q0030M vlan 1 radio 1 radio 2 ethernet 1 ethernet 2 ethernet 3 # wlan ap 00be-d5b3-98c0 model WAP712H serial-id 219801A1B69206Q0030J vlan 1 radio 1 radio 2 ethernet 1 ethernet 2 ethernet 3 # wlan ap 00be-d5b3-9ae0 model WAP712H serial-id 219801A1B69206Q00312 vlan 1 radio 1 radio 2 ethernet 1 ethernet 2 ethernet 3 # wlan ap 00be-d5b3-a480 model WAP712H serial-id 219801A1B69206Q0033K vlan 1 radio 1 radio 2 ethernet 1 ethernet 2 ethernet 3 # wlan ap 00be-d5b3-a640 model WAP712H serial-id 219801A1B69206Q00340 vlan 1 radio 1 radio 2 ethernet 1 ethernet 2 ethernet 3 # wlan ap 00be-d5b3-a1a0 model WAP712H serial-id 219801A1B69206Q0032T vlan 1 radio 1 radio 2 ethernet 1 ethernet 2 ethernet 3 # wlan ap 00be-d5b3-a4a0 model WAP712H serial-id 219801A1B69206Q0033L vlan 1 radio 1 radio 2 ethernet 1 ethernet 2 ethernet 3 # wlan ap 00be-d5b3-ab80 model WAP712H serial-id 219801A1B69206Q0035C vlan 1 radio 1 radio 2 ethernet 1 ethernet 2 ethernet 3 # wlan ap 00be-d5b3-ad40 model WAP712H serial-id 219801A1B69206Q0035T vlan 1 radio 1 radio 2 ethernet 1 ethernet 2 ethernet 3 # wlan ap 00be-d5b3-af40 model WAP712H serial-id 219801A1B69206Q0036B vlan 1 radio 1 radio 2 ethernet 1 ethernet 2 ethernet 3 # wlan ap 00be-d5b4-0000 model WAP712H serial-id 219801A1B69206Q003W5 vlan 1 radio 1 radio 2 ethernet 1 ethernet 2 ethernet 3 # wlan ap 00be-d5b4-0220 model WAP712H serial-id 219801A1B69206Q003WQ vlan 1 radio 1 radio 2 ethernet 1 ethernet 2 ethernet 3 # wlan ap 00be-d5b4-03c0 model WAP712H serial-id 219801A1B69206Q003X4 vlan 1 radio 1 radio 2 ethernet 1 ethernet 2 ethernet 3 # wlan ap 943b-b051-1740 model WAP712C-LI serial-id 219801A1Y78206P000GM vlan 1 radio 1 radio 2 gigabitethernet 1 # wlan ap 943b-b051-1750 model WAP712C-LI serial-id 219801A1Y78206P000GN vlan 1 radio 1 radio 2 gigabitethernet 1 # wlan ap 943b-b051-2320 model WAP712C-LI serial-id 219801A1Y78206P000NR vlan 1 radio 1 radio 2 gigabitethernet 1 # wlan ap 943b-b051-2370 model WAP712C-LI serial-id 219801A1Y78206P000NX vlan 1 radio 1 radio 2 gigabitethernet 1 # wlan ap 943b-b051-2420 model WAP712C-LI serial-id 219801A1Y78206P000P8 vlan 1 radio 1 radio 2 gigabitethernet 1 # wlan ap 943b-b051-2520 model WAP712C-LI serial-id 219801A1Y78206P000PS vlan 1 radio 1 radio 2 gigabitethernet 1 # wlan ap 943b-b051-5330 model WAP712C-LI serial-id 219801A1Y78206P001GK vlan 1 radio 1 radio 2 gigabitethernet 1 # wlan ap 943b-b051-18b0 model WAP712C-LI serial-id 219801A1Y78206P000HC vlan 1 radio 1 radio 2 gigabitethernet 1 # wlan ap 943b-b051-67f0 model WAP712C-LI serial-id 219801A1Y78206P001T8 vlan 1 radio 1 radio 2 gigabitethernet 1 # wlan ap 943b-b051-c490 model WAP712C-LI serial-id 219801A1Y78206P003C2 vlan 1 radio 1 radio 2 gigabitethernet 1 # wlan ap 943b-b051-ca80 model WAP712C-LI serial-id 219801A1Y78206P003G4 vlan 1 radio 1 radio 2 gigabitethernet 1 # wlan ap 943b-b051-ce20 model WAP712C-LI serial-id 219801A1Y78206P003J0 vlan 1 radio 1 radio 2 gigabitethernet 1 # wlan ap 943b-b051-d200 model WAP712C-LI serial-id 219801A1Y78206P003L0 vlan 1 radio 1 radio 2 gigabitethernet 1 # wlan ap 943b-b051-d340 model WAP712C-LI serial-id 219801A1Y78206P003LN vlan 1 radio 1 radio 2 gigabitethernet 1 # wlan ap 943b-b051-e670 model WAP712C-LI serial-id 219801A1Y78206P003XK vlan 1 radio 1 radio 2 gigabitethernet 1 # wlan ap 943b-b052-1190 model WAP712C-LI serial-id 219801A1Y78206P004MT vlan 1 radio 1 radio 2 gigabitethernet 1 # wlan drs enable # cloud-management server domain oasis.h3c.com # return =================================================== ===============display interface=============== Dialer1 Current state: UP Line protocol state: UP(spoofing) Description: Dialer1 Interface Bandwidth: 64 kbps Maximum transmission unit: 1492 Hold timer: 10 seconds, retry times: 5 Internet protocol processing: Disabled Link layer protocol: PPP LCP: initial Physical: Dialer, baudrate: 64000 bps Last clearing of counters: Never Last 300 seconds input rate: 0 bytes/sec, 0 bits/sec, 0 packets/sec Last 300 seconds output rate: 0 bytes/sec, 0 bits/sec, 0 packets/sec Input: 0 packets, 0 bytes, 0 drops Output: 0 packets, 0 bytes, 0 drops Dialer2 Current state: UP Line protocol state: UP(spoofing) Description: Dialer2 Interface Bandwidth: 64 kbps Maximum transmission unit: 1492 Hold timer: 10 seconds, retry times: 5 Internet protocol processing: Disabled Link layer protocol: PPP LCP: initial Physical: Dialer, baudrate: 64000 bps Last clearing of counters: Never Last 300 seconds input rate: 0 bytes/sec, 0 bits/sec, 0 packets/sec Last 300 seconds output rate: 0 bytes/sec, 0 bits/sec, 0 packets/sec Input: 0 packets, 0 bytes, 0 drops Output: 0 packets, 0 bytes, 0 drops Dialer3 Current state: UP Line protocol state: UP(spoofing) Description: Dialer3 Interface Bandwidth: 64 kbps Maximum transmission unit: 1492 Hold timer: 10 seconds, retry times: 5 Internet protocol processing: Disabled Link layer protocol: PPP LCP: initial Physical: Dialer, baudrate: 64000 bps Last clearing of counters: Never Last 300 seconds input rate: 0 bytes/sec, 0 bits/sec, 0 packets/sec Last 300 seconds output rate: 0 bytes/sec, 0 bits/sec, 0 packets/sec Input: 0 packets, 0 bytes, 0 drops Output: 0 packets, 0 bytes, 0 drops Dialer4 Current state: UP Line protocol state: UP(spoofing) Description: Dialer4 Interface Bandwidth: 64 kbps Maximum transmission unit: 1492 Hold timer: 10 seconds, retry times: 5 Internet protocol processing: Disabled Link layer protocol: PPP LCP: initial Physical: Dialer, baudrate: 64000 bps Last clearing of counters: Never Last 300 seconds input rate: 0 bytes/sec, 0 bits/sec, 0 packets/sec Last 300 seconds output rate: 0 bytes/sec, 0 bits/sec, 0 packets/sec Input: 0 packets, 0 bytes, 0 drops Output: 0 packets, 0 bytes, 0 drops Dialer5 Current state: UP Line protocol state: UP(spoofing) Description: Dialer5 Interface Bandwidth: 64 kbps Maximum transmission unit: 1492 Hold timer: 10 seconds, retry times: 5 Internet protocol processing: Disabled Link layer protocol: PPP LCP: initial Physical: Dialer, baudrate: 64000 bps Last clearing of counters: Never Last 300 seconds input rate: 0 bytes/sec, 0 bits/sec, 0 packets/sec Last 300 seconds output rate: 0 bytes/sec, 0 bits/sec, 0 packets/sec Input: 0 packets, 0 bytes, 0 drops Output: 0 packets, 0 bytes, 0 drops Dialer6 Current state: UP Line protocol state: UP(spoofing) Description: Dialer6 Interface Bandwidth: 64 kbps Maximum transmission unit: 1492 Hold timer: 10 seconds, retry times: 5 Internet protocol processing: Disabled Link layer protocol: PPP LCP: initial Physical: Dialer, baudrate: 64000 bps Last clearing of counters: Never Last 300 seconds input rate: 0 bytes/sec, 0 bits/sec, 0 packets/sec Last 300 seconds output rate: 0 bytes/sec, 0 bits/sec, 0 packets/sec Input: 0 packets, 0 bytes, 0 drops Output: 0 packets, 0 bytes, 0 drops Dialer7 Current state: UP Line protocol state: UP(spoofing) Description: Dialer7 Interface Bandwidth: 64 kbps Maximum transmission unit: 1492 Hold timer: 10 seconds, retry times: 5 Internet protocol processing: Disabled Link layer protocol: PPP LCP: initial Physical: Dialer, baudrate: 64000 bps Last clearing of counters: Never Last 300 seconds input rate: 0 bytes/sec, 0 bits/sec, 0 packets/sec Last 300 seconds output rate: 0 bytes/sec, 0 bits/sec, 0 packets/sec Input: 0 packets, 0 bytes, 0 drops Output: 0 packets, 0 bytes, 0 drops Dialer8 Current state: UP Line protocol state: UP(spoofing) Description: Dialer8 Interface Bandwidth: 64 kbps Maximum transmission unit: 1492 Hold timer: 10 seconds, retry times: 5 Internet protocol processing: Disabled Link layer protocol: PPP LCP: initial Physical: Dialer, baudrate: 64000 bps Last clearing of counters: Never Last 300 seconds input rate: 0 bytes/sec, 0 bits/sec, 0 packets/sec Last 300 seconds output rate: 0 bytes/sec, 0 bits/sec, 0 packets/sec Input: 0 packets, 0 bytes, 0 drops Output: 0 packets, 0 bytes, 0 drops GigabitEthernet1/0/1 Current state: UP Line protocol state: UP IP packet frame type: Ethernet II, hardware address: 905d-7c18-dcf1 Description: GigabitEthernet1/0/1 Interface Bandwidth: 1000000 kbps Loopback is not set Media type is twisted pair, promiscuous mode set 1000Mbps-speed mode, full-duplex mode Link speed type is autonegotiation, link duplex type is autonegotiation Flow-control is not enabled Maximum frame length: 4000 Allow jumbo frames to pass Broadcast max-ratio: 100% Multicast max-ratio: 100% Unicast max-ratio: 100% PVID: 1 Port link-type: Access Tagged VLANs: None Untagged VLANs: 1 Port priority: 0 Last link flapping: 0 hours 58 minutes 15 seconds Last clearing of counters: Never Last 300 second input: 2664 packets/sec 2262122 bytes/sec 1% Last 300 second output: 795 packets/sec 238513 bytes/sec 0% Input (total): 8041596 packets, 6316280730 bytes 7927582 unicasts, 36599 broadcasts, 77415 multicasts, 0 pauses Input (normal): 8041596 packets, 6316280730 bytes 7927582 unicasts, 36599 broadcasts, 77415 multicasts, 0 pauses Input: 0 input errors, 0 runts, 0 giants, - throttles 0 CRC, - frame, 0 overruns, 0 aborts - ignored, - parity errors Output (total): 3389388 packets, 1798393295 bytes 3388606 unicasts, 624 broadcasts, 158 multicasts, 0 pauses Output (normal): 3389388 packets, 1798393295 bytes 3388606 unicasts, 624 broadcasts, 158 multicasts, 0 pauses Output: 0 output errors, 0 underruns, - buffer failures - aborts, 0 deferred, 0 collisions, 0 late collisions - lost carrier, - no carrier GigabitEthernet1/0/2 Current state: UP Line protocol state: UP IP packet frame type: Ethernet II, hardware address: 905d-7c18-dcf2 Description: GigabitEthernet1/0/2 Interface Bandwidth: 1000000 kbps Loopback is not set Media type is twisted pair, promiscuous mode set 1000Mbps-speed mode, full-duplex mode Link speed type is autonegotiation, link duplex type is autonegotiation Flow-control is not enabled Maximum frame length: 4000 Allow jumbo frames to pass Broadcast max-ratio: 100% Multicast max-ratio: 100% Unicast max-ratio: 100% PVID: 1 Port link-type: Trunk VLAN Passing: 1(default vlan), 10, 100 VLAN permitted: 1(default vlan), 2-4094 Trunk port encapsulation: IEEE 802.1q Port priority: 0 Last link flapping: 0 hours 58 minutes 15 seconds Last clearing of counters: Never Last 300 second input: 306 packets/sec 70877 bytes/sec 0% Last 300 second output: 1073 packets/sec 783802 bytes/sec 0% Input (total): 1921400 packets, 1314339849 bytes 1918025 unicasts, 2118 broadcasts, 1257 multicasts, 0 pauses Input (normal): 1921400 packets, 1314339849 bytes 1918025 unicasts, 2118 broadcasts, 1257 multicasts, 0 pauses Input: 0 input errors, 0 runts, 0 giants, - throttles 0 CRC, - frame, 0 overruns, 0 aborts - ignored, - parity errors Output (total): 3220596 packets, 2159403157 bytes 3086503 unicasts, 47097 broadcasts, 86996 multicasts, 0 pauses Output (normal): 3220596 packets, 2159403157 bytes 3086503 unicasts, 47097 broadcasts, 86996 multicasts, 0 pauses Output: 0 output errors, 0 underruns, - buffer failures - aborts, 0 deferred, 0 collisions, 0 late collisions - lost carrier, - no carrier GigabitEthernet1/0/3 Current state: UP Line protocol state: UP IP packet frame type: Ethernet II, hardware address: 905d-7c18-dcf3 Description: GigabitEthernet1/0/3 Interface Bandwidth: 1000000 kbps Loopback is not set Media type is twisted pair, promiscuous mode set 1000Mbps-speed mode, full-duplex mode Link speed type is autonegotiation, link duplex type is autonegotiation Flow-control is not enabled Maximum frame length: 4000 Allow jumbo frames to pass Broadcast max-ratio: 100% Multicast max-ratio: 100% Unicast max-ratio: 100% PVID: 1 Port link-type: Trunk VLAN Passing: 1(default vlan), 10, 100 VLAN permitted: 1(default vlan), 2-4094 Trunk port encapsulation: IEEE 802.1q Port priority: 0 Last link flapping: 0 hours 58 minutes 15 seconds Last clearing of counters: Never Last 300 second input: 489 packets/sec 167867 bytes/sec 0% Last 300 second output: 1630 packets/sec 1486567 bytes/sec 1% Input (total): 1475603 packets, 485475470 bytes 1470305 unicasts, 3441 broadcasts, 1857 multicasts, 0 pauses Input (normal): 1475603 packets, 485475470 bytes 1470305 unicasts, 3441 broadcasts, 1857 multicasts, 0 pauses Input: 0 input errors, 0 runts, 0 giants, - throttles 0 CRC, - frame, 0 overruns, 0 aborts - ignored, - parity errors Output (total): 4976006 packets, 4187017971 bytes 4841967 unicasts, 47041 broadcasts, 86998 multicasts, 0 pauses Output (normal): 4976006 packets, 4187017971 bytes 4841967 unicasts, 47041 broadcasts, 86998 multicasts, 0 pauses Output: 0 output errors, 0 underruns, - buffer failures - aborts, 0 deferred, 0 collisions, 0 late collisions - lost carrier, - no carrier GigabitEthernet1/0/4 Current state: DOWN Line protocol state: DOWN IP packet frame type: Ethernet II, hardware address: 905d-7c18-dcf4 Description: GigabitEthernet1/0/4 Interface Loopback is not set Media type is not sure, Port hardware type is No connector, promiscuous mode set Unknown-speed mode, unknown-duplex mode Link speed type is autonegotiation, link duplex type is autonegotiation Flow-control is not enabled Maximum frame length: 4000 Allow jumbo frames to pass Broadcast max-ratio: 100% Multicast max-ratio: 100% Unicast max-ratio: 100% PVID: 1 Port link-type: Trunk VLAN Passing: 1(default vlan), 10, 100 VLAN permitted: 1(default vlan), 2-4094 Trunk port encapsulation: IEEE 802.1q Port priority: 0 Last link flapping: Never Last clearing of counters: Never Last 300 second input: 0 packets/sec 0 bytes/sec -% Last 300 second output: 0 packets/sec 0 bytes/sec -% Input (total): 0 packets, 0 bytes 0 unicasts, 0 broadcasts, 0 multicasts, 0 pauses Input (normal): 0 packets, 0 bytes 0 unicasts, 0 broadcasts, 0 multicasts, 0 pauses Input: 0 input errors, 0 runts, 0 giants, - throttles 0 CRC, - frame, 0 overruns, 0 aborts - ignored, - parity errors Output (total): 0 packets, 0 bytes 0 unicasts, 0 broadcasts, 0 multicasts, 0 pauses Output (normal): 0 packets, 0 bytes 0 unicasts, 0 broadcasts, 0 multicasts, 0 pauses Output: 0 output errors, 0 underruns, - buffer failures - aborts, 0 deferred, 0 collisions, 0 late collisions - lost carrier, - no carrier GigabitEthernet1/0/5 Current state: UP Line protocol state: UP IP packet frame type: Ethernet II, hardware address: 905d-7c18-dcf5 Description: GigabitEthernet1/0/5 Interface Bandwidth: 1000000 kbps Loopback is not set Media type is twisted pair, promiscuous mode set 1000Mbps-speed mode, full-duplex mode Link speed type is autonegotiation, link duplex type is autonegotiation Flow-control is not enabled Maximum frame length: 4000 Allow jumbo frames to pass Broadcast max-ratio: 100% Multicast max-ratio: 100% Unicast max-ratio: 100% PVID: 10 Port link-type: Access Tagged VLANs: None Untagged VLANs: 10 Port priority: 0 Last link flapping: 0 hours 58 minutes 15 seconds Last clearing of counters: Never Last 300 second input: 1980 packets/sec 745047 bytes/sec 0% Last 300 second output: 4375 packets/sec 3793274 bytes/sec 3% Input (total): 5111055 packets, 2182359141 bytes 5110971 unicasts, 0 broadcasts, 84 multicasts, 0 pauses Input (normal): 5111055 packets, 2182359141 bytes 5110971 unicasts, 0 broadcasts, 84 multicasts, 0 pauses Input: 0 input errors, 0 runts, 0 giants, - throttles 0 CRC, - frame, 0 overruns, 0 aborts - ignored, - parity errors Output (total): 10787197 packets, 9030630895 bytes 10787071 unicasts, 3 broadcasts, 123 multicasts, 0 pauses Output (normal): 10787197 packets, 9030630895 bytes 10787071 unicasts, 3 broadcasts, 123 multicasts, 0 pauses Output: 0 output errors, 0 underruns, - buffer failures - aborts, 0 deferred, 0 collisions, 0 late collisions - lost carrier, - no carrier GigabitEthernet1/0/6 Current state: DOWN Line protocol state: DOWN IP packet frame type: Ethernet II, hardware address: 905d-7c18-dcf6 Description: GigabitEthernet1/0/6 Interface Loopback is not set Media type is not sure, Port hardware type is No connector, promiscuous mode set Unknown-speed mode, unknown-duplex mode Link speed type is autonegotiation, link duplex type is autonegotiation Flow-control is not enabled Maximum frame length: 4000 Allow jumbo frames to pass Broadcast max-ratio: 100% Multicast max-ratio: 100% Unicast max-ratio: 100% PVID: 1 Port link-type: Access Tagged VLANs: None Untagged VLANs: 1 Port priority: 0 Last link flapping: Never Last clearing of counters: Never Last 300 second input: 0 packets/sec 0 bytes/sec -% Last 300 second output: 0 packets/sec 0 bytes/sec -% Input (total): 0 packets, 0 bytes 0 unicasts, 0 broadcasts, 0 multicasts, 0 pauses Input (normal): 0 packets, 0 bytes 0 unicasts, 0 broadcasts, 0 multicasts, 0 pauses Input: 0 input errors, 0 runts, 0 giants, - throttles 0 CRC, - frame, 0 overruns, 0 aborts - ignored, - parity errors Output (total): 0 packets, 0 bytes 0 unicasts, 0 broadcasts, 0 multicasts, 0 pauses Output (normal): 0 packets, 0 bytes 0 unicasts, 0 broadcasts, 0 multicasts, 0 pauses Output: 0 output errors, 0 underruns, - buffer failures - aborts, 0 deferred, 0 collisions, 0 late collisions - lost carrier, - no carrier GigabitEthernet1/0/7 Current state: UP Line protocol state: UP Description: GigabitEthernet1/0/7 Bandwidth: 1000000 kbps Maximum transmission unit: 1500 Internet address: 61.138.113.174/29 (primary) IP packet frame type: Ethernet II, hardware address: 905d-7c18-dcf7 IPv6 packet frame type: Ethernet II, hardware address: 905d-7c18-dcf7 Media type is twisted pair, promiscuous mode set Port priority: 0 1000Mbps-speed mode, full-duplex mode Link speed type is autonegotiation, link duplex type is autonegotiation Flow-control is not enabled The Maximum Frame Length is 4000 Last link flapping: 0 hours 58 minutes 15 seconds Last clearing of counters: Never Last 300 second input: 3413 packets/sec 3575200 bytes/sec 2% Last 300 second output: 2145 packets/sec 676634 bytes/sec 0% Input (total): 7891621 packets, 8447520576 bytes 7890967 unicasts, 164 broadcasts, 490 multicasts, 0 pauses Input (normal): 7891621 packets, 8447520576 bytes 7890967 unicasts, 164 broadcasts, 490 multicasts, 0 pauses Input: 0 input errors, 0 runts, 0 giants, - throttles 0 CRC, - frame, 0 overruns, 0 aborts - ignored, - parity errors Output (total): 5524998 packets, 1917326536 bytes 5524866 unicasts, 6 broadcasts, 126 multicasts, 0 pauses Output (normal): 5524998 packets, 1917326536 bytes 5524866 unicasts, 6 broadcasts, 126 multicasts, 0 pauses Output: 0 output errors, 0 underruns, - buffer failures - aborts, 0 deferred, 0 collisions, 0 late collisions - lost carrier, - no carrier GigabitEthernet1/0/8 Current state: DOWN Line protocol state: DOWN Description: GigabitEthernet1/0/8 Interface Maximum transmission unit: 1500 Internet protocol processing: Disabled IP packet frame type: Ethernet II, hardware address: 905d-7c18-dcf8 IPv6 packet frame type: Ethernet II, hardware address: 905d-7c18-dcf8 Media type is not sure, Port hardware type is No connector, promiscuous mode set Port priority: 0 Unknown-speed mode, unknown-duplex mode Link speed type is autonegotiation, link duplex type is autonegotiation Flow-control is not enabled The Maximum Frame Length is 4000 Last link flapping: Never Last clearing of counters: Never Last 300 second input: 0 packets/sec 0 bytes/sec -% Last 300 second output: 0 packets/sec 0 bytes/sec -% Input (total): 0 packets, 0 bytes 0 unicasts, 0 broadcasts, 0 multicasts, 0 pauses Input (normal): 0 packets, 0 bytes 0 unicasts, 0 broadcasts, 0 multicasts, 0 pauses Input: 0 input errors, 0 runts, 0 giants, - throttles 0 CRC, - frame, 0 overruns, 0 aborts - ignored, - parity errors Output (total): 0 packets, 0 bytes 0 unicasts, 0 broadcasts, 0 multicasts, 0 pauses Output (normal): 0 packets, 0 bytes 0 unicasts, 0 broadcasts, 0 multicasts, 0 pauses Output: 0 output errors, 0 underruns, - buffer failures - aborts, 0 deferred, 0 collisions, 0 late collisions - lost carrier, - no carrier InLoopBack0 Current state: UP Line protocol state: UP(spoofing) Description: InLoopBack0 Interface Maximum transmission unit: 1536 Physical: InLoopBack Last 300 seconds input rate: 0 bytes/sec, 0 bits/sec, 0 packets/sec Last 300 seconds output rate: 0 bytes/sec, 0 bits/sec, 0 packets/sec Input: 0 packets, 0 bytes, 0 drops Output: 0 packets, 0 bytes, 0 drops NULL0 Current state: UP Line protocol state: UP(spoofing) Description: NULL0 Interface Bandwidth: 1000000 kbps Maximum transmission unit: 1500 Internet protocol processing: Disabled Physical: NULL DEV, baudrate: 1000000 kbps Last clearing of counters: Never Last 300 seconds input rate: 0 bytes/sec, 0 bits/sec, 0 packets/sec Last 300 seconds output rate: 0 bytes/sec, 0 bits/sec, 0 packets/sec Input: 0 packets, 0 bytes, 0 drops Output: 0 packets, 0 bytes, 0 drops Vlan-interface1 Current state: UP Line protocol state: UP Description: Vlan-interface1 Interface Bandwidth: 1000000 kbps Maximum transmission unit: 1500 Internet address: 192.168.0.100/21 (primary) IP packet frame type: Ethernet II, hardware address: 905d-7c18-dcf0 IPv6 packet frame type: Ethernet II, hardware address: 905d-7c18-dcf0 Last clearing of counters: Never Last 300 seconds input rate: 6405 bytes/sec, 51240 bits/sec, 33 packets/sec Last 300 seconds output rate: 22 bytes/sec, 176 bits/sec, 0 packets/sec Input: 113143 packets, 22293364 bytes, 0 drops Output: 870 packets, 89147 bytes, 0 drops Vlan-interface10 Current state: UP Line protocol state: UP Description: HL-TP Bandwidth: 1000000 kbps Maximum transmission unit: 1500 Internet address: 10.12.1.1/30 (primary) IP packet frame type: Ethernet II, hardware address: 905d-7c18-dcf0 IPv6 packet frame type: Ethernet II, hardware address: 905d-7c18-dcf0 Last clearing of counters: Never Last 300 seconds input rate: 406687 bytes/sec, 3253496 bits/sec, 1653 packets/sec Last 300 seconds output rate: 1450863 bytes/sec, 11606904 bits/sec, 1255 packets/sec Input: 5111215 packets, 2160358253 bytes, 0 drops Output: 2112077 packets, 2157676474 bytes, 0 drops Vlan-interface100 Current state: UP Line protocol state: UP Description: YW Bandwidth: 1000000 kbps Maximum transmission unit: 1500 Internet address: 172.16.100.1/22 (primary) IP packet frame type: Ethernet II, hardware address: 905d-7c18-dcf0 IPv6 packet frame type: Ethernet II, hardware address: 905d-7c18-dcf0 Last clearing of counters: Never Last 300 seconds input rate: 250501 bytes/sec, 2004008 bits/sec, 945 packets/sec Last 300 seconds output rate: 2562445 bytes/sec, 20499560 bits/sec, 2049 packets/sec Input: 3459091 packets, 1559012656 bytes, 0 drops Output: 5169169 packets, 5978568945 bytes, 0 drops =================================================== ===============display interface brief=============== Brief information on interfaces in route mode: Link: ADM - administratively down; Stby - standby Protocol: (s) - spoofing Interface Link Protocol Primary IP Description Dia1 UP UP(s) -- Dia2 UP UP(s) -- Dia3 UP UP(s) -- Dia4 UP UP(s) -- Dia5 UP UP(s) -- Dia6 UP UP(s) -- Dia7 UP UP(s) -- Dia8 UP UP(s) -- GE1/0/7 UP UP 61.138.113.174 GigabitEthernet1/0/7 GE1/0/8 DOWN DOWN -- InLoop0 UP UP(s) -- NULL0 UP UP(s) -- Vlan1 UP UP 192.168.0.100 Vlan10 UP UP 10.12.1.1 HL-TP Vlan100 UP UP 172.16.100.1 YW Brief information on interfaces in bridge mode: Link: ADM - administratively down; Stby - standby Speed: (a) - auto Duplex: (a)/A - auto; H - half; F - full Type: A - access; T - trunk; H - hybrid Interface Link Speed Duplex Type PVID Description GE1/0/1 UP 1G(a) F(a) A 1 GE1/0/2 UP 1G(a) F(a) T 1 GE1/0/3 UP 1G(a) F(a) T 1 GE1/0/4 DOWN auto A T 1 GE1/0/5 UP 1G(a) F(a) A 10 GE1/0/6 DOWN auto A A 1 =================================================== ===============display logbuffer=============== Log buffer: Enabled Max buffer size: 1024 Actual buffer size: 512 Dropped messages: 0 Overwritten messages: 1910 Current messages: 512 %Mar 19 10:22:33:137 2022 XLL-R STAMGR/6/STAMGR_CLIENT_SNOOPING: Detected client IP change: Client MAC: 1649-0bcf-31d3, IP: 172.16.100.7, -NA-, -NA-, -NA-, Username: -NA-, AP name: 943b-b051-e670, Radio ID: 2, Channel number: 1, SSID: XLL, BSSID: 943b-b051-e680. %Mar 19 10:22:36:780 2022 XLL-R STAMGR/6/STAMGR_CLIENT_ONLINE: Client 7a06-25d1-854a went online from BSS 943b-b052-11a0 with SSID XLL on AP 943b-b052-1190. State changed to Run. %Mar 19 10:22:36:783 2022 XLL-R STAMGR/6/STAMGR_ROAM_SUCCESS: Client 7a06-25d1-854a roamed from BSSID 943b-b052-1190 on AP 943b-b052-1190 of AC IP 127.0.0.1 to BSSID 943b-b052-11a0 on AP 943b-b052-1190 of AC IP 127.0.0.1 successfully. %Mar 19 10:22:36:786 2022 XLL-R STAMGR/6/STAMGR_CLIENT_OFFLINE: Client 7a06-25d1-854a went offline from BSS 943b-b052-1190 with SSID XLL on AP 943b-b052-1190. State changed to Unauth. Reason:Successfully roamed to another BSS. %Mar 19 10:22:36:789 2022 XLL-R STAMGR/6/STAMGR_CLIENT_SNOOPING: Detected client IP change: Client MAC: 7a06-25d1-854a, IP: 172.16.100.43, -NA-, -NA-, -NA-, Username: -NA-, AP name: 943b-b052-1190, Radio ID: 2, Channel number: 11, SSID: XLL, BSSID: 943b-b052-11a0. %Mar 19 10:22:39:528 2022 XLL-R STAMGR/6/STAMGR_CLIENT_ONLINE: Client 7a06-25d1-854a went online from BSS 943b-b051-1760 with SSID XLL on AP 943b-b051-1750. State changed to Run. %Mar 19 10:22:39:530 2022 XLL-R STAMGR/6/STAMGR_ROAM_SUCCESS: Client 7a06-25d1-854a roamed from BSSID 943b-b052-11a0 on AP 943b-b052-1190 of AC IP 127.0.0.1 to BSSID 943b-b051-1760 on AP 943b-b051-1750 of AC IP 127.0.0.1 successfully. %Mar 19 10:22:39:532 2022 XLL-R STAMGR/6/STAMGR_CLIENT_SNOOPING: Detected client IP change: Client MAC: 7a06-25d1-854a, IP: 172.16.100.43, -NA-, -NA-, -NA-, Username: -NA-, AP name: 943b-b051-1750, Radio ID: 2, Channel number: 11, SSID: XLL, BSSID: 943b-b051-1760. %Mar 19 10:22:39:534 2022 XLL-R STAMGR/6/STAMGR_CLIENT_OFFLINE: Client 7a06-25d1-854a went offline from BSS 943b-b052-11a0 with SSID XLL on AP 943b-b052-1190. State changed to Unauth. Reason:Successfully roamed to another BSS. %Mar 19 10:23:06:879 2022 XLL-R STAMGR/6/STAMGR_CLIENT_ONLINE: Client 72ed-14da-d135 went online from BSS 943b-b051-e670 with SSID XLL on AP 943b-b051-e670. State changed to Run. %Mar 19 10:23:06:880 2022 XLL-R STAMGR/6/STAMGR_ROAM_SUCCESS: Client 72ed-14da-d135 roamed from BSSID 943b-b051-6800 on AP 943b-b051-67f0 of AC IP 127.0.0.1 to BSSID 943b-b051-e670 on AP 943b-b051-e670 of AC IP 127.0.0.1 successfully. %Mar 19 10:23:06:881 2022 XLL-R STAMGR/6/STAMGR_CLIENT_OFFLINE: Client 72ed-14da-d135 went offline from BSS 943b-b051-6800 with SSID XLL on AP 943b-b051-67f0. State changed to Unauth. Reason:Successfully roamed to another BSS. %Mar 19 10:23:06:886 2022 XLL-R STAMGR/6/STAMGR_CLIENT_SNOOPING: Detected client IP change: Client MAC: 72ed-14da-d135, IP: 172.16.100.13, -NA-, -NA-, -NA-, Username: -NA-, AP name: 943b-b051-e670, Radio ID: 1, Channel number: 36, SSID: XLL, BSSID: 943b-b051-e670. %Mar 19 10:23:19:953 2022 XLL-R STAMGR/6/STAMGR_CLIENT_ONLINE: Client a6e1-a489-f9e2 went online from BSS 943b-b051-2520 with SSID XLL on AP 943b-b051-2520. State changed to Run. %Mar 19 10:23:19:957 2022 XLL-R STAMGR/6/STAMGR_ROAM_SUCCESS: Client a6e1-a489-f9e2 roamed from BSSID 943b-b051-2530 on AP 943b-b051-2520 of AC IP 127.0.0.1 to BSSID 943b-b051-2520 on AP 943b-b051-2520 of AC IP 127.0.0.1 successfully. %Mar 19 10:23:19:958 2022 XLL-R STAMGR/6/STAMGR_CLIENT_OFFLINE: Client a6e1-a489-f9e2 went offline from BSS 943b-b051-2530 with SSID XLL on AP 943b-b051-2520. State changed to Unauth. Reason:Successfully roamed to another BSS. %Mar 19 10:23:19:960 2022 XLL-R STAMGR/6/STAMGR_CLIENT_SNOOPING: Detected client IP change: Client MAC: a6e1-a489-f9e2, IP: 172.16.100.5, 172.16.100.87, -NA-, -NA-, Username: -NA-, AP name: 943b-b051-2520, Radio ID: 1, Channel number: 36, SSID: XLL, BSSID: 943b-b051-2520. %Mar 19 10:23:43:004 2022 XLL-R STAMGR/6/STAMGR_CLIENT_ONLINE: Client a6e1-a489-f9e2 went online from BSS 943b-b051-2530 with SSID XLL on AP 943b-b051-2520. State changed to Run. %Mar 19 10:23:43:008 2022 XLL-R STAMGR/6/STAMGR_ROAM_SUCCESS: Client a6e1-a489-f9e2 roamed from BSSID 943b-b051-2520 on AP 943b-b051-2520 of AC IP 127.0.0.1 to BSSID 943b-b051-2530 on AP 943b-b051-2520 of AC IP 127.0.0.1 successfully. %Mar 19 10:23:43:009 2022 XLL-R STAMGR/6/STAMGR_CLIENT_OFFLINE: Client a6e1-a489-f9e2 went offline from BSS 943b-b051-2520 with SSID XLL on AP 943b-b051-2520. State changed to Unauth. Reason:Successfully roamed to another BSS. %Mar 19 10:23:43:012 2022 XLL-R STAMGR/6/STAMGR_CLIENT_SNOOPING: Detected client IP change: Client MAC: a6e1-a489-f9e2, IP: 172.16.100.5, 172.16.100.87, -NA-, -NA-, Username: -NA-, AP name: 943b-b051-2520, Radio ID: 2, Channel number: 6, SSID: XLL, BSSID: 943b-b051-2530. %Mar 19 10:23:47:387 2022 XLL-R STAMGR/6/STAMGR_CLIENT_ONLINE: Client d613-ad03-015e went online from BSS 943b-b051-d200 with SSID XLL on AP 943b-b051-d200. State changed to Run. %Mar 19 10:23:47:389 2022 XLL-R STAMGR/6/STAMGR_ROAM_SUCCESS: Client d613-ad03-015e roamed from BSSID 943b-b051-2320 on AP 943b-b051-2320 of AC IP 127.0.0.1 to BSSID 943b-b051-d200 on AP 943b-b051-d200 of AC IP 127.0.0.1 successfully. %Mar 19 10:23:47:393 2022 XLL-R STAMGR/6/STAMGR_CLIENT_OFFLINE: Client d613-ad03-015e went offline from BSS 943b-b051-2320 with SSID XLL on AP 943b-b051-2320. State changed to Unauth. Reason:Successfully roamed to another BSS. %Mar 19 10:23:47:393 2022 XLL-R STAMGR/6/STAMGR_CLIENT_SNOOPING: Detected client IP change: Client MAC: d613-ad03-015e, IP: 172.16.100.59, -NA-, -NA-, -NA-, Username: -NA-, AP name: 943b-b051-d200, Radio ID: 1, Channel number: 52, SSID: XLL, BSSID: 943b-b051-d200. %Mar 19 10:24:13:434 2022 XLL-R STAMGR/6/STAMGR_CLIENT_ONLINE: Client d613-ad03-015e went online from BSS 943b-b051-67f0 with SSID XLL on AP 943b-b051-67f0. State changed to Run. %Mar 19 10:24:13:435 2022 XLL-R STAMGR/6/STAMGR_ROAM_SUCCESS: Client d613-ad03-015e roamed from BSSID 943b-b051-d200 on AP 943b-b051-d200 of AC IP 127.0.0.1 to BSSID 943b-b051-67f0 on AP 943b-b051-67f0 of AC IP 127.0.0.1 successfully. %Mar 19 10:24:13:442 2022 XLL-R STAMGR/6/STAMGR_CLIENT_OFFLINE: Client d613-ad03-015e went offline from BSS 943b-b051-d200 with SSID XLL on AP 943b-b051-d200. State changed to Unauth. Reason:Successfully roamed to another BSS. %Mar 19 10:24:13:452 2022 XLL-R STAMGR/6/STAMGR_CLIENT_SNOOPING: Detected client IP change: Client MAC: d613-ad03-015e, IP: 172.16.100.59, -NA-, -NA-, -NA-, Username: -NA-, AP name: 943b-b051-67f0, Radio ID: 1, Channel number: 36, SSID: XLL, BSSID: 943b-b051-67f0. %Mar 19 10:24:14:534 2022 XLL-R STAMGR/6/STAMGR_CLIENT_OFFLINE: Client 32c9-c109-1a7b went offline from BSS 943b-b051-6800 with SSID XLL on AP 943b-b051-67f0. State changed to Unauth. Reason:Received deauthentication message in Run state: reason code=4 %Mar 19 10:24:46:074 2022 XLL-R STAMGR/6/STAMGR_CLIENT_ONLINE: Client a6e1-a489-f9e2 went online from BSS 943b-b051-2520 with SSID XLL on AP 943b-b051-2520. State changed to Run. %Mar 19 10:24:46:078 2022 XLL-R STAMGR/6/STAMGR_ROAM_SUCCESS: Client a6e1-a489-f9e2 roamed from BSSID 943b-b051-2530 on AP 943b-b051-2520 of AC IP 127.0.0.1 to BSSID 943b-b051-2520 on AP 943b-b051-2520 of AC IP 127.0.0.1 successfully. %Mar 19 10:24:46:079 2022 XLL-R STAMGR/6/STAMGR_CLIENT_OFFLINE: Client a6e1-a489-f9e2 went offline from BSS 943b-b051-2530 with SSID XLL on AP 943b-b051-2520. State changed to Unauth. Reason:Successfully roamed to another BSS. %Mar 19 10:24:46:081 2022 XLL-R STAMGR/6/STAMGR_CLIENT_SNOOPING: Detected client IP change: Client MAC: a6e1-a489-f9e2, IP: 172.16.100.5, 172.16.100.87, -NA-, -NA-, Username: -NA-, AP name: 943b-b051-2520, Radio ID: 1, Channel number: 36, SSID: XLL, BSSID: 943b-b051-2520. %Mar 19 10:24:49:208 2022 XLL-R STAMGR/6/STAMGR_CLIENT_ONLINE: Client a6e1-a489-f9e2 went online from BSS 943b-b051-2530 with SSID XLL on AP 943b-b051-2520. State changed to Run. %Mar 19 10:24:49:212 2022 XLL-R STAMGR/6/STAMGR_ROAM_SUCCESS: Client a6e1-a489-f9e2 roamed from BSSID 943b-b051-2520 on AP 943b-b051-2520 of AC IP 127.0.0.1 to BSSID 943b-b051-2530 on AP 943b-b051-2520 of AC IP 127.0.0.1 successfully. %Mar 19 10:24:49:213 2022 XLL-R STAMGR/6/STAMGR_CLIENT_OFFLINE: Client a6e1-a489-f9e2 went offline from BSS 943b-b051-2520 with SSID XLL on AP 943b-b051-2520. State changed to Unauth. Reason:Successfully roamed to another BSS. %Mar 19 10:24:49:215 2022 XLL-R STAMGR/6/STAMGR_CLIENT_SNOOPING: Detected client IP change: Client MAC: a6e1-a489-f9e2, IP: 172.16.100.5, 172.16.100.87, -NA-, -NA-, Username: -NA-, AP name: 943b-b051-2520, Radio ID: 2, Channel number: 6, SSID: XLL, BSSID: 943b-b051-2530. %Mar 19 10:24:50:587 2022 XLL-R STAMGR/6/STAMGR_CLIENT_ONLINE: Client 1649-0bcf-31d3 went online from BSS 943b-b051-67f0 with SSID XLL on AP 943b-b051-67f0. State changed to Run. %Mar 19 10:24:50:588 2022 XLL-R STAMGR/6/STAMGR_ROAM_SUCCESS: Client 1649-0bcf-31d3 roamed from BSSID 943b-b051-e680 on AP 943b-b051-e670 of AC IP 127.0.0.1 to BSSID 943b-b051-67f0 on AP 943b-b051-67f0 of AC IP 127.0.0.1 successfully. %Mar 19 10:24:50:591 2022 XLL-R STAMGR/6/STAMGR_CLIENT_OFFLINE: Client 1649-0bcf-31d3 went offline from BSS 943b-b051-e680 with SSID XLL on AP 943b-b051-e670. State changed to Unauth. Reason:Successfully roamed to another BSS. %Mar 19 10:24:50:594 2022 XLL-R STAMGR/6/STAMGR_CLIENT_SNOOPING: Detected client IP change: Client MAC: 1649-0bcf-31d3, IP: 172.16.100.7, -NA-, -NA-, -NA-, Username: -NA-, AP name: 943b-b051-67f0, Radio ID: 1, Channel number: 36, SSID: XLL, BSSID: 943b-b051-67f0. %Mar 19 10:24:54:963 2022 XLL-R STAMGR/6/STAMGR_CLIENT_OFFLINE: Client 1649-0bcf-31d3 went offline from BSS 943b-b051-67f0 with SSID XLL on AP 943b-b051-67f0. State changed to Unauth. Reason:Received deauthentication message in Run state: reason code=3 %Mar 19 10:24:55:292 2022 XLL-R STAMGR/6/STAMGR_CLIENT_ONLINE: Client 1649-0bcf-31d3 went online from BSS 943b-b051-67f0 with SSID XLL on AP 943b-b051-67f0. State changed to Run. %Mar 19 10:24:55:292 2022 XLL-R STAMGR/6/STAMGR_CLIENT_SNOOPING: Detected client IP change: Client MAC: 1649-0bcf-31d3, IP: 172.16.100.7, -NA-, -NA-, -NA-, Username: -NA-, AP name: 943b-b051-67f0, Radio ID: 1, Channel number: 36, SSID: XLL, BSSID: 943b-b051-67f0. %Mar 19 10:24:56:900 2022 XLL-R STAMGR/6/STAMGR_CLIENT_ONLINE: Client 1649-0bcf-31d3 went online from BSS 943b-b051-e680 with SSID XLL on AP 943b-b051-e670. State changed to Run. %Mar 19 10:24:56:901 2022 XLL-R STAMGR/6/STAMGR_ROAM_SUCCESS: Client 1649-0bcf-31d3 roamed from BSSID 943b-b051-67f0 on AP 943b-b051-67f0 of AC IP 127.0.0.1 to BSSID 943b-b051-e680 on AP 943b-b051-e670 of AC IP 127.0.0.1 successfully. %Mar 19 10:24:56:902 2022 XLL-R STAMGR/6/STAMGR_CLIENT_OFFLINE: Client 1649-0bcf-31d3 went offline from BSS 943b-b051-67f0 with SSID XLL on AP 943b-b051-67f0. State changed to Unauth. Reason:Successfully roamed to another BSS. %Mar 19 10:24:56:907 2022 XLL-R STAMGR/6/STAMGR_CLIENT_SNOOPING: Detected client IP change: Client MAC: 1649-0bcf-31d3, IP: 172.16.100.7, -NA-, -NA-, -NA-, Username: -NA-, AP name: 943b-b051-e670, Radio ID: 2, Channel number: 1, SSID: XLL, BSSID: 943b-b051-e680. %Mar 19 10:25:00:129 2022 XLL-R STAMGR/6/STAMGR_CLIENT_ONLINE: Client 1649-0bcf-31d3 went online from BSS 943b-b051-67f0 with SSID XLL on AP 943b-b051-67f0. State changed to Run. %Mar 19 10:25:00:131 2022 XLL-R STAMGR/6/STAMGR_ROAM_SUCCESS: Client 1649-0bcf-31d3 roamed from BSSID 943b-b051-e680 on AP 943b-b051-e670 of AC IP 127.0.0.1 to BSSID 943b-b051-67f0 on AP 943b-b051-67f0 of AC IP 127.0.0.1 successfully. %Mar 19 10:25:00:133 2022 XLL-R STAMGR/6/STAMGR_CLIENT_SNOOPING: Detected client IP change: Client MAC: 1649-0bcf-31d3, IP: 172.16.100.7, -NA-, -NA-, -NA-, Username: -NA-, AP name: 943b-b051-67f0, Radio ID: 1, Channel number: 36, SSID: XLL, BSSID: 943b-b051-67f0. %Mar 19 10:25:00:138 2022 XLL-R STAMGR/6/STAMGR_CLIENT_OFFLINE: Client 1649-0bcf-31d3 went offline from BSS 943b-b051-e680 with SSID XLL on AP 943b-b051-e670. State changed to Unauth. Reason:Successfully roamed to another BSS. %Mar 19 10:25:04:022 2022 XLL-R STAMGR/6/STAMGR_CLIENT_ONLINE: Client 7a06-25d1-854a went online from BSS 943b-b052-1190 with SSID XLL on AP 943b-b052-1190. State changed to Run. %Mar 19 10:25:04:024 2022 XLL-R STAMGR/6/STAMGR_ROAM_SUCCESS: Client 7a06-25d1-854a roamed from BSSID 943b-b051-1760 on AP 943b-b051-1750 of AC IP 127.0.0.1 to BSSID 943b-b052-1190 on AP 943b-b052-1190 of AC IP 127.0.0.1 successfully. %Mar 19 10:25:04:025 2022 XLL-R STAMGR/6/STAMGR_CLIENT_OFFLINE: Client 7a06-25d1-854a went offline from BSS 943b-b051-1760 with SSID XLL on AP 943b-b051-1750. State changed to Unauth. Reason:Successfully roamed to another BSS. %Mar 19 10:25:04:027 2022 XLL-R STAMGR/6/STAMGR_CLIENT_SNOOPING: Detected client IP change: Client MAC: 7a06-25d1-854a, IP: 172.16.100.43, -NA-, -NA-, -NA-, Username: -NA-, AP name: 943b-b052-1190, Radio ID: 1, Channel number: 36, SSID: XLL, BSSID: 943b-b052-1190. %Mar 19 10:25:07:595 2022 XLL-R STAMGR/6/STAMGR_CLIENT_ONLINE: Client 1649-0bcf-31d3 went online from BSS 943b-b051-e670 with SSID XLL on AP 943b-b051-e670. State changed to Run. %Mar 19 10:25:07:596 2022 XLL-R STAMGR/6/STAMGR_ROAM_SUCCESS: Client 1649-0bcf-31d3 roamed from BSSID 943b-b051-67f0 on AP 943b-b051-67f0 of AC IP 127.0.0.1 to BSSID 943b-b051-e670 on AP 943b-b051-e670 of AC IP 127.0.0.1 successfully. %Mar 19 10:25:07:601 2022 XLL-R STAMGR/6/STAMGR_CLIENT_OFFLINE: Client 1649-0bcf-31d3 went offline from BSS 943b-b051-67f0 with SSID XLL on AP 943b-b051-67f0. State changed to Unauth. Reason:Successfully roamed to another BSS. %Mar 19 10:25:07:605 2022 XLL-R STAMGR/6/STAMGR_CLIENT_SNOOPING: Detected client IP change: Client MAC: 1649-0bcf-31d3, IP: 172.16.100.7, -NA-, -NA-, -NA-, Username: -NA-, AP name: 943b-b051-e670, Radio ID: 1, Channel number: 36, SSID: XLL, BSSID: 943b-b051-e670. %Mar 19 10:25:08:097 2022 XLL-R STAMGR/6/STAMGR_CLIENT_OFFLINE: Client 7a06-25d1-854a went offline from BSS 943b-b052-1190 with SSID XLL on AP 943b-b052-1190. State changed to Unauth. Reason:Received deauthentication message in Run state: reason code=3 %Mar 19 10:25:09:289 2022 XLL-R STAMGR/6/STAMGR_CLIENT_ONLINE: Client 7a06-25d1-854a went online from BSS 943b-b052-1190 with SSID XLL on AP 943b-b052-1190. State changed to Run. %Mar 19 10:25:09:290 2022 XLL-R STAMGR/6/STAMGR_CLIENT_SNOOPING: Detected client IP change: Client MAC: 7a06-25d1-854a, IP: 172.16.100.43, -NA-, -NA-, -NA-, Username: -NA-, AP name: 943b-b052-1190, Radio ID: 1, Channel number: 36, SSID: XLL, BSSID: 943b-b052-1190. %Mar 19 10:25:13:325 2022 XLL-R STAMGR/6/STAMGR_CLIENT_ONLINE: Client 14c6-975f-979b went online from BSS 943b-b051-c4a0 with SSID XLL on AP 943b-b051-c490. State changed to Run. %Mar 19 10:25:13:326 2022 XLL-R STAMGR/6/STAMGR_ROAM_SUCCESS: Client 14c6-975f-979b roamed from BSSID 943b-b051-2530 on AP 943b-b051-2520 of AC IP 127.0.0.1 to BSSID 943b-b051-c4a0 on AP 943b-b051-c490 of AC IP 127.0.0.1 successfully. %Mar 19 10:25:13:328 2022 XLL-R STAMGR/6/STAMGR_CLIENT_OFFLINE: Client 14c6-975f-979b went offline from BSS 943b-b051-2530 with SSID XLL on AP 943b-b051-2520. State changed to Unauth. Reason:Successfully roamed to another BSS. %Mar 19 10:25:13:335 2022 XLL-R STAMGR/6/STAMGR_CLIENT_SNOOPING: Detected client IP change: Client MAC: 14c6-975f-979b, IP: 172.16.100.27, -NA-, -NA-, -NA-, Username: -NA-, AP name: 943b-b051-c490, Radio ID: 2, Channel number: 11, SSID: XLL, BSSID: 943b-b051-c4a0. %Mar 19 10:25:29:327 2022 XLL-R STAMGR/6/STAMGR_CLIENT_ONLINE: Client 32c9-c109-1a7b went online from BSS 943b-b051-d210 with SSID XLL on AP 943b-b051-d200. State changed to Run. %Mar 19 10:25:29:330 2022 XLL-R STAMGR/6/STAMGR_ROAM_SUCCESS: Client 32c9-c109-1a7b roamed from BSSID 943b-b051-6800 on AP 943b-b051-67f0 of AC IP 127.0.0.1 to BSSID 943b-b051-d210 on AP 943b-b051-d200 of AC IP 127.0.0.1 successfully. %Mar 19 10:25:29:331 2022 XLL-R STAMGR/6/STAMGR_CLIENT_SNOOPING: Detected client IP change: Client MAC: 32c9-c109-1a7b, IP: 172.16.100.58, -NA-, -NA-, -NA-, Username: -NA-, AP name: 943b-b051-d200, Radio ID: 2, Channel number: 6, SSID: XLL, BSSID: 943b-b051-d210. %Mar 19 10:25:33:418 2022 XLL-R STAMGR/6/STAMGR_CLIENT_ONLINE: Client 32c9-c109-1a7b went online from BSS 943b-b051-5340 with SSID XLL on AP 943b-b051-5330. State changed to Run. %Mar 19 10:25:33:420 2022 XLL-R STAMGR/6/STAMGR_ROAM_SUCCESS: Client 32c9-c109-1a7b roamed from BSSID 943b-b051-d210 on AP 943b-b051-d200 of AC IP 127.0.0.1 to BSSID 943b-b051-5340 on AP 943b-b051-5330 of AC IP 127.0.0.1 successfully. %Mar 19 10:25:33:421 2022 XLL-R STAMGR/6/STAMGR_CLIENT_OFFLINE: Client 32c9-c109-1a7b went offline from BSS 943b-b051-d210 with SSID XLL on AP 943b-b051-d200. State changed to Unauth. Reason:Successfully roamed to another BSS. %Mar 19 10:25:33:422 2022 XLL-R STAMGR/6/STAMGR_CLIENT_SNOOPING: Detected client IP change: Client MAC: 32c9-c109-1a7b, IP: 172.16.100.58, -NA-, -NA-, -NA-, Username: -NA-, AP name: 943b-b051-5330, Radio ID: 2, Channel number: 11, SSID: XLL, BSSID: 943b-b051-5340. %Mar 19 10:25:38:374 2022 XLL-R STAMGR/6/STAMGR_CLIENT_ONLINE: Client e0e0-fc27-eb31 went online from BSS 00be-d5b3-a640 with SSID XLL on AP 00be-d5b3-a640. State changed to Run. %Mar 19 10:25:38:379 2022 XLL-R STAMGR/6/STAMGR_ROAM_SUCCESS: Client e0e0-fc27-eb31 roamed from BSSID 00be-d5b4-0220 on AP 00be-d5b4-0220 of AC IP 127.0.0.1 to BSSID 00be-d5b3-a640 on AP 00be-d5b3-a640 of AC IP 127.0.0.1 successfully. %Mar 19 10:25:38:380 2022 XLL-R STAMGR/6/STAMGR_CLIENT_OFFLINE: Client e0e0-fc27-eb31 went offline from BSS 00be-d5b4-0220 with SSID XLL on AP 00be-d5b4-0220. State changed to Unauth. Reason:Successfully roamed to another BSS. %Mar 19 10:25:38:382 2022 XLL-R STAMGR/6/STAMGR_CLIENT_SNOOPING: Detected client IP change: Client MAC: e0e0-fc27-eb31, IP: 172.16.100.20, -NA-, -NA-, -NA-, Username: -NA-, AP name: 00be-d5b3-a640, Radio ID: 1, Channel number: 149, SSID: XLL, BSSID: 00be-d5b3-a640. %Mar 19 10:25:50:323 2022 XLL-R STAMGR/6/STAMGR_CLIENT_ONLINE: Client 1649-0bcf-31d3 went online from BSS 943b-b051-67f0 with SSID XLL on AP 943b-b051-67f0. State changed to Run. %Mar 19 10:25:50:324 2022 XLL-R STAMGR/6/STAMGR_ROAM_SUCCESS: Client 1649-0bcf-31d3 roamed from BSSID 943b-b051-e670 on AP 943b-b051-e670 of AC IP 127.0.0.1 to BSSID 943b-b051-67f0 on AP 943b-b051-67f0 of AC IP 127.0.0.1 successfully. %Mar 19 10:25:50:325 2022 XLL-R STAMGR/6/STAMGR_CLIENT_OFFLINE: Client 1649-0bcf-31d3 went offline from BSS 943b-b051-e670 with SSID XLL on AP 943b-b051-e670. State changed to Unauth. Reason:Successfully roamed to another BSS. %Mar 19 10:25:50:328 2022 XLL-R STAMGR/6/STAMGR_CLIENT_SNOOPING: Detected client IP change: Client MAC: 1649-0bcf-31d3, IP: 172.16.100.7, -NA-, -NA-, -NA-, Username: -NA-, AP name: 943b-b051-67f0, Radio ID: 1, Channel number: 36, SSID: XLL, BSSID: 943b-b051-67f0. %Mar 19 10:25:56:938 2022 XLL-R STAMGR/6/STAMGR_CLIENT_ONLINE: Client 32c9-c109-1a7b went online from BSS 943b-b051-d210 with SSID XLL on AP 943b-b051-d200. State changed to Run. %Mar 19 10:25:56:940 2022 XLL-R STAMGR/6/STAMGR_ROAM_SUCCESS: Client 32c9-c109-1a7b roamed from BSSID 943b-b051-5340 on AP 943b-b051-5330 of AC IP 127.0.0.1 to BSSID 943b-b051-d210 on AP 943b-b051-d200 of AC IP 127.0.0.1 successfully. %Mar 19 10:25:56:944 2022 XLL-R STAMGR/6/STAMGR_CLIENT_OFFLINE: Client 32c9-c109-1a7b went offline from BSS 943b-b051-5340 with SSID XLL on AP 943b-b051-5330. State changed to Unauth. Reason:Successfully roamed to another BSS. %Mar 19 10:25:56:945 2022 XLL-R STAMGR/6/STAMGR_CLIENT_SNOOPING: Detected client IP change: Client MAC: 32c9-c109-1a7b, IP: 172.16.100.58, -NA-, -NA-, -NA-, Username: -NA-, AP name: 943b-b051-d200, Radio ID: 2, Channel number: 6, SSID: XLL, BSSID: 943b-b051-d210. %Mar 19 10:25:56:950 2022 XLL-R STAMGR/6/STAMGR_CLIENT_OFFLINE: Client 32c9-c109-1a7b went offline from BSS 943b-b051-d210 with SSID XLL on AP 943b-b051-d200. State changed to Unauth. Reason:Kicked the new client because of ip-conflict. %Mar 19 10:26:02:043 2022 XLL-R STAMGR/6/STAMGR_CLIENT_ONLINE: Client 32c9-c109-1a7b went online from BSS 943b-b051-2530 with SSID XLL on AP 943b-b051-2520. State changed to Run. %Mar 19 10:26:02:309 2022 XLL-R STAMGR/6/STAMGR_CLIENT_SNOOPING: Detected client IP change: Client MAC: 32c9-c109-1a7b, IP: 172.16.100.58, -NA-, -NA-, -NA-, Username: -NA-, AP name: 943b-b051-2520, Radio ID: 2, Channel number: 6, SSID: XLL, BSSID: 943b-b051-2530. %Mar 19 10:26:02:712 2022 XLL-R STAMGR/6/STAMGR_CLIENT_ONLINE: Client 14c6-975f-979b went online from BSS 943b-b051-ca90 with SSID XLL on AP 943b-b051-ca80. State changed to Run. %Mar 19 10:26:02:713 2022 XLL-R STAMGR/6/STAMGR_ROAM_SUCCESS: Client 14c6-975f-979b roamed from BSSID 943b-b051-c4a0 on AP 943b-b051-c490 of AC IP 127.0.0.1 to BSSID 943b-b051-ca90 on AP 943b-b051-ca80 of AC IP 127.0.0.1 successfully. %Mar 19 10:26:02:714 2022 XLL-R STAMGR/6/STAMGR_CLIENT_OFFLINE: Client 14c6-975f-979b went offline from BSS 943b-b051-c4a0 with SSID XLL on AP 943b-b051-c490. State changed to Unauth. Reason:Successfully roamed to another BSS. %Mar 19 10:26:02:717 2022 XLL-R STAMGR/6/STAMGR_CLIENT_SNOOPING: Detected client IP change: Client MAC: 14c6-975f-979b, IP: 172.16.100.27, -NA-, -NA-, -NA-, Username: -NA-, AP name: 943b-b051-ca80, Radio ID: 2, Channel number: 11, SSID: XLL, BSSID: 943b-b051-ca90. %Mar 19 10:26:06:695 2022 XLL-R STAMGR/6/STAMGR_CLIENT_ONLINE: Client 72ed-14da-d135 went online from BSS 943b-b051-2520 with SSID XLL on AP 943b-b051-2520. State changed to Run. %Mar 19 10:26:06:697 2022 XLL-R STAMGR/6/STAMGR_ROAM_SUCCESS: Client 72ed-14da-d135 roamed from BSSID 943b-b051-e670 on AP 943b-b051-e670 of AC IP 127.0.0.1 to BSSID 943b-b051-2520 on AP 943b-b051-2520 of AC IP 127.0.0.1 successfully. %Mar 19 10:26:06:702 2022 XLL-R STAMGR/6/STAMGR_CLIENT_OFFLINE: Client 72ed-14da-d135 went offline from BSS 943b-b051-e670 with SSID XLL on AP 943b-b051-e670. State changed to Unauth. Reason:Successfully roamed to another BSS. %Mar 19 10:26:06:704 2022 XLL-R STAMGR/6/STAMGR_CLIENT_SNOOPING: Detected client IP change: Client MAC: 72ed-14da-d135, IP: 172.16.100.13, -NA-, -NA-, -NA-, Username: -NA-, AP name: 943b-b051-2520, Radio ID: 1, Channel number: 36, SSID: XLL, BSSID: 943b-b051-2520. %Mar 19 10:26:11:346 2022 XLL-R STAMGR/6/STAMGR_CLIENT_ONLINE: Client 14c6-975f-979b went online from BSS 943b-b051-2530 with SSID XLL on AP 943b-b051-2520. State changed to Run. %Mar 19 10:26:11:350 2022 XLL-R STAMGR/6/STAMGR_ROAM_SUCCESS: Client 14c6-975f-979b roamed from BSSID 943b-b051-ca90 on AP 943b-b051-ca80 of AC IP 127.0.0.1 to BSSID 943b-b051-2530 on AP 943b-b051-2520 of AC IP 127.0.0.1 successfully. %Mar 19 10:26:11:358 2022 XLL-R STAMGR/6/STAMGR_CLIENT_OFFLINE: Client 14c6-975f-979b went offline from BSS 943b-b051-ca90 with SSID XLL on AP 943b-b051-ca80. State changed to Unauth. Reason:Successfully roamed to another BSS. %Mar 19 10:26:11:360 2022 XLL-R STAMGR/6/STAMGR_CLIENT_SNOOPING: Detected client IP change: Client MAC: 14c6-975f-979b, IP: 172.16.100.27, -NA-, -NA-, -NA-, Username: -NA-, AP name: 943b-b051-2520, Radio ID: 2, Channel number: 6, SSID: XLL, BSSID: 943b-b051-2530. %Mar 19 10:26:11:841 2022 XLL-R STAMGR/6/STAMGR_CLIENT_ONLINE: Client 4cea-aee6-fe13 went online from BSS 943b-b051-e680 with SSID XLL on AP 943b-b051-e670. State changed to Run. %Mar 19 10:26:12:022 2022 XLL-R STAMGR/6/STAMGR_CLIENT_SNOOPING: Detected client IP change: Client MAC: 4cea-aee6-fe13, IP: 172.16.100.14, -NA-, -NA-, -NA-, Username: -NA-, AP name: 943b-b051-e670, Radio ID: 2, Channel number: 1, SSID: XLL, BSSID: 943b-b051-e680. %Mar 19 10:26:25:322 2022 XLL-R STAMGR/6/STAMGR_CLIENT_ONLINE: Client e0e0-fc27-eb31 went online from BSS 943b-b051-2370 with SSID XLL on AP 943b-b051-2370. State changed to Run. %Mar 19 10:26:25:327 2022 XLL-R STAMGR/6/STAMGR_ROAM_SUCCESS: Client e0e0-fc27-eb31 roamed from BSSID 00be-d5b3-a640 on AP 00be-d5b3-a640 of AC IP 127.0.0.1 to BSSID 943b-b051-2370 on AP 943b-b051-2370 of AC IP 127.0.0.1 successfully. %Mar 19 10:26:25:330 2022 XLL-R STAMGR/6/STAMGR_CLIENT_SNOOPING: Detected client IP change: Client MAC: e0e0-fc27-eb31, IP: 172.16.100.20, -NA-, -NA-, -NA-, Username: -NA-, AP name: 943b-b051-2370, Radio ID: 1, Channel number: 149, SSID: XLL, BSSID: 943b-b051-2370. %Mar 19 10:26:25:330 2022 XLL-R STAMGR/6/STAMGR_CLIENT_OFFLINE: Client e0e0-fc27-eb31 went offline from BSS 00be-d5b3-a640 with SSID XLL on AP 00be-d5b3-a640. State changed to Unauth. Reason:Successfully roamed to another BSS. %Mar 19 10:26:29:750 2022 XLL-R STAMGR/6/STAMGR_CLIENT_ONLINE: Client 66da-d947-0e6d went online from BSS 943b-b051-1750 with SSID XLL on AP 943b-b051-1740. State changed to Run. %Mar 19 10:26:29:751 2022 XLL-R STAMGR/6/STAMGR_ROAM_SUCCESS: Client 66da-d947-0e6d roamed from BSSID 943b-b051-2330 on AP 943b-b051-2320 of AC IP 127.0.0.1 to BSSID 943b-b051-1750 on AP 943b-b051-1740 of AC IP 127.0.0.1 successfully. %Mar 19 10:26:29:753 2022 XLL-R STAMGR/6/STAMGR_CLIENT_OFFLINE: Client 66da-d947-0e6d went offline from BSS 943b-b051-2330 with SSID XLL on AP 943b-b051-2320. State changed to Unauth. Reason:Successfully roamed to another BSS. %Mar 19 10:26:29:756 2022 XLL-R STAMGR/6/STAMGR_CLIENT_SNOOPING: Detected client IP change: Client MAC: 66da-d947-0e6d, IP: 172.16.100.63, -NA-, -NA-, -NA-, Username: -NA-, AP name: 943b-b051-1740, Radio ID: 2, Channel number: 11, SSID: XLL, BSSID: 943b-b051-1750. %Mar 19 10:26:34:887 2022 XLL-R STAMGR/6/STAMGR_CLIENT_ONLINE: Client f257-eb51-edca went online from BSS 943b-b051-2370 with SSID XLL on AP 943b-b051-2370. State changed to Run. %Mar 19 10:26:34:891 2022 XLL-R STAMGR/6/STAMGR_ROAM_SUCCESS: Client f257-eb51-edca roamed from BSSID 943b-b051-2380 on AP 943b-b051-2370 of AC IP 127.0.0.1 to BSSID 943b-b051-2370 on AP 943b-b051-2370 of AC IP 127.0.0.1 successfully. %Mar 19 10:26:34:897 2022 XLL-R STAMGR/6/STAMGR_CLIENT_OFFLINE: Client f257-eb51-edca went offline from BSS 943b-b051-2380 with SSID XLL on AP 943b-b051-2370. State changed to Unauth. Reason:Successfully roamed to another BSS. %Mar 19 10:26:34:902 2022 XLL-R STAMGR/6/STAMGR_CLIENT_SNOOPING: Detected client IP change: Client MAC: f257-eb51-edca, IP: 172.16.100.16, -NA-, -NA-, -NA-, Username: -NA-, AP name: 943b-b051-2370, Radio ID: 1, Channel number: 149, SSID: XLL, BSSID: 943b-b051-2370. %Mar 19 10:26:37:404 2022 XLL-R STAMGR/6/STAMGR_CLIENT_ONLINE: Client e0e0-fc27-eb31 went online from BSS 943b-b051-2320 with SSID XLL on AP 943b-b051-2320. State changed to Run. %Mar 19 10:26:37:405 2022 XLL-R STAMGR/6/STAMGR_ROAM_SUCCESS: Client e0e0-fc27-eb31 roamed from BSSID 943b-b051-2370 on AP 943b-b051-2370 of AC IP 127.0.0.1 to BSSID 943b-b051-2320 on AP 943b-b051-2320 of AC IP 127.0.0.1 successfully. %Mar 19 10:26:37:406 2022 XLL-R STAMGR/6/STAMGR_CLIENT_OFFLINE: Client e0e0-fc27-eb31 went offline from BSS 943b-b051-2370 with SSID XLL on AP 943b-b051-2370. State changed to Unauth. Reason:Successfully roamed to another BSS. %Mar 19 10:26:37:409 2022 XLL-R STAMGR/6/STAMGR_CLIENT_SNOOPING: Detected client IP change: Client MAC: e0e0-fc27-eb31, IP: 172.16.100.20, -NA-, -NA-, -NA-, Username: -NA-, AP name: 943b-b051-2320, Radio ID: 1, Channel number: 52, SSID: XLL, BSSID: 943b-b051-2320. %Mar 19 10:26:39:736 2022 XLL-R STAMGR/6/STAMGR_CLIENT_OFFLINE: Client f257-eb51-edca went offline from BSS 943b-b051-2370 with SSID XLL on AP 943b-b051-2370. State changed to Unauth. Reason:Received deauthentication message in Run state: reason code=3 %Mar 19 10:26:40:028 2022 XLL-R STAMGR/6/STAMGR_CLIENT_ONLINE: Client f257-eb51-edca went online from BSS 943b-b051-2370 with SSID XLL on AP 943b-b051-2370. State changed to Run. %Mar 19 10:26:40:029 2022 XLL-R STAMGR/6/STAMGR_CLIENT_SNOOPING: Detected client IP change: Client MAC: f257-eb51-edca, IP: 172.16.100.16, -NA-, -NA-, -NA-, Username: -NA-, AP name: 943b-b051-2370, Radio ID: 1, Channel number: 149, SSID: XLL, BSSID: 943b-b051-2370. %Mar 19 10:26:49:722 2022 XLL-R STAMGR/6/STAMGR_CLIENT_ONLINE: Client e0e0-fc27-eb31 went online from BSS 943b-b051-1760 with SSID XLL on AP 943b-b051-1750. State changed to Run. %Mar 19 10:26:49:725 2022 XLL-R STAMGR/6/STAMGR_ROAM_SUCCESS: Client e0e0-fc27-eb31 roamed from BSSID 943b-b051-2320 on AP 943b-b051-2320 of AC IP 127.0.0.1 to BSSID 943b-b051-1760 on AP 943b-b051-1750 of AC IP 127.0.0.1 successfully. %Mar 19 10:26:49:727 2022 XLL-R STAMGR/6/STAMGR_CLIENT_OFFLINE: Client e0e0-fc27-eb31 went offline from BSS 943b-b051-2320 with SSID XLL on AP 943b-b051-2320. State changed to Unauth. Reason:Successfully roamed to another BSS. %Mar 19 10:26:49:729 2022 XLL-R STAMGR/6/STAMGR_CLIENT_SNOOPING: Detected client IP change: Client MAC: e0e0-fc27-eb31, IP: 172.16.100.20, -NA-, -NA-, -NA-, Username: -NA-, AP name: 943b-b051-1750, Radio ID: 2, Channel number: 11, SSID: XLL, BSSID: 943b-b051-1760. %Mar 19 10:26:52:069 2022 XLL-R STAMGR/6/STAMGR_CLIENT_ONLINE: Client c205-f70b-cadf went online from BSS 943b-b051-2330 with SSID XLL on AP 943b-b051-2320. State changed to Run. %Mar 19 10:26:52:152 2022 XLL-R STAMGR/6/STAMGR_CLIENT_SNOOPING: Detected client IP change: Client MAC: c205-f70b-cadf, IP: 172.16.100.66, -NA-, -NA-, -NA-, Username: -NA-, AP name: 943b-b051-2320, Radio ID: 2, Channel number: 6, SSID: XLL, BSSID: 943b-b051-2330. %Mar 19 10:27:00:604 2022 XLL-R STAMGR/6/STAMGR_CLIENT_ONLINE: Client d613-ad03-015e went online from BSS 943b-b051-2520 with SSID XLL on AP 943b-b051-2520. State changed to Run. %Mar 19 10:27:00:607 2022 XLL-R STAMGR/6/STAMGR_ROAM_SUCCESS: Client d613-ad03-015e roamed from BSSID 943b-b051-67f0 on AP 943b-b051-67f0 of AC IP 127.0.0.1 to BSSID 943b-b051-2520 on AP 943b-b051-2520 of AC IP 127.0.0.1 successfully. %Mar 19 10:27:00:609 2022 XLL-R STAMGR/6/STAMGR_CLIENT_OFFLINE: Client d613-ad03-015e went offline from BSS 943b-b051-67f0 with SSID XLL on AP 943b-b051-67f0. State changed to Unauth. Reason:Successfully roamed to another BSS. %Mar 19 10:27:00:611 2022 XLL-R STAMGR/6/STAMGR_CLIENT_SNOOPING: Detected client IP change: Client MAC: d613-ad03-015e, IP: 172.16.100.59, -NA-, -NA-, -NA-, Username: -NA-, AP name: 943b-b051-2520, Radio ID: 1, Channel number: 36, SSID: XLL, BSSID: 943b-b051-2520. %Mar 19 10:27:01:038 2022 XLL-R STAMGR/6/STAMGR_CLIENT_ONLINE: Client 32c9-c109-1a7b went online from BSS 943b-b051-5340 with SSID XLL on AP 943b-b051-5330. State changed to Run. %Mar 19 10:27:01:042 2022 XLL-R STAMGR/6/STAMGR_ROAM_SUCCESS: Client 32c9-c109-1a7b roamed from BSSID 943b-b051-2530 on AP 943b-b051-2520 of AC IP 127.0.0.1 to BSSID 943b-b051-5340 on AP 943b-b051-5330 of AC IP 127.0.0.1 successfully. %Mar 19 10:27:01:044 2022 XLL-R STAMGR/6/STAMGR_CLIENT_OFFLINE: Client 32c9-c109-1a7b went offline from BSS 943b-b051-2530 with SSID XLL on AP 943b-b051-2520. State changed to Unauth. Reason:Successfully roamed to another BSS. %Mar 19 10:27:01:046 2022 XLL-R STAMGR/6/STAMGR_CLIENT_SNOOPING: Detected client IP change: Client MAC: 32c9-c109-1a7b, IP: 172.16.100.58, -NA-, -NA-, -NA-, Username: -NA-, AP name: 943b-b051-5330, Radio ID: 2, Channel number: 11, SSID: XLL, BSSID: 943b-b051-5340. %Mar 19 10:27:05:062 2022 XLL-R STAMGR/6/STAMGR_CLIENT_ONLINE: Client 7a06-25d1-854a went online from BSS 943b-b051-1760 with SSID XLL on AP 943b-b051-1750. State changed to Run. %Mar 19 10:27:05:065 2022 XLL-R STAMGR/6/STAMGR_ROAM_SUCCESS: Client 7a06-25d1-854a roamed from BSSID 943b-b052-1190 on AP 943b-b052-1190 of AC IP 127.0.0.1 to BSSID 943b-b051-1760 on AP 943b-b051-1750 of AC IP 127.0.0.1 successfully. %Mar 19 10:27:05:067 2022 XLL-R STAMGR/6/STAMGR_CLIENT_OFFLINE: Client 7a06-25d1-854a went offline from BSS 943b-b052-1190 with SSID XLL on AP 943b-b052-1190. State changed to Unauth. Reason:Successfully roamed to another BSS. %Mar 19 10:27:05:077 2022 XLL-R STAMGR/6/STAMGR_CLIENT_SNOOPING: Detected client IP change: Client MAC: 7a06-25d1-854a, IP: 172.16.100.43, -NA-, -NA-, -NA-, Username: -NA-, AP name: 943b-b051-1750, Radio ID: 2, Channel number: 11, SSID: XLL, BSSID: 943b-b051-1760. %Mar 19 10:27:10:380 2022 XLL-R STAMGR/6/STAMGR_CLIENT_ONLINE: Client 14c6-975f-979b went online from BSS 943b-b051-c4a0 with SSID XLL on AP 943b-b051-c490. State changed to Run. %Mar 19 10:27:10:383 2022 XLL-R STAMGR/6/STAMGR_ROAM_SUCCESS: Client 14c6-975f-979b roamed from BSSID 943b-b051-2530 on AP 943b-b051-2520 of AC IP 127.0.0.1 to BSSID 943b-b051-c4a0 on AP 943b-b051-c490 of AC IP 127.0.0.1 successfully. %Mar 19 10:27:10:384 2022 XLL-R STAMGR/6/STAMGR_CLIENT_SNOOPING: Detected client IP change: Client MAC: 14c6-975f-979b, IP: 172.16.100.27, -NA-, -NA-, -NA-, Username: -NA-, AP name: 943b-b051-c490, Radio ID: 2, Channel number: 11, SSID: XLL, BSSID: 943b-b051-c4a0. %Mar 19 10:27:10:384 2022 XLL-R STAMGR/6/STAMGR_CLIENT_OFFLINE: Client 14c6-975f-979b went offline from BSS 943b-b051-2530 with SSID XLL on AP 943b-b051-2520. State changed to Unauth. Reason:Successfully roamed to another BSS. %Mar 19 10:27:12:361 2022 XLL-R STAMGR/6/STAMGR_CLIENT_ONLINE: Client 7a06-25d1-854a went online from BSS 943b-b051-2330 with SSID XLL on AP 943b-b051-2320. State changed to Run. %Mar 19 10:27:12:365 2022 XLL-R STAMGR/6/STAMGR_ROAM_SUCCESS: Client 7a06-25d1-854a roamed from BSSID 943b-b051-1760 on AP 943b-b051-1750 of AC IP 127.0.0.1 to BSSID 943b-b051-2330 on AP 943b-b051-2320 of AC IP 127.0.0.1 successfully. %Mar 19 10:27:12:367 2022 XLL-R STAMGR/6/STAMGR_CLIENT_OFFLINE: Client 7a06-25d1-854a went offline from BSS 943b-b051-1760 with SSID XLL on AP 943b-b051-1750. State changed to Unauth. Reason:Successfully roamed to another BSS. %Mar 19 10:27:12:369 2022 XLL-R STAMGR/6/STAMGR_CLIENT_SNOOPING: Detected client IP change: Client MAC: 7a06-25d1-854a, IP: 172.16.100.43, -NA-, -NA-, -NA-, Username: -NA-, AP name: 943b-b051-2320, Radio ID: 2, Channel number: 6, SSID: XLL, BSSID: 943b-b051-2330. %Mar 19 10:27:15:672 2022 XLL-R STAMGR/6/STAMGR_CLIENT_ONLINE: Client 2e98-0262-94b2 went online from BSS 943b-b051-2530 with SSID XLL on AP 943b-b051-2520. State changed to Run. %Mar 19 10:27:15:673 2022 XLL-R STAMGR/6/STAMGR_ROAM_SUCCESS: Client 2e98-0262-94b2 roamed from BSSID 943b-b051-c490 on AP 943b-b051-c490 of AC IP 127.0.0.1 to BSSID 943b-b051-2530 on AP 943b-b051-2520 of AC IP 127.0.0.1 successfully. %Mar 19 10:27:15:675 2022 XLL-R STAMGR/6/STAMGR_CLIENT_OFFLINE: Client 2e98-0262-94b2 went offline from BSS 943b-b051-c490 with SSID XLL on AP 943b-b051-c490. State changed to Unauth. Reason:Successfully roamed to another BSS. %Mar 19 10:27:15:679 2022 XLL-R STAMGR/6/STAMGR_CLIENT_SNOOPING: Detected client IP change: Client MAC: 2e98-0262-94b2, IP: 172.16.100.23, -NA-, -NA-, -NA-, Username: -NA-, AP name: 943b-b051-2520, Radio ID: 2, Channel number: 6, SSID: XLL, BSSID: 943b-b051-2530. %Mar 19 10:27:16:806 2022 XLL-R STAMGR/6/STAMGR_CLIENT_ONLINE: Client 14c6-975f-979b went online from BSS 943b-b051-ca90 with SSID XLL on AP 943b-b051-ca80. State changed to Run. %Mar 19 10:27:16:808 2022 XLL-R STAMGR/6/STAMGR_ROAM_SUCCESS: Client 14c6-975f-979b roamed from BSSID 943b-b051-c4a0 on AP 943b-b051-c490 of AC IP 127.0.0.1 to BSSID 943b-b051-ca90 on AP 943b-b051-ca80 of AC IP 127.0.0.1 successfully. %Mar 19 10:27:16:809 2022 XLL-R STAMGR/6/STAMGR_CLIENT_OFFLINE: Client 14c6-975f-979b went offline from BSS 943b-b051-c4a0 with SSID XLL on AP 943b-b051-c490. State changed to Unauth. Reason:Successfully roamed to another BSS. %Mar 19 10:27:16:813 2022 XLL-R STAMGR/6/STAMGR_CLIENT_SNOOPING: Detected client IP change: Client MAC: 14c6-975f-979b, IP: 172.16.100.27, -NA-, -NA-, -NA-, Username: -NA-, AP name: 943b-b051-ca80, Radio ID: 2, Channel number: 11, SSID: XLL, BSSID: 943b-b051-ca90. %Mar 19 10:27:20:678 2022 XLL-R STAMGR/6/STAMGR_CLIENT_ONLINE: Client 14c6-975f-979b went online from BSS 943b-b051-c4a0 with SSID XLL on AP 943b-b051-c490. State changed to Run. %Mar 19 10:27:20:679 2022 XLL-R STAMGR/6/STAMGR_ROAM_SUCCESS: Client 14c6-975f-979b roamed from BSSID 943b-b051-ca90 on AP 943b-b051-ca80 of AC IP 127.0.0.1 to BSSID 943b-b051-c4a0 on AP 943b-b051-c490 of AC IP 127.0.0.1 successfully. %Mar 19 10:27:20:682 2022 XLL-R STAMGR/6/STAMGR_CLIENT_SNOOPING: Detected client IP change: Client MAC: 14c6-975f-979b, IP: 172.16.100.27, -NA-, -NA-, -NA-, Username: -NA-, AP name: 943b-b051-c490, Radio ID: 2, Channel number: 11, SSID: XLL, BSSID: 943b-b051-c4a0. %Mar 19 10:27:20:689 2022 XLL-R STAMGR/6/STAMGR_CLIENT_OFFLINE: Client 14c6-975f-979b went offline from BSS 943b-b051-ca90 with SSID XLL on AP 943b-b051-ca80. State changed to Unauth. Reason:Successfully roamed to another BSS. %Mar 19 10:27:25:244 2022 XLL-R STAMGR/6/STAMGR_CLIENT_ONLINE: Client e0e0-fc27-eb31 went online from BSS 943b-b052-1190 with SSID XLL on AP 943b-b052-1190. State changed to Run. %Mar 19 10:27:25:246 2022 XLL-R STAMGR/6/STAMGR_ROAM_SUCCESS: Client e0e0-fc27-eb31 roamed from BSSID 943b-b051-1760 on AP 943b-b051-1750 of AC IP 127.0.0.1 to BSSID 943b-b052-1190 on AP 943b-b052-1190 of AC IP 127.0.0.1 successfully. %Mar 19 10:27:25:247 2022 XLL-R STAMGR/6/STAMGR_CLIENT_OFFLINE: Client e0e0-fc27-eb31 went offline from BSS 943b-b051-1760 with SSID XLL on AP 943b-b051-1750. State changed to Unauth. Reason:Successfully roamed to another BSS. %Mar 19 10:27:25:248 2022 XLL-R STAMGR/6/STAMGR_CLIENT_SNOOPING: Detected client IP change: Client MAC: e0e0-fc27-eb31, IP: 172.16.100.20, -NA-, -NA-, -NA-, Username: -NA-, AP name: 943b-b052-1190, Radio ID: 1, Channel number: 36, SSID: XLL, BSSID: 943b-b052-1190. %Mar 19 10:27:26:751 2022 XLL-R STAMGR/6/STAMGR_CLIENT_ONLINE: Client 7a06-25d1-854a went online from BSS 943b-b052-1190 with SSID XLL on AP 943b-b052-1190. State changed to Run. %Mar 19 10:27:26:752 2022 XLL-R STAMGR/6/STAMGR_ROAM_SUCCESS: Client 7a06-25d1-854a roamed from BSSID 943b-b051-2330 on AP 943b-b051-2320 of AC IP 127.0.0.1 to BSSID 943b-b052-1190 on AP 943b-b052-1190 of AC IP 127.0.0.1 successfully. %Mar 19 10:27:26:754 2022 XLL-R STAMGR/6/STAMGR_CLIENT_OFFLINE: Client 7a06-25d1-854a went offline from BSS 943b-b051-2330 with SSID XLL on AP 943b-b051-2320. State changed to Unauth. Reason:Successfully roamed to another BSS. %Mar 19 10:27:26:756 2022 XLL-R STAMGR/6/STAMGR_CLIENT_SNOOPING: Detected client IP change: Client MAC: 7a06-25d1-854a, IP: 172.16.100.43, -NA-, -NA-, -NA-, Username: -NA-, AP name: 943b-b052-1190, Radio ID: 1, Channel number: 36, SSID: XLL, BSSID: 943b-b052-1190. %Mar 19 10:27:31:458 2022 XLL-R STAMGR/6/STAMGR_CLIENT_ONLINE: Client 14c6-975f-979b went online from BSS 943b-b051-c490 with SSID XLL on AP 943b-b051-c490. State changed to Run. %Mar 19 10:27:31:462 2022 XLL-R STAMGR/6/STAMGR_ROAM_SUCCESS: Client 14c6-975f-979b roamed from BSSID 943b-b051-c4a0 on AP 943b-b051-c490 of AC IP 127.0.0.1 to BSSID 943b-b051-c490 on AP 943b-b051-c490 of AC IP 127.0.0.1 successfully. %Mar 19 10:27:31:463 2022 XLL-R STAMGR/6/STAMGR_CLIENT_OFFLINE: Client 14c6-975f-979b went offline from BSS 943b-b051-c4a0 with SSID XLL on AP 943b-b051-c490. State changed to Unauth. Reason:Successfully roamed to another BSS. %Mar 19 10:27:31:465 2022 XLL-R STAMGR/6/STAMGR_CLIENT_SNOOPING: Detected client IP change: Client MAC: 14c6-975f-979b, IP: 172.16.100.27, -NA-, -NA-, -NA-, Username: -NA-, AP name: 943b-b051-c490, Radio ID: 1, Channel number: 36, SSID: XLL, BSSID: 943b-b051-c490. %Mar 19 10:27:42:218 2022 XLL-R STAMGR/6/STAMGR_CLIENT_ONLINE: Client cc81-2ab4-c711 went online from BSS 943b-b051-ce30 with SSID XLL on AP 943b-b051-ce20. State changed to Run. %Mar 19 10:27:42:299 2022 XLL-R STAMGR/6/STAMGR_CLIENT_SNOOPING: Detected client IP change: Client MAC: cc81-2ab4-c711, IP: 172.16.100.11, -NA-, -NA-, -NA-, Username: -NA-, AP name: 943b-b051-ce20, Radio ID: 2, Channel number: 11, SSID: XLL, BSSID: 943b-b051-ce30. %Mar 19 10:28:01:102 2022 XLL-R STAMGR/6/STAMGR_CLIENT_ONLINE: Client 9c0c-df8f-b07f went online from BSS 943b-b052-11a0 with SSID XLL on AP 943b-b052-1190. State changed to Run. %Mar 19 10:28:01:106 2022 XLL-R STAMGR/6/STAMGR_ROAM_SUCCESS: Client 9c0c-df8f-b07f roamed from BSSID 943b-b051-1750 on AP 943b-b051-1740 of AC IP 127.0.0.1 to BSSID 943b-b052-11a0 on AP 943b-b052-1190 of AC IP 127.0.0.1 successfully. %Mar 19 10:28:01:107 2022 XLL-R STAMGR/6/STAMGR_CLIENT_OFFLINE: Client 9c0c-df8f-b07f went offline from BSS 943b-b051-1750 with SSID XLL on AP 943b-b051-1740. State changed to Unauth. Reason:Successfully roamed to another BSS. %Mar 19 10:28:01:109 2022 XLL-R STAMGR/6/STAMGR_CLIENT_SNOOPING: Detected client IP change: Client MAC: 9c0c-df8f-b07f, IP: 172.16.100.3, -NA-, -NA-, -NA-, Username: -NA-, AP name: 943b-b052-1190, Radio ID: 2, Channel number: 11, SSID: XLL, BSSID: 943b-b052-11a0. %Mar 19 10:28:06:159 2022 XLL-R STAMGR/6/STAMGR_CLIENT_ONLINE: Client 32c9-c109-1a7b went online from BSS 943b-b051-2530 with SSID XLL on AP 943b-b051-2520. State changed to Run. %Mar 19 10:28:06:162 2022 XLL-R STAMGR/6/STAMGR_ROAM_SUCCESS: Client 32c9-c109-1a7b roamed from BSSID 943b-b051-5340 on AP 943b-b051-5330 of AC IP 127.0.0.1 to BSSID 943b-b051-2530 on AP 943b-b051-2520 of AC IP 127.0.0.1 successfully. %Mar 19 10:28:06:165 2022 XLL-R STAMGR/6/STAMGR_CLIENT_OFFLINE: Client 32c9-c109-1a7b went offline from BSS 943b-b051-5340 with SSID XLL on AP 943b-b051-5330. State changed to Unauth. Reason:Successfully roamed to another BSS. %Mar 19 10:28:06:168 2022 XLL-R STAMGR/6/STAMGR_CLIENT_SNOOPING: Detected client IP change: Client MAC: 32c9-c109-1a7b, IP: 172.16.100.58, -NA-, -NA-, -NA-, Username: -NA-, AP name: 943b-b051-2520, Radio ID: 2, Channel number: 6, SSID: XLL, BSSID: 943b-b051-2530. %Mar 19 10:28:18:213 2022 XLL-R STAMGR/6/STAMGR_CLIENT_ONLINE: Client 66da-d947-0e6d went online from BSS 943b-b051-2330 with SSID XLL on AP 943b-b051-2320. State changed to Run. %Mar 19 10:28:18:215 2022 XLL-R STAMGR/6/STAMGR_ROAM_SUCCESS: Client 66da-d947-0e6d roamed from BSSID 943b-b051-1750 on AP 943b-b051-1740 of AC IP 127.0.0.1 to BSSID 943b-b051-2330 on AP 943b-b051-2320 of AC IP 127.0.0.1 successfully. %Mar 19 10:28:18:220 2022 XLL-R STAMGR/6/STAMGR_CLIENT_OFFLINE: Client 66da-d947-0e6d went offline from BSS 943b-b051-1750 with SSID XLL on AP 943b-b051-1740. State changed to Unauth. Reason:Successfully roamed to another BSS. %Mar 19 10:28:18:224 2022 XLL-R STAMGR/6/STAMGR_CLIENT_SNOOPING: Detected client IP change: Client MAC: 66da-d947-0e6d, IP: 172.16.100.63, -NA-, -NA-, -NA-, Username: -NA-, AP name: 943b-b051-2320, Radio ID: 2, Channel number: 6, SSID: XLL, BSSID: 943b-b051-2330. %Mar 19 10:28:26:909 2022 XLL-R STAMGR/6/STAMGR_CLIENT_SNOOPING: Detected client IP change: Client MAC: 9c0c-df8f-b07f, IP: 172.16.100.3, -NA-, -NA-, -NA-, Username: -NA-, AP name: 943b-b051-1740, Radio ID: 2, Channel number: 11, SSID: XLL, BSSID: 943b-b051-1750. %Mar 19 10:28:26:927 2022 XLL-R STAMGR/6/STAMGR_CLIENT_ONLINE: Client 9c0c-df8f-b07f went online from BSS 943b-b051-1750 with SSID XLL on AP 943b-b051-1740. State changed to Run. %Mar 19 10:28:26:946 2022 XLL-R STAMGR/6/STAMGR_ROAM_SUCCESS: Client 9c0c-df8f-b07f roamed from BSSID 943b-b052-11a0 on AP 943b-b052-1190 of AC IP 127.0.0.1 to BSSID 943b-b051-1750 on AP 943b-b051-1740 of AC IP 127.0.0.1 successfully. %Mar 19 10:28:26:948 2022 XLL-R STAMGR/6/STAMGR_CLIENT_OFFLINE: Client 9c0c-df8f-b07f went offline from BSS 943b-b052-11a0 with SSID XLL on AP 943b-b052-1190. State changed to Unauth. Reason:Successfully roamed to another BSS. %Mar 19 10:28:29:933 2022 XLL-R STAMGR/6/STAMGR_CLIENT_ONLINE: Client d613-ad03-015e went online from BSS 943b-b051-2530 with SSID XLL on AP 943b-b051-2520. State changed to Run. %Mar 19 10:28:29:937 2022 XLL-R STAMGR/6/STAMGR_CLIENT_OFFLINE: Client d613-ad03-015e went offline from BSS 943b-b051-2520 with SSID XLL on AP 943b-b051-2520. State changed to Unauth. Reason:Successfully roamed to another BSS. %Mar 19 10:28:29:939 2022 XLL-R STAMGR/6/STAMGR_ROAM_SUCCESS: Client d613-ad03-015e roamed from BSSID 943b-b051-2520 on AP 943b-b051-2520 of AC IP 127.0.0.1 to BSSID 943b-b051-2530 on AP 943b-b051-2520 of AC IP 127.0.0.1 successfully. %Mar 19 10:28:29:940 2022 XLL-R STAMGR/6/STAMGR_CLIENT_SNOOPING: Detected client IP change: Client MAC: d613-ad03-015e, IP: 172.16.100.59, -NA-, -NA-, -NA-, Username: -NA-, AP name: 943b-b051-2520, Radio ID: 2, Channel number: 6, SSID: XLL, BSSID: 943b-b051-2530. %Mar 19 10:28:32:967 2022 XLL-R STAMGR/6/STAMGR_CLIENT_ONLINE: Client 7a06-25d1-854a went online from BSS 943b-b051-2420 with SSID XLL on AP 943b-b051-2420. State changed to Run. %Mar 19 10:28:32:972 2022 XLL-R STAMGR/6/STAMGR_ROAM_SUCCESS: Client 7a06-25d1-854a roamed from BSSID 943b-b052-1190 on AP 943b-b052-1190 of AC IP 127.0.0.1 to BSSID 943b-b051-2420 on AP 943b-b051-2420 of AC IP 127.0.0.1 successfully. %Mar 19 10:28:32:973 2022 XLL-R STAMGR/6/STAMGR_CLIENT_OFFLINE: Client 7a06-25d1-854a went offline from BSS 943b-b052-1190 with SSID XLL on AP 943b-b052-1190. State changed to Unauth. Reason:Successfully roamed to another BSS. %Mar 19 10:28:32:975 2022 XLL-R STAMGR/6/STAMGR_CLIENT_SNOOPING: Detected client IP change: Client MAC: 7a06-25d1-854a, IP: 172.16.100.43, -NA-, -NA-, -NA-, Username: -NA-, AP name: 943b-b051-2420, Radio ID: 1, Channel number: 36, SSID: XLL, BSSID: 943b-b051-2420. %Mar 19 10:28:36:952 2022 XLL-R STAMGR/6/STAMGR_CLIENT_ONLINE: Client 7a06-25d1-854a went online from BSS 943b-b051-2430 with SSID XLL on AP 943b-b051-2420. State changed to Run. %Mar 19 10:28:36:956 2022 XLL-R STAMGR/6/STAMGR_ROAM_SUCCESS: Client 7a06-25d1-854a roamed from BSSID 943b-b051-2420 on AP 943b-b051-2420 of AC IP 127.0.0.1 to BSSID 943b-b051-2430 on AP 943b-b051-2420 of AC IP 127.0.0.1 successfully. %Mar 19 10:28:36:965 2022 XLL-R STAMGR/6/STAMGR_CLIENT_OFFLINE: Client 7a06-25d1-854a went offline from BSS 943b-b051-2420 with SSID XLL on AP 943b-b051-2420. State changed to Unauth. Reason:Successfully roamed to another BSS. %Mar 19 10:28:36:966 2022 XLL-R STAMGR/6/STAMGR_CLIENT_SNOOPING: Detected client IP change: Client MAC: 7a06-25d1-854a, IP: 172.16.100.43, -NA-, -NA-, -NA-, Username: -NA-, AP name: 943b-b051-2420, Radio ID: 2, Channel number: 11, SSID: XLL, BSSID: 943b-b051-2430. %Mar 19 10:28:43:065 2022 XLL-R STAMGR/6/STAMGR_CLIENT_ONLINE: Client 7a06-25d1-854a went online from BSS 943b-b052-11a0 with SSID XLL on AP 943b-b052-1190. State changed to Run. %Mar 19 10:28:43:069 2022 XLL-R STAMGR/6/STAMGR_ROAM_SUCCESS: Client 7a06-25d1-854a roamed from BSSID 943b-b051-2430 on AP 943b-b051-2420 of AC IP 127.0.0.1 to BSSID 943b-b052-11a0 on AP 943b-b052-1190 of AC IP 127.0.0.1 successfully. %Mar 19 10:28:43:078 2022 XLL-R STAMGR/6/STAMGR_CLIENT_OFFLINE: Client 7a06-25d1-854a went offline from BSS 943b-b051-2430 with SSID XLL on AP 943b-b051-2420. State changed to Unauth. Reason:Successfully roamed to another BSS. %Mar 19 10:28:43:079 2022 XLL-R STAMGR/6/STAMGR_CLIENT_SNOOPING: Detected client IP change: Client MAC: 7a06-25d1-854a, IP: 172.16.100.43, -NA-, -NA-, -NA-, Username: -NA-, AP name: 943b-b052-1190, Radio ID: 2, Channel number: 11, SSID: XLL, BSSID: 943b-b052-11a0. %Mar 19 10:28:43:129 2022 XLL-R STAMGR/6/STAMGR_CLIENT_ONLINE: Client 0c93-8ff9-adc1 went online from BSS 943b-b051-1740 with SSID XLL on AP 943b-b051-1740. State changed to Run. %Mar 19 10:28:43:131 2022 XLL-R STAMGR/6/STAMGR_ROAM_SUCCESS: Client 0c93-8ff9-adc1 roamed from BSSID 943b-b051-2320 on AP 943b-b051-2320 of AC IP 127.0.0.1 to BSSID 943b-b051-1740 on AP 943b-b051-1740 of AC IP 127.0.0.1 successfully. %Mar 19 10:28:43:134 2022 XLL-R STAMGR/6/STAMGR_CLIENT_OFFLINE: Client 0c93-8ff9-adc1 went offline from BSS 943b-b051-2320 with SSID XLL on AP 943b-b051-2320. State changed to Unauth. Reason:Successfully roamed to another BSS. %Mar 19 10:28:43:136 2022 XLL-R STAMGR/6/STAMGR_CLIENT_SNOOPING: Detected client IP change: Client MAC: 0c93-8ff9-adc1, IP: 172.16.100.51, -NA-, -NA-, -NA-, Username: -NA-, AP name: 943b-b051-1740, Radio ID: 1, Channel number: 36, SSID: XLL, BSSID: 943b-b051-1740. %Mar 19 10:28:50:876 2022 XLL-R STAMGR/6/STAMGR_CLIENT_OFFLINE: Client 9c0c-df8f-b07f went offline from BSS 943b-b051-1750 with SSID XLL on AP 943b-b051-1740. State changed to Unauth. Reason:Received deauthentication message in Run state: reason code=3 %Mar 19 10:29:00:543 2022 XLL-R STAMGR/6/STAMGR_CLIENT_ONLINE: Client 32c9-c109-1a7b went online from BSS 943b-b051-2430 with SSID XLL on AP 943b-b051-2420. State changed to Run. %Mar 19 10:29:00:545 2022 XLL-R STAMGR/6/STAMGR_ROAM_SUCCESS: Client 32c9-c109-1a7b roamed from BSSID 943b-b051-2530 on AP 943b-b051-2520 of AC IP 127.0.0.1 to BSSID 943b-b051-2430 on AP 943b-b051-2420 of AC IP 127.0.0.1 successfully. %Mar 19 10:29:00:546 2022 XLL-R STAMGR/6/STAMGR_CLIENT_OFFLINE: Client 32c9-c109-1a7b went offline from BSS 943b-b051-2530 with SSID XLL on AP 943b-b051-2520. State changed to Unauth. Reason:Successfully roamed to another BSS. %Mar 19 10:29:00:548 2022 XLL-R STAMGR/6/STAMGR_CLIENT_SNOOPING: Detected client IP change: Client MAC: 32c9-c109-1a7b, IP: 172.16.100.58, -NA-, -NA-, -NA-, Username: -NA-, AP name: 943b-b051-2420, Radio ID: 2, Channel number: 11, SSID: XLL, BSSID: 943b-b051-2430. %Mar 19 10:29:00:703 2022 XLL-R STAMGR/6/STAMGR_CLIENT_ONLINE: Client 32c9-c109-1a7b went online from BSS 943b-b051-5340 with SSID XLL on AP 943b-b051-5330. State changed to Run. %Mar 19 10:29:00:705 2022 XLL-R STAMGR/6/STAMGR_ROAM_SUCCESS: Client 32c9-c109-1a7b roamed from BSSID 943b-b051-2430 on AP 943b-b051-2420 of AC IP 127.0.0.1 to BSSID 943b-b051-5340 on AP 943b-b051-5330 of AC IP 127.0.0.1 successfully. %Mar 19 10:29:00:709 2022 XLL-R STAMGR/6/STAMGR_CLIENT_SNOOPING: Detected client IP change: Client MAC: 32c9-c109-1a7b, IP: 172.16.100.58, -NA-, -NA-, -NA-, Username: -NA-, AP name: 943b-b051-5330, Radio ID: 2, Channel number: 11, SSID: XLL, BSSID: 943b-b051-5340. %Mar 19 10:29:00:715 2022 XLL-R STAMGR/6/STAMGR_CLIENT_OFFLINE: Client 32c9-c109-1a7b went offline from BSS 943b-b051-2430 with SSID XLL on AP 943b-b051-2420. State changed to Unauth. Reason:Successfully roamed to another BSS. %Mar 19 10:29:03:596 2022 XLL-R STAMGR/6/STAMGR_CLIENT_ONLINE: Client 14c6-975f-979b went online from BSS 943b-b051-2530 with SSID XLL on AP 943b-b051-2520. State changed to Run. %Mar 19 10:29:03:602 2022 XLL-R STAMGR/6/STAMGR_ROAM_SUCCESS: Client 14c6-975f-979b roamed from BSSID 943b-b051-c490 on AP 943b-b051-c490 of AC IP 127.0.0.1 to BSSID 943b-b051-2530 on AP 943b-b051-2520 of AC IP 127.0.0.1 successfully. %Mar 19 10:29:03:610 2022 XLL-R STAMGR/6/STAMGR_CLIENT_OFFLINE: Client 14c6-975f-979b went offline from BSS 943b-b051-c490 with SSID XLL on AP 943b-b051-c490. State changed to Unauth. Reason:Successfully roamed to another BSS. %Mar 19 10:29:03:616 2022 XLL-R STAMGR/6/STAMGR_CLIENT_SNOOPING: Detected client IP change: Client MAC: 14c6-975f-979b, IP: 172.16.100.27, -NA-, -NA-, -NA-, Username: -NA-, AP name: 943b-b051-2520, Radio ID: 2, Channel number: 6, SSID: XLL, BSSID: 943b-b051-2530. %Mar 19 10:29:03:642 2022 XLL-R STAMGR/6/STAMGR_CLIENT_OFFLINE: Client d613-ad03-015e went offline from BSS 943b-b051-2530 with SSID XLL on AP 943b-b051-2520. State changed to Unauth. Reason:Received disassociation frame in Run state: reason code=3 %Mar 19 10:29:04:568 2022 XLL-R STAMGR/6/STAMGR_CLIENT_ONLINE: Client d613-ad03-015e went online from BSS 943b-b051-6800 with SSID XLL on AP 943b-b051-67f0. State changed to Run. %Mar 19 10:29:04:572 2022 XLL-R STAMGR/6/STAMGR_ROAM_SUCCESS: Client d613-ad03-015e roamed from BSSID 943b-b051-2530 on AP 943b-b051-2520 of AC IP 127.0.0.1 to BSSID 943b-b051-6800 on AP 943b-b051-67f0 of AC IP 127.0.0.1 successfully. %Mar 19 10:29:04:575 2022 XLL-R STAMGR/6/STAMGR_CLIENT_SNOOPING: Detected client IP change: Client MAC: d613-ad03-015e, IP: 172.16.100.59, -NA-, -NA-, -NA-, Username: -NA-, AP name: 943b-b051-67f0, Radio ID: 2, Channel number: 6, SSID: XLL, BSSID: 943b-b051-6800. %Mar 19 10:29:07:978 2022 XLL-R STAMGR/6/STAMGR_CLIENT_ONLINE: Client a6e1-a489-f9e2 went online from BSS 943b-b051-2520 with SSID XLL on AP 943b-b051-2520. State changed to Run. %Mar 19 10:29:07:982 2022 XLL-R STAMGR/6/STAMGR_ROAM_SUCCESS: Client a6e1-a489-f9e2 roamed from BSSID 943b-b051-2530 on AP 943b-b051-2520 of AC IP 127.0.0.1 to BSSID 943b-b051-2520 on AP 943b-b051-2520 of AC IP 127.0.0.1 successfully. %Mar 19 10:29:07:983 2022 XLL-R STAMGR/6/STAMGR_CLIENT_OFFLINE: Client a6e1-a489-f9e2 went offline from BSS 943b-b051-2530 with SSID XLL on AP 943b-b051-2520. State changed to Unauth. Reason:Successfully roamed to another BSS. %Mar 19 10:29:07:986 2022 XLL-R STAMGR/6/STAMGR_CLIENT_SNOOPING: Detected client IP change: Client MAC: a6e1-a489-f9e2, IP: 172.16.100.5, 172.16.100.87, -NA-, -NA-, Username: -NA-, AP name: 943b-b051-2520, Radio ID: 1, Channel number: 36, SSID: XLL, BSSID: 943b-b051-2520. %Mar 19 10:29:09:231 2022 XLL-R STAMGR/6/STAMGR_CLIENT_ONLINE: Client 14c6-975f-979b went online from BSS 943b-b051-c4a0 with SSID XLL on AP 943b-b051-c490. State changed to Run. %Mar 19 10:29:09:234 2022 XLL-R STAMGR/6/STAMGR_ROAM_SUCCESS: Client 14c6-975f-979b roamed from BSSID 943b-b051-2530 on AP 943b-b051-2520 of AC IP 127.0.0.1 to BSSID 943b-b051-c4a0 on AP 943b-b051-c490 of AC IP 127.0.0.1 successfully. %Mar 19 10:29:09:235 2022 XLL-R STAMGR/6/STAMGR_CLIENT_SNOOPING: Detected client IP change: Client MAC: 14c6-975f-979b, IP: 172.16.100.27, -NA-, -NA-, -NA-, Username: -NA-, AP name: 943b-b051-c490, Radio ID: 2, Channel number: 11, SSID: XLL, BSSID: 943b-b051-c4a0. %Mar 19 10:29:09:238 2022 XLL-R STAMGR/6/STAMGR_CLIENT_OFFLINE: Client 14c6-975f-979b went offline from BSS 943b-b051-2530 with SSID XLL on AP 943b-b051-2520. State changed to Unauth. Reason:Successfully roamed to another BSS. %Mar 19 10:29:10:661 2022 XLL-R STAMGR/6/STAMGR_CLIENT_ONLINE: Client 0c93-8ff9-adc1 went online from BSS 00be-d5b3-a1a0 with SSID XLL on AP 00be-d5b3-a1a0. State changed to Run. %Mar 19 10:29:10:665 2022 XLL-R STAMGR/6/STAMGR_ROAM_SUCCESS: Client 0c93-8ff9-adc1 roamed from BSSID 943b-b051-1740 on AP 943b-b051-1740 of AC IP 127.0.0.1 to BSSID 00be-d5b3-a1a0 on AP 00be-d5b3-a1a0 of AC IP 127.0.0.1 successfully. %Mar 19 10:29:10:674 2022 XLL-R STAMGR/6/STAMGR_CLIENT_OFFLINE: Client 0c93-8ff9-adc1 went offline from BSS 943b-b051-1740 with SSID XLL on AP 943b-b051-1740. State changed to Unauth. Reason:Successfully roamed to another BSS. %Mar 19 10:29:10:676 2022 XLL-R STAMGR/6/STAMGR_CLIENT_SNOOPING: Detected client IP change: Client MAC: 0c93-8ff9-adc1, IP: 172.16.100.51, -NA-, -NA-, -NA-, Username: -NA-, AP name: 00be-d5b3-a1a0, Radio ID: 1, Channel number: 149, SSID: XLL, BSSID: 00be-d5b3-a1a0. %Mar 19 10:29:13:611 2022 XLL-R STAMGR/6/STAMGR_CLIENT_ONLINE: Client a6e1-a489-f9e2 went online from BSS 943b-b051-2530 with SSID XLL on AP 943b-b051-2520. State changed to Run. %Mar 19 10:29:13:615 2022 XLL-R STAMGR/6/STAMGR_ROAM_SUCCESS: Client a6e1-a489-f9e2 roamed from BSSID 943b-b051-2520 on AP 943b-b051-2520 of AC IP 127.0.0.1 to BSSID 943b-b051-2530 on AP 943b-b051-2520 of AC IP 127.0.0.1 successfully. %Mar 19 10:29:13:616 2022 XLL-R STAMGR/6/STAMGR_CLIENT_OFFLINE: Client a6e1-a489-f9e2 went offline from BSS 943b-b051-2520 with SSID XLL on AP 943b-b051-2520. State changed to Unauth. Reason:Successfully roamed to another BSS. %Mar 19 10:29:13:618 2022 XLL-R STAMGR/6/STAMGR_CLIENT_SNOOPING: Detected client IP change: Client MAC: a6e1-a489-f9e2, IP: 172.16.100.5, 172.16.100.87, -NA-, -NA-, Username: -NA-, AP name: 943b-b051-2520, Radio ID: 2, Channel number: 6, SSID: XLL, BSSID: 943b-b051-2530. %Mar 19 10:29:15:167 2022 XLL-R STAMGR/6/STAMGR_CLIENT_OFFLINE: Client 7a06-25d1-854a went offline from BSS 943b-b052-11a0 with SSID XLL on AP 943b-b052-1190. State changed to Unauth. Reason:Received deauthentication message in Run state: reason code=3 %Mar 19 10:29:22:035 2022 XLL-R STAMGR/6/STAMGR_CLIENT_ONLINE: Client d613-ad03-015e went online from BSS 943b-b051-d210 with SSID XLL on AP 943b-b051-d200. State changed to Run. %Mar 19 10:29:22:037 2022 XLL-R STAMGR/6/STAMGR_ROAM_SUCCESS: Client d613-ad03-015e roamed from BSSID 943b-b051-6800 on AP 943b-b051-67f0 of AC IP 127.0.0.1 to BSSID 943b-b051-d210 on AP 943b-b051-d200 of AC IP 127.0.0.1 successfully. %Mar 19 10:29:22:040 2022 XLL-R STAMGR/6/STAMGR_CLIENT_OFFLINE: Client d613-ad03-015e went offline from BSS 943b-b051-6800 with SSID XLL on AP 943b-b051-67f0. State changed to Unauth. Reason:Successfully roamed to another BSS. %Mar 19 10:29:22:042 2022 XLL-R STAMGR/6/STAMGR_CLIENT_SNOOPING: Detected client IP change: Client MAC: d613-ad03-015e, IP: 172.16.100.59, -NA-, -NA-, -NA-, Username: -NA-, AP name: 943b-b051-d200, Radio ID: 2, Channel number: 6, SSID: XLL, BSSID: 943b-b051-d210. %Mar 19 10:29:23:397 2022 XLL-R STAMGR/6/STAMGR_CLIENT_ONLINE: Client 0c93-8ff9-adc1 went online from BSS 00be-d5b3-98c0 with SSID XLL on AP 00be-d5b3-98c0. State changed to Run. %Mar 19 10:29:23:401 2022 XLL-R STAMGR/6/STAMGR_ROAM_SUCCESS: Client 0c93-8ff9-adc1 roamed from BSSID 00be-d5b3-a1a0 on AP 00be-d5b3-a1a0 of AC IP 127.0.0.1 to BSSID 00be-d5b3-98c0 on AP 00be-d5b3-98c0 of AC IP 127.0.0.1 successfully. %Mar 19 10:29:23:408 2022 XLL-R STAMGR/6/STAMGR_CLIENT_OFFLINE: Client 0c93-8ff9-adc1 went offline from BSS 00be-d5b3-a1a0 with SSID XLL on AP 00be-d5b3-a1a0. State changed to Unauth. Reason:Successfully roamed to another BSS. %Mar 19 10:29:23:410 2022 XLL-R STAMGR/6/STAMGR_CLIENT_SNOOPING: Detected client IP change: Client MAC: 0c93-8ff9-adc1, IP: 172.16.100.51, -NA-, -NA-, -NA-, Username: -NA-, AP name: 00be-d5b3-98c0, Radio ID: 1, Channel number: 149, SSID: XLL, BSSID: 00be-d5b3-98c0. %Mar 19 10:29:25:994 2022 XLL-R STAMGR/6/STAMGR_CLIENT_ONLINE: Client 32c9-c109-1a7b went online from BSS 943b-b051-d210 with SSID XLL on AP 943b-b051-d200. State changed to Run. %Mar 19 10:29:25:996 2022 XLL-R STAMGR/6/STAMGR_ROAM_SUCCESS: Client 32c9-c109-1a7b roamed from BSSID 943b-b051-5340 on AP 943b-b051-5330 of AC IP 127.0.0.1 to BSSID 943b-b051-d210 on AP 943b-b051-d200 of AC IP 127.0.0.1 successfully. %Mar 19 10:29:25:999 2022 XLL-R STAMGR/6/STAMGR_CLIENT_SNOOPING: Detected client IP change: Client MAC: 32c9-c109-1a7b, IP: 172.16.100.58, -NA-, -NA-, -NA-, Username: -NA-, AP name: 943b-b051-d200, Radio ID: 2, Channel number: 6, SSID: XLL, BSSID: 943b-b051-d210. %Mar 19 10:29:26:000 2022 XLL-R STAMGR/6/STAMGR_CLIENT_OFFLINE: Client 32c9-c109-1a7b went offline from BSS 943b-b051-5340 with SSID XLL on AP 943b-b051-5330. State changed to Unauth. Reason:Successfully roamed to another BSS. %Mar 19 10:29:26:860 2022 XLL-R STAMGR/6/STAMGR_CLIENT_ONLINE: Client c205-f70b-cadf went online from BSS 943b-b051-1750 with SSID XLL on AP 943b-b051-1740. State changed to Run. %Mar 19 10:29:26:862 2022 XLL-R STAMGR/6/STAMGR_ROAM_SUCCESS: Client c205-f70b-cadf roamed from BSSID 943b-b051-2330 on AP 943b-b051-2320 of AC IP 127.0.0.1 to BSSID 943b-b051-1750 on AP 943b-b051-1740 of AC IP 127.0.0.1 successfully. %Mar 19 10:29:26:864 2022 XLL-R STAMGR/6/STAMGR_CLIENT_OFFLINE: Client c205-f70b-cadf went offline from BSS 943b-b051-2330 with SSID XLL on AP 943b-b051-2320. State changed to Unauth. Reason:Successfully roamed to another BSS. %Mar 19 10:29:26:866 2022 XLL-R STAMGR/6/STAMGR_CLIENT_SNOOPING: Detected client IP change: Client MAC: c205-f70b-cadf, IP: 172.16.100.66, -NA-, -NA-, -NA-, Username: -NA-, AP name: 943b-b051-1740, Radio ID: 2, Channel number: 11, SSID: XLL, BSSID: 943b-b051-1750. %Mar 19 10:29:33:512 2022 XLL-R STAMGR/6/STAMGR_CLIENT_ONLINE: Client 32c9-c109-1a7b went online from BSS 943b-b051-5340 with SSID XLL on AP 943b-b051-5330. State changed to Run. %Mar 19 10:29:33:514 2022 XLL-R STAMGR/6/STAMGR_ROAM_SUCCESS: Client 32c9-c109-1a7b roamed from BSSID 943b-b051-d210 on AP 943b-b051-d200 of AC IP 127.0.0.1 to BSSID 943b-b051-5340 on AP 943b-b051-5330 of AC IP 127.0.0.1 successfully. %Mar 19 10:29:33:516 2022 XLL-R STAMGR/6/STAMGR_CLIENT_OFFLINE: Client 32c9-c109-1a7b went offline from BSS 943b-b051-d210 with SSID XLL on AP 943b-b051-d200. State changed to Unauth. Reason:Successfully roamed to another BSS. %Mar 19 10:29:33:517 2022 XLL-R STAMGR/6/STAMGR_CLIENT_SNOOPING: Detected client IP change: Client MAC: 32c9-c109-1a7b, IP: 172.16.100.58, -NA-, -NA-, -NA-, Username: -NA-, AP name: 943b-b051-5330, Radio ID: 2, Channel number: 11, SSID: XLL, BSSID: 943b-b051-5340. %Mar 19 10:29:35:096 2022 XLL-R STAMGR/6/STAMGR_CLIENT_ONLINE: Client a6e1-a489-f9e2 went online from BSS 943b-b051-2520 with SSID XLL on AP 943b-b051-2520. State changed to Run. %Mar 19 10:29:35:100 2022 XLL-R STAMGR/6/STAMGR_ROAM_SUCCESS: Client a6e1-a489-f9e2 roamed from BSSID 943b-b051-2530 on AP 943b-b051-2520 of AC IP 127.0.0.1 to BSSID 943b-b051-2520 on AP 943b-b051-2520 of AC IP 127.0.0.1 successfully. %Mar 19 10:29:35:101 2022 XLL-R STAMGR/6/STAMGR_CLIENT_OFFLINE: Client a6e1-a489-f9e2 went offline from BSS 943b-b051-2530 with SSID XLL on AP 943b-b051-2520. State changed to Unauth. Reason:Successfully roamed to another BSS. %Mar 19 10:29:35:104 2022 XLL-R STAMGR/6/STAMGR_CLIENT_SNOOPING: Detected client IP change: Client MAC: a6e1-a489-f9e2, IP: 172.16.100.5, 172.16.100.87, -NA-, -NA-, Username: -NA-, AP name: 943b-b051-2520, Radio ID: 1, Channel number: 36, SSID: XLL, BSSID: 943b-b051-2520. %Mar 19 10:29:37:487 2022 XLL-R STAMGR/6/STAMGR_CLIENT_ONLINE: Client c205-f70b-cadf went online from BSS 943b-b051-2330 with SSID XLL on AP 943b-b051-2320. State changed to Run. %Mar 19 10:29:37:489 2022 XLL-R STAMGR/6/STAMGR_ROAM_SUCCESS: Client c205-f70b-cadf roamed from BSSID 943b-b051-1750 on AP 943b-b051-1740 of AC IP 127.0.0.1 to BSSID 943b-b051-2330 on AP 943b-b051-2320 of AC IP 127.0.0.1 successfully. %Mar 19 10:29:37:491 2022 XLL-R STAMGR/6/STAMGR_CLIENT_OFFLINE: Client c205-f70b-cadf went offline from BSS 943b-b051-1750 with SSID XLL on AP 943b-b051-1740. State changed to Unauth. Reason:Successfully roamed to another BSS. %Mar 19 10:29:37:499 2022 XLL-R STAMGR/6/STAMGR_CLIENT_SNOOPING: Detected client IP change: Client MAC: c205-f70b-cadf, IP: 172.16.100.66, -NA-, -NA-, -NA-, Username: -NA-, AP name: 943b-b051-2320, Radio ID: 2, Channel number: 6, SSID: XLL, BSSID: 943b-b051-2330. %Mar 19 10:29:46:900 2022 XLL-R STAMGR/6/STAMGR_CLIENT_ONLINE: Client 14c6-975f-979b went online from BSS 943b-b051-c490 with SSID XLL on AP 943b-b051-c490. State changed to Run. %Mar 19 10:29:46:903 2022 XLL-R STAMGR/6/STAMGR_ROAM_SUCCESS: Client 14c6-975f-979b roamed from BSSID 943b-b051-c4a0 on AP 943b-b051-c490 of AC IP 127.0.0.1 to BSSID 943b-b051-c490 on AP 943b-b051-c490 of AC IP 127.0.0.1 successfully. %Mar 19 10:29:46:904 2022 XLL-R STAMGR/6/STAMGR_CLIENT_OFFLINE: Client 14c6-975f-979b went offline from BSS 943b-b051-c4a0 with SSID XLL on AP 943b-b051-c490. State changed to Unauth. Reason:Successfully roamed to another BSS. %Mar 19 10:29:46:907 2022 XLL-R STAMGR/6/STAMGR_CLIENT_SNOOPING: Detected client IP change: Client MAC: 14c6-975f-979b, IP: 172.16.100.27, -NA-, -NA-, -NA-, Username: -NA-, AP name: 943b-b051-c490, Radio ID: 1, Channel number: 36, SSID: XLL, BSSID: 943b-b051-c490. %Mar 19 10:29:48:351 2022 XLL-R STAMGR/6/STAMGR_CLIENT_OFFLINE: Client c205-f70b-cadf went offline from BSS 943b-b051-2330 with SSID XLL on AP 943b-b051-2320. State changed to Unauth. Reason:Received disassociation frame in Run state: reason code=8 %Mar 19 10:29:58:814 2022 XLL-R STAMGR/6/STAMGR_CLIENT_ONLINE: Client d613-ad03-015e went online from BSS 943b-b051-2320 with SSID XLL on AP 943b-b051-2320. State changed to Run. %Mar 19 10:29:58:815 2022 XLL-R STAMGR/6/STAMGR_ROAM_SUCCESS: Client d613-ad03-015e roamed from BSSID 943b-b051-d210 on AP 943b-b051-d200 of AC IP 127.0.0.1 to BSSID 943b-b051-2320 on AP 943b-b051-2320 of AC IP 127.0.0.1 successfully. %Mar 19 10:29:58:817 2022 XLL-R STAMGR/6/STAMGR_CLIENT_OFFLINE: Client d613-ad03-015e went offline from BSS 943b-b051-d210 with SSID XLL on AP 943b-b051-d200. State changed to Unauth. Reason:Successfully roamed to another BSS. %Mar 19 10:29:58:818 2022 XLL-R STAMGR/6/STAMGR_CLIENT_SNOOPING: Detected client IP change: Client MAC: d613-ad03-015e, IP: 172.16.100.59, -NA-, -NA-, -NA-, Username: -NA-, AP name: 943b-b051-2320, Radio ID: 1, Channel number: 52, SSID: XLL, BSSID: 943b-b051-2320. %Mar 19 10:30:02:348 2022 XLL-R STAMGR/6/STAMGR_CLIENT_ONLINE: Client eab4-fbe9-7fbb went online from BSS 943b-b051-2380 with SSID XLL on AP 943b-b051-2370. State changed to Run. %Mar 19 10:30:02:351 2022 XLL-R STAMGR/6/STAMGR_ROAM_SUCCESS: Client eab4-fbe9-7fbb roamed from BSSID 943b-b051-2370 on AP 943b-b051-2370 of AC IP 127.0.0.1 to BSSID 943b-b051-2380 on AP 943b-b051-2370 of AC IP 127.0.0.1 successfully. %Mar 19 10:30:02:353 2022 XLL-R STAMGR/6/STAMGR_CLIENT_OFFLINE: Client eab4-fbe9-7fbb went offline from BSS 943b-b051-2370 with SSID XLL on AP 943b-b051-2370. State changed to Unauth. Reason:Successfully roamed to another BSS. %Mar 19 10:30:02:355 2022 XLL-R STAMGR/6/STAMGR_CLIENT_SNOOPING: Detected client IP change: Client MAC: eab4-fbe9-7fbb, IP: 172.16.100.44, 172.16.100.55, -NA-, -NA-, Username: -NA-, AP name: 943b-b051-2370, Radio ID: 2, Channel number: 11, SSID: XLL, BSSID: 943b-b051-2380. %Mar 19 10:30:20:697 2022 XLL-R STAMGR/6/STAMGR_CLIENT_ONLINE: Client 66da-d947-0e6d went online from BSS 943b-b051-1750 with SSID XLL on AP 943b-b051-1740. State changed to Run. %Mar 19 10:30:20:698 2022 XLL-R STAMGR/6/STAMGR_ROAM_SUCCESS: Client 66da-d947-0e6d roamed from BSSID 943b-b051-2330 on AP 943b-b051-2320 of AC IP 127.0.0.1 to BSSID 943b-b051-1750 on AP 943b-b051-1740 of AC IP 127.0.0.1 successfully. %Mar 19 10:30:20:700 2022 XLL-R STAMGR/6/STAMGR_CLIENT_OFFLINE: Client 66da-d947-0e6d went offline from BSS 943b-b051-2330 with SSID XLL on AP 943b-b051-2320. State changed to Unauth. Reason:Successfully roamed to another BSS. %Mar 19 10:30:20:702 2022 XLL-R STAMGR/6/STAMGR_CLIENT_SNOOPING: Detected client IP change: Client MAC: 66da-d947-0e6d, IP: 172.16.100.63, -NA-, -NA-, -NA-, Username: -NA-, AP name: 943b-b051-1740, Radio ID: 2, Channel number: 11, SSID: XLL, BSSID: 943b-b051-1750. %Mar 19 10:30:23:697 2022 XLL-R STAMGR/6/STAMGR_CLIENT_ONLINE: Client 66da-d947-0e6d went online from BSS 943b-b051-2330 with SSID XLL on AP 943b-b051-2320. State changed to Run. %Mar 19 10:30:23:700 2022 XLL-R STAMGR/6/STAMGR_ROAM_SUCCESS: Client 66da-d947-0e6d roamed from BSSID 943b-b051-1750 on AP 943b-b051-1740 of AC IP 127.0.0.1 to BSSID 943b-b051-2330 on AP 943b-b051-2320 of AC IP 127.0.0.1 successfully. %Mar 19 10:30:23:712 2022 XLL-R STAMGR/6/STAMGR_CLIENT_OFFLINE: Client 66da-d947-0e6d went offline from BSS 943b-b051-1750 with SSID XLL on AP 943b-b051-1740. State changed to Unauth. Reason:Successfully roamed to another BSS. %Mar 19 10:30:23:717 2022 XLL-R STAMGR/6/STAMGR_CLIENT_SNOOPING: Detected client IP change: Client MAC: 66da-d947-0e6d, IP: 172.16.100.63, -NA-, -NA-, -NA-, Username: -NA-, AP name: 943b-b051-2320, Radio ID: 2, Channel number: 6, SSID: XLL, BSSID: 943b-b051-2330. %Mar 19 10:30:38:588 2022 XLL-R STAMGR/6/STAMGR_CLIENT_OFFLINE: Client 2218-ce9a-91fb went offline from BSS 943b-b051-2530 with SSID XLL on AP 943b-b051-2520. State changed to Unauth. Reason:Received deauthentication message in Run state: reason code=8 %Mar 19 10:30:42:487 2022 XLL-R STAMGR/6/STAMGR_CLIENT_ONLINE: Client c205-f70b-cadf went online from BSS 943b-b051-2330 with SSID XLL on AP 943b-b051-2320. State changed to Run. %Mar 19 10:30:42:487 2022 XLL-R STAMGR/6/STAMGR_CLIENT_SNOOPING: Detected client IP change: Client MAC: c205-f70b-cadf, IP: 172.16.100.66, -NA-, -NA-, -NA-, Username: -NA-, AP name: 943b-b051-2320, Radio ID: 2, Channel number: 6, SSID: XLL, BSSID: 943b-b051-2330. %Mar 19 10:30:58:422 2022 XLL-R STAMGR/6/STAMGR_CLIENT_ONLINE: Client 66da-d947-0e6d went online from BSS 00be-d5b3-af50 with SSID XLL on AP 00be-d5b3-af40. State changed to Run. %Mar 19 10:30:58:423 2022 XLL-R STAMGR/6/STAMGR_ROAM_SUCCESS: Client 66da-d947-0e6d roamed from BSSID 943b-b051-2330 on AP 943b-b051-2320 of AC IP 127.0.0.1 to BSSID 00be-d5b3-af50 on AP 00be-d5b3-af40 of AC IP 127.0.0.1 successfully. %Mar 19 10:30:58:424 2022 XLL-R STAMGR/6/STAMGR_CLIENT_OFFLINE: Client 66da-d947-0e6d went offline from BSS 943b-b051-2330 with SSID XLL on AP 943b-b051-2320. State changed to Unauth. Reason:Successfully roamed to another BSS. %Mar 19 10:30:58:429 2022 XLL-R STAMGR/6/STAMGR_CLIENT_SNOOPING: Detected client IP change: Client MAC: 66da-d947-0e6d, IP: 172.16.100.63, -NA-, -NA-, -NA-, Username: -NA-, AP name: 00be-d5b3-af40, Radio ID: 2, Channel number: 6, SSID: XLL, BSSID: 00be-d5b3-af50. %Mar 19 10:30:59:201 2022 XLL-R STAMGR/6/STAMGR_CLIENT_ONLINE: Client 66da-d947-0e6d went online from BSS 943b-b051-2330 with SSID XLL on AP 943b-b051-2320. State changed to Run. %Mar 19 10:30:59:202 2022 XLL-R STAMGR/6/STAMGR_ROAM_SUCCESS: Client 66da-d947-0e6d roamed from BSSID 00be-d5b3-af50 on AP 00be-d5b3-af40 of AC IP 127.0.0.1 to BSSID 943b-b051-2330 on AP 943b-b051-2320 of AC IP 127.0.0.1 successfully. %Mar 19 10:30:59:205 2022 XLL-R STAMGR/6/STAMGR_CLIENT_OFFLINE: Client 66da-d947-0e6d went offline from BSS 00be-d5b3-af50 with SSID XLL on AP 00be-d5b3-af40. State changed to Unauth. Reason:Successfully roamed to another BSS. %Mar 19 10:30:59:207 2022 XLL-R STAMGR/6/STAMGR_CLIENT_SNOOPING: Detected client IP change: Client MAC: 66da-d947-0e6d, IP: 172.16.100.63, -NA-, -NA-, -NA-, Username: -NA-, AP name: 943b-b051-2320, Radio ID: 2, Channel number: 6, SSID: XLL, BSSID: 943b-b051-2330. %Mar 19 10:31:02:569 2022 XLL-R STAMGR/6/STAMGR_CLIENT_ONLINE: Client 66da-d947-0e6d went online from BSS 00be-d5b3-9af0 with SSID XLL on AP 00be-d5b3-9ae0. State changed to Run. %Mar 19 10:31:02:570 2022 XLL-R STAMGR/6/STAMGR_ROAM_SUCCESS: Client 66da-d947-0e6d roamed from BSSID 943b-b051-2330 on AP 943b-b051-2320 of AC IP 127.0.0.1 to BSSID 00be-d5b3-9af0 on AP 00be-d5b3-9ae0 of AC IP 127.0.0.1 successfully. %Mar 19 10:31:02:572 2022 XLL-R STAMGR/6/STAMGR_CLIENT_OFFLINE: Client 66da-d947-0e6d went offline from BSS 943b-b051-2330 with SSID XLL on AP 943b-b051-2320. State changed to Unauth. Reason:Successfully roamed to another BSS. %Mar 19 10:31:02:575 2022 XLL-R STAMGR/6/STAMGR_CLIENT_SNOOPING: Detected client IP change: Client MAC: 66da-d947-0e6d, IP: 172.16.100.63, -NA-, -NA-, -NA-, Username: -NA-, AP name: 00be-d5b3-9ae0, Radio ID: 2, Channel number: 1, SSID: XLL, BSSID: 00be-d5b3-9af0. %Mar 19 10:31:03:200 2022 XLL-R STAMGR/6/STAMGR_CLIENT_ONLINE: Client 66da-d947-0e6d went online from BSS 943b-b051-2330 with SSID XLL on AP 943b-b051-2320. State changed to Run. %Mar 19 10:31:03:201 2022 XLL-R STAMGR/6/STAMGR_ROAM_SUCCESS: Client 66da-d947-0e6d roamed from BSSID 00be-d5b3-9af0 on AP 00be-d5b3-9ae0 of AC IP 127.0.0.1 to BSSID 943b-b051-2330 on AP 943b-b051-2320 of AC IP 127.0.0.1 successfully. %Mar 19 10:31:03:205 2022 XLL-R STAMGR/6/STAMGR_CLIENT_SNOOPING: Detected client IP change: Client MAC: 66da-d947-0e6d, IP: 172.16.100.63, -NA-, -NA-, -NA-, Username: -NA-, AP name: 943b-b051-2320, Radio ID: 2, Channel number: 6, SSID: XLL, BSSID: 943b-b051-2330. %Mar 19 10:31:03:209 2022 XLL-R STAMGR/6/STAMGR_CLIENT_OFFLINE: Client 66da-d947-0e6d went offline from BSS 00be-d5b3-9af0 with SSID XLL on AP 00be-d5b3-9ae0. State changed to Unauth. Reason:Successfully roamed to another BSS. %Mar 19 10:31:06:684 2022 XLL-R STAMGR/6/STAMGR_CLIENT_SNOOPING: Detected client IP change: Client MAC: a6e1-a489-f9e2, IP: 172.16.100.5, -NA-, -NA-, -NA-, Username: -NA-, AP name: 943b-b051-2520, Radio ID: 2, Channel number: 6, SSID: XLL, BSSID: 943b-b051-2530. %Mar 19 10:31:06:686 2022 XLL-R STAMGR/6/STAMGR_CLIENT_ONLINE: Client a6e1-a489-f9e2 went online from BSS 943b-b051-2530 with SSID XLL on AP 943b-b051-2520. State changed to Run. %Mar 19 10:31:06:691 2022 XLL-R STAMGR/6/STAMGR_ROAM_SUCCESS: Client a6e1-a489-f9e2 roamed from BSSID 943b-b051-2520 on AP 943b-b051-2520 of AC IP 127.0.0.1 to BSSID 943b-b051-2530 on AP 943b-b051-2520 of AC IP 127.0.0.1 successfully. %Mar 19 10:31:06:693 2022 XLL-R STAMGR/6/STAMGR_CLIENT_OFFLINE: Client a6e1-a489-f9e2 went offline from BSS 943b-b051-2520 with SSID XLL on AP 943b-b051-2520. State changed to Unauth. Reason:Successfully roamed to another BSS. %Mar 19 10:31:06:696 2022 XLL-R STAMGR/6/STAMGR_CLIENT_SNOOPING: Detected client IP change: Client MAC: a6e1-a489-f9e2, IP: 172.16.100.5, 172.16.100.87, -NA-, -NA-, Username: -NA-, AP name: 943b-b051-2520, Radio ID: 2, Channel number: 6, SSID: XLL, BSSID: 943b-b051-2530. %Mar 19 10:31:07:029 2022 XLL-R STAMGR/6/STAMGR_CLIENT_ONLINE: Client 14c6-975f-979b went online from BSS 943b-b051-ca90 with SSID XLL on AP 943b-b051-ca80. State changed to Run. %Mar 19 10:31:07:030 2022 XLL-R STAMGR/6/STAMGR_ROAM_SUCCESS: Client 14c6-975f-979b roamed from BSSID 943b-b051-c490 on AP 943b-b051-c490 of AC IP 127.0.0.1 to BSSID 943b-b051-ca90 on AP 943b-b051-ca80 of AC IP 127.0.0.1 successfully. %Mar 19 10:31:07:033 2022 XLL-R STAMGR/6/STAMGR_CLIENT_OFFLINE: Client 14c6-975f-979b went offline from BSS 943b-b051-c490 with SSID XLL on AP 943b-b051-c490. State changed to Unauth. Reason:Successfully roamed to another BSS. %Mar 19 10:31:07:036 2022 XLL-R STAMGR/6/STAMGR_CLIENT_SNOOPING: Detected client IP change: Client MAC: 14c6-975f-979b, IP: 172.16.100.27, -NA-, -NA-, -NA-, Username: -NA-, AP name: 943b-b051-ca80, Radio ID: 2, Channel number: 11, SSID: XLL, BSSID: 943b-b051-ca90. %Mar 19 10:31:36:817 2022 XLL-R STAMGR/6/STAMGR_CLIENT_ONLINE: Client a6e1-a489-f9e2 went online from BSS 943b-b051-2520 with SSID XLL on AP 943b-b051-2520. State changed to Run. %Mar 19 10:31:36:820 2022 XLL-R STAMGR/6/STAMGR_ROAM_SUCCESS: Client a6e1-a489-f9e2 roamed from BSSID 943b-b051-2530 on AP 943b-b051-2520 of AC IP 127.0.0.1 to BSSID 943b-b051-2520 on AP 943b-b051-2520 of AC IP 127.0.0.1 successfully. %Mar 19 10:31:36:822 2022 XLL-R STAMGR/6/STAMGR_CLIENT_OFFLINE: Client a6e1-a489-f9e2 went offline from BSS 943b-b051-2530 with SSID XLL on AP 943b-b051-2520. State changed to Unauth. Reason:Successfully roamed to another BSS. %Mar 19 10:31:36:824 2022 XLL-R STAMGR/6/STAMGR_CLIENT_SNOOPING: Detected client IP change: Client MAC: a6e1-a489-f9e2, IP: 172.16.100.5, 172.16.100.87, -NA-, -NA-, Username: -NA-, AP name: 943b-b051-2520, Radio ID: 1, Channel number: 36, SSID: XLL, BSSID: 943b-b051-2520. %Mar 19 10:31:58:194 2022 XLL-R STAMGR/6/STAMGR_CLIENT_ONLINE: Client e0e0-fc27-eb31 went online from BSS 943b-b051-2330 with SSID XLL on AP 943b-b051-2320. State changed to Run. %Mar 19 10:31:58:197 2022 XLL-R STAMGR/6/STAMGR_ROAM_SUCCESS: Client e0e0-fc27-eb31 roamed from BSSID 943b-b052-1190 on AP 943b-b052-1190 of AC IP 127.0.0.1 to BSSID 943b-b051-2330 on AP 943b-b051-2320 of AC IP 127.0.0.1 successfully. %Mar 19 10:31:58:198 2022 XLL-R STAMGR/6/STAMGR_CLIENT_OFFLINE: Client e0e0-fc27-eb31 went offline from BSS 943b-b052-1190 with SSID XLL on AP 943b-b052-1190. State changed to Unauth. Reason:Successfully roamed to another BSS. %Mar 19 10:31:58:199 2022 XLL-R STAMGR/6/STAMGR_CLIENT_SNOOPING: Detected client IP change: Client MAC: e0e0-fc27-eb31, IP: 172.16.100.20, -NA-, -NA-, -NA-, Username: -NA-, AP name: 943b-b051-2320, Radio ID: 2, Channel number: 6, SSID: XLL, BSSID: 943b-b051-2330. %Mar 19 10:31:58:205 2022 XLL-R STAMGR/6/STAMGR_CLIENT_OFFLINE: Client e0e0-fc27-eb31 went offline from BSS 943b-b051-2330 with SSID XLL on AP 943b-b051-2320. State changed to Unauth. Reason:Kicked the new client because of ip-conflict. %Mar 19 10:31:59:720 2022 XLL-R STAMGR/6/STAMGR_CLIENT_ONLINE: Client e0e0-fc27-eb31 went online from BSS 943b-b051-1740 with SSID XLL on AP 943b-b051-1740. State changed to Run. %Mar 19 10:31:59:824 2022 XLL-R STAMGR/6/STAMGR_CLIENT_SNOOPING: Detected client IP change: Client MAC: e0e0-fc27-eb31, IP: 172.16.100.20, -NA-, -NA-, -NA-, Username: -NA-, AP name: 943b-b051-1740, Radio ID: 1, Channel number: 36, SSID: XLL, BSSID: 943b-b051-1740. %Mar 19 10:32:06:833 2022 XLL-R STAMGR/6/STAMGR_CLIENT_ONLINE: Client e0e0-fc27-eb31 went online from BSS 943b-b051-2330 with SSID XLL on AP 943b-b051-2320. State changed to Run. %Mar 19 10:32:06:835 2022 XLL-R STAMGR/6/STAMGR_ROAM_SUCCESS: Client e0e0-fc27-eb31 roamed from BSSID 943b-b051-1740 on AP 943b-b051-1740 of AC IP 127.0.0.1 to BSSID 943b-b051-2330 on AP 943b-b051-2320 of AC IP 127.0.0.1 successfully. %Mar 19 10:32:06:837 2022 XLL-R STAMGR/6/STAMGR_CLIENT_SNOOPING: Detected client IP change: Client MAC: e0e0-fc27-eb31, IP: 172.16.100.20, -NA-, -NA-, -NA-, Username: -NA-, AP name: 943b-b051-2320, Radio ID: 2, Channel number: 6, SSID: XLL, BSSID: 943b-b051-2330. %Mar 19 10:32:06:838 2022 XLL-R STAMGR/6/STAMGR_CLIENT_OFFLINE: Client e0e0-fc27-eb31 went offline from BSS 943b-b051-1740 with SSID XLL on AP 943b-b051-1740. State changed to Unauth. Reason:Successfully roamed to another BSS. %Mar 19 10:32:08:729 2022 XLL-R STAMGR/6/STAMGR_CLIENT_ONLINE: Client 2e98-0262-94b2 went online from BSS 943b-b051-c490 with SSID XLL on AP 943b-b051-c490. State changed to Run. %Mar 19 10:32:08:730 2022 XLL-R STAMGR/6/STAMGR_ROAM_SUCCESS: Client 2e98-0262-94b2 roamed from BSSID 943b-b051-2530 on AP 943b-b051-2520 of AC IP 127.0.0.1 to BSSID 943b-b051-c490 on AP 943b-b051-c490 of AC IP 127.0.0.1 successfully. %Mar 19 10:32:08:732 2022 XLL-R STAMGR/6/STAMGR_CLIENT_OFFLINE: Client 2e98-0262-94b2 went offline from BSS 943b-b051-2530 with SSID XLL on AP 943b-b051-2520. State changed to Unauth. Reason:Successfully roamed to another BSS. %Mar 19 10:32:08:733 2022 XLL-R STAMGR/6/STAMGR_CLIENT_SNOOPING: Detected client IP change: Client MAC: 2e98-0262-94b2, IP: 172.16.100.23, -NA-, -NA-, -NA-, Username: -NA-, AP name: 943b-b051-c490, Radio ID: 1, Channel number: 36, SSID: XLL, BSSID: 943b-b051-c490. %Mar 19 10:32:18:692 2022 XLL-R STAMGR/6/STAMGR_CLIENT_ONLINE: Client 14c6-975f-979b went online from BSS 943b-b051-c490 with SSID XLL on AP 943b-b051-c490. State changed to Run. %Mar 19 10:32:18:693 2022 XLL-R STAMGR/6/STAMGR_ROAM_SUCCESS: Client 14c6-975f-979b roamed from BSSID 943b-b051-ca90 on AP 943b-b051-ca80 of AC IP 127.0.0.1 to BSSID 943b-b051-c490 on AP 943b-b051-c490 of AC IP 127.0.0.1 successfully. %Mar 19 10:32:18:696 2022 XLL-R STAMGR/6/STAMGR_CLIENT_SNOOPING: Detected client IP change: Client MAC: 14c6-975f-979b, IP: 172.16.100.27, -NA-, -NA-, -NA-, Username: -NA-, AP name: 943b-b051-c490, Radio ID: 1, Channel number: 36, SSID: XLL, BSSID: 943b-b051-c490. %Mar 19 10:32:18:702 2022 XLL-R STAMGR/6/STAMGR_CLIENT_OFFLINE: Client 14c6-975f-979b went offline from BSS 943b-b051-ca90 with SSID XLL on AP 943b-b051-ca80. State changed to Unauth. Reason:Successfully roamed to another BSS. %Mar 19 10:32:27:117 2022 XLL-R STAMGR/6/STAMGR_CLIENT_ONLINE: Client d613-ad03-015e went online from BSS 943b-b051-2330 with SSID XLL on AP 943b-b051-2320. State changed to Run. %Mar 19 10:32:27:122 2022 XLL-R STAMGR/6/STAMGR_ROAM_SUCCESS: Client d613-ad03-015e roamed from BSSID 943b-b051-2320 on AP 943b-b051-2320 of AC IP 127.0.0.1 to BSSID 943b-b051-2330 on AP 943b-b051-2320 of AC IP 127.0.0.1 successfully. %Mar 19 10:32:27:125 2022 XLL-R STAMGR/6/STAMGR_CLIENT_OFFLINE: Client d613-ad03-015e went offline from BSS 943b-b051-2320 with SSID XLL on AP 943b-b051-2320. State changed to Unauth. Reason:Successfully roamed to another BSS. %Mar 19 10:32:27:128 2022 XLL-R STAMGR/6/STAMGR_CLIENT_SNOOPING: Detected client IP change: Client MAC: d613-ad03-015e, IP: 172.16.100.59, -NA-, -NA-, -NA-, Username: -NA-, AP name: 943b-b051-2320, Radio ID: 2, Channel number: 6, SSID: XLL, BSSID: 943b-b051-2330. %Mar 19 10:32:32:215 2022 XLL-R STAMGR/6/STAMGR_CLIENT_ONLINE: Client a8a7-95cb-1439 went online from BSS 943b-b051-2530 with SSID XLL on AP 943b-b051-2520. State changed to Run. %Mar 19 10:32:32:217 2022 XLL-R STAMGR/6/STAMGR_ROAM_SUCCESS: Client a8a7-95cb-1439 roamed from BSSID 943b-b051-c4a0 on AP 943b-b051-c490 of AC IP 127.0.0.1 to BSSID 943b-b051-2530 on AP 943b-b051-2520 of AC IP 127.0.0.1 successfully. %Mar 19 10:32:32:218 2022 XLL-R STAMGR/6/STAMGR_CLIENT_OFFLINE: Client a8a7-95cb-1439 went offline from BSS 943b-b051-c4a0 with SSID XLL on AP 943b-b051-c490. State changed to Unauth. Reason:Successfully roamed to another BSS. %Mar 19 10:32:32:223 2022 XLL-R STAMGR/6/STAMGR_CLIENT_SNOOPING: Detected client IP change: Client MAC: a8a7-95cb-1439, IP: 172.16.100.140, -NA-, -NA-, -NA-, Username: -NA-, AP name: 943b-b051-2520, Radio ID: 2, Channel number: 6, SSID: XLL, BSSID: 943b-b051-2530. %Mar 19 10:32:40:430 2022 XLL-R STAMGR/6/STAMGR_CLIENT_ONLINE: Client 66da-d947-0e6d went online from BSS 943b-b051-1750 with SSID XLL on AP 943b-b051-1740. State changed to Run. %Mar 19 10:32:40:432 2022 XLL-R STAMGR/6/STAMGR_ROAM_SUCCESS: Client 66da-d947-0e6d roamed from BSSID 943b-b051-2330 on AP 943b-b051-2320 of AC IP 127.0.0.1 to BSSID 943b-b051-1750 on AP 943b-b051-1740 of AC IP 127.0.0.1 successfully. %Mar 19 10:32:40:434 2022 XLL-R STAMGR/6/STAMGR_CLIENT_OFFLINE: Client 66da-d947-0e6d went offline from BSS 943b-b051-2330 with SSID XLL on AP 943b-b051-2320. State changed to Unauth. Reason:Successfully roamed to another BSS. %Mar 19 10:32:40:442 2022 XLL-R STAMGR/6/STAMGR_CLIENT_SNOOPING: Detected client IP change: Client MAC: 66da-d947-0e6d, IP: 172.16.100.63, -NA-, -NA-, -NA-, Username: -NA-, AP name: 943b-b051-1740, Radio ID: 2, Channel number: 11, SSID: XLL, BSSID: 943b-b051-1750. %Mar 19 10:32:57:572 2022 XLL-R STAMGR/6/STAMGR_CLIENT_ONLINE: Client a6e1-a489-f9e2 went online from BSS 943b-b051-2530 with SSID XLL on AP 943b-b051-2520. State changed to Run. %Mar 19 10:32:57:575 2022 XLL-R STAMGR/6/STAMGR_ROAM_SUCCESS: Client a6e1-a489-f9e2 roamed from BSSID 943b-b051-2520 on AP 943b-b051-2520 of AC IP 127.0.0.1 to BSSID 943b-b051-2530 on AP 943b-b051-2520 of AC IP 127.0.0.1 successfully. %Mar 19 10:32:57:577 2022 XLL-R STAMGR/6/STAMGR_CLIENT_OFFLINE: Client a6e1-a489-f9e2 went offline from BSS 943b-b051-2520 with SSID XLL on AP 943b-b051-2520. State changed to Unauth. Reason:Successfully roamed to another BSS. %Mar 19 10:32:57:582 2022 XLL-R STAMGR/6/STAMGR_CLIENT_SNOOPING: Detected client IP change: Client MAC: a6e1-a489-f9e2, IP: 172.16.100.5, 172.16.100.87, -NA-, -NA-, Username: -NA-, AP name: 943b-b051-2520, Radio ID: 2, Channel number: 6, SSID: XLL, BSSID: 943b-b051-2530. %Mar 19 10:33:09:941 2022 XLL-R STAMGR/6/STAMGR_CLIENT_ONLINE: Client 0c93-8ff9-adc1 went online from BSS 00be-d5b3-98d0 with SSID XLL on AP 00be-d5b3-98c0. State changed to Run. %Mar 19 10:33:09:945 2022 XLL-R STAMGR/6/STAMGR_ROAM_SUCCESS: Client 0c93-8ff9-adc1 roamed from BSSID 00be-d5b3-98c0 on AP 00be-d5b3-98c0 of AC IP 127.0.0.1 to BSSID 00be-d5b3-98d0 on AP 00be-d5b3-98c0 of AC IP 127.0.0.1 successfully. %Mar 19 10:33:09:952 2022 XLL-R STAMGR/6/STAMGR_CLIENT_OFFLINE: Client 0c93-8ff9-adc1 went offline from BSS 00be-d5b3-98c0 with SSID XLL on AP 00be-d5b3-98c0. State changed to Unauth. Reason:Successfully roamed to another BSS. %Mar 19 10:33:09:955 2022 XLL-R STAMGR/6/STAMGR_CLIENT_SNOOPING: Detected client IP change: Client MAC: 0c93-8ff9-adc1, IP: 172.16.100.51, -NA-, -NA-, -NA-, Username: -NA-, AP name: 00be-d5b3-98c0, Radio ID: 2, Channel number: 1, SSID: XLL, BSSID: 00be-d5b3-98d0. %Mar 19 10:33:21:922 2022 XLL-R STAMGR/6/STAMGR_CLIENT_ONLINE: Client 3e31-2537-8aa1 went online from BSS 943b-b051-2530 with SSID XLL on AP 943b-b051-2520. State changed to Run. %Mar 19 10:33:21:925 2022 XLL-R STAMGR/6/STAMGR_ROAM_SUCCESS: Client 3e31-2537-8aa1 roamed from BSSID 943b-b051-c4a0 on AP 943b-b051-c490 of AC IP 127.0.0.1 to BSSID 943b-b051-2530 on AP 943b-b051-2520 of AC IP 127.0.0.1 successfully. %Mar 19 10:33:21:926 2022 XLL-R STAMGR/6/STAMGR_CLIENT_OFFLINE: Client 3e31-2537-8aa1 went offline from BSS 943b-b051-c4a0 with SSID XLL on AP 943b-b051-c490. State changed to Unauth. Reason:Successfully roamed to another BSS. %Mar 19 10:33:21:928 2022 XLL-R STAMGR/6/STAMGR_CLIENT_SNOOPING: Detected client IP change: Client MAC: 3e31-2537-8aa1, IP: 172.16.100.8, -NA-, -NA-, -NA-, Username: -NA-, AP name: 943b-b051-2520, Radio ID: 2, Channel number: 6, SSID: XLL, BSSID: 943b-b051-2530. %Mar 19 10:33:36:388 2022 XLL-R STAMGR/6/STAMGR_CLIENT_ONLINE: Client 7a06-25d1-854a went online from BSS 943b-b052-11a0 with SSID XLL on AP 943b-b052-1190. State changed to Run. %Mar 19 10:33:36:462 2022 XLL-R STAMGR/6/STAMGR_CLIENT_SNOOPING: Detected client IP change: Client MAC: 7a06-25d1-854a, IP: 172.16.100.43, -NA-, -NA-, -NA-, Username: -NA-, AP name: 943b-b052-1190, Radio ID: 2, Channel number: 11, SSID: XLL, BSSID: 943b-b052-11a0. %Mar 19 10:34:25:939 2022 XLL-R STAMGR/6/STAMGR_CLIENT_ONLINE: Client 7a06-25d1-854a went online from BSS 943b-b051-2430 with SSID XLL on AP 943b-b051-2420. State changed to Run. %Mar 19 10:34:25:944 2022 XLL-R STAMGR/6/STAMGR_ROAM_SUCCESS: Client 7a06-25d1-854a roamed from BSSID 943b-b052-11a0 on AP 943b-b052-1190 of AC IP 127.0.0.1 to BSSID 943b-b051-2430 on AP 943b-b051-2420 of AC IP 127.0.0.1 successfully. %Mar 19 10:34:25:946 2022 XLL-R STAMGR/6/STAMGR_CLIENT_OFFLINE: Client 7a06-25d1-854a went offline from BSS 943b-b052-11a0 with SSID XLL on AP 943b-b052-1190. State changed to Unauth. Reason:Successfully roamed to another BSS. %Mar 19 10:34:25:948 2022 XLL-R STAMGR/6/STAMGR_CLIENT_SNOOPING: Detected client IP change: Client MAC: 7a06-25d1-854a, IP: 172.16.100.43, -NA-, -NA-, -NA-, Username: -NA-, AP name: 943b-b051-2420, Radio ID: 2, Channel number: 11, SSID: XLL, BSSID: 943b-b051-2430. %Mar 19 10:34:26:177 2022 XLL-R STAMGR/6/STAMGR_CLIENT_ONLINE: Client 72ed-14da-d135 went online from BSS 943b-b051-2530 with SSID XLL on AP 943b-b051-2520. State changed to Run. %Mar 19 10:34:26:197 2022 XLL-R STAMGR/6/STAMGR_ROAM_SUCCESS: Client 72ed-14da-d135 roamed from BSSID 943b-b051-2520 on AP 943b-b051-2520 of AC IP 127.0.0.1 to BSSID 943b-b051-2530 on AP 943b-b051-2520 of AC IP 127.0.0.1 successfully. %Mar 19 10:34:26:199 2022 XLL-R STAMGR/6/STAMGR_CLIENT_OFFLINE: Client 72ed-14da-d135 went offline from BSS 943b-b051-2520 with SSID XLL on AP 943b-b051-2520. State changed to Unauth. Reason:Successfully roamed to another BSS. %Mar 19 10:34:26:201 2022 XLL-R STAMGR/6/STAMGR_CLIENT_SNOOPING: Detected client IP change: Client MAC: 72ed-14da-d135, IP: 172.16.100.13, -NA-, -NA-, -NA-, Username: -NA-, AP name: 943b-b051-2520, Radio ID: 2, Channel number: 6, SSID: XLL, BSSID: 943b-b051-2530. %Mar 19 10:34:36:472 2022 XLL-R STAMGR/6/STAMGR_CLIENT_ONLINE: Client 66da-d947-0e6d went online from BSS 00be-d5b3-ab90 with SSID XLL on AP 00be-d5b3-ab80. State changed to Run. %Mar 19 10:34:36:474 2022 XLL-R STAMGR/6/STAMGR_ROAM_SUCCESS: Client 66da-d947-0e6d roamed from BSSID 943b-b051-1750 on AP 943b-b051-1740 of AC IP 127.0.0.1 to BSSID 00be-d5b3-ab90 on AP 00be-d5b3-ab80 of AC IP 127.0.0.1 successfully. %Mar 19 10:34:36:477 2022 XLL-R STAMGR/6/STAMGR_CLIENT_OFFLINE: Client 66da-d947-0e6d went offline from BSS 943b-b051-1750 with SSID XLL on AP 943b-b051-1740. State changed to Unauth. Reason:Successfully roamed to another BSS. %Mar 19 10:34:36:480 2022 XLL-R STAMGR/6/STAMGR_CLIENT_SNOOPING: Detected client IP change: Client MAC: 66da-d947-0e6d, IP: 172.16.100.63, -NA-, -NA-, -NA-, Username: -NA-, AP name: 00be-d5b3-ab80, Radio ID: 2, Channel number: 1, SSID: XLL, BSSID: 00be-d5b3-ab90. %Mar 19 10:34:38:245 2022 XLL-R STAMGR/6/STAMGR_CLIENT_ONLINE: Client 66da-d947-0e6d went online from BSS 943b-b051-2330 with SSID XLL on AP 943b-b051-2320. State changed to Run. %Mar 19 10:34:38:247 2022 XLL-R STAMGR/6/STAMGR_ROAM_SUCCESS: Client 66da-d947-0e6d roamed from BSSID 00be-d5b3-ab90 on AP 00be-d5b3-ab80 of AC IP 127.0.0.1 to BSSID 943b-b051-2330 on AP 943b-b051-2320 of AC IP 127.0.0.1 successfully. %Mar 19 10:34:38:251 2022 XLL-R STAMGR/6/STAMGR_CLIENT_SNOOPING: Detected client IP change: Client MAC: 66da-d947-0e6d, IP: 172.16.100.63, -NA-, -NA-, -NA-, Username: -NA-, AP name: 943b-b051-2320, Radio ID: 2, Channel number: 6, SSID: XLL, BSSID: 943b-b051-2330. %Mar 19 10:34:38:251 2022 XLL-R STAMGR/6/STAMGR_CLIENT_OFFLINE: Client 66da-d947-0e6d went offline from BSS 00be-d5b3-ab90 with SSID XLL on AP 00be-d5b3-ab80. State changed to Unauth. Reason:Successfully roamed to another BSS. %Mar 19 10:34:42:638 2022 XLL-R STAMGR/6/STAMGR_CLIENT_ONLINE: Client 72ed-14da-d135 went online from BSS 943b-b051-67f0 with SSID XLL on AP 943b-b051-67f0. State changed to Run. %Mar 19 10:34:42:641 2022 XLL-R STAMGR/6/STAMGR_ROAM_SUCCESS: Client 72ed-14da-d135 roamed from BSSID 943b-b051-2530 on AP 943b-b051-2520 of AC IP 127.0.0.1 to BSSID 943b-b051-67f0 on AP 943b-b051-67f0 of AC IP 127.0.0.1 successfully. %Mar 19 10:34:42:642 2022 XLL-R STAMGR/6/STAMGR_CLIENT_OFFLINE: Client 72ed-14da-d135 went offline from BSS 943b-b051-2530 with SSID XLL on AP 943b-b051-2520. State changed to Unauth. Reason:Successfully roamed to another BSS. %Mar 19 10:34:42:645 2022 XLL-R STAMGR/6/STAMGR_CLIENT_SNOOPING: Detected client IP change: Client MAC: 72ed-14da-d135, IP: 172.16.100.13, -NA-, -NA-, -NA-, Username: -NA-, AP name: 943b-b051-67f0, Radio ID: 1, Channel number: 36, SSID: XLL, BSSID: 943b-b051-67f0. %Mar 19 10:34:50:266 2022 XLL-R STAMGR/6/STAMGR_CLIENT_ONLINE: Client 7a06-25d1-854a went online from BSS 943b-b051-2420 with SSID XLL on AP 943b-b051-2420. State changed to Run. %Mar 19 10:34:50:270 2022 XLL-R STAMGR/6/STAMGR_ROAM_SUCCESS: Client 7a06-25d1-854a roamed from BSSID 943b-b051-2430 on AP 943b-b051-2420 of AC IP 127.0.0.1 to BSSID 943b-b051-2420 on AP 943b-b051-2420 of AC IP 127.0.0.1 successfully. %Mar 19 10:34:50:273 2022 XLL-R STAMGR/6/STAMGR_CLIENT_OFFLINE: Client 7a06-25d1-854a went offline from BSS 943b-b051-2430 with SSID XLL on AP 943b-b051-2420. State changed to Unauth. Reason:Successfully roamed to another BSS. %Mar 19 10:34:50:275 2022 XLL-R STAMGR/6/STAMGR_CLIENT_SNOOPING: Detected client IP change: Client MAC: 7a06-25d1-854a, IP: 172.16.100.43, -NA-, -NA-, -NA-, Username: -NA-, AP name: 943b-b051-2420, Radio ID: 1, Channel number: 36, SSID: XLL, BSSID: 943b-b051-2420. %Mar 19 10:35:11:367 2022 XLL-R STAMGR/6/STAMGR_CLIENT_ONLINE: Client a6e1-a489-f9e2 went online from BSS 943b-b051-2520 with SSID XLL on AP 943b-b051-2520. State changed to Run. %Mar 19 10:35:11:371 2022 XLL-R STAMGR/6/STAMGR_ROAM_SUCCESS: Client a6e1-a489-f9e2 roamed from BSSID 943b-b051-2530 on AP 943b-b051-2520 of AC IP 127.0.0.1 to BSSID 943b-b051-2520 on AP 943b-b051-2520 of AC IP 127.0.0.1 successfully. %Mar 19 10:35:11:373 2022 XLL-R STAMGR/6/STAMGR_CLIENT_OFFLINE: Client a6e1-a489-f9e2 went offline from BSS 943b-b051-2530 with SSID XLL on AP 943b-b051-2520. State changed to Unauth. Reason:Successfully roamed to another BSS. %Mar 19 10:35:11:375 2022 XLL-R STAMGR/6/STAMGR_CLIENT_SNOOPING: Detected client IP change: Client MAC: a6e1-a489-f9e2, IP: 172.16.100.5, 172.16.100.87, -NA-, -NA-, Username: -NA-, AP name: 943b-b051-2520, Radio ID: 1, Channel number: 36, SSID: XLL, BSSID: 943b-b051-2520. %Mar 19 10:35:21:061 2022 XLL-R STAMGR/6/STAMGR_CLIENT_SNOOPING: Detected client IP change: Client MAC: a6e1-a489-f9e2, IP: 172.16.100.5, -NA-, -NA-, -NA-, Username: -NA-, AP name: 943b-b051-2520, Radio ID: 2, Channel number: 6, SSID: XLL, BSSID: 943b-b051-2530. %Mar 19 10:35:21:062 2022 XLL-R STAMGR/6/STAMGR_CLIENT_ONLINE: Client a6e1-a489-f9e2 went online from BSS 943b-b051-2530 with SSID XLL on AP 943b-b051-2520. State changed to Run. %Mar 19 10:35:21:068 2022 XLL-R STAMGR/6/STAMGR_ROAM_SUCCESS: Client a6e1-a489-f9e2 roamed from BSSID 943b-b051-2520 on AP 943b-b051-2520 of AC IP 127.0.0.1 to BSSID 943b-b051-2530 on AP 943b-b051-2520 of AC IP 127.0.0.1 successfully. %Mar 19 10:35:21:069 2022 XLL-R STAMGR/6/STAMGR_CLIENT_OFFLINE: Client a6e1-a489-f9e2 went offline from BSS 943b-b051-2520 with SSID XLL on AP 943b-b051-2520. State changed to Unauth. Reason:Successfully roamed to another BSS. %Mar 19 10:35:21:071 2022 XLL-R STAMGR/6/STAMGR_CLIENT_SNOOPING: Detected client IP change: Client MAC: a6e1-a489-f9e2, IP: 172.16.100.5, 172.16.100.87, -NA-, -NA-, Username: -NA-, AP name: 943b-b051-2520, Radio ID: 2, Channel number: 6, SSID: XLL, BSSID: 943b-b051-2530. %Mar 19 10:35:28:251 2022 XLL-R STAMGR/6/STAMGR_CLIENT_ONLINE: Client c205-f70b-cadf went online from BSS 943b-b051-6800 with SSID XLL on AP 943b-b051-67f0. State changed to Run. %Mar 19 10:35:28:254 2022 XLL-R STAMGR/6/STAMGR_ROAM_SUCCESS: Client c205-f70b-cadf roamed from BSSID 943b-b051-2330 on AP 943b-b051-2320 of AC IP 127.0.0.1 to BSSID 943b-b051-6800 on AP 943b-b051-67f0 of AC IP 127.0.0.1 successfully. %Mar 19 10:35:28:255 2022 XLL-R STAMGR/6/STAMGR_CLIENT_OFFLINE: Client c205-f70b-cadf went offline from BSS 943b-b051-2330 with SSID XLL on AP 943b-b051-2320. State changed to Unauth. Reason:Successfully roamed to another BSS. %Mar 19 10:35:28:258 2022 XLL-R STAMGR/6/STAMGR_CLIENT_SNOOPING: Detected client IP change: Client MAC: c205-f70b-cadf, IP: 172.16.100.66, -NA-, -NA-, -NA-, Username: -NA-, AP name: 943b-b051-67f0, Radio ID: 2, Channel number: 6, SSID: XLL, BSSID: 943b-b051-6800. %Mar 19 10:35:30:369 2022 XLL-R STAMGR/6/STAMGR_CLIENT_OFFLINE: Client c205-f70b-cadf went offline from BSS 943b-b051-6800 with SSID XLL on AP 943b-b051-67f0. State changed to Unauth. Reason:Received disassociation frame in Run state: reason code=8 %Mar 19 10:35:52:270 2022 XLL-R STAMGR/6/STAMGR_CLIENT_ONLINE: Client 14c6-975f-979b went online from BSS 943b-b051-2530 with SSID XLL on AP 943b-b051-2520. State changed to Run. %Mar 19 10:35:52:272 2022 XLL-R STAMGR/6/STAMGR_ROAM_SUCCESS: Client 14c6-975f-979b roamed from BSSID 943b-b051-c490 on AP 943b-b051-c490 of AC IP 127.0.0.1 to BSSID 943b-b051-2530 on AP 943b-b051-2520 of AC IP 127.0.0.1 successfully. %Mar 19 10:35:52:273 2022 XLL-R STAMGR/6/STAMGR_CLIENT_OFFLINE: Client 14c6-975f-979b went offline from BSS 943b-b051-c490 with SSID XLL on AP 943b-b051-c490. State changed to Unauth. Reason:Successfully roamed to another BSS. %Mar 19 10:35:52:275 2022 XLL-R STAMGR/6/STAMGR_CLIENT_SNOOPING: Detected client IP change: Client MAC: 14c6-975f-979b, IP: 172.16.100.27, -NA-, -NA-, -NA-, Username: -NA-, AP name: 943b-b051-2520, Radio ID: 2, Channel number: 6, SSID: XLL, BSSID: 943b-b051-2530. %Mar 19 10:36:27:514 2022 XLL-R WEB/5/LOGIN: admin logged in from 10.12.1.2 %Mar 19 10:36:28:338 2022 XLL-R STAMGR/6/STAMGR_CLIENT_ONLINE: Client c205-f70b-cadf went online from BSS 943b-b051-d210 with SSID XLL on AP 943b-b051-d200. State changed to Run. %Mar 19 10:36:28:340 2022 XLL-R STAMGR/6/STAMGR_ROAM_SUCCESS: Client c205-f70b-cadf roamed from BSSID 943b-b051-6800 on AP 943b-b051-67f0 of AC IP 127.0.0.1 to BSSID 943b-b051-d210 on AP 943b-b051-d200 of AC IP 127.0.0.1 successfully. %Mar 19 10:36:28:347 2022 XLL-R STAMGR/6/STAMGR_CLIENT_SNOOPING: Detected client IP change: Client MAC: c205-f70b-cadf, IP: 172.16.100.66, -NA-, -NA-, -NA-, Username: -NA-, AP name: 943b-b051-d200, Radio ID: 2, Channel number: 6, SSID: XLL, BSSID: 943b-b051-d210. %Mar 19 10:36:30:757 2022 XLL-R STAMGR/6/STAMGR_CLIENT_OFFLINE: Client c205-f70b-cadf went offline from BSS 943b-b051-d210 with SSID XLL on AP 943b-b051-d200. State changed to Unauth. Reason:Received disassociation frame in Run state: reason code=8 %Mar 19 10:36:42:359 2022 XLL-R STAMGR/6/STAMGR_CLIENT_ONLINE: Client a6e1-a489-f9e2 went online from BSS 943b-b051-2520 with SSID XLL on AP 943b-b051-2520. State changed to Run. %Mar 19 10:36:42:362 2022 XLL-R STAMGR/6/STAMGR_ROAM_SUCCESS: Client a6e1-a489-f9e2 roamed from BSSID 943b-b051-2530 on AP 943b-b051-2520 of AC IP 127.0.0.1 to BSSID 943b-b051-2520 on AP 943b-b051-2520 of AC IP 127.0.0.1 successfully. %Mar 19 10:36:42:365 2022 XLL-R STAMGR/6/STAMGR_CLIENT_OFFLINE: Client a6e1-a489-f9e2 went offline from BSS 943b-b051-2530 with SSID XLL on AP 943b-b051-2520. State changed to Unauth. Reason:Successfully roamed to another BSS. %Mar 19 10:36:42:367 2022 XLL-R STAMGR/6/STAMGR_CLIENT_SNOOPING: Detected client IP change: Client MAC: a6e1-a489-f9e2, IP: 172.16.100.5, 172.16.100.87, -NA-, -NA-, Username: -NA-, AP name: 943b-b051-2520, Radio ID: 1, Channel number: 36, SSID: XLL, BSSID: 943b-b051-2520. %Mar 19 10:37:09:339 2022 XLL-R STAMGR/6/STAMGR_CLIENT_ONLINE: Client 32c9-c109-1a7b went online from BSS 943b-b051-d210 with SSID XLL on AP 943b-b051-d200. State changed to Run. %Mar 19 10:37:09:344 2022 XLL-R STAMGR/6/STAMGR_ROAM_SUCCESS: Client 32c9-c109-1a7b roamed from BSSID 943b-b051-5340 on AP 943b-b051-5330 of AC IP 127.0.0.1 to BSSID 943b-b051-d210 on AP 943b-b051-d200 of AC IP 127.0.0.1 successfully. %Mar 19 10:37:09:345 2022 XLL-R STAMGR/6/STAMGR_CLIENT_OFFLINE: Client 32c9-c109-1a7b went offline from BSS 943b-b051-5340 with SSID XLL on AP 943b-b051-5330. State changed to Unauth. Reason:Successfully roamed to another BSS. %Mar 19 10:37:09:345 2022 XLL-R STAMGR/6/STAMGR_CLIENT_SNOOPING: Detected client IP change: Client MAC: 32c9-c109-1a7b, IP: 172.16.100.58, -NA-, -NA-, -NA-, Username: -NA-, AP name: 943b-b051-d200, Radio ID: 2, Channel number: 6, SSID: XLL, BSSID: 943b-b051-d210. %Mar 19 10:37:12:669 2022 XLL-R STAMGR/6/STAMGR_CLIENT_ONLINE: Client a6e1-a489-f9e2 went online from BSS 943b-b051-2530 with SSID XLL on AP 943b-b051-2520. State changed to Run. %Mar 19 10:37:12:674 2022 XLL-R STAMGR/6/STAMGR_ROAM_SUCCESS: Client a6e1-a489-f9e2 roamed from BSSID 943b-b051-2520 on AP 943b-b051-2520 of AC IP 127.0.0.1 to BSSID 943b-b051-2530 on AP 943b-b051-2520 of AC IP 127.0.0.1 successfully. %Mar 19 10:37:12:677 2022 XLL-R STAMGR/6/STAMGR_CLIENT_OFFLINE: Client a6e1-a489-f9e2 went offline from BSS 943b-b051-2520 with SSID XLL on AP 943b-b051-2520. State changed to Unauth. Reason:Successfully roamed to another BSS. %Mar 19 10:37:12:680 2022 XLL-R STAMGR/6/STAMGR_CLIENT_SNOOPING: Detected client IP change: Client MAC: a6e1-a489-f9e2, IP: 172.16.100.5, 172.16.100.87, -NA-, -NA-, Username: -NA-, AP name: 943b-b051-2520, Radio ID: 2, Channel number: 6, SSID: XLL, BSSID: 943b-b051-2530. %Mar 19 10:37:18:439 2022 XLL-R STAMGR/6/STAMGR_CLIENT_ONLINE: Client 66da-d947-0e6d went online from BSS 943b-b051-1750 with SSID XLL on AP 943b-b051-1740. State changed to Run. %Mar 19 10:37:18:440 2022 XLL-R STAMGR/6/STAMGR_ROAM_SUCCESS: Client 66da-d947-0e6d roamed from BSSID 943b-b051-2330 on AP 943b-b051-2320 of AC IP 127.0.0.1 to BSSID 943b-b051-1750 on AP 943b-b051-1740 of AC IP 127.0.0.1 successfully. %Mar 19 10:37:18:441 2022 XLL-R STAMGR/6/STAMGR_CLIENT_OFFLINE: Client 66da-d947-0e6d went offline from BSS 943b-b051-2330 with SSID XLL on AP 943b-b051-2320. State changed to Unauth. Reason:Successfully roamed to another BSS. %Mar 19 10:37:18:443 2022 XLL-R STAMGR/6/STAMGR_CLIENT_SNOOPING: Detected client IP change: Client MAC: 66da-d947-0e6d, IP: 172.16.100.63, -NA-, -NA-, -NA-, Username: -NA-, AP name: 943b-b051-1740, Radio ID: 2, Channel number: 11, SSID: XLL, BSSID: 943b-b051-1750. %Mar 19 10:37:18:979 2022 XLL-R STAMGR/6/STAMGR_CLIENT_ONLINE: Client 66da-d947-0e6d went online from BSS 943b-b051-2330 with SSID XLL on AP 943b-b051-2320. State changed to Run. %Mar 19 10:37:18:980 2022 XLL-R STAMGR/6/STAMGR_ROAM_SUCCESS: Client 66da-d947-0e6d roamed from BSSID 943b-b051-1750 on AP 943b-b051-1740 of AC IP 127.0.0.1 to BSSID 943b-b051-2330 on AP 943b-b051-2320 of AC IP 127.0.0.1 successfully. %Mar 19 10:37:18:985 2022 XLL-R STAMGR/6/STAMGR_CLIENT_OFFLINE: Client 66da-d947-0e6d went offline from BSS 943b-b051-1750 with SSID XLL on AP 943b-b051-1740. State changed to Unauth. Reason:Successfully roamed to another BSS. %Mar 19 10:37:18:991 2022 XLL-R STAMGR/6/STAMGR_CLIENT_SNOOPING: Detected client IP change: Client MAC: 66da-d947-0e6d, IP: 172.16.100.63, -NA-, -NA-, -NA-, Username: -NA-, AP name: 943b-b051-2320, Radio ID: 2, Channel number: 6, SSID: XLL, BSSID: 943b-b051-2330. %Mar 19 10:37:40:788 2022 XLL-R LOGIN/5/LOGIN_FAILED: shell failed to log in from 14.172.67.148. %Mar 19 10:37:47:924 2022 XLL-R STAMGR/6/STAMGR_CLIENT_ONLINE: Client a6e1-a489-f9e2 went online from BSS 943b-b051-2520 with SSID XLL on AP 943b-b051-2520. State changed to Run. %Mar 19 10:37:47:928 2022 XLL-R STAMGR/6/STAMGR_ROAM_SUCCESS: Client a6e1-a489-f9e2 roamed from BSSID 943b-b051-2530 on AP 943b-b051-2520 of AC IP 127.0.0.1 to BSSID 943b-b051-2520 on AP 943b-b051-2520 of AC IP 127.0.0.1 successfully. %Mar 19 10:37:47:930 2022 XLL-R STAMGR/6/STAMGR_CLIENT_OFFLINE: Client a6e1-a489-f9e2 went offline from BSS 943b-b051-2530 with SSID XLL on AP 943b-b051-2520. State changed to Unauth. Reason:Successfully roamed to another BSS. %Mar 19 10:37:47:931 2022 XLL-R STAMGR/6/STAMGR_CLIENT_SNOOPING: Detected client IP change: Client MAC: a6e1-a489-f9e2, IP: 172.16.100.5, 172.16.100.87, -NA-, -NA-, Username: -NA-, AP name: 943b-b051-2520, Radio ID: 1, Channel number: 36, SSID: XLL, BSSID: 943b-b051-2520. %Mar 19 10:37:54:989 2022 XLL-R LOGIN/5/LOGIN_FAILED: shell failed to log in from 14.172.67.148. %Mar 19 10:37:59:844 2022 XLL-R STAMGR/6/STAMGR_CLIENT_OFFLINE: Client 32c9-c109-1a7b went offline from BSS 943b-b051-d210 with SSID XLL on AP 943b-b051-d200. State changed to Unauth. Reason:Received deauthentication message in Run state: reason code=4 %Mar 19 10:38:02:399 2022 XLL-R STAMGR/6/STAMGR_CLIENT_ONLINE: Client 32c9-c109-1a7b went online from BSS 943b-b051-d210 with SSID XLL on AP 943b-b051-d200. State changed to Run. %Mar 19 10:38:02:399 2022 XLL-R STAMGR/6/STAMGR_CLIENT_SNOOPING: Detected client IP change: Client MAC: 32c9-c109-1a7b, IP: 172.16.100.58, -NA-, -NA-, -NA-, Username: -NA-, AP name: 943b-b051-d200, Radio ID: 2, Channel number: 6, SSID: XLL, BSSID: 943b-b051-d210. %Mar 19 10:38:02:400 2022 XLL-R STAMGR/6/STAMGR_ROAM_SUCCESS: Client 32c9-c109-1a7b roamed from BSSID 943b-b051-d210 on AP 943b-b051-d200 of AC IP 127.0.0.1 to BSSID 943b-b051-d210 on AP 943b-b051-d200 of AC IP 127.0.0.1 successfully. %Mar 19 10:38:06:634 2022 XLL-R LOGIN/5/LOGIN_FAILED: shell failed to log in from 14.172.67.148. %Mar 19 10:38:20:357 2022 XLL-R LOGIN/5/LOGIN_FAILED: shell failed to log in from 14.172.67.148. %Mar 19 10:38:31:767 2022 XLL-R STAMGR/6/STAMGR_CLIENT_ONLINE: Client 32c9-c109-1a7b went online from BSS 943b-b051-5340 with SSID XLL on AP 943b-b051-5330. State changed to Run. %Mar 19 10:38:31:769 2022 XLL-R STAMGR/6/STAMGR_ROAM_SUCCESS: Client 32c9-c109-1a7b roamed from BSSID 943b-b051-d210 on AP 943b-b051-d200 of AC IP 127.0.0.1 to BSSID 943b-b051-5340 on AP 943b-b051-5330 of AC IP 127.0.0.1 successfully. %Mar 19 10:38:31:770 2022 XLL-R STAMGR/6/STAMGR_CLIENT_OFFLINE: Client 32c9-c109-1a7b went offline from BSS 943b-b051-d210 with SSID XLL on AP 943b-b051-d200. State changed to Unauth. Reason:Successfully roamed to another BSS. %Mar 19 10:38:31:775 2022 XLL-R STAMGR/6/STAMGR_CLIENT_SNOOPING: Detected client IP change: Client MAC: 32c9-c109-1a7b, IP: 172.16.100.58, -NA-, -NA-, -NA-, Username: -NA-, AP name: 943b-b051-5330, Radio ID: 2, Channel number: 11, SSID: XLL, BSSID: 943b-b051-5340. %Mar 19 10:38:35:503 2022 XLL-R LOGIN/5/LOGIN_FAILED: shell failed to log in from 14.172.67.148. %Mar 19 10:38:46:346 2022 XLL-R LOGIN/5/LOGIN_FAILED: shell failed to log in from 14.172.67.148. %Mar 19 10:38:47:981 2022 XLL-R STAMGR/6/STAMGR_CLIENT_ONLINE: Client a6e1-a489-f9e2 went online from BSS 943b-b051-2530 with SSID XLL on AP 943b-b051-2520. State changed to Run. %Mar 19 10:38:47:985 2022 XLL-R STAMGR/6/STAMGR_ROAM_SUCCESS: Client a6e1-a489-f9e2 roamed from BSSID 943b-b051-2520 on AP 943b-b051-2520 of AC IP 127.0.0.1 to BSSID 943b-b051-2530 on AP 943b-b051-2520 of AC IP 127.0.0.1 successfully. %Mar 19 10:38:47:986 2022 XLL-R STAMGR/6/STAMGR_CLIENT_OFFLINE: Client a6e1-a489-f9e2 went offline from BSS 943b-b051-2520 with SSID XLL on AP 943b-b051-2520. State changed to Unauth. Reason:Successfully roamed to another BSS. %Mar 19 10:38:47:988 2022 XLL-R STAMGR/6/STAMGR_CLIENT_SNOOPING: Detected client IP change: Client MAC: a6e1-a489-f9e2, IP: 172.16.100.5, 172.16.100.87, -NA-, -NA-, Username: -NA-, AP name: 943b-b051-2520, Radio ID: 2, Channel number: 6, SSID: XLL, BSSID: 943b-b051-2530. %Mar 19 10:38:50:992 2022 XLL-R STAMGR/6/STAMGR_CLIENT_ONLINE: Client 32c9-c109-1a7b went online from BSS 943b-b051-d210 with SSID XLL on AP 943b-b051-d200. State changed to Run. %Mar 19 10:38:50:993 2022 XLL-R STAMGR/6/STAMGR_ROAM_SUCCESS: Client 32c9-c109-1a7b roamed from BSSID 943b-b051-5340 on AP 943b-b051-5330 of AC IP 127.0.0.1 to BSSID 943b-b051-d210 on AP 943b-b051-d200 of AC IP 127.0.0.1 successfully. %Mar 19 10:38:50:997 2022 XLL-R STAMGR/6/STAMGR_CLIENT_OFFLINE: Client 32c9-c109-1a7b went offline from BSS 943b-b051-5340 with SSID XLL on AP 943b-b051-5330. State changed to Unauth. Reason:Successfully roamed to another BSS. %Mar 19 10:38:51:001 2022 XLL-R STAMGR/6/STAMGR_CLIENT_SNOOPING: Detected client IP change: Client MAC: 32c9-c109-1a7b, IP: 172.16.100.58, -NA-, -NA-, -NA-, Username: -NA-, AP name: 943b-b051-d200, Radio ID: 2, Channel number: 6, SSID: XLL, BSSID: 943b-b051-d210. %Mar 19 10:38:57:425 2022 XLL-R LOGIN/5/LOGIN_FAILED: shell failed to log in from 14.172.67.148. %Mar 19 10:39:07:810 2022 XLL-R LOGIN/5/LOGIN_FAILED: shell failed to log in from 14.172.67.148. %Mar 19 10:39:09:335 2022 XLL-R STAMGR/6/STAMGR_CLIENT_ONLINE: Client 32c9-c109-1a7b went online from BSS 943b-b051-5340 with SSID XLL on AP 943b-b051-5330. State changed to Run. %Mar 19 10:39:09:336 2022 XLL-R STAMGR/6/STAMGR_ROAM_SUCCESS: Client 32c9-c109-1a7b roamed from BSSID 943b-b051-d210 on AP 943b-b051-d200 of AC IP 127.0.0.1 to BSSID 943b-b051-5340 on AP 943b-b051-5330 of AC IP 127.0.0.1 successfully. %Mar 19 10:39:09:339 2022 XLL-R STAMGR/6/STAMGR_CLIENT_OFFLINE: Client 32c9-c109-1a7b went offline from BSS 943b-b051-d210 with SSID XLL on AP 943b-b051-d200. State changed to Unauth. Reason:Successfully roamed to another BSS. %Mar 19 10:39:09:340 2022 XLL-R STAMGR/6/STAMGR_CLIENT_SNOOPING: Detected client IP change: Client MAC: 32c9-c109-1a7b, IP: 172.16.100.58, -NA-, -NA-, -NA-, Username: -NA-, AP name: 943b-b051-5330, Radio ID: 2, Channel number: 11, SSID: XLL, BSSID: 943b-b051-5340. %Mar 19 10:39:18:343 2022 XLL-R LOGIN/5/LOGIN_FAILED: shell failed to log in from 14.172.67.148. %Mar 19 10:39:29:182 2022 XLL-R LOGIN/5/LOGIN_FAILED: shell failed to log in from 14.172.67.148. %Mar 19 10:39:29:247 2022 XLL-R STAMGR/6/STAMGR_CLIENT_ONLINE: Client c205-f70b-cadf went online from BSS 943b-b051-2530 with SSID XLL on AP 943b-b051-2520. State changed to Run. %Mar 19 10:39:29:248 2022 XLL-R STAMGR/6/STAMGR_ROAM_SUCCESS: Client c205-f70b-cadf roamed from BSSID 943b-b051-d210 on AP 943b-b051-d200 of AC IP 127.0.0.1 to BSSID 943b-b051-2530 on AP 943b-b051-2520 of AC IP 127.0.0.1 successfully. %Mar 19 10:39:29:252 2022 XLL-R STAMGR/6/STAMGR_CLIENT_SNOOPING: Detected client IP change: Client MAC: c205-f70b-cadf, IP: 172.16.100.66, -NA-, -NA-, -NA-, Username: -NA-, AP name: 943b-b051-2520, Radio ID: 2, Channel number: 6, SSID: XLL, BSSID: 943b-b051-2530. %Mar 19 10:39:39:653 2022 XLL-R LOGIN/5/LOGIN_FAILED: shell failed to log in from 14.172.67.148. %Mar 19 10:39:40:340 2022 XLL-R STAMGR/6/STAMGR_CLIENT_ONLINE: Client 32c9-c109-1a7b went online from BSS 943b-b051-d210 with SSID XLL on AP 943b-b051-d200. State changed to Run. %Mar 19 10:39:40:342 2022 XLL-R STAMGR/6/STAMGR_ROAM_SUCCESS: Client 32c9-c109-1a7b roamed from BSSID 943b-b051-5340 on AP 943b-b051-5330 of AC IP 127.0.0.1 to BSSID 943b-b051-d210 on AP 943b-b051-d200 of AC IP 127.0.0.1 successfully. %Mar 19 10:39:40:351 2022 XLL-R STAMGR/6/STAMGR_CLIENT_SNOOPING: Detected client IP change: Client MAC: 32c9-c109-1a7b, IP: 172.16.100.58, -NA-, -NA-, -NA-, Username: -NA-, AP name: 943b-b051-d200, Radio ID: 2, Channel number: 6, SSID: XLL, BSSID: 943b-b051-d210. %Mar 19 10:39:40:353 2022 XLL-R STAMGR/6/STAMGR_CLIENT_OFFLINE: Client 32c9-c109-1a7b went offline from BSS 943b-b051-5340 with SSID XLL on AP 943b-b051-5330. State changed to Unauth. Reason:Successfully roamed to another BSS. %Mar 19 10:39:43:969 2022 XLL-R STAMGR/6/STAMGR_CLIENT_ONLINE: Client c205-f70b-cadf went online from BSS 943b-b051-d210 with SSID XLL on AP 943b-b051-d200. State changed to Run. %Mar 19 10:39:43:972 2022 XLL-R STAMGR/6/STAMGR_CLIENT_OFFLINE: Client c205-f70b-cadf went offline from BSS 943b-b051-2530 with SSID XLL on AP 943b-b051-2520. State changed to Unauth. Reason:Successfully roamed to another BSS. %Mar 19 10:39:43:973 2022 XLL-R STAMGR/6/STAMGR_ROAM_SUCCESS: Client c205-f70b-cadf roamed from BSSID 943b-b051-2530 on AP 943b-b051-2520 of AC IP 127.0.0.1 to BSSID 943b-b051-d210 on AP 943b-b051-d200 of AC IP 127.0.0.1 successfully. %Mar 19 10:39:43:977 2022 XLL-R STAMGR/6/STAMGR_CLIENT_SNOOPING: Detected client IP change: Client MAC: c205-f70b-cadf, IP: 172.16.100.66, -NA-, -NA-, -NA-, Username: -NA-, AP name: 943b-b051-d200, Radio ID: 2, Channel number: 6, SSID: XLL, BSSID: 943b-b051-d210. %Mar 19 10:39:50:714 2022 XLL-R STAMGR/6/STAMGR_CLIENT_ONLINE: Client 32c9-c109-1a7b went online from BSS 943b-b051-5340 with SSID XLL on AP 943b-b051-5330. State changed to Run. %Mar 19 10:39:50:715 2022 XLL-R STAMGR/6/STAMGR_ROAM_SUCCESS: Client 32c9-c109-1a7b roamed from BSSID 943b-b051-d210 on AP 943b-b051-d200 of AC IP 127.0.0.1 to BSSID 943b-b051-5340 on AP 943b-b051-5330 of AC IP 127.0.0.1 successfully. %Mar 19 10:39:50:717 2022 XLL-R STAMGR/6/STAMGR_CLIENT_OFFLINE: Client 32c9-c109-1a7b went offline from BSS 943b-b051-d210 with SSID XLL on AP 943b-b051-d200. State changed to Unauth. Reason:Successfully roamed to another BSS. %Mar 19 10:39:50:721 2022 XLL-R STAMGR/6/STAMGR_CLIENT_SNOOPING: Detected client IP change: Client MAC: 32c9-c109-1a7b, IP: 172.16.100.58, -NA-, -NA-, -NA-, Username: -NA-, AP name: 943b-b051-5330, Radio ID: 2, Channel number: 11, SSID: XLL, BSSID: 943b-b051-5340. %Mar 19 10:39:50:950 2022 XLL-R STAMGR/6/STAMGR_CLIENT_ONLINE: Client a6e1-a489-f9e2 went online from BSS 943b-b051-2520 with SSID XLL on AP 943b-b051-2520. State changed to Run. %Mar 19 10:39:50:956 2022 XLL-R STAMGR/6/STAMGR_ROAM_SUCCESS: Client a6e1-a489-f9e2 roamed from BSSID 943b-b051-2530 on AP 943b-b051-2520 of AC IP 127.0.0.1 to BSSID 943b-b051-2520 on AP 943b-b051-2520 of AC IP 127.0.0.1 successfully. %Mar 19 10:39:50:957 2022 XLL-R STAMGR/6/STAMGR_CLIENT_OFFLINE: Client a6e1-a489-f9e2 went offline from BSS 943b-b051-2530 with SSID XLL on AP 943b-b051-2520. State changed to Unauth. Reason:Successfully roamed to another BSS. %Mar 19 10:39:50:959 2022 XLL-R STAMGR/6/STAMGR_CLIENT_SNOOPING: Detected client IP change: Client MAC: a6e1-a489-f9e2, IP: 172.16.100.5, 172.16.100.87, -NA-, -NA-, Username: -NA-, AP name: 943b-b051-2520, Radio ID: 1, Channel number: 36, SSID: XLL, BSSID: 943b-b051-2520. %Mar 19 10:39:51:552 2022 XLL-R LOGIN/5/LOGIN_FAILED: shell failed to log in from 14.172.67.148. %Mar 19 10:39:56:451 2022 XLL-R STAMGR/6/STAMGR_CLIENT_ONLINE: Client a6e1-a489-f9e2 went online from BSS 943b-b051-2530 with SSID XLL on AP 943b-b051-2520. State changed to Run. %Mar 19 10:39:56:455 2022 XLL-R STAMGR/6/STAMGR_ROAM_SUCCESS: Client a6e1-a489-f9e2 roamed from BSSID 943b-b051-2520 on AP 943b-b051-2520 of AC IP 127.0.0.1 to BSSID 943b-b051-2530 on AP 943b-b051-2520 of AC IP 127.0.0.1 successfully. %Mar 19 10:39:56:456 2022 XLL-R STAMGR/6/STAMGR_CLIENT_OFFLINE: Client a6e1-a489-f9e2 went offline from BSS 943b-b051-2520 with SSID XLL on AP 943b-b051-2520. State changed to Unauth. Reason:Successfully roamed to another BSS. %Mar 19 10:39:56:458 2022 XLL-R STAMGR/6/STAMGR_CLIENT_SNOOPING: Detected client IP change: Client MAC: a6e1-a489-f9e2, IP: 172.16.100.5, 172.16.100.87, -NA-, -NA-, Username: -NA-, AP name: 943b-b051-2520, Radio ID: 2, Channel number: 6, SSID: XLL, BSSID: 943b-b051-2530. %Mar 19 10:40:01:739 2022 XLL-R STAMGR/6/STAMGR_CLIENT_OFFLINE: Client a6e1-a489-f9e2 went offline from BSS 943b-b051-2530 with SSID XLL on AP 943b-b051-2520. State changed to Unauth. Reason:Received deauthentication message in Run state: reason code=15 %Mar 19 10:40:02:359 2022 XLL-R LOGIN/5/LOGIN_FAILED: shell failed to log in from 14.172.67.148. %Mar 19 10:40:02:487 2022 XLL-R STAMGR/6/STAMGR_CLIENT_ONLINE: Client a6e1-a489-f9e2 went online from BSS 943b-b051-2530 with SSID XLL on AP 943b-b051-2520. State changed to Run. %Mar 19 10:40:02:488 2022 XLL-R STAMGR/6/STAMGR_CLIENT_SNOOPING: Detected client IP change: Client MAC: a6e1-a489-f9e2, IP: 172.16.100.5, 172.16.100.87, -NA-, -NA-, Username: -NA-, AP name: 943b-b051-2520, Radio ID: 2, Channel number: 6, SSID: XLL, BSSID: 943b-b051-2530. %Mar 19 10:40:13:326 2022 XLL-R LOGIN/5/LOGIN_FAILED: shell failed to log in from 14.172.67.148. %Mar 19 10:40:26:618 2022 XLL-R LOGIN/5/LOGIN_FAILED: shell failed to log in from 14.172.67.148. %Mar 19 10:40:28:622 2022 XLL-R STAMGR/6/STAMGR_CLIENT_ONLINE: Client a6e1-a489-f9e2 went online from BSS 943b-b051-2520 with SSID XLL on AP 943b-b051-2520. State changed to Run. %Mar 19 10:40:28:627 2022 XLL-R STAMGR/6/STAMGR_ROAM_SUCCESS: Client a6e1-a489-f9e2 roamed from BSSID 943b-b051-2530 on AP 943b-b051-2520 of AC IP 127.0.0.1 to BSSID 943b-b051-2520 on AP 943b-b051-2520 of AC IP 127.0.0.1 successfully. %Mar 19 10:40:28:630 2022 XLL-R STAMGR/6/STAMGR_CLIENT_OFFLINE: Client a6e1-a489-f9e2 went offline from BSS 943b-b051-2530 with SSID XLL on AP 943b-b051-2520. State changed to Unauth. Reason:Successfully roamed to another BSS. %Mar 19 10:40:28:632 2022 XLL-R STAMGR/6/STAMGR_CLIENT_SNOOPING: Detected client IP change: Client MAC: a6e1-a489-f9e2, IP: 172.16.100.5, 172.16.100.87, -NA-, -NA-, Username: -NA-, AP name: 943b-b051-2520, Radio ID: 1, Channel number: 36, SSID: XLL, BSSID: 943b-b051-2520. %Mar 19 10:40:36:870 2022 XLL-R STAMGR/6/STAMGR_CLIENT_ONLINE: Client a6e1-a489-f9e2 went online from BSS 943b-b051-2530 with SSID XLL on AP 943b-b051-2520. State changed to Run. %Mar 19 10:40:36:873 2022 XLL-R STAMGR/6/STAMGR_ROAM_SUCCESS: Client a6e1-a489-f9e2 roamed from BSSID 943b-b051-2520 on AP 943b-b051-2520 of AC IP 127.0.0.1 to BSSID 943b-b051-2530 on AP 943b-b051-2520 of AC IP 127.0.0.1 successfully. %Mar 19 10:40:36:874 2022 XLL-R STAMGR/6/STAMGR_CLIENT_OFFLINE: Client a6e1-a489-f9e2 went offline from BSS 943b-b051-2520 with SSID XLL on AP 943b-b051-2520. State changed to Unauth. Reason:Successfully roamed to another BSS. %Mar 19 10:40:36:876 2022 XLL-R STAMGR/6/STAMGR_CLIENT_SNOOPING: Detected client IP change: Client MAC: a6e1-a489-f9e2, IP: 172.16.100.5, 172.16.100.87, -NA-, -NA-, Username: -NA-, AP name: 943b-b051-2520, Radio ID: 2, Channel number: 6, SSID: XLL, BSSID: 943b-b051-2530. %Mar 19 10:40:50:329 2022 XLL-R SHELL/6/SHELL_CMD: -Line=-IPAddr=**-User=**; Command is display diagnostic-information diag.tar.gz ========================================================== ===============display process memory=============== JID Text Data Stack Dynamic Name 1 132 8920 32 132 scmd 2 0 0 0 0 [kthreadd] 3 0 0 0 0 [migration/0] 4 0 0 0 0 [ksoftirqd/0] 5 0 0 0 0 [watchdog/0] 6 0 0 0 0 [migration/1] 7 0 0 0 0 [ksoftirqd/1] 8 0 0 0 0 [watchdog/1] 9 0 0 0 0 [migration/2] 10 0 0 0 0 [ksoftirqd/2] 11 0 0 0 0 [watchdog/2] 12 0 0 0 0 [migration/3] 13 0 0 0 0 [ksoftirqd/3] 14 0 0 0 0 [watchdog/3] 15 0 0 0 0 [migration/4] 16 0 0 0 0 [ksoftirqd/4] 17 0 0 0 0 [watchdog/4] 18 0 0 0 0 [migration/5] 19 0 0 0 0 [ksoftirqd/5] 20 0 0 0 0 [watchdog/5] 21 0 0 0 0 [migration/6] 22 0 0 0 0 [ksoftirqd/6] 23 0 0 0 0 [watchdog/6] 24 0 0 0 0 [migration/7] 25 0 0 0 0 [ksoftirqd/7] 26 0 0 0 0 [watchdog/7] 27 0 0 0 0 [events/0] 28 0 0 0 0 [events/1] 29 0 0 0 0 [events/2] 30 0 0 0 0 [events/3] 31 0 0 0 0 [events/4] 32 0 0 0 0 [events/5] 33 0 0 0 0 [events/6] 34 0 0 0 0 [events/7] 35 0 0 0 0 [khelper] 36 0 0 0 0 [kblockd/0] 37 0 0 0 0 [kblockd/1] 38 0 0 0 0 [kblockd/2] 39 0 0 0 0 [kblockd/3] 40 0 0 0 0 [kblockd/4] 41 0 0 0 0 [kblockd/5] 42 0 0 0 0 [kblockd/6] 43 0 0 0 0 [kblockd/7] 44 0 0 0 0 [khubd] 45 0 0 0 0 [vzmond] 46 0 0 0 0 [pdflush] 47 0 0 0 0 [pdflush] 48 0 0 0 0 [kswapd0] 49 0 0 0 0 [aio/0] 50 0 0 0 0 [aio/1] 51 0 0 0 0 [aio/2] 52 0 0 0 0 [aio/3] 53 0 0 0 0 [aio/4] 54 0 0 0 0 [aio/5] 55 0 0 0 0 [aio/6] 56 0 0 0 0 [aio/7] 57 0 0 0 0 [mtdblockd] 73 0 0 0 0 [kmmcd] 74 0 0 0 0 [spi-xlp.0] 88 0 0 0 0 [fshe] 99 0 0 0 0 [kdrvfwd3] 100 0 0 0 0 [kdrvfwd4] 101 0 0 0 0 [kdrvfwd5] 102 0 0 0 0 [kdrvfwd6] 103 0 0 0 0 [kdrvfwd7] 106 0 0 0 0 [lipc_topology] 108 0 0 0 0 [LOAD] 109 0 0 0 0 [LOADProc] 110 0 0 0 0 [timesyncs] 111 0 0 0 0 [lipc_portevt] 112 0 0 0 0 [kuserlog] 113 0 0 0 0 [kevent] 114 0 0 0 0 [kifupdown] 115 0 0 0 0 [MinishellMain] 116 0 0 0 0 [kmac/1] 117 0 0 0 0 [kipfs/1] 118 0 0 0 0 [kip6fs/1] 119 0 0 0 0 [ktcp_proxy/1/0] 120 0 0 0 0 [ktcp_proxy/1/1] 121 0 0 0 0 [ktcp_proxy/1/2] 122 0 0 0 0 [ktcp_proxy/1/32] 123 0 0 0 0 [ktcp_proxy/1/33] 124 0 0 0 0 [ktcp_proxy/1/34] 125 0 0 0 0 [sock/1] 126 0 0 0 0 [UFLT_KTHREAD1] 127 0 0 0 0 [kdrs] 129 8 420 8 4 cioctld 130 120 8680 20 8 fsd 132 216 1236 44 168 licd 133 108 26600 24 3396 dbmd 135 20 676 8 20 drvdiagd 136 72 9304 12 456 diagd 138 104 432 16 16 had 139 144 10216 0 464 syslogd 140 204 9256 20 8 devd 143 36 51048 20 64 ifmgr 144 148 9268 20 16 edev 147 16 1388 24 32 drvciud 156 44 2676 16 60 moduleproxyd 157 256 62528 40 5460 ofcd 158 76 1304 8 68 trackd 159 4084 37236 40 8800 apmgrd 160 100 1208 56 28 sysmand 161 148 23620 64 4460 lauthd 162 72 800 16 8 ttymgrd 163 176 2516 12 96 aaad 164 408 34784 16 24 laggd 165 40 516 12 36 tranged 166 272 9648 24 152 vland 167 36 920 12 8 cryptomgrd 175 572 22116 24 324 aclmgrd 190 64 15428 24 260 qosd 193 44 804 8 12 ipcimd 194 256 9732 12 112 ethd 195 20 584 8 48 coppd 199 12140 22776 28 7340 comsh 204 3988 30204 48 5136 stamgrd 213 100 6440 16 24 maintaind 216 136 9048 20 56 dnsd 218 716 66192 16 904 pppd 219 12 688 8 12 appprofiled 220 188 13916 40 3744 aprd 221 164 11660 0 72 cmtnlmgrd 223 188 9896 12 20 ddrd 224 652 22712 20 1628 dhcpd 225 100 2524 20 428 dhcpcd 226 200 15584 40 12652 dpid 227 156 23068 36 16016 drsd 228 60 21284 76 1160 httpd 229 344 9996 0 124 ipstackd 230 336 18176 32 120 lldpd 231 4 1480 12 196 natd 232 380 11808 12 852 nqad 233 56 760 12 20 nqasd 234 192 9964 20 80 ntpd 235 1168 38340 68 1952 portald 237 716 41008 12 480 portsecd 238 24 22700 12 964 routed 239 280 9448 44 1352 rrmd 240 4 11072 20 708 sessiond 241 116 1336 12 12 telnetd 242 116 1316 16 4 telnetd 243 392 69820 28 2108 xmlcfgd 244 48 868 12 16 scheduler 253 172 13456 12 384 staticrtd 257 0 0 0 0 [karp/1] 258 0 0 0 0 [kwadj/1] 259 0 0 0 0 [kfib/1] 289 0 0 0 0 [loop0] 292 0 0 0 0 [loop1] 295 0 0 0 0 [loop2] 297 0 0 0 0 [loop3] 300 0 0 0 0 [loop4] 1127 216 10788 24 28 sshd 1141 12140 26832 65 4506 comsh 1143 12140 35024 77 4502 comsh 1145 1092 464 8 244 gzip 1146 12140 36156 129 8518 comsh ================================================= ===============display process log=============== Process JobID PID Abort Core Exit Kill StartTime EndTime mdcd 137 137 N N -- 36 03-19 01:41:01 03-19 01:41:01 fips 142 142 N N 0 -- 03-19 09:41:01 03-19 09:41:02 knotify 154 154 N N 0 -- 03-19 09:41:02 03-19 09:41:02 knotify 155 155 N N 0 -- 03-19 09:41:02 03-19 09:41:02 knotify 192 192 N N 0 -- 03-19 09:41:02 03-19 09:41:03 comsh 214 214 N N 0 -- 03-19 09:42:03 03-19 09:42:11 delete.sh 321 321 N N 0 -- 03-19 09:42:34 03-19 09:42:34 knotify 324 324 N N 0 -- 03-19 09:42:34 03-19 09:42:34 pkg_update 215 215 N N 0 -- 03-19 09:42:03 03-19 09:42:34 bdrplugin 322 322 N N 0 -- 03-19 09:42:34 03-19 09:42:36 ================================================================== ===============display cpu=============== Unit CPU usage: 16% in last 5 seconds 8% in last 1 minute 7% in last 5 minutes =========================================================== ===============display cpu-usage history=============== 100%| 95%| 90%| 85%| 80%| 75%| 70%| 65%| 60%| 55%| 50%| 45%| 40%| 35%| 30%| 25%| 20%| # 15%| ## 10%|#### # # # # ## # # ## 5%|########################################################### ------------------------------------------------------------ 10 20 30 40 50 60 (minutes) cpu-usage last 60 minutes (SYSTEM) ================================================================= ===============display process=============== JID PID %CPU %MEM STAT PRI TTY HH:MM:SS COMMAND 1 1 0.0 0.0 S 120 - 00:02:06 scmd 2 2 0.0 0.0 S 115 - 00:00:00 [kthreadd] 3 3 0.0 0.0 S 99 - 00:00:00 [migration/0] 4 4 0.0 0.0 S 115 - 00:00:01 [ksoftirqd/0] 5 5 0.0 0.0 S 99 - 00:00:00 [watchdog/0] 6 6 0.0 0.0 S 99 - 00:00:00 [migration/1] 7 7 0.0 0.0 S 115 - 00:00:01 [ksoftirqd/1] 8 8 0.0 0.0 S 99 - 00:00:00 [watchdog/1] 9 9 0.0 0.0 S 99 - 00:00:00 [migration/2] 10 10 0.0 0.0 S 115 - 00:00:01 [ksoftirqd/2] 11 11 0.0 0.0 S 99 - 00:00:00 [watchdog/2] 12 12 0.0 0.0 S 99 - 00:00:00 [migration/3] 13 13 0.0 0.0 S 115 - 00:00:00 [ksoftirqd/3] 14 14 0.0 0.0 S 99 - 00:00:00 [watchdog/3] 15 15 0.0 0.0 S 99 - 00:00:00 [migration/4] 16 16 0.0 0.0 S 115 - 00:00:00 [ksoftirqd/4] 17 17 0.0 0.0 S 99 - 00:00:00 [watchdog/4] 18 18 0.0 0.0 S 99 - 00:00:00 [migration/5] 19 19 0.0 0.0 S 115 - 00:00:00 [ksoftirqd/5] 20 20 0.0 0.0 S 99 - 00:00:00 [watchdog/5] 21 21 0.0 0.0 S 99 - 00:00:00 [migration/6] 22 22 0.0 0.0 S 115 - 00:00:00 [ksoftirqd/6] 23 23 0.0 0.0 S 99 - 00:00:00 [watchdog/6] 24 24 0.0 0.0 S 99 - 00:00:00 [migration/7] 25 25 0.0 0.0 S 115 - 00:00:00 [ksoftirqd/7] 26 26 0.0 0.0 S 99 - 00:00:00 [watchdog/7] 27 27 0.0 0.0 S 115 - 00:00:00 [events/0] 28 28 0.0 0.0 S 115 - 00:00:16 [events/1] 29 29 0.0 0.0 S 115 - 00:00:00 [events/2] 30 30 0.0 0.0 S 115 - 00:00:00 [events/3] 31 31 0.0 0.0 S 115 - 00:00:00 [events/4] 32 32 0.0 0.0 S 115 - 00:00:00 [events/5] 33 33 0.0 0.0 S 115 - 00:00:00 [events/6] 34 34 0.0 0.0 S 115 - 00:00:00 [events/7] 35 35 0.0 0.0 S 115 - 00:00:00 [khelper] 36 36 0.0 0.0 S 115 - 00:00:00 [kblockd/0] 37 37 0.0 0.0 S 115 - 00:00:00 [kblockd/1] 38 38 0.0 0.0 S 115 - 00:00:00 [kblockd/2] 39 39 0.0 0.0 S 115 - 00:00:00 [kblockd/3] 40 40 0.0 0.0 S 115 - 00:00:00 [kblockd/4] 41 41 0.0 0.0 S 115 - 00:00:00 [kblockd/5] 42 42 0.0 0.0 S 115 - 00:00:00 [kblockd/6] 43 43 0.0 0.0 S 115 - 00:00:00 [kblockd/7] 44 44 0.0 0.0 S 115 - 00:00:00 [khubd] 45 45 0.0 0.0 S 120 - 00:00:00 [vzmond] 46 46 0.0 0.0 S 120 - 00:00:00 [pdflush] 47 47 0.0 0.0 S 120 - 00:00:00 [pdflush] 48 48 0.0 0.0 S 115 - 00:00:00 [kswapd0] 49 49 0.0 0.0 S 115 - 00:00:00 [aio/0] 50 50 0.0 0.0 S 115 - 00:00:00 [aio/1] 51 51 0.0 0.0 S 115 - 00:00:00 [aio/2] 52 52 0.0 0.0 S 115 - 00:00:00 [aio/3] 53 53 0.0 0.0 S 115 - 00:00:00 [aio/4] 54 54 0.0 0.0 S 115 - 00:00:00 [aio/5] 55 55 0.0 0.0 S 115 - 00:00:00 [aio/6] 56 56 0.0 0.0 S 115 - 00:00:00 [aio/7] 57 57 0.0 0.0 S 115 - 00:00:00 [mtdblockd] 73 73 0.0 0.0 S 115 - 00:00:00 [kmmcd] 74 74 0.0 0.0 S 115 - 00:00:02 [spi-xlp.0] 88 88 0.0 0.0 S 115 - 00:00:00 [fshe] 99 99 0.7 0.0 R 115 - 00:02:16 [kdrvfwd3] 100 100 0.6 0.0 R 115 - 00:06:19 [kdrvfwd4] 101 101 0.4 0.0 R 115 - 00:03:20 [kdrvfwd5] 102 102 0.6 0.0 R 115 - 00:03:42 [kdrvfwd6] 103 103 0.2 0.0 R 115 - 00:02:29 [kdrvfwd7] 106 106 0.0 0.0 D 100 - 00:00:00 [lipc_topology] 108 108 0.0 0.0 S 120 - 00:00:00 [LOAD] 109 109 0.0 0.0 S 120 - 00:00:00 [LOADProc] 110 110 0.0 0.0 S 120 - 00:00:00 [timesyncs] 111 111 0.0 0.0 S 115 - 00:00:00 [lipc_portevt] 112 112 0.0 0.0 S 115 - 00:00:00 [kuserlog] 113 113 0.0 0.0 S 105 - 00:00:00 [kevent] 114 114 0.0 0.0 S 125 - 00:00:00 [kifupdown] 115 115 0.0 0.0 S 115 - 00:00:00 [MinishellMain] 116 116 0.0 0.0 S 120 - 00:00:03 [kmac/1] 117 117 0.0 0.0 S 120 - 00:00:00 [kipfs/1] 118 118 0.0 0.0 S 120 - 00:00:00 [kip6fs/1] 119 119 0.0 0.0 S 115 - 00:00:00 [ktcp_proxy/1/0] 120 120 0.0 0.0 S 115 - 00:00:00 [ktcp_proxy/1/1] 121 121 0.0 0.0 S 115 - 00:00:00 [ktcp_proxy/1/2] 122 122 0.0 0.0 S 115 - 00:00:00 [ktcp_proxy/1/32] 123 123 0.0 0.0 S 115 - 00:00:00 [ktcp_proxy/1/33] 124 124 0.0 0.0 S 115 - 00:00:00 [ktcp_proxy/1/34] 125 125 0.0 0.0 S 105 - 00:00:01 [sock/1] 126 126 0.0 0.0 S 115 - 00:00:00 [UFLT_KTHREAD1] 127 127 0.0 0.0 S 115 - 00:00:23 [kdrs] 129 129 0.0 0.0 S 110 - 00:00:00 cioctld 130 130 0.0 0.0 S 120 - 00:00:00 fsd 132 132 0.0 0.0 S 120 - 00:00:00 licd --mode=3 --did=2 133 133 0.0 0.2 S 100 - 00:00:13 dbmd 135 135 0.0 0.0 S 120 - 00:00:00 drvdiagd 136 136 0.2 0.0 S 120 - 00:01:08 diagd -dflash --memale 138 138 0.0 0.0 S 105 - 00:00:00 had 139 139 0.0 0.0 S 120 - 00:00:13 syslogd --logfile=1 -- 140 140 0.0 0.0 S 120 - 00:00:04 devd 143 143 0.0 0.0 S 120 - 00:00:02 ifmgr 144 144 0.0 0.0 S 120 - 00:00:00 edev --RuntimeCountByD 147 147 0.0 0.0 S 120 - 00:00:00 drvciud 156 156 0.0 0.0 S 120 - 00:00:01 moduleproxyd 157 157 0.0 0.2 S 120 - 00:00:05 ofcd --DatapathNum=819 158 158 0.0 0.0 S 115 - 00:00:00 trackd 159 159 0.5 0.4 S 120 - 00:02:48 apmgrd --BootMode=1 -- 160 160 0.0 0.0 S 120 - 00:00:00 sysmand 161 161 0.0 0.1 S 120 - 00:01:00 lauthd --MaxManageUser 162 162 0.0 0.0 S 120 - 00:00:00 ttymgrd --MaxCOnNum=1 163 163 0.0 0.0 S 120 - 00:00:01 aaad 164 164 0.0 0.0 S 110 - 00:00:02 laggd 165 165 0.0 0.0 S 120 - 00:00:00 tranged 166 166 0.0 0.0 S 120 - 00:00:05 vland 167 167 0.0 0.0 S 120 - 00:00:00 cryptomgrd 175 175 0.0 0.0 S 120 - 00:00:03 aclmgrd 190 190 0.0 0.0 S 120 - 00:00:01 qosd --LogicIfType=63 193 193 0.0 0.0 S 125 - 00:00:01 ipcimd 194 194 0.0 0.0 S 120 - 00:00:01 ethd --MACCFG=0x1 195 195 0.0 0.0 S 110 - 00:00:00 coppd 199 199 0.0 0.5 S 120 - 00:00:28 comsh server ac 204 204 0.2 0.3 S 120 - 00:01:23 stamgrd --BootMode=1 213 213 0.0 0.0 S 110 - 00:00:20 maintaind 216 216 0.0 0.0 S 120 - 00:00:01 dnsd 218 218 0.0 0.1 S 120 - 00:00:14 pppd 219 219 0.0 0.0 S 120 - 00:00:00 appprofiled 220 220 0.0 0.1 S 120 - 00:00:08 aprd 221 221 0.0 0.0 S 120 - 00:00:02 cmtnlmgrd 223 223 0.0 0.0 S 120 - 00:00:02 ddrd 224 224 0.0 0.1 S 125 - 00:00:03 dhcpd --maxDhcprDynami 225 225 0.0 0.0 S 125 - 00:00:00 dhcpcd 226 226 0.0 0.4 S 120 - 00:00:10 dpid 227 227 0.1 0.4 S 120 - 00:04:19 drsd 228 228 0.0 0.1 S 125 - 00:00:06 httpd -w 2 -c 1024 229 229 0.0 0.0 S 125 - 00:00:01 ipstackd --ARPMaxStati 230 230 0.0 0.0 S 120 - 00:00:27 lldpd 231 231 0.0 0.0 S 120 - 00:00:00 natd 232 232 0.0 0.0 S 120 - 00:00:27 nqad 233 233 0.0 0.0 S 120 - 00:00:00 nqasd 234 234 0.0 0.0 S 125 - 00:00:01 ntpd 235 235 0.0 0.2 S 120 - 00:00:05 portald --devtype=2 237 237 0.0 0.1 S 120 - 00:00:02 portsecd 238 238 0.0 0.0 S 120 - 00:00:00 routed --ipv4 239 239 0.0 0.1 S 120 - 00:00:37 rrmd 240 240 0.0 0.0 S 120 - 00:00:00 sessiond 241 241 0.0 0.0 S 119 - 00:00:00 telnetd -6 242 242 0.0 0.0 S 119 - 00:00:00 telnetd -I 243 243 0.4 0.5 S 120 - 00:00:48 xmlcfgd --webMaxUserCo 244 244 0.0 0.0 S 120 - 00:00:00 scheduler 253 253 0.0 0.0 S 120 - 00:00:00 staticrtd --ipv4 257 257 0.0 0.0 S 115 - 00:00:09 [karp/1] 258 258 0.0 0.0 S 115 - 00:00:01 [kwadj/1] 259 259 0.0 0.0 S 115 - 00:00:00 [kfib/1] 289 289 0.0 0.0 S 100 - 00:00:00 [loop0] 292 292 0.0 0.0 S 100 - 00:00:00 [loop1] 295 295 0.0 0.0 S 100 - 00:00:00 [loop2] 297 297 0.0 0.0 S 100 - 00:00:00 [loop3] 300 300 0.0 0.0 S 100 - 00:00:00 [loop4] 1127 1127 2.6 0.0 S 120 - 00:00:01 sshd 1141 1141 6.3 0.6 S 120 - 00:00:03 comsh cmd display diag 1143 1143 0.0 0.4 S 120 - 00:00:00 comsh cmd display diag 1145 1145 0.0 0.0 S 120 - 00:00:00 gzip -f 1146 1146 2.2 0.4 S 120 - 00:00:03 comsh cmd display diag ================================================================= ===============display process cpu=============== CPU utilization in 5 secs: 16.2%; 1 min: 8.5%; 5 mins: 7.2% JID 5Sec 1Min 5Min Name 1 0.0% 0.0% 0.0% scmd 2 0.0% 0.0% 0.0% [kthreadd] 3 0.0% 0.0% 0.0% [migration/0] 4 0.0% 0.0% 0.0% [ksoftirqd/0] 5 0.0% 0.0% 0.0% [watchdog/0] 6 0.0% 0.0% 0.0% [migration/1] 7 0.0% 0.0% 0.0% [ksoftirqd/1] 8 0.0% 0.0% 0.0% [watchdog/1] 9 0.0% 0.0% 0.0% [migration/2] 10 0.0% 0.0% 0.0% [ksoftirqd/2] 11 0.0% 0.0% 0.0% [watchdog/2] 12 0.0% 0.0% 0.0% [migration/3] 13 0.0% 0.0% 0.0% [ksoftirqd/3] 14 0.0% 0.0% 0.0% [watchdog/3] 15 0.0% 0.0% 0.0% [migration/4] 16 0.0% 0.0% 0.0% [ksoftirqd/4] 17 0.0% 0.0% 0.0% [watchdog/4] 18 0.0% 0.0% 0.0% [migration/5] 19 0.0% 0.0% 0.0% [ksoftirqd/5] 20 0.0% 0.0% 0.0% [watchdog/5] 21 0.0% 0.0% 0.0% [migration/6] 22 0.0% 0.0% 0.0% [ksoftirqd/6] 23 0.0% 0.0% 0.0% [watchdog/6] 24 0.0% 0.0% 0.0% [migration/7] 25 0.0% 0.0% 0.0% [ksoftirqd/7] 26 0.0% 0.0% 0.0% [watchdog/7] 27 0.0% 0.0% 0.0% [events/0] 28 0.0% 0.0% 0.0% [events/1] 29 0.0% 0.0% 0.0% [events/2] 30 0.0% 0.0% 0.0% [events/3] 31 0.0% 0.0% 0.0% [events/4] 32 0.0% 0.0% 0.0% [events/5] 33 0.0% 0.0% 0.0% [events/6] 34 0.0% 0.0% 0.0% [events/7] 35 0.0% 0.0% 0.0% [khelper] 36 0.0% 0.0% 0.0% [kblockd/0] 37 0.0% 0.0% 0.0% [kblockd/1] 38 0.0% 0.0% 0.0% [kblockd/2] 39 0.0% 0.0% 0.0% [kblockd/3] 40 0.0% 0.0% 0.0% [kblockd/4] 41 0.0% 0.0% 0.0% [kblockd/5] 42 0.0% 0.0% 0.0% [kblockd/6] 43 0.0% 0.0% 0.0% [kblockd/7] 44 0.0% 0.0% 0.0% [khubd] 45 0.0% 0.0% 0.0% [vzmond] 46 0.0% 0.0% 0.0% [pdflush] 47 0.0% 0.0% 0.0% [pdflush] 48 0.0% 0.0% 0.0% [kswapd0] 49 0.0% 0.0% 0.0% [aio/0] 50 0.0% 0.0% 0.0% [aio/1] 51 0.0% 0.0% 0.0% [aio/2] 52 0.0% 0.0% 0.0% [aio/3] 53 0.0% 0.0% 0.0% [aio/4] 54 0.0% 0.0% 0.0% [aio/5] 55 0.0% 0.0% 0.0% [aio/6] 56 0.0% 0.0% 0.0% [aio/7] 57 0.0% 0.0% 0.0% [mtdblockd] 73 0.0% 0.0% 0.0% [kmmcd] 74 0.0% 0.0% 0.0% [spi-xlp.0] 88 0.0% 0.0% 0.0% [fshe] 99 0.7% 1.1% 0.4% [kdrvfwd3] 100 0.6% 1.3% 1.3% [kdrvfwd4] 101 0.4% 1.0% 1.0% [kdrvfwd5] 102 0.6% 0.5% 0.9% [kdrvfwd6] 103 0.2% 0.9% 0.6% [kdrvfwd7] 106 0.0% 0.0% 0.0% [lipc_topology] 108 0.0% 0.0% 0.0% [LOAD] 109 0.0% 0.0% 0.0% [LOADProc] 110 0.0% 0.0% 0.0% [timesyncs] 111 0.0% 0.0% 0.0% [lipc_portevt] 112 0.0% 0.0% 0.0% [kuserlog] 113 0.0% 0.0% 0.0% [kevent] 114 0.0% 0.0% 0.0% [kifupdown] 115 0.0% 0.0% 0.0% [MinishellMain] 116 0.0% 0.0% 0.0% [kmac/1] 117 0.0% 0.0% 0.0% [kipfs/1] 118 0.0% 0.0% 0.0% [kip6fs/1] 119 0.0% 0.0% 0.0% [ktcp_proxy/1/0] 120 0.0% 0.0% 0.0% [ktcp_proxy/1/1] 121 0.0% 0.0% 0.0% [ktcp_proxy/1/2] 122 0.0% 0.0% 0.0% [ktcp_proxy/1/32] 123 0.0% 0.0% 0.0% [ktcp_proxy/1/33] 124 0.0% 0.0% 0.0% [ktcp_proxy/1/34] 125 0.0% 0.0% 0.0% [sock/1] 126 0.0% 0.0% 0.0% [UFLT_KTHREAD1] 127 0.0% 0.0% 0.0% [kdrs] 129 0.0% 0.0% 0.0% cioctld 130 0.0% 0.0% 0.0% fsd 132 0.0% 0.0% 0.0% licd 133 0.0% 0.0% 0.0% dbmd 135 0.0% 0.0% 0.0% drvdiagd 136 0.2% 0.2% 0.2% diagd 138 0.0% 0.0% 0.0% had 139 0.0% 0.0% 0.0% syslogd 140 0.0% 0.0% 0.0% devd 143 0.0% 0.0% 0.0% ifmgr 144 0.0% 0.0% 0.0% edev 147 0.0% 0.0% 0.0% drvciud 156 0.0% 0.0% 0.0% moduleproxyd 157 0.0% 0.0% 0.0% ofcd 158 0.0% 0.0% 0.0% trackd 159 0.5% 0.5% 0.5% apmgrd 160 0.0% 0.0% 0.0% sysmand 161 0.0% 0.0% 0.0% lauthd 162 0.0% 0.0% 0.0% ttymgrd 163 0.0% 0.0% 0.0% aaad 164 0.0% 0.0% 0.0% laggd 165 0.0% 0.0% 0.0% tranged 166 0.0% 0.0% 0.0% vland 167 0.0% 0.0% 0.0% cryptomgrd 175 0.0% 0.0% 0.0% aclmgrd 190 0.0% 0.0% 0.0% qosd 193 0.0% 0.0% 0.0% ipcimd 194 0.0% 0.0% 0.0% ethd 195 0.0% 0.0% 0.0% coppd 199 0.0% 0.0% 0.0% comsh 204 0.2% 0.3% 0.2% stamgrd 213 0.0% 0.0% 0.0% maintaind 216 0.0% 0.0% 0.0% dnsd 218 0.0% 0.0% 0.0% pppd 219 0.0% 0.0% 0.0% appprofiled 220 0.0% 0.0% 0.0% aprd 221 0.0% 0.0% 0.0% cmtnlmgrd 223 0.0% 0.0% 0.0% ddrd 224 0.0% 0.0% 0.0% dhcpd 225 0.0% 0.0% 0.0% dhcpcd 226 0.0% 0.0% 0.0% dpid 227 0.1% 0.1% 0.6% drsd 228 0.0% 0.0% 0.0% httpd 229 0.0% 0.0% 0.0% ipstackd 230 0.0% 0.0% 0.0% lldpd 231 0.0% 0.0% 0.0% natd 232 0.0% 0.0% 0.0% nqad 233 0.0% 0.0% 0.0% nqasd 234 0.0% 0.0% 0.0% ntpd 235 0.0% 0.0% 0.0% portald 237 0.0% 0.0% 0.0% portsecd 238 0.0% 0.0% 0.0% routed 239 0.0% 0.1% 0.1% rrmd 240 0.0% 0.0% 0.0% sessiond 241 0.0% 0.0% 0.0% telnetd 242 0.0% 0.0% 0.0% telnetd 243 0.4% 0.2% 0.0% xmlcfgd 244 0.0% 0.0% 0.0% scheduler 253 0.0% 0.0% 0.0% staticrtd 257 0.0% 0.0% 0.0% [karp/1] 258 0.0% 0.0% 0.0% [kwadj/1] 259 0.0% 0.0% 0.0% [kfib/1] 289 0.0% 0.0% 0.0% [loop0] 292 0.0% 0.0% 0.0% [loop1] 295 0.0% 0.0% 0.0% [loop2] 297 0.0% 0.0% 0.0% [loop3] 300 0.0% 0.0% 0.0% [loop4] 1127 2.6% 0.2% 0.0% sshd 1141 6.3% 0.5% 0.1% comsh 1143 0.0% 0.0% 0.0% comsh 1145 0.0% 0.0% 0.0% gzip 1146 2.2% 0.2% 0.0% comsh ================================================================= ===============display kernel deadloop 20 verbose=============== No information to display. ================================================================= ===============display kernel exception 10 verbose=============== --------------------- Exception record 1 --------------------- Description : Kernel oops - Oops[#2]: Recorded at : 2021-01-25 14:05:53.937441 Occurred at : 2021-01-25 14:05:53.937441 Instruction address : 0xf1c772cc Thread : kdrvfwd7 (TID: 103) Context : thread context Slot : 1 Cpu : 0 VCPU ID : 7 Kernel module info : module name (system) module address (0xf1b52000) module name (addon) module address (0xf010c000) Last 5 thread switches : kdrvfwd7 (14:5:52.790557)--> watchdog/7 (14:5:53.180237)--> kdrvfwd7 (14:5:53.180252)--> events/7 (14:5:53.793192)--> kdrvfwd7 (14:5:53.793217) Register content: Reg: zero, Val = 0x00000000 ; Reg: at, Val = 0xb8004240 ; Reg: v0, Val = 0x00000000 ; Reg: v1, Val = 0x00000001 ; Reg: a0, Val = 0xe802b928 ; Reg: a1, Val = 0x00000000 ; Reg: a2, Val = 0x00000000 ; Reg: a3, Val = 0x00000006 ; Reg: t0, Val = 0x00000028 ; Reg: t1, Val = 0x801054e8 ; Reg: t2, Val = 0xffffffff ; Reg: t3, Val = 0xffff0000 ; Reg: t4, Val = 0x00030019 ; Reg: t5, Val = 0x00000000 ; Reg: t6, Val = 0x00000000 ; Reg: t7, Val = 0x0000ffe7 ; Reg: s0, Val = 0x00000001 ; Reg: s1, Val = 0x00000001 ; Reg: s2, Val = 0x0000ffff ; Reg: s3, Val = 0xf2fc6c24 ; Reg: s4, Val = 0xf2fcde08 ; Reg: s5, Val = 0xf2990000 ; Reg: s6, Val = 0xf2990000 ; Reg: s7, Val = 0xf1b6d590 ; Reg: t8, Val = 0x00000000 ; Reg: t9, Val = 0xf1cfce20 ; Reg: k0, Val = 0xd392f158 ; Reg: k1, Val = 0x00000000 ; Reg: gp, Val = 0xd3928000 ; Reg: sp, Val = 0xd392f180 ; Reg: s8/fp, Val = 0x00000000 ; Reg: ra, Val = 0xf1b67a50 ; Reg status, Val = 0x1000f803 ; Reg: hi, Val = 0x00000575 ; Reg: lo, Val = 0x91687777 ; Reg: badvaddr, Val = 0x00000004 ; Reg: cause, Val = 0x00800008 ; Reg: epc, Val = 0xf1c772cc ; Dump stack (total 1024 bytes, 16 bytes/line): 0xd392f180: f2 33 eb 00 f1 bc 33 3c f1 cf b0 14 f1 cf b9 78 0xd392f190: 80 16 8f 10 80 11 da 90 00 00 00 00 00 00 00 00 0xd392f1a0: 00 00 00 01 00 00 00 01 00 00 ff ff f2 fc 6c 24 0xd392f1b0: f1 b6 e3 60 f2 99 00 00 f2 99 00 00 f1 b6 d5 90 0xd392f1c0: 00 00 00 00 f1 b6 7a 50 00 00 00 28 80 10 54 e8 0xd392f1d0: ff ff ff ff 00 00 00 00 00 00 00 02 f2 99 42 80 0xd392f1e0: 00 00 00 00 00 00 00 01 00 00 ff ff 00 00 00 01 0xd392f1f0: 00 00 00 00 80 2a ff 88 80 40 1c 98 80 4c 00 00 0xd392f200: f3 00 f6 38 80 51 00 ac 80 51 00 90 82 07 0f c0 0xd392f210: 80 40 1c 98 80 4c 00 00 80 51 00 00 00 00 01 7a 0xd392f220: f3 02 b1 d8 f1 d7 5d fc 00 00 00 01 00 00 00 00 0xd392f230: d3 92 f3 58 f1 d6 e8 34 80 51 00 90 80 50 df c0 0xd392f240: 00 00 00 00 00 00 00 01 00 00 ff ff 00 00 00 01 0xd392f250: 80 51 00 00 80 12 22 94 82 07 26 28 00 00 00 00 0xd392f260: 00 00 00 04 80 40 1c 98 00 00 00 01 80 14 b8 40 0xd392f270: 5a 5a 5c 26 d3 92 f3 58 e8 17 5b 00 00 00 00 0b 0xd392f280: e1 fa 28 90 00 00 00 00 00 00 00 38 80 12 85 3c 0xd392f290: e8 25 aa 18 00 00 00 07 00 00 00 08 5a 5a 5c 26 0xd392f2a0: 00 00 00 08 f2 8f 24 1c 00 00 00 08 f2 8f 23 ec 0xd392f2b0: d3 92 f2 b0 00 03 00 01 f1 de f3 50 00 00 01 00 0xd392f2c0: 00 00 00 07 e8 25 ac 18 e8 25 ae 18 80 4c e3 80 0xd392f2d0: 82 07 26 28 d3 ed 40 00 80 4c e3 80 00 00 00 00 0xd392f2e0: 80 4c e3 80 80 4c 70 c8 00 00 00 10 00 00 00 0a 0xd392f2f0: 80 50 e5 94 80 50 db 00 80 51 00 90 80 15 42 88 0xd392f300: 00 00 00 00 80 4c 76 40 00 00 00 07 80 19 61 04 0xd392f310: 80 51 00 ac d3 ed 40 00 00 00 00 00 c0 5b be 40 0xd392f320: 00 00 00 00 d3 92 f4 c0 e1 fa 28 90 d3 92 f4 e4 0xd392f330: 00 00 00 00 d3 92 fd 40 c0 5b be 40 00 00 00 00 0xd392f340: d3 92 f4 c0 e1 fa 28 90 d3 92 f4 e4 00 00 00 00 0xd392f350: 00 00 01 7a 80 10 08 60 00 00 00 01 f2 4b ec b0 0xd392f360: d3 92 f3 c8 00 00 6e bc 00 00 6e bc d3 92 f4 50 0xd392f370: 00 00 00 00 b8 00 42 40 c3 44 66 04 5a 5a 5c 22 0xd392f380: 5a 5a 5a 5a 00 00 01 c0 00 00 17 50 d3 92 fd 40 0xd392f390: 00 00 b0 51 80 10 55 0c 00 00 00 00 00 00 00 00 0xd392f3a0: 00 00 00 01 00 00 00 00 00 00 43 ba 3f 13 3a be 0xd392f3b0: d3 92 fd 40 c0 5b be 40 00 00 00 00 d3 92 f4 c0 0xd392f3c0: e1 fa 28 90 d3 92 f4 e4 00 00 00 00 00 00 01 7a 0xd392f3d0: 00 00 00 00 f1 dc 27 80 d3 92 f4 e4 f2 8d 50 44 0xd392f3e0: d3 92 80 00 d3 92 f4 08 f3 02 b1 d8 f2 8f 23 ec 0xd392f3f0: 10 00 f8 03 00 00 00 03 1f 7f 0d c4 5a 5a 5c 26 0xd392f400: 00 80 00 08 f2 8f 24 1c f2 4c 7d bc 80 3a 3c 58 0xd392f410: 85 10 00 00 ca ef 79 ce 85 10 00 00 83 e0 cb d4 0xd392f420: 85 10 00 00 f2 4c 7d e4 86 a2 3b 80 ca ef 79 da 0xd392f430: ca ef 79 de ca ef 79 e2 ff ff ff ff 00 20 43 20 0xd392f440: 00 00 00 00 01 00 0a 0a 00 00 00 00 00 00 00 00 0xd392f450: 00 00 00 00 00 00 00 00 00 00 01 00 00 00 00 00 0xd392f460: 00 00 00 1f 00 00 00 07 00 00 00 07 00 00 00 00 0xd392f470: 00 00 00 00 ff ff ff ff 00 00 00 0e b4 43 26 52 0xd392f480: 21 50 90 5d 7c 18 dc f7 08 00 00 00 00 00 00 00 0xd392f490: c2 02 00 00 86 a2 3b 80 00 00 00 00 ca ef 79 ce 0xd392f4a0: 00 00 00 14 00 00 00 00 00 00 00 00 00 00 00 02 0xd392f4b0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0xd392f4c0: 00 18 00 00 00 00 0b 00 00 00 00 00 00 00 00 00 0xd392f4d0: 00 00 00 00 00 00 00 00 94 3b b0 51 17 50 d2 1b 0xd392f4e0: 62 76 30 c5 94 3b b0 51 17 50 00 00 00 00 00 00 0xd392f4f0: 00 00 3c 00 00 00 00 00 00 00 00 00 00 00 00 00 0xd392f500: 00 00 00 00 f2 1f 06 58 3d 8a 71 a9 00 00 00 00 0xd392f510: 00 00 00 00 00 00 00 05 86 a2 3b 80 ed 04 12 60 0xd392f520: c0 d0 40 00 00 00 00 52 d3 92 f5 90 d3 92 f5 88 0xd392f530: ca ef 79 ce ff ff ff ff ca ef 79 ce f2 1e 15 68 0xd392f540: 86 a2 3b 80 00 00 00 01 00 00 00 00 00 00 00 00 0xd392f550: d3 92 f5 90 00 00 00 00 86 a2 3b 80 ff ff ff ff 0xd392f560: f2 fb 00 00 00 00 00 00 ff ff ff ff 86 a2 3b 80 0xd392f570: 00 00 00 16 00 00 00 46 f2 fb f5 bc 00 00 00 07 Call trace: Function Address = 0xf1c772cc Function Address = 0xf1b67a50 Function Address = 0xf1d75dfc Function Address = 0x80122294 Function Address = 0x8012853c Function Address = 0x80100860 Function Address = 0xf28f241c Function Address = 0xf28f53e8 Function Address = 0xf2222644 Function Address = 0xf205914c Function Address = 0xf232cef0 Function Address = 0xf233e73c Function Address = 0xf233eb00 Function Address = 0xf1bc333c Function Address = 0xf1cfb014 Function Address = 0xf1cfb978 Function Address = 0x80168f10 Function Address = 0x8011da90 Instruction dump: afb50034 afb40030 afb3002c afb20028 afb10024 14600029 afb00020 3c14f2fd 24030001 2694de08 ac43e4f4 8e820014 <8c430004> 2402ffff 10620020 3c11f2fd --------------------- Exception record 2 --------------------- Description : Kernel oops - Oops[#1]: Recorded at : 2021-01-25 14:05:45.527067 Occurred at : 2021-01-25 14:05:45.527067 Instruction address : 0xf28f241c Thread : kdrvfwd7 (TID: 103) Context : thread context Slot : 1 Cpu : 0 VCPU ID : 7 Kernel module info : module name (system) module address (0xf1b52000) module name (addon) module address (0xf010c000) Last 5 thread switches : kdrvfwd7 (14:5:43.762516)--> watchdog/7 (14:5:44.583329)--> kdrvfwd7 (14:5:44.583340)--> events/7 (14:5:44.762984)--> kdrvfwd7 (14:5:44.763002) Register content: Reg: zero, Val = 0x00000000 ; Reg: at, Val = 0xb8004240 ; Reg: v0, Val = 0xc3446604 ; Reg: v1, Val = 0x5a5a5c22 ; Reg: a0, Val = 0x5a5a5a5a ; Reg: a1, Val = 0x000001c0 ; Reg: a2, Val = 0x00001750 ; Reg: a3, Val = 0xd392fd40 ; Reg: t0, Val = 0x0000b051 ; Reg: t1, Val = 0x8010550c ; Reg: t2, Val = 0x00000000 ; Reg: t3, Val = 0x00000000 ; Reg: t4, Val = 0x00000001 ; Reg: t5, Val = 0x00000000 ; Reg: t6, Val = 0x000043ba ; Reg: t7, Val = 0x3f133abe ; Reg: s0, Val = 0xd392fd40 ; Reg: s1, Val = 0xc05bbe40 ; Reg: s2, Val = 0x00000000 ; Reg: s3, Val = 0xd392f4c0 ; Reg: s4, Val = 0xe1fa2890 ; Reg: s5, Val = 0xd392f4e4 ; Reg: s6, Val = 0x00000000 ; Reg: s7, Val = 0x0000017a ; Reg: t8, Val = 0x00000000 ; Reg: t9, Val = 0xf1dc2780 ; Reg: k0, Val = 0xd392f4e4 ; Reg: k1, Val = 0xf28d5044 ; Reg: gp, Val = 0xd3928000 ; Reg: sp, Val = 0xd392f408 ; Reg: s8/fp, Val = 0xf302b1d8 ; Reg: ra, Val = 0xf28f23ec ; Reg status, Val = 0x1000f803 ; Reg: hi, Val = 0x00000003 ; Reg: lo, Val = 0x1f7f0dc4 ; Reg: badvaddr, Val = 0x5a5a5c26 ; Reg: cause, Val = 0x00800008 ; Reg: epc, Val = 0xf28f241c ; Dump stack (total 1024 bytes, 16 bytes/line): 0xd392f408: f2 4c 7d bc 80 3a 3c 58 85 10 00 00 ca ef 79 ce 0xd392f418: 85 10 00 00 83 e0 cb d4 85 10 00 00 f2 4c 7d e4 0xd392f428: 86 a2 3b 80 ca ef 79 da ca ef 79 de ca ef 79 e2 0xd392f438: ff ff ff ff 00 20 43 20 00 00 00 00 01 00 0a 0a 0xd392f448: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0xd392f458: 00 00 01 00 00 00 00 00 00 00 00 1f 00 00 00 07 0xd392f468: 00 00 00 07 00 00 00 00 00 00 00 00 ff ff ff ff 0xd392f478: 00 00 00 0e b4 43 26 52 21 50 90 5d 7c 18 dc f7 0xd392f488: 08 00 00 00 00 00 00 00 c2 02 00 00 86 a2 3b 80 0xd392f498: 00 00 00 00 ca ef 79 ce 00 00 00 14 00 00 00 00 0xd392f4a8: 00 00 00 00 00 00 00 02 00 00 00 00 00 00 00 00 0xd392f4b8: 00 00 00 00 00 00 00 00 00 18 00 00 00 00 0b 00 0xd392f4c8: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0xd392f4d8: 94 3b b0 51 17 50 d2 1b 62 76 30 c5 94 3b b0 51 0xd392f4e8: 17 50 00 00 00 00 00 00 00 00 3c 00 00 00 00 00 0xd392f4f8: 00 00 00 00 00 00 00 00 00 00 00 00 f2 1f 06 58 0xd392f508: 3d 8a 71 a9 00 00 00 00 00 00 00 00 00 00 00 05 0xd392f518: 86 a2 3b 80 ed 04 12 60 c0 d0 40 00 00 00 00 52 0xd392f528: d3 92 f5 90 d3 92 f5 88 ca ef 79 ce ff ff ff ff 0xd392f538: ca ef 79 ce f2 1e 15 68 86 a2 3b 80 00 00 00 01 0xd392f548: 00 00 00 00 00 00 00 00 d3 92 f5 90 00 00 00 00 0xd392f558: 86 a2 3b 80 ff ff ff ff f2 fb 00 00 00 00 00 00 0xd392f568: ff ff ff ff 86 a2 3b 80 00 00 00 16 00 00 00 46 0xd392f578: f2 fb f5 bc 00 00 00 07 00 00 00 01 f1 c7 1d 7c 0xd392f588: ed 04 12 60 00 00 00 00 c5 d5 35 28 c5 56 00 d0 0xd392f598: 00 00 09 c9 00 00 00 24 00 00 00 00 00 00 00 00 0xd392f5a8: 10 02 20 01 ff ff ff ff 00 00 00 00 01 ff 00 00 0xd392f5b8: 00 00 00 00 c5 6c 23 00 c5 6c 23 00 00 00 05 f3 0xd392f5c8: ff ff ff ff 00 00 00 07 00 02 00 00 3d 8a 71 a9 0xd392f5d8: 00 00 00 01 00 00 00 00 00 07 00 02 00 02 3d 8a 0xd392f5e8: 3d 8a 71 ae 00 00 00 00 00 00 00 00 00 00 00 00 0xd392f5f8: 00 00 20 01 00 00 00 00 00 08 00 00 1d 01 00 00 0xd392f608: ff ff ff ff 00 00 00 00 ff ff ff ff 00 00 00 00 0xd392f618: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0xd392f628: d3 59 fb 00 f2 08 bc f0 d3 92 f9 30 ed 04 12 60 0xd392f638: 00 00 00 00 ca ef 79 ce d3 59 f8 7c d3 92 fa 78 0xd392f648: 00 00 00 07 00 00 00 52 c0 d0 40 00 f2 21 ed dc 0xd392f658: 00 00 ed 9f c0 a8 00 2e d3 92 f6 90 00 00 00 11 0xd392f668: 00 00 00 01 f2 4b ec b0 d3 92 f6 d8 00 00 ed 9f 0xd392f678: 00 00 ed 9f f2 4b ed 58 00 08 55 d8 f1 bc 59 08 0xd392f688: ca ef 79 ce cc eb 62 f4 c0 a8 00 2e 00 00 ed 9f 0xd392f698: 00 00 00 01 11 00 00 00 00 00 00 00 06 00 c1 47 0xd392f6a8: 00 50 00 00 ce f0 dd 4e 00 00 00 00 f2 97 a2 d0 0xd392f6b8: c0 a8 00 2e f2 4b c4 20 00 00 00 00 00 00 00 00 0xd392f6c8: 00 00 00 00 00 00 00 36 00 00 00 01 00 00 00 02 0xd392f6d8: 00 00 00 00 00 00 00 01 85 10 00 00 c5 08 73 b0 0xd392f6e8: d3 92 fd 40 d3 92 fd 58 00 00 00 01 c5 25 ae 40 0xd392f6f8: 00 00 00 07 80 15 40 84 c5 08 74 44 f2 4c 69 b8 0xd392f708: 00 00 00 01 d3 92 f7 a0 85 10 00 00 f2 4c 66 44 0xd392f718: d3 92 fd 40 d3 92 fd 58 00 00 00 00 c5 25 ae 40 0xd392f728: 85 10 00 00 00 00 00 00 85 10 00 00 f2 4c 79 24 0xd392f738: d3 92 fd 58 ce f0 dd 4e d3 92 fd 40 d3 92 f7 88 0xd392f748: 00 00 00 14 d3 92 fd 40 00 00 01 c0 00 00 00 15 0xd392f758: f3 02 b1 d8 f2 8f 53 e8 83 c8 f6 60 d3 92 f8 00 0xd392f768: c0 15 00 00 d3 92 fd 40 d3 92 fd 40 00 00 00 00 0xd392f778: 00 00 00 13 c0 5b be 40 00 20 43 20 f2 1f 4c 20 0xd392f788: 00 00 01 bb d3 92 fd 58 00 00 00 00 d3 92 fd 40 0xd392f798: d3 92 fd 40 f1 f3 60 68 00 00 00 00 00 00 01 bb 0xd392f7a8: d3 92 fd 58 ed 04 00 00 83 c8 f6 60 ce f0 dd 4e 0xd392f7b8: ce f0 dd 4e d3 92 fd 40 00 00 01 c0 00 00 00 15 0xd392f7c8: f3 02 b1 d8 f2 22 26 44 00 00 00 15 d3 92 fd 40 0xd392f7d8: d3 59 f8 00 d3 92 f8 00 d3 92 fd 40 d3 92 fd 40 0xd392f7e8: ff ff ff ff c0 d4 00 00 00 00 00 00 f2 01 52 34 0xd392f7f8: d3 59 f8 00 c0 d0 40 00 ce f0 dd 4e 00 00 00 00 Call trace: Function Address = 0xf28f241c Function Address = 0xf28f53e8 Function Address = 0xf2222644 Function Address = 0xf205914c Function Address = 0xf232cef0 Function Address = 0xf233e73c Function Address = 0xf233eb00 Function Address = 0xf1bc333c Function Address = 0xf1cfb014 Function Address = 0xf1cfb978 Function Address = 0x80168f10 Function Address = 0x8011da90 Instruction dump: 1040018d 0040a021 8c420030 1040ff93 00000000 8c440028 1080ff90 02003821 8f830010 24630032 000318c0 00831821 <8c650004> 8c660000 24a20001 0045282b --------------------- Exception record 3 --------------------- Description : Kernel oops - Oops[#2]: Recorded at : 2020-03-11 09:24:06.177557 Occurred at : 2020-03-11 09:24:06.177557 Instruction address : 0xf19bca0c Thread : swapper (TID: 0) Context : irq context Slot : 1 Cpu : 0 VCPU ID : 0 Kernel module info : module name (system) module address (0xf1832000) module name (addon) module address (0xf010c000) Last 5 thread switches : swapper (9:24:6.60663)--> pppd (9:24:6.106776)--> swapper (9:24:6.106840)--> pppd (9:24:6.127543)--> swapper (9:24:6.127602) Register content: Reg: zero, Val = 0x00000000 ; Reg: at, Val = 0xb8004240 ; Reg: v0, Val = 0x00000000 ; Reg: v1, Val = 0x00000001 ; Reg: a0, Val = 0xd31b18a8 ; Reg: a1, Val = 0x00000000 ; Reg: a2, Val = 0x00000000 ; Reg: a3, Val = 0x00000006 ; Reg: t0, Val = 0x00000028 ; Reg: t1, Val = 0x801054e8 ; Reg: t2, Val = 0xffffffff ; Reg: t3, Val = 0xffff0000 ; Reg: t4, Val = 0x00030019 ; Reg: t5, Val = 0x00000000 ; Reg: t6, Val = 0x00000000 ; Reg: t7, Val = 0x0000ffe7 ; Reg: s0, Val = 0x00000001 ; Reg: s1, Val = 0x00000001 ; Reg: s2, Val = 0x0000ffff ; Reg: s3, Val = 0xf29cd5b0 ; Reg: s4, Val = 0xf29db8e8 ; Reg: s5, Val = 0xf25d0000 ; Reg: s6, Val = 0xf25d0000 ; Reg: s7, Val = 0xf184d1b0 ; Reg: t8, Val = 0x00000000 ; Reg: t9, Val = 0xf192d2f0 ; Reg: k0, Val = 0x80467d50 ; Reg: k1, Val = 0x00000000 ; Reg: gp, Val = 0x80460000 ; Reg: sp, Val = 0x80467d78 ; Reg: s8/fp, Val = 0x00000000 ; Reg: ra, Val = 0xf1847670 ; Reg status, Val = 0x5000f803 ; Reg: hi, Val = 0x00000575 ; Reg: lo, Val = 0x91687777 ; Reg: badvaddr, Val = 0x00000004 ; Reg: cause, Val = 0x00800008 ; Reg: epc, Val = 0xf19bca0c ; Dump stack (total 1024 bytes, 16 bytes/line): 0x80467d78: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x80467d88: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x80467d98: 00 00 00 01 00 00 00 01 00 00 ff ff f2 9c d5 b0 0x80467da8: f1 84 df 80 f2 5d 00 00 f2 5d 00 00 f1 84 d1 b0 0x80467db8: 00 00 00 00 f1 84 76 70 00 00 00 28 80 10 54 e8 0x80467dc8: ff ff ff ff 00 00 00 00 00 00 00 02 f2 5d 59 18 0x80467dd8: 00 00 00 00 00 00 00 01 00 00 ff ff 00 00 00 01 0x80467de8: 00 00 00 00 80 2a ff 38 80 40 1c 38 80 4c 00 00 0x80467df8: f2 a1 5d e8 80 51 00 70 80 51 00 70 82 04 df c0 0x80467e08: 80 40 1c 38 80 4c 00 00 80 51 00 00 80 51 00 70 0x80467e18: 80 51 00 00 f1 a6 64 cc 00 00 00 01 00 00 00 00 0x80467e28: 80 46 7e c0 f1 a5 ef 04 80 51 00 70 80 50 df c0 0x80467e38: 00 00 00 00 00 00 00 01 00 00 ff ff 00 00 00 01 0x80467e48: 80 51 00 00 80 12 22 44 00 00 00 10 00 00 00 00 0x80467e58: 00 00 00 04 80 40 1c 38 00 00 00 01 80 14 b7 f0 0x80467e68: 80 46 7e c0 80 10 0a a0 00 00 50 00 82 07 50 00 0x80467e78: 80 51 67 40 80 50 d0 00 00 00 25 c0 80 12 33 78 0x80467e88: 00 00 50 00 ec 86 1a 00 80 51 51 80 bf ff 00 fe 0x80467e98: 00 00 25 c0 00 00 00 00 80 51 67 40 80 15 43 b8 0x80467ea8: 50 00 f8 03 80 51 00 00 80 51 67 40 00 00 50 00 0x80467eb8: 82 07 50 00 80 10 0f e0 00 00 00 00 80 2e 90 30 0x80467ec8: 80 46 80 00 ec 86 1a 00 5e 68 3d b6 00 01 f2 37 0x80467ed8: 00 00 00 00 80 51 00 00 80 10 0a 80 80 46 00 08 0x80467ee8: 80 5a 00 00 ec 86 1a 00 80 51 51 80 bf ff 00 fe 0x80467ef8: 00 00 00 00 00 00 00 00 00 00 00 00 c1 7f 00 00 0x80467f08: 00 00 00 a9 00 00 00 00 00 00 00 b5 00 a8 91 a7 0x80467f18: 80 51 00 00 80 51 67 40 00 00 50 00 82 07 50 00 0x80467f28: 80 51 67 40 80 50 d0 00 00 00 25 c0 80 51 00 70 0x80467f38: 00 00 00 00 f1 90 a3 e0 00 00 00 00 00 00 00 00 0x80467f48: 80 46 00 00 80 46 7f 70 80 51 00 00 80 11 d9 34 0x80467f58: 50 48 f8 05 00 00 00 01 33 33 33 35 80 51 00 70 0x80467f68: 00 80 00 00 80 10 0a a0 80 4d 55 70 00 00 00 01 0x80467f78: 00 00 00 00 80 55 00 00 80 55 00 00 80 4e 0e 84 0x80467f88: 00 00 00 00 00 00 00 01 00 00 00 00 ff ff ff ff 0x80467f98: 80 4e 12 e8 00 00 00 00 80 51 49 50 00 00 00 00 0x80467fa8: 82 10 00 00 82 14 00 00 82 14 00 00 00 00 00 00 0x80467fb8: 00 00 00 00 82 14 60 10 8c 01 f8 98 8c 08 52 50 0x80467fc8: 00 00 00 02 82 10 13 a0 00 00 00 00 00 00 00 00 0x80467fd8: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x80467fe8: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x80467ff8: 00 00 00 00 00 00 00 00 00 00 00 00 80 46 00 00 0x80468008: 00 00 00 02 00 00 00 00 00 00 00 00 ff ff ff ff 0x80468018: 00 00 00 01 00 00 00 8c 00 00 00 78 00 00 00 8c 0x80468028: 80 40 87 3c 00 00 00 00 00 00 04 00 00 40 00 00 0x80468038: 00 00 00 00 00 00 00 00 00 00 00 00 80 46 80 44 0x80468048: 80 46 80 44 00 00 00 00 00 00 00 00 00 00 00 00 0x80468058: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x80468068: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x80468078: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x80468088: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x80468098: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x804680a8: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x804680b8: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x804680c8: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x804680d8: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x804680e8: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x804680f8: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x80468108: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x80468118: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x80468128: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x80468138: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x80468148: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x80468158: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x80468168: 00 00 00 00 82 04 f0 00 00 00 00 00 00 00 00 00 Call trace: Function Address = 0xf19bca0c Function Address = 0xf1847670 Function Address = 0xf1a664cc Function Address = 0x80122244 Function Address = 0x80123378 Function Address = 0x80100fe0 Instruction dump: afb50034 afb40030 afb3002c afb20028 afb10024 14600029 afb00020 3c14f29e 24030001 2694b8e8 ac43bfdc 8e820014 <8c430004> 2402ffff 10620020 3c11f29e --------------------- Exception record 4 --------------------- Description : Kernel oops - NMI[#1]: Recorded at : 2020-03-11 09:24:06.170582 Occurred at : 2020-03-11 09:24:06.170582 Instruction address : 0x80100aa0 Thread : swapper (TID: 0) Context : thread context Slot : 1 Cpu : 0 VCPU ID : 0 Kernel module info : module name (system) module address (0xf1832000) module name (addon) module address (0xf010c000) Last 5 thread switches : swapper (9:24:6.60663)--> pppd (9:24:6.106776)--> swapper (9:24:6.106840)--> pppd (9:24:6.127543)--> swapper (9:24:6.127602) Register content: Reg: zero, Val = 0x00000000 ; Reg: at, Val = 0x80510000 ; Reg: v0, Val = 0x80100a80 ; Reg: v1, Val = 0x80460008 ; Reg: a0, Val = 0x805a0000 ; Reg: a1, Val = 0xec861a00 ; Reg: a2, Val = 0x80515180 ; Reg: a3, Val = 0xbfff00fe ; Reg: t0, Val = 0x00000000 ; Reg: t1, Val = 0x00000000 ; Reg: t2, Val = 0x00000000 ; Reg: t3, Val = 0xc17f0000 ; Reg: t4, Val = 0x000000a9 ; Reg: t5, Val = 0x00000000 ; Reg: t6, Val = 0x000000b5 ; Reg: t7, Val = 0x00a891a7 ; Reg: s0, Val = 0x80510000 ; Reg: s1, Val = 0x80516740 ; Reg: s2, Val = 0x00005000 ; Reg: s3, Val = 0x82075000 ; Reg: s4, Val = 0x80516740 ; Reg: s5, Val = 0x8050d000 ; Reg: s6, Val = 0x000025c0 ; Reg: s7, Val = 0x80510070 ; Reg: t8, Val = 0x00000000 ; Reg: t9, Val = 0xf190a3e0 ; Reg: k0, Val = 0x00000000 ; Reg: k1, Val = 0x00000000 ; Reg: gp, Val = 0x80460000 ; Reg: sp, Val = 0x80467f70 ; Reg: s8/fp, Val = 0x80510000 ; Reg: ra, Val = 0x8011d934 ; Reg status, Val = 0x5048f805 ; Reg: hi, Val = 0x00000001 ; Reg: lo, Val = 0x33333335 ; Reg: badvaddr, Val = 0x80510070 ; Reg: cause, Val = 0x00800000 ; Reg: epc, Val = 0x80100aa0 ; Dump stack (total 1024 bytes, 16 bytes/line): 0x80467f70: 80 4d 55 70 00 00 00 01 00 00 00 00 80 55 00 00 0x80467f80: 80 55 00 00 80 4e 0e 84 00 00 00 00 00 00 00 01 0x80467f90: 00 00 00 00 ff ff ff ff 80 4e 12 e8 00 00 00 00 0x80467fa0: 80 51 49 50 00 00 00 00 82 10 00 00 82 14 00 00 0x80467fb0: 82 14 00 00 00 00 00 00 00 00 00 00 82 14 60 10 0x80467fc0: 8c 01 f8 98 8c 08 52 50 00 00 00 02 82 10 13 a0 0x80467fd0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x80467fe0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x80467ff0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x80468000: 00 00 00 00 80 46 00 00 00 00 00 02 00 00 00 00 0x80468010: 00 00 00 00 ff ff ff ff 00 00 00 01 00 00 00 8c 0x80468020: 00 00 00 78 00 00 00 8c 80 40 87 3c 00 00 00 00 0x80468030: 00 00 04 00 00 40 00 00 00 00 00 00 00 00 00 00 0x80468040: 00 00 00 00 80 46 80 44 80 46 80 44 00 00 00 00 0x80468050: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x80468060: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x80468070: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x80468080: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x80468090: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x804680a0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x804680b0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x804680c0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x804680d0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x804680e0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x804680f0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x80468100: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x80468110: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x80468120: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x80468130: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x80468140: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x80468150: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x80468160: 00 00 00 00 00 00 00 00 00 00 00 00 82 04 f0 00 0x80468170: 00 00 00 00 00 00 00 00 80 46 81 78 80 46 81 78 0x80468180: 00 00 03 e8 00 00 00 00 00 00 00 20 00 00 00 00 0x80468190: 00 00 00 00 00 00 00 00 00 00 00 01 00 00 00 00 0x804681a0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x804681b0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x804681c0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x804681d0: e8 04 01 d0 eb d0 a8 d0 80 46 81 d8 80 46 81 d8 0x804681e0: 80 46 81 e0 80 46 81 e0 00 00 00 00 d3 38 63 00 0x804681f0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x80468200: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x80468210: 00 00 00 00 80 46 80 00 80 46 80 00 e8 04 02 24 0x80468220: e8 04 08 a4 80 46 82 24 80 46 82 24 80 46 80 00 0x80468230: 00 00 00 00 80 4c cf 14 80 4c cf 10 00 00 00 00 0x80468240: e8 04 08 bc 80 4c cf 10 00 00 00 00 e8 04 08 c8 0x80468250: 80 4c cf 10 00 00 00 00 00 00 00 00 00 00 00 00 0x80468260: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x80468270: 00 02 21 39 00 00 00 00 00 02 21 39 00 00 00 00 0x80468280: 00 00 00 00 00 00 00 00 00 00 00 00 00 01 d3 54 0x80468290: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x804682a0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x804682b0: 00 00 00 00 00 00 00 00 80 46 82 b8 80 46 82 b8 0x804682c0: 80 46 82 c0 80 46 82 c0 80 46 82 c8 80 46 82 c8 0x804682d0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x804682e0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x804682f0: 80 4c cc 24 ff ff ff ff ff ff ff ff 00 00 00 00 0x80468300: 00 00 00 00 ff ff ff ff ff ff ff ff ff ff ff ff 0x80468310: ff ff ff ff 00 00 00 00 80 4c cb bc 73 77 61 70 0x80468320: 70 65 72 00 00 00 00 00 00 00 00 00 00 00 00 00 0x80468330: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x80468340: 80 46 80 00 ec 86 1a 00 82 04 ef c0 80 51 00 70 0x80468350: 80 50 ef c0 80 51 51 80 80 46 82 8c 80 50 ef c0 0x80468360: 80 46 7e e8 00 00 00 01 80 3a 06 d0 50 00 f8 00 Call trace: Function Address = 0x80100aa0 Function Address = 0x8011d934 Instruction dump: 00000000 00000000 00000000 00000000 8f880008 00000000 31080004 15000004 00000000 00000000 00000000 42000020 <03e00008> 00000000 00000000 00000000 --------------------- Exception record 5 --------------------- Description : Kernel oops - Oops[#2]: Recorded at : 2022-12-04 04:39:42.588608 Occurred at : 2022-12-04 04:39:42.588608 Instruction address : 0xf19bca0c Thread : swapper (TID: 0) Context : irq context Slot : 1 Cpu : 0 VCPU ID : 0 Kernel module info : module name (system) module address (0xf1832000) module name (addon) module address (0xf010c000) Last 5 thread switches : swapper (4:39:42.560200)--> nqad (4:39:42.570160)--> swapper (4:39:42.570200)--> nqad (4:39:42.580160)--> swapper (4:39:42.580200) Register content: Reg: zero, Val = 0x00000000 ; Reg: at, Val = 0xb8004240 ; Reg: v0, Val = 0x00000000 ; Reg: v1, Val = 0x00000001 ; Reg: a0, Val = 0xe833b928 ; Reg: a1, Val = 0x00000000 ; Reg: a2, Val = 0x00000000 ; Reg: a3, Val = 0x00000006 ; Reg: t0, Val = 0x00000028 ; Reg: t1, Val = 0x801054e8 ; Reg: t2, Val = 0xffffffff ; Reg: t3, Val = 0xffff0000 ; Reg: t4, Val = 0x00030019 ; Reg: t5, Val = 0x00000000 ; Reg: t6, Val = 0x00000000 ; Reg: t7, Val = 0x0000ffe7 ; Reg: s0, Val = 0x00000001 ; Reg: s1, Val = 0x00000001 ; Reg: s2, Val = 0x0000ffff ; Reg: s3, Val = 0xf29cd5b0 ; Reg: s4, Val = 0xf29db8e8 ; Reg: s5, Val = 0xf25d0000 ; Reg: s6, Val = 0xf25d0000 ; Reg: s7, Val = 0xf184d1b0 ; Reg: t8, Val = 0x00000000 ; Reg: t9, Val = 0xf192d2f0 ; Reg: k0, Val = 0x80467d50 ; Reg: k1, Val = 0x00000000 ; Reg: gp, Val = 0x80460000 ; Reg: sp, Val = 0x80467d78 ; Reg: s8/fp, Val = 0x00000000 ; Reg: ra, Val = 0xf1847670 ; Reg status, Val = 0x1000f803 ; Reg: hi, Val = 0x00000575 ; Reg: lo, Val = 0x91687777 ; Reg: badvaddr, Val = 0x00000004 ; Reg: cause, Val = 0x00800008 ; Reg: epc, Val = 0xf19bca0c ; Dump stack (total 1024 bytes, 16 bytes/line): 0x80467d78: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x80467d88: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x80467d98: 00 00 00 01 00 00 00 01 00 00 ff ff f2 9c d5 b0 0x80467da8: f1 84 df 80 f2 5d 00 00 f2 5d 00 00 f1 84 d1 b0 0x80467db8: 00 00 00 00 f1 84 76 70 00 00 00 28 80 10 54 e8 0x80467dc8: ff ff ff ff 00 00 00 00 00 00 00 02 f2 5d 59 18 0x80467dd8: 00 00 00 00 00 00 00 01 00 00 ff ff 00 00 00 01 0x80467de8: 00 00 00 00 80 2a ff 38 80 40 1c 38 80 4c 00 00 0x80467df8: f2 a1 5d e8 80 51 00 70 80 51 00 70 82 04 df c0 0x80467e08: 80 40 1c 38 80 4c 00 00 80 51 00 00 80 51 00 70 0x80467e18: 80 51 00 00 f1 a6 64 cc 00 00 00 01 00 00 00 00 0x80467e28: 80 46 7e c0 f1 a5 ef 04 80 51 00 70 80 50 df c0 0x80467e38: 00 00 00 00 00 00 00 01 00 00 ff ff 00 00 00 01 0x80467e48: 80 51 00 00 80 12 22 44 00 00 00 10 00 00 00 00 0x80467e58: 00 00 00 04 80 40 1c 38 00 00 00 01 80 14 b7 f0 0x80467e68: 80 46 7e c0 80 10 0a a0 00 00 50 00 82 07 50 00 0x80467e78: 80 51 67 40 80 50 d0 00 00 00 25 c0 80 12 33 78 0x80467e88: 00 00 50 00 eb 48 e8 00 80 51 51 80 bf ff 00 fe 0x80467e98: 00 00 25 c0 00 00 00 00 80 51 67 40 80 15 43 b8 0x80467ea8: 80 4d 00 00 80 51 00 00 80 51 67 40 00 00 50 00 0x80467eb8: 82 07 50 00 80 10 0f e0 00 00 00 00 80 2e 90 30 0x80467ec8: 80 46 80 00 eb 48 e8 00 63 8b b4 0e 00 08 da 40 0x80467ed8: 00 00 00 00 80 51 00 00 80 10 0a 80 80 46 00 08 0x80467ee8: 80 5a 00 00 eb 48 e8 00 80 51 51 80 bf ff 00 fe 0x80467ef8: 00 00 00 00 00 00 00 00 00 00 00 00 eb 7e 00 00 0x80467f08: 00 00 02 38 00 00 00 00 00 00 02 62 02 38 1a f6 0x80467f18: 80 51 00 00 80 51 67 40 00 00 50 00 82 07 50 00 0x80467f28: 80 51 67 40 80 50 d0 00 00 00 25 c0 80 51 00 70 0x80467f38: 00 00 00 00 f1 90 a3 e0 00 00 00 00 00 00 00 00 0x80467f48: 80 46 00 00 80 46 7f 70 80 51 00 00 80 11 d9 34 0x80467f58: 10 48 f8 05 00 00 00 02 00 00 00 03 80 51 00 70 0x80467f68: 00 80 00 00 80 10 0a a0 80 4d 55 70 00 00 00 01 0x80467f78: 00 00 00 00 80 55 00 00 80 55 00 00 80 4e 0e 84 0x80467f88: 00 00 00 00 00 00 00 01 00 00 00 00 ff ff ff ff 0x80467f98: 80 4e 12 e8 00 00 00 00 80 51 49 50 00 00 00 00 0x80467fa8: 82 10 00 00 82 14 00 00 82 14 00 00 00 00 00 00 0x80467fb8: 00 00 00 00 82 14 60 10 8c 01 f8 98 8c 08 52 50 0x80467fc8: 00 00 00 02 82 10 13 a0 00 00 00 00 00 00 00 00 0x80467fd8: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x80467fe8: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x80467ff8: 00 00 00 00 00 00 00 00 00 00 00 00 80 46 00 00 0x80468008: 00 00 00 02 00 00 00 00 00 00 00 00 ff ff ff ff 0x80468018: 00 00 00 01 00 00 00 8c 00 00 00 78 00 00 00 8c 0x80468028: 80 40 87 3c 00 00 00 00 00 00 04 00 00 40 00 00 0x80468038: 00 00 00 00 00 00 00 00 00 00 00 00 80 46 80 44 0x80468048: 80 46 80 44 00 00 00 00 00 00 00 00 00 00 00 00 0x80468058: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x80468068: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x80468078: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x80468088: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x80468098: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x804680a8: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x804680b8: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x804680c8: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x804680d8: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x804680e8: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x804680f8: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x80468108: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x80468118: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x80468128: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x80468138: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x80468148: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x80468158: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x80468168: 00 00 00 00 82 04 f0 00 00 00 00 00 00 00 00 00 Call trace: Function Address = 0xf19bca0c Function Address = 0xf1847670 Function Address = 0xf1a664cc Function Address = 0x80122244 Function Address = 0x80123378 Function Address = 0x80100fe0 Instruction dump: afb50034 afb40030 afb3002c afb20028 afb10024 14600029 afb00020 3c14f29e 24030001 2694b8e8 ac43bfdc 8e820014 <8c430004> 2402ffff 10620020 3c11f29e --------------------- Exception record 6 --------------------- Description : Kernel oops - NMI[#1]: Recorded at : 2022-12-04 04:39:42.581639 Occurred at : 2022-12-04 04:39:42.581639 Instruction address : 0x80100aa0 Thread : swapper (TID: 0) Context : thread context Slot : 1 Cpu : 0 VCPU ID : 0 Kernel module info : module name (system) module address (0xf1832000) module name (addon) module address (0xf010c000) Last 5 thread switches : swapper (4:39:42.560200)--> nqad (4:39:42.570160)--> swapper (4:39:42.570200)--> nqad (4:39:42.580160)--> swapper (4:39:42.580200) Register content: Reg: zero, Val = 0x00000000 ; Reg: at, Val = 0x80510000 ; Reg: v0, Val = 0x80100a80 ; Reg: v1, Val = 0x80460008 ; Reg: a0, Val = 0x805a0000 ; Reg: a1, Val = 0xeb48e800 ; Reg: a2, Val = 0x80515180 ; Reg: a3, Val = 0xbfff00fe ; Reg: t0, Val = 0x00000000 ; Reg: t1, Val = 0x00000000 ; Reg: t2, Val = 0x00000000 ; Reg: t3, Val = 0xeb7e0000 ; Reg: t4, Val = 0x00000238 ; Reg: t5, Val = 0x00000000 ; Reg: t6, Val = 0x00000262 ; Reg: t7, Val = 0x02381af6 ; Reg: s0, Val = 0x80510000 ; Reg: s1, Val = 0x80516740 ; Reg: s2, Val = 0x00005000 ; Reg: s3, Val = 0x82075000 ; Reg: s4, Val = 0x80516740 ; Reg: s5, Val = 0x8050d000 ; Reg: s6, Val = 0x000025c0 ; Reg: s7, Val = 0x80510070 ; Reg: t8, Val = 0x00000000 ; Reg: t9, Val = 0xf190a3e0 ; Reg: k0, Val = 0x00000000 ; Reg: k1, Val = 0x00000000 ; Reg: gp, Val = 0x80460000 ; Reg: sp, Val = 0x80467f70 ; Reg: s8/fp, Val = 0x80510000 ; Reg: ra, Val = 0x8011d934 ; Reg status, Val = 0x1048f805 ; Reg: hi, Val = 0x00000002 ; Reg: lo, Val = 0x00000003 ; Reg: badvaddr, Val = 0x80510070 ; Reg: cause, Val = 0x00800000 ; Reg: epc, Val = 0x80100aa0 ; Dump stack (total 1024 bytes, 16 bytes/line): 0x80467f70: 80 4d 55 70 00 00 00 01 00 00 00 00 80 55 00 00 0x80467f80: 80 55 00 00 80 4e 0e 84 00 00 00 00 00 00 00 01 0x80467f90: 00 00 00 00 ff ff ff ff 80 4e 12 e8 00 00 00 00 0x80467fa0: 80 51 49 50 00 00 00 00 82 10 00 00 82 14 00 00 0x80467fb0: 82 14 00 00 00 00 00 00 00 00 00 00 82 14 60 10 0x80467fc0: 8c 01 f8 98 8c 08 52 50 00 00 00 02 82 10 13 a0 0x80467fd0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x80467fe0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x80467ff0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x80468000: 00 00 00 00 80 46 00 00 00 00 00 02 00 00 00 00 0x80468010: 00 00 00 00 ff ff ff ff 00 00 00 01 00 00 00 8c 0x80468020: 00 00 00 78 00 00 00 8c 80 40 87 3c 00 00 00 00 0x80468030: 00 00 04 00 00 40 00 00 00 00 00 00 00 00 00 00 0x80468040: 00 00 00 00 80 46 80 44 80 46 80 44 00 00 00 00 0x80468050: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x80468060: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x80468070: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x80468080: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x80468090: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x804680a0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x804680b0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x804680c0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x804680d0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x804680e0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x804680f0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x80468100: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x80468110: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x80468120: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x80468130: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x80468140: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x80468150: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x80468160: 00 00 00 00 00 00 00 00 00 00 00 00 82 04 f0 00 0x80468170: 00 00 00 00 00 00 00 00 80 46 81 78 80 46 81 78 0x80468180: 00 00 03 e8 00 00 00 00 00 00 00 20 00 00 00 00 0x80468190: 00 00 00 00 00 00 00 00 00 00 00 01 00 00 00 00 0x804681a0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x804681b0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x804681c0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x804681d0: e8 04 01 d0 c2 20 d6 50 80 46 81 d8 80 46 81 d8 0x804681e0: 80 46 81 e0 80 46 81 e0 00 00 00 00 d3 37 d6 80 0x804681f0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x80468200: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x80468210: 00 00 00 00 80 46 80 00 80 46 80 00 e8 04 02 24 0x80468220: e8 04 08 a4 80 46 82 24 80 46 82 24 80 46 80 00 0x80468230: 00 00 00 00 80 4c cf 14 80 4c cf 10 00 00 00 00 0x80468240: e8 04 08 bc 80 4c cf 10 00 00 00 00 e8 04 08 c8 0x80468250: 80 4c cf 10 00 00 00 00 00 00 00 00 00 00 00 00 0x80468260: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x80468270: 00 07 87 ac 00 00 00 00 00 07 87 ac 00 00 00 00 0x80468280: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 75 c2 0x80468290: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x804682a0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x804682b0: 00 00 00 00 00 00 00 00 80 46 82 b8 80 46 82 b8 0x804682c0: 80 46 82 c0 80 46 82 c0 80 46 82 c8 80 46 82 c8 0x804682d0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x804682e0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x804682f0: 80 4c cc 24 ff ff ff ff ff ff ff ff 00 00 00 00 0x80468300: 00 00 00 00 ff ff ff ff ff ff ff ff ff ff ff ff 0x80468310: ff ff ff ff 00 00 00 00 80 4c cb bc 73 77 61 70 0x80468320: 70 65 72 00 00 00 00 00 00 00 00 00 00 00 00 00 0x80468330: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x80468340: 80 46 80 00 eb 48 e8 00 82 04 ef c0 80 51 00 70 0x80468350: 80 50 ef c0 80 51 51 80 80 46 82 8c 80 50 ef c0 0x80468360: 80 46 7e e8 00 00 00 01 80 3a 06 d0 10 00 f8 00 Call trace: Function Address = 0x80100aa0 Function Address = 0x8011d934 Instruction dump: 00000000 00000000 00000000 00000000 8f880008 00000000 31080004 15000004 00000000 00000000 00000000 42000020 <03e00008> 00000000 00000000 00000000 ================================================================= ===============display kernel reboot 20 verbose =============== --------------------- Reboot record 1 --------------------- Recorded at : 2022-03-19 09:25:52.955228 Occurred at : 2022-03-19 09:25:52.955228 Reason : 0xb Thread : diagd (TID: 136) Context : thread context Slot : 1 Cpu : 0 VCPU ID : 2 Kernel module info : module name (system) module address (0xf1b52000) module name (addon) module address (0xf010c000) Last 5 thread switches : dhcpd (9:25:52.953711)--> dhcpd (9:25:52.953759)--> nqad (9:25:52.953794)--> kmac/1 (9:25:52.953827)--> diagd (9:25:52.954810) Dump stack (total 1024 bytes, 16 bytes/line): 0xed12fb70: 00 00 00 04 f2 9a ad d4 f2 9a bb 7c 00 00 00 01 0xed12fb80: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0xed12fb90: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0xed12fba0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0xed12fbb0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0xed12fbc0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0xed12fbd0: 00 00 00 00 ed 12 fc 20 80 51 00 98 e8 03 21 00 0xed12fbe0: 00 00 00 0b 80 50 de e0 01 b4 a0 00 80 17 49 e8 0xed12fbf0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0xed12fc00: 62 35 31 20 38 ef a0 96 00 00 00 01 80 17 38 a8 0xed12fc10: 00 00 00 00 80 12 06 1c 00 00 00 00 00 00 00 00 0xed12fc20: 62 35 31 20 00 0e 93 5c 80 54 00 00 ed 12 fb 70 0xed12fc30: 00 00 00 02 80 17 3e 14 f1 b6 e3 60 f2 99 00 00 0xed12fc40: f2 99 00 00 00 00 00 01 ec b4 ae 00 81 f9 4b 08 0xed12fc50: 80 4d 2e 50 f1 b8 4f 30 f2 99 a0 54 80 1c f0 94 0xed12fc60: ff ff ff ff ff ff ff ff ec b4 ae 00 f1 b6 e3 60 0xed12fc70: 00 00 00 32 f2 9a 00 00 ec b4 ae 00 f1 b6 e3 60 0xed12fc80: f2 9a 00 00 f2 9a 00 00 f1 b6 d5 90 f1 b8 4f 30 0xed12fc90: f2 99 00 00 f1 b6 d5 90 00 00 00 00 00 00 00 06 0xed12fca0: 00 00 00 04 f2 99 a0 54 00 00 ff ff 00 00 00 0b 0xed12fcb0: 00 00 00 01 00 00 ff ff f2 fc 6c 24 f1 b6 e3 60 0xed12fcc0: f2 99 00 00 f1 b6 78 40 80 4d 29 40 00 00 00 42 0xed12fcd0: 00 00 00 00 00 00 00 00 00 00 00 02 f2 99 42 80 0xed12fce0: 00 00 00 00 00 00 00 01 00 00 ff ff 00 00 00 0b 0xed12fcf0: 00 00 00 00 00 00 00 c8 80 55 00 00 80 1d 75 00 0xed12fd00: f3 00 f6 38 00 00 00 03 80 4d 00 00 00 00 00 00 0xed12fd10: 80 4d 29 40 00 00 00 00 00 00 00 00 00 00 00 00 0xed12fd20: 00 00 00 10 f1 d7 5d fc 00 00 00 01 00 00 00 d0 0xed12fd30: 00 00 00 03 f1 d6 e8 34 00 00 00 48 80 4d 00 00 0xed12fd40: 00 00 00 00 00 00 00 01 00 00 ff ff 00 00 00 0b 0xed12fd50: 00 00 00 d0 80 1a 43 4c 00 00 00 00 00 00 00 00 0xed12fd60: 00 00 00 01 80 18 31 38 e8 0c 06 80 00 00 00 03 0xed12fd70: 00 00 00 00 00 00 00 00 e8 0c 06 80 00 00 00 03 0xed12fd80: 00 00 00 d0 00 00 00 00 80 4d 29 40 80 1a 7f 9c 0xed12fd90: 00 02 00 d0 00 00 00 00 81 f9 80 40 e8 02 16 80 0xed12fda0: 00 00 00 00 00 00 00 48 00 00 00 00 00 00 00 00 0xed12fdb0: 00 00 00 00 00 00 00 00 00 00 00 01 00 00 00 00 0xed12fdc0: 00 00 00 00 00 00 00 08 00 02 00 d0 ff ff 2c 76 0xed12fdd0: 80 4d 29 44 00 00 00 80 80 4d 29 44 00 00 00 00 0xed12fde0: ec c5 00 00 01 20 00 12 7f ca e6 a8 ed 12 ff 30 0xed12fdf0: 00 00 00 00 e8 0c 06 80 80 52 00 00 00 00 00 00 0xed12fe00: 72 2d b3 78 80 1a 80 5c 01 20 00 12 01 20 00 12 0xed12fe10: 7f ca e6 a8 ed 12 ff 30 00 00 00 00 80 14 94 68 0xed12fe20: 00 00 80 d0 80 1c e6 6c 80 1d c0 44 00 00 00 90 0xed12fe30: 80 4d 45 3c 86 a4 c0 00 80 4d 00 00 85 3a 82 40 0xed12fe40: e8 02 22 80 00 00 80 d0 00 00 00 01 00 00 00 b0 0xed12fe50: 00 00 00 00 72 1c 47 f8 01 20 00 12 00 00 00 00 0xed12fe60: 7f ca e6 a8 ed 12 ff 30 00 00 00 00 72 1c 47 f8 0xed12fe70: 72 1c 47 f0 7f ca eb c8 7f ca e7 08 80 14 a5 f4 0xed12fe80: 80 1d c0 44 80 1e 31 84 86 a4 c0 00 e8 05 63 c0 0xed12fe90: 72 2d b3 78 00 00 00 00 00 00 00 00 e8 05 64 00 0xed12fea0: e8 05 63 c0 00 00 00 0f 86 a4 c1 00 72 1c 47 f8 0xed12feb0: 72 1c 47 f0 7f ca eb c8 00 00 00 01 80 1d 77 84 0xed12fec0: 00 00 00 00 80 1e 2d e4 62 35 31 1d 7f ca e6 e8 0xed12fed0: 72 2d b3 10 00 00 00 88 7f ca e6 f8 72 2d b7 54 0xed12fee0: 72 1c 47 f8 80 14 a8 a0 e9 2f a9 00 7f ca ea d0 0xed12fef0: 00 00 00 80 80 1d b2 0c 00 00 00 00 72 2d b3 78 0xed12ff00: 00 00 00 00 00 42 00 00 72 2d b7 54 80 11 f6 34 0xed12ff10: 00 00 00 00 00 00 00 00 00 00 00 80 72 1c 47 f8 0xed12ff20: 00 00 00 00 72 2d b3 78 7f ca ea d0 80 10 2c d8 0xed12ff30: 01 20 00 12 00 00 00 00 00 00 00 00 00 00 00 00 0xed12ff40: 7f ca e6 88 00 00 00 10 00 00 00 00 00 00 00 00 0xed12ff50: 00 00 10 18 72 2e 27 50 01 20 00 12 00 00 00 00 0xed12ff60: 00 00 00 00 00 00 00 00 00 00 00 25 7f ca e0 c8 Call trace: Function Address = 0xf1d75dfc Function Address = 0x801a434c Function Address = 0x801a7f9c Function Address = 0x801a805c Function Address = 0x80149468 Function Address = 0x8014a5f4 Function Address = 0x8014a8a0 Function Address = 0x8011f634 Function Address = 0x80102cd8 --------------------- Reboot record 2 --------------------- Recorded at : 2022-03-19 09:20:08.501784 Occurred at : 2022-03-19 09:20:08.501784 Reason : 0xb Thread : ifmgr (TID: 146) Context : thread context Slot : 1 Cpu : 0 VCPU ID : 0 Kernel module info : module name (system) module address (0xf1b52000) module name (addon) module address (0xf010c000) Last 5 thread switches : diagd (9:20:8.500757)--> kmac/1 (9:20:8.500914)--> diagd (9:20:8.501004)--> kmac/1 (9:20:8.501454)--> ifmgr (9:20:8.501605) Dump stack (total 1024 bytes, 16 bytes/line): 0xd68cfb70: 00 00 00 04 f2 9a ad d4 f2 9a bb 7c 00 00 00 01 0xd68cfb80: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0xd68cfb90: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0xd68cfba0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0xd68cfbb0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0xd68cfbc0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0xd68cfbd0: 00 00 00 00 d6 8c fc 20 80 51 00 90 e8 03 08 40 0xd68cfbe0: 00 00 00 0b 80 50 de e0 01 b4 00 00 80 17 49 e8 0xd68cfbf0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0xd68cfc00: 62 35 2f c8 1d e8 a0 36 00 00 00 01 80 17 38 a8 0xd68cfc10: 00 00 00 00 80 12 06 1c 00 00 00 00 00 00 00 00 0xd68cfc20: 62 35 2f c8 00 07 a8 18 80 54 00 00 d6 8c fb 70 0xd68cfc30: 00 00 00 00 80 17 3e 14 f1 b6 e3 60 f2 99 00 00 0xd68cfc40: f2 99 00 00 00 00 00 01 d3 2c d1 00 81 a6 51 70 0xd68cfc50: 80 4d 2e 50 f1 b8 4f 30 f2 99 a0 54 80 1c f0 94 0xd68cfc60: ff ff ff ff ff ff ff ff d3 2c d1 00 f1 b6 e3 60 0xd68cfc70: 00 00 00 32 f2 9a 00 00 d3 2c d1 00 f1 b6 e3 60 0xd68cfc80: f2 9a 00 00 f2 9a 00 00 f1 b6 d5 90 f1 b8 4f 30 0xd68cfc90: f2 99 00 00 f1 b6 d5 90 00 00 00 00 00 00 00 06 0xd68cfca0: 00 00 00 04 f2 99 a0 54 00 00 ff ff 00 00 00 0b 0xd68cfcb0: 00 00 00 01 00 00 ff ff f2 fc 6c 24 f1 b6 e3 60 0xd68cfcc0: f2 99 00 00 f1 b6 78 40 80 4d 29 40 00 00 00 42 0xd68cfcd0: 00 00 00 00 00 00 00 00 00 00 00 02 f2 99 42 80 0xd68cfce0: 00 00 00 00 00 00 00 01 00 00 ff ff 00 00 00 0b 0xd68cfcf0: 00 00 00 00 00 00 00 48 80 55 00 00 80 1d 75 00 0xd68cfd00: f3 00 f6 38 00 00 00 03 80 4d 00 00 00 00 00 00 0xd68cfd10: 80 4d 29 40 00 00 00 00 00 00 00 00 00 00 00 00 0xd68cfd20: 00 00 00 10 f1 d7 5d fc 00 00 00 01 00 00 00 d0 0xd68cfd30: 00 00 00 03 f1 d6 e8 34 00 00 00 48 80 4d 00 00 0xd68cfd40: 00 00 00 00 00 00 00 01 00 00 ff ff 00 00 00 0b 0xd68cfd50: 00 00 00 d0 80 1a 43 4c 00 00 00 00 00 00 00 00 0xd68cfd60: 00 00 00 01 80 18 31 38 d6 8d 06 80 00 00 00 03 0xd68cfd70: 00 00 00 00 00 00 00 00 d6 8d 06 80 00 00 00 03 0xd68cfd80: 00 00 00 d0 00 00 00 00 80 4d 29 40 80 1a 7f 9c 0xd68cfd90: 00 02 00 d0 00 00 00 00 81 f9 0b 40 e8 02 16 80 0xd68cfda0: 00 00 00 00 00 00 00 48 00 00 00 00 00 00 00 00 0xd68cfdb0: 00 00 00 00 00 00 00 00 00 00 00 01 00 00 00 00 0xd68cfdc0: 00 00 00 00 00 00 00 08 00 02 00 d0 08 bd 02 0e 0xd68cfdd0: 80 4d 29 44 00 00 00 80 80 4d 29 44 00 01 08 00 0xd68cfde0: ec a1 54 80 00 3d 0f 00 72 58 40 e0 d6 8c ff 30 0xd68cfdf0: 00 00 00 00 d6 8d 06 80 80 52 00 00 00 01 08 00 0xd68cfe00: 72 58 45 98 80 1a 80 5c 00 3d 0f 00 00 3d 0f 00 0xd68cfe10: 72 58 40 e0 d6 8c ff 30 00 00 00 00 80 14 94 68 0xd68cfe20: 00 00 00 00 00 00 00 00 d3 49 07 b8 00 00 00 00 0xd68cfe30: 00 00 00 01 80 3a 3a 58 00 00 05 68 80 2c c0 64 0xd68cfe40: 74 c4 01 d0 80 3a 3c b4 d6 8d 06 80 d3 49 07 80 0xd68cfe50: 00 00 00 00 00 00 00 00 00 3d 0f 00 72 58 45 98 0xd68cfe60: 72 58 40 e0 d6 8c ff 30 00 00 00 00 00 00 00 00 0xd68cfe70: 00 00 00 00 00 40 63 e0 00 00 00 00 80 14 a5 f4 0xd68cfe80: 00 00 00 00 d5 03 80 00 d6 8c fe c8 00 03 00 02 0xd68cfe90: 72 58 45 98 00 00 00 00 00 00 00 00 f2 34 4b f8 0xd68cfea0: 00 00 00 01 d5 03 80 00 0f 51 a1 d0 00 00 05 68 0xd68cfeb0: 00 00 00 00 00 00 00 00 d6 8c fe a8 00 00 00 01 0xd68cfec0: 00 00 00 00 74 87 27 a8 d6 8c ff 08 72 58 45 30 0xd68cfed0: 74 c1 69 2c 74 c2 80 00 00 00 00 00 00 00 00 00 0xd68cfee0: 00 00 00 00 80 14 a8 a0 d5 03 80 10 d5 03 80 48 0xd68cfef0: 00 00 00 48 d5 03 80 50 72 58 45 98 72 58 45 98 0xd68cff00: 00 00 00 00 80 15 32 bd 00 00 00 05 80 11 f6 34 0xd68cff10: 74 c1 69 2c 00 00 10 00 00 80 00 00 71 d8 50 00 0xd68cff20: 72 58 45 98 72 58 45 98 00 40 63 e0 80 10 2c d8 0xd68cff30: 00 3d 0f 00 72 58 40 e0 72 58 45 98 72 58 b9 70 0xd68cff40: 74 8f 02 68 04 00 00 01 00 00 00 00 80 10 50 e4 0xd68cff50: 00 00 10 18 72 58 b9 70 00 3d 0f 00 72 58 40 e0 0xd68cff60: 72 58 45 98 72 58 b9 70 00 00 00 00 00 00 00 00 Call trace: Function Address = 0xf1d75dfc Function Address = 0x801a434c Function Address = 0x801a7f9c Function Address = 0x801a805c Function Address = 0x80149468 Function Address = 0x8014a5f4 Function Address = 0x8014a8a0 Function Address = 0x8011f634 Function Address = 0x80102cd8 --------------------- Reboot record 3 --------------------- Recorded at : 2022-03-17 16:30:23.724012 Occurred at : 2022-03-17 16:30:23.724012 Reason : 0xb Thread : diagd (TID: 136) Context : thread context Slot : 1 Cpu : 0 VCPU ID : 0 Kernel module info : module name (system) module address (0xf1b52000) module name (addon) module address (0xf010c000) Last 5 thread switches : apmgrd (16:30:23.719407)--> ifmgr (16:30:23.719463)--> apmgrd (16:30:23.722078)--> ifmgr (16:30:23.722144)--> diagd (16:30:23.723590) Dump stack (total 1024 bytes, 16 bytes/line): 0xe92ffb70: 00 00 00 04 f2 9a ad d4 f2 9a bb 7c 00 00 00 01 0xe92ffb80: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0xe92ffb90: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0xe92ffba0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0xe92ffbb0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0xe92ffbc0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0xe92ffbd0: 00 00 00 00 e9 2f fc 20 80 51 00 90 d3 33 00 00 0xe92ffbe0: 00 00 00 0b 80 50 de e0 01 b4 00 00 80 17 49 e8 0xe92ffbf0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0xe92ffc00: 62 32 f1 9f 2b 27 8f aa 00 00 00 01 80 17 38 a8 0xe92ffc10: 00 00 00 00 80 12 06 1c 00 00 00 00 00 00 00 00 0xe92ffc20: 62 32 f1 9f 00 0b 0c 2c 80 54 00 00 e9 2f fb 70 0xe92ffc30: 00 00 00 00 80 17 3e 14 f1 b6 e3 60 f2 99 00 00 0xe92ffc40: f2 99 00 00 00 00 00 01 c5 88 02 00 81 79 fa 00 0xe92ffc50: 80 4d 2e 50 f1 b8 4f 30 f2 99 a0 54 80 1c f0 94 0xe92ffc60: ff ff ff ff ff ff ff ff c5 88 02 00 f1 b6 e3 60 0xe92ffc70: 00 00 00 32 f2 9a 00 00 c5 88 02 00 f1 b6 e3 60 0xe92ffc80: f2 9a 00 00 f2 9a 00 00 f1 b6 d5 90 f1 b8 4f 30 0xe92ffc90: f2 99 00 00 f1 b6 d5 90 00 00 00 00 00 00 00 06 0xe92ffca0: 00 00 00 04 f2 99 a0 54 00 00 ff ff 00 00 00 0b 0xe92ffcb0: 00 00 00 01 00 00 ff ff f2 fc 6c 24 f1 b6 e3 60 0xe92ffcc0: f2 99 00 00 f1 b6 78 40 80 4d 29 40 00 00 00 42 0xe92ffcd0: 00 00 00 00 00 00 00 00 00 00 00 02 f2 99 42 80 0xe92ffce0: 00 00 00 00 00 00 00 01 00 00 ff ff 00 00 00 0b 0xe92ffcf0: 00 00 00 00 00 00 00 48 80 55 00 00 80 1d 75 00 0xe92ffd00: f3 00 f6 38 00 00 00 03 80 4d 00 00 00 00 00 00 0xe92ffd10: 80 4d 29 40 00 00 00 00 00 00 00 00 00 00 00 00 0xe92ffd20: 00 00 00 10 f1 d7 5d fc 00 00 00 01 00 00 00 d0 0xe92ffd30: 00 00 00 03 f1 d6 e8 34 00 00 00 48 80 4d 00 00 0xe92ffd40: 00 00 00 00 00 00 00 01 00 00 ff ff 00 00 00 0b 0xe92ffd50: 00 00 00 d0 80 1a 43 4c 00 00 00 00 00 00 00 00 0xe92ffd60: 00 00 00 01 80 18 31 38 e8 0c 13 80 00 00 00 03 0xe92ffd70: 00 00 00 00 00 00 00 00 e8 0c 13 80 00 00 00 03 0xe92ffd80: 00 00 00 d0 00 00 00 00 80 4d 29 40 80 1a 7f 9c 0xe92ffd90: 00 02 00 d0 00 00 00 00 81 0d 0b 60 e8 02 16 80 0xe92ffda0: 00 00 00 00 00 00 00 48 00 00 00 00 00 00 00 00 0xe92ffdb0: 00 00 00 00 00 00 00 00 00 00 00 01 00 00 00 00 0xe92ffdc0: 00 00 00 00 00 00 00 08 00 02 00 d0 3b dc f3 9f 0xe92ffdd0: 80 4d 29 44 00 00 00 80 80 4d 29 44 00 00 00 00 0xe92ffde0: 84 03 f5 00 01 20 00 12 7f 92 42 88 e9 2f ff 30 0xe92ffdf0: 00 00 00 00 e8 0c 13 80 80 52 00 00 00 00 00 00 0xe92ffe00: 73 bd 23 78 80 1a 80 5c 01 20 00 12 01 20 00 12 0xe92ffe10: 7f 92 42 88 e9 2f ff 30 00 00 00 00 80 14 94 68 0xe92ffe20: 00 00 00 00 00 00 00 00 d3 4d 87 b8 00 00 00 00 0xe92ffe30: 00 00 00 01 80 3a 3a 58 80 4d 00 00 80 2c c0 64 0xe92ffe40: 73 b0 7f 98 80 3a 3c b4 e8 0c 13 80 d3 4d 87 80 0xe92ffe50: 00 00 00 00 00 00 00 00 01 20 00 12 00 00 00 00 0xe92ffe60: 7f 92 42 88 e9 2f ff 30 00 00 00 00 73 ab b7 f8 0xe92ffe70: 73 ab b7 f0 7f 92 47 a8 7f 92 42 e8 80 14 a5 f4 0xe92ffe80: 80 1d c0 44 80 1e 31 84 83 13 e6 00 00 03 00 02 0xe92ffe90: 73 bd 23 78 00 00 00 00 00 00 00 00 e8 05 64 00 0xe92ffea0: e8 05 63 c0 00 00 00 0f 83 13 f9 00 73 ab b7 f8 0xe92ffeb0: 73 ab b7 f0 7f 92 47 a8 00 00 00 01 80 1d 77 84 0xe92ffec0: 00 00 00 00 80 1e 2d e4 62 32 f1 9d 7f 92 42 c8 0xe92ffed0: 73 bd 23 10 00 00 00 88 7f 92 42 d8 73 bd 27 54 0xe92ffee0: 73 ab b7 f8 80 14 a8 a0 eb 7e 31 00 7f 92 46 b0 0xe92ffef0: 00 00 00 80 80 1d b2 0c 00 00 00 00 73 bd 23 78 0xe92fff00: 00 00 00 00 00 42 00 00 73 bd 27 54 80 11 f6 34 0xe92fff10: 73 a3 db e4 00 00 00 01 7f 92 42 e8 73 bd 27 54 0xe92fff20: 00 00 00 00 73 bd 23 78 7f 92 47 a8 80 10 2c d8 0xe92fff30: 01 20 00 12 00 00 00 00 00 00 00 00 00 00 00 00 0xe92fff40: 7f 92 42 68 00 00 00 10 00 00 00 00 ff ff ff fd 0xe92fff50: 00 00 10 18 73 bd 97 50 01 20 00 12 00 00 00 00 0xe92fff60: 00 00 00 00 00 00 00 00 00 00 00 00 e0 08 3c 00 Call trace: Function Address = 0xf1d75dfc Function Address = 0x801a434c Function Address = 0x801a7f9c Function Address = 0x801a805c Function Address = 0x80149468 Function Address = 0x8014a5f4 Function Address = 0x8014a8a0 Function Address = 0x8011f634 Function Address = 0x80102cd8 --------------------- Reboot record 4 --------------------- Recorded at : 2021-11-08 20:36:20.800006 Occurred at : 2021-11-08 20:36:20.800006 Reason : 0x0 Thread : devd (TID: 141) Context : thread context Slot : 1 Cpu : 0 VCPU ID : 1 Kernel module info : module name (system) module address (0xf1b52000) module name (addon) module address (0xf010c000) Last 5 thread switches : devd (20:36:20.789823)--> swapper (20:36:20.792968)--> devd (20:36:20.792980)--> apmgrd (20:36:20.799910)--> devd (20:36:20.799952) Dump stack (total 1024 bytes, 16 bytes/line): 0xd35efc20: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0xd35efc30: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0xd35efc40: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0xd35efc50: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0xd35efc60: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0xd35efc70: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0xd35efc80: 00 00 00 00 d3 5e fc d0 80 51 00 94 d3 2f 88 40 0xd35efc90: 00 00 00 00 80 50 de e0 01 b4 50 00 80 17 49 e8 0xd35efca0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0xd35efcb0: 61 89 19 c4 2f af 21 0f 00 00 00 01 80 17 38 a8 0xd35efcc0: 00 00 00 00 80 12 06 1c 00 00 00 00 00 00 00 00 0xd35efcd0: 61 89 19 c4 00 0c 35 06 80 54 00 00 d3 5e fc 20 0xd35efce0: 00 00 00 01 80 17 3e 14 74 00 00 00 00 00 00 00 0xd35efcf0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0xd35efd00: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0xd35efd10: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0xd35efd20: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0xd35efd30: 00 00 00 00 00 00 00 00 00 00 00 90 f1 b8 4f 30 0xd35efd40: 61 88 38 ba 00 06 23 ce e1 c7 68 f8 00 00 00 06 0xd35efd50: 00 00 00 00 00 00 ff ff 00 00 ff ff 00 00 00 00 0xd35efd60: 00 00 ff ff 00 00 ff ff f2 fc 6c 24 f1 b6 e3 60 0xd35efd70: f2 99 00 00 f1 b6 78 40 82 05 35 58 d3 5e fe 0c 0xd35efd80: 22 22 22 22 00 00 ff ff 00 00 00 02 f2 99 42 80 0xd35efd90: 00 00 ff ff 00 00 ff ff 00 00 ff ff 00 00 00 00 0xd35efda0: 00 00 00 00 ed 17 d2 00 00 00 00 00 e0 00 06 f0 0xd35efdb0: f3 00 f6 38 00 00 ff ff d3 5e fe f4 00 00 00 01 0xd35efdc0: 80 10 50 e0 00 00 00 00 80 10 54 20 00 40 54 28 0xd35efdd0: 70 a3 e0 18 f1 d7 5d fc d3 5e fe 18 00 00 00 01 0xd35efde0: 00 00 ff ff 00 00 ff ff d3 5e fe f4 00 00 00 00 0xd35efdf0: 80 10 50 e0 00 00 00 00 80 10 54 20 00 40 54 28 0xd35efe00: 00 00 ff ff f1 e5 ea dc e1 fe 57 00 81 d6 7a 84 0xd35efe10: 00 00 00 00 80 41 00 00 80 4d 32 f0 e1 fe 57 00 0xd35efe20: 81 d6 7a 84 80 1c ae bc 80 4d 32 f0 00 00 00 d0 0xd35efe30: 03 0f 00 01 f2 3b d6 60 e1 fe 57 6c ff ff ff ff 0xd35efe40: ff ff ff ff 00 00 00 00 00 00 00 00 00 00 01 2f 0xd35efe50: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0xd35efe60: 00 00 00 00 00 00 00 00 00 00 00 00 00 40 54 28 0xd35efe70: 00 00 00 01 80 3a 3a 58 80 4d 32 f0 00 00 00 d0 0xd35efe80: 00 00 00 01 03 0f 00 01 80 4d 32 f0 00 00 00 00 0xd35efe90: 00 00 00 01 03 0f 00 01 00 00 00 40 80 1d 04 1c 0xd35efea0: 00 00 00 00 f1 de e1 38 e0 0e 2c c0 00 00 00 03 0xd35efeb0: 82 05 3a 1c e1 fe 57 00 f1 e5 e2 e0 f2 a8 00 00 0xd35efec0: 80 13 b6 e0 00 00 00 00 00 00 00 00 00 00 00 00 0xd35efed0: 00 40 54 28 f2 3b d5 58 00 00 00 00 80 1d 78 88 0xd35efee0: 00 00 00 39 e8 05 66 80 00 00 00 00 d3 5e fe f4 0xd35efef0: 00 00 00 00 00 00 00 00 00 00 00 46 00 00 00 24 0xd35eff00: 70 a3 df 38 00 00 00 00 00 00 00 00 70 a3 de e8 0xd35eff10: 70 a3 de 98 00 00 03 fb 00 00 00 00 00 00 00 00 0xd35eff20: 00 00 00 00 00 00 00 24 70 a3 df b4 80 10 2c d8 0xd35eff30: 00 3d 0f 00 70 a3 e0 e0 70 a3 e5 98 70 a4 59 70 0xd35eff40: 70 a3 d8 38 00 00 00 10 00 00 00 00 80 51 00 04 0xd35eff50: 00 00 10 e4 00 00 00 02 70 a3 de 9c 70 a3 df 38 0xd35eff60: 00 00 00 00 70 e2 a4 30 00 00 00 03 70 a3 da 60 0xd35eff70: ff ff ff fc 70 a3 da 60 0c cc cc cc 00 00 00 0a 0xd35eff80: 70 ca e0 04 70 c9 a9 88 00 00 00 10 70 a3 d8 48 0xd35eff90: 00 00 00 74 00 00 00 03 00 00 00 01 00 00 24 e4 0xd35effa0: 00 00 00 00 00 40 54 28 7f ff ff ff 70 c5 23 10 0xd35effb0: 70 e2 a4 30 00 00 00 00 70 cb 63 a0 70 a3 de 60 0xd35effc0: 70 a3 d8 00 70 e1 1b cc 00 00 f8 13 00 00 00 01 0xd35effd0: 99 99 99 9c 70 cb 92 f0 00 80 00 20 70 c5 23 58 0xd35effe0: 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 0xd35efff0: 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 0xd35f0000: 00 00 00 02 03 06 00 00 00 00 00 00 01 5a 5a 5a 0xd35f0010: 22 7d 0d 0a 2c 7b 22 49 6e 64 65 78 22 3a 22 31 Call trace: Function Address = 0xf1d75dfc Function Address = 0xf1e5eadc Function Address = 0xf23bd558 Function Address = 0x80102cd8 --------------------- Reboot record 5 --------------------- Recorded at : 2021-07-09 08:38:58.1372 Occurred at : 2021-07-09 08:38:58.1372 Reason : 0x0 Thread : devd (TID: 141) Context : thread context Slot : 1 Cpu : 0 VCPU ID : 1 Kernel module info : module name (system) module address (0xf1b52000) module name (addon) module address (0xf010c000) Last 5 thread switches : devd (8:38:57.646624)--> karp/1 (8:38:57.748732)--> devd (8:38:57.748761)--> dpid (8:38:57.962051)--> devd (8:38:57.962086) Dump stack (total 1024 bytes, 16 bytes/line): 0xeb7dfc20: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0xeb7dfc30: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0xeb7dfc40: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0xeb7dfc50: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0xeb7dfc60: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0xeb7dfc70: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0xeb7dfc80: 00 00 00 00 eb 7d fc d0 80 51 00 94 d3 2f 88 40 0xeb7dfc90: 00 00 00 00 80 50 de e0 01 b4 50 00 80 17 49 e8 0xeb7dfca0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0xeb7dfcb0: 60 e7 9a a2 00 14 f0 28 00 00 00 01 80 17 38 a8 0xeb7dfcc0: 00 00 00 00 80 12 06 1c 00 00 00 00 00 00 00 00 0xeb7dfcd0: 60 e7 9a a2 00 00 05 5c 80 54 00 00 eb 7d fc 20 0xeb7dfce0: 00 00 00 01 80 17 3e 14 74 00 00 00 00 00 00 00 0xeb7dfcf0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0xeb7dfd00: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0xeb7dfd10: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0xeb7dfd20: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0xeb7dfd30: 00 00 00 00 00 00 00 00 00 00 00 90 f1 b8 4f 30 0xeb7dfd40: 60 e6 b9 9a 00 01 f1 df ec e0 13 10 00 00 00 06 0xeb7dfd50: 00 00 00 00 00 00 ff ff 00 00 ff ff 00 00 00 00 0xeb7dfd60: 00 00 ff ff 00 00 ff ff f2 fc 6c 24 f1 b6 e3 60 0xeb7dfd70: f2 99 00 00 f1 b6 78 40 00 00 00 00 eb 7d fe 0c 0xeb7dfd80: 22 22 22 22 00 00 ff ff 00 00 00 02 f2 99 42 80 0xeb7dfd90: 00 00 ff ff 00 00 ff ff 00 00 ff ff 00 00 00 00 0xeb7dfda0: 00 00 00 00 eb 7f 31 00 00 00 00 00 e0 20 99 38 0xeb7dfdb0: f3 00 f6 38 00 00 ff ff eb 7d fe f4 00 00 00 01 0xeb7dfdc0: 80 10 50 e0 00 00 00 00 80 10 54 20 00 40 54 28 0xeb7dfdd0: 6a 39 60 18 f1 d7 5d fc eb 7d fe 18 00 00 00 01 0xeb7dfde0: 00 00 ff ff 00 00 ff ff eb 7d fe f4 00 00 00 00 0xeb7dfdf0: 80 10 50 e0 00 00 00 00 80 10 54 20 00 40 54 28 0xeb7dfe00: 00 00 ff ff f1 e5 ea dc 84 d9 cc 00 81 0f c3 b0 0xeb7dfe10: 00 00 00 00 80 41 00 00 80 4d 32 f0 84 d9 cc 00 0xeb7dfe20: 81 0f c3 b0 80 1c ae bc 80 4d 32 f0 00 00 00 d0 0xeb7dfe30: 03 0f 00 01 f2 3b d6 60 84 d9 cc 6c ff ff ff ff 0xeb7dfe40: ff ff ff ff 00 00 00 00 00 00 00 00 00 00 01 2f 0xeb7dfe50: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0xeb7dfe60: 00 00 00 00 00 00 00 00 00 00 00 00 00 40 54 28 0xeb7dfe70: 00 00 00 01 80 3a 3a 58 80 4d 32 f0 00 00 00 d0 0xeb7dfe80: 00 00 00 01 03 0f 00 01 80 4d 32 f0 00 00 00 00 0xeb7dfe90: 00 00 00 01 03 0f 00 01 00 00 00 40 80 1d 04 1c 0xeb7dfea0: 00 00 00 00 f1 de e1 38 e0 09 17 80 00 00 00 03 0xeb7dfeb0: 82 05 3a 1c 84 d9 cc 00 f1 e5 e2 e0 f2 a8 00 00 0xeb7dfec0: 80 13 b6 e0 00 00 00 00 00 00 00 00 00 00 00 00 0xeb7dfed0: 00 40 54 28 f2 3b d5 58 00 00 00 00 80 1d 78 88 0xeb7dfee0: 00 00 00 39 e8 0f c4 00 00 00 00 00 eb 7d fe f4 0xeb7dfef0: 00 00 00 00 00 00 00 00 00 00 00 46 00 00 00 24 0xeb7dff00: 6a 39 5f 38 00 00 00 00 00 00 00 00 6a 39 5e e8 0xeb7dff10: 6a 39 5e 98 00 00 03 fb 00 00 00 00 00 00 00 00 0xeb7dff20: 00 00 00 00 00 00 00 24 6a 39 5f b4 80 10 2c d8 0xeb7dff30: 00 3d 0f 00 6a 39 60 e0 6a 39 65 98 6a 39 d9 70 0xeb7dff40: 6a 39 58 38 00 00 00 10 00 00 00 00 00 00 00 01 0xeb7dff50: 00 00 10 e4 00 00 00 02 6a 39 5e 9c 6a 39 5f 38 0xeb7dff60: 00 00 00 00 6a 78 24 30 00 00 00 00 00 00 00 00 0xeb7dff70: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0xeb7dff80: 00 00 00 00 00 00 00 00 0d c3 5d 78 6a 39 3e a4 0xeb7dff90: 00 00 00 01 00 00 00 00 00 00 00 90 00 01 00 0a 0xeb7dffa0: 00 00 00 00 00 40 54 28 00 00 00 00 6a 5a a3 10 0xeb7dffb0: 6a 78 24 30 00 00 00 00 6a 60 e3 a0 6a 39 5e 60 0xeb7dffc0: 6a 39 60 18 6a 76 9b cc 00 00 f8 13 00 00 02 c8 0xeb7dffd0: 00 03 4e d8 6a 39 40 00 00 80 00 20 6a 5a a3 58 0xeb7dffe0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0xeb7dfff0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0xeb7e0000: 80 51 70 00 80 51 70 00 ed 03 50 00 80 51 70 00 0xeb7e0010: 80 51 70 00 80 51 70 00 80 51 70 00 80 51 70 00 Call trace: Function Address = 0xf1d75dfc Function Address = 0xf1e5eadc Function Address = 0xf23bd558 Function Address = 0x80102cd8 --------------------- Reboot record 6 --------------------- Recorded at : 2021-06-09 08:16:20.619968 Occurred at : 2021-06-09 08:16:20.619968 Reason : 0x0 Thread : devd (TID: 141) Context : thread context Slot : 1 Cpu : 0 VCPU ID : 2 Kernel module info : module name (system) module address (0xf1b52000) module name (addon) module address (0xf010c000) Last 5 thread switches : devd (8:16:20.337782)--> dhcpd (8:16:20.439283)--> devd (8:16:20.439325)--> dhcpd (8:16:20.537776)--> devd (8:16:20.537804) Dump stack (total 1024 bytes, 16 bytes/line): 0xe964fc20: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0xe964fc30: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0xe964fc40: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0xe964fc50: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0xe964fc60: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0xe964fc70: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0xe964fc80: 00 00 00 00 e9 64 fc d0 80 51 00 98 e8 03 18 c0 0xe964fc90: 00 00 00 00 80 50 de e0 01 b4 a0 00 80 17 49 e8 0xe964fca0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0xe964fcb0: 60 c0 08 54 24 f3 f7 72 00 00 00 01 80 17 38 a8 0xe964fcc0: 00 00 00 00 80 12 06 1c 00 00 00 00 00 00 00 00 0xe964fcd0: 60 c0 08 54 00 09 75 c0 80 54 00 00 e9 64 fc 20 0xe964fce0: 00 00 00 02 80 17 3e 14 74 00 00 00 00 00 00 00 0xe964fcf0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0xe964fd00: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0xe964fd10: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0xe964fd20: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0xe964fd30: 00 00 00 00 00 00 00 00 00 00 00 90 f1 b8 4f 30 0xe964fd40: 60 bf 27 4c 00 06 a9 9e e0 3d a0 38 00 00 00 06 0xe964fd50: 00 00 00 00 00 00 ff ff 00 00 ff ff 00 00 00 00 0xe964fd60: 00 00 ff ff 00 00 ff ff f2 fc 6c 24 f1 b6 e3 60 0xe964fd70: f2 99 00 00 f1 b6 78 40 00 00 00 00 e9 64 fe 0c 0xe964fd80: 22 22 22 22 00 00 ff ff 00 00 00 02 f2 99 42 80 0xe964fd90: 00 00 ff ff 00 00 ff ff 00 00 ff ff 00 00 00 00 0xe964fda0: 00 00 00 00 e9 0d 15 00 00 00 00 00 e0 20 ab 80 0xe964fdb0: f3 00 f6 38 00 00 ff ff e9 64 fe f4 00 00 00 01 0xe964fdc0: 80 10 50 e0 00 00 00 00 80 10 54 20 00 40 54 28 0xe964fdd0: 6c e1 20 18 f1 d7 5d fc e9 64 fe 18 00 00 00 01 0xe964fde0: 00 00 ff ff 00 00 ff ff e9 64 fe f4 00 00 00 00 0xe964fdf0: 80 10 50 e0 00 00 00 00 80 10 54 20 00 40 54 28 0xe964fe00: 00 00 ff ff f1 e5 ea dc c7 4e 55 00 81 7f be 84 0xe964fe10: 00 00 00 00 80 41 00 00 80 4d 32 f0 c7 4e 55 00 0xe964fe20: 81 7f be 84 80 1c ae bc 80 4d 32 f0 00 00 00 d0 0xe964fe30: 03 0f 00 01 f2 3b d6 60 c7 4e 55 6c ff ff ff ff 0xe964fe40: ff ff ff ff 00 00 00 00 00 00 00 00 00 00 01 2f 0xe964fe50: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0xe964fe60: 00 00 00 00 00 00 00 00 00 00 00 00 00 40 54 28 0xe964fe70: 00 00 00 01 80 3a 3a 58 80 4d 32 f0 00 00 00 d0 0xe964fe80: 00 00 00 01 03 0f 00 01 80 4d 32 f0 00 00 00 00 0xe964fe90: 00 00 00 01 03 0f 00 01 00 00 00 40 80 1d 04 1c 0xe964fea0: 00 00 00 00 f1 de e1 38 e0 0e 3a 80 00 00 00 03 0xe964feb0: 82 05 8a 1c c7 4e 55 00 f1 e5 e2 e0 f2 a8 00 00 0xe964fec0: 80 13 b6 e0 00 00 00 00 00 00 00 00 00 00 00 00 0xe964fed0: 00 40 54 28 f2 3b d5 58 00 00 00 00 80 1d 78 88 0xe964fee0: 00 00 00 39 e8 05 65 40 00 00 00 00 e9 64 fe f4 0xe964fef0: 00 00 00 00 00 00 00 00 00 00 00 46 00 00 00 24 0xe964ff00: 6c e1 1f 38 00 00 00 00 00 00 00 00 6c e1 1e e8 0xe964ff10: 6c e1 1e 98 00 00 03 fb 00 00 00 00 00 00 00 00 0xe964ff20: 00 00 00 00 00 00 00 24 6c e1 1f b4 80 10 2c d8 0xe964ff30: 00 3d 0f 00 6c e1 20 e0 6c e1 25 98 6c e1 99 70 0xe964ff40: 6c e1 18 38 00 00 00 10 00 00 00 00 ff ff ff fd 0xe964ff50: 00 00 10 e4 00 00 00 02 6c e1 1e 9c 6c e1 1f 38 0xe964ff60: 00 00 00 00 6d 1f e4 30 00 00 00 00 80 00 00 08 0xe964ff70: 80 15 33 70 ff ff ff f0 00 00 00 01 00 00 00 00 0xe964ff80: 00 00 d5 31 c6 8c a9 7b 6d 08 71 c8 7f 89 29 0c 0xe964ff90: 6c e1 1d 14 00 00 00 3d 6d 04 d4 c0 6d 06 e6 70 0xe964ffa0: 00 00 00 00 00 40 54 28 00 00 00 00 6d 02 63 10 0xe964ffb0: 6d 1f e4 30 00 00 00 00 6d 08 a3 a0 6c e1 1e 60 0xe964ffc0: 6c e1 20 18 6d 1e 5b cc 40 00 f8 13 00 00 00 00 0xe964ffd0: 00 00 00 1d 6d 08 d2 f0 00 80 00 20 6d 02 63 58 0xe964ffe0: 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 0xe964fff0: 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 0xe9650000: e8 11 a7 00 80 4c b2 c4 00 10 00 00 6d 8a d9 70 0xe9650010: 00 00 00 00 00 00 00 00 80 00 00 00 00 00 00 00 Call trace: Function Address = 0xf1d75dfc Function Address = 0xf1e5eadc Function Address = 0xf23bd558 Function Address = 0x80102cd8 --------------------- Reboot record 7 --------------------- Recorded at : 2021-06-02 15:29:21.8677 Occurred at : 2021-06-02 15:29:21.8677 Reason : 0x0 Thread : devd (TID: 141) Context : thread context Slot : 1 Cpu : 0 VCPU ID : 1 Kernel module info : module name (system) module address (0xf1b52000) module name (addon) module address (0xf010c000) Last 5 thread switches : devd (15:29:20.777552)--> ntpd (15:29:20.795059)--> devd (15:29:20.795199)--> ofcd (15:29:20.956481)--> devd (15:29:20.956558) Dump stack (total 1024 bytes, 16 bytes/line): 0xd360fc20: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0xd360fc30: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0xd360fc40: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0xd360fc50: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0xd360fc60: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0xd360fc70: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0xd360fc80: 00 00 00 00 d3 60 fc d0 80 51 00 94 e8 03 18 c0 0xd360fc90: 00 00 00 00 80 50 de e0 01 b4 50 00 80 17 49 e8 0xd360fca0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0xd360fcb0: 60 b7 33 51 00 84 67 73 00 00 00 01 80 17 38 a8 0xd360fcc0: 00 00 00 00 80 12 06 1c 00 00 00 00 00 00 00 00 0xd360fcd0: 60 b7 33 51 00 00 21 e5 80 54 00 00 d3 60 fc 20 0xd360fce0: 00 00 00 01 80 17 3e 14 74 00 00 00 00 00 00 00 0xd360fcf0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0xd360fd00: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0xd360fd10: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0xd360fd20: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0xd360fd30: 00 00 00 00 00 00 00 00 00 00 00 90 f1 b8 4f 30 0xd360fd40: 60 b6 52 49 00 04 ad 70 e1 ca 61 f8 00 00 00 06 0xd360fd50: 00 00 00 00 00 00 ff ff 00 00 ff ff 00 00 00 00 0xd360fd60: 00 00 ff ff 00 00 ff ff f2 fc 6c 24 f1 b6 e3 60 0xd360fd70: f2 99 00 00 f1 b6 78 40 00 00 00 00 d3 60 fe 0c 0xd360fd80: 22 22 22 22 00 00 ff ff 00 00 00 02 f2 99 42 80 0xd360fd90: 00 00 ff ff 00 00 ff ff 00 00 ff ff 00 00 00 00 0xd360fda0: 00 00 00 00 ed 16 fa 00 00 00 00 00 e0 00 37 b0 0xd360fdb0: f3 00 f6 38 00 00 ff ff d3 60 fe f4 00 00 00 01 0xd360fdc0: 80 10 50 e0 00 00 00 00 80 10 54 20 00 40 54 28 0xd360fdd0: 6d 4f 60 18 f1 d7 5d fc d3 60 fe 18 00 00 00 01 0xd360fde0: 00 00 ff ff 00 00 ff ff d3 60 fe f4 00 00 00 00 0xd360fdf0: 80 10 50 e0 00 00 00 00 80 10 54 20 00 40 54 28 0xd360fe00: 00 00 ff ff f1 e5 ea dc c3 54 2d 00 81 72 d1 68 0xd360fe10: 00 00 00 00 80 41 00 00 80 4d 32 f0 c3 54 2d 00 0xd360fe20: 81 72 d1 68 80 1c ae bc 80 4d 32 f0 00 00 00 d0 0xd360fe30: 03 0f 00 01 f2 3b d6 60 c3 54 2d 6c ff ff ff ff 0xd360fe40: ff ff ff ff 00 00 00 00 00 00 00 00 00 00 01 2f 0xd360fe50: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0xd360fe60: 00 00 00 00 00 00 00 00 00 00 00 00 00 40 54 28 0xd360fe70: 00 00 00 01 80 3a 3a 58 80 4d 32 f0 00 00 00 d0 0xd360fe80: 00 00 00 01 03 0f 00 01 80 4d 32 f0 00 00 00 00 0xd360fe90: 00 00 00 01 03 0f 00 01 00 00 00 40 80 1d 04 1c 0xd360fea0: 00 00 00 00 f1 de e1 38 e0 09 da 80 00 00 00 03 0xd360feb0: 82 05 3a 1c c3 54 2d 00 f1 e5 e2 e0 f2 a8 00 00 0xd360fec0: 80 13 b6 e0 00 00 00 00 00 00 00 00 00 00 00 00 0xd360fed0: 00 40 54 28 f2 3b d5 58 00 00 00 00 80 1d 78 88 0xd360fee0: 00 00 00 39 e8 05 65 40 00 00 00 00 d3 60 fe f4 0xd360fef0: 00 00 00 00 00 00 00 00 00 00 00 46 00 00 00 24 0xd360ff00: 6d 4f 5f 38 00 00 00 00 00 00 00 00 6d 4f 5e e8 0xd360ff10: 6d 4f 5e 98 00 00 03 fb 00 00 00 00 00 00 00 00 0xd360ff20: 00 00 00 00 00 00 00 24 6d 4f 5f b4 80 10 2c d8 0xd360ff30: 00 3d 0f 00 6d 4f 60 e0 6d 4f 65 98 6d 4f d9 70 0xd360ff40: 6d 4f 58 38 00 00 00 10 00 00 00 00 ff ff ff fd 0xd360ff50: 00 00 10 e4 00 00 00 02 6d 4f 5e 9c 6d 4f 5f 38 0xd360ff60: 00 00 00 00 6d 8e 24 30 6d 77 33 0c 6d 76 e5 9c 0xd360ff70: f0 00 00 00 00 00 00 01 00 00 08 07 00 00 08 00 0xd360ff80: 00 00 04 00 6d 97 77 64 00 00 00 10 6d 4f 58 48 0xd360ff90: 00 00 00 74 00 00 00 03 00 00 00 01 00 00 24 e4 0xd360ffa0: 00 00 00 00 00 40 54 28 00 00 01 33 6d 70 a3 10 0xd360ffb0: 6d 8e 24 30 00 00 00 00 6d 76 e3 a0 6d 4f 5e 60 0xd360ffc0: 6d 4f 58 00 6d 8c 9b cc 00 00 f8 13 00 00 01 95 0xd360ffd0: 00 01 58 3d 6d 77 12 f0 00 80 00 20 6d 70 a3 58 0xd360ffe0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0xd360fff0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0xd3610000: e8 0c 1a 00 80 4c b2 c4 00 10 00 00 6d 9b d4 40 0xd3610010: 00 00 00 02 00 00 00 00 80 00 00 00 00 00 00 00 Call trace: Function Address = 0xf1d75dfc Function Address = 0xf1e5eadc Function Address = 0xf23bd558 Function Address = 0x80102cd8 --------------------- Reboot record 8 --------------------- Recorded at : 2021-03-26 13:43:27.190433 Occurred at : 2021-03-26 13:43:27.190433 Reason : 0x0 Thread : devd (TID: 141) Context : thread context Slot : 1 Cpu : 0 VCPU ID : 1 Kernel module info : module name (system) module address (0xf1b52000) module name (addon) module address (0xf010c000) Last 5 thread switches : devd (13:43:27.42563)--> portsecd (13:43:27.98623)--> devd (13:43:27.98682)--> events/1 (13:43:27.151416)--> devd (13:43:27.151431) Dump stack (total 1024 bytes, 16 bytes/line): 0xed177c20: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0xed177c30: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0xed177c40: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0xed177c50: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0xed177c60: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0xed177c70: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0xed177c80: 00 00 00 00 ed 17 7c d0 80 51 00 94 d3 2e 90 80 0xed177c90: 00 00 00 00 80 50 de e0 01 b4 50 00 80 17 49 e8 0xed177ca0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0xed177cb0: 60 5d 74 7f 0b 59 ca 94 00 00 00 01 80 17 38 a8 0xed177cc0: 00 00 00 00 80 12 06 1c 00 00 00 00 00 00 00 00 0xed177cd0: 60 5d 74 7f 00 02 e7 e1 80 54 00 00 ed 17 7c 20 0xed177ce0: 00 00 00 01 80 17 3e 14 74 00 00 00 00 00 00 00 0xed177cf0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0xed177d00: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0xed177d10: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0xed177d20: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0xed177d30: 00 00 00 00 00 00 00 00 00 00 00 90 f1 b8 4f 30 0xed177d40: 60 5c 93 77 00 01 ec 54 e8 0d f9 a0 00 00 00 06 0xed177d50: 00 00 00 00 00 00 ff ff 00 00 ff ff 00 00 00 00 0xed177d60: 00 00 ff ff 00 00 ff ff f2 fc 6c 24 f1 b6 e3 60 0xed177d70: f2 99 00 00 f1 b6 78 40 00 00 00 00 ed 17 7e 0c 0xed177d80: 22 22 22 22 00 00 ff ff 00 00 00 02 f2 99 42 80 0xed177d90: 00 00 ff ff 00 00 ff ff 00 00 ff ff 00 00 00 00 0xed177da0: 00 00 00 00 ed 14 c6 00 00 00 00 00 e0 00 06 f0 0xed177db0: f3 00 f6 38 00 00 ff ff ed 17 7e f4 00 00 00 01 0xed177dc0: 80 10 50 e0 00 00 00 00 80 10 54 20 00 40 54 28 0xed177dd0: 69 2f c0 18 f1 d7 5d fc ed 17 7e 18 00 00 00 01 0xed177de0: 00 00 ff ff 00 00 ff ff ed 17 7e f4 00 00 00 00 0xed177df0: 80 10 50 e0 00 00 00 00 80 10 54 20 00 40 54 28 0xed177e00: 00 00 ff ff f1 e5 ea dc c5 aa e7 00 81 7a 6b 58 0xed177e10: 00 00 00 00 80 41 00 00 80 4d 32 f0 c5 aa e7 00 0xed177e20: 81 7a 6b 58 80 1c ae bc 80 4d 32 f0 00 00 00 d0 0xed177e30: 03 0f 00 01 f2 3b d6 60 c5 aa e7 6c ff ff ff ff 0xed177e40: ff ff ff ff 00 00 00 00 00 00 00 00 00 00 01 2f 0xed177e50: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0xed177e60: 00 00 00 00 00 00 00 00 00 00 00 00 00 40 54 28 0xed177e70: 00 00 00 01 80 3a 3a 58 80 4d 32 f0 00 00 00 d0 0xed177e80: 00 00 00 01 03 0f 00 01 80 4d 32 f0 00 00 00 00 0xed177e90: 00 00 00 01 03 0f 00 01 00 00 00 40 80 1d 04 1c 0xed177ea0: 00 00 00 00 f1 de e1 38 e0 09 d3 00 00 00 00 03 0xed177eb0: 82 05 8a 1c c5 aa e7 00 f1 e5 e2 e0 f2 a8 00 00 0xed177ec0: 80 13 b6 e0 00 00 00 00 00 00 00 00 00 00 00 00 0xed177ed0: 00 40 54 28 f2 3b d5 58 00 00 00 00 80 1d 78 88 0xed177ee0: 00 00 00 39 e8 05 65 40 00 00 00 00 ed 17 7e f4 0xed177ef0: 00 00 00 00 00 00 00 00 00 00 00 46 00 00 00 24 0xed177f00: 69 2f bf 38 00 00 00 00 00 00 00 00 69 2f be e8 0xed177f10: 69 2f be 98 00 00 03 fb 00 00 00 00 00 00 00 00 0xed177f20: 00 00 00 00 00 00 00 24 69 2f bf b4 80 10 2c d8 0xed177f30: 00 3d 0f 00 69 2f c0 e0 69 2f c5 98 69 30 39 70 0xed177f40: 69 2f b8 38 00 00 00 10 00 00 00 00 80 51 00 08 0xed177f50: 00 00 10 e4 00 00 00 02 69 2f be 9c 69 2f bf 38 0xed177f60: 00 00 00 00 69 6e 84 30 00 00 00 76 00 00 00 00 0xed177f70: 00 00 00 01 00 00 00 00 00 00 a7 37 00 00 00 00 0xed177f80: 00 00 b3 8b a7 36 45 19 00 00 00 10 69 2f b8 48 0xed177f90: 00 00 00 74 00 00 00 03 00 00 00 01 00 00 24 e4 0xed177fa0: 00 00 00 00 00 40 54 28 00 00 00 00 69 51 03 10 0xed177fb0: 69 6e 84 30 00 00 00 00 69 57 43 a0 69 2f be 60 0xed177fc0: 69 2f b8 00 69 6c fb cc 40 00 f8 13 00 00 00 00 0xed177fd0: cc cc cc ce 69 57 72 f0 00 80 00 20 69 51 03 58 0xed177fe0: 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 0xed177ff0: 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 0xed178000: e8 0c 13 80 80 4c b2 c4 00 10 00 00 72 25 f8 a0 0xed178010: 00 00 00 02 00 00 00 00 00 00 00 00 00 00 00 00 Call trace: Function Address = 0xf1d75dfc Function Address = 0xf1e5eadc Function Address = 0xf23bd558 Function Address = 0x80102cd8 --------------------- Reboot record 9 --------------------- Recorded at : 2021-03-11 16:36:03.824638 Occurred at : 2021-03-11 16:36:03.824638 Reason : 0x0 Thread : devd (TID: 141) Context : thread context Slot : 1 Cpu : 0 VCPU ID : 0 Kernel module info : module name (system) module address (0xf1b52000) module name (addon) module address (0xf010c000) Last 5 thread switches : devd (16:36:3.649122)--> dhcpd (16:36:3.702494)--> devd (16:36:3.702550)--> dhcpd (16:36:3.803390)--> devd (16:36:3.803418) Dump stack (total 1024 bytes, 16 bytes/line): 0xd689fc20: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0xd689fc30: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0xd689fc40: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0xd689fc50: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0xd689fc60: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0xd689fc70: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0xd689fc80: 00 00 00 00 d6 89 fc d0 80 51 00 90 d3 2f 80 00 0xd689fc90: 00 00 00 00 80 50 de e0 01 b4 00 00 80 17 49 e8 0xd689fca0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0xd689fcb0: 60 49 d6 73 31 26 fd dc 00 00 00 01 80 17 38 a8 0xd689fcc0: 00 00 00 00 80 12 06 1c 00 00 00 00 00 00 00 00 0xd689fcd0: 60 49 d6 73 00 0c 95 3e 80 54 00 00 d6 89 fc 20 0xd689fce0: 00 00 00 00 80 17 3e 14 74 00 00 00 00 00 00 00 0xd689fcf0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0xd689fd00: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0xd689fd10: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0xd689fd20: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0xd689fd30: 00 00 00 00 00 00 00 00 00 00 00 90 f1 b8 4f 30 0xd689fd40: 60 48 f5 6b 00 07 85 f8 e1 c5 e7 a8 00 00 00 06 0xd689fd50: 00 00 00 00 00 00 ff ff 00 00 ff ff 00 00 00 00 0xd689fd60: 00 00 ff ff 00 00 ff ff f2 fc 6c 24 f1 b6 e3 60 0xd689fd70: f2 99 00 00 f1 b6 78 40 00 00 00 00 d6 89 fe 0c 0xd689fd80: 22 22 22 22 00 00 ff ff 00 00 00 02 f2 99 42 80 0xd689fd90: 00 00 ff ff 00 00 ff ff 00 00 ff ff 00 00 00 00 0xd689fda0: 00 00 00 00 d3 41 5a 00 00 00 00 00 e0 20 99 38 0xd689fdb0: f3 00 f6 38 00 00 ff ff d6 89 fe f4 00 00 00 01 0xd689fdc0: 80 10 50 e0 00 00 00 00 80 10 54 20 00 40 54 28 0xd689fdd0: 6b 20 f0 18 f1 d7 5d fc d6 89 fe 18 00 00 00 01 0xd689fde0: 00 00 ff ff 00 00 ff ff d6 89 fe f4 00 00 00 00 0xd689fdf0: 80 10 50 e0 00 00 00 00 80 10 54 20 00 40 54 28 0xd689fe00: 00 00 ff ff f1 e5 ea dc e1 d6 3f 00 81 d5 f8 1c 0xd689fe10: 00 00 00 00 80 41 00 00 80 4d 32 f0 e1 d6 3f 00 0xd689fe20: 81 d5 f8 1c 80 1c ae bc 80 4d 32 f0 00 00 00 d0 0xd689fe30: 03 0f 00 01 f2 3b d6 60 e1 d6 3f 6c ff ff ff ff 0xd689fe40: ff ff ff ff 00 00 00 00 00 00 00 00 00 00 01 2f 0xd689fe50: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0xd689fe60: 00 00 00 00 00 00 00 00 00 00 00 00 00 40 54 28 0xd689fe70: 00 00 00 01 80 3a 3a 58 80 4d 32 f0 00 00 00 d0 0xd689fe80: 00 00 00 01 03 0f 00 01 80 4d 32 f0 00 00 00 00 0xd689fe90: 00 00 00 01 03 0f 00 01 00 00 00 40 80 1d 04 1c 0xd689fea0: 00 00 00 00 f1 de e1 38 e0 04 97 80 00 00 00 03 0xd689feb0: 82 04 e7 24 e1 d6 3f 00 f1 e5 e2 e0 f2 a8 00 00 0xd689fec0: 80 13 b6 e0 00 00 00 00 00 00 00 00 00 00 00 00 0xd689fed0: 00 40 54 28 f2 3b d5 58 00 00 00 00 80 1d 78 88 0xd689fee0: 00 00 00 39 e8 0f c5 40 00 00 00 00 d6 89 fe f4 0xd689fef0: 00 00 00 00 00 00 00 00 00 00 00 46 00 00 00 24 0xd689ff00: 6b 20 ef 38 00 00 00 00 00 00 00 00 6b 20 ee e8 0xd689ff10: 6b 20 ee 98 00 00 24 8d 00 00 00 00 00 00 00 00 0xd689ff20: 00 00 00 00 00 00 00 24 6b 20 ef b4 80 10 2c d8 0xd689ff30: 00 3d 0f 00 6b 20 f0 e0 6b 20 f5 98 6b 21 69 70 0xd689ff40: 6b 20 e8 38 00 00 00 10 00 00 00 00 ff ff ff fd 0xd689ff50: 00 00 10 e4 00 00 00 02 6b 20 ee 9c 6b 20 ef 38 0xd689ff60: 00 00 00 00 6b 5f b4 30 6b 48 c3 0c 6b 48 75 9c 0xd689ff70: f0 00 00 00 00 00 00 01 00 00 00 01 00 00 00 00 0xd689ff80: 00 00 1f 12 6b 69 07 64 6b 6d 0d 04 05 6a 5f 40 0xd689ff90: 6b 6d 0e 38 00 00 02 d5 6b 6d 02 b0 00 00 00 01 0xd689ffa0: 6b 68 2c e4 ff ff ff ff 00 00 01 33 6b 42 33 10 0xd689ffb0: 6b 5f b4 30 00 00 00 00 6b 48 73 a0 6b 20 ee 60 0xd689ffc0: 6b 20 ee 40 6b 5e 2b cc 00 00 f8 13 00 00 01 95 0xd689ffd0: 00 01 58 3d 6b 48 a2 f0 00 80 00 20 6b 42 33 58 0xd689ffe0: 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 0xd689fff0: 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 0xd68a0000: ed 12 27 00 80 4c b2 c4 00 10 00 00 6f b1 64 40 0xd68a0010: 00 00 00 02 00 00 00 00 80 00 00 00 00 00 00 00 Call trace: Function Address = 0xf1d75dfc Function Address = 0xf1e5eadc Function Address = 0xf23bd558 Function Address = 0x80102cd8 --------------------- Reboot record 10 --------------------- Recorded at : 2021-01-26 14:30:13.24930 Occurred at : 2021-01-26 14:30:13.24930 Reason : 0x0 Thread : devd (TID: 141) Context : thread context Slot : 1 Cpu : 0 VCPU ID : 2 Kernel module info : module name (system) module address (0xf1b52000) module name (addon) module address (0xf010c000) Last 5 thread switches : devd (14:30:12.939225)--> dhcpd (14:30:12.975192)--> devd (14:30:12.975221)--> events/2 (14:30:12.999879)--> devd (14:30:12.999894) Dump stack (total 1024 bytes, 16 bytes/line): 0xe92efc20: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0xe92efc30: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0xe92efc40: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0xe92efc50: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0xe92efc60: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0xe92efc70: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0xe92efc80: 00 00 00 00 e9 2e fc d0 80 51 00 98 d3 2f 90 80 0xe92efc90: 00 00 00 00 80 50 de e0 01 b4 a0 00 80 17 49 e8 0xe92efca0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0xe92efcb0: 60 0f b6 f5 01 7c 6a 22 00 00 00 01 80 17 38 a8 0xe92efcc0: 00 00 00 00 80 12 06 1c 00 00 00 00 00 00 00 00 0xe92efcd0: 60 0f b6 f5 00 00 61 62 80 54 00 00 e9 2e fc 20 0xe92efce0: 00 00 00 02 80 17 3e 14 74 00 00 00 00 00 00 00 0xe92efcf0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0xe92efd00: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0xe92efd10: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0xe92efd20: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0xe92efd30: 00 00 00 00 00 00 00 00 00 00 00 90 f1 b8 4f 30 0xe92efd40: 60 0e d5 ed 00 04 dc 8b e8 18 99 a0 00 00 00 06 0xe92efd50: 00 00 00 00 00 00 ff ff 00 00 ff ff 00 00 00 00 0xe92efd60: 00 00 ff ff 00 00 ff ff f2 fc 6c 24 f1 b6 e3 60 0xe92efd70: f2 99 00 00 f1 b6 78 40 00 00 00 00 e9 2e fe 0c 0xe92efd80: 22 22 22 22 00 00 ff ff 00 00 00 02 f2 99 42 80 0xe92efd90: 00 00 ff ff 00 00 ff ff 00 00 ff ff 00 00 00 00 0xe92efda0: 00 00 00 00 e9 2d 0d 00 00 00 00 00 e0 20 99 38 0xe92efdb0: f3 00 f6 38 00 00 ff ff e9 2e fe f4 00 00 00 01 0xe92efdc0: 80 10 50 e0 00 00 00 00 80 10 54 20 00 40 54 28 0xe92efdd0: 69 c7 80 18 f1 d7 5d fc e9 2e fe 18 00 00 00 01 0xe92efde0: 00 00 ff ff 00 00 ff ff e9 2e fe f4 00 00 00 00 0xe92efdf0: 80 10 50 e0 00 00 00 00 80 10 54 20 00 40 54 28 0xe92efe00: 00 00 ff ff f1 e5 ea dc cf 8d 0d 80 81 9a 8a 40 0xe92efe10: 00 00 00 00 80 41 00 00 80 4d 32 f0 cf 8d 0d 80 0xe92efe20: 81 9a 8a 40 80 1c ae bc 80 4d 32 f0 00 00 00 d0 0xe92efe30: 03 0f 00 01 f2 3b d6 60 cf 8d 0d ec ff ff ff ff 0xe92efe40: ff ff ff ff 00 00 00 00 00 00 00 00 00 00 01 2f 0xe92efe50: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0xe92efe60: 00 00 00 00 00 00 00 00 00 00 00 00 00 40 54 28 0xe92efe70: 00 00 00 01 80 3a 3a 58 80 4d 32 f0 00 00 00 d0 0xe92efe80: 00 00 00 01 03 0f 00 01 80 4d 32 f0 00 00 00 00 0xe92efe90: 00 00 00 01 03 0f 00 01 00 00 00 40 80 1d 04 1c 0xe92efea0: 00 00 00 00 f1 de e1 38 e0 09 d4 80 00 00 00 03 0xe92efeb0: 82 04 e7 24 cf 8d 0d 80 f1 e5 e2 e0 f2 a8 00 00 0xe92efec0: 80 13 b6 e0 00 00 00 00 00 00 00 00 00 00 00 00 0xe92efed0: 00 40 54 28 f2 3b d5 58 00 00 00 00 80 1d 78 88 0xe92efee0: 00 00 00 39 e8 0f c5 40 00 00 00 00 e9 2e fe f4 0xe92efef0: 00 00 00 00 00 00 00 00 00 00 00 46 00 00 00 24 0xe92eff00: 69 c7 7f 38 00 00 00 00 00 00 00 00 69 c7 7e e8 0xe92eff10: 69 c7 7e 98 00 00 03 fb 00 00 00 00 00 00 00 00 0xe92eff20: 00 00 00 00 00 00 00 24 69 c7 7f b4 80 10 2c d8 0xe92eff30: 00 3d 0f 00 69 c7 80 e0 69 c7 85 98 69 c7 f9 70 0xe92eff40: 69 c7 78 38 00 00 00 10 00 00 00 00 ff ff ff fd 0xe92eff50: 00 00 10 e4 00 00 00 02 69 c7 7e 9c 69 c7 7f 38 0xe92eff60: 00 00 00 00 6a 06 44 30 69 ef 53 0c 69 ef 05 9c 0xe92eff70: f0 00 00 00 00 00 00 01 00 00 00 01 00 00 00 00 0xe92eff80: 00 00 56 df 6a 0f 97 64 6a 13 9d 04 05 6a 5f 40 0xe92eff90: 6a 13 9e 38 00 00 02 d5 6a 13 92 b0 00 00 00 01 0xe92effa0: 6a 0e bc e4 ff ff ff ff 00 00 01 33 69 e8 c3 10 0xe92effb0: 6a 06 44 30 00 00 00 00 69 ef 03 a0 69 c7 7e 60 0xe92effc0: 69 c7 7e 40 6a 04 bb cc 00 00 f8 13 00 00 01 95 0xe92effd0: 00 01 58 3d 69 ef 32 f0 00 80 00 20 69 e8 c3 58 0xe92effe0: 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 0xe92efff0: 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 0xe92f0000: e8 11 c7 80 80 4c b2 c4 00 10 00 00 77 59 48 a0 0xe92f0010: 00 00 00 02 00 00 00 00 00 00 00 00 00 00 00 00 Call trace: Function Address = 0xf1d75dfc Function Address = 0xf1e5eadc Function Address = 0xf23bd558 Function Address = 0x80102cd8 --------------------- Reboot record 11 --------------------- Recorded at : 2021-01-25 14:06:02.363239 Occurred at : 2021-01-25 14:06:02.363239 Reason : 0x1 Thread : kdrvfwd7 (TID: 103) Context : thread context Slot : 1 Cpu : 0 VCPU ID : 7 Kernel module info : module name (system) module address (0xf1b52000) module name (addon) module address (0xf010c000) Last 5 thread switches : kdrvfwd7 (14:6:0.810577)--> watchdog/7 (14:6:1.762421)--> kdrvfwd7 (14:6:1.762431)--> events/7 (14:6:1.812081)--> kdrvfwd7 (14:6:1.812105) Dump stack (total 1024 bytes, 16 bytes/line): 0xd392ede8: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0xd392edf8: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0xd392ee08: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0xd392ee18: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0xd392ee28: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0xd392ee38: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0xd392ee48: 00 00 00 00 d3 92 ee 98 80 51 00 ac e8 03 42 00 0xd392ee58: 00 00 00 01 80 50 de e0 01 b6 30 00 80 17 49 e8 0xd392ee68: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0xd392ee78: 60 0e 5f ca 15 a6 96 da 00 00 00 01 80 17 38 a8 0xd392ee88: 00 00 00 00 80 12 06 1c 00 00 00 00 00 00 00 00 0xd392ee98: 60 0e 5f ca 00 05 8a e7 80 54 00 00 d3 92 ed e8 0xd392eea8: 00 00 00 07 80 17 3e 14 74 00 00 00 00 00 00 00 0xd392eeb8: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0xd392eec8: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0xd392eed8: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0xd392eee8: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0xd392eef8: 00 00 00 00 00 00 00 00 00 00 00 90 f1 b8 4f 30 0xd392ef08: 60 0d 7e c2 00 02 f2 26 e8 2a 5b 60 00 00 00 06 0xd392ef18: 00 00 00 01 00 00 00 01 00 00 ff ff 00 00 00 01 0xd392ef28: 00 00 00 01 00 00 ff ff f2 fc 6c 24 f1 b6 e3 60 0xd392ef38: f2 99 00 00 f1 b6 78 40 00 00 00 28 80 10 54 e8 0xd392ef48: ff ff ff ff 00 00 00 00 00 00 00 02 f2 99 42 80 0xd392ef58: 00 00 00 00 00 00 00 01 00 00 ff ff 00 00 00 01 0xd392ef68: 00 00 00 00 80 2a ff 88 80 40 1c 98 80 4c 00 00 0xd392ef78: f3 00 f6 38 80 51 00 ac 80 51 00 90 82 07 0f c0 0xd392ef88: 80 40 1c 98 80 4c 00 00 80 51 00 00 f1 b6 d5 90 0xd392ef98: 00 00 00 00 f1 d7 5d fc 00 00 00 01 00 00 00 00 0xd392efa8: d3 92 f0 d0 f1 d6 e8 34 80 51 00 90 80 50 df c0 0xd392efb8: 00 00 00 00 00 00 00 01 00 00 ff ff 00 00 00 01 0xd392efc8: 80 51 00 00 80 12 22 94 3c 34 3e 5b 00 00 00 00 0xd392efd8: 00 00 00 04 80 40 1c 98 00 00 00 02 80 14 b8 40 0xd392efe8: 00 00 00 04 d3 92 f0 d0 e8 17 5b 00 00 00 00 0b 0xd392eff8: f2 fc de 08 00 00 00 00 00 00 00 38 80 12 85 3c 0xd392f008: 00 00 00 00 00 00 00 07 00 00 00 08 00 00 00 04 0xd392f018: 00 00 00 08 f1 c7 72 cc 00 00 00 08 f1 b6 7a 50 0xd392f028: ff ff ff ff 00 03 00 01 00 01 00 4b 00 00 ff e7 0xd392f038: ff ff ff ff ff ff ff ff ff ff ff ff ff ff 00 00 0xd392f048: 00 02 00 32 00 00 ff e7 ff ff ff ff ff ff ff ff 0xd392f058: ff ff ff ff ff ff 00 00 00 03 00 19 00 00 ff e7 0xd392f068: ff ff ff ff ff ff ff ff ff ff ff ff 00 00 00 00 0xd392f078: 00 00 00 00 00 00 08 68 00 00 08 68 00 00 08 68 0xd392f088: e8 02 b0 c0 00 00 00 01 80 14 b8 20 f1 b6 be 8c 0xd392f098: 00 00 00 00 00 00 00 00 00 00 00 04 af 00 00 40 0xd392f0a8: 00 00 00 06 00 00 00 01 00 00 00 01 00 00 ff ff 0xd392f0b8: f2 fc 6c 24 f2 fc de 08 f2 99 00 00 f2 99 00 00 0xd392f0c8: f1 b6 d5 90 80 10 08 60 00 00 00 05 00 00 00 06 0xd392f0d8: 00 00 00 19 00 00 00 00 00 00 00 79 00 00 00 01 0xd392f0e8: 00 00 00 00 b8 00 42 40 00 00 00 00 00 00 00 01 0xd392f0f8: e8 02 b9 28 00 00 00 00 00 00 00 00 00 00 00 06 0xd392f108: 00 00 00 28 80 10 54 e8 ff ff ff ff ff ff 00 00 0xd392f118: 00 03 00 19 00 00 00 00 00 00 00 00 00 00 ff e7 0xd392f128: 00 00 00 01 00 00 00 01 00 00 ff ff f2 fc 6c 24 0xd392f138: f2 fc de 08 f2 99 00 00 f2 99 00 00 f1 b6 d5 90 0xd392f148: 00 00 00 00 f1 cf ce 20 d3 92 f1 58 00 00 00 00 0xd392f158: d3 92 80 00 d3 92 f1 80 00 00 00 00 f1 b6 7a 50 0xd392f168: 10 00 f8 03 00 00 05 75 91 68 77 77 00 00 00 04 0xd392f178: 00 80 00 08 f1 c7 72 cc f2 33 eb 00 f1 bc 33 3c 0xd392f188: f1 cf b0 14 f1 cf b9 78 80 16 8f 10 80 11 da 90 0xd392f198: 00 00 00 00 00 00 00 00 00 00 00 01 00 00 00 01 0xd392f1a8: 00 00 ff ff f2 fc 6c 24 f1 b6 e3 60 f2 99 00 00 0xd392f1b8: f2 99 00 00 f1 b6 d5 90 00 00 00 00 f1 b6 7a 50 0xd392f1c8: 00 00 00 28 80 10 54 e8 ff ff ff ff 00 00 00 00 0xd392f1d8: 00 00 00 02 f2 99 42 80 00 00 00 00 00 00 00 01 Call trace: Function Address = 0xf1d75dfc Function Address = 0x80122294 Function Address = 0x8012853c Function Address = 0x80100860 Function Address = 0xf1c772cc Function Address = 0xf1b67a50 Function Address = 0xf1d75dfc Function Address = 0x80122294 Function Address = 0x8012853c Function Address = 0x80100860 Function Address = 0xf28f241c Function Address = 0xf28f53e8 Function Address = 0xf2222644 Function Address = 0xf205914c Function Address = 0xf232cef0 Function Address = 0xf233e73c Function Address = 0xf233eb00 Function Address = 0xf1bc333c Function Address = 0xf1cfb014 Function Address = 0xf1cfb978 --------------------- Reboot record 12 --------------------- Recorded at : 2021-01-25 14:05:53.907757 Occurred at : 2021-01-25 14:05:53.907757 Reason : 0x1 Thread : kdrvfwd7 (TID: 103) Context : thread context Slot : 1 Cpu : 0 VCPU ID : 7 Kernel module info : module name (system) module address (0xf1b52000) module name (addon) module address (0xf010c000) Last 5 thread switches : kdrvfwd7 (14:5:52.790557)--> watchdog/7 (14:5:53.180237)--> kdrvfwd7 (14:5:53.180252)--> events/7 (14:5:53.793192)--> kdrvfwd7 (14:5:53.793217) Dump stack (total 1024 bytes, 16 bytes/line): 0xd392f070: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0xd392f080: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0xd392f090: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0xd392f0a0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0xd392f0b0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0xd392f0c0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0xd392f0d0: 00 00 00 00 d3 92 f1 20 80 51 00 ac e8 03 42 00 0xd392f0e0: 00 00 00 01 80 50 de e0 01 b6 30 00 80 17 49 e8 0xd392f0f0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0xd392f100: 60 0e 5f c1 36 1b 47 94 00 00 00 01 80 17 38 a8 0xd392f110: 00 00 00 00 80 12 06 1c 00 00 00 00 00 00 00 00 0xd392f120: 60 0e 5f c1 00 0d d9 ed 80 54 00 00 d3 92 f0 70 0xd392f130: 00 00 00 07 80 17 3e 14 74 00 00 00 00 00 00 00 0xd392f140: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0xd392f150: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0xd392f160: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0xd392f170: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0xd392f180: 00 00 00 00 00 00 00 00 00 00 00 90 f1 b8 4f 30 0xd392f190: 60 0d 7e b9 00 02 ab f4 e8 2a 5b 60 00 00 00 06 0xd392f1a0: 00 00 00 01 00 00 00 01 00 00 ff ff 00 00 00 01 0xd392f1b0: 00 00 00 01 00 00 ff ff f2 fc 6c 24 f1 b6 e3 60 0xd392f1c0: f2 99 00 00 f1 b6 78 40 00 00 00 28 80 10 54 e8 0xd392f1d0: ff ff ff ff 00 00 00 00 00 00 00 02 f2 99 42 80 0xd392f1e0: 00 00 00 00 00 00 00 01 00 00 ff ff 00 00 00 01 0xd392f1f0: 00 00 00 00 80 2a ff 88 80 40 1c 98 80 4c 00 00 0xd392f200: f3 00 f6 38 80 51 00 ac 80 51 00 90 82 07 0f c0 0xd392f210: 80 40 1c 98 80 4c 00 00 80 51 00 00 00 00 01 7a 0xd392f220: f3 02 b1 d8 f1 d7 5d fc 00 00 00 01 00 00 00 00 0xd392f230: d3 92 f3 58 f1 d6 e8 34 80 51 00 90 80 50 df c0 0xd392f240: 00 00 00 00 00 00 00 01 00 00 ff ff 00 00 00 01 0xd392f250: 80 51 00 00 80 12 22 94 82 07 26 28 00 00 00 00 0xd392f260: 00 00 00 04 80 40 1c 98 00 00 00 01 80 14 b8 40 0xd392f270: 5a 5a 5c 26 d3 92 f3 58 e8 17 5b 00 00 00 00 0b 0xd392f280: e1 fa 28 90 00 00 00 00 00 00 00 38 80 12 85 3c 0xd392f290: e8 25 aa 18 00 00 00 07 00 00 00 08 5a 5a 5c 26 0xd392f2a0: 00 00 00 08 f2 8f 24 1c 00 00 00 08 f2 8f 23 ec 0xd392f2b0: d3 92 f2 b0 00 03 00 01 f1 de f3 50 00 00 01 00 0xd392f2c0: 00 00 00 07 e8 25 ac 18 e8 25 ae 18 80 4c e3 80 0xd392f2d0: 82 07 26 28 d3 ed 40 00 80 4c e3 80 00 00 00 00 0xd392f2e0: 80 4c e3 80 80 4c 70 c8 00 00 00 10 00 00 00 0a 0xd392f2f0: 80 50 e5 94 80 50 db 00 80 51 00 90 80 15 42 88 0xd392f300: 00 00 00 00 80 4c 76 40 00 00 00 07 80 19 61 04 0xd392f310: 80 51 00 ac d3 ed 40 00 00 00 00 00 c0 5b be 40 0xd392f320: 00 00 00 00 d3 92 f4 c0 e1 fa 28 90 d3 92 f4 e4 0xd392f330: 00 00 00 00 d3 92 fd 40 c0 5b be 40 00 00 00 00 0xd392f340: d3 92 f4 c0 e1 fa 28 90 d3 92 f4 e4 00 00 00 00 0xd392f350: 00 00 01 7a 80 10 08 60 00 00 00 01 f2 4b ec b0 0xd392f360: d3 92 f3 c8 00 00 6e bc 00 00 6e bc d3 92 f4 50 0xd392f370: 00 00 00 00 b8 00 42 40 c3 44 66 04 5a 5a 5c 22 0xd392f380: 5a 5a 5a 5a 00 00 01 c0 00 00 17 50 d3 92 fd 40 0xd392f390: 00 00 b0 51 80 10 55 0c 00 00 00 00 00 00 00 00 0xd392f3a0: 00 00 00 01 00 00 00 00 00 00 43 ba 3f 13 3a be 0xd392f3b0: d3 92 fd 40 c0 5b be 40 00 00 00 00 d3 92 f4 c0 0xd392f3c0: e1 fa 28 90 d3 92 f4 e4 00 00 00 00 00 00 01 7a 0xd392f3d0: 00 00 00 00 f1 dc 27 80 d3 92 f4 e4 f2 8d 50 44 0xd392f3e0: d3 92 80 00 d3 92 f4 08 f3 02 b1 d8 f2 8f 23 ec 0xd392f3f0: 10 00 f8 03 00 00 00 03 1f 7f 0d c4 5a 5a 5c 26 0xd392f400: 00 80 00 08 f2 8f 24 1c f2 4c 7d bc 80 3a 3c 58 0xd392f410: 85 10 00 00 ca ef 79 ce 85 10 00 00 83 e0 cb d4 0xd392f420: 85 10 00 00 f2 4c 7d e4 86 a2 3b 80 ca ef 79 da 0xd392f430: ca ef 79 de ca ef 79 e2 ff ff ff ff 00 20 43 20 0xd392f440: 00 00 00 00 01 00 0a 0a 00 00 00 00 00 00 00 00 0xd392f450: 00 00 00 00 00 00 00 00 00 00 01 00 00 00 00 00 0xd392f460: 00 00 00 1f 00 00 00 07 00 00 00 07 00 00 00 00 Call trace: Function Address = 0xf1d75dfc Function Address = 0x80122294 Function Address = 0x8012853c Function Address = 0x80100860 Function Address = 0xf28f241c Function Address = 0xf28f53e8 Function Address = 0xf2222644 Function Address = 0xf205914c Function Address = 0xf232cef0 Function Address = 0xf233e73c Function Address = 0xf233eb00 Function Address = 0xf1bc333c Function Address = 0xf1cfb014 Function Address = 0xf1cfb978 Function Address = 0x80168f10 Function Address = 0x8011da90 --------------------- Reboot record 13 --------------------- Recorded at : 2021-01-06 10:02:27.708827 Occurred at : 2021-01-06 10:02:27.708827 Reason : 0x0 Thread : devd (TID: 143) Context : thread context Slot : 1 Cpu : 0 VCPU ID : 2 Kernel module info : module name (system) module address (0xf1b52000) module name (addon) module address (0xf010c000) Last 5 thread switches : devd (10:2:27.519200)--> dhcpd (10:2:27.537064)--> devd (10:2:27.537098)--> dhcpd (10:2:27.638752)--> devd (10:2:27.638780) Dump stack (total 1024 bytes, 16 bytes/line): 0xd68d7c20: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0xd68d7c30: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0xd68d7c40: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0xd68d7c50: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0xd68d7c60: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0xd68d7c70: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0xd68d7c80: 00 00 00 00 d6 8d 7c d0 80 51 00 98 d3 2e a1 00 0xd68d7c90: 00 00 00 00 80 50 de e0 01 b4 a0 00 80 17 49 e8 0xd68d7ca0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0xd68d7cb0: 5f f5 1a 33 2a 3f db 24 00 00 00 01 80 17 38 a8 0xd68d7cc0: 00 00 00 00 80 12 06 1c 00 00 00 00 00 00 00 00 0xd68d7cd0: 5f f5 1a 33 00 0a d0 db 80 54 00 00 d6 8d 7c 20 0xd68d7ce0: 00 00 00 02 80 17 3e 14 74 00 00 00 00 00 00 00 0xd68d7cf0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0xd68d7d00: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0xd68d7d10: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0xd68d7d20: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0xd68d7d30: 00 00 00 00 00 00 00 00 00 00 00 90 f1 b8 4f 30 0xd68d7d40: 5f f4 39 2c 00 03 d3 d6 e8 24 4b 98 00 00 00 06 0xd68d7d50: 00 00 00 00 00 00 ff ff 00 00 ff ff 00 00 00 00 0xd68d7d60: 00 00 ff ff 00 00 ff ff f2 fc 6c 24 f1 b6 e3 60 0xd68d7d70: f2 99 00 00 f1 b6 78 40 00 00 00 00 d6 8d 7e 0c 0xd68d7d80: 22 22 22 22 00 00 ff ff 00 00 00 02 f2 99 42 80 0xd68d7d90: 00 00 ff ff 00 00 ff ff 00 00 ff ff 00 00 00 00 0xd68d7da0: 00 00 00 00 d3 3f 8d 00 00 00 00 00 e0 00 08 f8 0xd68d7db0: f3 00 f6 38 00 00 ff ff d6 8d 7e f4 00 00 00 01 0xd68d7dc0: 80 10 50 e0 00 00 00 00 80 10 54 20 00 40 54 28 0xd68d7dd0: 75 a3 a0 18 f1 d7 5d fc d6 8d 7e 18 00 00 00 01 0xd68d7de0: 00 00 ff ff 00 00 ff ff d6 8d 7e f4 00 00 00 00 0xd68d7df0: 80 10 50 e0 00 00 00 00 80 10 54 20 00 40 54 28 0xd68d7e00: 00 00 ff ff f1 e5 ea dc c5 41 88 00 81 79 14 e0 0xd68d7e10: 00 00 00 00 80 41 00 00 80 4d 32 f0 c5 41 88 00 0xd68d7e20: 81 79 14 e0 80 1c ae bc 80 4d 32 f0 00 00 00 d0 0xd68d7e30: 03 0f 00 01 f2 3b d6 60 c5 41 88 6c ff ff ff ff 0xd68d7e40: ff ff ff ff 00 00 00 00 00 00 00 00 00 00 01 2f 0xd68d7e50: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0xd68d7e60: 00 00 00 00 00 00 00 00 00 00 00 00 00 40 54 28 0xd68d7e70: 00 00 00 01 80 3a 3a 58 80 4d 32 f0 00 00 00 d0 0xd68d7e80: 00 00 00 01 03 0f 00 01 80 4d 32 f0 00 00 00 00 0xd68d7e90: 00 00 00 01 03 0f 00 01 00 00 00 40 80 1d 04 1c 0xd68d7ea0: 00 00 00 00 f1 de e1 38 e0 0e 28 40 00 00 00 03 0xd68d7eb0: 82 05 3a 1c c5 41 88 00 f1 e5 e2 e0 f2 a8 00 00 0xd68d7ec0: 80 13 b6 e0 00 00 00 00 00 00 00 00 00 00 00 00 0xd68d7ed0: 00 40 54 28 f2 3b d5 58 00 00 00 00 80 1d 78 88 0xd68d7ee0: 00 00 00 39 e8 05 65 40 00 00 00 00 d6 8d 7e f4 0xd68d7ef0: 00 00 00 00 00 00 00 00 00 00 00 46 00 00 00 24 0xd68d7f00: 75 a3 9f 38 00 00 00 00 00 00 00 00 75 a3 9e e8 0xd68d7f10: 75 a3 9e 98 00 00 0b 62 00 00 00 00 00 00 00 00 0xd68d7f20: 00 00 00 00 00 00 00 24 75 a3 9f b4 80 10 2c d8 0xd68d7f30: 00 3d 0f 00 75 a3 a0 e0 75 a3 a5 98 75 a4 19 70 0xd68d7f40: 75 a3 98 38 00 00 00 10 00 00 00 00 00 00 00 01 0xd68d7f50: 00 00 10 e4 00 00 00 02 75 a3 9e 9c 75 a3 9f 38 0xd68d7f60: 00 00 00 00 75 e2 64 30 00 00 00 00 00 00 00 00 0xd68d7f70: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0xd68d7f80: 00 00 00 00 00 00 00 00 0e 3d ed 78 75 a3 7e a4 0xd68d7f90: 00 00 00 01 00 00 00 00 00 00 00 90 00 01 00 0a 0xd68d7fa0: 00 00 00 00 00 40 54 28 00 00 00 00 75 c4 e3 10 0xd68d7fb0: 75 e2 64 30 00 00 00 00 75 cb 23 a0 75 a3 9e 60 0xd68d7fc0: 75 a3 a0 18 75 e0 db cc 00 00 f8 13 00 00 02 c8 0xd68d7fd0: 00 03 4e d8 75 a3 80 00 00 80 00 20 75 c4 e3 58 0xd68d7fe0: 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 0xd68d7ff0: 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 0xd68d8000: 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 02 0xd68d8010: 00 00 00 01 00 00 00 61 00 00 00 01 ff ff 00 00 Call trace: Function Address = 0xf1d75dfc Function Address = 0xf1e5eadc Function Address = 0xf23bd558 Function Address = 0x80102cd8 --------------------- Reboot record 14 --------------------- Recorded at : 2020-12-03 08:07:01.701536 Occurred at : 2020-12-03 08:07:01.701536 Reason : 0x0 Thread : devd (TID: 143) Context : thread context Slot : 1 Cpu : 0 VCPU ID : 0 Kernel module info : module name (system) module address (0xf1b52000) module name (addon) module address (0xf010c000) Last 5 thread switches : devd (8:7:1.526351)--> stamgrd (8:7:1.626075)--> devd (8:7:1.626155)--> events/0 (8:7:1.682131)--> devd (8:7:1.682170) Dump stack (total 1024 bytes, 16 bytes/line): 0xe907fc20: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0xe907fc30: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0xe907fc40: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0xe907fc50: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0xe907fc60: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0xe907fc70: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0xe907fc80: 00 00 00 00 e9 07 fc d0 80 51 00 90 d3 2e 90 80 0xe907fc90: 00 00 00 00 80 50 de e0 01 b4 00 00 80 17 49 e8 0xe907fca0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0xe907fcb0: 5f c8 2c 25 29 d0 98 63 00 00 00 01 80 17 38 a8 0xe907fcc0: 00 00 00 00 80 12 06 1c 00 00 00 00 00 00 00 00 0xe907fcd0: 5f c8 2c 25 00 0a b4 60 80 54 00 00 e9 07 fc 20 0xe907fce0: 00 00 00 00 80 17 3e 14 74 00 00 00 00 00 00 00 0xe907fcf0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0xe907fd00: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0xe907fd10: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0xe907fd20: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0xe907fd30: 00 00 00 00 00 00 00 00 00 00 00 90 f1 b8 4f 30 0xe907fd40: 5f c7 4b 1e 00 01 eb 89 e8 00 98 50 00 00 00 06 0xe907fd50: 00 00 00 00 00 00 ff ff 00 00 ff ff 00 00 00 00 0xe907fd60: 00 00 ff ff 00 00 ff ff f2 fc 6c 24 f1 b6 e3 60 0xe907fd70: f2 99 00 00 f1 b6 78 40 00 00 00 00 e9 07 fe 0c 0xe907fd80: 22 22 22 22 00 00 ff ff 00 00 00 02 f2 99 42 80 0xe907fd90: 00 00 ff ff 00 00 ff ff 00 00 ff ff 00 00 00 00 0xe907fda0: 00 00 00 00 d5 01 20 00 00 00 00 00 e0 28 2b 80 0xe907fdb0: f3 00 f6 38 00 00 ff ff e9 07 fe f4 00 00 00 01 0xe907fdc0: 80 10 50 e0 00 00 00 00 80 10 54 20 00 40 54 28 0xe907fdd0: 76 da b0 18 f1 d7 5d fc e9 07 fe 18 00 00 00 01 0xe907fde0: 00 00 ff ff 00 00 ff ff e9 07 fe f4 00 00 00 00 0xe907fdf0: 80 10 50 e0 00 00 00 00 80 10 54 20 00 40 54 28 0xe907fe00: 00 00 ff ff f1 e5 ea dc c5 28 78 80 81 78 c3 6c 0xe907fe10: 00 00 00 00 80 41 00 00 80 4d 32 f0 c5 28 78 80 0xe907fe20: 81 78 c3 6c 80 1c ae bc 80 4d 32 f0 00 00 00 d0 0xe907fe30: 03 0f 00 01 f2 3b d6 60 c5 28 78 ec ff ff ff ff 0xe907fe40: ff ff ff ff 00 00 00 00 00 00 00 00 00 00 01 2f 0xe907fe50: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0xe907fe60: 00 00 00 00 00 00 00 00 00 00 00 00 00 40 54 28 0xe907fe70: 00 00 00 01 80 3a 3a 58 80 4d 32 f0 00 00 00 d0 0xe907fe80: 00 00 00 01 03 0f 00 01 80 4d 32 f0 00 00 00 00 0xe907fe90: 00 00 00 01 03 0f 00 01 00 00 00 40 80 1d 04 1c 0xe907fea0: 00 00 00 00 f1 de e1 38 e0 0e a8 40 00 00 00 03 0xe907feb0: 82 05 3a 1c c5 28 78 80 f1 e5 e2 e0 f2 a8 00 00 0xe907fec0: 80 13 b6 e0 00 00 00 00 00 00 00 00 00 00 00 00 0xe907fed0: 00 40 54 28 f2 3b d5 58 00 00 00 00 80 1d 78 88 0xe907fee0: 00 00 00 39 e8 0f c6 80 00 00 00 00 e9 07 fe f4 0xe907fef0: 00 00 00 00 00 00 00 00 00 00 00 46 00 00 00 24 0xe907ff00: 76 da af 38 00 00 00 00 00 00 00 00 76 da ae e8 0xe907ff10: 76 da ae 98 00 00 03 fb 00 00 00 00 00 00 00 00 0xe907ff20: 00 00 00 00 00 00 00 24 76 da af b4 80 10 2c d8 0xe907ff30: 00 3d 0f 00 76 da b0 e0 76 da b5 98 76 db 29 70 0xe907ff40: 76 da a8 38 00 00 00 10 00 00 00 00 ff ff ff fd 0xe907ff50: 00 00 10 e4 00 00 00 02 76 da ae 9c 76 da af 38 0xe907ff60: 00 00 00 00 77 19 74 30 77 02 83 0c 77 02 35 9c 0xe907ff70: f0 00 00 00 00 00 00 01 00 00 00 00 76 da a6 28 0xe907ff80: 00 00 00 10 77 22 c7 64 77 26 cd 04 05 6a 5f 40 0xe907ff90: 77 26 ce 38 00 00 02 d5 77 26 c2 b0 00 00 00 01 0xe907ffa0: 77 21 ec e4 ff ff ff ff 00 00 01 33 76 fb f3 10 0xe907ffb0: 77 19 74 30 00 00 00 00 77 02 33 a0 76 da ae 60 0xe907ffc0: 76 da ae 40 77 17 eb cc 00 00 f8 13 00 00 01 95 0xe907ffd0: 00 01 58 3d 77 02 62 f0 00 80 00 20 76 fb f3 58 0xe907ffe0: 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 0xe907fff0: 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 0xe9080000: e9 2f 9a 00 80 4c b2 c4 00 10 00 00 6a ae 24 40 0xe9080010: 00 00 00 01 00 00 00 00 80 00 00 00 00 00 00 00 Call trace: Function Address = 0xf1d75dfc Function Address = 0xf1e5eadc Function Address = 0xf23bd558 Function Address = 0x80102cd8 --------------------- Reboot record 15 --------------------- Recorded at : 2020-08-07 11:46:30.681411 Occurred at : 2020-08-07 11:46:30.681411 Reason : 0x0 Thread : devd (TID: 143) Context : thread context Slot : 1 Cpu : 0 VCPU ID : 0 Kernel module info : module name (system) module address (0xf1b52000) module name (addon) module address (0xf010c000) Last 5 thread switches : devd (11:46:30.611075)--> stamgrd (11:46:30.614088)--> devd (11:46:30.614350)--> stamgrd (11:46:30.620339)--> devd (11:46:30.620468) Dump stack (total 1024 bytes, 16 bytes/line): 0xd68bfc20: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0xd68bfc30: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0xd68bfc40: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0xd68bfc50: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0xd68bfc60: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0xd68bfc70: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0xd68bfc80: 00 00 00 00 d6 8b fc d0 80 51 00 90 d3 30 80 00 0xd68bfc90: 00 00 00 00 80 50 de e0 01 b4 00 00 80 17 49 e8 0xd68bfca0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0xd68bfcb0: 5f 2c ce 96 28 9d 83 90 00 00 00 01 80 17 38 a8 0xd68bfcc0: 00 00 00 00 80 12 06 1c 00 00 00 00 00 00 00 00 0xd68bfcd0: 5f 2c ce 96 00 0a 65 c3 80 54 00 00 d6 8b fc 20 0xd68bfce0: 00 00 00 00 80 17 3e 14 74 00 00 00 00 00 00 00 0xd68bfcf0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0xd68bfd00: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0xd68bfd10: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0xd68bfd20: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0xd68bfd30: 00 00 00 00 00 00 00 00 00 00 00 90 f1 b8 4f 30 0xd68bfd40: 5f 2b ed 95 00 01 e6 17 e4 29 92 a0 00 00 00 06 0xd68bfd50: 00 00 00 00 00 00 ff ff 00 00 ff ff 00 00 00 00 0xd68bfd60: 00 00 ff ff 00 00 ff ff f2 fc 6c 24 f1 b6 e3 60 0xd68bfd70: f2 99 00 00 f1 b6 78 40 00 00 00 00 d6 8b fe 0c 0xd68bfd80: 22 22 22 22 00 00 ff ff 00 00 00 02 f2 99 42 80 0xd68bfd90: 00 00 ff ff 00 00 ff ff 00 00 ff ff 00 00 00 00 0xd68bfda0: 00 00 00 00 d3 44 88 00 00 00 00 00 e0 00 04 e8 0xd68bfdb0: f3 00 f6 38 00 00 ff ff d6 8b fe f4 00 00 00 01 0xd68bfdc0: 80 10 50 e0 00 00 00 00 80 10 54 20 00 40 54 28 0xd68bfdd0: 72 ef 70 18 f1 d7 5d fc d6 8b fe 18 00 00 00 01 0xd68bfde0: 00 00 ff ff 00 00 ff ff d6 8b fe f4 00 00 00 00 0xd68bfdf0: 80 10 50 e0 00 00 00 00 80 10 54 20 00 40 54 28 0xd68bfe00: 00 00 ff ff f1 e5 ea dc c3 58 3a 00 81 72 de 9c 0xd68bfe10: 00 00 00 00 80 41 00 00 80 4d 32 f0 c3 58 3a 00 0xd68bfe20: 81 72 de 9c 80 1c ae bc 80 4d 32 f0 00 00 00 d0 0xd68bfe30: 03 0f 00 01 f2 3b d6 60 c3 58 3a 6c ff ff ff ff 0xd68bfe40: ff ff ff ff 00 00 00 00 00 00 00 00 00 00 01 2f 0xd68bfe50: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0xd68bfe60: 00 00 00 00 00 00 00 00 00 00 00 00 00 40 54 28 0xd68bfe70: 00 00 00 01 80 3a 3a 58 80 4d 32 f0 00 00 00 d0 0xd68bfe80: 00 00 00 01 03 0f 00 01 80 4d 32 f0 00 00 00 00 0xd68bfe90: 00 00 00 01 03 0f 00 01 00 00 00 40 80 1d 04 1c 0xd68bfea0: 00 00 00 00 f1 de e1 38 e0 0e a6 c0 00 00 00 03 0xd68bfeb0: 82 04 e7 24 c3 58 3a 00 f1 e5 e2 e0 f2 a8 00 00 0xd68bfec0: 80 13 b6 e0 00 00 00 00 00 00 00 00 00 00 00 00 0xd68bfed0: 00 40 54 28 f2 3b d5 58 00 00 00 00 80 1d 78 88 0xd68bfee0: 00 00 00 39 e8 0f c6 80 00 00 00 00 d6 8b fe f4 0xd68bfef0: 00 00 00 00 00 00 00 00 00 00 00 46 00 00 00 24 0xd68bff00: 72 ef 6f 38 00 00 00 00 00 00 00 00 72 ef 6e e8 0xd68bff10: 72 ef 6e 98 00 00 03 fb 00 00 00 00 00 00 00 00 0xd68bff20: 00 00 00 00 00 00 00 24 72 ef 6f b4 80 10 2c d8 0xd68bff30: 00 3d 0f 00 72 ef 70 e0 72 ef 75 98 72 ef e9 70 0xd68bff40: 72 ef 68 38 00 00 00 10 00 00 00 00 00 00 00 01 0xd68bff50: 00 00 10 e4 00 00 00 02 72 ef 6e 9c 72 ef 6f 38 0xd68bff60: 00 00 00 00 73 2e 34 30 00 00 00 00 00 00 00 00 0xd68bff70: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0xd68bff80: 00 00 00 00 00 00 00 00 05 3f 8d 78 72 ef 4e a4 0xd68bff90: 00 00 00 01 00 00 00 00 00 00 00 90 00 01 00 0a 0xd68bffa0: 00 00 00 00 00 40 54 28 00 00 00 00 73 10 b3 10 0xd68bffb0: 73 2e 34 30 00 00 00 00 73 16 f3 a0 72 ef 6e 60 0xd68bffc0: 72 ef 70 18 73 2c ab cc 00 00 f8 13 00 00 02 c8 0xd68bffd0: 00 03 4e d8 72 ef 50 00 00 80 00 20 73 10 b3 58 0xd68bffe0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0xd68bfff0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0xd68c0000: 00 53 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0xd68c0010: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Call trace: Function Address = 0xf1d75dfc Function Address = 0xf1e5eadc Function Address = 0xf23bd558 Function Address = 0x80102cd8 --------------------- Reboot record 16 --------------------- Recorded at : 2020-03-11 09:24:06.215143 Occurred at : 2020-03-11 09:24:06.215143 Reason : 0x1 Thread : swapper (TID: 0) Context : irq context Slot : 1 Cpu : 0 VCPU ID : 0 Kernel module info : module name (system) module address (0xf1832000) module name (addon) module address (0xf010c000) Last 5 thread switches : swapper (9:24:6.60663)--> pppd (9:24:6.106776)--> swapper (9:24:6.106840)--> pppd (9:24:6.127543)--> swapper (9:24:6.127602) Dump stack (total 1024 bytes, 16 bytes/line): 0x80467f70: 80 4d 55 70 00 00 00 01 00 00 00 00 80 55 00 00 0x80467f80: 80 55 00 00 80 4e 0e 84 00 00 00 00 00 00 00 01 0x80467f90: 00 00 00 00 ff ff ff ff 80 4e 12 e8 00 00 00 00 0x80467fa0: 80 51 49 50 00 00 00 00 82 10 00 00 82 14 00 00 0x80467fb0: 82 14 00 00 00 00 00 00 00 00 00 00 82 14 60 10 0x80467fc0: 8c 01 f8 98 8c 08 52 50 00 00 00 02 82 10 13 a0 0x80467fd0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x80467fe0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x80467ff0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x80468000: 00 00 00 00 80 46 00 00 00 00 00 02 00 00 00 00 0x80468010: 00 00 00 00 ff ff ff ff 00 00 00 01 00 00 00 8c 0x80468020: 00 00 00 78 00 00 00 8c 80 40 87 3c 00 00 00 00 0x80468030: 00 00 04 00 00 40 00 00 00 00 00 00 00 00 00 00 0x80468040: 00 00 00 00 80 46 80 44 80 46 80 44 00 00 00 00 0x80468050: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x80468060: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x80468070: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x80468080: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x80468090: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x804680a0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x804680b0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x804680c0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x804680d0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x804680e0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x804680f0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x80468100: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x80468110: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x80468120: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x80468130: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x80468140: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x80468150: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x80468160: 00 00 00 00 00 00 00 00 00 00 00 00 82 04 f0 00 0x80468170: 00 00 00 00 00 00 00 00 80 46 81 78 80 46 81 78 0x80468180: 00 00 03 e8 00 00 00 00 00 00 00 20 00 00 00 00 0x80468190: 00 00 00 00 00 00 00 00 00 00 00 01 00 00 00 00 0x804681a0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x804681b0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x804681c0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x804681d0: e8 04 01 d0 eb d0 a8 d0 80 46 81 d8 80 46 81 d8 0x804681e0: 80 46 81 e0 80 46 81 e0 00 00 00 00 d3 38 63 00 0x804681f0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x80468200: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x80468210: 00 00 00 00 80 46 80 00 80 46 80 00 e8 04 02 24 0x80468220: e8 04 08 a4 80 46 82 24 80 46 82 24 80 46 80 00 0x80468230: 00 00 00 00 80 4c cf 14 80 4c cf 10 00 00 00 00 0x80468240: e8 04 08 bc 80 4c cf 10 00 00 00 00 e8 04 08 c8 0x80468250: 80 4c cf 10 00 00 00 00 00 00 00 00 00 00 00 00 0x80468260: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x80468270: 00 02 21 40 00 00 00 00 00 02 21 40 00 00 00 00 0x80468280: 00 00 00 00 00 00 00 00 00 00 00 00 00 01 d3 54 0x80468290: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x804682a0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x804682b0: 00 00 00 00 00 00 00 00 80 46 82 b8 80 46 82 b8 0x804682c0: 80 46 82 c0 80 46 82 c0 80 46 82 c8 80 46 82 c8 0x804682d0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x804682e0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x804682f0: 80 4c cc 24 ff ff ff ff ff ff ff ff 00 00 00 00 0x80468300: 00 00 00 00 ff ff ff ff ff ff ff ff ff ff ff ff 0x80468310: ff ff ff ff 00 00 00 00 80 4c cb bc 73 77 61 70 0x80468320: 70 65 72 00 00 00 00 00 00 00 00 00 00 00 00 00 0x80468330: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x80468340: 80 46 80 00 ec 86 1a 00 82 04 ef c0 80 51 00 70 0x80468350: 80 50 ef c0 80 51 51 80 80 46 82 8c 80 50 ef c0 0x80468360: 80 46 7e e8 00 00 00 01 80 3a 06 d0 50 00 f8 00 Call trace: Function Address = 0xf1a664cc Function Address = 0x8014b724 Function Address = 0x801222d8 Function Address = 0x801284ec Function Address = 0x80100860 Function Address = 0xf19bca0c Function Address = 0xf1847670 Function Address = 0xf1a664cc Function Address = 0x80122244 Function Address = 0x80123378 Function Address = 0x80100fe0 --------------------- Reboot record 17 --------------------- Recorded at : 2020-03-11 09:24:06.173272 Occurred at : 2020-03-11 09:24:06.173272 Reason : 0x1 Thread : swapper (TID: 0) Context : irq context Slot : 1 Cpu : 0 VCPU ID : 0 Kernel module info : module name (system) module address (0xf1832000) module name (addon) module address (0xf010c000) Last 5 thread switches : swapper (9:24:6.60663)--> pppd (9:24:6.106776)--> swapper (9:24:6.106840)--> pppd (9:24:6.127543)--> swapper (9:24:6.127602) Dump stack (total 1024 bytes, 16 bytes/line): 0x80467f70: 80 4d 55 70 00 00 00 01 00 00 00 00 80 55 00 00 0x80467f80: 80 55 00 00 80 4e 0e 84 00 00 00 00 00 00 00 01 0x80467f90: 00 00 00 00 ff ff ff ff 80 4e 12 e8 00 00 00 00 0x80467fa0: 80 51 49 50 00 00 00 00 82 10 00 00 82 14 00 00 0x80467fb0: 82 14 00 00 00 00 00 00 00 00 00 00 82 14 60 10 0x80467fc0: 8c 01 f8 98 8c 08 52 50 00 00 00 02 82 10 13 a0 0x80467fd0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x80467fe0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x80467ff0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x80468000: 00 00 00 00 80 46 00 00 00 00 00 02 00 00 00 00 0x80468010: 00 00 00 00 ff ff ff ff 00 00 00 01 00 00 00 8c 0x80468020: 00 00 00 78 00 00 00 8c 80 40 87 3c 00 00 00 00 0x80468030: 00 00 04 00 00 40 00 00 00 00 00 00 00 00 00 00 0x80468040: 00 00 00 00 80 46 80 44 80 46 80 44 00 00 00 00 0x80468050: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x80468060: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x80468070: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x80468080: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x80468090: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x804680a0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x804680b0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x804680c0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x804680d0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x804680e0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x804680f0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x80468100: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x80468110: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x80468120: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x80468130: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x80468140: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x80468150: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x80468160: 00 00 00 00 00 00 00 00 00 00 00 00 82 04 f0 00 0x80468170: 00 00 00 00 00 00 00 00 80 46 81 78 80 46 81 78 0x80468180: 00 00 03 e8 00 00 00 00 00 00 00 20 00 00 00 00 0x80468190: 00 00 00 00 00 00 00 00 00 00 00 01 00 00 00 00 0x804681a0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x804681b0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x804681c0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x804681d0: e8 04 01 d0 eb d0 a8 d0 80 46 81 d8 80 46 81 d8 0x804681e0: 80 46 81 e0 80 46 81 e0 00 00 00 00 d3 38 63 00 0x804681f0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x80468200: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x80468210: 00 00 00 00 80 46 80 00 80 46 80 00 e8 04 02 24 0x80468220: e8 04 08 a4 80 46 82 24 80 46 82 24 80 46 80 00 0x80468230: 00 00 00 00 80 4c cf 14 80 4c cf 10 00 00 00 00 0x80468240: e8 04 08 bc 80 4c cf 10 00 00 00 00 e8 04 08 c8 0x80468250: 80 4c cf 10 00 00 00 00 00 00 00 00 00 00 00 00 0x80468260: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x80468270: 00 02 21 3a 00 00 00 00 00 02 21 3a 00 00 00 00 0x80468280: 00 00 00 00 00 00 00 00 00 00 00 00 00 01 d3 54 0x80468290: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x804682a0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x804682b0: 00 00 00 00 00 00 00 00 80 46 82 b8 80 46 82 b8 0x804682c0: 80 46 82 c0 80 46 82 c0 80 46 82 c8 80 46 82 c8 0x804682d0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x804682e0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x804682f0: 80 4c cc 24 ff ff ff ff ff ff ff ff 00 00 00 00 0x80468300: 00 00 00 00 ff ff ff ff ff ff ff ff ff ff ff ff 0x80468310: ff ff ff ff 00 00 00 00 80 4c cb bc 73 77 61 70 0x80468320: 70 65 72 00 00 00 00 00 00 00 00 00 00 00 00 00 0x80468330: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x80468340: 80 46 80 00 ec 86 1a 00 82 04 ef c0 80 51 00 70 0x80468350: 80 50 ef c0 80 51 51 80 80 46 82 8c 80 50 ef c0 0x80468360: 80 46 7e e8 00 00 00 01 80 3a 06 d0 50 00 f8 00 Call trace: Function Address = 0xf1a664cc Function Address = 0x80122244 Function Address = 0x80123378 Function Address = 0x80100fe0 --------------------- Reboot record 18 --------------------- Recorded at : 2022-12-04 04:39:42.626134 Occurred at : 2022-12-04 04:39:42.626134 Reason : 0x1 Thread : swapper (TID: 0) Context : irq context Slot : 1 Cpu : 0 VCPU ID : 0 Kernel module info : module name (system) module address (0xf1832000) module name (addon) module address (0xf010c000) Last 5 thread switches : swapper (4:39:42.560200)--> nqad (4:39:42.570160)--> swapper (4:39:42.570200)--> nqad (4:39:42.580160)--> swapper (4:39:42.580200) Dump stack (total 1024 bytes, 16 bytes/line): 0x80467f70: 80 4d 55 70 00 00 00 01 00 00 00 00 80 55 00 00 0x80467f80: 80 55 00 00 80 4e 0e 84 00 00 00 00 00 00 00 01 0x80467f90: 00 00 00 00 ff ff ff ff 80 4e 12 e8 00 00 00 00 0x80467fa0: 80 51 49 50 00 00 00 00 82 10 00 00 82 14 00 00 0x80467fb0: 82 14 00 00 00 00 00 00 00 00 00 00 82 14 60 10 0x80467fc0: 8c 01 f8 98 8c 08 52 50 00 00 00 02 82 10 13 a0 0x80467fd0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x80467fe0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x80467ff0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x80468000: 00 00 00 00 80 46 00 00 00 00 00 02 00 00 00 00 0x80468010: 00 00 00 00 ff ff ff ff 00 00 00 01 00 00 00 8c 0x80468020: 00 00 00 78 00 00 00 8c 80 40 87 3c 00 00 00 00 0x80468030: 00 00 04 00 00 40 00 00 00 00 00 00 00 00 00 00 0x80468040: 00 00 00 00 80 46 80 44 80 46 80 44 00 00 00 00 0x80468050: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x80468060: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x80468070: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x80468080: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x80468090: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x804680a0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x804680b0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x804680c0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x804680d0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x804680e0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x804680f0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x80468100: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x80468110: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x80468120: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x80468130: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x80468140: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x80468150: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x80468160: 00 00 00 00 00 00 00 00 00 00 00 00 82 04 f0 00 0x80468170: 00 00 00 00 00 00 00 00 80 46 81 78 80 46 81 78 0x80468180: 00 00 03 e8 00 00 00 00 00 00 00 20 00 00 00 00 0x80468190: 00 00 00 00 00 00 00 00 00 00 00 01 00 00 00 00 0x804681a0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x804681b0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x804681c0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x804681d0: e8 04 01 d0 c2 20 d6 50 80 46 81 d8 80 46 81 d8 0x804681e0: 80 46 81 e0 80 46 81 e0 00 00 00 00 d3 37 d6 80 0x804681f0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x80468200: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x80468210: 00 00 00 00 80 46 80 00 80 46 80 00 e8 04 02 24 0x80468220: e8 04 08 a4 80 46 82 24 80 46 82 24 80 46 80 00 0x80468230: 00 00 00 00 80 4c cf 14 80 4c cf 10 00 00 00 00 0x80468240: e8 04 08 bc 80 4c cf 10 00 00 00 00 e8 04 08 c8 0x80468250: 80 4c cf 10 00 00 00 00 00 00 00 00 00 00 00 00 0x80468260: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x80468270: 00 07 87 b3 00 00 00 00 00 07 87 b3 00 00 00 00 0x80468280: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 75 c2 0x80468290: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x804682a0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x804682b0: 00 00 00 00 00 00 00 00 80 46 82 b8 80 46 82 b8 0x804682c0: 80 46 82 c0 80 46 82 c0 80 46 82 c8 80 46 82 c8 0x804682d0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x804682e0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x804682f0: 80 4c cc 24 ff ff ff ff ff ff ff ff 00 00 00 00 0x80468300: 00 00 00 00 ff ff ff ff ff ff ff ff ff ff ff ff 0x80468310: ff ff ff ff 00 00 00 00 80 4c cb bc 73 77 61 70 0x80468320: 70 65 72 00 00 00 00 00 00 00 00 00 00 00 00 00 0x80468330: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x80468340: 80 46 80 00 eb 48 e8 00 82 04 ef c0 80 51 00 70 0x80468350: 80 50 ef c0 80 51 51 80 80 46 82 8c 80 50 ef c0 0x80468360: 80 46 7e e8 00 00 00 01 80 3a 06 d0 10 00 f8 00 Call trace: Function Address = 0xf1a664cc Function Address = 0x8014b724 Function Address = 0x801222d8 Function Address = 0x801284ec Function Address = 0x80100860 Function Address = 0xf19bca0c Function Address = 0xf1847670 Function Address = 0xf1a664cc Function Address = 0x80122244 Function Address = 0x80123378 Function Address = 0x80100fe0 --------------------- Reboot record 19 --------------------- Recorded at : 2022-12-04 04:39:42.584313 Occurred at : 2022-12-04 04:39:42.584313 Reason : 0x1 Thread : swapper (TID: 0) Context : irq context Slot : 1 Cpu : 0 VCPU ID : 0 Kernel module info : module name (system) module address (0xf1832000) module name (addon) module address (0xf010c000) Last 5 thread switches : swapper (4:39:42.560200)--> nqad (4:39:42.570160)--> swapper (4:39:42.570200)--> nqad (4:39:42.580160)--> swapper (4:39:42.580200) Dump stack (total 1024 bytes, 16 bytes/line): 0x80467f70: 80 4d 55 70 00 00 00 01 00 00 00 00 80 55 00 00 0x80467f80: 80 55 00 00 80 4e 0e 84 00 00 00 00 00 00 00 01 0x80467f90: 00 00 00 00 ff ff ff ff 80 4e 12 e8 00 00 00 00 0x80467fa0: 80 51 49 50 00 00 00 00 82 10 00 00 82 14 00 00 0x80467fb0: 82 14 00 00 00 00 00 00 00 00 00 00 82 14 60 10 0x80467fc0: 8c 01 f8 98 8c 08 52 50 00 00 00 02 82 10 13 a0 0x80467fd0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x80467fe0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x80467ff0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x80468000: 00 00 00 00 80 46 00 00 00 00 00 02 00 00 00 00 0x80468010: 00 00 00 00 ff ff ff ff 00 00 00 01 00 00 00 8c 0x80468020: 00 00 00 78 00 00 00 8c 80 40 87 3c 00 00 00 00 0x80468030: 00 00 04 00 00 40 00 00 00 00 00 00 00 00 00 00 0x80468040: 00 00 00 00 80 46 80 44 80 46 80 44 00 00 00 00 0x80468050: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x80468060: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x80468070: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x80468080: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x80468090: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x804680a0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x804680b0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x804680c0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x804680d0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x804680e0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x804680f0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x80468100: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x80468110: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x80468120: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x80468130: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x80468140: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x80468150: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x80468160: 00 00 00 00 00 00 00 00 00 00 00 00 82 04 f0 00 0x80468170: 00 00 00 00 00 00 00 00 80 46 81 78 80 46 81 78 0x80468180: 00 00 03 e8 00 00 00 00 00 00 00 20 00 00 00 00 0x80468190: 00 00 00 00 00 00 00 00 00 00 00 01 00 00 00 00 0x804681a0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x804681b0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x804681c0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x804681d0: e8 04 01 d0 c2 20 d6 50 80 46 81 d8 80 46 81 d8 0x804681e0: 80 46 81 e0 80 46 81 e0 00 00 00 00 d3 37 d6 80 0x804681f0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x80468200: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x80468210: 00 00 00 00 80 46 80 00 80 46 80 00 e8 04 02 24 0x80468220: e8 04 08 a4 80 46 82 24 80 46 82 24 80 46 80 00 0x80468230: 00 00 00 00 80 4c cf 14 80 4c cf 10 00 00 00 00 0x80468240: e8 04 08 bc 80 4c cf 10 00 00 00 00 e8 04 08 c8 0x80468250: 80 4c cf 10 00 00 00 00 00 00 00 00 00 00 00 00 0x80468260: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x80468270: 00 07 87 ad 00 00 00 00 00 07 87 ad 00 00 00 00 0x80468280: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 75 c2 0x80468290: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x804682a0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x804682b0: 00 00 00 00 00 00 00 00 80 46 82 b8 80 46 82 b8 0x804682c0: 80 46 82 c0 80 46 82 c0 80 46 82 c8 80 46 82 c8 0x804682d0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x804682e0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x804682f0: 80 4c cc 24 ff ff ff ff ff ff ff ff 00 00 00 00 0x80468300: 00 00 00 00 ff ff ff ff ff ff ff ff ff ff ff ff 0x80468310: ff ff ff ff 00 00 00 00 80 4c cb bc 73 77 61 70 0x80468320: 70 65 72 00 00 00 00 00 00 00 00 00 00 00 00 00 0x80468330: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x80468340: 80 46 80 00 eb 48 e8 00 82 04 ef c0 80 51 00 70 0x80468350: 80 50 ef c0 80 51 51 80 80 46 82 8c 80 50 ef c0 0x80468360: 80 46 7e e8 00 00 00 01 80 3a 06 d0 10 00 f8 00 Call trace: Function Address = 0xf1a664cc Function Address = 0x80122244 Function Address = 0x80123378 Function Address = 0x80100fe0 ================================================ ===============monitor process dumbtty=============== 159 processes; 230 threads; 2225 fds Thread states: 6 running, 224 sleeping, 0 stopped, 0 zombie CPU0 states: 81.34% idle, 5.22% user, 13.43% kernel, 0.00% interrupt CPU1 states: 70.14% idle, 3.73% user, 23.13% kernel, 2.98% interrupt CPU2 states: 74.07% idle, 22.96% user, 2.22% kernel, 0.74% interrupt CPU3 states: 91.04% idle, 0.00% user, 5.97% kernel, 2.98% interrupt CPU4 states: 92.59% idle, 0.00% user, 5.92% kernel, 1.48% interrupt CPU5 states: 93.28% idle, 0.00% user, 5.22% kernel, 1.49% interrupt CPU6 states: 95.48% idle, 0.00% user, 3.75% kernel, 0.75% interrupt CPU7 states: 98.50% idle, 0.00% user, 1.49% kernel, 0.00% interrupt Memory: 953M total, 179M available, page size 4K JID PID PRI State FDs MEM HH:MM:SS CPU Name 136 136 120 S 17 10936K 00:01:09 5.58% diagd 99 99 115 R 0 0K 00:02:16 1.61% [kdrvfwd3] 100 100 115 R 0 0K 00:06:19 1.17% [kdrvfwd4] 101 101 115 R 0 0K 00:03:21 1.02% [kdrvfwd5] 102 102 115 R 0 0K 00:03:42 0.88% [kdrvfwd6] 103 103 115 R 0 0K 00:02:29 0.44% [kdrvfwd7] 159 159 120 S 148 49352K 00:02:48 0.44% apmgrd 28 28 115 S 0 0K 00:00:16 0.14% [events/1] 127 127 115 S 0 0K 00:00:23 0.14% [kdrs] 140 140 120 S 14 13332K 00:00:04 0.14% devd 204 204 120 S 160 45696K 00:01:24 0.14% stamgrd 218 218 120 S 91 74932K 00:00:14 0.14% pppd 227 227 120 S 22 31532K 00:04:19 0.14% drsd 230 230 120 S 32 22532K 00:00:27 0.14% lldpd 232 232 120 S 19 18844K 00:00:27 0.14% nqad 235 235 120 S 86 49736K 00:00:05 0.14% portald 237 237 120 S 67 49536K 00:00:02 0.14% portsecd 239 239 120 S 23 16384K 00:00:37 0.14% rrmd 1155 1155 120 S 31 2476K 00:00:00 0.14% top 1 1 120 S 18 10688K 00:02:06 0.00% scmd 2 2 115 S 0 0K 00:00:00 0.00% [kthreadd] 3 3 99 S 0 0K 00:00:00 0.00% [migration/0] 4 4 115 S 0 0K 00:00:01 0.00% [ksoftirqd/0] 5 5 99 S 0 0K 00:00:00 0.00% [watchdog/0] 6 6 99 S 0 0K 00:00:00 0.00% [migration/1] 7 7 115 S 0 0K 00:00:01 0.00% [ksoftirqd/1] 8 8 99 S 0 0K 00:00:00 0.00% [watchdog/1] 9 9 99 S 0 0K 00:00:00 0.00% [migration/2] 10 10 115 S 0 0K 00:00:01 0.00% [ksoftirqd/2] 11 11 99 S 0 0K 00:00:00 0.00% [watchdog/2] 12 12 99 S 0 0K 00:00:00 0.00% [migration/3] 13 13 115 S 0 0K 00:00:00 0.00% [ksoftirqd/3] 14 14 99 S 0 0K 00:00:00 0.00% [watchdog/3] 15 15 99 S 0 0K 00:00:00 0.00% [migration/4] 16 16 115 S 0 0K 00:00:00 0.00% [ksoftirqd/4] 17 17 99 S 0 0K 00:00:00 0.00% [watchdog/4] 18 18 99 S 0 0K 00:00:00 0.00% [migration/5] 19 19 115 S 0 0K 00:00:00 0.00% [ksoftirqd/5] 20 20 99 S 0 0K 00:00:00 0.00% [watchdog/5] 21 21 99 S 0 0K 00:00:00 0.00% [migration/6] 22 22 115 S 0 0K 00:00:00 0.00% [ksoftirqd/6] 23 23 99 S 0 0K 00:00:00 0.00% [watchdog/6] 24 24 99 S 0 0K 00:00:00 0.00% [migration/7] 25 25 115 S 0 0K 00:00:00 0.00% [ksoftirqd/7] 26 26 99 S 0 0K 00:00:00 0.00% [watchdog/7] 27 27 115 S 0 0K 00:00:00 0.00% [events/0] 29 29 115 S 0 0K 00:00:00 0.00% [events/2] 30 30 115 S 0 0K 00:00:00 0.00% [events/3] 31 31 115 S 0 0K 00:00:00 0.00% [events/4] 32 32 115 S 0 0K 00:00:00 0.00% [events/5] 33 33 115 S 0 0K 00:00:00 0.00% [events/6] 34 34 115 S 0 0K 00:00:00 0.00% [events/7] 35 35 115 S 0 0K 00:00:00 0.00% [khelper] 36 36 115 S 0 0K 00:00:00 0.00% [kblockd/0] 37 37 115 S 0 0K 00:00:00 0.00% [kblockd/1] 38 38 115 S 0 0K 00:00:00 0.00% [kblockd/2] 39 39 115 S 0 0K 00:00:00 0.00% [kblockd/3] 40 40 115 S 0 0K 00:00:00 0.00% [kblockd/4] 41 41 115 S 0 0K 00:00:00 0.00% [kblockd/5] 42 42 115 S 0 0K 00:00:00 0.00% [kblockd/6] 43 43 115 S 0 0K 00:00:00 0.00% [kblockd/7] 44 44 115 S 0 0K 00:00:00 0.00% [khubd] 45 45 120 S 0 0K 00:00:00 0.00% [vzmond] 46 46 120 S 0 0K 00:00:00 0.00% [pdflush] 47 47 120 S 0 0K 00:00:00 0.00% [pdflush] 48 48 115 S 0 0K 00:00:00 0.00% [kswapd0] 49 49 115 S 0 0K 00:00:00 0.00% [aio/0] 50 50 115 S 0 0K 00:00:00 0.00% [aio/1] 51 51 115 S 0 0K 00:00:00 0.00% [aio/2] 52 52 115 S 0 0K 00:00:00 0.00% [aio/3] 53 53 115 S 0 0K 00:00:00 0.00% [aio/4] 54 54 115 S 0 0K 00:00:00 0.00% [aio/5] 55 55 115 S 0 0K 00:00:00 0.00% [aio/6] 56 56 115 S 0 0K 00:00:00 0.00% [aio/7] 57 57 115 S 0 0K 00:00:00 0.00% [mtdblockd] 73 73 115 S 0 0K 00:00:00 0.00% [kmmcd] 74 74 115 S 0 0K 00:00:02 0.00% [spi-xlp.0] 88 88 115 S 0 0K 00:00:00 0.00% [fshe] 106 106 100 D 0 0K 00:00:00 0.00% [lipc_topology] 108 108 120 S 0 0K 00:00:00 0.00% [LOAD] 109 109 120 S 0 0K 00:00:00 0.00% [LOADProc] 110 110 120 S 0 0K 00:00:00 0.00% [timesyncs] 111 111 115 S 0 0K 00:00:00 0.00% [lipc_portevt] 112 112 115 S 0 0K 00:00:00 0.00% [kuserlog] 113 113 105 S 0 0K 00:00:00 0.00% [kevent] 114 114 125 S 0 0K 00:00:00 0.00% [kifupdown] 115 115 115 S 0 0K 00:00:00 0.00% [MinishellMain] 116 116 120 S 0 0K 00:00:03 0.00% [kmac/1] 117 117 120 S 0 0K 00:00:00 0.00% [kipfs/1] 118 118 120 S 0 0K 00:00:00 0.00% [kip6fs/1] 119 119 115 S 0 0K 00:00:00 0.00% [ktcp_proxy/1/0] 120 120 115 S 0 0K 00:00:00 0.00% [ktcp_proxy/1/1] 121 121 115 S 0 0K 00:00:00 0.00% [ktcp_proxy/1/2] 122 122 115 S 0 0K 00:00:00 0.00% [ktcp_proxy/1/32] 123 123 115 S 0 0K 00:00:00 0.00% [ktcp_proxy/1/33] 124 124 115 S 0 0K 00:00:00 0.00% [ktcp_proxy/1/34] 125 125 105 S 0 0K 00:00:01 0.00% [sock/1] 126 126 115 S 0 0K 00:00:00 0.00% [UFLT_KTHREAD1] 129 129 110 S 6 1744K 00:00:00 0.00% cioctld 130 130 120 S 14 10132K 00:00:00 0.00% fsd 132 132 120 S 11 4948K 00:00:00 0.00% licd 133 133 100 S 137 43468K 00:00:13 0.00% dbmd 135 135 120 S 9 2188K 00:00:00 0.00% drvdiagd 138 138 105 S 58 1852K 00:00:00 0.00% had 139 139 120 S 25 14080K 00:00:13 0.00% syslogd 143 143 120 S 21 56408K 00:00:02 0.00% ifmgr 144 144 120 S 14 13284K 00:00:00 0.00% edev 147 147 120 S 8 5812K 00:00:00 0.00% drvciud 156 156 120 S 15 9496K 00:00:01 0.00% moduleproxyd 157 157 120 S 98 68248K 00:00:05 0.00% ofcd 158 158 115 S 13 5044K 00:00:00 0.00% trackd 160 160 120 S 11 5380K 00:00:00 0.00% sysmand 161 161 120 S 26 30104K 00:01:00 0.00% lauthd 162 162 120 S 12 3872K 00:00:00 0.00% ttymgrd 163 163 120 S 40 7684K 00:00:01 0.00% aaad 164 164 110 S 34 40220K 00:00:02 0.00% laggd 165 165 120 S 17 1900K 00:00:00 0.00% tranged 166 166 120 S 13 13972K 00:00:05 0.00% vland 167 167 120 S 20 3980K 00:00:00 0.00% cryptomgrd 175 175 120 S 45 29692K 00:00:03 0.00% aclmgrd 190 190 120 S 45 23808K 00:00:01 0.00% qosd 193 193 125 S 24 2420K 00:00:01 0.00% ipcimd 194 194 120 S 28 13660K 00:00:01 0.00% ethd 195 195 110 S 14 2016K 00:00:00 0.00% coppd 199 199 120 S 14 57000K 00:00:28 0.00% comsh 213 213 110 S 28 12648K 00:00:20 0.00% maintaind 216 216 120 S 24 12292K 00:00:01 0.00% dnsd 219 219 120 S 9 2084K 00:00:00 0.00% appprofiled 220 220 120 S 21 19576K 00:00:08 0.00% aprd 221 221 120 S 25 18144K 00:00:02 0.00% cmtnlmgrd 223 223 120 S 22 14408K 00:00:02 0.00% ddrd 224 224 125 S 44 28932K 00:00:03 0.00% dhcpd 225 225 125 S 13 7684K 00:00:00 0.00% dhcpcd 226 226 120 S 38 22836K 00:00:10 0.00% dpid 228 228 125 S 55 26540K 00:00:06 0.00% httpd 229 229 125 S 85 14400K 00:00:01 0.00% ipstackd 231 231 120 S 26 3752K 00:00:00 0.00% natd 233 233 120 S 12 3864K 00:00:00 0.00% nqasd 234 234 125 S 15 14144K 00:00:01 0.00% ntpd 238 238 120 S 30 27372K 00:00:00 0.00% routed 240 240 120 S 25 16728K 00:00:00 0.00% sessiond 241 241 119 S 16 4948K 00:00:00 0.00% telnetd 242 242 119 S 10 4928K 00:00:00 0.00% telnetd 243 243 120 S 38 100480K 00:00:48 0.00% xmlcfgd 244 244 120 S 8 2628K 00:00:00 0.00% scheduler 253 253 120 S 29 17472K 00:00:00 0.00% staticrtd 257 257 115 S 0 0K 00:00:09 0.00% [karp/1] 258 258 115 S 0 0K 00:00:01 0.00% [kwadj/1] 259 259 115 S 0 0K 00:00:00 0.00% [kfib/1] 289 289 100 S 0 0K 00:00:00 0.00% [loop0] 292 292 100 S 0 0K 00:00:00 0.00% [loop1] 295 295 100 S 0 0K 00:00:00 0.00% [loop2] 297 297 100 S 0 0K 00:00:00 0.00% [loop3] 300 300 100 S 0 0K 00:00:00 0.00% [loop4] 1127 1127 120 S 19 17312K 00:00:01 0.00% sshd 1141 1141 120 S 33 61064K 00:00:03 0.00% comsh 1143 1143 120 S 34 69280K 00:00:00 0.00% comsh 1145 1145 120 S 31 2376K 00:00:01 0.00% gzip 1146 1146 120 S 35 70396K 00:00:03 0.00% comsh ============================================================ ===============display memory=============== Memory statistics are measured in KB: Slot 1: Total Used Free Shared Buffers Cached FreeRatio Mem: 976164 792516 183648 0 1948 191736 18.8% -/+ Buffers/Cache: 598832 377332 Swap: 0 0 0 =============================================== ===============display placement location all=============== ========================================================== ===============display placement policy program all=============== =========================================================== ===============boot-loader infomation=============== Software images on the device: Current software images: flash:/boot.bin flash:/system.bin Main startup software images: flash:/boot.bin flash:/system.bin Backup startup software images: NOne==================================================================== ===============debugging infomation=============== ==================================================================== ===============info-center infomation=============== Information Center: Enabled Console: Enabled Monitor: Enabled Log host: Enabled Log buffer: Enabled Max buffer size 1024, current buffer size 512 Current messages 512, dropped messages 0, overwritten messages 1910 Log file: Disabled Security log file: Disabled Information timestamp format: Log host: Date Other output destination: Date ==================================================================== ===============logfile summary infomation=============== Log file: Disabled Log file size quota: 10 MB Log file directory: flash:/logfile Writing frequency: 24 hour 0 min 0 sec ==================================================================== ===============install active infomation=============== Active packages on the device: flash:/boot.bin flash:/system.bin ==================================================================== ===============install committed infomation=============== Committed packages on the device: flash:/boot.bin flash:/system.bin ==================================================================== ===============install package all infomation=============== flash:/system.bin [Package] Vendor: H3C Product: MSG360-40 Service name: system Platform version: 7.1.064 Product version: Release 5272 Supported board: mpu flash:/boot.bin [Package] Vendor: H3C Product: MSG360-40 Service name: boot Platform version: 7.1.064 Product version: Release 5272 Supported board: mpu ==================================================================== ===============license infomation=============== ==================================================================== ===============startup infomation=============== Current startup saved-configuration file: flash:/startup.cfg Next main startup saved-configuration file: flash:/startup.cfg Next backup startup saved-configuration file: NULL ==================================================================== ===============users infomation=============== Idx Line Idle Time Pid Type + : Current operation user. F : Current operation user works in async mode. =============================================== ===============printk irq trace info =============== ===============printk scm log =============== [2011-01-01 00:00:04] insmod pid is 64. [2011-01-01 00:00:04] insmod pid is 76. [2022-03-19 01:41:00] The service CIOCTL is starting... [2022-03-19 01:41:00] The service FS is starting... [2022-03-19 01:41:00] The service CIOCTL is running... [2022-03-19 01:41:00] The service FS is running... [2022-03-19 01:41:00] The service LICD is starting... [2022-03-19 01:41:00] The service DBM is starting... [2022-03-19 01:41:01] The service LICD is running... [2022-03-19 01:41:01] The service DBM is running... [2022-03-19 01:41:01] The service DRVDIAGD is starting... [2022-03-19 01:41:01] The service DIAG is starting... [2022-03-19 01:41:01] The service MDC is starting... [2022-03-19 01:41:01] The service HA is starting... [2022-03-19 01:41:01] The service HA is running... [2022-03-19 01:41:01] The service SYSLOG is starting... [2022-03-19 01:41:01] The service MDC is running... [2022-03-19 01:41:01] The service MDC is stopping... [2022-03-19 01:41:01] The service MDC is stopped... [2022-03-19 01:41:01] The service DIAG is running... [2022-03-19 01:41:01] The service DEV is starting... [2022-03-19 09:41:01] The service DRVDIAGD is running... [2022-03-19 09:41:01] The service DEV is running... [2022-03-19 09:41:01] The service FIPS is starting... [2022-03-19 09:41:01] The service IFMGR is starting... [2022-03-19 09:41:01] The service EDEV is starting... [2022-03-19 09:41:01] The service SYSLOG is running... [2022-03-19 09:41:01] The service DRVCIU is starting... [2022-03-19 09:41:01] The service DRVCIU is running... [2022-03-19 09:41:02] The service FIPS is running... [2022-03-19 09:41:02] The service FIPS is stopped... [2022-03-19 09:41:02] The service IFMGR is running... [2022-03-19 09:41:02] The service KNPHASE1 is starting... [2022-03-19 09:41:02] The service KNPHASE1 is running... [2022-03-19 09:41:02] The service KNPHASE1BOTTOMHALF is starting... [2022-03-19 09:41:02] The service KNPHASE1 is stopped... [2022-03-19 09:41:02] The service KNPHASE1BOTTOMHALF is running... [2022-03-19 09:41:02] The service KNPHASE1BOTTOMHALF is stopped... [2022-03-19 09:41:02] The service EDEV is running... [2022-03-19 09:41:02] kernel load cost 2 seconds. [2022-03-19 09:41:02] System service initialization completed, took 1 second. [2022-03-19 09:41:02] begin send sig of phase end 2 event. [2022-03-19 09:41:02] The service MDPROXY is starting... [2022-03-19 09:41:02] The service OFC is starting... [2022-03-19 09:41:02] The service TRACK is starting... [2022-03-19 09:41:02] The service APMGR is starting... [2022-03-19 09:41:02] The service SYSMAN is starting... [2022-03-19 09:41:02] The service LOCAL-SERVER is starting... [2022-03-19 09:41:02] The service TTYMGR is starting... [2022-03-19 09:41:02] The service AAA is starting... [2022-03-19 09:41:02] The service LAGG is starting... [2022-03-19 09:41:02] The service TRANGE is starting... [2022-03-19 09:41:02] The service VLAN is starting... [2022-03-19 09:41:02] The service CRYPTOMGR is starting... [2022-03-19 09:41:02] The service TRACK is running... [2022-03-19 09:41:02] The service SYSMAN is running... [2022-03-19 09:41:02] The service TRANGE is running... [2022-03-19 09:41:02] The service ACL is starting... [2022-03-19 09:41:03] The service TTYMGR is running... [2022-03-19 09:41:03] The service LAGG is running... [2022-03-19 09:41:03] The service OFC is running... [2022-03-19 09:41:03] The service CRYPTOMGR is running... [2022-03-19 09:41:03] The service MDPROXY is running... [2022-03-19 09:41:03] The service ACL is running... [2022-03-19 09:41:03] The service QOS is starting... [2022-03-19 09:41:03] The service VLAN is running... [2022-03-19 09:41:03] The service KNPHASE2 is starting... [2022-03-19 09:41:03] The service IPCIM is starting... [2022-03-19 09:41:03] The service ETH is starting... [2022-03-19 09:41:03] The service COPP is starting... [2022-03-19 09:41:03] The service KNPHASE2 is running... [2022-03-19 09:41:03] The service KNPHASE2 is stopped... [2022-03-19 09:41:03] The service COPP is running... [2022-03-19 09:41:03] The service IPCIM is running... [2022-03-19 09:41:04] The service AAA is running... [2022-03-19 09:41:04] The service ETH is running... [2022-03-19 09:41:04] The service COMSH-SERVER is starting... [2022-03-19 09:41:04] The service QOS is running... [2022-03-19 09:41:05] The service APMGR is running... [2022-03-19 09:41:05] The service STAMGR is starting... [2022-03-19 09:41:07] The service STAMGR is running... [2022-03-19 09:41:32] The service COMSH-SERVER is running... [2022-03-19 09:42:03] The service LOCAL-SERVER is running... [2022-03-19 09:42:03] Autorun service initialization completed, took 61 seconds. [2022-03-19 09:42:03] The service MAINTAIN is starting... [2022-03-19 09:42:03] The service recover is starting... [2022-03-19 09:42:03] The service pkg_upgrade is starting... [2022-03-19 09:42:03] begin send sig of phase end 3 event. [2022-03-19 09:42:03] send sig of phase end event of pid 159 ret:0 [2022-03-19 09:42:03] The service DNS is starting... [2022-03-19 09:42:03] The service PPP is starting... [2022-03-19 09:42:03] The service APPPROFILE is starting... [2022-03-19 09:42:03] The service APR is starting... [2022-03-19 09:42:03] The service CMTNLMGR is starting... [2022-03-19 09:42:03] The service DDR is starting... [2022-03-19 09:42:03] The service DHCP is starting... [2022-03-19 09:42:03] The service DHCPC is starting... [2022-03-19 09:42:03] The service DPI is starting... [2022-03-19 09:42:03] The service DRS is starting... [2022-03-19 09:42:03] The service HTTP is starting... [2022-03-19 09:42:03] The service IPStack is starting... [2022-03-19 09:42:04] The service LLDP is starting... [2022-03-19 09:42:04] The service NAT is starting... [2022-03-19 09:42:04] The service NQA is starting... [2022-03-19 09:42:04] The service NQAS is starting... [2022-03-19 09:42:04] The service NTP is starting... [2022-03-19 09:42:04] The service PORTAL is starting... [2022-03-19 09:42:04] The service PORTSEC is starting... [2022-03-19 09:42:04] The service ROUTE4 is starting... [2022-03-19 09:42:04] The service RRM is starting... [2022-03-19 09:42:04] The service SESSION is starting... [2022-03-19 09:42:04] The service TELNET is starting... [2022-03-19 09:42:04] The service TELNET is starting... [2022-03-19 09:42:04] The service XMLCFGD is starting... [2022-03-19 09:42:04] The service scheduler is starting... [2022-03-19 09:42:04] The service APPPROFILE is running... [2022-03-19 09:42:04] The service DNS is running... [2022-03-19 09:42:04] The service NQAS is running... [2022-03-19 09:42:04] The service MAINTAIN is running... [2022-03-19 09:42:04] The service CMTNLMGR is running... [2022-03-19 09:42:04] The service DDR is running... [2022-03-19 09:42:04] The service TELNET is running... [2022-03-19 09:42:04] The service scheduler is running... [2022-03-19 09:42:04] The service TELNET is running... [2022-03-19 09:42:04] The service NAT is running... [2022-03-19 09:42:04] The service ROUTE4 is running... [2022-03-19 09:42:04] The service STATICRT4 is starting... [2022-03-19 09:42:05] The service NQA is running... [2022-03-19 09:42:05] The service NTP is running... [2022-03-19 09:42:05] The service STATICRT4 is running... [2022-03-19 09:42:05] The service SESSION is running... [2022-03-19 09:42:06] The service LLDP is running... [2022-03-19 09:42:06] The service HTTP is running... [2022-03-19 09:42:06] The service PORTSEC is running... [2022-03-19 09:42:07] The service RRM is running... [2022-03-19 09:42:07] The service pkg_upgrade is running... [2022-03-19 09:42:08] The service IPStack is running... [2022-03-19 09:42:08] The service PPP is running... [2022-03-19 09:42:08] The service DHCPC is running... [2022-03-19 09:42:08] The service DHCP is running... [2022-03-19 09:42:08] The service PORTAL is running... [2022-03-19 09:42:10] The service APR is running... [2022-03-19 09:42:11] The service recover is running... [2022-03-19 09:42:11] The service recover is stopped... [2022-03-19 09:42:17] The service DPI is running... [2022-03-19 09:42:17] The service DRS is running... [2022-03-19 09:42:34] The service XMLCFGD is running... [2022-03-19 09:42:34] On-demand service initialization completed, took 31 seconds. [2022-03-19 09:42:34] The service delete is starting... [2022-03-19 09:42:34] The service bdrinstall is starting... [2022-03-19 09:42:34] The service KNPHASE3 is starting... [2022-03-19 09:42:34] begin send sig of phase end 4 event. [2022-03-19 09:42:34] send sig of phase end event of pid 215 ret:0 [2022-03-19 09:42:34] send sig of phase end event of pid 230 ret:0 [2022-03-19 09:42:34] send sig of phase end event of pid 163 ret:0 [2022-03-19 09:42:34] send sig of phase end event of pid 175 ret:0 [2022-03-19 09:42:34] send sig of phase end event of pid 160 ret:0 [2022-03-19 09:42:34] send sig of phase end event of pid 144 ret:0 [2022-03-19 09:42:34] send sig of phase end event of pid 143 ret:0 [2022-03-19 09:42:34] send sig of phase end event of pid 139 ret:0 [2022-03-19 09:42:34] send sig of phase end event of pid 140 ret:0 [2022-03-19 09:42:34] send sig of phase end event of pid 132 ret:0 [2022-03-19 09:42:34] send sig of phase end event of pid 133 ret:0 [2022-03-19 09:42:34] The service delete is running... [2022-03-19 09:42:34] The service delete is stopped... [2022-03-19 09:42:34] The service KNPHASE3 is running... [2022-03-19 09:42:34] The service KNPHASE3 is stopped... [2022-03-19 09:42:34] The service pkg_upgrade is stopped... [2022-03-19 09:42:36] The service bdrinstall is running... [2022-03-19 09:42:36] The service bdrinstall is stopped... [2022-03-19 09:42:36] Early Application initialization completed, took 2 seconds. [2022-03-19 09:42:36] begin send sig of phase end 5 event. [2022-03-19 09:42:36] send sig of phase end event of pid 143 ret:0 [2022-03-19 09:42:36] send sig of phase end event of pid 232 ret:0 [2022-03-19 09:42:36] send sig of phase end event of pid 162 ret:0 [2022-03-19 09:42:36] send sig of phase end event of pid 147 ret:0 [2022-03-19 09:42:36] send sig of phase end event of pid 138 ret:0 [2022-03-19 09:42:36] send sig of phase end event of pid 130 ret:0 [2022-03-19 10:40:42] The service SSH is starting... [2022-03-19 10:40:42] The service SSH is running... [2022-03-19 10:40:50] open cgroup file /dev/cgroup/cpu/0/ControlPlane/BandWidth/tasks failed ===============printk log buffer info =============== <4>---------- secondary log buffer [1] ---------- <6>[ 0.000000] 0:Initializing cgroup subsys cpuset <6>0:done <6>[ 0.000000] 0:Initializing cgroup subsys cpu <6>0:done <5>[ 0.000000] 0:Linux version (none) (CMO@host) (gcc version 4.4.5 20100516 (prerelease) (GCC) ) #1 SMP Wed May 29 16:00:00 CST 2019 <4>[ 0.000000] Standard version 0.50 <4>[ 0.000000] envp = 82146014 <4>[ 0.000000] Boot cmdline: phymemsize=1024M cOnsole=ttyS0,9600 mem=208M@0M mem=768M@512M BoardName=MSG360-40 WebMode=255 dataecctype=80208 tagbits=8 nandpgsz=1000 nandoobsz=e0 nandpgblk=40 nandblknum=1000 nandbbttype=10 nandid=0xa32c cpio=0x43e8f48@0x38000000 loader=1 cOnsole=ttyS0,9600 rdinit=/sbin/scmd loglevel=0 kdb=on-onlykey extMem=768M@512M slub_debug ccd_threshold=180 secondary_log_buf=0x100000@0xf000000 rd_start=0x82200000 rd_size=0x00375e5e dtb_start=0x82187000 dtb_end=0x821871bb <4>[ 0.000000] New FDT (from cmdline) 0x82187000 <4>[ 0.000000] Cached handle for FDT @ 82187000 <4>[ 0.000000] FDT Cmdline: <4>[ 0.000000] FDT: cpu_cells: 1 onlinemask[0]: 000000ff <4>[ 0.000000] fdt_cpumask: 000000ff <4>[ 0.000000] XLP IO base: 0xb8000000 <4>[ 0.000000] XLP FMN base: 0x10024000 <4>[ 0.000000] XLP MAC base: 0x10000000 <4>[ 0.000000] XLP NAE base: 0x1000e000 <4>[ 0.000000] XLP POE pcim base: 0x10020000 <4>[ 0.000000] XLP POE pcie base: 0x18019000 <4>[ 0.000000] XLP SYS base: 0x18035000 <4>[ 0.000000] Setup early serial port on UART_0 <4>[ 0.000000] Setup early serial port on UART_1 <4>[ 0.000000] Kick cpu 1 out of bootware control. <4>[ 0.000000] cpu 1 is ready. <4>[ 0.000000] Kick cpu 2 out of bootware control. <4>[ 0.000000] cpu 2 is ready. <4>[ 0.000000] Kick cpu 3 out of bootware control. <4>[ 0.000000] cpu 3 is ready. <4>[ 0.000000] Kick cpu 4 out of bootware control. <4>[ 0.000000] cpu 4 is ready. <4>[ 0.000000] Kick cpu 5 out of bootware control. <4>[ 0.000000] cpu 5 is ready. <4>[ 0.000000] Kick cpu 6 out of bootware control. <4>[ 0.000000] cpu 6 is ready. <4>[ 0.000000] Kick cpu 7 out of bootware control. <4>[ 0.000000] cpu 7 is ready. <6>[ 0.000000] 0:console [early0] enabled <6>[ 0.000000] 0:CPU revision is: 000c1203 (XLP208 Rev B0) <6>[ 0.000000] 0:FPU revision is: 00771203 <4>[ 0.000000] Determined physical RAM map: <4>[ 0.000000] User-defined physical RAM map: <4>[ 0.000000] memory: 0d000000 @ 00000000 (usable) <4>[ 0.000000] memory: 30000000 @ 20000000 (usable) <7>[ 0.000000] 0:Entering add_active_range(0, 0, 53248) 0 entries of 256 used <7>[ 0.000000] 0:Entering add_active_range(0, 131072, 327680) 1 entries of 256 used <6>[ 0.000000] 0:Initial ramdisk at: 0x82200000 (3628638 bytes) <6>[ 0.000000] 0:Anditional ramdisk #0 at: 0xd8000000 (71208776 bytes) <4>[ 0.000000] lastpfn 20000 <4>[ 0.000000] Zone PFN ranges: <4>[ 0.000000] Normal 0 -> 327680 <4>[ 0.000000] HighMem 327680 -> 327680 <4>[ 0.000000] Movable zone start PFN for each node <4>[ 0.000000] early_node_map[2] active PFN ranges <4>[ 0.000000] 0: 0 -> 53248 <4>[ 0.000000] 0: 131072 -> 327680 <7>[ 0.000000] 0:On node 0 totalpages: 249856 <7>[ 0.000000] 0: Normal zone: 4160 pages used for memmap <7>[ 0.000000] 0: Normal zone: 0 pages reserved <7>[ 0.000000] 0: Normal zone: 245696 pages, LIFO batch:31 <7>[ 0.000000] 0: HighMem zone: 0 pages used for memmap <7>[ 0.000000] 0: Movable zone: 0 pages used for memmap <4>[ 0.000000] FDT CPU map 000000ff <4>[ 0.000000] Probe CPU map 000000ff <4>[ 0.000000] Possible/Present CPU map 000000ff <4>[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 245696 <7>[ 0.000000] 0:Kernel command line: phymemsize=1024M cOnsole=ttyS0,9600 mem=208M@0M mem=768M@512M BoardName=MSG360-40 WebMode=255 dataecctype=80208 tagbits=8 nandpgsz=1000 nandoobsz=e0 nandpgblk=40 nandblknum=1000 nandbbttype=10 nandid=0xa32c cpio=0x43e8f48@0x38000000 loader=1 cOnsole=ttyS0,9600 rdinit=/sbin/scmd loglevel=0 kdb=on-onlykey extMem=768M@512M slub_debug ccd_threshold=180 secondary_log_buf=0x100000@0xf000000 rd_start=0x82200000 rd_size=0x00375e5e dtb_start=0x82187000 dtb_end=0x821871bb <4>[ 0.000000] Primary instruction cache 64kB, 4-way, linesize 32 bytes. <4>[ 0.000000] Primary data cache 16kB 4-way, linesize 32 bytes. <4>[ 0.000000] Dumping TLBS (0 --> 31): nwired = 3 <4>[ 0.000000] Index: 0 pgmask=256Mb va=c0000000 asid=00 <4>[ 0.000000] [pa=20000000 c=3 d=1 v=1 g=1] [pa=30000000 c=3 d=1 v=1 g=1] <4>[ 0.000000] Index: 1 pgmask=64Mb va=e0000000 asid=00 <4>[ 0.000000] [pa=40000000 c=3 d=1 v=1 g=1] [pa=44000000 c=3 d=1 v=1 g=1] <4>[ 0.000000] Index: 2 pgmask=64Mb va=e8000000 asid=00 <4>[ 0.000000] [pa=48000000 c=3 d=1 v=1 g=1] [pa=4c000000 c=3 d=1 v=1 g=1] <4>[ 0.000000] <4>[ 0.000000] ra[0]=trap_init+0x48/0x5c4 <4>[ 0.000000] ra[0]=trap_init+0x5c/0x5c4 <4>[ 0.000000] ra[0]=set_except_vector+0x80/0x90 <4>[ 0.000000] ra[0]=trap_init+0x108/0x5c4 <4>[ 0.000000] ra[0]=set_except_vector+0x80/0x90 <4>[ 0.000000] ra[0]=trap_init+0x584/0x5c4 <4>[ 0.000000] ra[0]=flush_tlb_handlers+0x24/0x58 <4>[ 0.000000] ra[0]=flush_tlb_handlers+0x38/0x58 <4>[ 0.000000] ra[0]=trap_init+0x58c/0x5c4 <4>[ 0.000000] PID hash table entries: 4096 (order: 12, 16384 bytes) <4>[ 0.000000] mips_hpt_frequency = 1000000000 <4>[ 0.000000] pic_clock = 200000000 <6>[ 0.000103] 0:console handover: boot [early0] -> real [ttyS0] <6>[ 0.000474] 0:Dentry cache hash table entries: 131072 (order: 7, 524288 bytes) <6>[ 0.002329] 0:Inode-cache hash table entries: 65536 (order: 6, 262144 bytes) <6>[ 0.104731] 0:Memory: 902532k/999424k available (2718k kernel code, 96528k reserved, 1249k data, 192k init, 0k highmem) <6>[ 0.104934] 0:SLUB: Genslabs=12, HWalign=64, Order=0-3, MinObjects=0, CPUs=8, Nodes=1 <4>[ 0.105286] Delay calibration in progress: <7>[ 0.105306] 0:Calibrating delay loop... 454.65 BogoMIPS (lpj=227328) <4>[ 0.125050] kdb_init enter <4>[ 0.125431] kdb version 4.4 by Keith Owens, Scott Lurndal. Copyright SGI, All Rights Reserved <6>[ 0.125779] 0:Security Framework initialized <6>[ 0.125830] 0:Capability LSM initialized <4>[ 0.126003] Mount-cache hash table entries: 512 <6>[ 0.127811] 0:Initializing cgroup subsys memory <6>0:done <4>[ 0.129370] logical cpu 1 physical cpu 1 <4>[ 0.129393] Sent a wakeup message to cpu 1, gp=e8098000 sp=e809ffe0 <6>[ 0.129432] 1:CPU revision is: 000c1203 (XLP208 Rev B0) <6>[ 0.129452] 1:FPU revision is: 00771203 <4>[ 0.129595] Dumping TLBS (0 --> 31): nwired = 3 <4>[ 0.129617] Index: 0 pgmask=256Mb va=c0000000 asid=00 <4>[ 0.129643] [pa=20000000 c=3 d=1 v=1 g=1] [pa=30000000 c=3 d=1 v=1 g=1] <4>[ 0.129669] Index: 1 pgmask=64Mb va=e0000000 asid=00 <4>[ 0.129691] [pa=40000000 c=3 d=1 v=1 g=1] [pa=44000000 c=3 d=1 v=1 g=1] <4>[ 0.129716] Index: 2 pgmask=64Mb va=e8000000 asid=00 <4>[ 0.129738] [pa=48000000 c=3 d=1 v=1 g=1] [pa=4c000000 c=3 d=1 v=1 g=1] <4>[ 0.129764] <4>[ 0.129812] Delay calibration in progress: <7>[ 0.129827] 1:Calibrating delay loop... 474.11 BogoMIPS (lpj=237056) <4>[ 0.147987] logical cpu 2 physical cpu 2 <4>[ 0.148016] Sent a wakeup message to cpu 2, gp=e80c8000 sp=e80cffe0 <6>[ 0.148040] 2:CPU revision is: 000c1203 (XLP208 Rev B0) <6>[ 0.148057] 2:FPU revision is: 00771203 <4>[ 0.148174] Dumping TLBS (0 --> 31): nwired = 3 <4>[ 0.148191] Index: 0 pgmask=256Mb va=c0000000 asid=00 <4>[ 0.148212] [pa=20000000 c=3 d=1 v=1 g=1] [pa=30000000 c=3 d=1 v=1 g=1] <4>[ 0.148232] Index: 1 pgmask=64Mb va=e0000000 asid=00 <4>[ 0.148251] [pa=40000000 c=3 d=1 v=1 g=1] [pa=44000000 c=3 d=1 v=1 g=1] <4>[ 0.148271] Index: 2 pgmask=64Mb va=e8000000 asid=00 <4>[ 0.148289] [pa=48000000 c=3 d=1 v=1 g=1] [pa=4c000000 c=3 d=1 v=1 g=1] <4>[ 0.148309] <4>[ 0.148347] Delay calibration in progress: <7>[ 0.148358] 2:Calibrating delay loop... 577.53 BogoMIPS (lpj=288768) <4>[ 0.169956] logical cpu 3 physical cpu 3 <4>[ 0.169980] Sent a wakeup message to cpu 3, gp=e8120000 sp=e8127fe0 <6>[ 0.170003] 3:CPU revision is: 000c1203 (XLP208 Rev B0) <6>[ 0.170014] 3:FPU revision is: 00771203 <4>[ 0.170123] Dumping TLBS (0 --> 31): nwired = 3 <4>[ 0.170137] Index: 0 pgmask=256Mb va=c0000000 asid=00 <4>[ 0.170153] [pa=20000000 c=3 d=1 v=1 g=1] [pa=30000000 c=3 d=1 v=1 g=1] <4>[ 0.170169] Index: 1 pgmask=64Mb va=e0000000 asid=00 <4>[ 0.170185] [pa=40000000 c=3 d=1 v=1 g=1] [pa=44000000 c=3 d=1 v=1 g=1] <4>[ 0.170199] Index: 2 pgmask=64Mb va=e8000000 asid=00 <4>[ 0.170212] [pa=48000000 c=3 d=1 v=1 g=1] [pa=4c000000 c=3 d=1 v=1 g=1] <4>[ 0.170226] <4>[ 0.170252] Delay calibration in progress: <7>[ 0.170261] 3:Calibrating delay loop... 817.15 BogoMIPS (lpj=408576) <4>[ 0.190901] logical cpu 4 physical cpu 4 <4>[ 0.190920] Sent a wakeup message to cpu 4, gp=e8178000 sp=e817ffe0 <6>[ 0.190961] 4:CPU revision is: 000c1203 (XLP208 Rev B0) <6>[ 0.190987] 4:FPU revision is: 00771203 <4>[ 0.191122] Dumping TLBS (0 --> 31): nwired = 3 <4>[ 0.191144] Index: 0 pgmask=256Mb va=c0000000 asid=00 <4>[ 0.191170] [pa=20000000 c=3 d=1 v=1 g=1] [pa=30000000 c=3 d=1 v=1 g=1] <4>[ 0.191197] Index: 1 pgmask=64Mb va=e0000000 asid=00 <4>[ 0.191221] [pa=40000000 c=3 d=1 v=1 g=1] [pa=44000000 c=3 d=1 v=1 g=1] <4>[ 0.191248] Index: 2 pgmask=64Mb va=e8000000 asid=00 <4>[ 0.191273] [pa=48000000 c=3 d=1 v=1 g=1] [pa=4c000000 c=3 d=1 v=1 g=1] <4>[ 0.191300] <4>[ 0.191355] Delay calibration in progress: <7>[ 0.191372] 4:Calibrating delay loop... 452.60 BogoMIPS (lpj=226304) <4>[ 0.210281] logical cpu 5 physical cpu 5 <4>[ 0.210317] Sent a wakeup message to cpu 5, gp=e81d8000 sp=e81dffe0 <6>[ 0.210341] 5:CPU revision is: 000c1203 (XLP208 Rev B0) <6>[ 0.210360] 5:FPU revision is: 00771203 <4>[ 0.210484] Dumping TLBS (0 --> 31): nwired = 3 <4>[ 0.210504] Index: 0 pgmask=256Mb va=c0000000 asid=00 <4>[ 0.210528] [pa=20000000 c=3 d=1 v=1 g=1] [pa=30000000 c=3 d=1 v=1 g=1] <4>[ 0.210554] Index: 1 pgmask=64Mb va=e0000000 asid=00 <4>[ 0.210576] [pa=40000000 c=3 d=1 v=1 g=1] [pa=44000000 c=3 d=1 v=1 g=1] <4>[ 0.210601] Index: 2 pgmask=64Mb va=e8000000 asid=00 <4>[ 0.210624] [pa=48000000 c=3 d=1 v=1 g=1] [pa=4c000000 c=3 d=1 v=1 g=1] <4>[ 0.210648] <4>[ 0.210681] Delay calibration in progress: <7>[ 0.210695] 5:Calibrating delay loop... 474.11 BogoMIPS (lpj=237056) <4>[ 0.229223] logical cpu 6 physical cpu 6 <4>[ 0.229253] Sent a wakeup message to cpu 6, gp=e8238000 sp=e823ffe0 <6>[ 0.229276] 6:CPU revision is: 000c1203 (XLP208 Rev B0) <6>[ 0.229291] 6:FPU revision is: 00771203 <4>[ 0.229407] Dumping TLBS (0 --> 31): nwired = 3 <4>[ 0.229425] Index: 0 pgmask=256Mb va=c0000000 asid=00 <4>[ 0.229444] [pa=20000000 c=3 d=1 v=1 g=1] [pa=30000000 c=3 d=1 v=1 g=1] <4>[ 0.229465] Index: 1 pgmask=64Mb va=e0000000 asid=00 <4>[ 0.229483] [pa=40000000 c=3 d=1 v=1 g=1] [pa=44000000 c=3 d=1 v=1 g=1] <4>[ 0.229504] Index: 2 pgmask=64Mb va=e8000000 asid=00 <4>[ 0.229523] [pa=48000000 c=3 d=1 v=1 g=1] [pa=4c000000 c=3 d=1 v=1 g=1] <4>[ 0.229543] <4>[ 0.229573] Delay calibration in progress: <7>[ 0.229584] 6:Calibrating delay loop... 563.20 BogoMIPS (lpj=281600) <4>[ 0.252182] logical cpu 7 physical cpu 7 <4>[ 0.252205] Sent a wakeup message to cpu 7, gp=e8288000 sp=e828ffe0 <6>[ 0.252228] 7:CPU revision is: 000c1203 (XLP208 Rev B0) <6>[ 0.252239] 7:FPU revision is: 00771203 <4>[ 0.252349] Dumping TLBS (0 --> 31): nwired = 3 <4>[ 0.252362] Index: 0 pgmask=256Mb va=c0000000 asid=00 <4>[ 0.252378] [pa=20000000 c=3 d=1 v=1 g=1] [pa=30000000 c=3 d=1 v=1 g=1] <4>[ 0.252393] Index: 1 pgmask=64Mb va=e0000000 asid=00 <4>[ 0.252406] [pa=40000000 c=3 d=1 v=1 g=1] [pa=44000000 c=3 d=1 v=1 g=1] <4>[ 0.252421] Index: 2 pgmask=64Mb va=e8000000 asid=00 <4>[ 0.252434] [pa=48000000 c=3 d=1 v=1 g=1] [pa=4c000000 c=3 d=1 v=1 g=1] <4>[ 0.252448] <4>[ 0.252483] Delay calibration in progress: <7>[ 0.252492] 7:Calibrating delay loop... 819.20 BogoMIPS (lpj=409600) <6>[ 0.273774] 7:Brought up 8 CPUs <5>[ 0.280176] 7:con_start=309b ve_log_start=0 ve_log_end=309b <5>[ 0.280225] 7:log_buf switch to: af000040 length: 0x80000, for the first time <4>[ 0.280756] Initializing USB Interface <4>[ 0.282798] USB 1 corebase 0x10100000 <4>[ 0.283830] GCTL 0x30c11000 <4>[ 0.283855] PHYCFG 0x1408x <4>[ 0.284880] PIPECTL 0x240002 <4>[ 0.288920] [xlp_pcibios_init]: IO-Remapped phys=14000000, size=2000000 to vaddr=b4000000 <4>[ 0.288978] Registering XLP PCIE Controller. <7>[ 0.289019] 7:Controller 0 is in EP mode <7>[ 0.289050] 7:Controller 1 is in EP mode <7>[ 0.289083] 7:Controller 2 is in RC mode <7>[ 0.289115] 7:Controller 3 is in EP mode <7>[ 0.289148] 7:PLC = 0x2, mode = 0x4 <4>[ 0.289178] 7:LTSSM state is 0x0. Fn 2 link not up <7>[ 0.289227] 7:[pcie_controller_init_done]: PCIE Controller initialization done <5>[ 0.294689] 7:SCSI subsystem initialized <6>[ 0.295265] 7:usbcore: registered new interface driver usbfs <6>[ 0.295532] 7:usbcore: registered new interface driver hub <6>[ 0.295810] 7:usbcore: registered new device driver usb <7>[ 0.302391] 7:pci 0000:00:00.0: Assigning interrupt 0x56 <7>[ 0.302447] 7:pci 0000:00:00.4: Assigning interrupt 0x56 <7>[ 0.302529] 7:pci 0000:00:03.0: Assigning interrupt 0x56 <7>[ 0.302581] 7:pci 0000:00:03.1: Assigning interrupt 0x56 <7>[ 0.302633] 7:pci 0000:00:04.0: Assigning interrupt 0x56 <7>[ 0.302684] 7:pci 0000:00:04.1: Assigning interrupt 0x56 <7>[ 0.302736] 7:pci 0000:00:04.2: Assigning interrupt 0x56 <7>[ 0.302787] 7:pci 0000:00:04.3: Assigning interrupt 0x56 <7>[ 0.302839] 7:pci 0000:00:05.0: Assigning interrupt 0x56 <7>[ 0.302890] 7:pci 0000:00:05.1: Assigning interrupt 0x56 <7>[ 0.302942] 7:pci 0000:00:05.2: Assigning interrupt 0x56 <7>[ 0.302995] 7:pci 0000:00:05.3: Assigning interrupt 0x56 <7>[ 0.303046] 7:pci 0000:00:05.5: Assigning interrupt 0x56 <7>[ 0.303098] 7:pci 0000:00:06.0: Assigning interrupt 0x56 <7>[ 0.303150] 7:pci 0000:00:06.1: Assigning interrupt 0x56 <7>[ 0.303202] 7:pci 0000:00:06.4: Assigning interrupt 0x56 <7>[ 0.303254] 7:pci 0000:00:06.5: Assigning interrupt 0x56 <7>[ 0.303306] 7:pci 0000:00:06.6: Assigning interrupt 0x56 <7>[ 0.303358] 7:pci 0000:00:06.7: Assigning interrupt 0x56 <7>[ 0.303416] 7:pci 0000:00:07.0: Assigning interrupt 0x56 <7>[ 0.303468] 7:pci 0000:00:07.1: Assigning interrupt 0x56 <7>[ 0.303520] 7:pci 0000:00:07.2: Assigning interrupt 0x56 <7>[ 0.303571] 7:pci 0000:00:07.3: Assigning interrupt 0x56 <4>[ 0.303622] mem shortage create <4>[ 0.303662] mem shortage set as Gate-safe: 153600 kB Gate-floor: 102400 kB at last <7>[ 0.303744] 0:Switched to high resolution mode on CPU 0 <7>[ 0.303825] 2:Switched to high resolution mode on CPU 2 <7>[ 0.304007] 6:Switched to high resolution mode on CPU 6 <7>[ 0.304041] 4:Switched to high resolution mode on CPU 4 <7>[ 0.304170] 5:Switched to high resolution mode on CPU 5 <7>[ 0.304378] 1:Switched to high resolution mode on CPU 1 <7>[ 0.304426] 7:Switched to high resolution mode on CPU 7 <7>[ 0.304626] 3:Switched to high resolution mode on CPU 3 <6>[ 0.306205] 7:Trying to unpack rootfs image as initramfs... <6>[ 0.624298] 7:Freeing initrd memory: 3543k freed <4>[ 0.624364] Unpacking additional initramfs ... <4>[ 0.624400] #0 0x43e8f48@0xd8000000 OK <6>[ 3.861292] 7:Freeing initrd memory: 69539k freed <4>[ 3.895657] ra[0]=register_kprobe+0x3a0/0x530 <5>[ 3.914897] 7:VFS: Disk quotas dquot_6.5.1 <4>[ 3.915238] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes) <6>[ 3.916676] 7:JFFS2 version 2.2. (NAND) (SUMMARY) (ZLIB) (LZO) (RTIME) (CMODE_NONE) (c) 2001-2006 Red Hat, Inc. <4>[ 3.918619] fuse init (API version 7.9) <6>[ 3.919258] 7:msgmni has been set to 1906 <6>[ 3.919309] 7:io scheduler noop registered <6>[ 3.919344] 7:io scheduler anticipatory registered (default) <6>[ 3.919388] 7:io scheduler deadline registered <6>[ 3.919831] 7:io scheduler cfq registered <7>[ 3.982280] 7:Serial: 8250/16550 driver $Revision: 1.90 $ 2 ports, IRQ sharing disabled <7>[ 3.982553] 7:serial8250: ttyS0 at MMIO 0xffffffffb8030100 (irq = 17) is a 16550A <7>[ 3.982784] 7:serial8250: ttyS1 at MMIO 0xffffffffb8031100 (irq = 18) is a 16550A <7>[ 3.983375] 7:serial8250.0: ttyS0 at MMIO 0xffffffffb8030100 (irq = 17) is a 16550A <7>[ 3.983879] 7:serial8250.0: ttyS1 at MMIO 0xffffffffb8031100 (irq = 18) is a 16550A <7>[ 3.984420] 7:serial8250.1: ttyS1 at MMIO 0xffffffffb8031100 (irq = 18) is a 16550A <6>[ 3.990861] 7:brd: module loaded <6>[ 3.993808] 7:loop: module loaded <6>[ 3.993943] 7:usbcore: registered new interface driver ub <6>[ 3.993992] 7:Uniform Multi-Platform E-IDE driver <6>[ 3.994034] 7:ide: Assuming 33MHz system bus speed for PIO modes; override with idebus=xx <6>[ 3.994342] 7:ide_generic: please use "probe_mask=0x3f" module parameter for probing all legacy ISA IDE ports <4>[ 3.994965] 7:Driver "sd" needs updating - please use bus_type methods <5>[ 3.995692] 7:usbmon: debugfs is not available <6>[ 3.995730] 7:ehci_hcd: USB 2.0 "Enhanced" Host Controller (EHCI) Driver <6>[ 3.995781] 7:ehci_hcd: USB 2.0 "Enhanced" Host Controller (EHCI) Driver <7>[ 3.996035] 7:ohci_hcd: 2006 August 04 USB 1.1 "Open" Host Controller (OHCI) Driver <7>[ 3.996358] 7:PCI: Setting latency timer of device 0000:00:04.1 to 64 <6>[ 3.996419] 7:xhci_hcd 0000:00:04.1: xHCI Host Controller <6>[ 3.996577] 7:xhci_hcd 0000:00:04.1: new USB bus registered, assigned bus number 1 <7>[ 3.996676] 7:xhci_hcd 0000:00:04.1: xHCI capability registers at b0100000: <7>[ 3.996731] 7:xhci_hcd 0000:00:04.1: CAPLENGTH AND HCIVERSION 0x1000020: <7>[ 3.996784] 7:xhci_hcd 0000:00:04.1: CAPLENGTH: 0x20 <7>[ 3.996824] 7:xhci_hcd 0000:00:04.1: HCIVERSION: 0x100 <7>[ 3.996870] 7:xhci_hcd 0000:00:04.1: HCSPARAMS 1: 0x2000840 <7>[ 3.996915] 7:xhci_hcd 0000:00:04.1: Max device slots: 64 <7>[ 3.996960] 7:xhci_hcd 0000:00:04.1: Max interrupters: 8 <7>[ 3.997005] 7:xhci_hcd 0000:00:04.1: Max ports: 2 <7>[ 3.997048] 7:xhci_hcd 0000:00:04.1: HCSPARAMS 2: 0xc0000f1 <7>[ 3.997094] 7:xhci_hcd 0000:00:04.1: Isoc scheduling threshold: 1 <7>[ 3.997144] 7:xhci_hcd 0000:00:04.1: Maximum allowed segments in event ring: 15 <7>[ 3.997213] 7:xhci_hcd 0000:00:04.1: HCSPARAMS 3 0x7ff000a: <7>[ 3.997259] 7:xhci_hcd 0000:00:04.1: Worst case U1 device exit latency: 10 <7>[ 3.997314] 7:xhci_hcd 0000:00:04.1: Worst case U2 device exit latency: 2047 <7>[ 3.997370] 7:xhci_hcd 0000:00:04.1: HCC PARAMS 0x258f065: <7>[ 3.997415] 7:xhci_hcd 0000:00:04.1: HC generates 64 bit addresses <7>[ 3.997465] 7:xhci_hcd 0000:00:04.1: FIXME: more HCCPARAMS debugging <7>[ 3.997518] 7:xhci_hcd 0000:00:04.1: RTSOFF 0x440: <7>[ 3.997558] 7:xhci_hcd 0000:00:04.1: xHCI operational registers at b0100020: <7>[ 3.997613] 7:xhci_hcd 0000:00:04.1: USBCMD 0x0: <7>[ 3.997651] 7:xhci_hcd 0000:00:04.1: HC is being stopped <7>[ 3.997696] 7:xhci_hcd 0000:00:04.1: HC has finished hard reset <7>[ 3.997745] 7:xhci_hcd 0000:00:04.1: Event Interrupts disabled <7>[ 3.997793] 7:xhci_hcd 0000:00:04.1: Host System Error Interrupts disabled <7>[ 3.997848] 7:xhci_hcd 0000:00:04.1: HC has finished light reset <7>[ 3.997897] 7:xhci_hcd 0000:00:04.1: USBSTS 0x1: <7>[ 3.997935] 7:xhci_hcd 0000:00:04.1: Event ring is empty <7>[ 3.997980] 7:xhci_hcd 0000:00:04.1: No Host System Error <7>[ 3.998025] 7:xhci_hcd 0000:00:04.1: HC is halted <7>[ 3.998068] 7:xhci_hcd 0000:00:04.1: b0100420 port status reg = 0x2a0 <7>[ 3.998120] 7:xhci_hcd 0000:00:04.1: b0100424 port power reg = 0x0 <7>[ 3.998178] 7:xhci_hcd 0000:00:04.1: b0100428 port link reg = 0x0 <7>[ 3.998229] 7:xhci_hcd 0000:00:04.1: b010042c port reserved reg = 0x0 <7>[ 3.998280] 7:xhci_hcd 0000:00:04.1: b0100430 port status reg = 0x2a0 <7>[ 3.998332] 7:xhci_hcd 0000:00:04.1: b0100434 port power reg = 0x0 <7>[ 3.998382] 7:xhci_hcd 0000:00:04.1: b0100438 port link reg = 0x0 <7>[ 3.998431] 7:xhci_hcd 0000:00:04.1: b010043c port reserved reg = 0x0 <7>[ 3.998484] 7:xhci_hcd 0000:00:04.1: // Halt the HC <7>[ 3.998527] 7:xhci_hcd 0000:00:04.1: Resetting HCD <7>[ 3.998568] 7:xhci_hcd 0000:00:04.1: // Reset the HC <7>[ 3.998650] 7:xhci_hcd 0000:00:04.1: Wait for controller to be ready for doorbell rings <7>[ 3.998711] 7:xhci_hcd 0000:00:04.1: Reset complete <7>[ 3.998752] 7:xhci_hcd 0000:00:04.1: Enabling 64-bit DMA addresses. <7>[ 3.998801] 7:xhci_hcd 0000:00:04.1: Calling HCD init <7>[ 3.998843] 7:xhci_hcd 0000:00:04.1: xhci_init <7>[ 3.998880] 7:xhci_hcd 0000:00:04.1: xHCI doesn"t need link TRB QUIRK <7>[ 3.998933] 7:xhci_hcd 0000:00:04.1: Supported page size register = 0x1 <7>[ 3.998986] 7:xhci_hcd 0000:00:04.1: Supported page size of 4K <7>[ 3.999035] 7:xhci_hcd 0000:00:04.1: HCD page size set to 4K <7>[ 3.999082] 7:xhci_hcd 0000:00:04.1: // xHC can handle at most 64 device slots. <7>[ 3.999141] 7:xhci_hcd 0000:00:04.1: // Setting Max device slots reg = 0x40. <7>[ 3.999212] 7:xhci_hcd 0000:00:04.1: // Device context base array address = 0x3329c000 (DMA), d329c000 (virt) <7>[ 3.999328] 7:xhci_hcd 0000:00:04.1: Allocated command ring at e8ed1d80 <7>[ 3.999382] 7:xhci_hcd 0000:00:04.1: First segment DMA is 0x3329e000 <7>[ 3.999433] 7:xhci_hcd 0000:00:04.1: // Setting command ring address to 0x40 <7>[ 3.999490] 7:xhci_hcd 0000:00:04.1: // xHC command ring deq ptr low bits + flags = @00000000 <7>[ 3.999554] 7:xhci_hcd 0000:00:04.1: // xHC command ring deq ptr high bits = @00000000 <7>[ 3.999649] 7:xhci_hcd 0000:00:04.1: // Doorbell array is located at offset 0x560 from cap regs base addr <7>[ 3.999720] 7:xhci_hcd 0000:00:04.1: // xHCI capability registers at b0100000: <7>[ 3.999778] 7:xhci_hcd 0000:00:04.1: // @b0100000 = 0x1000020 (CAPLENGTH AND HCIVERSION) <7>[ 3.999839] 7:xhci_hcd 0000:00:04.1: // CAPLENGTH: 0x20 <7>[ 3.999883] 7:xhci_hcd 0000:00:04.1: // xHCI operational registers at b0100020: <7>[ 3.999940] 7:xhci_hcd 0000:00:04.1: // @b0100018 = 0x440 RTSOFF <7>[ 3.999988] 7:xhci_hcd 0000:00:04.1: // xHCI runtime registers at b0100440: <7>[ 4.000044] 7:xhci_hcd 0000:00:04.1: // @b0100014 = 0x560 DBOFF <7>[ 4.000093] 7:xhci_hcd 0000:00:04.1: // Doorbell array at b0100560: <7>[ 4.000143] 7:xhci_hcd 0000:00:04.1: xHCI runtime registers at b0100440: <7>[ 4.000205] 7:xhci_hcd 0000:00:04.1: b0100440: Microframe index = 0x0 <7>[ 4.000260] 7:xhci_hcd 0000:00:04.1: // Allocating event ring <7>[ 4.000321] 7:xhci_hcd 0000:00:04.1: TRB math tests passed. <7>[ 4.000368] 7:xhci_hcd 0000:00:04.1: // Allocated event ring segment table at 0x332a6000 <7>[ 4.000432] 7:xhci_hcd 0000:00:04.1: Set ERST to 0; private num segs = 1, virt addr = d32a6000, dma addr = 0x332a6000 <7>[ 4.000511] 7:xhci_hcd 0000:00:04.1: // Write ERST size = 1 to ir_set 0 (some bits preserved) <7>[ 4.000575] 7:xhci_hcd 0000:00:04.1: // Set ERST entries to point to event ring. <7>[ 4.000634] 7:xhci_hcd 0000:00:04.1: // Set ERST base address for ir_set 0 = 0x332a6000 <7>[ 4.000698] 7:xhci_hcd 0000:00:04.1: // Write event ring dequeue pointer, preserving EHB bit <7>[ 4.000761] 7:xhci_hcd 0000:00:04.1: Wrote ERST address to ir_set 0. <7>[ 4.000814] 7:xhci_hcd 0000:00:04.1: Allocating 1 scratchpad buffers <7>[ 4.000893] 7:xhci_hcd 0000:00:04.1: Ext Cap b0100970, port offset = 1, count = 1, revision = 0x2 <7>[ 4.000960] 7:xhci_hcd 0000:00:04.1: xHCI 1.0: support USB2 software lpm <7>[ 4.001013] 7:xhci_hcd 0000:00:04.1: xHCI 1.0: support USB2 hardware lpm <7>[ 4.001069] 7:xhci_hcd 0000:00:04.1: Ext Cap b0100980, port offset = 2, count = 1, revision = 0x3 <7>[ 4.001138] 7:xhci_hcd 0000:00:04.1: Found 1 USB 2.0 ports and 1 USB 3.0 ports. <7>[ 4.001207] 7:xhci_hcd 0000:00:04.1: USB 2.0 port at index 0, addr = b0100420 <7>[ 4.001265] 7:xhci_hcd 0000:00:04.1: USB 3.0 port at index 1, addr = b0100430 <7>[ 4.001321] 7:xhci_hcd 0000:00:04.1: Finished xhci_init <7>[ 4.001365] 7:xhci_hcd 0000:00:04.1: Called HCD init <7>[ 4.001409] 7:xhci_hcd 0000:00:04.1: Got SBRN 0 <7>[ 4.001448] 7:PCI: cache line size of 64 is not supported by device 0000:00:04.1 <7>[ 4.001505] 7:xhci_hcd 0000:00:04.1: Finished xhci_pci_reinit <7>[ 4.001553] 7:xhci_hcd 0000:00:04.1: xhci_run <7>[ 4.001594] 7:xhci_hcd 0000:00:04.1: Failed to enable MSI-X <7>[ 4.001642] 7:xhci_hcd 0000:00:04.1: failed to allocate MSI entry <7>[ 4.001711] 7:xhci_hcd 0000:00:04.1: Command ring memory map follows: <7>[ 4.001766] 7:xhci_hcd 0000:00:04.1: @000000003329e000 00000000 00000000 00000000 00000000 <7>[ 4.001830] 7:xhci_hcd 0000:00:04.1: @000000003329e010 00000000 00000000 00000000 00000000 <7>[ 4.001895] 7:xhci_hcd 0000:00:04.1: @000000003329e020 00000000 00000000 00000000 00000000 <7>[ 4.001959] 7:xhci_hcd 0000:00:04.1: @000000003329e030 00000000 00000000 00000000 00000000 <7>[ 4.002023] 7:xhci_hcd 0000:00:04.1: @000000003329e040 00000000 00000000 00000000 00000000 <7>[ 4.002088] 7:xhci_hcd 0000:00:04.1: @000000003329e050 00000000 00000000 00000000 00000000 <7>[ 4.002154] 7:xhci_hcd 0000:00:04.1: @000000003329e060 00000000 00000000 00000000 00000000 <7>[ 4.002226] 7:xhci_hcd 0000:00:04.1: @000000003329e070 00000000 00000000 00000000 00000000 <7>[ 4.002291] 7:xhci_hcd 0000:00:04.1: @000000003329e080 00000000 00000000 00000000 00000000 <7>[ 4.002356] 7:xhci_hcd 0000:00:04.1: @000000003329e090 00000000 00000000 00000000 00000000 <7>[ 4.002421] 7:xhci_hcd 0000:00:04.1: @000000003329e0a0 00000000 00000000 00000000 00000000 <7>[ 4.002485] 7:xhci_hcd 0000:00:04.1: @000000003329e0b0 00000000 00000000 00000000 00000000 <7>[ 4.002550] 7:xhci_hcd 0000:00:04.1: @000000003329e0c0 00000000 00000000 00000000 00000000 <7>[ 4.002615] 7:xhci_hcd 0000:00:04.1: @000000003329e0d0 00000000 00000000 00000000 00000000 <7>[ 4.002680] 7:xhci_hcd 0000:00:04.1: @000000003329e0e0 00000000 00000000 00000000 00000000 <7>[ 4.002744] 7:xhci_hcd 0000:00:04.1: @000000003329e0f0 00000000 00000000 00000000 00000000 <7>[ 4.002808] 7:xhci_hcd 0000:00:04.1: @000000003329e100 00000000 00000000 00000000 00000000 <7>[ 4.002872] 7:xhci_hcd 0000:00:04.1: @000000003329e110 00000000 00000000 00000000 00000000 <7>[ 4.002936] 7:xhci_hcd 0000:00:04.1: @000000003329e120 00000000 00000000 00000000 00000000 <7>[ 4.003000] 7:xhci_hcd 0000:00:04.1: @000000003329e130 00000000 00000000 00000000 00000000 <7>[ 4.003065] 7:xhci_hcd 0000:00:04.1: @000000003329e140 00000000 00000000 00000000 00000000 <7>[ 4.003131] 7:xhci_hcd 0000:00:04.1: @000000003329e150 00000000 00000000 00000000 00000000 <7>[ 4.003202] 7:xhci_hcd 0000:00:04.1: @000000003329e160 00000000 00000000 00000000 00000000 <7>[ 4.003267] 7:xhci_hcd 0000:00:04.1: @000000003329e170 00000000 00000000 00000000 00000000 <7>[ 4.003332] 7:xhci_hcd 0000:00:04.1: @000000003329e180 00000000 00000000 00000000 00000000 <7>[ 4.003397] 7:xhci_hcd 0000:00:04.1: @000000003329e190 00000000 00000000 00000000 00000000 <7>[ 4.003461] 7:xhci_hcd 0000:00:04.1: @000000003329e1a0 00000000 00000000 00000000 00000000 <7>[ 4.003525] 7:xhci_hcd 0000:00:04.1: @000000003329e1b0 00000000 00000000 00000000 00000000 <7>[ 4.003590] 7:xhci_hcd 0000:00:04.1: @000000003329e1c0 00000000 00000000 00000000 00000000 <7>[ 4.003655] 7:xhci_hcd 0000:00:04.1: @000000003329e1d0 00000000 00000000 00000000 00000000 <7>[ 4.003720] 7:xhci_hcd 0000:00:04.1: @000000003329e1e0 00000000 00000000 00000000 00000000 <7>[ 4.003783] 7:xhci_hcd 0000:00:04.1: @000000003329e1f0 00000000 00000000 00000000 00000000 <7>[ 4.003848] 7:xhci_hcd 0000:00:04.1: @000000003329e200 00000000 00000000 00000000 00000000 <7>[ 4.003912] 7:xhci_hcd 0000:00:04.1: @000000003329e210 00000000 00000000 00000000 00000000 <7>[ 4.003979] 7:xhci_hcd 0000:00:04.1: @000000003329e220 00000000 00000000 00000000 00000000 <7>[ 4.004045] 7:xhci_hcd 0000:00:04.1: @000000003329e230 00000000 00000000 00000000 00000000 <7>[ 4.004110] 7:xhci_hcd 0000:00:04.1: @000000003329e240 00000000 00000000 00000000 00000000 <7>[ 4.004182] 7:xhci_hcd 0000:00:04.1: @000000003329e250 00000000 00000000 00000000 00000000 <7>[ 4.004247] 7:xhci_hcd 0000:00:04.1: @000000003329e260 00000000 00000000 00000000 00000000 <7>[ 4.004312] 7:xhci_hcd 0000:00:04.1: @000000003329e270 00000000 00000000 00000000 00000000 <7>[ 4.004377] 7:xhci_hcd 0000:00:04.1: @000000003329e280 00000000 00000000 00000000 00000000 <7>[ 4.004442] 7:xhci_hcd 0000:00:04.1: @000000003329e290 00000000 00000000 00000000 00000000 <7>[ 4.004506] 7:xhci_hcd 0000:00:04.1: @000000003329e2a0 00000000 00000000 00000000 00000000 <7>[ 4.004571] 7:xhci_hcd 0000:00:04.1: @000000003329e2b0 00000000 00000000 00000000 00000000 <7>[ 4.004636] 7:xhci_hcd 0000:00:04.1: @000000003329e2c0 00000000 00000000 00000000 00000000 <7>[ 4.004701] 7:xhci_hcd 0000:00:04.1: @000000003329e2d0 00000000 00000000 00000000 00000000 <7>[ 4.004765] 7:xhci_hcd 0000:00:04.1: @000000003329e2e0 00000000 00000000 00000000 00000000 <7>[ 4.004829] 7:xhci_hcd 0000:00:04.1: @000000003329e2f0 00000000 00000000 00000000 00000000 <7>[ 4.004893] 7:xhci_hcd 0000:00:04.1: @000000003329e300 00000000 00000000 00000000 00000000 <7>[ 4.004957] 7:xhci_hcd 0000:00:04.1: @000000003329e310 00000000 00000000 00000000 00000000 <7>[ 4.005021] 7:xhci_hcd 0000:00:04.1: @000000003329e320 00000000 00000000 00000000 00000000 <7>[ 4.005086] 7:xhci_hcd 0000:00:04.1: @000000003329e330 00000000 00000000 00000000 00000000 <7>[ 4.005151] 7:xhci_hcd 0000:00:04.1: @000000003329e340 00000000 00000000 00000000 00000000 <7>[ 4.005223] 7:xhci_hcd 0000:00:04.1: @000000003329e350 00000000 00000000 00000000 00000000 <7>[ 4.005288] 7:xhci_hcd 0000:00:04.1: @000000003329e360 00000000 00000000 00000000 00000000 <7>[ 4.005353] 7:xhci_hcd 0000:00:04.1: @000000003329e370 00000000 00000000 00000000 00000000 <7>[ 4.005418] 7:xhci_hcd 0000:00:04.1: @000000003329e380 00000000 00000000 00000000 00000000 <7>[ 4.005482] 7:xhci_hcd 0000:00:04.1: @000000003329e390 00000000 00000000 00000000 00000000 <7>[ 4.005547] 7:xhci_hcd 0000:00:04.1: @000000003329e3a0 00000000 00000000 00000000 00000000 <7>[ 4.005611] 7:xhci_hcd 0000:00:04.1: @000000003329e3b0 00000000 00000000 00000000 00000000 <7>[ 4.005677] 7:xhci_hcd 0000:00:04.1: @000000003329e3c0 00000000 00000000 00000000 00000000 <7>[ 4.005742] 7:xhci_hcd 0000:00:04.1: @000000003329e3d0 00000000 00000000 00000000 00000000 <7>[ 4.005805] 7:xhci_hcd 0000:00:04.1: @000000003329e3e0 00000000 00000000 00000000 00000000 <7>[ 4.005869] 7:xhci_hcd 0000:00:04.1: @000000003329e3f0 3329e000 00000000 00000000 00001802 <7>[ 4.005933] 7:xhci_hcd 0000:00:04.1: Ring has not been updated <7>[ 4.005983] 7:xhci_hcd 0000:00:04.1: Ring deq = d329e000 (virt), 0x3329e000 (dma) <7>[ 4.006043] 7:xhci_hcd 0000:00:04.1: Ring deq updated 0 times <7>[ 4.006091] 7:xhci_hcd 0000:00:04.1: Ring enq = d329e000 (virt), 0x3329e000 (dma) <7>[ 4.006150] 7:xhci_hcd 0000:00:04.1: Ring enq updated 0 times <7>[ 4.006205] 7:xhci_hcd 0000:00:04.1: // xHC command ring deq ptr low bits + flags = @00000000 <7>[ 4.006269] 7:xhci_hcd 0000:00:04.1: // xHC command ring deq ptr high bits = @00000000 <7>[ 4.006330] 7:xhci_hcd 0000:00:04.1: ERST memory map follows: <7>[ 4.006379] 7:xhci_hcd 0000:00:04.1: @00000000332a6000 3329e400 00000000 00000040 00000000 <7>[ 4.006442] 7:xhci_hcd 0000:00:04.1: Event ring: <7>[ 4.006483] 7:xhci_hcd 0000:00:04.1: @000000003329e400 00000000 00000000 00000000 00000000 <7>[ 4.006547] 7:xhci_hcd 0000:00:04.1: @000000003329e410 00000000 00000000 00000000 00000000 <7>[ 4.006612] 7:xhci_hcd 0000:00:04.1: @000000003329e420 00000000 00000000 00000000 00000000 <7>[ 4.006677] 7:xhci_hcd 0000:00:04.1: @000000003329e430 00000000 00000000 00000000 00000000 <7>[ 4.006741] 7:xhci_hcd 0000:00:04.1: @000000003329e440 00000000 00000000 00000000 00000000 <7>[ 4.006805] 7:xhci_hcd 0000:00:04.1: @000000003329e450 00000000 00000000 00000000 00000000 <7>[ 4.006870] 7:xhci_hcd 0000:00:04.1: @000000003329e460 00000000 00000000 00000000 00000000 <7>[ 4.006933] 7:xhci_hcd 0000:00:04.1: @000000003329e470 00000000 00000000 00000000 00000000 <7>[ 4.006998] 7:xhci_hcd 0000:00:04.1: @000000003329e480 00000000 00000000 00000000 00000000 <7>[ 4.007064] 7:xhci_hcd 0000:00:04.1: @000000003329e490 00000000 00000000 00000000 00000000 <7>[ 4.007129] 7:xhci_hcd 0000:00:04.1: @000000003329e4a0 00000000 00000000 00000000 00000000 <7>[ 4.007201] 7:xhci_hcd 0000:00:04.1: @000000003329e4b0 00000000 00000000 00000000 00000000 <7>[ 4.007265] 7:xhci_hcd 0000:00:04.1: @000000003329e4c0 00000000 00000000 00000000 00000000 <7>[ 4.007330] 7:xhci_hcd 0000:00:04.1: @000000003329e4d0 00000000 00000000 00000000 00000000 <7>[ 4.007395] 7:xhci_hcd 0000:00:04.1: @000000003329e4e0 00000000 00000000 00000000 00000000 <7>[ 4.007459] 7:xhci_hcd 0000:00:04.1: @000000003329e4f0 00000000 00000000 00000000 00000000 <7>[ 4.007524] 7:xhci_hcd 0000:00:04.1: @000000003329e500 00000000 00000000 00000000 00000000 <7>[ 4.007589] 7:xhci_hcd 0000:00:04.1: @000000003329e510 00000000 00000000 00000000 00000000 <7>[ 4.007654] 7:xhci_hcd 0000:00:04.1: @000000003329e520 00000000 00000000 00000000 00000000 <7>[ 4.007718] 7:xhci_hcd 0000:00:04.1: @000000003329e530 00000000 00000000 00000000 00000000 <7>[ 4.007782] 7:xhci_hcd 0000:00:04.1: @000000003329e540 00000000 00000000 00000000 00000000 <7>[ 4.007846] 7:xhci_hcd 0000:00:04.1: @000000003329e550 00000000 00000000 00000000 00000000 <7>[ 4.007910] 7:xhci_hcd 0000:00:04.1: @000000003329e560 00000000 00000000 00000000 00000000 <7>[ 4.007976] 7:xhci_hcd 0000:00:04.1: @000000003329e570 00000000 00000000 00000000 00000000 <7>[ 4.008043] 7:xhci_hcd 0000:00:04.1: @000000003329e580 00000000 00000000 00000000 00000000 <7>[ 4.008108] 7:xhci_hcd 0000:00:04.1: @000000003329e590 00000000 00000000 00000000 00000000 <7>[ 4.008181] 7:xhci_hcd 0000:00:04.1: @000000003329e5a0 00000000 00000000 00000000 00000000 <7>[ 4.008245] 7:xhci_hcd 0000:00:04.1: @000000003329e5b0 00000000 00000000 00000000 00000000 <7>[ 4.008310] 7:xhci_hcd 0000:00:04.1: @000000003329e5c0 00000000 00000000 00000000 00000000 <7>[ 4.008375] 7:xhci_hcd 0000:00:04.1: @000000003329e5d0 00000000 00000000 00000000 00000000 <7>[ 4.008440] 7:xhci_hcd 0000:00:04.1: @000000003329e5e0 00000000 00000000 00000000 00000000 <7>[ 4.008504] 7:xhci_hcd 0000:00:04.1: @000000003329e5f0 00000000 00000000 00000000 00000000 <7>[ 4.008569] 7:xhci_hcd 0000:00:04.1: @000000003329e600 00000000 00000000 00000000 00000000 <7>[ 4.008633] 7:xhci_hcd 0000:00:04.1: @000000003329e610 00000000 00000000 00000000 00000000 <7>[ 4.008698] 7:xhci_hcd 0000:00:04.1: @000000003329e620 00000000 00000000 00000000 00000000 <7>[ 4.008763] 7:xhci_hcd 0000:00:04.1: @000000003329e630 00000000 00000000 00000000 00000000 <7>[ 4.008827] 7:xhci_hcd 0000:00:04.1: @000000003329e640 00000000 00000000 00000000 00000000 <7>[ 4.008891] 7:xhci_hcd 0000:00:04.1: @000000003329e650 00000000 00000000 00000000 00000000 <7>[ 4.008955] 7:xhci_hcd 0000:00:04.1: @000000003329e660 00000000 00000000 00000000 00000000 <7>[ 4.009019] 7:xhci_hcd 0000:00:04.1: @000000003329e670 00000000 00000000 00000000 00000000 <7>[ 4.009085] 7:xhci_hcd 0000:00:04.1: @000000003329e680 00000000 00000000 00000000 00000000 <7>[ 4.009150] 7:xhci_hcd 0000:00:04.1: @000000003329e690 00000000 00000000 00000000 00000000 <7>[ 4.009221] 7:xhci_hcd 0000:00:04.1: @000000003329e6a0 00000000 00000000 00000000 00000000 <7>[ 4.009286] 7:xhci_hcd 0000:00:04.1: @000000003329e6b0 00000000 00000000 00000000 00000000 <7>[ 4.009351] 7:xhci_hcd 0000:00:04.1: @000000003329e6c0 00000000 00000000 00000000 00000000 <7>[ 4.009415] 7:xhci_hcd 0000:00:04.1: @000000003329e6d0 00000000 00000000 00000000 00000000 <7>[ 4.009480] 7:xhci_hcd 0000:00:04.1: @000000003329e6e0 00000000 00000000 00000000 00000000 <7>[ 4.009545] 7:xhci_hcd 0000:00:04.1: @000000003329e6f0 00000000 00000000 00000000 00000000 <7>[ 4.009610] 7:xhci_hcd 0000:00:04.1: @000000003329e700 00000000 00000000 00000000 00000000 <7>[ 4.009675] 7:xhci_hcd 0000:00:04.1: @000000003329e710 00000000 00000000 00000000 00000000 <7>[ 4.009740] 7:xhci_hcd 0000:00:04.1: @000000003329e720 00000000 00000000 00000000 00000000 <7>[ 4.009804] 7:xhci_hcd 0000:00:04.1: @000000003329e730 00000000 00000000 00000000 00000000 <7>[ 4.009868] 7:xhci_hcd 0000:00:04.1: @000000003329e740 00000000 00000000 00000000 00000000 <7>[ 4.009932] 7:xhci_hcd 0000:00:04.1: @000000003329e750 00000000 00000000 00000000 00000000 <7>[ 4.009996] 7:xhci_hcd 0000:00:04.1: @000000003329e760 00000000 00000000 00000000 00000000 <7>[ 4.010062] 7:xhci_hcd 0000:00:04.1: @000000003329e770 00000000 00000000 00000000 00000000 <7>[ 4.010127] 7:xhci_hcd 0000:00:04.1: @000000003329e780 00000000 00000000 00000000 00000000 <7>[ 4.010199] 7:xhci_hcd 0000:00:04.1: @000000003329e790 00000000 00000000 00000000 00000000 <7>[ 4.010264] 7:xhci_hcd 0000:00:04.1: @000000003329e7a0 00000000 00000000 00000000 00000000 <7>[ 4.010328] 7:xhci_hcd 0000:00:04.1: @000000003329e7b0 00000000 00000000 00000000 00000000 <7>[ 4.010393] 7:xhci_hcd 0000:00:04.1: @000000003329e7c0 00000000 00000000 00000000 00000000 <7>[ 4.010457] 7:xhci_hcd 0000:00:04.1: @000000003329e7d0 00000000 00000000 00000000 00000000 <7>[ 4.010522] 7:xhci_hcd 0000:00:04.1: @000000003329e7e0 00000000 00000000 00000000 00000000 <7>[ 4.010586] 7:xhci_hcd 0000:00:04.1: @000000003329e7f0 00000000 00000000 00000000 00000000 <7>[ 4.010649] 7:xhci_hcd 0000:00:04.1: Ring has not been updated <7>[ 4.010699] 7:xhci_hcd 0000:00:04.1: Ring deq = d329e400 (virt), 0x3329e400 (dma) <7>[ 4.010756] 7:xhci_hcd 0000:00:04.1: Ring deq updated 0 times <7>[ 4.010803] 7:xhci_hcd 0000:00:04.1: Ring enq = d329e400 (virt), 0x3329e400 (dma) <7>[ 4.010860] 7:xhci_hcd 0000:00:04.1: Ring enq updated 0 times <7>[ 4.010907] 7:xhci_hcd 0000:00:04.1: ERST deq = 64"h3329e400 <7>[ 4.010953] 7:xhci_hcd 0000:00:04.1: // Set the interrupt modulation register <7>[ 4.011012] 7:xhci_hcd 0000:00:04.1: // Enable interrupts, cmd = 0x4. <7>[ 4.011064] 7:xhci_hcd 0000:00:04.1: // Enabling event ring interrupter b0100460 by writing 0x2 to irq_pending <7>[ 4.011141] 7:xhci_hcd 0000:00:04.1: b0100460: ir_set[0] <7>[ 4.011193] 7:xhci_hcd 0000:00:04.1: b0100460: ir_set.pending = 0x2 <7>[ 4.011245] 7:xhci_hcd 0000:00:04.1: b0100464: ir_set.cOntrol= 0xa0 <7>[ 4.011298] 7:xhci_hcd 0000:00:04.1: b0100468: ir_set.erst_size = 0x1 <7>[ 4.011351] 7:xhci_hcd 0000:00:04.1: b0100470: ir_set.erst_base = @332a6000 <7>[ 4.011408] 7:xhci_hcd 0000:00:04.1: b0100478: ir_set.erst_dequeue = @3329e400 <7>[ 4.011465] 7:xhci_hcd 0000:00:04.1: Finished xhci_run for USB2 roothub <7>[ 4.011760] 7:usb usb1: default language 0x0409 <7>[ 4.011948] 7:usb usb1: udev 1, busnum 1, minor = 0 <7>[ 4.011993] 7:usb usb1: New USB device found, idVendor=1d6b, idProduct=0002 <7>[ 4.012050] 7:usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 <7>[ 4.012108] 7:usb usb1: Product: xHCI Host Controller <7>[ 4.012152] 7:usb usb1: Manufacturer: Linux (none) xhci_hcd <7>[ 4.012206] 7:usb usb1: SerialNumber: 0000:00:04.1 <7>[ 4.012524] 7:usb usb1: usb_probe_device <7>[ 4.012562] 7:usb usb1: configuration #1 chosen from 1 choice <7>[ 4.012688] 7:usb usb1: adding 1-0:1.0 (config #1, interface 0) <7>[ 4.012909] 7:hub 1-0:1.0: usb_probe_interface <7>[ 4.012948] 7:hub 1-0:1.0: usb_probe_interface - got id <6>[ 4.012992] 7:hub 1-0:1.0: USB hub found <6>[ 4.013107] 7:hub 1-0:1.0: 1 port detected <7>[ 4.013148] 7:hub 1-0:1.0: standalone hub <7>[ 4.013193] 7:hub 1-0:1.0: no power switching (usb 1.0) <7>[ 4.013236] 7:hub 1-0:1.0: individual port over-current protection <7>[ 4.013285] 7:hub 1-0:1.0: Single TT <7>[ 4.013318] 7:hub 1-0:1.0: TT requires at most 8 FS bit times (666 ns) <7>[ 4.013370] 7:hub 1-0:1.0: power on to power good time: 20ms <7>[ 4.013509] 7:hub 1-0:1.0: local power source is good <7>[ 4.013590] 7:hub 1-0:1.0: trying to enable port power on non-switchable hub <7>[ 4.013656] 7:xhci_hcd 0000:00:04.1: set port power, actual port 0 status = 0x2a0 <6>[ 4.014252] 7:xhci_hcd 0000:00:04.1: xHCI Host Controller <6>[ 4.014332] 7:xhci_hcd 0000:00:04.1: new USB bus registered, assigned bus number 2 <7>[ 4.014403] 7:xhci_hcd 0000:00:04.1: // Turn on HC, cmd = 0x5. <7>[ 4.014452] 7:xhci_hcd 0000:00:04.1: Finished xhci_run for USB3 roothub <7>[ 4.014727] 7:usb usb2: skipped 1 descriptor after endpoint <7>[ 4.014827] 7:usb usb2: default language 0x0409 <7>[ 4.015015] 7:usb usb2: udev 1, busnum 2, minor = 128 <7>[ 4.015062] 7:usb usb2: New USB device found, idVendor=1d6b, idProduct=0003 <7>[ 4.015118] 7:usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 <7>[ 4.015184] 7:usb usb2: Product: xHCI Host Controller <7>[ 4.015227] 7:usb usb2: Manufacturer: Linux (none) xhci_hcd <7>[ 4.015273] 7:usb usb2: SerialNumber: 0000:00:04.1 <7>[ 4.015572] 7:usb usb2: usb_probe_device <7>[ 4.015609] 7:usb usb2: configuration #1 chosen from 1 choice <7>[ 4.015727] 7:usb usb2: adding 2-0:1.0 (config #1, interface 0) <7>[ 4.015935] 7:hub 2-0:1.0: usb_probe_interface <7>[ 4.015975] 7:hub 2-0:1.0: usb_probe_interface - got id <6>[ 4.016018] 7:hub 2-0:1.0: USB hub found <6>[ 4.016114] 7:hub 2-0:1.0: 1 port detected <7>[ 4.016151] 7:hub 2-0:1.0: standalone hub <7>[ 4.016195] 7:hub 2-0:1.0: no power switching (usb 1.0) <7>[ 4.016237] 7:hub 2-0:1.0: individual port over-current protection <7>[ 4.016288] 7:hub 2-0:1.0: TT requires at most 8 FS bit times (666 ns) <7>[ 4.016340] 7:hub 2-0:1.0: power on to power good time: 20ms <7>[ 4.016464] 7:hub 2-0:1.0: local power source is good <7>[ 4.016540] 7:hub 2-0:1.0: trying to enable port power on non-switchable hub <7>[ 4.016603] 7:xhci_hcd 0000:00:04.1: set port power, actual port 0 status = 0x2a0 <7>[ 4.017018] 7:PCI: Setting latency timer of device 0000:00:04.2 to 64 <6>[ 4.017074] 7:xhci_hcd 0000:00:04.2: xHCI Host Controller <6>[ 4.017167] 7:xhci_hcd 0000:00:04.2: new USB bus registered, assigned bus number 3 <7>[ 4.017257] 7:xhci_hcd 0000:00:04.2: xHCI capability registers at b0200000: <7>[ 4.017311] 7:xhci_hcd 0000:00:04.2: CAPLENGTH AND HCIVERSION 0x1000020: <7>[ 4.017363] 7:xhci_hcd 0000:00:04.2: CAPLENGTH: 0x20 <7>[ 4.017405] 7:xhci_hcd 0000:00:04.2: HCIVERSION: 0x100 <7>[ 4.017448] 7:xhci_hcd 0000:00:04.2: HCSPARAMS 1: 0x2000840 <7>[ 4.017494] 7:xhci_hcd 0000:00:04.2: Max device slots: 64 <7>[ 4.017539] 7:xhci_hcd 0000:00:04.2: Max interrupters: 8 <7>[ 4.017583] 7:xhci_hcd 0000:00:04.2: Max ports: 2 <7>[ 4.017624] 7:xhci_hcd 0000:00:04.2: HCSPARAMS 2: 0xc0000f1 <7>[ 4.017669] 7:xhci_hcd 0000:00:04.2: Isoc scheduling threshold: 1 <7>[ 4.017718] 7:xhci_hcd 0000:00:04.2: Maximum allowed segments in event ring: 15 <7>[ 4.017776] 7:xhci_hcd 0000:00:04.2: HCSPARAMS 3 0x7ff000a: <7>[ 4.017821] 7:xhci_hcd 0000:00:04.2: Worst case U1 device exit latency: 10 <7>[ 4.017875] 7:xhci_hcd 0000:00:04.2: Worst case U2 device exit latency: 2047 <7>[ 4.017931] 7:xhci_hcd 0000:00:04.2: HCC PARAMS 0x258f065: <7>[ 4.017977] 7:xhci_hcd 0000:00:04.2: HC generates 64 bit addresses <7>[ 4.018027] 7:xhci_hcd 0000:00:04.2: FIXME: more HCCPARAMS debugging <7>[ 4.018078] 7:xhci_hcd 0000:00:04.2: RTSOFF 0x440: <7>[ 4.018119] 7:xhci_hcd 0000:00:04.2: xHCI operational registers at b0200020: <7>[ 4.018182] 7:xhci_hcd 0000:00:04.2: USBCMD 0x0: <7>[ 4.018221] 7:xhci_hcd 0000:00:04.2: HC is being stopped <7>[ 4.018266] 7:xhci_hcd 0000:00:04.2: HC has finished hard reset <7>[ 4.018314] 7:xhci_hcd 0000:00:04.2: Event Interrupts disabled <7>[ 4.018362] 7:xhci_hcd 0000:00:04.2: Host System Error Interrupts disabled <7>[ 4.018417] 7:xhci_hcd 0000:00:04.2: HC has finished light reset <7>[ 4.018467] 7:xhci_hcd 0000:00:04.2: USBSTS 0x1: <7>[ 4.018506] 7:xhci_hcd 0000:00:04.2: Event ring is empty <7>[ 4.018550] 7:xhci_hcd 0000:00:04.2: No Host System Error <7>[ 4.018595] 7:xhci_hcd 0000:00:04.2: HC is halted <7>[ 4.018637] 7:xhci_hcd 0000:00:04.2: b0200420 port status reg = 0x2a0 <7>[ 4.018689] 7:xhci_hcd 0000:00:04.2: b0200424 port power reg = 0x0 <7>[ 4.018740] 7:xhci_hcd 0000:00:04.2: b0200428 port link reg = 0x0 <7>[ 4.018788] 7:xhci_hcd 0000:00:04.2: b020042c port reserved reg = 0x0 <7>[ 4.018839] 7:xhci_hcd 0000:00:04.2: b0200430 port status reg = 0x80 <7>[ 4.018890] 7:xhci_hcd 0000:00:04.2: b0200434 port power reg = 0x0 <7>[ 4.018939] 7:xhci_hcd 0000:00:04.2: b0200438 port link reg = 0x0 <7>[ 4.018988] 7:xhci_hcd 0000:00:04.2: b020043c port reserved reg = 0x0 <7>[ 4.019042] 7:xhci_hcd 0000:00:04.2: // Halt the HC <7>[ 4.019084] 7:xhci_hcd 0000:00:04.2: Resetting HCD <7>[ 4.019126] 7:xhci_hcd 0000:00:04.2: // Reset the HC <7>[ 4.019212] 7:xhci_hcd 0000:00:04.2: Wait for controller to be ready for doorbell rings <7>[ 4.019273] 7:xhci_hcd 0000:00:04.2: Reset complete <7>[ 4.019314] 7:xhci_hcd 0000:00:04.2: Enabling 64-bit DMA addresses. <7>[ 4.019363] 7:xhci_hcd 0000:00:04.2: Calling HCD init <7>[ 4.019404] 7:xhci_hcd 0000:00:04.2: xhci_init <7>[ 4.019443] 7:xhci_hcd 0000:00:04.2: xHCI doesn"t need link TRB QUIRK <7>[ 4.019494] 7:xhci_hcd 0000:00:04.2: Supported page size register = 0x1 <7>[ 4.019546] 7:xhci_hcd 0000:00:04.2: Supported page size of 4K <7>[ 4.019592] 7:xhci_hcd 0000:00:04.2: HCD page size set to 4K <7>[ 4.019639] 7:xhci_hcd 0000:00:04.2: // xHC can handle at most 64 device slots. <7>[ 4.019696] 7:xhci_hcd 0000:00:04.2: // Setting Max device slots reg = 0x40. <7>[ 4.019758] 7:xhci_hcd 0000:00:04.2: // Device context base array address = 0x332b6000 (DMA), d32b6000 (virt) <7>[ 4.019857] 7:xhci_hcd 0000:00:04.2: Allocated command ring at e8ed1f00 <7>[ 4.019909] 7:xhci_hcd 0000:00:04.2: First segment DMA is 0x332b7000 <7>[ 4.019960] 7:xhci_hcd 0000:00:04.2: // Setting command ring address to 0x40 <7>[ 4.020017] 7:xhci_hcd 0000:00:04.2: // xHC command ring deq ptr low bits + flags = @00000000 <7>[ 4.020082] 7:xhci_hcd 0000:00:04.2: // xHC command ring deq ptr high bits = @00000000 <7>[ 4.020164] 7:xhci_hcd 0000:00:04.2: // Doorbell array is located at offset 0x560 from cap regs base addr <7>[ 4.020236] 7:xhci_hcd 0000:00:04.2: // xHCI capability registers at b0200000: <7>[ 4.020294] 7:xhci_hcd 0000:00:04.2: // @b0200000 = 0x1000020 (CAPLENGTH AND HCIVERSION) <7>[ 4.020355] 7:xhci_hcd 0000:00:04.2: // CAPLENGTH: 0x20 <7>[ 4.020399] 7:xhci_hcd 0000:00:04.2: // xHCI operational registers at b0200020: <7>[ 4.020457] 7:xhci_hcd 0000:00:04.2: // @b0200018 = 0x440 RTSOFF <7>[ 4.020505] 7:xhci_hcd 0000:00:04.2: // xHCI runtime registers at b0200440: <7>[ 4.020561] 7:xhci_hcd 0000:00:04.2: // @b0200014 = 0x560 DBOFF <7>[ 4.020608] 7:xhci_hcd 0000:00:04.2: // Doorbell array at b0200560: <7>[ 4.020658] 7:xhci_hcd 0000:00:04.2: xHCI runtime registers at b0200440: <7>[ 4.020711] 7:xhci_hcd 0000:00:04.2: b0200440: Microframe index = 0x0 <7>[ 4.020765] 7:xhci_hcd 0000:00:04.2: // Allocating event ring <7>[ 4.020831] 7:xhci_hcd 0000:00:04.2: TRB math tests passed. <7>[ 4.020879] 7:xhci_hcd 0000:00:04.2: // Allocated event ring segment table at 0x332ba000 <7>[ 4.020942] 7:xhci_hcd 0000:00:04.2: Set ERST to 0; private num segs = 1, virt addr = d32ba000, dma addr = 0x332ba000 <7>[ 4.021021] 7:xhci_hcd 0000:00:04.2: // Write ERST size = 1 to ir_set 0 (some bits preserved) <7>[ 4.021086] 7:xhci_hcd 0000:00:04.2: // Set ERST entries to point to event ring. <7>[ 4.021144] 7:xhci_hcd 0000:00:04.2: // Set ERST base address for ir_set 0 = 0x332ba000 <7>[ 4.021214] 7:xhci_hcd 0000:00:04.2: // Write event ring dequeue pointer, preserving EHB bit <7>[ 4.021279] 7:xhci_hcd 0000:00:04.2: Wrote ERST address to ir_set 0. <7>[ 4.021330] 7:xhci_hcd 0000:00:04.2: Allocating 1 scratchpad buffers <7>[ 4.021405] 7:xhci_hcd 0000:00:04.2: Ext Cap b0200970, port offset = 1, count = 1, revision = 0x2 <7>[ 4.021472] 7:xhci_hcd 0000:00:04.2: xHCI 1.0: support USB2 software lpm <7>[ 4.021525] 7:xhci_hcd 0000:00:04.2: xHCI 1.0: support USB2 hardware lpm <7>[ 4.021580] 7:xhci_hcd 0000:00:04.2: Ext Cap b0200980, port offset = 2, count = 1, revision = 0x3 <7>[ 4.021648] 7:xhci_hcd 0000:00:04.2: Found 1 USB 2.0 ports and 1 USB 3.0 ports. <7>[ 4.021707] 7:xhci_hcd 0000:00:04.2: USB 2.0 port at index 0, addr = b0200420 <7>[ 4.021765] 7:xhci_hcd 0000:00:04.2: USB 3.0 port at index 1, addr = b0200430 <7>[ 4.021820] 7:xhci_hcd 0000:00:04.2: Finished xhci_init <7>[ 4.021863] 7:xhci_hcd 0000:00:04.2: Called HCD init <7>[ 4.021905] 7:xhci_hcd 0000:00:04.2: Got SBRN 0 <7>[ 4.021943] 7:PCI: cache line size of 64 is not supported by device 0000:00:04.2 <7>[ 4.022000] 7:xhci_hcd 0000:00:04.2: Finished xhci_pci_reinit <7>[ 4.022049] 7:xhci_hcd 0000:00:04.2: xhci_run <7>[ 4.022088] 7:xhci_hcd 0000:00:04.2: Failed to enable MSI-X <7>[ 4.022137] 7:xhci_hcd 0000:00:04.2: failed to allocate MSI entry <7>[ 4.022204] 7:xhci_hcd 0000:00:04.2: Command ring memory map follows: <7>[ 4.022258] 7:xhci_hcd 0000:00:04.2: @00000000332b7000 00000000 00000000 00000000 00000000 <7>[ 4.022323] 7:xhci_hcd 0000:00:04.2: @00000000332b7010 00000000 00000000 00000000 00000000 <7>[ 4.022389] 7:xhci_hcd 0000:00:04.2: @00000000332b7020 00000000 00000000 00000000 00000000 <7>[ 4.022453] 7:xhci_hcd 0000:00:04.2: @00000000332b7030 00000000 00000000 00000000 00000000 <7>[ 4.022519] 7:xhci_hcd 0000:00:04.2: @00000000332b7040 00000000 00000000 00000000 00000000 <7>[ 4.022584] 7:xhci_hcd 0000:00:04.2: @00000000332b7050 00000000 00000000 00000000 00000000 <7>[ 4.022648] 7:xhci_hcd 0000:00:04.2: @00000000332b7060 00000000 00000000 00000000 00000000 <7>[ 4.022713] 7:xhci_hcd 0000:00:04.2: @00000000332b7070 00000000 00000000 00000000 00000000 <7>[ 4.022778] 7:xhci_hcd 0000:00:04.2: @00000000332b7080 00000000 00000000 00000000 00000000 <7>[ 4.022842] 7:xhci_hcd 0000:00:04.2: @00000000332b7090 00000000 00000000 00000000 00000000 <7>[ 4.022906] 7:xhci_hcd 0000:00:04.2: @00000000332b70a0 00000000 00000000 00000000 00000000 <7>[ 4.022971] 7:xhci_hcd 0000:00:04.2: @00000000332b70b0 00000000 00000000 00000000 00000000 <7>[ 4.023039] 7:xhci_hcd 0000:00:04.2: @00000000332b70c0 00000000 00000000 00000000 00000000 <7>[ 4.023106] 7:xhci_hcd 0000:00:04.2: @00000000332b70d0 00000000 00000000 00000000 00000000 <7>[ 4.023178] 7:xhci_hcd 0000:00:04.2: @00000000332b70e0 00000000 00000000 00000000 00000000 <7>[ 4.023243] 7:xhci_hcd 0000:00:04.2: @00000000332b70f0 00000000 00000000 00000000 00000000 <7>[ 4.023309] 7:xhci_hcd 0000:00:04.2: @00000000332b7100 00000000 00000000 00000000 00000000 <7>[ 4.023374] 7:xhci_hcd 0000:00:04.2: @00000000332b7110 00000000 00000000 00000000 00000000 <7>[ 4.023438] 7:xhci_hcd 0000:00:04.2: @00000000332b7120 00000000 00000000 00000000 00000000 <7>[ 4.023503] 7:xhci_hcd 0000:00:04.2: @00000000332b7130 00000000 00000000 00000000 00000000 <7>[ 4.023568] 7:xhci_hcd 0000:00:04.2: @00000000332b7140 00000000 00000000 00000000 00000000 <7>[ 4.023633] 7:xhci_hcd 0000:00:04.2: @00000000332b7150 00000000 00000000 00000000 00000000 <7>[ 4.023697] 7:xhci_hcd 0000:00:04.2: @00000000332b7160 00000000 00000000 00000000 00000000 <7>[ 4.023762] 7:xhci_hcd 0000:00:04.2: @00000000332b7170 00000000 00000000 00000000 00000000 <7>[ 4.023826] 7:xhci_hcd 0000:00:04.2: @00000000332b7180 00000000 00000000 00000000 00000000 <7>[ 4.023889] 7:xhci_hcd 0000:00:04.2: @00000000332b7190 00000000 00000000 00000000 00000000 <7>[ 4.023954] 7:xhci_hcd 0000:00:04.2: @00000000332b71a0 00000000 00000000 00000000 00000000 <7>[ 4.024018] 7:xhci_hcd 0000:00:04.2: @00000000332b71b0 00000000 00000000 00000000 00000000 <7>[ 4.024083] 7:xhci_hcd 0000:00:04.2: @00000000332b71c0 00000000 00000000 00000000 00000000 <7>[ 4.024148] 7:xhci_hcd 0000:00:04.2: @00000000332b71d0 00000000 00000000 00000000 00000000 <7>[ 4.024220] 7:xhci_hcd 0000:00:04.2: @00000000332b71e0 00000000 00000000 00000000 00000000 <7>[ 4.024285] 7:xhci_hcd 0000:00:04.2: @00000000332b71f0 00000000 00000000 00000000 00000000 <7>[ 4.024350] 7:xhci_hcd 0000:00:04.2: @00000000332b7200 00000000 00000000 00000000 00000000 <7>[ 4.024414] 7:xhci_hcd 0000:00:04.2: @00000000332b7210 00000000 00000000 00000000 00000000 <7>[ 4.024479] 7:xhci_hcd 0000:00:04.2: @00000000332b7220 00000000 00000000 00000000 00000000 <7>[ 4.024544] 7:xhci_hcd 0000:00:04.2: @00000000332b7230 00000000 00000000 00000000 00000000 <7>[ 4.024608] 7:xhci_hcd 0000:00:04.2: @00000000332b7240 00000000 00000000 00000000 00000000 <7>[ 4.024673] 7:xhci_hcd 0000:00:04.2: @00000000332b7250 00000000 00000000 00000000 00000000 <7>[ 4.024738] 7:xhci_hcd 0000:00:04.2: @00000000332b7260 00000000 00000000 00000000 00000000 <7>[ 4.024802] 7:xhci_hcd 0000:00:04.2: @00000000332b7270 00000000 00000000 00000000 00000000 <7>[ 4.024865] 7:xhci_hcd 0000:00:04.2: @00000000332b7280 00000000 00000000 00000000 00000000 <7>[ 4.024929] 7:xhci_hcd 0000:00:04.2: @00000000332b7290 00000000 00000000 00000000 00000000 <7>[ 4.024993] 7:xhci_hcd 0000:00:04.2: @00000000332b72a0 00000000 00000000 00000000 00000000 <7>[ 4.025059] 7:xhci_hcd 0000:00:04.2: @00000000332b72b0 00000000 00000000 00000000 00000000 <7>[ 4.025124] 7:xhci_hcd 0000:00:04.2: @00000000332b72c0 00000000 00000000 00000000 00000000 <7>[ 4.025196] 7:xhci_hcd 0000:00:04.2: @00000000332b72d0 00000000 00000000 00000000 00000000 <7>[ 4.025260] 7:xhci_hcd 0000:00:04.2: @00000000332b72e0 00000000 00000000 00000000 00000000 <7>[ 4.025325] 7:xhci_hcd 0000:00:04.2: @00000000332b72f0 00000000 00000000 00000000 00000000 <7>[ 4.025390] 7:xhci_hcd 0000:00:04.2: @00000000332b7300 00000000 00000000 00000000 00000000 <7>[ 4.025455] 7:xhci_hcd 0000:00:04.2: @00000000332b7310 00000000 00000000 00000000 00000000 <7>[ 4.025519] 7:xhci_hcd 0000:00:04.2: @00000000332b7320 00000000 00000000 00000000 00000000 <7>[ 4.025584] 7:xhci_hcd 0000:00:04.2: @00000000332b7330 00000000 00000000 00000000 00000000 <7>[ 4.025649] 7:xhci_hcd 0000:00:04.2: @00000000332b7340 00000000 00000000 00000000 00000000 <7>[ 4.025714] 7:xhci_hcd 0000:00:04.2: @00000000332b7350 00000000 00000000 00000000 00000000 <7>[ 4.025778] 7:xhci_hcd 0000:00:04.2: @00000000332b7360 00000000 00000000 00000000 00000000 <7>[ 4.025841] 7:xhci_hcd 0000:00:04.2: @00000000332b7370 00000000 00000000 00000000 00000000 <7>[ 4.025905] 7:xhci_hcd 0000:00:04.2: @00000000332b7380 00000000 00000000 00000000 00000000 <7>[ 4.025971] 7:xhci_hcd 0000:00:04.2: @00000000332b7390 00000000 00000000 00000000 00000000 <7>[ 4.026038] 7:xhci_hcd 0000:00:04.2: @00000000332b73a0 00000000 00000000 00000000 00000000 <7>[ 4.026105] 7:xhci_hcd 0000:00:04.2: @00000000332b73b0 00000000 00000000 00000000 00000000 <7>[ 4.026177] 7:xhci_hcd 0000:00:04.2: @00000000332b73c0 00000000 00000000 00000000 00000000 <7>[ 4.026242] 7:xhci_hcd 0000:00:04.2: @00000000332b73d0 00000000 00000000 00000000 00000000 <7>[ 4.026307] 7:xhci_hcd 0000:00:04.2: @00000000332b73e0 00000000 00000000 00000000 00000000 <7>[ 4.026372] 7:xhci_hcd 0000:00:04.2: @00000000332b73f0 332b7000 00000000 00000000 00001802 <7>[ 4.026435] 7:xhci_hcd 0000:00:04.2: Ring has not been updated <7>[ 4.026485] 7:xhci_hcd 0000:00:04.2: Ring deq = d32b7000 (virt), 0x332b7000 (dma) <7>[ 4.026543] 7:xhci_hcd 0000:00:04.2: Ring deq updated 0 times <7>[ 4.026590] 7:xhci_hcd 0000:00:04.2: Ring enq = d32b7000 (virt), 0x332b7000 (dma) <7>[ 4.026648] 7:xhci_hcd 0000:00:04.2: Ring enq updated 0 times <7>[ 4.026696] 7:xhci_hcd 0000:00:04.2: // xHC command ring deq ptr low bits + flags = @00000000 <7>[ 4.026761] 7:xhci_hcd 0000:00:04.2: // xHC command ring deq ptr high bits = @00000000 <7>[ 4.026820] 7:xhci_hcd 0000:00:04.2: ERST memory map follows: <7>[ 4.026868] 7:xhci_hcd 0000:00:04.2: @00000000332ba000 332b7400 00000000 00000040 00000000 <7>[ 4.026930] 7:xhci_hcd 0000:00:04.2: Event ring: <7>[ 4.026974] 7:xhci_hcd 0000:00:04.2: @00000000332b7400 00000000 00000000 00000000 00000000 <7>[ 4.027041] 7:xhci_hcd 0000:00:04.2: @00000000332b7410 00000000 00000000 00000000 00000000 <7>[ 4.027107] 7:xhci_hcd 0000:00:04.2: @00000000332b7420 00000000 00000000 00000000 00000000 <7>[ 4.027179] 7:xhci_hcd 0000:00:04.2: @00000000332b7430 00000000 00000000 00000000 00000000 <7>[ 4.027244] 7:xhci_hcd 0000:00:04.2: @00000000332b7440 00000000 00000000 00000000 00000000 <7>[ 4.027309] 7:xhci_hcd 0000:00:04.2: @00000000332b7450 00000000 00000000 00000000 00000000 <7>[ 4.027374] 7:xhci_hcd 0000:00:04.2: @00000000332b7460 00000000 00000000 00000000 00000000 <7>[ 4.027438] 7:xhci_hcd 0000:00:04.2: @00000000332b7470 00000000 00000000 00000000 00000000 <7>[ 4.027503] 7:xhci_hcd 0000:00:04.2: @00000000332b7480 00000000 00000000 00000000 00000000 <7>[ 4.027568] 7:xhci_hcd 0000:00:04.2: @00000000332b7490 00000000 00000000 00000000 00000000 <7>[ 4.027632] 7:xhci_hcd 0000:00:04.2: @00000000332b74a0 00000000 00000000 00000000 00000000 <7>[ 4.027697] 7:xhci_hcd 0000:00:04.2: @00000000332b74b0 00000000 00000000 00000000 00000000 <7>[ 4.027762] 7:xhci_hcd 0000:00:04.2: @00000000332b74c0 00000000 00000000 00000000 00000000 <7>[ 4.027826] 7:xhci_hcd 0000:00:04.2: @00000000332b74d0 00000000 00000000 00000000 00000000 <7>[ 4.027890] 7:xhci_hcd 0000:00:04.2: @00000000332b74e0 00000000 00000000 00000000 00000000 <7>[ 4.027954] 7:xhci_hcd 0000:00:04.2: @00000000332b74f0 00000000 00000000 00000000 00000000 <7>[ 4.028019] 7:xhci_hcd 0000:00:04.2: @00000000332b7500 00000000 00000000 00000000 00000000 <7>[ 4.028084] 7:xhci_hcd 0000:00:04.2: @00000000332b7510 00000000 00000000 00000000 00000000 <7>[ 4.028150] 7:xhci_hcd 0000:00:04.2: @00000000332b7520 00000000 00000000 00000000 00000000 <7>[ 4.028221] 7:xhci_hcd 0000:00:04.2: @00000000332b7530 00000000 00000000 00000000 00000000 <7>[ 4.028286] 7:xhci_hcd 0000:00:04.2: @00000000332b7540 00000000 00000000 00000000 00000000 <7>[ 4.028351] 7:xhci_hcd 0000:00:04.2: @00000000332b7550 00000000 00000000 00000000 00000000 <7>[ 4.028416] 7:xhci_hcd 0000:00:04.2: @00000000332b7560 00000000 00000000 00000000 00000000 <7>[ 4.028481] 7:xhci_hcd 0000:00:04.2: @00000000332b7570 00000000 00000000 00000000 00000000 <7>[ 4.028546] 7:xhci_hcd 0000:00:04.2: @00000000332b7580 00000000 00000000 00000000 00000000 <7>[ 4.028610] 7:xhci_hcd 0000:00:04.2: @00000000332b7590 00000000 00000000 00000000 00000000 <7>[ 4.028674] 7:xhci_hcd 0000:00:04.2: @00000000332b75a0 00000000 00000000 00000000 00000000 <7>[ 4.028739] 7:xhci_hcd 0000:00:04.2: @00000000332b75b0 00000000 00000000 00000000 00000000 <7>[ 4.028804] 7:xhci_hcd 0000:00:04.2: @00000000332b75c0 00000000 00000000 00000000 00000000 <7>[ 4.028868] 7:xhci_hcd 0000:00:04.2: @00000000332b75d0 00000000 00000000 00000000 00000000 <7>[ 4.028931] 7:xhci_hcd 0000:00:04.2: @00000000332b75e0 00000000 00000000 00000000 00000000 <7>[ 4.028995] 7:xhci_hcd 0000:00:04.2: @00000000332b75f0 00000000 00000000 00000000 00000000 <7>[ 4.029061] 7:xhci_hcd 0000:00:04.2: @00000000332b7600 00000000 00000000 00000000 00000000 <7>[ 4.029126] 7:xhci_hcd 0000:00:04.2: @00000000332b7610 00000000 00000000 00000000 00000000 <7>[ 4.029198] 7:xhci_hcd 0000:00:04.2: @00000000332b7620 00000000 00000000 00000000 00000000 <7>[ 4.029262] 7:xhci_hcd 0000:00:04.2: @00000000332b7630 00000000 00000000 00000000 00000000 <7>[ 4.029327] 7:xhci_hcd 0000:00:04.2: @00000000332b7640 00000000 00000000 00000000 00000000 <7>[ 4.029391] 7:xhci_hcd 0000:00:04.2: @00000000332b7650 00000000 00000000 00000000 00000000 <7>[ 4.029456] 7:xhci_hcd 0000:00:04.2: @00000000332b7660 00000000 00000000 00000000 00000000 <7>[ 4.029520] 7:xhci_hcd 0000:00:04.2: @00000000332b7670 00000000 00000000 00000000 00000000 <7>[ 4.029584] 7:xhci_hcd 0000:00:04.2: @00000000332b7680 00000000 00000000 00000000 00000000 <7>[ 4.029649] 7:xhci_hcd 0000:00:04.2: @00000000332b7690 00000000 00000000 00000000 00000000 <7>[ 4.029714] 7:xhci_hcd 0000:00:04.2: @00000000332b76a0 00000000 00000000 00000000 00000000 <7>[ 4.029778] 7:xhci_hcd 0000:00:04.2: @00000000332b76b0 00000000 00000000 00000000 00000000 <7>[ 4.029842] 7:xhci_hcd 0000:00:04.2: @00000000332b76c0 00000000 00000000 00000000 00000000 <7>[ 4.029906] 7:xhci_hcd 0000:00:04.2: @00000000332b76d0 00000000 00000000 00000000 00000000 <7>[ 4.029972] 7:xhci_hcd 0000:00:04.2: @00000000332b76e0 00000000 00000000 00000000 00000000 <7>[ 4.030039] 7:xhci_hcd 0000:00:04.2: @00000000332b76f0 00000000 00000000 00000000 00000000 <7>[ 4.030106] 7:xhci_hcd 0000:00:04.2: @00000000332b7700 00000000 00000000 00000000 00000000 <7>[ 4.030178] 7:xhci_hcd 0000:00:04.2: @00000000332b7710 00000000 00000000 00000000 00000000 <7>[ 4.030243] 7:xhci_hcd 0000:00:04.2: @00000000332b7720 00000000 00000000 00000000 00000000 <7>[ 4.030308] 7:xhci_hcd 0000:00:04.2: @00000000332b7730 00000000 00000000 00000000 00000000 <7>[ 4.030373] 7:xhci_hcd 0000:00:04.2: @00000000332b7740 00000000 00000000 00000000 00000000 <7>[ 4.030438] 7:xhci_hcd 0000:00:04.2: @00000000332b7750 00000000 00000000 00000000 00000000 <7>[ 4.030502] 7:xhci_hcd 0000:00:04.2: @00000000332b7760 00000000 00000000 00000000 00000000 <7>[ 4.030567] 7:xhci_hcd 0000:00:04.2: @00000000332b7770 00000000 00000000 00000000 00000000 <7>[ 4.030632] 7:xhci_hcd 0000:00:04.2: @00000000332b7780 00000000 00000000 00000000 00000000 <7>[ 4.030696] 7:xhci_hcd 0000:00:04.2: @00000000332b7790 00000000 00000000 00000000 00000000 <7>[ 4.030761] 7:xhci_hcd 0000:00:04.2: @00000000332b77a0 00000000 00000000 00000000 00000000 <7>[ 4.030825] 7:xhci_hcd 0000:00:04.2: @00000000332b77b0 00000000 00000000 00000000 00000000 <7>[ 4.030889] 7:xhci_hcd 0000:00:04.2: @00000000332b77c0 00000000 00000000 00000000 00000000 <7>[ 4.030953] 7:xhci_hcd 0000:00:04.2: @00000000332b77d0 00000000 00000000 00000000 00000000 <7>[ 4.031018] 7:xhci_hcd 0000:00:04.2: @00000000332b77e0 00000000 00000000 00000000 00000000 <7>[ 4.031083] 7:xhci_hcd 0000:00:04.2: @00000000332b77f0 00000000 00000000 00000000 00000000 <7>[ 4.031146] 7:xhci_hcd 0000:00:04.2: Ring has not been updated <7>[ 4.031203] 7:xhci_hcd 0000:00:04.2: Ring deq = d32b7400 (virt), 0x332b7400 (dma) <7>[ 4.031261] 7:xhci_hcd 0000:00:04.2: Ring deq updated 0 times <7>[ 4.031309] 7:xhci_hcd 0000:00:04.2: Ring enq = d32b7400 (virt), 0x332b7400 (dma) <7>[ 4.031367] 7:xhci_hcd 0000:00:04.2: Ring enq updated 0 times <7>[ 4.031415] 7:xhci_hcd 0000:00:04.2: ERST deq = 64"h332b7400 <7>[ 4.031461] 7:xhci_hcd 0000:00:04.2: // Set the interrupt modulation register <7>[ 4.031518] 7:xhci_hcd 0000:00:04.2: // Enable interrupts, cmd = 0x4. <7>[ 4.031570] 7:xhci_hcd 0000:00:04.2: // Enabling event ring interrupter b0200460 by writing 0x2 to irq_pending <7>[ 4.031645] 7:xhci_hcd 0000:00:04.2: b0200460: ir_set[0] <7>[ 4.031690] 7:xhci_hcd 0000:00:04.2: b0200460: ir_set.pending = 0x2 <7>[ 4.031741] 7:xhci_hcd 0000:00:04.2: b0200464: ir_set.cOntrol= 0xa0 <7>[ 4.031792] 7:xhci_hcd 0000:00:04.2: b0200468: ir_set.erst_size = 0x1 <7>[ 4.031845] 7:xhci_hcd 0000:00:04.2: b0200470: ir_set.erst_base = @332ba000 <7>[ 4.031901] 7:xhci_hcd 0000:00:04.2: b0200478: ir_set.erst_dequeue = @332b7400 <7>[ 4.031958] 7:xhci_hcd 0000:00:04.2: Finished xhci_run for USB2 roothub <7>[ 4.032229] 7:usb usb3: default language 0x0409 <7>[ 4.032411] 7:usb usb3: udev 1, busnum 3, minor = 256 <7>[ 4.032455] 7:usb usb3: New USB device found, idVendor=1d6b, idProduct=0002 <7>[ 4.032512] 7:usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1 <7>[ 4.032570] 7:usb usb3: Product: xHCI Host Controller <7>[ 4.032612] 7:usb usb3: Manufacturer: Linux (none) xhci_hcd <7>[ 4.032658] 7:usb usb3: SerialNumber: 0000:00:04.2 <7>[ 4.032948] 7:usb usb3: usb_probe_device <7>[ 4.032986] 7:usb usb3: configuration #1 chosen from 1 choice <7>[ 4.033116] 7:usb usb3: adding 3-0:1.0 (config #1, interface 0) <7>[ 4.033353] 7:hub 3-0:1.0: usb_probe_interface <7>[ 4.033393] 7:hub 3-0:1.0: usb_probe_interface - got id <6>[ 4.033436] 7:hub 3-0:1.0: USB hub found <6>[ 4.033540] 7:hub 3-0:1.0: 1 port detected <7>[ 4.033578] 7:hub 3-0:1.0: standalone hub <7>[ 4.033613] 7:hub 3-0:1.0: no power switching (usb 1.0) <7>[ 4.033656] 7:hub 3-0:1.0: individual port over-current protection <7>[ 4.033704] 7:hub 3-0:1.0: Single TT <7>[ 4.033737] 7:hub 3-0:1.0: TT requires at most 8 FS bit times (666 ns) <7>[ 4.033788] 7:hub 3-0:1.0: power on to power good time: 20ms <7>[ 4.033906] 7:hub 3-0:1.0: local power source is good <7>[ 4.034009] 7:hub 3-0:1.0: trying to enable port power on non-switchable hub <7>[ 4.034076] 7:xhci_hcd 0000:00:04.2: set port power, actual port 0 status = 0x2a0 <6>[ 4.034606] 7:xhci_hcd 0000:00:04.2: xHCI Host Controller <6>[ 4.034683] 7:xhci_hcd 0000:00:04.2: new USB bus registered, assigned bus number 4 <7>[ 4.034754] 7:xhci_hcd 0000:00:04.2: // Turn on HC, cmd = 0x5. <7>[ 4.034802] 7:xhci_hcd 0000:00:04.2: Finished xhci_run for USB3 roothub <7>[ 4.035072] 7:usb usb4: skipped 1 descriptor after endpoint <7>[ 4.035184] 7:usb usb4: default language 0x0409 <7>[ 4.035362] 7:usb usb4: udev 1, busnum 4, minor = 384 <7>[ 4.035407] 7:usb usb4: New USB device found, idVendor=1d6b, idProduct=0003 <7>[ 4.035463] 7:usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1 <7>[ 4.035522] 7:usb usb4: Product: xHCI Host Controller <7>[ 4.035563] 7:usb usb4: Manufacturer: Linux (none) xhci_hcd <7>[ 4.035608] 7:usb usb4: SerialNumber: 0000:00:04.2 <7>[ 4.035909] 7:usb usb4: usb_probe_device <7>[ 4.035945] 7:usb usb4: configuration #1 chosen from 1 choice <7>[ 4.036064] 7:usb usb4: adding 4-0:1.0 (config #1, interface 0) <7>[ 4.036297] 7:hub 4-0:1.0: usb_probe_interface <7>[ 4.036336] 7:hub 4-0:1.0: usb_probe_interface - got id <6>[ 4.036380] 7:hub 4-0:1.0: USB hub found <6>[ 4.036470] 7:hub 4-0:1.0: 1 port detected <7>[ 4.036507] 7:hub 4-0:1.0: standalone hub <7>[ 4.036542] 7:hub 4-0:1.0: no power switching (usb 1.0) <7>[ 4.036584] 7:hub 4-0:1.0: individual port over-current protection <7>[ 4.036634] 7:hub 4-0:1.0: TT requires at most 8 FS bit times (666 ns) <7>[ 4.036686] 7:hub 4-0:1.0: power on to power good time: 20ms <7>[ 4.036839] 7:hub 4-0:1.0: local power source is good <7>[ 4.036915] 7:hub 4-0:1.0: trying to enable port power on non-switchable hub <7>[ 4.036980] 7:xhci_hcd 0000:00:04.2: set port power, actual port 0 status = 0x80 <7>[ 4.037422] 7:PCI: Setting latency timer of device 0000:00:04.3 to 64 <6>[ 4.037479] 7:xhci_hcd 0000:00:04.3: xHCI Host Controller <6>[ 4.037560] 7:xhci_hcd 0000:00:04.3: new USB bus registered, assigned bus number 5 <7>[ 4.037651] 7:xhci_hcd 0000:00:04.3: xHCI capability registers at b0300000: <7>[ 4.037705] 7:xhci_hcd 0000:00:04.3: CAPLENGTH AND HCIVERSION 0x1000020: <7>[ 4.037758] 7:xhci_hcd 0000:00:04.3: CAPLENGTH: 0x20 <7>[ 4.037799] 7:xhci_hcd 0000:00:04.3: HCIVERSION: 0x100 <7>[ 4.037842] 7:xhci_hcd 0000:00:04.3: HCSPARAMS 1: 0x2000840 <7>[ 4.037887] 7:xhci_hcd 0000:00:04.3: Max device slots: 64 <7>[ 4.037932] 7:xhci_hcd 0000:00:04.3: Max interrupters: 8 <7>[ 4.037978] 7:xhci_hcd 0000:00:04.3: Max ports: 2 <7>[ 4.038019] 7:xhci_hcd 0000:00:04.3: HCSPARAMS 2: 0xc0000f1 <7>[ 4.038064] 7:xhci_hcd 0000:00:04.3: Isoc scheduling threshold: 1 <7>[ 4.038114] 7:xhci_hcd 0000:00:04.3: Maximum allowed segments in event ring: 15 <7>[ 4.038181] 7:xhci_hcd 0000:00:04.3: HCSPARAMS 3 0x7ff000a: <7>[ 4.038227] 7:xhci_hcd 0000:00:04.3: Worst case U1 device exit latency: 10 <7>[ 4.038281] 7:xhci_hcd 0000:00:04.3: Worst case U2 device exit latency: 2047 <7>[ 4.038337] 7:xhci_hcd 0000:00:04.3: HCC PARAMS 0x258f065: <7>[ 4.038381] 7:xhci_hcd 0000:00:04.3: HC generates 64 bit addresses <7>[ 4.038431] 7:xhci_hcd 0000:00:04.3: FIXME: more HCCPARAMS debugging <7>[ 4.038483] 7:xhci_hcd 0000:00:04.3: RTSOFF 0x440: <7>[ 4.038524] 7:xhci_hcd 0000:00:04.3: xHCI operational registers at b0300020: <7>[ 4.038579] 7:xhci_hcd 0000:00:04.3: USBCMD 0x0: <7>[ 4.038619] 7:xhci_hcd 0000:00:04.3: HC is being stopped <7>[ 4.038664] 7:xhci_hcd 0000:00:04.3: HC has finished hard reset <7>[ 4.038712] 7:xhci_hcd 0000:00:04.3: Event Interrupts disabled <7>[ 4.038760] 7:xhci_hcd 0000:00:04.3: Host System Error Interrupts disabled <7>[ 4.038814] 7:xhci_hcd 0000:00:04.3: HC has finished light reset <7>[ 4.038863] 7:xhci_hcd 0000:00:04.3: USBSTS 0x1: <7>[ 4.038901] 7:xhci_hcd 0000:00:04.3: Event ring is empty <7>[ 4.038946] 7:xhci_hcd 0000:00:04.3: No Host System Error <7>[ 4.038991] 7:xhci_hcd 0000:00:04.3: HC is halted <7>[ 4.039035] 7:xhci_hcd 0000:00:04.3: b0300420 port status reg = 0x2a0 <7>[ 4.039088] 7:xhci_hcd 0000:00:04.3: b0300424 port power reg = 0x0 <7>[ 4.039138] 7:xhci_hcd 0000:00:04.3: b0300428 port link reg = 0x0 <7>[ 4.039196] 7:xhci_hcd 0000:00:04.3: b030042c port reserved reg = 0x0 <7>[ 4.039247] 7:xhci_hcd 0000:00:04.3: b0300430 port status reg = 0x80 <7>[ 4.039298] 7:xhci_hcd 0000:00:04.3: b0300434 port power reg = 0x0 <7>[ 4.039348] 7:xhci_hcd 0000:00:04.3: b0300438 port link reg = 0x0 <7>[ 4.039398] 7:xhci_hcd 0000:00:04.3: b030043c port reserved reg = 0x0 <7>[ 4.039450] 7:xhci_hcd 0000:00:04.3: // Halt the HC <7>[ 4.039492] 7:xhci_hcd 0000:00:04.3: Resetting HCD <7>[ 4.039532] 7:xhci_hcd 0000:00:04.3: // Reset the HC <7>[ 4.039612] 7:xhci_hcd 0000:00:04.3: Wait for controller to be ready for doorbell rings <7>[ 4.039673] 7:xhci_hcd 0000:00:04.3: Reset complete <7>[ 4.039713] 7:xhci_hcd 0000:00:04.3: Enabling 64-bit DMA addresses. <7>[ 4.039763] 7:xhci_hcd 0000:00:04.3: Calling HCD init <7>[ 4.039804] 7:xhci_hcd 0000:00:04.3: xhci_init <7>[ 4.039842] 7:xhci_hcd 0000:00:04.3: xHCI doesn"t need link TRB QUIRK <7>[ 4.039893] 7:xhci_hcd 0000:00:04.3: Supported page size register = 0x1 <7>[ 4.039945] 7:xhci_hcd 0000:00:04.3: Supported page size of 4K <7>[ 4.039992] 7:xhci_hcd 0000:00:04.3: HCD page size set to 4K <7>[ 4.040040] 7:xhci_hcd 0000:00:04.3: // xHC can handle at most 64 device slots. <7>[ 4.040100] 7:xhci_hcd 0000:00:04.3: // Setting Max device slots reg = 0x40. <7>[ 4.040168] 7:xhci_hcd 0000:00:04.3: // Device context base array address = 0x332c3000 (DMA), d32c3000 (virt) <7>[ 4.040279] 7:xhci_hcd 0000:00:04.3: Allocated command ring at d32b90c0 <7>[ 4.040332] 7:xhci_hcd 0000:00:04.3: First segment DMA is 0x332c5000 <7>[ 4.040383] 7:xhci_hcd 0000:00:04.3: // Setting command ring address to 0x40 <7>[ 4.040440] 7:xhci_hcd 0000:00:04.3: // xHC command ring deq ptr low bits + flags = @00000000 <7>[ 4.040505] 7:xhci_hcd 0000:00:04.3: // xHC command ring deq ptr high bits = @00000000 <7>[ 4.040579] 7:xhci_hcd 0000:00:04.3: // Doorbell array is located at offset 0x560 from cap regs base addr <7>[ 4.040650] 7:xhci_hcd 0000:00:04.3: // xHCI capability registers at b0300000: <7>[ 4.040707] 7:xhci_hcd 0000:00:04.3: // @b0300000 = 0x1000020 (CAPLENGTH AND HCIVERSION) <7>[ 4.040768] 7:xhci_hcd 0000:00:04.3: // CAPLENGTH: 0x20 <7>[ 4.040813] 7:xhci_hcd 0000:00:04.3: // xHCI operational registers at b0300020: <7>[ 4.040869] 7:xhci_hcd 0000:00:04.3: // @b0300018 = 0x440 RTSOFF <7>[ 4.040917] 7:xhci_hcd 0000:00:04.3: // xHCI runtime registers at b0300440: <7>[ 4.040973] 7:xhci_hcd 0000:00:04.3: // @b0300014 = 0x560 DBOFF <7>[ 4.041021] 7:xhci_hcd 0000:00:04.3: // Doorbell array at b0300560: <7>[ 4.041071] 7:xhci_hcd 0000:00:04.3: xHCI runtime registers at b0300440: <7>[ 4.041125] 7:xhci_hcd 0000:00:04.3: b0300440: Microframe index = 0x0 <7>[ 4.041187] 7:xhci_hcd 0000:00:04.3: // Allocating event ring <7>[ 4.041243] 7:xhci_hcd 0000:00:04.3: TRB math tests passed. <7>[ 4.041291] 7:xhci_hcd 0000:00:04.3: // Allocated event ring segment table at 0x332c7000 <7>[ 4.041354] 7:xhci_hcd 0000:00:04.3: Set ERST to 0; private num segs = 1, virt addr = d32c7000, dma addr = 0x332c7000 <7>[ 4.041434] 7:xhci_hcd 0000:00:04.3: // Write ERST size = 1 to ir_set 0 (some bits preserved) <7>[ 4.041499] 7:xhci_hcd 0000:00:04.3: // Set ERST entries to point to event ring. <7>[ 4.041557] 7:xhci_hcd 0000:00:04.3: // Set ERST base address for ir_set 0 = 0x332c7000 <7>[ 4.041619] 7:xhci_hcd 0000:00:04.3: // Write event ring dequeue pointer, preserving EHB bit <7>[ 4.041684] 7:xhci_hcd 0000:00:04.3: Wrote ERST address to ir_set 0. <7>[ 4.041736] 7:xhci_hcd 0000:00:04.3: Allocating 1 scratchpad buffers <7>[ 4.041822] 7:xhci_hcd 0000:00:04.3: Ext Cap b0300970, port offset = 1, count = 1, revision = 0x2 <7>[ 4.041888] 7:xhci_hcd 0000:00:04.3: xHCI 1.0: support USB2 software lpm <7>[ 4.041940] 7:xhci_hcd 0000:00:04.3: xHCI 1.0: support USB2 hardware lpm <7>[ 4.041996] 7:xhci_hcd 0000:00:04.3: Ext Cap b0300980, port offset = 2, count = 1, revision = 0x3 <7>[ 4.042065] 7:xhci_hcd 0000:00:04.3: Found 1 USB 2.0 ports and 1 USB 3.0 ports. <7>[ 4.042125] 7:xhci_hcd 0000:00:04.3: USB 2.0 port at index 0, addr = b0300420 <7>[ 4.042191] 7:xhci_hcd 0000:00:04.3: USB 3.0 port at index 1, addr = b0300430 <7>[ 4.042247] 7:xhci_hcd 0000:00:04.3: Finished xhci_init <7>[ 4.042291] 7:xhci_hcd 0000:00:04.3: Called HCD init <7>[ 4.042333] 7:xhci_hcd 0000:00:04.3: Got SBRN 0 <7>[ 4.042373] 7:PCI: cache line size of 64 is not supported by device 0000:00:04.3 <7>[ 4.042430] 7:xhci_hcd 0000:00:04.3: Finished xhci_pci_reinit <7>[ 4.042478] 7:xhci_hcd 0000:00:04.3: xhci_run <7>[ 4.042518] 7:xhci_hcd 0000:00:04.3: Failed to enable MSI-X <7>[ 4.042567] 7:xhci_hcd 0000:00:04.3: failed to allocate MSI entry <7>[ 4.042626] 7:xhci_hcd 0000:00:04.3: Command ring memory map follows: <7>[ 4.042680] 7:xhci_hcd 0000:00:04.3: @00000000332c5000 00000000 00000000 00000000 00000000 <7>[ 4.042746] 7:xhci_hcd 0000:00:04.3: @00000000332c5010 00000000 00000000 00000000 00000000 <7>[ 4.042810] 7:xhci_hcd 0000:00:04.3: @00000000332c5020 00000000 00000000 00000000 00000000 <7>[ 4.042874] 7:xhci_hcd 0000:00:04.3: @00000000332c5030 00000000 00000000 00000000 00000000 <7>[ 4.042939] 7:xhci_hcd 0000:00:04.3: @00000000332c5040 00000000 00000000 00000000 00000000 <7>[ 4.043003] 7:xhci_hcd 0000:00:04.3: @00000000332c5050 00000000 00000000 00000000 00000000 <7>[ 4.043069] 7:xhci_hcd 0000:00:04.3: @00000000332c5060 00000000 00000000 00000000 00000000 <7>[ 4.043134] 7:xhci_hcd 0000:00:04.3: @00000000332c5070 00000000 00000000 00000000 00000000 <7>[ 4.043206] 7:xhci_hcd 0000:00:04.3: @00000000332c5080 00000000 00000000 00000000 00000000 <7>[ 4.043271] 7:xhci_hcd 0000:00:04.3: @00000000332c5090 00000000 00000000 00000000 00000000 <7>[ 4.043336] 7:xhci_hcd 0000:00:04.3: @00000000332c50a0 00000000 00000000 00000000 00000000 <7>[ 4.043400] 7:xhci_hcd 0000:00:04.3: @00000000332c50b0 00000000 00000000 00000000 00000000 <7>[ 4.043465] 7:xhci_hcd 0000:00:04.3: @00000000332c50c0 00000000 00000000 00000000 00000000 <7>[ 4.043530] 7:xhci_hcd 0000:00:04.3: @00000000332c50d0 00000000 00000000 00000000 00000000 <7>[ 4.043595] 7:xhci_hcd 0000:00:04.3: @00000000332c50e0 00000000 00000000 00000000 00000000 <7>[ 4.043660] 7:xhci_hcd 0000:00:04.3: @00000000332c50f0 00000000 00000000 00000000 00000000 <7>[ 4.043725] 7:xhci_hcd 0000:00:04.3: @00000000332c5100 00000000 00000000 00000000 00000000 <7>[ 4.043789] 7:xhci_hcd 0000:00:04.3: @00000000332c5110 00000000 00000000 00000000 00000000 <7>[ 4.043853] 7:xhci_hcd 0000:00:04.3: @00000000332c5120 00000000 00000000 00000000 00000000 <7>[ 4.043917] 7:xhci_hcd 0000:00:04.3: @00000000332c5130 00000000 00000000 00000000 00000000 <7>[ 4.043982] 7:xhci_hcd 0000:00:04.3: @00000000332c5140 00000000 00000000 00000000 00000000 <7>[ 4.044049] 7:xhci_hcd 0000:00:04.3: @00000000332c5150 00000000 00000000 00000000 00000000 <7>[ 4.044114] 7:xhci_hcd 0000:00:04.3: @00000000332c5160 00000000 00000000 00000000 00000000 <7>[ 4.044186] 7:xhci_hcd 0000:00:04.3: @00000000332c5170 00000000 00000000 00000000 00000000 <7>[ 4.044250] 7:xhci_hcd 0000:00:04.3: @00000000332c5180 00000000 00000000 00000000 00000000 <7>[ 4.044315] 7:xhci_hcd 0000:00:04.3: @00000000332c5190 00000000 00000000 00000000 00000000 <7>[ 4.044380] 7:xhci_hcd 0000:00:04.3: @00000000332c51a0 00000000 00000000 00000000 00000000 <7>[ 4.044444] 7:xhci_hcd 0000:00:04.3: @00000000332c51b0 00000000 00000000 00000000 00000000 <7>[ 4.044509] 7:xhci_hcd 0000:00:04.3: @00000000332c51c0 00000000 00000000 00000000 00000000 <7>[ 4.044573] 7:xhci_hcd 0000:00:04.3: @00000000332c51d0 00000000 00000000 00000000 00000000 <7>[ 4.044638] 7:xhci_hcd 0000:00:04.3: @00000000332c51e0 00000000 00000000 00000000 00000000 <7>[ 4.044702] 7:xhci_hcd 0000:00:04.3: @00000000332c51f0 00000000 00000000 00000000 00000000 <7>[ 4.044767] 7:xhci_hcd 0000:00:04.3: @00000000332c5200 00000000 00000000 00000000 00000000 <7>[ 4.044830] 7:xhci_hcd 0000:00:04.3: @00000000332c5210 00000000 00000000 00000000 00000000 <7>[ 4.044894] 7:xhci_hcd 0000:00:04.3: @00000000332c5220 00000000 00000000 00000000 00000000 <7>[ 4.044958] 7:xhci_hcd 0000:00:04.3: @00000000332c5230 00000000 00000000 00000000 00000000 <7>[ 4.045022] 7:xhci_hcd 0000:00:04.3: @00000000332c5240 00000000 00000000 00000000 00000000 <7>[ 4.045087] 7:xhci_hcd 0000:00:04.3: @00000000332c5250 00000000 00000000 00000000 00000000 <7>[ 4.045152] 7:xhci_hcd 0000:00:04.3: @00000000332c5260 00000000 00000000 00000000 00000000 <7>[ 4.045224] 7:xhci_hcd 0000:00:04.3: @00000000332c5270 00000000 00000000 00000000 00000000 <7>[ 4.045289] 7:xhci_hcd 0000:00:04.3: @00000000332c5280 00000000 00000000 00000000 00000000 <7>[ 4.045353] 7:xhci_hcd 0000:00:04.3: @00000000332c5290 00000000 00000000 00000000 00000000 <7>[ 4.045418] 7:xhci_hcd 0000:00:04.3: @00000000332c52a0 00000000 00000000 00000000 00000000 <7>[ 4.045483] 7:xhci_hcd 0000:00:04.3: @00000000332c52b0 00000000 00000000 00000000 00000000 <7>[ 4.045548] 7:xhci_hcd 0000:00:04.3: @00000000332c52c0 00000000 00000000 00000000 00000000 <7>[ 4.045612] 7:xhci_hcd 0000:00:04.3: @00000000332c52d0 00000000 00000000 00000000 00000000 <7>[ 4.045677] 7:xhci_hcd 0000:00:04.3: @00000000332c52e0 00000000 00000000 00000000 00000000 <7>[ 4.045742] 7:xhci_hcd 0000:00:04.3: @00000000332c52f0 00000000 00000000 00000000 00000000 <7>[ 4.045806] 7:xhci_hcd 0000:00:04.3: @00000000332c5300 00000000 00000000 00000000 00000000 <7>[ 4.045870] 7:xhci_hcd 0000:00:04.3: @00000000332c5310 00000000 00000000 00000000 00000000 <7>[ 4.045934] 7:xhci_hcd 0000:00:04.3: @00000000332c5320 00000000 00000000 00000000 00000000 <7>[ 4.045998] 7:xhci_hcd 0000:00:04.3: @00000000332c5330 00000000 00000000 00000000 00000000 <7>[ 4.046063] 7:xhci_hcd 0000:00:04.3: @00000000332c5340 00000000 00000000 00000000 00000000 <7>[ 4.046128] 7:xhci_hcd 0000:00:04.3: @00000000332c5350 00000000 00000000 00000000 00000000 <7>[ 4.046200] 7:xhci_hcd 0000:00:04.3: @00000000332c5360 00000000 00000000 00000000 00000000 <7>[ 4.046265] 7:xhci_hcd 0000:00:04.3: @00000000332c5370 00000000 00000000 00000000 00000000 <7>[ 4.046330] 7:xhci_hcd 0000:00:04.3: @00000000332c5380 00000000 00000000 00000000 00000000 <7>[ 4.046394] 7:xhci_hcd 0000:00:04.3: @00000000332c5390 00000000 00000000 00000000 00000000 <7>[ 4.046459] 7:xhci_hcd 0000:00:04.3: @00000000332c53a0 00000000 00000000 00000000 00000000 <7>[ 4.046524] 7:xhci_hcd 0000:00:04.3: @00000000332c53b0 00000000 00000000 00000000 00000000 <7>[ 4.046588] 7:xhci_hcd 0000:00:04.3: @00000000332c53c0 00000000 00000000 00000000 00000000 <7>[ 4.046653] 7:xhci_hcd 0000:00:04.3: @00000000332c53d0 00000000 00000000 00000000 00000000 <7>[ 4.046718] 7:xhci_hcd 0000:00:04.3: @00000000332c53e0 00000000 00000000 00000000 00000000 <7>[ 4.046783] 7:xhci_hcd 0000:00:04.3: @00000000332c53f0 332c5000 00000000 00000000 00001802 <7>[ 4.046846] 7:xhci_hcd 0000:00:04.3: Ring has not been updated <7>[ 4.046894] 7:xhci_hcd 0000:00:04.3: Ring deq = d32c5000 (virt), 0x332c5000 (dma) <7>[ 4.046952] 7:xhci_hcd 0000:00:04.3: Ring deq updated 0 times <7>[ 4.046999] 7:xhci_hcd 0000:00:04.3: Ring enq = d32c5000 (virt), 0x332c5000 (dma) <7>[ 4.047058] 7:xhci_hcd 0000:00:04.3: Ring enq updated 0 times <7>[ 4.047106] 7:xhci_hcd 0000:00:04.3: // xHC command ring deq ptr low bits + flags = @00000000 <7>[ 4.047178] 7:xhci_hcd 0000:00:04.3: // xHC command ring deq ptr high bits = @00000000 <7>[ 4.047239] 7:xhci_hcd 0000:00:04.3: ERST memory map follows: <7>[ 4.047287] 7:xhci_hcd 0000:00:04.3: @00000000332c7000 332c5400 00000000 00000040 00000000 <7>[ 4.047350] 7:xhci_hcd 0000:00:04.3: Event ring: <7>[ 4.047391] 7:xhci_hcd 0000:00:04.3: @00000000332c5400 00000000 00000000 00000000 00000000 <7>[ 4.047456] 7:xhci_hcd 0000:00:04.3: @00000000332c5410 00000000 00000000 00000000 00000000 <7>[ 4.047520] 7:xhci_hcd 0000:00:04.3: @00000000332c5420 00000000 00000000 00000000 00000000 <7>[ 4.047585] 7:xhci_hcd 0000:00:04.3: @00000000332c5430 00000000 00000000 00000000 00000000 <7>[ 4.047650] 7:xhci_hcd 0000:00:04.3: @00000000332c5440 00000000 00000000 00000000 00000000 <7>[ 4.047715] 7:xhci_hcd 0000:00:04.3: @00000000332c5450 00000000 00000000 00000000 00000000 <7>[ 4.047779] 7:xhci_hcd 0000:00:04.3: @00000000332c5460 00000000 00000000 00000000 00000000 <7>[ 4.047843] 7:xhci_hcd 0000:00:04.3: @00000000332c5470 00000000 00000000 00000000 00000000 <7>[ 4.047907] 7:xhci_hcd 0000:00:04.3: @00000000332c5480 00000000 00000000 00000000 00000000 <7>[ 4.047974] 7:xhci_hcd 0000:00:04.3: @00000000332c5490 00000000 00000000 00000000 00000000 <7>[ 4.048041] 7:xhci_hcd 0000:00:04.3: @00000000332c54a0 00000000 00000000 00000000 00000000 <7>[ 4.048107] 7:xhci_hcd 0000:00:04.3: @00000000332c54b0 00000000 00000000 00000000 00000000 <7>[ 4.048179] 7:xhci_hcd 0000:00:04.3: @00000000332c54c0 00000000 00000000 00000000 00000000 <7>[ 4.048244] 7:xhci_hcd 0000:00:04.3: @00000000332c54d0 00000000 00000000 00000000 00000000 <7>[ 4.048309] 7:xhci_hcd 0000:00:04.3: @00000000332c54e0 00000000 00000000 00000000 00000000 <7>[ 4.048373] 7:xhci_hcd 0000:00:04.3: @00000000332c54f0 00000000 00000000 00000000 00000000 <7>[ 4.048438] 7:xhci_hcd 0000:00:04.3: @00000000332c5500 00000000 00000000 00000000 00000000 <7>[ 4.048503] 7:xhci_hcd 0000:00:04.3: @00000000332c5510 00000000 00000000 00000000 00000000 <7>[ 4.048567] 7:xhci_hcd 0000:00:04.3: @00000000332c5520 00000000 00000000 00000000 00000000 <7>[ 4.048631] 7:xhci_hcd 0000:00:04.3: @00000000332c5530 00000000 00000000 00000000 00000000 <7>[ 4.048696] 7:xhci_hcd 0000:00:04.3: @00000000332c5540 00000000 00000000 00000000 00000000 <7>[ 4.048761] 7:xhci_hcd 0000:00:04.3: @00000000332c5550 00000000 00000000 00000000 00000000 <7>[ 4.048825] 7:xhci_hcd 0000:00:04.3: @00000000332c5560 00000000 00000000 00000000 00000000 <7>[ 4.048889] 7:xhci_hcd 0000:00:04.3: @00000000332c5570 00000000 00000000 00000000 00000000 <7>[ 4.048953] 7:xhci_hcd 0000:00:04.3: @00000000332c5580 00000000 00000000 00000000 00000000 <7>[ 4.049018] 7:xhci_hcd 0000:00:04.3: @00000000332c5590 00000000 00000000 00000000 00000000 <7>[ 4.049083] 7:xhci_hcd 0000:00:04.3: @00000000332c55a0 00000000 00000000 00000000 00000000 <7>[ 4.049148] 7:xhci_hcd 0000:00:04.3: @00000000332c55b0 00000000 00000000 00000000 00000000 <7>[ 4.049220] 7:xhci_hcd 0000:00:04.3: @00000000332c55c0 00000000 00000000 00000000 00000000 <7>[ 4.049284] 7:xhci_hcd 0000:00:04.3: @00000000332c55d0 00000000 00000000 00000000 00000000 <7>[ 4.049349] 7:xhci_hcd 0000:00:04.3: @00000000332c55e0 00000000 00000000 00000000 00000000 <7>[ 4.049414] 7:xhci_hcd 0000:00:04.3: @00000000332c55f0 00000000 00000000 00000000 00000000 <7>[ 4.049479] 7:xhci_hcd 0000:00:04.3: @00000000332c5600 00000000 00000000 00000000 00000000 <7>[ 4.049543] 7:xhci_hcd 0000:00:04.3: @00000000332c5610 00000000 00000000 00000000 00000000 <7>[ 4.049608] 7:xhci_hcd 0000:00:04.3: @00000000332c5620 00000000 00000000 00000000 00000000 <7>[ 4.049673] 7:xhci_hcd 0000:00:04.3: @00000000332c5630 00000000 00000000 00000000 00000000 <7>[ 4.049738] 7:xhci_hcd 0000:00:04.3: @00000000332c5640 00000000 00000000 00000000 00000000 <7>[ 4.049801] 7:xhci_hcd 0000:00:04.3: @00000000332c5650 00000000 00000000 00000000 00000000 <7>[ 4.049865] 7:xhci_hcd 0000:00:04.3: @00000000332c5660 00000000 00000000 00000000 00000000 <7>[ 4.049929] 7:xhci_hcd 0000:00:04.3: @00000000332c5670 00000000 00000000 00000000 00000000 <7>[ 4.049994] 7:xhci_hcd 0000:00:04.3: @00000000332c5680 00000000 00000000 00000000 00000000 <7>[ 4.050060] 7:xhci_hcd 0000:00:04.3: @00000000332c5690 00000000 00000000 00000000 00000000 <7>[ 4.050125] 7:xhci_hcd 0000:00:04.3: @00000000332c56a0 00000000 00000000 00000000 00000000 <7>[ 4.050197] 7:xhci_hcd 0000:00:04.3: @00000000332c56b0 00000000 00000000 00000000 00000000 <7>[ 4.050262] 7:xhci_hcd 0000:00:04.3: @00000000332c56c0 00000000 00000000 00000000 00000000 <7>[ 4.050326] 7:xhci_hcd 0000:00:04.3: @00000000332c56d0 00000000 00000000 00000000 00000000 <7>[ 4.050390] 7:xhci_hcd 0000:00:04.3: @00000000332c56e0 00000000 00000000 00000000 00000000 <7>[ 4.050455] 7:xhci_hcd 0000:00:04.3: @00000000332c56f0 00000000 00000000 00000000 00000000 <7>[ 4.050520] 7:xhci_hcd 0000:00:04.3: @00000000332c5700 00000000 00000000 00000000 00000000 <7>[ 4.050585] 7:xhci_hcd 0000:00:04.3: @00000000332c5710 00000000 00000000 00000000 00000000 <7>[ 4.050650] 7:xhci_hcd 0000:00:04.3: @00000000332c5720 00000000 00000000 00000000 00000000 <7>[ 4.050714] 7:xhci_hcd 0000:00:04.3: @00000000332c5730 00000000 00000000 00000000 00000000 <7>[ 4.050778] 7:xhci_hcd 0000:00:04.3: @00000000332c5740 00000000 00000000 00000000 00000000 <7>[ 4.050842] 7:xhci_hcd 0000:00:04.3: @00000000332c5750 00000000 00000000 00000000 00000000 <7>[ 4.050906] 7:xhci_hcd 0000:00:04.3: @00000000332c5760 00000000 00000000 00000000 00000000 <7>[ 4.050971] 7:xhci_hcd 0000:00:04.3: @00000000332c5770 00000000 00000000 00000000 00000000 <7>[ 4.051038] 7:xhci_hcd 0000:00:04.3: @00000000332c5780 00000000 00000000 00000000 00000000 <7>[ 4.051105] 7:xhci_hcd 0000:00:04.3: @00000000332c5790 00000000 00000000 00000000 00000000 <7>[ 4.051177] 7:xhci_hcd 0000:00:04.3: @00000000332c57a0 00000000 00000000 00000000 00000000 <7>[ 4.051242] 7:xhci_hcd 0000:00:04.3: @00000000332c57b0 00000000 00000000 00000000 00000000 <7>[ 4.051307] 7:xhci_hcd 0000:00:04.3: @00000000332c57c0 00000000 00000000 00000000 00000000 <7>[ 4.051372] 7:xhci_hcd 0000:00:04.3: @00000000332c57d0 00000000 00000000 00000000 00000000 <7>[ 4.051437] 7:xhci_hcd 0000:00:04.3: @00000000332c57e0 00000000 00000000 00000000 00000000 <7>[ 4.051502] 7:xhci_hcd 0000:00:04.3: @00000000332c57f0 00000000 00000000 00000000 00000000 <7>[ 4.051565] 7:xhci_hcd 0000:00:04.3: Ring has not been updated <7>[ 4.051614] 7:xhci_hcd 0000:00:04.3: Ring deq = d32c5400 (virt), 0x332c5400 (dma) <7>[ 4.051672] 7:xhci_hcd 0000:00:04.3: Ring deq updated 0 times <7>[ 4.051719] 7:xhci_hcd 0000:00:04.3: Ring enq = d32c5400 (virt), 0x332c5400 (dma) <7>[ 4.051776] 7:xhci_hcd 0000:00:04.3: Ring enq updated 0 times <7>[ 4.051824] 7:xhci_hcd 0000:00:04.3: ERST deq = 64"h332c5400 <7>[ 4.051870] 7:xhci_hcd 0000:00:04.3: // Set the interrupt modulation register <7>[ 4.051926] 7:xhci_hcd 0000:00:04.3: // Enable interrupts, cmd = 0x4. <7>[ 4.051980] 7:xhci_hcd 0000:00:04.3: // Enabling event ring interrupter b0300460 by writing 0x2 to irq_pending <7>[ 4.052057] 7:xhci_hcd 0000:00:04.3: b0300460: ir_set[0] <7>[ 4.052104] 7:xhci_hcd 0000:00:04.3: b0300460: ir_set.pending = 0x2 <7>[ 4.052163] 7:xhci_hcd 0000:00:04.3: b0300464: ir_set.cOntrol= 0xa0 <7>[ 4.052215] 7:xhci_hcd 0000:00:04.3: b0300468: ir_set.erst_size = 0x1 <7>[ 4.052269] 7:xhci_hcd 0000:00:04.3: b0300470: ir_set.erst_base = @332c7000 <7>[ 4.052326] 7:xhci_hcd 0000:00:04.3: b0300478: ir_set.erst_dequeue = @332c5400 <7>[ 4.052384] 7:xhci_hcd 0000:00:04.3: Finished xhci_run for USB2 roothub <7>[ 4.052643] 7:usb usb5: default language 0x0409 <7>[ 4.052848] 7:usb usb5: udev 1, busnum 5, minor = 512 <7>[ 4.052894] 7:usb usb5: New USB device found, idVendor=1d6b, idProduct=0002 <7>[ 4.052951] 7:usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1 <7>[ 4.053009] 7:usb usb5: Product: xHCI Host Controller <7>[ 4.053053] 7:usb usb5: Manufacturer: Linux (none) xhci_hcd <7>[ 4.053100] 7:usb usb5: SerialNumber: 0000:00:04.3 <7>[ 4.053414] 7:usb usb5: usb_probe_device <7>[ 4.053452] 7:usb usb5: configuration #1 chosen from 1 choice <7>[ 4.053581] 7:usb usb5: adding 5-0:1.0 (config #1, interface 0) <7>[ 4.053794] 7:hub 5-0:1.0: usb_probe_interface <7>[ 4.053833] 7:hub 5-0:1.0: usb_probe_interface - got id <6>[ 4.053876] 7:hub 5-0:1.0: USB hub found <6>[ 4.053969] 7:hub 5-0:1.0: 1 port detected <7>[ 4.054009] 7:hub 5-0:1.0: standalone hub <7>[ 4.054046] 7:hub 5-0:1.0: no power switching (usb 1.0) <7>[ 4.054089] 7:hub 5-0:1.0: individual port over-current protection <7>[ 4.054139] 7:hub 5-0:1.0: Single TT <7>[ 4.054180] 7:hub 5-0:1.0: TT requires at most 8 FS bit times (666 ns) <7>[ 4.054232] 7:hub 5-0:1.0: power on to power good time: 20ms <7>[ 4.054370] 7:hub 5-0:1.0: local power source is good <7>[ 4.054448] 7:hub 5-0:1.0: trying to enable port power on non-switchable hub <7>[ 4.054511] 7:xhci_hcd 0000:00:04.3: set port power, actual port 0 status = 0x2a0 <6>[ 4.055104] 7:xhci_hcd 0000:00:04.3: xHCI Host Controller <6>[ 4.055193] 7:xhci_hcd 0000:00:04.3: new USB bus registered, assigned bus number 6 <7>[ 4.055263] 7:xhci_hcd 0000:00:04.3: // Turn on HC, cmd = 0x5. <7>[ 4.055312] 7:xhci_hcd 0000:00:04.3: Finished xhci_run for USB3 roothub <7>[ 4.055588] 7:usb usb6: skipped 1 descriptor after endpoint <7>[ 4.055687] 7:usb usb6: default language 0x0409 <7>[ 4.055865] 7:usb usb6: udev 1, busnum 6, minor = 640 <7>[ 4.055910] 7:usb usb6: New USB device found, idVendor=1d6b, idProduct=0003 <7>[ 4.055965] 7:usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1 <7>[ 4.056023] 7:usb usb6: Product: xHCI Host Controller <7>[ 4.056066] 7:usb usb6: Manufacturer: Linux (none) xhci_hcd <7>[ 4.056113] 7:usb usb6: SerialNumber: 0000:00:04.3 <7>[ 4.056424] 7:usb usb6: usb_probe_device <7>[ 4.056462] 7:usb usb6: configuration #1 chosen from 1 choice <7>[ 4.056578] 7:usb usb6: adding 6-0:1.0 (config #1, interface 0) <7>[ 4.056790] 7:hub 6-0:1.0: usb_probe_interface <7>[ 4.056829] 7:hub 6-0:1.0: usb_probe_interface - got id <6>[ 4.056872] 7:hub 6-0:1.0: USB hub found <6>[ 4.056973] 7:hub 6-0:1.0: 1 port detected <7>[ 4.057013] 7:hub 6-0:1.0: standalone hub <7>[ 4.057048] 7:hub 6-0:1.0: no power switching (usb 1.0) <7>[ 4.057092] 7:hub 6-0:1.0: individual port over-current protection <7>[ 4.057142] 7:hub 6-0:1.0: TT requires at most 8 FS bit times (666 ns) <7>[ 4.057202] 7:hub 6-0:1.0: power on to power good time: 20ms <7>[ 4.057335] 7:hub 6-0:1.0: local power source is good <7>[ 4.057413] 7:hub 6-0:1.0: trying to enable port power on non-switchable hub <7>[ 4.057476] 7:xhci_hcd 0000:00:04.3: set port power, actual port 0 status = 0x80 <6>[ 4.058006] 7:Initializing USB Mass Storage driver... <6>[ 4.058209] 7:usbcore: registered new interface driver usb-storage <6>[ 4.058260] 7:USB Mass Storage support registered. <6>[ 4.058635] 7:usbcore: registered new interface driver usbserial <6>[ 4.058801] 7:usbserial: USB Serial support registered for generic <6>[ 4.058985] 7:usbcore: registered new interface driver usbserial_generic <6>[ 4.059036] 7:usbserial: USB Serial Driver core <7>[ 4.114207] 7:xhci_hcd 0000:00:04.1: get port status, actual port 0 status = 0x2a0 <7>[ 4.114272] 7:xhci_hcd 0000:00:04.1: Get port status returned 0x100 <7>[ 4.114400] 1:hub 1-0:1.0: state 7 ports 1 chg 0000 evt 0000 <7>[ 4.116188] 7:xhci_hcd 0000:00:04.1: get port status, actual port 0 status = 0x2a0 <7>[ 4.116250] 7:xhci_hcd 0000:00:04.1: Get port status returned 0x2a0 <7>[ 4.116352] 1:hub 2-0:1.0: state 7 ports 1 chg 0000 evt 0000 <7>[ 4.134187] 7:xhci_hcd 0000:00:04.2: get port status, actual port 0 status = 0x2a0 <7>[ 4.134248] 7:xhci_hcd 0000:00:04.2: Get port status returned 0x100 <7>[ 4.134348] 1:hub 3-0:1.0: state 7 ports 1 chg 0000 evt 0000 <7>[ 4.137187] 7:xhci_hcd 0000:00:04.2: get port status, actual port 0 status = 0x80 <7>[ 4.137247] 7:xhci_hcd 0000:00:04.2: Get port status returned 0x80 <7>[ 4.137345] 1:hub 4-0:1.0: state 7 ports 1 chg 0000 evt 0000 <7>[ 4.154201] 7:xhci_hcd 0000:00:04.3: get port status, actual port 0 status = 0x2a0 <7>[ 4.154262] 7:xhci_hcd 0000:00:04.3: Get port status returned 0x100 <7>[ 4.154363] 1:hub 5-0:1.0: state 7 ports 1 chg 0000 evt 0000 <7>[ 4.157204] 7:xhci_hcd 0000:00:04.3: get port status, actual port 0 status = 0x80 <7>[ 4.157264] 7:xhci_hcd 0000:00:04.3: Get port status returned 0x80 <7>[ 4.157363] 1:hub 6-0:1.0: state 7 ports 1 chg 0000 evt 0000 <6>[ 4.188922] 7:Freeing unused kernel memory: 192k freed <4>[ 4.189368] <4>[ 4.189380] Jumping to Userland... <4>[ 4.291418] ra[0]=sys_init_module+0x1a04/0x1da0 <4>[ 4.291481] ra[0]=sys_init_module+0x1a18/0x1da0 <0>[ 4.293768] 2:dware_init - pcCmdLine : phymemsize=1024M cOnsole=ttyS0,9600 mem=208M@0M mem=768M@512M BoardName=MSG360-40 WebMode=255 dataecctype=80208 tagbits=8 nandpgsz=1000 nandoobsz=e0 nandpgblk=40 nandblknum=1000 nandbbttype=10 nandid=0xa32c cpio=0x43e8f48@0x38000000 loader=1 cOnsole=ttyS0,9600 rdinit=/sbin/scmd loglevel=0 kdb=on-onlykey extMem=768M@512M slub_debug ccd_threshold=180 secondary_log_buf=0x100000@0xf000000 rd_start=0x82200000 rd_size=0x00375e5e dtb_start=0x82187000 dtb_end=0x821871bb . <0>[ 4.294088] 2:dware_init tag 1 <0>[ 4.294125] 2:dware_init - Get nandid from boot cmdline : 0xa32c. <4>[ 4.294755] <4>[ 4.294766] begin to init nand flash <5>[ 4.294802] 2:dware mmc: do 1 mmc/sd register. <5>[ 4.295616] 2:res 0,start=0x17, end=0x17, flag=1024 <5>[ 4.295658] 2:res 1,start=0x0, end=0x0, flag=1024 <5>[ 4.295696] 2:res 2,start=0x1803b000, end=0x1803b0ff, flag=512 <5>[ 4.295742] 2:res 3,start=0x1803b100, end=0x1803b1ff, flag=512 <5>[ 4.295789] 2:res 4,start=0x1803b200, end=0x1803b2ff, flag=512 <4>[ 4.295834] ******pstData->ulSlotnum 1<5>2:mmc device 0: pdata at d35ae1e0 len 28. <4>[ 4.295907] DWARE add device mmc_dev <4>[ 4.296104] dware mmc sys vaddr:b803b300 <4>[ 4.296187] dware mmc slot 0 host->base at b803b100 <6>[ 4.323280] 2:mmc0: SDHCI controller on platform [mmc_dev.0] using ADMA <6>[ 4.323436] 2:NAND device: 0x40000000, 0x40000 0x1000 0xe0 0x10001 <6>[ 4.323486] 2:NAND device: Manufacturer ID: 0x2c, Chip ID: 0xa3 <4>[ 4.323546] <4>[ 4.323556] mtd_nand_has_bch<7>2:Bad block table found at page 262080, version 0x02 <7>[ 4.384589] 2:check_pattern err <7>[ 4.443167] 2:Bad block table found at page 262016, version 0x02 <7>[ 4.444154] 2:nand_read_bbt: Bad block at 0x1c2c0000 <4>[ 4.444951] <4>[ 4.444962] begin to mount -t yaffs2 -o null /dev/mtdblock0 /mnt/flash: <7>[ 4.445383] 2:yaffs: dev is 32505856 name is "nand-xlp" <7>[ 4.445425] 2:yaffs: passed flags "ecc-8bit" <4>[ 4.445517] try to use 8bit ecc <4>[ 4.869466] <4>[ 4.869482] begin to init nor flash <0>[ 4.869701] 2:m25p80_init <4>[ 4.869897] spi_xlp_probe... <7>[ 4.870270] 2:spi-xlp spi-xlp.0: registered master spi1 <4>[ 4.870463] ###m25p_probe... <4>[ 4.870498] ###jedec_probe... <4>[ 4.870570] ###jedec_probe, jedec = 0xc22017. <6>[ 4.870619] 2:m25p80 spi1.0: mx25l6405d (8192 Kbytes) <4>[ 4.870661] mtd .name = spi1.0, .size = 0x00800000 (8MiB) .erasesize = 0x00010000 (64KiB) .numeraseregiOns= 0 <4>[ 4.871345] m25p_probe, get_mtd_device_nm: spi1.0, g_ulSpiFlashNo = 0. <7>[ 4.871406] 2:spi-xlp spi-xlp.0: registered child spi1.0 <4>[ 5.010038] 0:system: module license "unspecified" taints kernel. <4>[ 6.361870] ra[0]=sys_init_module+0x1a04/0x1da0 <4>[ 6.361933] ra[0]=sys_init_module+0x1a18/0x1da0 <3>[ 6.460382] 2:id=0x0,proc=0xf1b53090,funname=USR_RCU_Init <3>[ 6.460483] 2:id=0x0,proc=0xf1b55cd0,funname=USR_ISSU_Init <3>[ 6.463692] 2:id=0x1000,proc=0xf1d8f520,funname=EOM_Init <3>[ 6.463787] 2:id=0x1000,proc=0xf1c32370,funname=WCM_DRV_InitPreCmw <4>[ 7.052919] <4>[ 7.052930] NAE frequncy set to = 250Mhz VSEMI configuration is OK <4>[ 15.817471] DEV_XLP_NaeLaneResetTxpll: block 0 lane_ctrl 4 <4>[ 15.818109] DEV_XLP_NaeLaneResetTxpll value before power down =0x24100000 <4>[ 15.818740] DEV_XLP_NaeLaneResetTxpll value after power up =0x4100000 <4>[ 16.404198] Before register reset de-assertion PMA status value=0x841 <4>[ 16.405867] DEV_XLP_NaeLaneResetTxpll: block 0 lane_ctrl 5 <4>[ 16.406491] DEV_XLP_NaeLaneResetTxpll value before power down =0x24100000 <4>[ 16.407133] DEV_XLP_NaeLaneResetTxpll value after power up =0x4100000 <4>[ 16.991364] Before register reset de-assertion PMA status value=0x841 <4>[ 16.992859] DEV_XLP_NaeLaneResetTxpll: block 0 lane_ctrl 6 <4>[ 16.993481] DEV_XLP_NaeLaneResetTxpll value before power down =0x24100000 <4>[ 16.994121] DEV_XLP_NaeLaneResetTxpll value after power up =0x4100000 <4>[ 17.578576] Before register reset de-assertion PMA status value=0x841 <4>[ 17.579859] DEV_XLP_NaeLaneResetTxpll: block 0 lane_ctrl 7 <4>[ 17.580482] DEV_XLP_NaeLaneResetTxpll value before power down =0x24100000 <4>[ 17.581122] DEV_XLP_NaeLaneResetTxpll value after power up =0x4100000 <4>[ 18.165365] Before register reset de-assertion PMA status value=0x841 <4>[ 26.872450] VSEMI configuration is OK <4>[ 26.872486] DEV_XLP_NaeLaneResetTxpll: block 1 lane_ctrl 4 <4>[ 26.873121] DEV_XLP_NaeLaneResetTxpll value before power down =0x24100000 <4>[ 26.873751] DEV_XLP_NaeLaneResetTxpll value after power up =0x4100000 <4>[ 27.459216] Before register reset de-assertion PMA status value=0x841 <4>[ 27.460861] DEV_XLP_NaeLaneResetTxpll: block 1 lane_ctrl 5 <4>[ 27.461485] DEV_XLP_NaeLaneResetTxpll value before power down =0x24100000 <4>[ 27.462126] DEV_XLP_NaeLaneResetTxpll value after power up =0x4100000 <4>[ 28.046352] Before register reset de-assertion PMA status value=0x841 <4>[ 28.047859] DEV_XLP_NaeLaneResetTxpll: block 1 lane_ctrl 6 <4>[ 28.048482] DEV_XLP_NaeLaneResetTxpll value before power down =0x24100000 <4>[ 28.049122] DEV_XLP_NaeLaneResetTxpll value after power up =0x4100000 <4>[ 28.633548] Before register reset de-assertion PMA status value=0x841 <4>[ 28.634859] DEV_XLP_NaeLaneResetTxpll: block 1 lane_ctrl 7 <4>[ 28.635482] DEV_XLP_NaeLaneResetTxpll value before power down =0x24100000 <4>[ 28.636122] DEV_XLP_NaeLaneResetTxpll value after power up =0x4100000 <4>[ 29.220498] Before register reset de-assertion PMA status value=0x841 <0>[ 29.238396] 2: <4>[ 29.238410] FEL_MINISHELL_PdtReg:457<0>2: MINISHELL reg sussess <4>[ 29.251336] phy init end <4>[ 29.265323] <4>[ 29.265336] phy init end <4>[ 29.283797] <4>[ 29.283808] phy init end <4>[ 29.306803] <4>[ 29.306815] phy init end <4>[ 29.334317] <4>[ 29.334328] phy init end <4>[ 29.366336] <4>[ 29.366348] phy init end <4>[ 29.402893] <4>[ 29.402905] phy init end <4>[ 29.443935] <4>[ 29.443947] phy init end <0>[ 29.458558] 2:ERROR port <{FILE}> 767 HAL_PORT_TraversalActionShut vcpu(255): hal port Msg get failed <4>[ 29.458645] <4>[ 29.458655] <I>--[F]DEV_RECORDINFO_Init,[TK]scmd: <4>[ 29.458680] DEV_RECORDINFO Init is beginning! <4>[ 29.669545] <I>--[F]DEV_RECORDINFO_Init,[TK]scmd: <4>[ 29.669572] DEV_RECORDINFO Init is end!<0>2:ERROR lpu <{FILE}> 1197 HAL_DRV_LPU_GetSysMemAssignLocation vcpu(2): hal lpu get sysmem assign failed for drv failed <0>[ 29.669807] 2:ERROR mm <{FILE}> 5154 FEL_MM_AssignSysMM vcpu(2): HAL_LPU_GetMemAssignLocation fail. <0>[ 29.669898] 2:ERROR lpu <{FILE}> 1197 HAL_DRV_LPU_GetSysMemAssignLocation vcpu(2): hal lpu get sysmem assign failed for drv failed <0>[ 29.669987] 2:ERROR mm <{FILE}> 5154 FEL_MM_AssignSysMM vcpu(2): HAL_LPU_GetMemAssignLocation fail. <0>[ 29.757709] 2:ERROR mm <{FILE}> 1430 FEL_MM_Check_DrvInfoNode vcpu(2): crc error: DST_TYPE_dm_hgmem uiCrc=6960, SaveCrc=efdfc99b. <0>[ 29.757807] 2:ERROR mm <{FILE}> 260 FEL_MM_DM_HGMEM_Init vcpu(2): DM Check error ret=1073807361. <0>[ 30.865206] 2:ERROR per <{FILE}> 340 WCM_DRV_PWR_IsSupportFRU vcpu(2): WCM_DRV_PWR_IsSupportFRU(ulIndex =0x1, pulIsSupport =0xe804f9dc) <3>[ 127.568514] 2:id=0x1001,proc=0xf1b57670,funname=USR_OEM_Init <3>[ 127.568744] 2:id=0x1fff,proc=0xf1b55860,funname=USR_IPV6MC_DrvInit <3>[ 127.568807] 2:id=0x1fff,proc=0xf1b552c0,funname=IP_Install_Drv <3>[ 127.568886] 2:id=0x1fff,proc=0xf1b57ab0,funname=USR_PFLT_DrvInit <3>[ 127.568936] 2:id=0x1fff,proc=0xf1b55600,funname=USR_IPMC_DrvInit <3>[ 127.568987] 2:id=0x3fff,proc=0xf1b530c0,funname=RC_ModInit <3>[ 127.569041] 2:id=0x4000,proc=0xf209eb70,funname=MBUF_Init <3>[ 127.569085] 2:id=0x4001,proc=0xf1b56c10,funname=MBUF_DrvInit <3>[ 127.569133] 2:id=0x4002,proc=0xf20a29c0,funname=MBUF_StartupInit <3>[ 127.572356] 2:id=0x5000,proc=0xf1b54760,funname=FASTMBUF_DrvInit <3>[ 127.572409] 2:id=0x5001,proc=0xf209dcc0,funname=FASTMBUF_Run <3>[ 127.574072] 2:id=0x6000,proc=0xf20b2d40,funname=domaininit <7>[ 127.578654] 2:SYS_CALL_TABLE is 80102f28, 80102eb4 <7>[ 127.578701] 2:SYSCALL_ENTRY 356 modified here, f20bc4f0 <7>[ 127.578744] 2:SYS_CALL_TABLE is 80102f28, 80102eb4 <7>[ 127.578784] 2:SYSCALL_ENTRY 350 modified here, f20bc280 <7>[ 127.578827] 2:SYS_CALL_TABLE is 80102f28, 80102eb4 <7>[ 127.578880] 2:SYSCALL_ENTRY 366 modified here, f20bc990 <7>[ 127.578922] 2:SYS_CALL_TABLE is 80102f28, 80102eb4 <7>[ 127.578961] 2:SYSCALL_ENTRY 204 modified here, f20bcfd0 <7>[ 127.579002] 2:SYS_CALL_TABLE is 80102f28, 80102eb4 <7>[ 127.579041] 2:SYSCALL_ENTRY 340 modified here, f20bc870 <7>[ 127.579083] 2:SYS_CALL_TABLE is 80102f28, 80102eb4 <7>[ 127.579122] 2:SYSCALL_ENTRY 336 modified here, f20bcd90 <7>[ 127.579163] 2:SYS_CALL_TABLE is 80102f28, 80102eb4 <7>[ 127.579202] 2:SYSCALL_ENTRY 360 modified here, f20bc5c0 <7>[ 127.579243] 2:SYS_CALL_TABLE is 80102f28, 80102eb4 <7>[ 127.579281] 2:SYSCALL_ENTRY 352 modified here, f20bc350 <7>[ 127.579323] 2:SYS_CALL_TABLE is 80102f28, 80102eb4 <7>[ 127.579361] 2:SYSCALL_ENTRY 358 modified here, f20bc430 <7>[ 127.579402] 2:SYS_CALL_TABLE is 80102f28, 80102eb4 <7>[ 127.579440] 2:SYSCALL_ENTRY 354 modified here, f20bc1c0 <7>[ 127.579482] 2:SYS_CALL_TABLE is 80102f28, 80102eb4 <7>[ 127.579521] 2:SYSCALL_ENTRY 364 modified here, f20bc090 <7>[ 127.579562] 2:SYS_CALL_TABLE is 80102f28, 80102eb4 <7>[ 127.579601] 2:SYSCALL_ENTRY 338 modified here, f20bc900 <7>[ 127.579642] 2:SYS_CALL_TABLE is 80102f28, 80102eb4 <7>[ 127.579681] 2:SYSCALL_ENTRY 348 modified here, f20bc7e0 <7>[ 127.579722] 2:SYS_CALL_TABLE is 80102f28, 80102eb4 <7>[ 127.579762] 2:SYSCALL_ENTRY 344 modified here, f20bcf40 <7>[ 127.579804] 2:SYS_CALL_TABLE is 80102f28, 80102eb4 <7>[ 127.579842] 2:SYSCALL_ENTRY 342 modified here, f20bcb40 <7>[ 127.580168] 2:SYS_CALL_TABLE is 80102f28, 80102eb4 <7>[ 127.580208] 2:SYSCALL_ENTRY 368 modified here, f20bc120 <7>[ 127.580250] 2:SYS_CALL_TABLE is 80102f28, 80102eb4 <7>[ 127.580288] 2:SYSCALL_ENTRY 362 modified here, f20bc740 <7>[ 127.580330] 2:SYS_CALL_TABLE is 80102f28, 80102eb4 <7>[ 127.580368] 2:SYSCALL_ENTRY 346 modified here, f20bc6a0 <3>[ 127.582218] 2:id=0x6001,proc=0xf20b28f0,funname=net_add_domain <3>[ 127.584170] 2:id=0x6001,proc=0xf1fc8700,funname=OSI_Init <3>[ 127.584704] 2:id=0x6001,proc=0xf20b28f0,funname=net_add_domain <3>[ 127.584761] 2:id=0x6001,proc=0xf1fc2bc0,funname=LPS_Init <3>[ 127.585304] 2:id=0x6001,proc=0xf1b56ca0,funname=USR_MBUS_Init <3>[ 127.585382] 2:id=0x6001,proc=0xf20b28f0,funname=net_add_domain <3>[ 127.585690] 2:id=0x6001,proc=0xf20b28f0,funname=net_add_domain <3>[ 127.586067] 2:id=0x6001,proc=0xf22c6320,funname=PACKET_Init <3>[ 127.586118] 2:id=0x6002,proc=0xf28edb80,funname=DOT11_USR_RegPacketSW <3>[ 127.586658] 2:id=0x6002,proc=0xf293e390,funname=PPP_USR_RegPacketSW <3>[ 127.587229] 2:id=0x6002,proc=0xf1b561f0,funname=USR_LIPC_Init <3>[ 127.600903] 2:id=0x6002,proc=0xf208ee00,funname=ETH_USR_RegPacketSW <3>[ 127.601495] 2:id=0x6002,proc=0xf22ff520,funname=TUNNEL_USR_RegSW <3>[ 127.602170] 2:id=0x6100,proc=0xf23bfc30,funname=genl_init <3>[ 127.778007] 2:id=0x6100,proc=0xf23bfe60,funname=KEvent_Init <3>[ 127.778084] 2:id=0x6fff,proc=0xf20b28a0,funname=domainfinalize <3>[ 127.778132] 2:id=0x8001,proc=0xf1b542b0,funname=USR_DEV_Init <4>[ 127.780487] 2:DEV_KDBG: Md:DRV Lv:WARN Ln: 558 GetInfo DriNotSupport! class(9) chass(65535) slot(65535) sslot(65535) cmd(18) <4>[ 127.780669] 2:DEV_KDBG: Md:DRV Lv:WARN Ln: 558 GetInfo DriNotSupport! class(9) chass(65535) slot(65535) sslot(65535) cmd(19) <4>[ 127.781598] 2:DEV_KDBG: Md:DRV Lv:WARN Ln: 558 GetInfo DriNotSupport! class(3) chass(65535) slot(65535) sslot(65535) cmd(30) <4>[ 127.781785] 2:DEV_KDBG: Md:DRV Lv:WARN Ln: 558 GetInfo DriNotSupport! class(9) chass(65535) slot(65535) sslot(65535) cmd(30) <4>[ 127.781981] 2:DEV_KDBG: Md:DRV Lv:WARN Ln: 558 GetInfo DriNotSupport! class(3) chass(65535) slot(65535) sslot(65535) cmd(31) <4>[ 127.782164] 2:DEV_KDBG: Md:DRV Lv:WARN Ln: 558 GetInfo DriNotSupport! class(9) chass(65535) slot(65535) sslot(65535) cmd(31) <4>[ 127.782348] 2:DEV_KDBG: Md:DRV Lv:WARN Ln: 558 GetInfo DriNotSupport! class(11) chass(65535) slot(65535) sslot(65535) cmd(35) <4>[ 127.782530] 2:DEV_KDBG: Md:DRV Lv:WARN Ln: 558 GetInfo DriNotSupport! class(3) chass(65535) slot(65535) sslot(65535) cmd(37) <4>[ 127.782710] 2:DEV_KDBG: Md:DRV Lv:WARN Ln: 558 GetInfo DriNotSupport! class(9) chass(65535) slot(65535) sslot(65535) cmd(37) <4>[ 127.782905] 2:DEV_KDBG: Md:DRV Lv:WARN Ln: 558 GetInfo DriNotSupport! class(3) chass(65535) slot(65535) sslot(65535) cmd(38) <4>[ 127.783090] 2:DEV_KDBG: Md:DRV Lv:WARN Ln: 558 GetInfo DriNotSupport! class(9) chass(65535) slot(65535) sslot(65535) cmd(38) <4>[ 127.785403] 2:DEV_KDBG: Md:DRV Lv:WARN Ln: 558 GetInfo DriNotSupport! class(9) chass(0) slot(1) sslot(65535) cmd(18) <4>[ 127.785581] 2:DEV_KDBG: Md:DRV Lv:WARN Ln: 558 GetInfo DriNotSupport! class(9) chass(0) slot(1) sslot(65535) cmd(19) <4>[ 127.786470] 2:DEV_KDBG: Md:DRV Lv:WARN Ln: 558 GetInfo DriNotSupport! class(3) chass(0) slot(65535) sslot(65535) cmd(30) <4>[ 127.786645] 2:DEV_KDBG: Md:DRV Lv:WARN Ln: 558 GetInfo DriNotSupport! class(9) chass(0) slot(1) sslot(65535) cmd(30) <4>[ 127.786827] 2:DEV_KDBG: Md:DRV Lv:WARN Ln: 558 GetInfo DriNotSupport! class(3) chass(0) slot(65535) sslot(65535) cmd(31) <4>[ 127.787020] 2:DEV_KDBG: Md:DRV Lv:WARN Ln: 558 GetInfo DriNotSupport! class(9) chass(0) slot(1) sslot(65535) cmd(31) <4>[ 127.787201] 2:DEV_KDBG: Md:DRV Lv:WARN Ln: 558 GetInfo DriNotSupport! class(11) chass(0) slot(65535) sslot(65535) cmd(35) <4>[ 127.787380] 2:DEV_KDBG: Md:DRV Lv:WARN Ln: 558 GetInfo DriNotSupport! class(3) chass(0) slot(65535) sslot(65535) cmd(37) <4>[ 127.787560] 2:DEV_KDBG: Md:DRV Lv:WARN Ln: 558 GetInfo DriNotSupport! class(9) chass(0) slot(1) sslot(65535) cmd(37) <4>[ 127.787741] 2:DEV_KDBG: Md:DRV Lv:WARN Ln: 558 GetInfo DriNotSupport! class(3) chass(0) slot(65535) sslot(65535) cmd(38) <4>[ 127.787936] 2:DEV_KDBG: Md:DRV Lv:WARN Ln: 558 GetInfo DriNotSupport! class(9) chass(0) slot(1) sslot(65535) cmd(38) <4>[ 127.788838] 2:DEV_KDBG: Md:KENV Lv:INFO Ln: 599 the device [0:65535:65535] not support sensor <0>[ 127.789495] 2:ERROR lpu <{FILE}> 1929 HAL_DRV_LPU_GetDeviceType vcpu(2): hal lpu get poe type failed for func not support <4>[ 127.789835] 2:DEV_KDBG: Md:KD Lv:INFO Ln:1001 DEV_Init completed! <3>[ 127.789905] 2:id=0x9000,proc=0xf1b54160,funname=USR_CFM_Init <3>[ 127.803944] 2:id=0xa000,proc=0xf1b563a0,funname=USR_LOAD_Init <3>[ 127.828901] 2:id=0xe001,proc=0xf1e1f9f0,funname=MDC_CORE_Init <3>[ 127.828967] 2:id=0xe002,proc=0xf1e33e50,funname=TIME_SYNC_Init <3>[ 127.834900] 2:id=0xe002,proc=0xf1dfe7f0,funname=LIPC_PortEvt_Init <3>[ 127.840898] 2:id=0xf001,proc=0xf20436c0,funname=MC_Msg_Init <3>[ 127.841664] 2:id=0x10fff,proc=0xf20b0a70,funname=domainservinit <3>[ 127.843543] 2:id=0x11000,proc=0xf1e32930,funname=SYSLOG_Init <3>[ 127.843724] 2:id=0x13002,proc=0xf25fa010,funname=USERLOG_Init <3>[ 127.849905] 2:id=0x14001,proc=0xf1b54d00,funname=USR_IF_Init <3>[ 127.863046] 2:id=0x15001,proc=0xf1e32790,funname=SYNC_Init <3>[ 127.863972] 2:id=0x16fff,proc=0xf23b79f0,funname=Knotify_Init <3>[ 127.864049] 2:id=0x17001,proc=0xf1d8d920,funname=DIAG_Init <3>[ 127.864129] 2:id=0x19001,proc=0xf1b55e60,funname=USR_L3VPN_Init <3>[ 127.864181] 2:id=0x1a000,proc=0xf1fcc2b0,funname=IPAddr_StartInit <3>[ 127.864327] 2:id=0x1b000,proc=0xf23ae3b0,funname=IP6Addr_StartInit <3>[ 127.864563] 2:id=0x1c001,proc=0xf1b54460,funname=USR_ETH_Init <3>[ 127.865034] 2:id=0x1f001,proc=0xf2937110,funname=PPP_ModInit <3>[ 127.865957] 2:id=0x20001,proc=0xf28ea9c0,funname=DOT11_Init <3>[ 127.866042] 2:id=0x26000,proc=0xf1c320d0,funname=WCM_DRV_InitPostCmw <4>[ 127.867058] fel mm misc update boot type 1 <3>[ 128.365174] 2:id=0x27001,proc=0xf1b58770,funname=USR_VLAN_Init <3>[ 128.365579] 2:id=0x27002,proc=0xf1b58740,funname=USR_VLAN_Run <3>[ 128.365912] 2:id=0x29000,proc=0xf1b58440,funname=USR_STG_Init <3>[ 128.366400] 2:id=0x2a001,proc=0xf1b56930,funname=USR_MAC_Init <3>[ 128.372920] 2:id=0x2c001,proc=0xf1fff020,funname=MACFW_Init <3>[ 128.373373] 2:id=0x2f000,proc=0xf1b58fc0,funname=USR_WLANFW_Init <3>[ 128.374266] 2:id=0x30001,proc=0xf20cdfc0,funname=ADJ_ModInit <3>[ 128.374771] 2:id=0x31000,proc=0xf1b551c0,funname=USR_IPFS_Init <3>[ 128.374823] 2:id=0x31001,proc=0xf2228d60,funname=IPFS_Init <3>[ 128.381142] 2:id=0x32000,proc=0xf21ddbe0,funname=IPFW_Init <3>[ 128.381815] 2:id=0x33000,proc=0xf228a980,funname=IP6FW_Init <3>[ 128.382358] 2:id=0x34000,proc=0xf1b55160,funname=USR_IP6FS_Init <3>[ 128.382410] 2:id=0x34001,proc=0xf22c0200,funname=IP6FS_Init <3>[ 128.387939] 2:id=0x36fff,proc=0xf1b53a90,funname=USR_ACL_Init <3>[ 128.388043] 2:id=0x37fff,proc=0xf1b58200,funname=USR_QOSFW_Init <3>[ 128.388290] 2:id=0x38fff,proc=0xf1b574d0,funname=USR_MQC_Init <3>[ 128.388381] 2:id=0x39fff,proc=0xf1b57f40,funname=USR_PRIMAP_Init <3>[ 128.388436] 2:id=0x3afff,proc=0xf1b53fd0,funname=USR_CAR_Init <3>[ 128.388485] 2:id=0x3ffff,proc=0xf1b54230,funname=USR_COPP_Init <3>[ 128.388538] 2:id=0x40fff,proc=0xf1b54cb0,funname=USR_GTS_Init <3>[ 128.388585] 2:id=0x41fff,proc=0xf1b586f0,funname=USR_USERQOS_Init <3>[ 128.388663] 2:id=0x42fff,proc=0xf1b56660,funname=USR_LR_Init <3>[ 128.388712] 2:id=0x44001,proc=0xf1b547b0,funname=USR_FIB6_Init <3>[ 128.388763] 2:id=0x45001,proc=0xf1b548f0,funname=USR_FIB_Init <3>[ 128.410528] 2:id=0x46001,proc=0xf1b53b00,funname=USR_ARP_Init <3>[ 128.413638] 2:id=0x47001,proc=0xf1b57550,funname=USR_ND_Init <3>[ 128.416105] 2:id=0x48001,proc=0xf1b58dd0,funname=USR_WADJ4_Init <3>[ 128.416691] 2:id=0x49001,proc=0xf1b58ed0,funname=USR_WADJ6_Init <3>[ 128.417283] 2:id=0x4a000,proc=0xf222ab80,funname=MCFWD_Adaptor_Init <3>[ 128.417363] 2:id=0x4f001,proc=0xf22c4fd0,funname=PMTU_Init <3>[ 128.417415] 2:id=0x52001,proc=0xf1b55b10,funname=USR_USERBIND_StartUpInit <3>[ 128.418446] 2:id=0x53fff,proc=0xf1b543e0,funname=DHCP_Install_Driver <3>[ 128.418500] 2:id=0x57fff,proc=0xf1b56e80,funname=USR_MGROUP_Init <3>[ 128.418565] 2:id=0x60000,proc=0xf1b55510,funname=USR_IPMC_Init <3>[ 128.418618] 2:id=0x60000,proc=0xf1b55780,funname=USR_IPV6MC_Init <3>[ 128.418670] 2:id=0x61fff,proc=0xf1b55f60,funname=USR_LAGG_Init <3>[ 128.418993] 2:id=0x64fff,proc=0xf1b585d0,funname=USR_TUNNEL_Init <3>[ 128.419426] 2:id=0x66fff,proc=0xf1b54a30,funname=USR_GRE_Init <3>[ 128.419480] 2:id=0x6e001,proc=0xf1b579f0,funname=USR_PBR_Init <3>[ 128.421040] 2:id=0x73001,proc=0xf23c0660,funname=UDPH_ModInit <3>[ 128.421240] 2:id=0x76fff,proc=0xf1b54060,funname=USR_CCF_Init <3>[ 128.421982] 2:id=0x77fff,proc=0xf1b55640,funname=USR_IPSEC_Init <3>[ 128.422080] 2:id=0x7cfff,proc=0xf1b57a80,funname=USR_PFLT_StartUpInit <3>[ 128.422135] 2:id=0x7dfff,proc=0xf1b538b0,funname=USR_APR_StartUpInit <3>[ 128.422228] 2:id=0x7ffff,proc=0xf252ebd0,funname=USR_ATK_StartUpInit <3>[ 128.422284] 2:id=0x80fff,proc=0xf1b57530,funname=USR_NAT_StartUpInit <3>[ 128.423618] 2:id=0x81fff,proc=0xf1b53c50,funname=USR_ASPF_StartUpInit <3>[ 128.423816] 2:id=0x82fff,proc=0xf1b584d0,funname=USR_TCP_PROXY_Init <3>[ 128.443894] 2:id=0x83fff,proc=0xf1b55d10,funname=USR_KHTTP_Init <3>[ 128.445401] 2:id=0x84fff,proc=0xf1b583d0,funname=USR_SSLVPN_Init <3>[ 128.445676] 2:id=0x85fff,proc=0xf1b55d30,funname=USR_KSSL_Init <3>[ 128.448942] 2:id=0x87fff,proc=0xf1b561d0,funname=USR_LB_Init <3>[ 128.462414] 2:id=0x8afff,proc=0xf1b58280,funname=USR_SESSION_StartUpInit <3>[ 128.486932] 2:id=0x8bfff,proc=0xf1b57bc0,funname=USR_PORTAL_StartUpInit <3>[ 128.487103] 2:id=0x8ffff,proc=0xf293e810,funname=PPPOES_KInit <3>[ 128.487211] 2:id=0x90fff,proc=0xf1b57d90,funname=USR_PPPOEC_Init <3>[ 128.487457] 2:id=0x94fff,proc=0xf1b540a0,funname=USR_CELLULAR_Init <3>[ 128.487594] 2:id=0x98fff,proc=0xf1b55d50,funname=USR_L2TPV2_StartUpInit <3>[ 128.487949] 2:id=0x9efff,proc=0xf1b579a0,funname=USR_OFP_Init <3>[ 128.488261] 2:id=0xa1fff,proc=0xf1b57cc0,funname=USR_PORTSEC_Init <3>[ 128.488435] 2:id=0xa4fff,proc=0xf1b53ae0,funname=USR_APMGR_Init <3>[ 128.490080] 2:id=0xa5fff,proc=0xf1b583f0,funname=USR_STAMGR_Init <4>[ 128.490407] Init bss cache success ! <4>[ 128.490727] Init bss service cache success. <4>[ 128.491016] Init station cache success. <3>[ 128.491845] 2:id=0xa8fff,proc=0xf1b586d0,funname=USR_TWAMP_Init <3>[ 128.491955] 2:id=0xb6fff,proc=0xf1b53a20,funname=USR_AAA_StartUpInit <3>[ 128.492198] 2:id=0xb7fff,proc=0xf1b539c0,funname=USR_TCPREASSEMBLE_StartUpInit <3>[ 128.492399] 2:id=0xb8fff,proc=0xf24ba640,funname=DIM_KInit <3>[ 128.499629] 2:id=0xbbfff,proc=0xf24aeb50,funname=AVC_Init <3>[ 128.500650] 2:id=0xbcfff,proc=0xf24e7bb0,funname=UFLT_KInit <3>[ 128.500809] 2:id=0xc7fff,proc=0xf28d22a0,funname=KDRS_Init <3>[ 128.500870] 2:id=0xcafff,proc=0xf1b53960,funname=USR_NBAR_StartUpInit <3>[ 128.501220] 2:id=0x10000000,proc=0xf1b55ca0,funname=USR_ISSU_Run <3>[ 128.501284] 2:id=0x10001000,proc=0xf1e1fc40,funname=OEM_AutoRun <3>[ 128.501333] 2:id=0x10004000,proc=0xf20a2df0,funname=MBUF_InitThread <3>[ 128.501383] 2:id=0x10006001,proc=0xf1defeb0,funname=USR_LIPC_AutoRun <3>[ 128.501461] 2:id=0x10006fff,proc=0xf1fc8300,funname=OSI_AutoRun <3>[ 128.501513] 2:id=0x10006fff,proc=0xf2241360,funname=inet6_autorun <3>[ 128.501604] 2:id=0x10006fff,proc=0xf20b2bc0,funname=domainrun <4>[ 128.507970] 1:DEV_KDBG: Md:HOT Lv:INFO Ln: 991 RegisterSlaveSwitchCallback, RetHandle=1 <3>[ 128.508719] 2:id=0x10006fff,proc=0xf1fc2b70,funname=LPS_AutoRun <3>[ 128.508780] 2:id=0x10006fff,proc=0xf224b4c0,funname=inet_autorun <3>[ 128.509160] 2:id=0x10008001,proc=0xf1b54280,funname=USR_DEV_Run <3>[ 128.509544] 2:id=0x10009000,proc=0xf1d69e50,funname=USR_CFM_Run <3>[ 128.509595] 2:id=0x1000a000,proc=0xf1b56370,funname=USR_LOAD_Run <3>[ 128.509644] 2:id=0x1000e002,proc=0xf1e32af0,funname=TIME_SYNC_Run <3>[ 128.509693] 2:id=0x10011000,proc=0xf1e32920,funname=SYSLOG_Run <3>[ 128.509767] 2:id=0x10013002,proc=0xf25fa000,funname=USERLOG_Run <3>[ 128.509880] 2:id=0x10019001,proc=0xf1b55e50,funname=USR_L3VPN_Run <3>[ 128.509930] 2:id=0x1001a001,proc=0xf1fcc1b0,funname=IPAddr_StartRun <3>[ 128.509999] 2:id=0x1001b001,proc=0xf23ae280,funname=IP6Addr_StartRun <3>[ 128.510063] 2:id=0x1001cfff,proc=0xf204feb0,funname=ETH_AutoRun <3>[ 128.510165] 2:id=0x1001ffff,proc=0xf2936950,funname=PPP_ModRun <3>[ 128.510225] 2:id=0x10029000,proc=0xf1b58410,funname=USR_STG_Run <3>[ 128.510275] 2:id=0x1002a001,proc=0xf1fe9700,funname=MAC_ModRun <4>[ 128.510909] 2:DEV_KDBG: Md:HOT Lv:INFO Ln: 991 RegisterSlaveSwitchCallback, RetHandle=2 <3>[ 128.511996] 2:id=0x1002c001,proc=0xf1ffefb0,funname=MACFW_Run <3>[ 128.512057] 2:id=0x1002f001,proc=0xf28fef30,funname=USR_WLANFW_Run <3>[ 128.512122] 2:id=0x10030000,proc=0xf20cdec0,funname=ADJ_ModRun <3>[ 128.530896] 2:id=0x10031fff,proc=0xf2229040,funname=IPFS_Run <3>[ 128.531743] 2:id=0x10032fff,proc=0xf21ddd60,funname=IPFW_Run <3>[ 128.531843] 2:id=0x10033fff,proc=0xf228a350,funname=IP6FW_Run <3>[ 128.531914] 2:id=0x10034fff,proc=0xf22c0690,funname=IP6FS_Run <3>[ 128.532725] 2:id=0x10036fff,proc=0xf1b53a50,funname=USR_ACL_Run <3>[ 128.533110] 2:id=0x10037fff,proc=0xf1b580f0,funname=USR_QOSFW_Run <3>[ 128.533752] 2:id=0x10038fff,proc=0xf1b57350,funname=USR_MQC_Run <3>[ 128.534083] 2:id=0x10039fff,proc=0xf1b57e60,funname=USR_PRIMAP_Run <3>[ 128.534257] 2:id=0x1003afff,proc=0xf1b53e30,funname=USR_CAR_Run <3>[ 128.535524] 2:id=0x1003ffff,proc=0xf1b541a0,funname=USR_COPP_Run <3>[ 128.537102] 2:id=0x10040fff,proc=0xf1b54b90,funname=USR_GTS_Run <3>[ 128.537199] 2:id=0x10041fff,proc=0xf1b586e0,funname=USR_USERQOS_Run <3>[ 128.537347] 2:id=0x10042fff,proc=0xf1b56520,funname=USR_LR_Run <3>[ 128.537414] 2:id=0x10044001,proc=0xf1b547a0,funname=USR_FIB6_Run <3>[ 128.537463] 2:id=0x10045001,proc=0xf1b548e0,funname=USR_FIB_Run <3>[ 128.537686] 2:id=0x10046001,proc=0xf1b53af0,funname=USR_ARP_Run <3>[ 128.537776] 2:id=0x10047001,proc=0xf1b57540,funname=USR_ND_Run <3>[ 128.537941] 2:id=0x10048001,proc=0xf1b58dc0,funname=USR_WADJ4_Run <3>[ 128.537996] 2:id=0x10049001,proc=0xf1b58ec0,funname=USR_WADJ6_Run <3>[ 128.538056] 2:id=0x1004bfff,proc=0xf2443470,funname=VRRP_Run <3>[ 128.538310] 2:id=0x1004f001,proc=0xf22c4f30,funname=PMTU_Run <3>[ 128.538413] 2:id=0x10053fff,proc=0xf23d1900,funname=DHCP_AutoRun <3>[ 128.538559] 2:id=0x10054fff,proc=0xf23e4aa0,funname=DHCPSR_AutoRun <3>[ 128.538702] 2:id=0x10055fff,proc=0xf23d22f0,funname=DHCPSP_AutoRun <3>[ 128.538910] 2:id=0x10056fff,proc=0xf23d64e0,funname=DHCPSP6_AutoRun <3>[ 128.539071] 2:id=0x10057000,proc=0xf1b56dd0,funname=USR_MGROUP_Run <3>[ 128.539264] 2:id=0x10060fff,proc=0xf1b55700,funname=USR_IPV6MC_Run <3>[ 128.549877] 2:id=0x10060fff,proc=0xf1b55490,funname=USR_IPMC_Run <3>[ 128.549930] 2:id=0x10061fff,proc=0xf1b55ec0,funname=USR_LAGG_Run <3>[ 128.549979] 2:id=0x10064fff,proc=0xf1b58500,funname=USR_TUNNEL_Run <3>[ 128.556320] 2:id=0x10065001,proc=0xf1e2d4a0,funname=SNMP_Run <3>[ 128.556401] 2:id=0x10066fff,proc=0xf1b54a20,funname=USR_GRE_Run <3>[ 128.556518] 2:id=0x1006dfff,proc=0xf1b563d0,funname=USR_LPDT_Run <3>[ 128.556575] 2:id=0x1006e001,proc=0xf1b57a30,funname=USR_PBR_Run <3>[ 128.556627] 2:id=0x10073001,proc=0xf23c05d0,funname=UDPH_ModRun <3>[ 128.556680] 2:id=0x10074001,proc=0xf1fd4e30,funname=IPVFR_ModRun <3>[ 128.556777] 2:id=0x10076fff,proc=0xf1b54020,funname=USR_CCF_Run <3>[ 128.563848] 2:id=0x10077fff,proc=0xf1b55630,funname=USR_IPSEC_Run <3>[ 128.564144] 2:id=0x1007cfff,proc=0xf1b57a70,funname=USR_PFLT_StartUpAutoRun <3>[ 128.566339] 2:id=0x1007dfff,proc=0xf1b53880,funname=USR_APR_StartUpAutoRun <3>[ 128.566780] 2:id=0x1007ffff,proc=0xf252ebc0,funname=USR_ATK_StartUpAutoRun <3>[ 128.567613] 2:id=0x10080fff,proc=0xf1b57520,funname=USR_NAT_StartUpAutoRun <3>[ 128.568641] 2:id=0x10081fff,proc=0xf1b53c40,funname=USR_ASPF_StartUpAutoRun <3>[ 128.568768] 2:id=0x10082fff,proc=0xf1b584c0,funname=USR_TCP_PROXY_Run <3>[ 128.569002] 2:id=0x10083fff,proc=0xf1b55d00,funname=USR_KHTTP_Run <3>[ 128.569063] 2:id=0x10084fff,proc=0xf1b58380,funname=USR_SSLVPN_Run <3>[ 128.570643] 2:id=0x10085fff,proc=0xf1b55d20,funname=USR_KSSL_Run <3>[ 128.578472] 2:id=0x10087fff,proc=0xf1b561c0,funname=USR_LB_Run <3>[ 128.580547] 2:id=0x1008afff,proc=0xf1b58250,funname=USR_SESSION_StartUpAutoRun <3>[ 128.586868] 2:id=0x1008bfff,proc=0xf1b57ac0,funname=USR_PORTAL_StartUpAutoRun <3>[ 128.587581] 2:id=0x1008ffff,proc=0xf293e780,funname=PPPOES_AutoRun <3>[ 128.587684] 2:id=0x10090fff,proc=0xf1b57d80,funname=USR_PPPOEC_Run <3>[ 128.587743] 2:id=0x10091001,proc=0xf29318d0,funname=DDR_KRun <3>[ 128.587981] 2:id=0x10094fff,proc=0xf1b54090,funname=USR_CELLULAR_Run <3>[ 128.588091] 2:id=0x10096fff,proc=0xf1e2d1c0,funname=RMON_Init <3>[ 128.588146] 2:id=0x10098fff,proc=0xf1b55d40,funname=USR_L2TPV2_StartUpAutoRun <3>[ 128.588459] 2:id=0x1009efff,proc=0xf1b57800,funname=USR_OFP_Run <3>[ 128.588694] 2:id=0x100a4fff,proc=0xf1b53ad0,funname=USR_APMGR_Run <3>[ 128.589097] 2:id=0x100a5fff,proc=0xf1b583e0,funname=USR_STAMGR_Run <4>[ 128.589194] Success to register upward frame proccess <4>[ 128.589235] [USERSEC] Success to register upward frame proccess <4>[ 128.589281] Success to register downward frame proccess <3>[ 128.589325] 2:id=0x100a6fff,proc=0xf2936940,funname=LTE_AutoRun <3>[ 128.589378] 2:id=0x100b6fff,proc=0xf1b539f0,funname=USR_AAA_StartUpAutoRun <3>[ 128.589521] 2:id=0x100b7fff,proc=0xf1b53990,funname=USR_TCPREASSEMBLE_StartUpAutoRun <3>[ 128.590448] 2:id=0x100b8fff,proc=0xf24ba360,funname=DIM_KRun <3>[ 128.591153] 2:id=0x100bbfff,proc=0xf24ae9b0,funname=AVC_Run <3>[ 128.592628] 2:id=0x100bcfff,proc=0xf24e7a90,funname=UFLT_KRun <3>[ 128.598906] 2:id=0x100c7fff,proc=0xf28d2290,funname=KDRS_Run <3>[ 128.604899] 2:id=0x100c8fff,proc=0xf1b55bd0,funname=USR_ISOVLAN_AutoRun <3>[ 128.605100] 2:id=0x100cafff,proc=0xf1b53930,funname=USR_NBAR_StartUpAutoRun <3>[ 128.605186] 2:id=0xffffffff,proc=0xf1e1fa30,funname=MDC_HandleInitOver <4>[ 130.273167] <4>[ 130.273189] <4>[ 130.273220] DRV_CELLULAR_PhyInit 2101 <4>[ 130.273252] <4>[ 130.273265] <4>[ 130.273871] -----hw_cdc_init4039------ <6>[ 130.274188] 0:usbcore: registered new interface driver huawei_ether <4>[ 130.274257] Usbnet_Init 108 <6>[ 130.274523] 0:usbcore: registered new interface driver umodem <0>[ 130.274627] 0:ERROR cellular <{FILE}> 946 CONTROLLER_CELLULAR_MakeSureIOCtlParaValid vcpu(0): IOCTL:Receive NOTSUPPORT CMD[0x108003e],Para:00000001 <4>[ 130.274697] <0>[ 131.136507] 0:ERROR devm <{FILE}> 6211 DAL_DRV_DEV_GetInfo vcpu(0): return error <4>[ 705.986368] 2022-03-19 01:50:37 2022-03-19 01:57:51 2022-03-19 02:03:23 2022-03-19 02:04:01 2022-03-19 02:19:04 2022-03-19 02:22:04 2022-03-19 02:34:09 ===============system memory info =============== MemTotal: 976164 kB MemFree: 183196 kB Buffers: 1948 kB Cached: 191752 kB SwapCached: 0 kB Active: 181964 kB Inactive: 142024 kB HighTotal: 0 kB HighFree: 0 kB LowTotal: 976164 kB LowFree: 183196 kB SwapTotal: 0 kB SwapFree: 0 kB Dirty: 0 kB Writeback: 0 kB AnonPages: 130368 kB Mapped: 49124 kB Slab: 246148 kB SReclaimable: 6432 kB SUnreclaim: 239716 kB PageTables: 2860 kB NFS_Unstable: 0 kB Bounce: 0 kB WritebackTmp: 0 kB CommitLimit: 488080 kB Committed_AS: 842580 kB VmallocTotal: 229368 kB VmallocUsed: 38376 kB VmallocChunk: 176844 kB ==============free memory stat =============== Node 0, zone Normal 9 45 14 40 46 12 1 3 1 3 1 2 3 1 1 0 ==============area malloc usage info =============== 0xf0000000-0xf0002000 8192 kdb_reservevaddr+0x14/0x40 ioremap 0xf0002000-0xf0004000 8192 mtdoops_console_init+0x24/0xb0 pages=1 vmalloc 0xf0004000-0xf0006000 8192 module_alloc+0x3c/0x90 pages=1 vmalloc 0xf0006000-0xf0012000 49152 cramfs_uncompress_init+0x44/0x80 pages=11 vmalloc 0xf0012000-0xf0055000 274432 jffs2_zlib_init+0x1c/0xc4 pages=66 vmalloc 0xf0055000-0xf0061000 49152 jffs2_zlib_init+0x58/0xc4 pages=11 vmalloc 0xf0061000-0xf0072000 69632 jffs2_lzo_init+0x14/0x88 pages=16 vmalloc 0xf0072000-0xf0075000 12288 jffs2_lzo_init+0x24/0x88 pages=2 vmalloc 0xf0075000-0xf0077000 8192 FEL_WAN_Hash_Create+0xe8/0x230 [system] pages=1 vmalloc 0xf0077000-0xf00b8000 266240 PPP_KCB_InitGlobal+0x20/0xf0 [system] pages=64 vmalloc 0xf00b8000-0xf00bb000 12288 HASH_Large_Create+0x40/0xc0 [system] pages=2 vmalloc 0xf00bb000-0xf00bd000 8192 HASH_Large_Create+0x40/0xc0 [system] pages=1 vmalloc 0xf00bd000-0xf00c0000 12288 HASH_Large_Create+0x40/0xc0 [system] pages=2 vmalloc 0xf00c0000-0xf00c2000 8192 HASH_Large_Create+0x40/0xc0 [system] pages=1 vmalloc 0xf00c2000-0xf00e3000 135168 IPFS_CacheVar_Init+0xc4/0x3c0 [system] pages=32 vmalloc 0xf00e3000-0xf0104000 135168 IP6FS_CacheInit+0xa4/0x5b0 [system] pages=32 vmalloc 0xf0104000-0xf0106000 8192 HASH_Large_Create+0x40/0xc0 [system] pages=1 vmalloc 0xf0106000-0xf0108000 8192 MCFS_CACHE_HashTableInit+0x58/0x160 [system] pages=1 vmalloc 0xf0108000-0xf010a000 8192 HASH_Large_Create+0x40/0xc0 [system] pages=1 vmalloc 0xf010a000-0xf010c000 8192 MCFS_CACHE_HashTableInit+0x58/0x160 [system] pages=1 vmalloc 0xf010c000-0xf017d000 462848 module_alloc+0x3c/0x90 pages=112 vmalloc 0xf017d000-0xf021e000 659456 FEL_WAN_Hash_Create+0xc0/0x230 [system] pages=160 vmalloc 0xf021e000-0xf0620000 4202496 fib_hash_MDCInit+0x130/0x160 [system] pages=1025 vmalloc 0xf0620000-0xf0722000 1056768 SESSION_KHash_Init+0x40/0x180 [system] pages=257 vmalloc 0xf0722000-0xf0824000 1056768 SESSION_KHash_Init+0x40/0x180 [system] pages=257 vmalloc 0xf0824000-0xf0926000 1056768 SESSION_KHash_Init+0x40/0x180 [system] pages=257 vmalloc 0xf0926000-0xf0a28000 1056768 SESSION_KHash_Init+0x40/0x180 [system] pages=257 vmalloc 0xf0a28000-0xf0b2a000 1056768 SESSION_KHash_Init+0x40/0x180 [system] pages=257 vmalloc 0xf0b2a000-0xf0c2c000 1056768 SESSION_KHash_Init+0x40/0x180 [system] pages=257 vmalloc 0xf0c2c000-0xf0d2e000 1056768 SESSION_KHash_Init+0x40/0x180 [system] pages=257 vmalloc 0xf0d2e000-0xf0d31000 12288 HASH_Large_Create+0x40/0xc0 [system] pages=2 vmalloc 0xf0d31000-0xf0d36000 20480 MCFS_CACHE_HashTableInit+0x58/0x160 [system] pages=4 vmalloc 0xf0d36000-0xf0d39000 12288 HASH_Large_Create+0x40/0xc0 [system] pages=2 vmalloc 0xf0d39000-0xf0d3e000 20480 MCFS_CACHE_HashTableInit+0x58/0x160 [system] pages=4 vmalloc 0xf0d3e000-0xf0d81000 274432 connlmt_KStat_HashTableInit+0x34/0x150 [system] pages=66 vmalloc 0xf1b52000-0xf334b000 25137152 module_alloc+0x3c/0x90 pages=6136 vmalloc ==============system memory stat =============== nr_free_pages 45783 nr_inactive 35502 nr_active 45495 nr_anon_pages 32592 nr_mapped 12288 nr_file_pages 48426 nr_dirty 0 nr_writeback 0 nr_slab_reclaimable 1610 nr_slab_unreclaimable 59949 nr_page_table_pages 715 nr_unstable 0 nr_bounce 0 nr_vmscan_write 0 nr_writeback_temp 0 ==============memory zone info =============== Node 0, zone Normal pages free 45783 min 991 low 1238 high 1486 scanned 0 (a: 0 i: 0) spanned 327680 present 245696 nr_free_pages 45783 nr_inactive 35502 nr_active 45495 nr_anon_pages 32592 nr_mapped 12288 nr_file_pages 48426 nr_dirty 0 nr_writeback 0 nr_slab_reclaimable 1610 nr_slab_unreclaimable 59949 nr_page_table_pages 715 nr_unstable 0 nr_bounce 0 nr_vmscan_write 0 nr_writeback_temp 0 protection: (0, 0, 0) pagesets cpu: 0 count: 45 high: 186 batch: 31 vm stats threshold: 32 cpu: 1 count: 90 high: 186 batch: 31 vm stats threshold: 32 cpu: 2 count: 141 high: 186 batch: 31 vm stats threshold: 32 cpu: 3 count: 36 high: 186 batch: 31 vm stats threshold: 32 cpu: 4 count: 43 high: 186 batch: 31 vm stats threshold: 32 cpu: 5 count: 35 high: 186 batch: 31 vm stats threshold: 32 cpu: 6 count: 43 high: 186 batch: 31 vm stats threshold: 32 cpu: 7 count: 163 high: 186 batch: 31 vm stats threshold: 32 all_unreclaimable: 0 prev_priority: 12 start_pfn: 0 ==============memory alert stat =============== Free memory threshold: Minor: 96M Severe: 64M Critical: 48M Normal: 128M Current memory state: Normal Event statistics: [Back to normal state] First notification: 0.0 Latest notification: 0.0 Total number of notifications sent: 0 [Enter minor low-memory state] First notification at: 0.0 Latest notification at: 0.0 Total number of notifications sent: 0 [Back to minor low-memory state] First notification at: 0.0 Latest notification at: 0.0 Total number of notifications sent: 0 [Enter severe low-memory state] First notification at: 0.0 Latest notification at: 0.0 Total number of notifications sent: 0 [Back to severe low-memory state] First notification at: 0.0 Latest notification at: 0.0 Total number of notifications sent: 0 [Enter critical low-memory state] First notification at: 0.0 Latest notification at: 0.0 Total number of notifications sent: 0 ===============io memory info =============== 00000000-0cffffff : System RAM 00100000-003a780f : Kernel code 003a7810-004dffff : Kernel data 10100000-101fffff : xhci_hcd 10200000-102fffff : xhci_hcd 10300000-103fffff : xhci_hcd 18030000-18030000 : serial8250.0 18031000-18031000 : serial8250.1 18038000-18038000 : nor-xlp.0 18039000-18039000 : nand-xlp.0 1803a000-1803afff : spi 1803a000-1803afff : spi-xlp 1803b000-1803b0ff : mmc_dev 1803b000-1803b000 : mmc-xlp.0 1803b100-1803b1ff : mmc_dev 1803b100-1803b1ff : mmc0 1803b200-1803b2ff : mmc_dev 20000000-4fffffff : System RAM d0000000-dfffffff : XLP PCI MEM ==============cpu info =============== system type : Netlogic XLP SoC processor : 0 cpu model : XLP208 Rev B0 FPU BogoMIPS : 454.65 wait instruction : yes microsecond timers : yes tlb_entries : 32 extra interrupt vector : yes count: 1, address/irw mask: [0x0fff] hardware watchpoint : yes ASEs implemented : shadow register sets : 1 core : 0 VCED exceptions : not available VCEI exceptions : not available processor : 1 cpu model : XLP208 Rev B0 FPU BogoMIPS : 474.11 wait instruction : yes microsecond timers : yes tlb_entries : 32 extra interrupt vector : yes count: 1, address/irw mask: [0x0fff] hardware watchpoint : yes ASEs implemented : shadow register sets : 1 core : 0 VCED exceptions : not available VCEI exceptions : not available processor : 2 cpu model : XLP208 Rev B0 FPU BogoMIPS : 577.53 wait instruction : yes microsecond timers : yes tlb_entries : 32 extra interrupt vector : yes count: 1, address/irw mask: [0x0fff] hardware watchpoint : yes ASEs implemented : shadow register sets : 1 core : 0 VCED exceptions : not available VCEI exceptions : not available processor : 3 cpu model : XLP208 Rev B0 FPU BogoMIPS : 817.15 wait instruction : yes microsecond timers : yes tlb_entries : 32 extra interrupt vector : yes count: 1, address/irw mask: [0x0fff] hardware watchpoint : yes ASEs implemented : shadow register sets : 1 core : 0 VCED exceptions : not available VCEI exceptions : not available processor : 4 cpu model : XLP208 Rev B0 FPU BogoMIPS : 452.60 wait instruction : yes microsecond timers : yes tlb_entries : 32 extra interrupt vector : yes count: 1, address/irw mask: [0x0fff] hardware watchpoint : yes ASEs implemented : shadow register sets : 1 core : 0 VCED exceptions : not available VCEI exceptions : not available processor : 5 cpu model : XLP208 Rev B0 FPU BogoMIPS : 474.11 wait instruction : yes microsecond timers : yes tlb_entries : 32 extra interrupt vector : yes count: 1, address/irw mask: [0x0fff] hardware watchpoint : yes ASEs implemented : shadow register sets : 1 core : 0 VCED exceptions : not available VCEI exceptions : not available processor : 6 cpu model : XLP208 Rev B0 FPU BogoMIPS : 563.20 wait instruction : yes microsecond timers : yes tlb_entries : 32 extra interrupt vector : yes count: 1, address/irw mask: [0x0fff] hardware watchpoint : yes ASEs implemented : shadow register sets : 1 core : 0 VCED exceptions : not available VCEI exceptions : not available processor : 7 cpu model : XLP208 Rev B0 FPU BogoMIPS : 819.20 wait instruction : yes microsecond timers : yes tlb_entries : 32 extra interrupt vector : yes count: 1, address/irw mask: [0x0fff] hardware watchpoint : yes ASEs implemented : shadow register sets : 1 core : 0 VCED exceptions : not available VCEI exceptions : not available ===============interrupt info =============== CPU0 CPU1 CPU2 CPU3 CPU4 CPU5 CPU6 CPU7 3: 0 0 0 0 0 0 0 0 Netlogic-RSVD-PIC nlm_common_rsvd_action 4: 0 0 0 0 0 0 0 0 Netlogic-RSVD-PIC nlm_common_rsvd_action 7: 4699824 4938378 5193424 3730675 3731025 3730992 3730982 3730949 XLP-PIC timer 17: 83 0 0 0 0 0 0 0 XLP-PIC serial 23: 0 0 0 0 0 0 0 0 XLP-PIC mmc0 24: 0 0 0 0 0 0 0 0 XLP-PIC 25: 0 0 0 0 0 0 0 0 XLP-PIC 26: 0 0 0 0 0 0 0 0 XLP-PIC 29: 0 0 0 0 0 0 0 0 Netlogic-RSVD-PIC nlm_common_rsvd_action ERR: 0 ==============queue info =============== kque_debug: 0 ontrail: ID name depth/cursize/max/drops (magic) 0: e8331d00 memalert 1024/0/0/0 (0x4b515545) 0: d35b2d00 load_server 100/0/0/0 (0x4b515545) 0: d35b2e00 load_cache 100/0/0/0 (0x4b515545) 0: d35b2f00 lipcevt 4096/0/4/0 (0x4b515545) 0: d35b3200 userlog_que 1024/0/1/0 (0x4b515545) 0: d35b3400 kifupdown 2/0/1/0 (0x4b515545) 0: d35b3600 Mini 128/0/0/0 (0x4b515545) 0: d35b3900 ipfs 100/0/1/0 (0x4b515545) 0: d35b3a00 ip6fs 100/0/0/0 (0x4b515545) 0: d35b3c00 FIBVNQ 1/0/0/0 (0x4b515545) 0: d35b3d00 FIBRVQ 1/0/1/0 (0x4b515545) 0: d35b3e00 FIBVRQ 1/0/1/4 (0x4b515545) 0: d35b3f00 ARP_TIMER 128/0/11/0 (0x4b515545) 0: d3da2000 ARP_SINGLEEVENT 1/0/1/0 (0x4b515545) 0: d3da2100 ARP_SEND 1024/0/0/0 (0x4b515545) 0: d3da2200 ARP_RULE 4096/0/0/0 (0x4b515545) 0: d3da2300 ARP_RBHASHNOTIFY 1/0/0/0 (0x4b515545) 0: d3da2500 ARP_DTC 2048/0/0/0 (0x4b515545) 0: d3da2600 ARP_RETHTIMER 1024/0/0/0 (0x4b515545) 0: d3da2700 ND_TIMER 1024/0/0/0 (0x4b515545) 0: d3da2800 ND_SINGLEEVENT 1/0/0/0 (0x4b515545) 0: d3da2900 ND_MACNOTIFYEVENT 1/0/0/0 (0x4b515545) 0: d3da2a00 ND_RULE 4096/0/0/0 (0x4b515545) 0: d3da2c00 WADJ_TIMER 1024/0/4/0 (0x4b515545) 0: d3da2d00 WADJ_ENTRY 1/0/1/7 (0x4b515545) 0: d3da2e00 WADJ6_TIMER 1024/0/0/0 (0x4b515545) 0: d3da2f00 WADJ6_ENTRY 1/0/0/0 (0x4b515545) 0: d3da3100 UDPH_PKT 1024/0/0/0 (0x4b515545) 0: d3da3200 UDPH_MULTI_PKT 1024/0/0/0 (0x4b515545) 0: d3da3300 UDPH_EVT 1/0/0/0 (0x4b515545) 0: d3da3400 UDPH_MULTI_EVT 1/0/0/0 (0x4b515545) 0: d3da3500 TP_THREAD_Queue 1/0/0/0 (0x4b515545) 0: d3da3600 TP_THREAD_Queue 1/0/0/0 (0x4b515545) 0: d3da3700 TP_THREAD_Queue 1/0/0/0 (0x4b515545) 0: d3da3800 TP_THREAD_Queue 1/0/0/0 (0x4b515545) 0: d3da3900 TP_THREAD_Queue 1/0/0/0 (0x4b515545) 0: d3da3a00 TP_THREAD_Queue 1/0/0/0 (0x4b515545) 0: c1886000 socket_evque 100/0/2/0 (0x4b515545) 0: c1886200 MAC_EVENT 4096/0/3/0 (0x4b515545) 0: c1886300 MAC_TIMER 128/0/2/0 (0x4b515545) 0: c1886400 MAC_ENTRYQV1N0 1/0/0/0 (0x4b515545) 0: c1886500 MAC_ENTRYQV1N1 1/0/0/0 (0x4b515545) 0: c1886600 MAC_ENTRYQV1N2 1/0/0/0 (0x4b515545) 0: c1886700 MAC_ENTRYQV1N3 1/0/1/0 (0x4b515545) 0: c1886800 MAC_ENTRYQV1N4 1/0/1/0 (0x4b515545) 0: c1886900 MAC_ENTRYQV1N5 1/0/1/0 (0x4b515545) 0: c1886a00 MAC_ENTRYQV1N6 1/0/1/0 (0x4b515545) 0: c1886b00 MAC_ENTRYQV1N7 1/0/1/0 (0x4b515545) 0: c1886c00 MAC_NOTIFY 1024/0/0/0 (0x4b515545) 0: c1886d00 MAC_NOTIFY_EVENT 4096/0/2/0 (0x4b515545) 0: c1f35300 KDRS PKT Queue 128/0/2/0 (0x4b515545) 0: c2286000 UFLT_KQUEUE1 100/0/1/0 (0x4b515545) 0: c1f35400 KDRS Session Queue 1024/0/198/0 (0x4b515545) 0: c1f35700 ARPSNP_PKT 4096/0/0/0 (0x4b515545) 0: c1f35800 ARP_EVENT 1024/0/3/0 (0x4b515545) 0: c1f35900 ARP_MACNOTIFYEVENT 1/0/1/0 (0x4b515545) 0: c1f35a00 ARP_PKT 4096/0/3/0 (0x4b515545) 0: c1f35b00 WADJ_EVENT 1024/0/0/0 (0x4b515545) 0: c1f35c00 FIBComQ 100/0/0/0 (0x4b515545) 0: c1f35d00 FIBTimerQ 100/0/1/0 (0x4b515545) 0: c1f35e00 FIBVNReDrvQ 1/0/0/0 (0x4b515545) 0: c1f35f00 FIBVNEcmpReDrvQ 1/0/0/0 (0x4b515545) 0: ec874000 FIBPrefixQ 1/0/1/0 (0x4b515545) 0: ec874100 FIBARPHRQ 1/0/1/0 (0x4b515545) 0: ec874200 FIBPreReDrvQ 1/0/0/0 (0x4b515545) 0: ec874300 FIB6PrefixQ 1/0/0/0 (0x4b515545) 0: ec874400 FIB6NDHRQ 1/0/0/0 (0x4b515545) 0: ec874500 FIB6PreReDrvQ 1/0/0/0 (0x4b515545) 0: ec874600 L3VPNReDrvQ 1/0/0/0 (0x4b515545) ===============mounts stat =============== rootfs / rootfs rw,noatime 0 0 /proc /proc proc rw 0 0 /sys /sys sysfs rw 0 0 /dev/pts /dev/pts devpts rw,mode=600 0 0 cgroup /dev/cgroup/cpu cgroup rw,cpu 0 0 cgroup /dev/cgroup/cpuset cgroup rw,cpuset 0 0 cgroup /dev/cgroup/memory cgroup rw,memory 0 0 /dev/mtdblock0 /mnt/flash: yaffs2 ecc-8bit rw,noexec,nodiratime,relatime 0 0 sockfsdev /proc/sockfs sockfs rw 0 0 /dev/loop0 /www/web/frame cramfs ro 0 0 /dev/loop1 /www/web/mgroup cramfs ro 0 0 /dev/loop2 /www/web/wsmbfile cramfs ro 0 0 /dev/loop3 /www/web/sslvpn cramfs ro 0 0 /dev/loop4 /www/web/lb cramfs ro 0 0 ===============timer list =============== Timer List Version: v0.3 HRTIMER_MAX_CLOCK_BASES: 2 now at 3727433274942 nsecs cpu: 0 clock 0: .index: 0 .resolution: 1 nsecs .get_time: ktime_get_real .offset: 1647653931763499323 nsecs active timers: clock 1: .index: 1 .resolution: 1 nsecs .get_time: ktime_get .offset: 0 nsecs active timers: #0: <c6467dc0>, tick_sched_timer, S:01 # expires at 3727434000000 nsecs [in 725058 nsecs] #1: <c6467dc0>, timerfd_tmrproc, S:01 # expires at 3727439778907 nsecs [in 6503965 nsecs] #2: <c6467dc0>, timerfd_tmrproc, S:01 # expires at 3727446448617 nsecs [in 13173675 nsecs] #3: <c6467dc0>, timerfd_tmrproc, S:01 # expires at 3727455906862 nsecs [in 22631920 nsecs] #4: <c6467dc0>, timerfd_tmrproc, S:01 # expires at 3727465654402 nsecs [in 32379460 nsecs] #5: <c6467dc0>, timerfd_tmrproc, S:01 # expires at 3727506342967 nsecs [in 73068025 nsecs] #6: <c6467dc0>, timerfd_tmrproc, S:01 # expires at 3727519528967 nsecs [in 86254025 nsecs] #7: <c6467dc0>, timerfd_tmrproc, S:01 # expires at 3727705302062 nsecs [in 272027120 nsecs] #8: <c6467dc0>, timerfd_tmrproc, S:01 # expires at 3727767301712 nsecs [in 334026770 nsecs] #9: <c6467dc0>, timerfd_tmrproc, S:01 # expires at 3727793262662 nsecs [in 359987720 nsecs] #10: <c6467dc0>, timerfd_tmrproc, S:01 # expires at 3727800277567 nsecs [in 367002625 nsecs] #11: <c6467dc0>, timerfd_tmrproc, S:01 # expires at 3727831280327 nsecs [in 398005385 nsecs] #12: <c6467dc0>, timerfd_tmrproc, S:01 # expires at 3727840237332 nsecs [in 406962390 nsecs] #13: <c6467dc0>, timerfd_tmrproc, S:01 # expires at 3727898319667 nsecs [in 465044725 nsecs] #14: <c6467dc0>, timerfd_tmrproc, S:01 # expires at 3727923791527 nsecs [in 490516585 nsecs] #15: <c6467dc0>, timerfd_tmrproc, S:01 # expires at 3728013581897 nsecs [in 580306955 nsecs] #16: <c6467dc0>, timerfd_tmrproc, S:01 # expires at 3728025488817 nsecs [in 592213875 nsecs] #17: <c6467dc0>, irqcheck_hrtimer_handler, S:01 # expires at 3728059753642 nsecs [in 626478700 nsecs] #18: <c6467dc0>, timerfd_tmrproc, S:01 # expires at 3728060247917 nsecs [in 626972975 nsecs] #19: <c6467dc0>, timerfd_tmrproc, S:01 # expires at 3728060285692 nsecs [in 627010750 nsecs] #20: <c6467dc0>, timerfd_tmrproc, S:01 # expires at 3728060325032 nsecs [in 627050090 nsecs] #21: <c6467dc0>, timerfd_tmrproc, S:01 # expires at 3728136389117 nsecs [in 703114175 nsecs] #22: <c6467dc0>, timerfd_tmrproc, S:01 # expires at 3728148048152 nsecs [in 714773210 nsecs] #23: <c6467dc0>, timerfd_tmrproc, S:01 # expires at 3728157698597 nsecs [in 724423655 nsecs] #24: <c6467dc0>, timerfd_tmrproc, S:01 # expires at 3728195985777 nsecs [in 762710835 nsecs] #25: <c6467dc0>, timerfd_tmrproc, S:01 # expires at 3728220871717 nsecs [in 787596775 nsecs] #26: <c6467dc0>, timerfd_tmrproc, S:01 # expires at 3728288018937 nsecs [in 854743995 nsecs] #27: <c6467dc0>, timerfd_tmrproc, S:01 # expires at 3728294899647 nsecs [in 861624705 nsecs] #28: <c6467dc0>, timerfd_tmrproc, S:01 # expires at 3728383505412 nsecs [in 950230470 nsecs] #29: <c6467dc0>, timerfd_tmrproc, S:01 # expires at 3728398800427 nsecs [in 965525485 nsecs] #30: <c6467dc0>, timerfd_tmrproc, S:01 # expires at 3728430618147 nsecs [in 997343205 nsecs] #31: <c6467dc0>, timerfd_tmrproc, S:01 # expires at 3729609963767 nsecs [in 2176688825 nsecs] #32: <c6467dc0>, timerfd_tmrproc, S:01 # expires at 86529963308087 nsecs [in 82802530033145 nsecs] #33: <c6467dc0>, timerfd_tmrproc, S:01 # expires at 86529980807067 nsecs [in 82802547532125 nsecs] .expires_next : 3727434000000 nsecs .hres_active : 1 .nr_events : 4699534 .nohz_mode : 0 .idle_tick : 0 nsecs .tick_stopped : 0 .idle_jiffies : 0 .idle_calls : 0 .idle_sleeps : 0 .idle_entrytime : 0 nsecs .idle_waketime : 0 nsecs .idle_exittime : 0 nsecs .idle_sleeptime : 0 nsecs .last_jiffies : 0 .next_jiffies : 0 .idle_expires : 0 nsecs jiffies: 3427433 cpu: 1 clock 0: .index: 0 .resolution: 1 nsecs .get_time: ktime_get_real .offset: 1647653931763499323 nsecs active timers: clock 1: .index: 1 .resolution: 1 nsecs .get_time: ktime_get .offset: 0 nsecs active timers: #0: <c6467dc0>, tick_sched_timer, S:01 # expires at 3727434062500 nsecs [in 787558 nsecs] #1: <c6467dc0>, timerfd_tmrproc, S:01 # expires at 3727435017782 nsecs [in 1742840 nsecs] #2: <c6467dc0>, timerfd_tmrproc, S:01 # expires at 3727437170852 nsecs [in 3895910 nsecs] #3: <c6467dc0>, timerfd_tmrproc, S:01 # expires at 3727437955177 nsecs [in 4680235 nsecs] #4: <c6467dc0>, timerfd_tmrproc, S:01 # expires at 3727444406202 nsecs [in 11131260 nsecs] #5: <c6467dc0>, timerfd_tmrproc, S:01 # expires at 3727461147737 nsecs [in 27872795 nsecs] #6: <c6467dc0>, hrtimer_wakeup, S:01 # expires at 3727466863327 nsecs [in 33588385 nsecs] #7: <c6467dc0>, timerfd_tmrproc, S:01 # expires at 3727469928547 nsecs [in 36653605 nsecs] #8: <c6467dc0>, timerfd_tmrproc, S:01 # expires at 3727472776222 nsecs [in 39501280 nsecs] #9: <c6467dc0>, timerfd_tmrproc, S:01 # expires at 3727475046447 nsecs [in 41771505 nsecs] #10: <c6467dc0>, timerfd_tmrproc, S:01 # expires at 3727511244977 nsecs [in 77970035 nsecs] #11: <c6467dc0>, timerfd_tmrproc, S:01 # expires at 3727520984617 nsecs [in 87709675 nsecs] #12: <c6467dc0>, timerfd_tmrproc, S:01 # expires at 3727572203437 nsecs [in 138928495 nsecs] #13: <c6467dc0>, timerfd_tmrproc, S:01 # expires at 3727598809137 nsecs [in 165534195 nsecs] #14: <c6467dc0>, timerfd_tmrproc, S:01 # expires at 3727666258812 nsecs [in 232983870 nsecs] #15: <c6467dc0>, timerfd_tmrproc, S:01 # expires at 3727844316277 nsecs [in 411041335 nsecs] #16: <c6467dc0>, timerfd_tmrproc, S:01 # expires at 3727958172142 nsecs [in 524897200 nsecs] #17: <c6467dc0>, irqcheck_hrtimer_handler, S:01 # expires at 3728059753587 nsecs [in 626478645 nsecs] #18: <c6467dc0>, timerfd_tmrproc, S:01 # expires at 3728060267522 nsecs [in 626992580 nsecs] #19: <c6467dc0>, timerfd_tmrproc, S:01 # expires at 3728060304232 nsecs [in 627029290 nsecs] #20: <c6467dc0>, timerfd_tmrproc, S:01 # expires at 3728060345882 nsecs [in 627070940 nsecs] #21: <c6467dc0>, timerfd_tmrproc, S:01 # expires at 3728084355027 nsecs [in 651080085 nsecs] #22: <c6467dc0>, timerfd_tmrproc, S:01 # expires at 3728176213772 nsecs [in 742938830 nsecs] #23: <c6467dc0>, timerfd_tmrproc, S:01 # expires at 3728239061367 nsecs [in 805786425 nsecs] #24: <c6467dc0>, timerfd_tmrproc, S:01 # expires at 3728246975347 nsecs [in 813700405 nsecs] #25: <c6467dc0>, timerfd_tmrproc, S:01 # expires at 3728303277657 nsecs [in 870002715 nsecs] #26: <c6467dc0>, timerfd_tmrproc, S:01 # expires at 3728328886087 nsecs [in 895611145 nsecs] #27: <c6467dc0>, timerfd_tmrproc, S:01 # expires at 3728344840367 nsecs [in 911565425 nsecs] #28: <c6467dc0>, timerfd_tmrproc, S:01 # expires at 3728348038032 nsecs [in 914763090 nsecs] #29: <c6467dc0>, timerfd_tmrproc, S:01 # expires at 3728352963767 nsecs [in 919688825 nsecs] #30: <c6467dc0>, timerfd_tmrproc, S:01 # expires at 3728388461172 nsecs [in 955186230 nsecs] #31: <c6467dc0>, timerfd_tmrproc, S:01 # expires at 3729610960122 nsecs [in 2177685180 nsecs] #32: <c6467dc0>, timerfd_tmrproc, S:01 # expires at 3729751131207 nsecs [in 2317856265 nsecs] #33: <c6467dc0>, timerfd_tmrproc, S:01 # expires at 3730614397007 nsecs [in 3181122065 nsecs] #34: <c6467dc0>, timerfd_tmrproc, S:01 # expires at 3731634203827 nsecs [in 4200928885 nsecs] #35: <c6467dc0>, timerfd_tmrproc, S:01 # expires at 3732352929867 nsecs [in 4919654925 nsecs] #36: <c6467dc0>, timerfd_tmrproc, S:01 # expires at 3735743728712 nsecs [in 8310453770 nsecs] #37: <c6467dc0>, timerfd_tmrproc, S:01 # expires at 86529443350922 nsecs [in 82802010075980 nsecs] .expires_next : 3727435017782 nsecs .hres_active : 1 .nr_events : 4938215 .nohz_mode : 0 .idle_tick : 0 nsecs .tick_stopped : 0 .idle_jiffies : 0 .idle_calls : 0 .idle_sleeps : 0 .idle_entrytime : 0 nsecs .idle_waketime : 0 nsecs .idle_exittime : 0 nsecs .idle_sleeptime : 0 nsecs .last_jiffies : 0 .next_jiffies : 0 .idle_expires : 0 nsecs jiffies: 3427434 cpu: 2 clock 0: .index: 0 .resolution: 1 nsecs .get_time: ktime_get_real .offset: 1647653931763499323 nsecs active timers: clock 1: .index: 1 .resolution: 1 nsecs .get_time: ktime_get .offset: 0 nsecs active timers: #0: <c6467dc0>, tick_sched_timer, S:01 # expires at 3727435125000 nsecs [in 1850058 nsecs] #1: <c6467dc0>, timerfd_tmrproc, S:01 # expires at 3727435987797 nsecs [in 2712855 nsecs] #2: <c6467dc0>, timerfd_tmrproc, S:01 # expires at 3727439764697 nsecs [in 6489755 nsecs] #3: <c6467dc0>, timerfd_tmrproc, S:01 # expires at 3727439951002 nsecs [in 6676060 nsecs] #4: <c6467dc0>, timerfd_tmrproc, S:01 # expires at 3727441040102 nsecs [in 7765160 nsecs] #5: <c6467dc0>, timerfd_tmrproc, S:01 # expires at 3727442005942 nsecs [in 8731000 nsecs] #6: <c6467dc0>, timerfd_tmrproc, S:01 # expires at 3727449929737 nsecs [in 16654795 nsecs] #7: <c6467dc0>, timerfd_tmrproc, S:01 # expires at 3727461264032 nsecs [in 27989090 nsecs] #8: <c6467dc0>, timerfd_tmrproc, S:01 # expires at 3727461329772 nsecs [in 28054830 nsecs] #9: <c6467dc0>, timerfd_tmrproc, S:01 # expires at 3727468214982 nsecs [in 34940040 nsecs] #10: <c6467dc0>, timerfd_tmrproc, S:01 # expires at 3727470971692 nsecs [in 37696750 nsecs] #11: <c6467dc0>, timerfd_tmrproc, S:01 # expires at 3727949704432 nsecs [in 516429490 nsecs] #12: <c6467dc0>, timerfd_tmrproc, S:01 # expires at 3728030668612 nsecs [in 597393670 nsecs] #13: <c6467dc0>, irqcheck_hrtimer_handler, S:01 # expires at 3728059753542 nsecs [in 626478600 nsecs] #14: <c6467dc0>, timerfd_tmrproc, S:01 # expires at 3728149281802 nsecs [in 716006860 nsecs] #15: <c6467dc0>, timerfd_tmrproc, S:01 # expires at 3784197936977 nsecs [in 56764662035 nsecs] #16: <c6467dc0>, timerfd_tmrproc, S:01 # expires at 3786496524837 nsecs [in 59063249895 nsecs] #17: <c6467dc0>, timerfd_tmrproc, S:01 # expires at 3827058562687 nsecs [in 99625287745 nsecs] #18: <c6467dc0>, timerfd_tmrproc, S:01 # expires at 86531220245412 nsecs [in 82803786970470 nsecs] #19: <c6467dc0>, timerfd_tmrproc, S:01 # expires at 86531224773727 nsecs [in 82803791498785 nsecs] .expires_next : 3727435125000 nsecs .hres_active : 1 .nr_events : 5193282 .nohz_mode : 0 .idle_tick : 0 nsecs .tick_stopped : 0 .idle_jiffies : 0 .idle_calls : 0 .idle_sleeps : 0 .idle_entrytime : 0 nsecs .idle_waketime : 0 nsecs .idle_exittime : 0 nsecs .idle_sleeptime : 0 nsecs .last_jiffies : 0 .next_jiffies : 0 .idle_expires : 0 nsecs jiffies: 3427434 cpu: 3 clock 0: .index: 0 .resolution: 1 nsecs .get_time: ktime_get_real .offset: 1647653931763499323 nsecs active timers: clock 1: .index: 1 .resolution: 1 nsecs .get_time: ktime_get .offset: 0 nsecs active timers: #0: <c6467dc0>, tick_sched_timer, S:01 # expires at 3727435187500 nsecs [in 1912558 nsecs] #1: <c6467dc0>, irqcheck_hrtimer_handler, S:01 # expires at 3728059753487 nsecs [in 626478545 nsecs] .expires_next : 3727435187500 nsecs .hres_active : 1 .nr_events : 3730551 .nohz_mode : 0 .idle_tick : 0 nsecs .tick_stopped : 0 .idle_jiffies : 0 .idle_calls : 0 .idle_sleeps : 0 .idle_entrytime : 0 nsecs .idle_waketime : 0 nsecs .idle_exittime : 0 nsecs .idle_sleeptime : 0 nsecs .last_jiffies : 0 .next_jiffies : 0 .idle_expires : 0 nsecs jiffies: 3427434 cpu: 4 clock 0: .index: 0 .resolution: 1 nsecs .get_time: ktime_get_real .offset: 1647653931763499323 nsecs active timers: clock 1: .index: 1 .resolution: 1 nsecs .get_time: ktime_get .offset: 0 nsecs active timers: #0: <c6467dc0>, tick_sched_timer, S:01 # expires at 3727435250000 nsecs [in 1975058 nsecs] #1: <c6467dc0>, irqcheck_hrtimer_handler, S:01 # expires at 3728059755457 nsecs [in 626480515 nsecs] .expires_next : 3727435250000 nsecs .hres_active : 1 .nr_events : 3730922 .nohz_mode : 0 .idle_tick : 0 nsecs .tick_stopped : 0 .idle_jiffies : 0 .idle_calls : 0 .idle_sleeps : 0 .idle_entrytime : 0 nsecs .idle_waketime : 0 nsecs .idle_exittime : 0 nsecs .idle_sleeptime : 0 nsecs .last_jiffies : 0 .next_jiffies : 0 .idle_expires : 0 nsecs jiffies: 3427434 cpu: 5 clock 0: .index: 0 .resolution: 1 nsecs .get_time: ktime_get_real .offset: 1647653931763499323 nsecs active timers: clock 1: .index: 1 .resolution: 1 nsecs .get_time: ktime_get .offset: 0 nsecs active timers: #0: <c6467dc0>, tick_sched_timer, S:01 # expires at 3727435312500 nsecs [in 2037558 nsecs] #1: <c6467dc0>, irqcheck_hrtimer_handler, S:01 # expires at 3728059755522 nsecs [in 626480580 nsecs] .expires_next : 3727435312500 nsecs .hres_active : 1 .nr_events : 3730908 .nohz_mode : 0 .idle_tick : 0 nsecs .tick_stopped : 0 .idle_jiffies : 0 .idle_calls : 0 .idle_sleeps : 0 .idle_entrytime : 0 nsecs .idle_waketime : 0 nsecs .idle_exittime : 0 nsecs .idle_sleeptime : 0 nsecs .last_jiffies : 0 .next_jiffies : 0 .idle_expires : 0 nsecs jiffies: 3427434 cpu: 6 clock 0: .index: 0 .resolution: 1 nsecs .get_time: ktime_get_real .offset: 1647653931763499323 nsecs active timers: clock 1: .index: 1 .resolution: 1 nsecs .get_time: ktime_get .offset: 0 nsecs active timers: #0: <c6467dc0>, tick_sched_timer, S:01 # expires at 3727435375000 nsecs [in 2100058 nsecs] #1: <c6467dc0>, irqcheck_hrtimer_handler, S:01 # expires at 3728059755577 nsecs [in 626480635 nsecs] .expires_next : 3727435375000 nsecs .hres_active : 1 .nr_events : 3730917 .nohz_mode : 0 .idle_tick : 0 nsecs .tick_stopped : 0 .idle_jiffies : 0 .idle_calls : 0 .idle_sleeps : 0 .idle_entrytime : 0 nsecs .idle_waketime : 0 nsecs .idle_exittime : 0 nsecs .idle_sleeptime : 0 nsecs .last_jiffies : 0 .next_jiffies : 0 .idle_expires : 0 nsecs jiffies: 3427435 cpu: 7 clock 0: .index: 0 .resolution: 1 nsecs .get_time: ktime_get_real .offset: 1647653931763499323 nsecs active timers: clock 1: .index: 1 .resolution: 1 nsecs .get_time: ktime_get .offset: 0 nsecs active timers: #0: <c6467dc0>, tick_sched_timer, S:01 # expires at 3727435437500 nsecs [in 2162558 nsecs] #1: <c6467dc0>, irqcheck_hrtimer_handler, S:01 # expires at 3728059759457 nsecs [in 626484515 nsecs] .expires_next : 3727435437500 nsecs .hres_active : 1 .nr_events : 3730908 .nohz_mode : 0 .idle_tick : 0 nsecs .tick_stopped : 0 .idle_jiffies : 0 .idle_calls : 0 .idle_sleeps : 0 .idle_entrytime : 0 nsecs .idle_waketime : 0 nsecs .idle_exittime : 0 nsecs .idle_sleeptime : 0 nsecs .last_jiffies : 0 .next_jiffies : 0 .idle_expires : 0 nsecs jiffies: 3427435 Tick Device: mode: 1 Clock Event Device: MIPS max_delta_ns: 2147483647 min_delta_ns: 1000 mult: 1073741824 shift: 30 mode: 3 next_event: 3727436000000 nsecs set_next_event: mips_next_event set_mode: mips_set_mode event_handler: hrtimer_interrupt Tick Device: mode: 1 Clock Event Device: MIPS max_delta_ns: 2147483647 min_delta_ns: 1000 mult: 1073741824 shift: 30 mode: 3 next_event: 3727436062500 nsecs set_next_event: mips_next_event set_mode: mips_set_mode event_handler: hrtimer_interrupt Tick Device: mode: 1 Clock Event Device: MIPS max_delta_ns: 2147483647 min_delta_ns: 1000 mult: 1073741824 shift: 30 mode: 3 next_event: 3727435987797 nsecs set_next_event: mips_next_event set_mode: mips_set_mode event_handler: hrtimer_interrupt Tick Device: mode: 1 Clock Event Device: MIPS max_delta_ns: 2147483647 min_delta_ns: 1000 mult: 1073741824 shift: 30 mode: 3 next_event: 3727436187500 nsecs set_next_event: mips_next_event set_mode: mips_set_mode event_handler: hrtimer_interrupt Tick Device: mode: 1 Clock Event Device: MIPS max_delta_ns: 2147483647 min_delta_ns: 1000 mult: 1073741824 shift: 30 mode: 3 next_event: 3727436250000 nsecs set_next_event: mips_next_event set_mode: mips_set_mode event_handler: hrtimer_interrupt Tick Device: mode: 1 Clock Event Device: MIPS max_delta_ns: 2147483647 min_delta_ns: 1000 mult: 1073741824 shift: 30 mode: 3 next_event: 3727435312500 nsecs set_next_event: mips_next_event set_mode: mips_set_mode event_handler: hrtimer_interrupt Tick Device: mode: 1 Clock Event Device: MIPS max_delta_ns: 2147483647 min_delta_ns: 1000 mult: 1073741824 shift: 30 mode: 3 next_event: 3727435375000 nsecs set_next_event: mips_next_event set_mode: mips_set_mode event_handler: hrtimer_interrupt Tick Device: mode: 1 Clock Event Device: MIPS max_delta_ns: 2147483647 min_delta_ns: 1000 mult: 1073741824 shift: 30 mode: 3 next_event: 3727435437500 nsecs set_next_event: mips_next_event set_mode: mips_set_mode event_handler: hrtimer_interrupt ===============display wlan ap all=============== Total number of APs: 31 Total number of connected APs: 30 Total number of connected manual APs: 30 Total number of connected auto APs: 0 Total number of connected common APs: 30 Total number of connected WTUs: 0 Total number of inside APs: 0 Maximum supported APs: 80 Remaining APs: 50 Total AP licenses: 40 Remaining AP licenses: 17.50 Sync AP licenses: 0 AP information State : I = Idle, J = Join, JA = JoinAck, IL = ImageLoad C = Config, DC = DataCheck, R = Run, M = Master, B = Backup AP name APID State Model Serial ID 00be-d5b3-9800 26 R/M WAP712H 219801A1B69206Q0030B 00be-d5b3-9880 23 R/M WAP712H 219801A1B69206Q0030G 00be-d5b3-98c0 17 R/M WAP712H 219801A1B69206Q0030J 00be-d5b3-9920 19 R/M WAP712H 219801A1B69206Q0030M 00be-d5b3-9ae0 30 R/M WAP712H 219801A1B69206Q00312 00be-d5b3-a1a0 20 R/M WAP712H 219801A1B69206Q0032T 00be-d5b3-a480 22 R/M WAP712H 219801A1B69206Q0033K 00be-d5b3-a4a0 28 R/M WAP712H 219801A1B69206Q0033L 00be-d5b3-a640 25 R/M WAP712H 219801A1B69206Q00340 00be-d5b3-ab80 24 R/M WAP712H 219801A1B69206Q0035C 00be-d5b3-ad40 29 R/M WAP712H 219801A1B69206Q0035T 00be-d5b3-af40 27 R/M WAP712H 219801A1B69206Q0036B 00be-d5b4-0000 21 R/M WAP712H 219801A1B69206Q003W5 00be-d5b4-0220 16 R/M WAP712H 219801A1B69206Q003WQ 00be-d5b4-03c0 18 R/M WAP712H 219801A1B69206Q003X4 943b-b051-1740 14 R/M WAP712C-LI 219801A1Y78206P000GM 943b-b051-1750 10 R/M WAP712C-LI 219801A1Y78206P000GN 943b-b051-18b0 9 I WAP712C-LI 219801A1Y78206P000HC 943b-b051-2320 31 R/M WAP712C-LI 219801A1Y78206P000NR 943b-b051-2370 15 R/M WAP712C-LI 219801A1Y78206P000NX 943b-b051-2420 2 R/M WAP712C-LI 219801A1Y78206P000P8 943b-b051-2520 1 R/M WAP712C-LI 219801A1Y78206P000PS 943b-b051-5330 13 R/M WAP712C-LI 219801A1Y78206P001GK 943b-b051-67f0 7 R/M WAP712C-LI 219801A1Y78206P001T8 943b-b051-c490 8 R/M WAP712C-LI 219801A1Y78206P003C2 943b-b051-ca80 4 R/M WAP712C-LI 219801A1Y78206P003G4 943b-b051-ce20 5 R/M WAP712C-LI 219801A1Y78206P003J0 943b-b051-d200 6 R/M WAP712C-LI 219801A1Y78206P003L0 943b-b051-d340 3 R/M WAP712C-LI 219801A1Y78206P003LN 943b-b051-e670 12 R/M WAP712C-LI 219801A1Y78206P003XK 943b-b052-1190 11 R/M WAP712C-LI 219801A1Y78206P004MT ============================================================= ===============display wlan ap connection record all=============== AP name IP address State Time 00be-d5b3-a640 10.12.1.2 Run 03-19 10:10:57 00be-d5b3-9800 10.12.1.2 Run 03-19 09:45:12 943b-b051-e670 10.12.1.2 Run 03-19 09:44:44 00be-d5b3-a480 10.12.1.2 Run 03-19 09:44:42 00be-d5b4-0000 10.12.1.2 Run 03-19 09:44:40 943b-b051-2320 10.12.1.2 Run 03-19 09:44:34 00be-d5b3-ab80 10.12.1.2 Run 03-19 09:44:31 00be-d5b3-a1a0 10.12.1.2 Run 03-19 09:44:28 00be-d5b4-0220 10.12.1.2 Run 03-19 09:44:27 00be-d5b3-a4a0 10.12.1.2 Run 03-19 09:44:22 00be-d5b3-98c0 10.12.1.2 Run 03-19 09:44:18 00be-d5b3-9920 10.12.1.2 Run 03-19 09:44:15 943b-b051-1740 10.12.1.2 Run 03-19 09:43:59 943b-b052-1190 10.12.1.2 Run 03-19 09:43:59 00be-d5b3-9ae0 10.12.1.2 Run 03-19 09:43:58 943b-b051-ca80 10.12.1.2 Run 03-19 09:43:57 943b-b051-2420 10.12.1.2 Run 03-19 09:43:56 00be-d5b3-ad40 10.12.1.2 Run 03-19 09:43:49 943b-b051-d340 10.12.1.2 Run 03-19 09:43:48 943b-b051-1750 10.12.1.2 Run 03-19 09:43:45 00be-d5b3-9880 10.12.1.2 Run 03-19 09:43:42 943b-b051-ce20 10.12.1.2 Run 03-19 09:43:39 943b-b051-2370 10.12.1.2 Run 03-19 09:43:38 00be-d5b4-03c0 10.12.1.2 Run 03-19 09:43:32 943b-b051-d200 10.12.1.2 Run 03-19 09:43:28 943b-b051-5330 10.12.1.2 Run 03-19 09:43:26 943b-b051-2520 10.12.1.2 Run 03-19 09:43:23 943b-b051-67f0 10.12.1.2 Run 03-19 09:43:23 943b-b051-c490 10.12.1.2 Run 03-19 09:43:18 00be-d5b3-af40 10.12.1.2 Run 03-19 09:43:10 ============================================================= ===============display wlan ap statistics online-record=============== Time Manual AP Auto AP Total Total delta 2022-03-19/10:40:05 30 0 30 0 2022-03-19/10:39:05 30 0 30 0 2022-03-19/10:38:05 30 0 30 0 2022-03-19/10:37:05 30 0 30 0 2022-03-19/10:36:05 30 0 30 0 2022-03-19/10:35:05 30 0 30 0 2022-03-19/10:34:05 30 0 30 0 2022-03-19/10:33:05 30 0 30 0 2022-03-19/10:32:05 30 0 30 0 2022-03-19/10:31:05 30 0 30 0 2022-03-19/10:30:05 30 0 30 0 2022-03-19/10:29:05 30 0 30 0 2022-03-19/10:28:05 30 0 30 0 2022-03-19/10:27:05 30 0 30 0 2022-03-19/10:26:05 30 0 30 0 2022-03-19/10:25:05 30 0 30 0 2022-03-19/10:24:05 30 0 30 0 2022-03-19/10:23:05 30 0 30 0 2022-03-19/10:22:05 30 0 30 0 2022-03-19/10:21:05 30 0 30 0 2022-03-19/10:20:05 30 0 30 0 2022-03-19/10:19:05 30 0 30 0 2022-03-19/10:18:05 30 0 30 0 2022-03-19/10:17:05 30 0 30 0 2022-03-19/10:16:05 30 0 30 0 2022-03-19/10:15:05 30 0 30 0 2022-03-19/10:14:05 30 0 30 0 2022-03-19/10:13:05 30 0 30 0 2022-03-19/10:12:05 30 0 30 0 2022-03-19/10:11:05 30 0 30 0 2022-03-19/10:10:05 30 0 30 0 2022-03-19/10:09:05 30 0 30 0 2022-03-19/10:08:05 30 0 30 0 2022-03-19/10:07:05 30 0 30 0 2022-03-19/10:06:05 30 0 30 0 2022-03-19/10:05:05 30 0 30 0 2022-03-19/10:04:05 30 0 30 0 2022-03-19/10:03:05 30 0 30 0 2022-03-19/10:02:05 30 0 30 0 2022-03-19/10:01:05 30 0 30 0 2022-03-19/10:00:05 30 0 30 0 2022-03-19/09:59:05 30 0 30 0 2022-03-19/09:58:05 30 0 30 0 2022-03-19/09:57:05 30 0 30 0 2022-03-19/09:56:05 30 0 30 0 2022-03-19/09:55:05 30 0 30 0 2022-03-19/09:54:05 30 0 30 0 2022-03-19/09:53:05 30 0 30 0 2022-03-19/09:52:05 30 0 30 0 2022-03-19/09:51:05 30 0 30 0 2022-03-19/09:50:05 30 0 30 0 2022-03-19/09:49:05 30 0 30 0 2022-03-19/09:48:05 30 0 30 0 2022-03-19/09:47:05 30 0 30 0 2022-03-19/09:46:05 30 0 30 1 2022-03-19/09:45:05 29 0 29 10 2022-03-19/09:44:05 19 0 19 19 2022-03-19/09:43:05 0 0 0 0 2022-03-19/09:42:05 0 0 0 0 ============================================================= ===============display wlan ap statistics association-failure-record=============== ============================================================= ===============display wlan ap statistics tunnel-down-record=============== AP name AP ID Tunnel down at Tunnel Down Reason 00be-d5b3-a640 25 03-19/10:10:09 Failed to retransmit messa ge ============================================================= ===============display wlan ap all radio=============== Total number of APs: 31 Total number of connected APs: 30 Total number of connected manual APs: 30 Total number of connected auto APs: 0 Total number of connected common APs: 30 Total number of connected WTUs: 0 Total number of inside APs: 0 Maximum supported APs: 80 Remaining APs: 50 Total AP licenses: 40 Remaining AP licenses: 17.50 Sync AP licenses: 0 AP name RID State Channel Usage TxPower Clients (%) (dBm) 00be-d5b3-9800 1 Up 52(auto) 1 16 0 00be-d5b3-9800 2 Up 11(auto) 28 19 0 00be-d5b3-9880 1 Up 52(auto) 0 16 0 00be-d5b3-9880 2 Up 11(auto) 14 19 1 00be-d5b3-98c0 1 Up 149(auto) 2 16 0 00be-d5b3-98c0 2 Up 1(auto) 47 13 3 00be-d5b3-9920 1 Up 52(auto) 0 19 0 00be-d5b3-9920 2 Up 6(auto) 39 19 0 00be-d5b3-9ae0 1 Up 52(auto) 0 16 0 00be-d5b3-9ae0 2 Up 1(auto) 28 13 0 00be-d5b3-a1a0 1 Up 149(auto) 1 16 0 00be-d5b3-a1a0 2 Up 11(auto) 35 16 0 00be-d5b3-a480 1 Up 36(auto) 2 16 0 00be-d5b3-a480 2 Up 11(auto) 27 19 0 00be-d5b3-a4a0 1 Up 149(auto) 2 16 1 00be-d5b3-a4a0 2 Up 1(auto) 20 16 1 00be-d5b3-a640 1 Up 149(auto) 2 16 0 00be-d5b3-a640 2 Up 11(auto) 25 19 1 00be-d5b3-ab80 1 Up 149(auto) 2 13 0 00be-d5b3-ab80 2 Up 1(auto) 23 16 0 00be-d5b3-ad40 1 Up 149(auto) 3 16 0 00be-d5b3-ad40 2 Up 11(auto) 19 16 0 00be-d5b3-af40 1 Up 36(auto) 0 13 1 00be-d5b3-af40 2 Up 6(auto) 67 13 0 00be-d5b4-0000 1 Up 149(auto) 3 16 1 00be-d5b4-0000 2 Up 6(auto) 19 19 0 00be-d5b4-0220 1 Up 36(auto) 0 16 1 00be-d5b4-0220 2 Up 1(auto) 19 13 1 00be-d5b4-03c0 1 Up 149(auto) 3 13 0 00be-d5b4-03c0 2 Up 6(auto) 44 13 0 943b-b051-1740 1 Up 36(auto) 2 20 0 943b-b051-1740 2 Up 11(auto) 27 14 0 943b-b051-1750 1 Up 52(auto) 1 17 0 943b-b051-1750 2 Up 11(auto) 35 14 4 943b-b051-18b0 1 Down 52(auto) 0 20 0 943b-b051-18b0 2 Down 1(auto) 0 20 0 943b-b051-2320 1 Up 52(auto) 1 17 1 943b-b051-2320 2 Up 6(auto) 63 20 6 943b-b051-2370 1 Up 149(auto) 0 20 3 943b-b051-2370 2 Up 11(auto) 29 14 1 943b-b051-2420 1 Up 36(auto) 1 20 1 943b-b051-2420 2 Up 11(auto) 16 17 0 943b-b051-2520 1 Up 36(auto) 14 17 5 943b-b051-2520 2 Up 6(auto) 71 20 9 943b-b051-5330 1 Up 52(auto) 1 20 0 943b-b051-5330 2 Up 11(auto) 47 14 1 943b-b051-67f0 1 Up 36(auto) 2 17 7 943b-b051-67f0 2 Up 6(auto) 59 20 2 943b-b051-c490 1 Up 36(auto) 4 17 1 943b-b051-c490 2 Up 11(auto) 36 14 3 943b-b051-ca80 1 Up 36(auto) 1 20 0 943b-b051-ca80 2 Up 11(auto) 36 20 0 943b-b051-ce20 1 Up 52(auto) 1 17 0 943b-b051-ce20 2 Up 11(auto) 27 17 1 943b-b051-d200 1 Up 52(auto) 1 20 0 943b-b051-d200 2 Up 6(auto) 56 20 2 943b-b051-d340 1 Up 149(auto) 0 20 1 943b-b051-d340 2 Up 1(auto) 37 20 0 943b-b051-e670 1 Up 36(auto) 7 17 0 943b-b051-e670 2 Up 1(auto) 25 20 1 943b-b052-1190 1 Up 36(auto) 1 20 0 943b-b052-1190 2 Up 11(auto) 27 14 1 ============================================================ ===============display wlan client=============== Total number of clients: 61 MAC address User name AP name R IP address VLAN 040e-3c62-b098 N/A 943b-b051-c490 2 172.16.100.147 100 066c-f126-3549 N/A 943b-b051-2520 2 172.16.100.62 100 0c93-8ff9-adc1 N/A 00be-d5b3-98c0 2 172.16.100.51 100 1413-3331-d0df N/A 943b-b051-2520 2 172.16.100.150 100 147d-dae1-63c6 N/A 943b-b051-67f0 1 172.16.100.17 100 14c6-975f-979b N/A 943b-b051-2520 2 172.16.100.27 100 1649-0bcf-31d3 N/A 943b-b051-67f0 1 172.16.100.7 100 2202-ef6c-7671 N/A 943b-b051-c490 2 172.16.100.25 100 226e-9c98-ddd6 N/A 00be-d5b3-af40 1 172.16.100.6 100 2276-84ee-7d89 N/A 943b-b051-2520 1 172.16.100.48 100 22f3-9308-089e N/A 00be-d5b4-0000 1 172.16.100.46 100 2406-aa0c-f05d N/A 943b-b051-67f0 1 172.16.100.18 100 2479-f380-d6eb N/A 943b-b051-2370 1 172.16.100.33 100 2cd9-74d2-2bc0 N/A 943b-b052-1190 2 172.16.100.22 100 2e98-0262-94b2 N/A 943b-b051-c490 1 172.16.100.23 100 304f-00a2-98c5 N/A 943b-b051-67f0 1 172.16.100.19 100 32c9-c109-1a7b N/A 943b-b051-5330 2 172.16.100.58 100 3e31-2537-8aa1 N/A 943b-b051-2520 2 172.16.100.8 100 4466-fc9d-3327 N/A 00be-d5b4-0220 2 172.16.100.31 100 4cea-ae1a-0353 N/A 943b-b051-2370 1 172.16.100.29 100 4cea-aee6-fe13 N/A 943b-b051-e670 2 172.16.100.14 100 5492-0972-18e0 N/A 943b-b051-2520 2 172.16.100.52 100 6007-c4d7-7367 N/A 943b-b051-1750 2 172.16.100.24 100 62e8-5d8a-c8de N/A 943b-b051-2320 2 172.16.100.34 100 66da-d947-0e6d N/A 943b-b051-2320 2 172.16.100.63 100 68a0-3e0f-a8a4 N/A 00be-d5b4-0220 1 172.16.100.45 100 6c5c-14b7-4055 N/A 943b-b051-67f0 1 172.16.100.10 100 708f-4765-505d N/A 00be-d5b3-98c0 2 172.16.100.56 100 725b-1b4a-f4f1 N/A 00be-d5b3-98c0 2 172.16.100.30 100 72b3-52e2-9393 N/A 943b-b051-2520 2 172.16.100.67 100 72ed-14da-d135 N/A 943b-b051-67f0 1 172.16.100.13 100 7836-ccf3-41fb N/A 00be-d5b3-a640 2 172.16.100.41 100 7a06-25d1-854a N/A 943b-b051-2420 1 172.16.100.43 100 7a74-0c97-8223 N/A 943b-b051-2320 1 172.16.100.50 100 8c7a-3dab-4c72 N/A 00be-d5b3-9880 2 172.16.100.15 100 a235-5b13-eaa5 N/A 943b-b051-d200 2 172.16.100.49 100 a2bc-542d-ce83 N/A 943b-b051-2520 1 172.16.100.36 100 a6e1-a489-f9e2 N/A 943b-b051-2520 2 172.16.100.5 100 a87d-12af-357d N/A 943b-b051-2520 1 172.16.100.12 100 a8a7-95cb-1439 N/A 943b-b051-2520 2 172.16.100.140 100 aeed-b09d-3fb6 N/A 943b-b051-2520 1 172.16.100.9 100 b222-7f42-90fa N/A 943b-b051-1750 2 172.16.100.47 100 b29d-c47f-bb20 N/A 943b-b051-2320 2 172.16.100.55 100 b4cb-5702-c08b N/A 943b-b051-1750 2 172.16.100.53 100 c0a5-ddd2-6cc7 N/A 943b-b051-67f0 2 172.16.100.138 100 c205-f70b-cadf N/A 943b-b051-d200 2 172.16.100.66 100 c267-ceb0-2645 N/A 943b-b051-c490 2 172.16.100.60 100 c2ce-556e-1088 N/A 943b-b051-2320 2 172.16.100.42 100 cc81-2ab4-c711 N/A 943b-b051-ce20 2 172.16.100.11 100 d097-fe2a-fe78 N/A 00be-d5b3-a4a0 1 172.16.100.57 100 d231-74b5-401f N/A 943b-b051-2520 2 172.16.100.2 100 d460-75ef-9f18 N/A 00be-d5b3-a4a0 2 172.16.100.4 100 d613-ad03-015e N/A 943b-b051-2320 2 172.16.100.59 100 e0cc-f8a4-a87f N/A 943b-b051-67f0 1 172.16.100.26 100 e0e0-fc27-eb31 N/A 943b-b051-2320 2 172.16.100.20 100 e213-84c1-5bb9 N/A 943b-b051-d340 1 172.16.100.38 100 e216-32f1-a6b3 N/A 943b-b051-2520 1 172.16.100.54 100 eab4-fbe9-7fbb N/A 943b-b051-2370 2 172.16.100.44 100 f257-eb51-edca N/A 943b-b051-2370 1 172.16.100.16 100 f8d0-277e-1375 N/A 943b-b051-67f0 2 172.16.100.116 100 fcfc-482e-e15f N/A 943b-b051-1750 2 172.16.100.37 100 ============================================================= ===============display wlan mobility group=============== ============================================================= ===============display portal packet statistics=============== Extend-auth server : qq Pkt-Type Success Error Timeout Conn-failure REQ_ACCESSTOKEN 0 0 0 0 REQ_OPENID 0 0 0 0 REQ_USERINFO 0 0 0 0 RESP_ACCESSTOKEN 0 0 0 0 RESP_OPNEID 0 0 0 0 RESP_USERINFO 0 0 0 0 AUTHENTICATION 0 0 0 0 Extend-auth server : mail Pkt-Type Success Error Timeout Conn-failure Deny REQ_POP3 0 0 0 0 0 REQ_IMAP 0 0 0 0 0 AUTHENTICATION 0 0 0 0 0 Extend-auth server : cloud Update interval : 60 Pkt-Type Success Error Timeout Conn-failure REQ_ACCESSTOKEN 0 0 0 0 REQ_USERINFO 0 0 0 0 RESP_ACCESSTOKEN 0 0 0 0 RESP_USERINFO 0 0 0 0 POST_ONLINEDATA 0 0 0 0 RESP_ONLINEDATA 0 0 0 0 POST_OFFLINEUSER 0 0 0 0 REPORT_ONLINEUSER 0 0 0 0 REQ_CLOUDBIND 0 0 0 0 RESP_CLOUDBIND 0 0 0 0 REQ_BINDUSERINFO 0 0 0 0 RESP_BINDUSERINFO 0 0 0 0 AUTHENTICATION 0 0 0 0 Extend-auth server : wechat Pkt-Type Success Error Timeout Conn-failure REQ_ACCESSTOKEN 0 0 0 0 REQ_USERINFO 0 0 0 0 RESP_ACCESSTOKEN 0 0 0 0 RESP_USERINFO 0 0 0 0 POST_OFFLINEUSER 0 0 0 0 REPORT_ONLINEUSER 0 0 0 0 AUTHENTICATION 0 0 0 0 ============================================================= ===============display portal redirect group=============== Slot 1: HttpReq : 0 HttpResp : 0 HttpsReq : 0 HttpsResp : 0 ============================================================= ===============display portal safe-redirect group=============== Slot 1: Redirect statistics: Success: 0 Failure: 0 Total : 0 Method statistics: Get : 0 Post : 0 Others : 0 Useragent statistics: Forbidden URL statistics: Forbidden filename extension statistics: ============================================================= ===============display udp statistics=============== Received packets: Total: 173055 checksum error: 0, no checksum: 95280 shorter than header: 0, data length larger than packet: 0 no socket on port(unicast): 55374 no socket on port(broadcast/multicast): 11281 not delivered, input socket full: 0 Sent packets: Total: 70618 ============================================================= ===============display tcp statistics=============== Received packets: Total: 667326 packets in sequence: 4884 (752987 bytes) window probe packets: 0, window update packets: 28 checksum error: 0, offset error: 0, short error: 0 packets dropped for lack of memory: 0 packets dropped due to PAWS: 4 duplicate packets: 89 (777 bytes), partially duplicate packets: 0 (0 bytes) out-of-order packets: 0 (0 bytes) packets with data after window: 0 (0 bytes) packets after close: 2 ACK packets: 8197 (8215068 bytes) duplicate ACK packets: 415, ACK packets for unsent data: 0 Sent packets: Total: 655991 urgent packets: 0 control packets: 149 window probe packets: 0, window update packets: 84 data packets: 11235 (8215050 bytes), data packets retransmitted: 48 (1104 bytes) ACK-only packets: 644475 (0 delayed) unnecessary packet retransmissions: 2 Syncache/synCOOKIE related statistics: entries added to syncache: 1571 syncache entries retransmitted: 171 duplicate SYN packets: 637757 reply failures: 2 successfully build new socket: 225 bucket overflows: 0 zone failures: 0 syncache entries removed due to RST: 1312 syncache entries removed due to timed out: 29 ACK checked by syncache or synCOOKIE failures: 5 syncache entries aborted: 0 syncache entries removed due to bad ACK: 0 syncache entries removed due to ICMP unreachable: 1 SYN COOKIEs sent: 0 SYN COOKIEs received: 0 SACK related statistics: SACK recoveries: 0 SACK retransmitted segments: 0 (0 bytes) SACK blocks (options) received: 20 SACK blocks (options) sent: 0 SACK scoreboard overflows: 0 Other statistics: retransmitted timeout: 437, connections dropped in retransmitted timeout: 23 persist timeout: 0 keepalive timeout: 0, keepalive probe: 0 keepalive timeout, so connections disconnected: 0 fin_wait_2 timeout, so connections disconnected: 0 initiated connections: 0, accepted connections: 225, established connections: 225 closed connections: 115 (dropped: 44, initiated dropped: 0) bad connection attempt: 0 ignored RSTs in the window: 279 listen queue overflows: 0 RTT updates: 7614(attempt segment: 7452) correct ACK header predictions: 10 correct data packet header predictions: 1133 resends due to MTU discovery: 0 packets dropped with MD5 authentication: 0 packets permitted with MD5 authentication: 0 ============================================================= ===============display ip statistics=============== Input: sum 16556960 local 842445 bad protocol 1076 bad format 8163 bad checksum 0 bad options 0 dropped 5 Output: forwarding 15647286 local 743546 dropped 12378 no route 61 compress fails 0 Fragment:input 75 output 36 dropped 0 fragmented 18 couldn"t fragment 0 Reassembling:sum 31 timeouts 0 ============================================================= ===============display mac-forwarding statistics=============== Input: Sum: 20063835 Unknown Unicast: 394 Broadcast: 46148 Multicast: 87061 Filtered: 0 STP discarded: 0 Service dropped: 2 Source dropped: 0 Unknown dropped: 59 Learning dropped: 0 Blackhole dropped: 0 Suppress dropped: 0 Source MAC dropped:0 Deliver: Sum: 8701555 L2 protocol: 90619 Local MAC address: 8564788 Output: Sum: 19414441 Filtered: 0 Blackhole dropped: 0 STP discarded: 0 Service dropped: 0 Dest MAC dropped: 3 ============================================================= ===============display dhcp server statistics=============== Pool number: 2 Pool utilization: 5.32% Bindings: Automatic: 68 Manual: 0 Expired: 3 Conflict: 2 Messages received: 861 DHCPDISCOVER: 210 DHCPREQUEST: 631 DHCPDECLINE: 3 DHCPRELEASE: 0 DHCPINFORM: 17 BOOTPREQUEST: 0 Messages sent: 448 DHCPOFFER: 148 DHCPACK: 276 DHCPNAK: 24 BOOTPREPLY: 0 Bad Messages: 0 ============================================================= ===============display dhcp client verbose=============== ============================================================= ===============display cloud state=============== Cloud connection state : Unconnected Device state : Idle Cloud server address : N/A Cloud server domain name : oasis.h3c.com Local port : 443 Connected at : N/A Duration : 00d 00h 00m 00s Process state : N/A Failure reason : DNS parse failed Last down reason : N/A Last down at : N/A Last report failure reason : N/A Last report failure at : N/A Dropped packets after reaching buffer limit : 0 Total dropped packets : 0 Last report incomplete reason : N/A Last report incomplete at : N/A Buffer full count : 0 ============================================================= ===============display cmtunnel state=============== Cloud management tunnel is not configured. ============================================================= ===============display system internal wlan ap incorrect-radio-status=============== ============================================================= ===============display system internal wlan adapter-asyncinfo all=============== ThreadID: Pid: session node: seqmap node: 0 0 1 0 0 1951319328 0 0 ============================================================= ===============display system internal wlan ap-count per-thread=============== The total number of threads :1 thread APNums 0 31 ============================================================= ===============display system internal wlan command-cache=============== ============================================================= ===============display system internal wlan mobility statistics=============== DB add pre roam count :102 DB delete pre roam count :41 DB update pre roam bssid count :500 DB update pre roam roam sta count :618 Rgrls received delete pre roam count :41 IAC received delete pre roam count :0 Topo delete preroam no exists pre roam count :0 Topo delete pre roam of sta event count :41 Topo DPR of sta event no need count :0 Topo delete pre roam of sta event NOK count :0 Topo delete pre roam of fail vlan count :0 Topo delete pre roam of fail vlan NOK count :0 Rgrls received reset single pre roam count :0 Rgrls received reset all pre roam count :0 Rgrls received add pre roam count :102 IAC received add pre roam count :0 Topo no need update pre roam count :0 Topo update pre roam count :0 Topo update modify pre roam count :0 Topo update readd pre roam count :0 Topo add new pre roam count :102 Topo add pre roam count :102 Topo add pre roam NOK count :0 Rgrls received RR count :516 IAC received RR count :0 Hand off RR no exists PR count :0 Hand off RR HA roam count :516 Hand off RR HA roam RR count :16 Hand off RR HA roam V count :0 Hand off RR HA roam MOR count :500 Hand off RR HA NOK mem lack count :0 Hand off RR HA NOK net down count :0 Hand off RR HA NOK pre roam lack count :0 Hand off RR HA NOK select policy count :0 Hand off RR HA NOK vlan add count :0 Hand off RR FA roam count :0 Hand off RR FA NOK mem lack count :0 Hand off RR FA NOK net down count :0 Hand off RR FA NOK pre roam lack count :0 Hand off RR FA NOK select policy count :0 Hand off RR FA NOK vlan add count :0 Rgrls received roam log off count :73 Topo log off no exists pre roam count :0 Topo roam log off count :18 Topo roam log off NOK count :55 Rgrls received roam left count :484 IAC received roam left count :0 Hand off roam left no exists pre roam count :0 Hand off HA roam left count :58 Hand off HA roam left NOK count :426 Hand off FA roam left count :0 Hand off FA roam left NAK count :0 Rgrls received roam log on count :0 Rgrls received MOR count :500 Rgrls received MOR LR not exists count :0 Rgrls received MOR PR not exists count :0 Rgrls received MOR RR not need :0 Rgrls received MOR LR not match count :0 Rgrls received MOR NOK LR not exists count :0 Rgrls received MOR NOK LR not match count :0 Rgrls received MOR NOK BSSID not match count :0 Rgrls received MOR NOK count :0 Mcmas received roam log on count :0 IAC leave DPR HA count :0 IAC leave DPR FA count :0 IAC leave DPR MC count :0 IAC leave DPR Total count :0 Horizontal syn DPR count :0 Horizontal syn DPR not ready count :0 Horizontal syn DPR NOK count :0 DB IAC send add count :0 DB IAC send del count :0 DB IAC send free count :0 IAC send cache count :0 IAC send NOK count :0 IAC Rcv SR PR Not Exists count :0 DB share node add count :389 DB share node del count :357 DB AC node add count :0 DB AC node del count :0 DB IAC node add count :0 DB IAC node del count :0 RG RCV MORP TO count :0 RG RCV MORP TO del GPR count :0 Global search req timeout count :0 Global roam req timeoou count :0 Iac send search resp nack count :0 Rgrls send search resp nack count :0 Send search resp fail count :0 Rgrls recv roam req handoff fail count :0 Rgrls send roam resp fail count :0 Rgrls recv move in req handoff fail count :0 Rgrls send move in resp fail count :0 Rgrls send move out req fail count :0 Rgrls recv move out resp data handoff fail :0 Rgrls recv move out resp nack handoff fail :0 Rgrls recv MOResp to del pr for no sta :0 Rgrls recv SReq preroam not exist count :105 Iac recv RResp preroam not exist count :0 Rglrs reply move in resp preroam not exist count :0 Wroam globalReq add :500 Wroam globalReq del :500 Wroam globalReqAdd sendMoveOutReq :0 Wroam globalReqAdd roamReqForeign :0 Wroam globalReqAdd sendMoveOutReqHome :500 Wroam globalReqAdd creatSrchReqNode :0 Wroam globalReqDel moveOutReqTmOutCallBack :0 Wroam globalReqDel recvMoveOutRespData :500 Wroam GlobalReqDel recvMoveOutRespFailed :0 Wroam globalReqDel roamReqTmOutCallBack :0 Wroam globalReqDel roamReqForeign :0 Wroam globalReqDel moveOutReqTmrOutCallBack :0 Wroam globalReqDel getReqNodeACID :0 Wroam globalReqDel globalReqAdd :0 Wroam globalReqDel searchRespData :0 Wroam globalReqDel searchRespNack :0 Wroam globalReqDel timeOutCallBack :0 Rgrls recv Private data FA invalid count :0 Rgrls Recv Count :1894 Rgrls Send Count :1235 Rgrls Send NOK Count :0 Rgrls recv Src Req Csount :178 Rgrls Recv MIR Count :0 Rgrls recv Pri Data Count :0 Rgrls Recv Update Preroam Count :0 Rgrls Recv Ap Up Count :0 Rgrls recv Ap Down Count :0 Rgrls Recv MCMA Count :0 Rgrls Send Add Preroam Count :0 Rgrls Send Add Preroam NOK Count :0 Rgrls Send Del Preroam Count :41 Rgrls Send Del Preroam NOK Count :0 Rgrls Send Kick Sta Count :0 Rgrls Send Kick Sta NOK Count :0 Rgrls Send MIR Count :0 Rgrls Send MIR NOK Count :0 Rgrls Send MIR Fail Count :0 Rgrls Send MIR Fail NOK Count :0 Rgrls Send MOR Count :500 Rgrls Send MOR NOK Count :0 Rgrls Send Pri Data Count :0 Rgrls Send Pri Data NOK Count :0 Rgrls Send RL Count :0 Rgrls Send RL NOK Count :0 Rgrls Send RR Count :516 Rgrls Send RR NOK Count :0 Rgrls Send SR Count :73 Rgrls Send RR NOK Count :0 Rgrls Send SR Fail Count :105 Rgrls Send SR Fail NOK Count :0 Rgrls Send Update Preroam Count :0 Rgrls Send Update Preroam NOK Count :0 ============================================================= ===============display system internal wlan mobility summary=============== Wroam Intra Ac Count :516 Wroam Inter Ac Count :0 Wroam Roam Out Count :0 Wroam Searching Count :0 Wroam Slow Count :0 Wroam Fast Count :0 Wroam Roam Authing Count :0 Wroam Roam Failed Count :0 Wroam Intra Ac Slow Count :505 Wroam Inter Ac Slow Count :0 Wroam Intra Ac Fast Count :0 Wroam Inter Ac Fast Count :0 Wroam Intra Ma Slow Count :0 Wroam Inter Ma Slow Count :0 Wroam Intra Ma Fast Count :0 Wroam Inter Ma Fast Count :0 Wroam Roam Back Slow Count :0 Wroam Roam Back Fast Count :0 Wroam Intra Bssid Fast Count :0 Wroam Intra Bssid Slow Count :11 Wroam Rsn 1x Slow Count :0 ============================================================= ===============display system internal wlan history wlanid all=============== AP name: 00be-d5b3-9800 AP ID : 26 Radio ID: 1 Alloc Success Count: 1 Free Success Count: 0 Alloc Failed Count: 0 Free Failed Count: 0 Record 1: STAMGR Alloc WlanID 1 SUCCESS time: Sat Mar 19 09:41:07 2022 Radio ID: 2 Alloc Success Count: 1 Free Success Count: 0 Alloc Failed Count: 0 Free Failed Count: 0 Record 1: STAMGR Alloc WlanID 1 SUCCESS time: Sat Mar 19 09:41:07 2022 AP name: 00be-d5b3-9880 AP ID : 23 Radio ID: 1 Alloc Success Count: 1 Free Success Count: 0 Alloc Failed Count: 0 Free Failed Count: 0 Record 1: STAMGR Alloc WlanID 1 SUCCESS time: Sat Mar 19 09:41:07 2022 Radio ID: 2 Alloc Success Count: 1 Free Success Count: 0 Alloc Failed Count: 0 Free Failed Count: 0 Record 1: STAMGR Alloc WlanID 1 SUCCESS time: Sat Mar 19 09:41:07 2022 AP name: 00be-d5b3-98c0 AP ID : 17 Radio ID: 1 Alloc Success Count: 1 Free Success Count: 0 Alloc Failed Count: 0 Free Failed Count: 0 Record 1: STAMGR Alloc WlanID 1 SUCCESS time: Sat Mar 19 09:41:07 2022 Radio ID: 2 Alloc Success Count: 1 Free Success Count: 0 Alloc Failed Count: 0 Free Failed Count: 0 Record 1: STAMGR Alloc WlanID 1 SUCCESS time: Sat Mar 19 09:41:07 2022 AP name: 00be-d5b3-9920 AP ID : 19 Radio ID: 1 Alloc Success Count: 1 Free Success Count: 0 Alloc Failed Count: 0 Free Failed Count: 0 Record 1: STAMGR Alloc WlanID 1 SUCCESS time: Sat Mar 19 09:41:07 2022 Radio ID: 2 Alloc Success Count: 1 Free Success Count: 0 Alloc Failed Count: 0 Free Failed Count: 0 Record 1: STAMGR Alloc WlanID 1 SUCCESS time: Sat Mar 19 09:41:07 2022 AP name: 00be-d5b3-9ae0 AP ID : 30 Radio ID: 1 Alloc Success Count: 1 Free Success Count: 0 Alloc Failed Count: 0 Free Failed Count: 0 Record 1: STAMGR Alloc WlanID 1 SUCCESS time: Sat Mar 19 09:41:07 2022 Radio ID: 2 Alloc Success Count: 1 Free Success Count: 0 Alloc Failed Count: 0 Free Failed Count: 0 Record 1: STAMGR Alloc WlanID 1 SUCCESS time: Sat Mar 19 09:41:07 2022 AP name: 00be-d5b3-a1a0 AP ID : 20 Radio ID: 1 Alloc Success Count: 1 Free Success Count: 0 Alloc Failed Count: 0 Free Failed Count: 0 Record 1: STAMGR Alloc WlanID 1 SUCCESS time: Sat Mar 19 09:41:07 2022 Radio ID: 2 Alloc Success Count: 1 Free Success Count: 0 Alloc Failed Count: 0 Free Failed Count: 0 Record 1: STAMGR Alloc WlanID 1 SUCCESS time: Sat Mar 19 09:41:07 2022 AP name: 00be-d5b3-a480 AP ID : 22 Radio ID: 1 Alloc Success Count: 1 Free Success Count: 0 Alloc Failed Count: 0 Free Failed Count: 0 Record 1: STAMGR Alloc WlanID 1 SUCCESS time: Sat Mar 19 09:41:07 2022 Radio ID: 2 Alloc Success Count: 1 Free Success Count: 0 Alloc Failed Count: 0 Free Failed Count: 0 Record 1: STAMGR Alloc WlanID 1 SUCCESS time: Sat Mar 19 09:41:07 2022 AP name: 00be-d5b3-a4a0 AP ID : 28 Radio ID: 1 Alloc Success Count: 1 Free Success Count: 0 Alloc Failed Count: 0 Free Failed Count: 0 Record 1: STAMGR Alloc WlanID 1 SUCCESS time: Sat Mar 19 09:41:07 2022 Radio ID: 2 Alloc Success Count: 1 Free Success Count: 0 Alloc Failed Count: 0 Free Failed Count: 0 Record 1: STAMGR Alloc WlanID 1 SUCCESS time: Sat Mar 19 09:41:07 2022 AP name: 00be-d5b3-a640 AP ID : 25 Radio ID: 1 Alloc Success Count: 1 Free Success Count: 0 Alloc Failed Count: 0 Free Failed Count: 0 Record 1: STAMGR Alloc WlanID 1 SUCCESS time: Sat Mar 19 09:41:07 2022 Radio ID: 2 Alloc Success Count: 1 Free Success Count: 0 Alloc Failed Count: 0 Free Failed Count: 0 Record 1: STAMGR Alloc WlanID 1 SUCCESS time: Sat Mar 19 09:41:07 2022 AP name: 00be-d5b3-ab80 AP ID : 24 Radio ID: 1 Alloc Success Count: 1 Free Success Count: 0 Alloc Failed Count: 0 Free Failed Count: 0 Record 1: STAMGR Alloc WlanID 1 SUCCESS time: Sat Mar 19 09:41:07 2022 Radio ID: 2 Alloc Success Count: 1 Free Success Count: 0 Alloc Failed Count: 0 Free Failed Count: 0 Record 1: STAMGR Alloc WlanID 1 SUCCESS time: Sat Mar 19 09:41:07 2022 AP name: 00be-d5b3-ad40 AP ID : 29 Radio ID: 1 Alloc Success Count: 1 Free Success Count: 0 Alloc Failed Count: 0 Free Failed Count: 0 Record 1: STAMGR Alloc WlanID 1 SUCCESS time: Sat Mar 19 09:41:07 2022 Radio ID: 2 Alloc Success Count: 1 Free Success Count: 0 Alloc Failed Count: 0 Free Failed Count: 0 Record 1: STAMGR Alloc WlanID 1 SUCCESS time: Sat Mar 19 09:41:07 2022 AP name: 00be-d5b3-af40 AP ID : 27 Radio ID: 1 Alloc Success Count: 1 Free Success Count: 0 Alloc Failed Count: 0 Free Failed Count: 0 Record 1: STAMGR Alloc WlanID 1 SUCCESS time: Sat Mar 19 09:41:07 2022 Radio ID: 2 Alloc Success Count: 1 Free Success Count: 0 Alloc Failed Count: 0 Free Failed Count: 0 Record 1: STAMGR Alloc WlanID 1 SUCCESS time: Sat Mar 19 09:41:07 2022 AP name: 00be-d5b4-0000 AP ID : 21 Radio ID: 1 Alloc Success Count: 1 Free Success Count: 0 Alloc Failed Count: 0 Free Failed Count: 0 Record 1: STAMGR Alloc WlanID 1 SUCCESS time: Sat Mar 19 09:41:07 2022 Radio ID: 2 Alloc Success Count: 1 Free Success Count: 0 Alloc Failed Count: 0 Free Failed Count: 0 Record 1: STAMGR Alloc WlanID 1 SUCCESS time: Sat Mar 19 09:41:07 2022 AP name: 00be-d5b4-0220 AP ID : 16 Radio ID: 1 Alloc Success Count: 1 Free Success Count: 0 Alloc Failed Count: 0 Free Failed Count: 0 Record 1: STAMGR Alloc WlanID 1 SUCCESS time: Sat Mar 19 09:41:07 2022 Radio ID: 2 Alloc Success Count: 1 Free Success Count: 0 Alloc Failed Count: 0 Free Failed Count: 0 Record 1: STAMGR Alloc WlanID 1 SUCCESS time: Sat Mar 19 09:41:07 2022 AP name: 00be-d5b4-03c0 AP ID : 18 Radio ID: 1 Alloc Success Count: 1 Free Success Count: 0 Alloc Failed Count: 0 Free Failed Count: 0 Record 1: STAMGR Alloc WlanID 1 SUCCESS time: Sat Mar 19 09:41:07 2022 Radio ID: 2 Alloc Success Count: 1 Free Success Count: 0 Alloc Failed Count: 0 Free Failed Count: 0 Record 1: STAMGR Alloc WlanID 1 SUCCESS time: Sat Mar 19 09:41:07 2022 AP name: 943b-b051-1740 AP ID : 14 Radio ID: 1 Alloc Success Count: 1 Free Success Count: 0 Alloc Failed Count: 0 Free Failed Count: 0 Record 1: STAMGR Alloc WlanID 1 SUCCESS time: Sat Mar 19 09:41:07 2022 Radio ID: 2 Alloc Success Count: 1 Free Success Count: 0 Alloc Failed Count: 0 Free Failed Count: 0 Record 1: STAMGR Alloc WlanID 1 SUCCESS time: Sat Mar 19 09:41:07 2022 AP name: 943b-b051-1750 AP ID : 10 Radio ID: 1 Alloc Success Count: 1 Free Success Count: 0 Alloc Failed Count: 0 Free Failed Count: 0 Record 1: STAMGR Alloc WlanID 1 SUCCESS time: Sat Mar 19 09:41:07 2022 Radio ID: 2 Alloc Success Count: 1 Free Success Count: 0 Alloc Failed Count: 0 Free Failed Count: 0 Record 1: STAMGR Alloc WlanID 1 SUCCESS time: Sat Mar 19 09:41:07 2022 AP name: 943b-b051-18b0 AP ID : 9 Radio ID: 1 Alloc Success Count: 1 Free Success Count: 0 Alloc Failed Count: 0 Free Failed Count: 0 Record 1: STAMGR Alloc WlanID 1 SUCCESS time: Sat Mar 19 09:41:07 2022 Radio ID: 2 Alloc Success Count: 1 Free Success Count: 0 Alloc Failed Count: 0 Free Failed Count: 0 Record 1: STAMGR Alloc WlanID 1 SUCCESS time: Sat Mar 19 09:41:07 2022 AP name: 943b-b051-2320 AP ID : 31 Radio ID: 1 Alloc Success Count: 1 Free Success Count: 0 Alloc Failed Count: 0 Free Failed Count: 0 Record 1: STAMGR Alloc WlanID 1 SUCCESS time: Sat Mar 19 09:41:07 2022 Radio ID: 2 Alloc Success Count: 1 Free Success Count: 0 Alloc Failed Count: 0 Free Failed Count: 0 Record 1: STAMGR Alloc WlanID 1 SUCCESS time: Sat Mar 19 09:41:07 2022 AP name: 943b-b051-2370 AP ID : 15 Radio ID: 1 Alloc Success Count: 1 Free Success Count: 0 Alloc Failed Count: 0 Free Failed Count: 0 Record 1: STAMGR Alloc WlanID 1 SUCCESS time: Sat Mar 19 09:41:07 2022 Radio ID: 2 Alloc Success Count: 1 Free Success Count: 0 Alloc Failed Count: 0 Free Failed Count: 0 Record 1: STAMGR Alloc WlanID 1 SUCCESS time: Sat Mar 19 09:41:07 2022 AP name: 943b-b051-2420 AP ID : 2 Radio ID: 1 Alloc Success Count: 1 Free Success Count: 0 Alloc Failed Count: 0 Free Failed Count: 0 Record 1: STAMGR Alloc WlanID 1 SUCCESS time: Sat Mar 19 09:41:07 2022 Radio ID: 2 Alloc Success Count: 1 Free Success Count: 0 Alloc Failed Count: 0 Free Failed Count: 0 Record 1: STAMGR Alloc WlanID 1 SUCCESS time: Sat Mar 19 09:41:07 2022 AP name: 943b-b051-2520 AP ID : 1 Radio ID: 1 Alloc Success Count: 1 Free Success Count: 0 Alloc Failed Count: 0 Free Failed Count: 0 Record 1: STAMGR Alloc WlanID 1 SUCCESS time: Sat Mar 19 09:41:07 2022 Radio ID: 2 Alloc Success Count: 1 Free Success Count: 0 Alloc Failed Count: 0 Free Failed Count: 0 Record 1: STAMGR Alloc WlanID 1 SUCCESS time: Sat Mar 19 09:41:07 2022 AP name: 943b-b051-5330 AP ID : 13 Radio ID: 1 Alloc Success Count: 1 Free Success Count: 0 Alloc Failed Count: 0 Free Failed Count: 0 Record 1: STAMGR Alloc WlanID 1 SUCCESS time: Sat Mar 19 09:41:07 2022 Radio ID: 2 Alloc Success Count: 1 Free Success Count: 0 Alloc Failed Count: 0 Free Failed Count: 0 Record 1: STAMGR Alloc WlanID 1 SUCCESS time: Sat Mar 19 09:41:07 2022 AP name: 943b-b051-67f0 AP ID : 7 Radio ID: 1 Alloc Success Count: 1 Free Success Count: 0 Alloc Failed Count: 0 Free Failed Count: 0 Record 1: STAMGR Alloc WlanID 1 SUCCESS time: Sat Mar 19 09:41:07 2022 Radio ID: 2 Alloc Success Count: 1 Free Success Count: 0 Alloc Failed Count: 0 Free Failed Count: 0 Record 1: STAMGR Alloc WlanID 1 SUCCESS time: Sat Mar 19 09:41:07 2022 AP name: 943b-b051-c490 AP ID : 8 Radio ID: 1 Alloc Success Count: 1 Free Success Count: 0 Alloc Failed Count: 0 Free Failed Count: 0 Record 1: STAMGR Alloc WlanID 1 SUCCESS time: Sat Mar 19 09:41:07 2022 Radio ID: 2 Alloc Success Count: 1 Free Success Count: 0 Alloc Failed Count: 0 Free Failed Count: 0 Record 1: STAMGR Alloc WlanID 1 SUCCESS time: Sat Mar 19 09:41:07 2022 AP name: 943b-b051-ca80 AP ID : 4 Radio ID: 1 Alloc Success Count: 1 Free Success Count: 0 Alloc Failed Count: 0 Free Failed Count: 0 Record 1: STAMGR Alloc WlanID 1 SUCCESS time: Sat Mar 19 09:41:07 2022 Radio ID: 2 Alloc Success Count: 1 Free Success Count: 0 Alloc Failed Count: 0 Free Failed Count: 0 Record 1: STAMGR Alloc WlanID 1 SUCCESS time: Sat Mar 19 09:41:07 2022 AP name: 943b-b051-ce20 AP ID : 5 Radio ID: 1 Alloc Success Count: 1 Free Success Count: 0 Alloc Failed Count: 0 Free Failed Count: 0 Record 1: STAMGR Alloc WlanID 1 SUCCESS time: Sat Mar 19 09:41:07 2022 Radio ID: 2 Alloc Success Count: 1 Free Success Count: 0 Alloc Failed Count: 0 Free Failed Count: 0 Record 1: STAMGR Alloc WlanID 1 SUCCESS time: Sat Mar 19 09:41:07 2022 AP name: 943b-b051-d200 AP ID : 6 Radio ID: 1 Alloc Success Count: 1 Free Success Count: 0 Alloc Failed Count: 0 Free Failed Count: 0 Record 1: STAMGR Alloc WlanID 1 SUCCESS time: Sat Mar 19 09:41:07 2022 Radio ID: 2 Alloc Success Count: 1 Free Success Count: 0 Alloc Failed Count: 0 Free Failed Count: 0 Record 1: STAMGR Alloc WlanID 1 SUCCESS time: Sat Mar 19 09:41:07 2022 AP name: 943b-b051-d340 AP ID : 3 Radio ID: 1 Alloc Success Count: 1 Free Success Count: 0 Alloc Failed Count: 0 Free Failed Count: 0 Record 1: STAMGR Alloc WlanID 1 SUCCESS time: Sat Mar 19 09:41:07 2022 Radio ID: 2 Alloc Success Count: 1 Free Success Count: 0 Alloc Failed Count: 0 Free Failed Count: 0 Record 1: STAMGR Alloc WlanID 1 SUCCESS time: Sat Mar 19 09:41:07 2022 AP name: 943b-b051-e670 AP ID : 12 Radio ID: 1 Alloc Success Count: 1 Free Success Count: 0 Alloc Failed Count: 0 Free Failed Count: 0 Record 1: STAMGR Alloc WlanID 1 SUCCESS time: Sat Mar 19 09:41:07 2022 Radio ID: 2 Alloc Success Count: 1 Free Success Count: 0 Alloc Failed Count: 0 Free Failed Count: 0 Record 1: STAMGR Alloc WlanID 1 SUCCESS time: Sat Mar 19 09:41:07 2022 AP name: 943b-b052-1190 AP ID : 11 Radio ID: 1 Alloc Success Count: 1 Free Success Count: 0 Alloc Failed Count: 0 Free Failed Count: 0 Record 1: STAMGR Alloc WlanID 1 SUCCESS time: Sat Mar 19 09:41:07 2022 Radio ID: 2 Alloc Success Count: 1 Free Success Count: 0 Alloc Failed Count: 0 Free Failed Count: 0 Record 1: STAMGR Alloc WlanID 1 SUCCESS time: Sat Mar 19 09:41:07 2022 ============================================================= ===============display system internal wlan client thread statistics trigger main=============== APMGR Msg Count : 100797 APMGR Init Link Fail Cnt : 0 APMGR Init Reconnect Cnt : 0 APMGR Init Relink Cnt : 0 APMGR Add Epoll Fail Cnt : 0 APMGR Init Reconnect Fail Cnt : 0 APMGR Fini Link Cnt : 0 Mesh Client Rcv Msg Count : 0 Mesh Client Notify Msg Connect Msg Count : 0 Mesh Client Notify Msg Disconnect Msg Count : 0 Static Vlan Create Msg Count : 1 Dynamic Vlan Create Msg Count : 0 Static Vlan Destroy Msg Count : 0 IF Event Proc Bss If Msg Count : 62 IF Event Delete Client MAC Address on IF Count : 0 IF Slot Fast Remove Delete Client MAC Address on IF Count: 0 Mlpu Msg Count : 0 Mlpu Port Up : 0 Mlpu port Down : 0 Mlpu Port Up Fail : 0 Vlan Group Destroy Msg Count : 0 Vlan Group Add Vlan Msg Count : 0 Vlan Group Delete Vlan Msg Count : 0 Vlan port Up : 1 Vlan port Down : 0 Vlan Port Up Fail : 0 Usrpf Proc Connect Event Msg Count : 0 Usrpf port Up : 0 Usrpf Port Down : 0 Usrpf Port Up Fail : 0 Ofc Connect Msg Count : 62 Ofc PacketIn Msg Count : 0 Ofc Begin Smooth Msg Count : 62 Ofc FlowResult Msg Count : 0 Ofc Port Up : 1 Ofc Port Down : 0 Acl Port Up Event Msg Count : 1 Acl Proc Event Pack Msg Count : 0 Acl Port Up : 1 Acl Port Down : 0 Acl Port Up Fail : 0 Byod Connect Msg Count : 1 Byod Port Up : 1 Byod Port Down : 0 If Msg Down : 2 Main-Thrd Snd ApmgrLib Msg Cnt : 100779 Srv-Thrd Rcv ApmgrLib Msg Cnt : 100779 ============================================================= ===============display system internal wlan client process statistics=============== Apmgr IOCTL Down Fail Count : 0 Apmgr Link Up End Of Ioctl Count : 3192 Apmgr IOCTL UP Fail Count : 0 Bss Create Count : 62 Bss Delete Count : 2 Bss Smooth Delete Count : 0 Bss Roll Back Count : 0 Bss Roll Back Exist Sta Count : 0 Bss Delete Without Sta Count : 2 Bss Finish Count : 2 IF Create Count In Srv Thrd : 62 IF Save Count In Srv Thrd : 62 IF Roll Back Count In Srv Thrd : 0 IF Alloc Name ID Succeed Count : 62 IF Alloc Name ID Failed Count : 0 IF Dealloc Name ID Count : 2 IF Create Record Exist Count : 0 IF Create Record Conflict Count : 0 IF Create Record Add Count : 62 IF Create Record Del Count : 62 Get IF Create Record Conflict Count : 0 Get IF Create Record Conflict AP Down Count : 0 IF Roll Back Success Count In Work Thrd : 0 IF Create Msg In Work Thrd : 62 IF Delete Msg In Work Thrd : 0 IF Batch Delete Msg In Work Thrd : 1 IF Create Success In Work Thrd : 62 IF Create Failed In Work Thrd : 0 IF Create no resource In Work Thrd : 0 IF Delete Success In Work Thrd : 0 IF Delete Failed In Work Thrd : 0 IF Batch Delete Success In Work Thrd : 2 IF Batch Delete Failed In Work Thrd : 0 IF Count Of Ap Delete : 0 Without APCB Of Ap Down Call Back : 0 IF Delete Count Of Ap Delete : 0 Not Support Mgr Pkt Count : 0 Batch Create Bss IF Count : 0 Batch Create Bss IF 4 one Succeed Count : 0 Batch Create Bss IF 4 one Failed Count : 0 Batch Create Bss IF Get Node From List Count : 0 Smooth Create Bss Link Down Count : 0 Create Bss Link-Down Succeed Count : 62 Create Bss Link-Down Failed Count : 0 Create Bss Link-Down Respond Count : 62 Create Bss Receive Link-Down Message Count : 0 Create Bss Send Link-Down Resp Succeed Count : 0 Create Bss Send Link-Down Resp Failed Count : 0 Delete Bss AP down Link-Down Count : 2 Delete Bss Link-Down Succeed Count : 2 Delete Bss Link-Down Failed Count : 0 Delete Bss Link-Down Respond Count : 2 Delete Bss Receive Link-Down Message Count : 0 Delete Bss Send Link-Down Resp Succeed Count : 0 Delete Bss Send Link-Down Resp Failed Count : 0 Update Bss Link-Down Succeed Count : 203 Update Bss Link-Down Failed Count : 0 Update Bss Link-Down Respond Count : 203 Update Bss Receive Link-Down Message Count : 0 Update Bss Send Link-Down Resp Succeed Count : 0 Update Bss Send Link-Down Resp Failed Count : 0 Client Deactive Notify Srv Succeed Count : 5013 Client Deactive Notify Srv Failed Count : 0 Client Delete Notify Srv Succeed Count : 7128 Client Delete Notify Srv Failed Count : 0 Create Client Link-Down Succeed Count : 1926 Create Client Link-Down Failed Count : 0 Create Client Link-Down Respond Count : 1926 Create Client Receive Link-Down Message Count : 0 Create Client Send Link-Down Resp Succeed Count : 0 Create Client Send Link-Down Resp Failed Count : 0 Delete Client Link-Down Succeed Count : 631 Delete Client Link-Down Failed Count : 0 Delete Client Link-Down Respond Count : 631 Delete Client Receive Link-Down Message Count : 0 Delete Client Send Link-Down Resp Succeed Count : 0 Delete Client Send Link-Down Resp Failed Count : 0 Create Client Link-Up Succeed Count : 0 Create Client Link-Up Failed Count : 1926 Create Client Link-Up Respond Count : 0 Create Client Receive Link-Up Message Count : 0 Create Client Send Link-Up Resp Succeed Count : 0 Create Client Send Link-Up Resp Failed Count : 0 Delete Client Link-Up Succeed Count : 0 Delete Client Link-Up Failed Count : 631 Delete Client Link-Up Respond Count : 0 Delete Client Receive Link-Up Message Count : 0 Delete Client Send Link-Up Resp Succeed Count : 0 Delete Client Send Link-Up Resp Failed Count : 0 Client Kick Repeat Count : 0 Client Det after TE Count : 19 Client Kick Normal TE Count : 0 Client Deactive Convert Notify Count : 0 Client Deactive Convert Count : 0 Client Delete Convert Notify Count : 0 Client Delete Convert Count : 0 Client Add CallBack with Delete Timer : 0 Client Add CallBack with Deleting : 0 Wroam Client Active Count : 102 Wroam Client Active NOK Count : 0 Wroam Client Reactive : 0 Wroam Client Reactive NOK : 0 Wroam Client Delete Succeed Count : 41 Wroam Client Delete No Match Count : 22 Wroam Client Delete LPR No Match Count : 531 Wroam Client Smooth Delete Send Succeed Count : 0 Wroam Client Smooth Delete Send Failed Count : 0 Wroam Rgrlc Send Count : 1894 Wroam Rgrlc Send NOK Count : 0 Wroam Rgrlc Send Add Preroam Count : 102 Wroam Rgrlc Send Add Preroam NOK Count : 0 Wroam Rgrlc Send Del Preroam Count : 41 Wroam Rgrlc Send Del Preroam NOK Count : 0 Wroam Rgrlc Send RR Count : 516 Wroam Rgrlc Send RR NOK Count : 0 Wroam Rgrlc Send SR Count : 178 Wroam Rgrlc Send SR NOK Count : 0 Wroam Rgrlc Send Sta logon Count : 0 Wroam Rgrlc Send Sta Logon NOK Count : 0 Wroam Rgrlc Send Sta Logoff Count : 73 Wroam Rgrlc Send Sta Logoff NOK Count : 0 Wroam Rgrlc Send RL Count : 484 Wroam Rgrlc Send RL NOK Count : 0 Wroam Rgrlc Send MOR Data Count : 500 Wroam Rgrlc Send MOR Data NOK Count : 0 Wroam Rgrlc Send MOR Fail Count : 0 Wroam Rgrlc Send MOR Fail NOK Count : 0 Wroam Rgrlc Send MIR Count : 0 Wroam Rgrlc Send MIR NOK Count : 0 Wroam Rgrlc Send Upd Preroam Count : 0 Wroam Rgrlc Send Upd Preroam NOK Count : 0 Wroam Rgrlc Send Pri Data Count : 0 Wroam Rgrlc Send Pri Data NOK Count : 0 Wroam Rgrlc Send Ap Up Count : 0 Wroam Rgrlc Send Ap Up NOK Count : 0 Wroam Rgrlc Send Ap Down Count : 0 Wroam Rgrlc Send Ap Down NOK Count : 0 Wroam Rgrlc Send MCMA Count : 0 Wroam Rgrlc Send MCMA NOK Count : 0 Wroam DB LPR Add Count : 175 Wroam DB LPR Del Count : 82 Wroam DB LPR Free Count : 0 Wroam DB LPR Update Count : 0 Wroam DB Failed Vlan Del LPR : 0 Wroam DB Failed Vlan Del LPR NE : 0 Wroam Rgrlc Recv Count : 1235 Wroam Rgrlc Rcv Add PR Count : 0 Wroam Rgrlc Rcv MOR Count : 500 Wroam Rgrlc Rcv DPR Count : 41 Wroam Rgrlc Rcv DPR LPR NE Count : 0 Wroam Rgrlc Rcv DPR LPR Count : 41 Wroam Rgrlc Rcv Kick Sta Count : 0 Wroam Rgrlc Rcv Srch Resp Count : 178 Wroam Rgrlc Rcv Roam Left Count : 0 Wroam Rgrlc Rcv MIR Count : 0 Wroam Rgrlc Rcv PriData Count : 0 Wroam Rgrlc Rcv Upd Preroam Count : 0 Wroam Rcv MOR NOK Count : 0 Wroam DB LPR MOR Update BSSID Count : 500 Wroam Rcv MOR LPR Not Exists Count : 0 Wroam Rcv MOR Sta Not Exists Count : 0 Wroam Rcv MOR Get Info NOK Count : 0 Wroam Snd MOR Response NOK Count : 0 Wroam Rgrlc Rcv RRR Count : 516 Wroam RRR DB LPR Update BSSID Count : 516 Wroam RRR Sta No Exists Count : 0 Wroam RRR Sta RP Not Match Count : 0 Wroam RRR LPR No Exists Count : 0 Wroam RRR LR Not Exists Count : 0 Wroam RRR LR Not Exists Fix Count : 0 Wroam RRR LR Not Match Count : 0 Wroam RRR Roam Failed Del LPR Count : 0 Wroam RRR Roam Failed LPR Not Exists Count : 0 Wroam RRR BSSID Not Match : 0 Wroam DB LR Add Count : 694 Wroam DB LR Del Count : 694 Wroam DB LR Del Deative Count : 0 Wroam DB LR Free Count : 0 Wroam DB LR Update Count : 0 Wroam Rgrlc Snd RR Timeout : 0 Wroam RR Timeout Del LPR : 0 Wroam RR Timeout Del Sta : 0 Wroam Rgrlc Snd SR Timeout : 0 Wroam RSR LR Not Exists : 0 Wroam RSR LR Not Match Type : 0 Wroam RSR LR Not Match BSSID : 0 Wroam auth send search req fail count : 0 Wroam assoc send search req fail count : 0 Wroam iac send search req fail count : 0 Wroam send roam req fail count : 0 Wroam recv roam resp handoff fail count : 0 Wroam iac recv roam resp handoff fail count : 0 Wroam send move in req fail count : 0 Wroam recv move in resp data handoff fail count : 0 Wroam recv move in resp nack handoff fail count : 0 Wroam send move out resp data fail count : 0 Wroam send move out resp nack fail count : 0 Wroam recv inter MOReq fakesta no exists count : 0 Wroam del sta for intra move out success count : 500 Wroam del sta for inter move out success count : 0 Wroam notify wroam success bss bot exist count : 0 Roamback recv MOReq fakesta not exist count : 0 Roamback recv MOReq ldb not exist count : 0 Wroam rcv MOReq hand fail ldb not exist count : 0 Wroam send RR LR not exist count : 0 Wroam send move in req LR not exist count : 0 Auth State Without Timer And Create Count : 0 DB Client Add Count : 655 DB Client Delete Count : 594 Bss Add Hash Table Conflict Count : 0 DB BSS Add : 62 DB BSS Delete : 2 Up Delete Mobile With Timer Count : 0 Add ST bind for radio cnt : 0 Del ST bind for radio cnt : 0 Add merger ST bind for radio cnt : 62 Del merger ST bind for radio cnt : 0 Add merger ST bind concurrence cnt : 0 Radio Down Recv Up Add Sta Count : 0 Radio Down Recv Up Sync Sta status Count : 0 Radio Down Recv Down Add Sta Count : 0 Radio Down Recv Down Sync Sta status Count : 0 Deactive Bss Del All Sta Succeed Count : 2 Deactive Bss Del All Sta Failed Count : 0 Deactive Bss Del All Sta Notify Count : 2 Get Bss By WLAN ID Witout AP CB Count : 0 Deactive Bss Del Sta Resp Without Bss Count : 0 Deactive Bss Del Sta Resp Without Handle Count : 0 Notify Deactive Bss Succeed Count : 0 Notify Deactive Bss Failed Count : 0 Notify Deactive Bss Notify Count : 0 Notify Deactive Bss Resp Without Bss Count : 0 Notify Deactive Bss Resp Without Handle Count : 0 Recover Sta Run Data And Sta Is Null Count : 0 Recover Sta Get Ap From Stamgr Failed Cnt : 8193 Recover Sta Get Ap From Apmgr Failed Cnt : 0 Recover Sta Get Radio From Stamgr Failed Cnt : 47831 Recover Sta Get Radio From Apmgr Failed Cnt : 0 Recover Sta Get Bss Failed Cnt : 0 Recover Sta Run Data Success Count : 0 Recover Sta Run Data Fail Count : 0 Ap Up Fini ST disable Count : 0 Delete Bss Link-Down with AP unreal : 0 Delete Bss Kernel Get Location Type Failed Cnt : 0 Recv AP CFG Update With Invalid TLV Handle Cnt : 0 Recv Update WLAN With Invalid TLV Handle Cnt : 0 AP Inter Smooth Req Cnt : 0 Bss Inter Smooth Req Cnt : 0 Sta Inter Smooth Req Cnt : 0 Send Up AP Inter Smooth Req Cnt : 0 Recv Up AP Inter Smooth Req Cnt : 0 Send Down AP Inter Smooth Update CFG Cnt : 0 Send Down AP Inter Smooth Radio Bind Cnt : 0 Send Up Bss Inter Smooth Req Cnt : 0 Recv Up Bss Inter Smooth Req Cnt : 0 Send Down Bss Inter Smooth Req Cnt : 0 Recv Down Bss Inter Smooth Req Cnt : 0 Send Down Bss Inter Smooth End Cnt : 0 Recv Down Bss Inter Smooth End Cnt : 0 Send Up Sta Inter Smooth Req Cnt : 0 Recv Up Sta Inter Smooth Req Cnt : 0 Send Down Sta Inter Smooth Req Cnt : 0 Recv Down Sta Inter Smooth Req Cnt : 0 Send Up Sta Inter Smooth Packet Cnt : 0 Recv Up Sta Inter Smooth Packet Cnt : 0 Send Up Sta Inter Smooth End Cnt : 0 Recv Up Sta Inter Smooth End Cnt : 0 Send Down Sta Inter Smooth Packet Cnt : 0 Recv Down Sta Inter Smooth Packet Cnt : 0 Send Down Sta Inter Smooth End Cnt : 0 Recv Down Sta Inter Smooth End Cnt : 0 Recv Remote BSS IF Index Cnt : 0 Add Remote BSS IF Index 2 Cache Cnt : 0 Del Remote BSS IF Index From Cache Cnt : 0 Add Remote BSS IF Index Private Data Cnt : 0 Del Remote BSS IF Index Private Data Cnt : 0 Pop Remote BSS IF Index Cache Cnt : 0 Pop Remote BSS IF Index Private Data Cnt : 0 Ap Link-Up Sta statis success Count : 0 Ap Link-Up Sta statis fail Count : 0 Ac Recv Link-Up Sta statis Count : 3868 Ac Link-Up Sta statis fail Count : 0 Ap Link-Up Bss statis success Count : 0 Ap Link-Up Bss statis fail Count : 0 Ac Recv Link-Up Bss statis Count : 4027 Ac Link-Up Bss statis fail Count : 4027 Ap Link-Up Ap statis success Count : 0 Ap Link-Up Ap statis fail Count : 0 Ac Recv Link-Up Ap statis Count : 2014 Ac Link-Up Ap statis fail Count : 2014 Ap Link-Up Radio statis success Count : 0 Ap Link-Up Radio statis fail Count : 0 Ac Recv Link-Up Radio statis Count : 4027 Ac Link-Up Radio statis fail Count : 4027 Delete Remain Sta After up Statis : 0 Delete Remain Sta With Same Aid : 0 Ac Send to Ap Remain Sta Count : 0 Ap Recv Inter Smooth Del Remain Sta Count : 0 Ap Del Remain STA Count : 0 Create timer Count : 4766 Create timer fail Count : 0 Delete timer Count : 4551 Send to cloud Online/Offline"s client Count : 0 Send to cloud Run info"s client Count : 0 Send to cloud Smooth info"s client Count : 0 Send to cloud Failed info"s client Count : 0 Send to cloud Online/Offline"s package Count : 0 Send to cloud Run info"s package Count : 0 Send to cloud Smooth info"s package Count : 0 Send to cloud Failed info"s package Count : 0 Ap Link-Up Ap BssNum BssID Frame success Count : 0 Ac Recv Link-Up BssNum BssID Frame Count : 2016 Ap Link-Up BssNum BssID Frame fail Count : 0 Ac Link-Up BssNum BssID Frame fail Count : 0 Ap Reboot Summary Count : 0 BssID Not Match Count : 0 Ap Report Unknown Ioctl Up Cmd Count : 0 Ap Report Unknown Ioctl Down Cmd Count : 0 Ap Report Unknown Base Ioctl Down Async Cmd Cnt : 0 Add BYOD Vendor Node Count : 4 Del BYOD Vendor Node Count : 0 ============================================================= ===============display system internal wlan client process cOntext=============== HA Master : True Run Once : True Interface Dimension : Three Sub Slot to Slot : False Stamgr Boot Mode : AC Chassis Number : 0 Slot Number : 1 Sub Slot Number : 0 Memory State : 0 APMGR Fd : 64 OFC Fd : 140 ACL Fd : 141 BYOD Fd : 151 IF Event Fd : 96 IF Event Handle : 121 IF Slot Event Handle : 122 BSS IF PDInstance : 1969881124 BSS Brief IF PDInstance : 1969882020 MaxNum ST Capacity : 40 MaxNum STA Capacity : 2048 MaxNum BSS Active Capacity : 1280 MaxNum BSS Basic Capacity : 1280 BSS Capacity Increase Ratio : 1 MaxNum Ap Support : 2147483647 MaxNum Ap Template : 2147483647 BSS Capa Increase Ratio Failed : 0 BSS Capa Increase Ratio 0 Failed : 0 BSS Capa Increase Ratio Revert : 0 Total number of ST : 1 Total number of BSS : 62 Total number of Station : 61 Total number of Asso cnt : 61 Debugging AP ID : 0 Debugging Level : 6 Service thread count : 3 Stamgr-Plgdmns Global Fd : 69 Stamgr-Plgdmns Local Fd : 70 Batch Create Bss Interface : Disable Client hot-Backup : Disable Stamgr Mesh Handle : 0 Stamgr Unicast Service Fd : 102 Stamgr Unicast Port Fd : 118 Stamgr Syslog Switch : 1 Stamgr BSS IF Pool Max IF Count : 0 Stamgr Sync All AP Sec : 0 Stamgr Sync All AP USec : 359862 Stamgr Async All AP Sec : 0 Stamgr Async All AP USec : 0 Stamgr WBKP Init Sec : 0 Stamgr WBKP Init USec : 26238 Stamgr HA Async All AP Sec : 0 Stamgr HA Async All AP USec : 0 Stamgr Slot Fast Remove Sec : 0 Stamgr Slot Fast Remove USec : 0 ============================================================= ===============ddisplay system internal wlan bss process statistics=============== Ap Up Adapter Create Bss : 62 Smooth Check Single Radio Create Bss : 0 Bind ST : 0 Recover Bss : 0 Merge Create Bss : 0 ST Enable : 0 Bss Create Recv Count : 62 Get Radio Private Fail Count : 0 (*) Bss Is Exist Count : 0 Malloc Fail Count : 0 (*) Calc Bssid Fail Count : 0 (*) Bss Node Create Fail Count : 0 (*) Init Location Fail Count : 0 (*) Need To Cteate Bss Count : 62 No Need To Create Bss Count : 0 Set Kernel Fwd Fail Count : 0 (*) Bss Create Fail Roll Back Count : 0 (*) Get IFHandle Fail Count : 0 (*) Send Msg 2 Work Thrd Fail Count : 0 (*) Send Msg 2 Work Thrd Success Count : 62 Batch Get Bss IF Node Count : 0 Batch Create Bss IF Count : 0 Batch Create Bss If 4 One Success Count : 0 Batch Create Bss If 4 One Failed Count : 0 (*) Single Create Bss If Count : 62 Single Create Bss If Success Count : 62 Single Create Bss If Failed Count : 0 (*) Async Create Bss If Req Succeed Count : 0 Async Create Bss If Req Failed Count : 0 Async Create Bss If Resp Count : 0 Async Create Bss If 4 One Success Count : 0 Async Create Bss If 4 One Failed Count : 0 IRF Notify BSS Event With Invalid IF Index Count : 0 IRF BSS IF UP Notify BSS Event Count : 0 IRF Daemon Restart Recover BSS IF List Node Count : 0 Rcv If Create Bss Msg Work Thread Count : 62 IF Create Bss Success In Work Thread Count : 62 IF Create Bss Failed In Work Thread Count : 0 (*) No Resource In Work Thread Count : 0 (*) IF Alloc Name ID Succeed Count : 62 IF Alloc Name ID Failed Count : 0 IF Dealloc Name ID Count : 2 IF Create Record Exist Count : 0 IF Create Record Conflict Count : 0 IF Create Record Add Count : 62 IF Create Record Del Count : 62 Get IF Create Record Conflict Count : 0 Get IF Create Record Conflict AP Down Count : 0 Roll Back If In Srv Thrd Count : 0 Roll Back If In Work Thrd Count : 0 Bss Create Roll Back Success Count : 0 Bss Create Save Ifindex In Bss Count : 62 Bss Create IF Create Count In Srv Thrd Count : 62 Bss Create Interface Create Failed Count : 0 (*) Bss Create Add Bss Index Failed Count : 0 (*) Bss Create Set Unknown Src Mac Count : 0 (*) Bss Create Add Bss Vlan Fail Count : 0 (*) Set Kernel Fwd Fail Count : 0 (*) Link Down Add Fail Count : 0 (*) Fail Create Bss Roll Back Count : 0 (*) Bss Set Kernel Fwd Count : 62 Get LocaType Fail count : 0 (*) Fill Add Bss Kernel Fail Count : 0 (*) Cioctl Success Count : 62 Fwd CioCtl Fail Count : 0 (*) Bss Create Link Down Add Count : 62 Create Tlv Handle Fail count : 0 (*) IOCTL Success Count : 62 IOCTL Fail Count : 0 (*) Bss Link Down Add Callback Count : 62 Result is Timeout : 0 Result is End of Ioctl Cnt : 0 Result is Fail : 0 (*) Bss Not Exist Count : 0 Bss Not Match Count : 0 Roll Back Bss : 0 (*) Bss Del Recv Count : 2 Get Bss By WlanId No APCB Count : 0 (*) Bss Not Exist Count : 0 Bss has Been Deleting Count : 0 Notify Bss Event Count : 64 Bss Sync Kernel Brief Info Fail Count : 0 (*) Bss Notify Bss Event Fail Count : 0 (*) Send Rt Del Bss Count : 2 Wbkp Standby Not Ready Count : 0 Get Ap Location Type Fail Count : 0 (*) DBM Key Fail Count : 0 (*) Pbss Del 2 Kernel Success Count : 0 Pbss Del 2 Kernel Fail Count : 0 (*) Create Handle Fail Count : 0 (*) Bss Is Deactive Count : 0 Bss Fini Count : 2 Bss Del Without STA Count : 2 Set If Node Count : 2 Send 2 Work Thrd Count : 0 Ap Down Del Link Down Count : 2 Link Down Ap UnReal Count : 0 IOCTL Return Success Count : 2 IOCTL Return Fail Count : 0 (*) Link Down Success Count : 2 Link Down Fail Count : 0 (*) Link Down Resp Count : 2 Rcv Link Down Count : 0 Link Down Resp Success Count : 0 Link Down Resp Fail Count : 0 (*) Reset Kernel Fwd Count : 2 kernel Get Location Failed Count : 0 (*) Kernel CIOCTL Success Count : 2 Kernel CIOCTL Fail Count : 0 (*) Work Thrd Rcv If Delete Msg Count : 0 Work Thrd If Delete Success Count : 0 Work Thrd If Delete Failed Count : 0 (*) Deactive Bss Count : 2 Del STA Failed Count : 0 (*) Del STA Success Count : 2 Del STA Notify Count : 2 Del STA Notify No Handle Count : 0 Del STA Notify No Bss Count : 0 Bss Update Wlan count : 203 to kernel Fail Count : 0 (*) to Kernel Get Location Type Fail : 0 (*) Other Type Count : 0 to Kernel CIOCTL Success Count : 203 to kernel CIOCTL Fail Count : 0 (*) IOCTL Success Count : 203 IOCTL Fail Count : 0 (*) to IOCTL LinkDown Fail Count : 0 (*) Bss Update Wbkp Count : 0 Not Ready Count : 0 Get Location Type Fail Count : 0 (*) Fill Fail Count : 0 (*) Send Ap Msg Fail Count : 0 (*) Bss Del OffService Get Radio pri Fail Count : 0 (*) Bss Notify Radio Event Fail Count : 0 (*) Rcv Link Down Add Bss Count : 0 Link Down Resp Success Count : 0 Link Down Resp Failed Count : 0 (*) Get RadioCB Fail : 0 (*) Apid Invalid : 0 (*) RadioId Invalid : 0 (*) Create Bss : 0 Create Bss Fail : 0 (*) Create Bss Handle Fail : 0 (*) Init Location Fail : 0 (*) Set Fwd Local Fail : 0 (*) Work Thread Recv Create Msg : 62 Send Msg to Work Thrd Fail : 0 (*) Create Interface Call Back : 0 Bss Null or Index Fail : 0 (*) Resp Node is Fail : 0 (*) Add Bss Index Fail : 0 (*) Add Vlan Fail : 0 (*) Set SRC Fail : 0 (*) Set Kernel FWD Fail : 0 (*) Active Bss Fail : 0 (*) Link Down Fail : 0 (*) Roll Back Bss : 0 Set Kernel FWD Fail : 0 (*) Active Bss Fail : 0 (*) Link Down Fail : 0 (*) Link Down UpResp Fail Get Bss : 0 (*) Link down upResp Code Fail : 0 (*) Create Bss Fail Roll Back BSS : 0 (*) Check Bss Fail : 0 (*) Update Bss Data : 0 Update Bss Data fit ap Resp : 0 (*) Update Bss Data Link down : 0 Create Handle Fail : 0 (*) Link Down Resp : 0 Get Bss Fail : 0 (*) link down Resp Code Fail : 0 (*) link down Fail : 0 (*) Update Bss Data Fail : 0 (*) Rcv Link Down Del Bss Count : 0 Link Down Resp Success Count : 0 Link Down Resp Failed Count : 0 (*) Create Handle Failed : 0 (*) Recv Del Bss : 2 Hchy Del Bss CallBack : 0 Hchy Del Bss CallBack ErrCode Fail : 0 (*) Rcv Wlan Fail : 0 (*) Smooth Create Bss Get Radio Private Fail : 0 (*) Smooth Create Bss Detail Count : 0 Create Bss Count : 0 Init Location Fail : 0 (*) Set Fwd Local Fail : 0 (*) Send 2 Work Thread Fail : 0 (*) Smooth Create Interface Callback : 0 Bss Not Exist : 0 (*) Roll Back Bss InterFace : 0 (*) Fail Create Bss InterFace : 0 (*) Add Bss Index 2 If Index Fail : 0 (*) Add Bss Vlan On Port Fail : 0 (*) Set Src Mac Action Fail : 0 (*) Set Kernel Fwd Fail : 0 (*) Active Bss Fail : 0 (*) Roll Back Bss : 0 (*) Create Handle Fail : 0 (*) Active Bss Fail : 0 (*) Set Kernel Fwd Fail : 0 (*) Roll Back Bss : 0 (*) Add Bss Vlan on Port : 0 Add Bss Vlan on Port Fail : 0 (*) Del Bss Vlan on Port : 166 Del Bss Vlan on Port Fail : 0 (*) Roll Back Count : 0 (*) Bss Create Fail Roll Back Count : 0 (*) Fail Create Bss Interface Roll Back : 0 (*) Link Down Add Call Back Roll Back : 0 (*) Create Bss Interface Resp Roll Back : 0 (*) Hchy Create Bss Fail Roll Back : 0 (*) Smooth Create Interface Call Back : 0 (*) Smooth Create Bss Detail Roll Back : 0 (*) Bss Fini STA Exist Bss Count : 0 Bss Fini STA Exist Count : 0 Bss Not Delete Count Of Ap Delete : 0 Bss Interface Not Delete Count Of Ap Delete : 0 Station Not Delete Count Of Ap Delete : 0 BSS Finish No Apcb : 0 Delete IF Without Apcb : 0 Smooth Bss Check Remain Bss Calc Bssid Fail : 0 (*) Smooth Bss Check Remain Bss Set Kernel Success : 0 Smooth Bss Check Remain Bss Set Kernel Fail : 0 (*) ============================================================= ===============display system internal wlan client delete process statistics=============== STA DB Add Hash Node Count : 655 STA DB Del Hash Node Count : 594 Remain STA Hash Node Number : 61 (*) STA Del Ridiculous Sta Count : 0 STA Del Smooth Del Sta Count : 0 STA Del By Hash Node Count : 0 STA Del Init Srv Phase Sta Fail Count : 0 (*) STA Del Adpt Call Back Count : 594 STA Del Adpt Fail Count : 0 (*) STA Del Inter Smooth Del Sta Count : 0 STA Del Rcv Del Sta Avl Count : 631 Del Ridiculous Sta Avl Count : 0 Smooth Del Sta Avl Count : 0 Entity Sta Avl Count : 631 Inter Smooth Delte Sta Avl Count : 0 Del Sta Avl Syn Del 2 Ap Sta Avl Cnt : 461 Del Sta Avl Ap Sta Avl Not equal Cnt : 170 Del Sta Avl Syn Del Sta Info No APCB : 0 Del Sta Avl Syn Del 2 Radio Sta Avl Cnt : 557 Del Sta Avl Radio Sta Avl Note qual Cnt : 74 Del Sta Avl Syn Del Sta Info No Radio CB : 0 Del Sta Avl Send 2 Cfg Sta Not Run Cnt : 74 Del Sta Avl No Need Send 2 Cfg Cnt : 0 Del Sta Avl Srv Create Sta Cfg Info Fail Cnt : 0 STA Del Srv Send Cfg Del Msg Count : 557 STA Del Cfg Rcv Del Msg Count : 557 Syn Del Sta Avl 4 Cfg Thread Cnt : 156 Sta Del Cfg Rcv Del Msg Bssid Not Equal Cnt : 401 Sta Del Cfg Get Global Sta Avl Node Cnt : 0 STA Add Ap Sta Avl Node Count : 618 STA Del Ap Sta Avl Node Count : 557 Remain Ap Sta Avl Node Number : 61 (*) STA Syn Add 2 Ap Sta Avl Del Old Cnt : 96 STA Syn Del 2 Ap Sta Avl Cnt : 461 STA Syn Add Bkp Sta Avl Del Old Cnt : 0 STA Syn Del Bkp Sta Avl Del Old Cnt : 0 STA Add Radio Sta Avl Node Count : 618 STA Del Radio Sta Avl Node Count : 557 Remain Radio Sta Avl Node Number : 61 (*) STA Syn Add 2 Radio Sta Avl Del Old Node count : 0 STA Syn Del 2 Radio Sta Avl Cnt : 557 STA Syn Add Bkp Del Old Radio Sta Avl Node Cnt : 0 STA Syn Del Bkp Del Old Radio Sta Avl Node Cnt : 0 STA Add Global Sta Avl Node Count : 1152 STA Del Global Sta Avl Node Count : 1091 Remain Global Sta Avl Node Number : 61 (*) STA Add ST Sta Avl Node Count : 1152 STA Del ST Sta Avl Node Count : 1091 Remain ST Sta Avl Node Number : 61 (*) Syn Add 2 Global Sta Avl Del Old Node Cnt : 935 Syn Del Sta Avl 4 Cfg Thread : 156 Sta Del Link up Resp Fail Count : 0 (*) Sta Del Link Down Resp Fail Count : 0 (*) Sta Del Ioctl Up Success Count : 0 Sta Del Ioctl Up Fail Count : 631 (*) Sta Del Link Down Success Count : 631 Sta Del Link Down Fail Count : 0 (*) Sta Del Rev Kick Del Sta Count : 520 Kick Del STA is Remote Ap and FWD in Local : 0 Kick Del STA Get APCB Fail Count : 0 (*) Kick Del STA Repeat Del Count : 0 Kick Del STA Send Deauth Count : 20 Kick Del No Need Send Deauth Count : 0 Kick Del Link Up Fail Count : 520 (*) Kick Del Link Down Fail count : 0 (*) Kick Del STA Fail Count : 0 (*) Rev Kick Normal Del Count : 0 Kick Normal STA is Remote Ap and FWD in Local : 0 Kick Normal STA Repeat Del Sta Count : 0 Kick Normal STA Send Deauth Count : 0 Kick Normal STA No Need Send Deauth Count : 0 Kick Normal STA Link up Fail Count : 0 (*) Kick Normal STA Link Down Fail Count : 0 (*) Kick Normal STA Fail Count : 0 (*) Rcv STA Del Count : 631 Notify Offline Count : 557 SDelete Timer Count : 0 Delete Address Count : 631 Reset Kernel Fwd Count : 612 Notify Del Fp Rule Count : 571 Link Down 4 Del Pbss Count : 0 Delete Dba STA Key count : 557 Create Del MobCtx Fail Count : 0 (*) Deactive Fail Count : 0 (*) State Not Run : 74 Deactive Callback Del Count : 557 Deactive Callback Fail Count : 0 (*) STA Del Rev Del Entity Count : 631 Repeat Timer Count : 0 Entity Sta Avl Count : 631 Sta Deactive Convert Count : 0 Entity With Timer Count : 56 Up Del Moble Has Timer Count : 0 Up Del Moble With Timer Count : 0 Entity With No Timer Count : 575 STA Del With Timer Count : 56 Cache Aging Timer Min Count : 0 Timer Create Fail Count : 0 (*) Timer Create Success Count : 56 Timer Out Count : 19 Rcv Del No Timer Count : 594 With No timer Del Timer Count : 19 Adpt Fail Count : 0 (*) Timer Create Success Count : 56 Timer Delete Count : 56 Del Sta Entity Timer Out Count : 19 Smooth Del Sta Del Sta Timer Count : 0 Rcv Auth Del Sta Timer Count : 18 Syn Create Sta Del Sta Timer Count : 0 With No timer Del Timer Count : 19 Smooth Del Remain Sta Del Sta Timer Count : 0 Rcv Asyn Up Sta Status Count : 0 STA Update Status Radio Down Count : 0 STA Update Status Add Msg 4 Srv Thread Count : 618 STA Syn Add Msg Del Old Sta Fail Count : 0 STA Syn Add 2 Ap StaAvl Get Ap Pri Fail Count : 0 (*) STA Syn Add 2 Ap Sta Avl Fail Count : 0 (*) STA Syn Add 2 Radio Sta Avl Get Radio Pri Fail : 0 (*) STA Syn Add 2 Radio Sta Avl Fail Count : 0 (*) AMS Create Sta Count : 672 AMS Destroy Sta Count : 611 AMS Rcv Add Mobile Count : 0 AMS Add Sta Parameter Fail Count : 0 (*) AMS Add Sta Is Auth Point Count : 0 AMS Add Sta Fail Count : 0 (*) CMS Create Sta Count : 672 CMS Destroy Sta Count : 611 CMS Rcv Add Mobile Count : 0 CMS Add Sta Parameter Fail count : 0 (*) CMS Add Sta Is Auth Point Count : 0 CMS Add Sta Fail Count : 0 (*) Sta Create Link Down Success : 1926 Sta Create Link Down Failed : 0 (*) Radio Down Rcv Down Add Sta : 0 Create Sta Fail : 0 (*) Add Mac Addr Fail : 0 (*) Add Msg 4 Srv Thread Fail : 0 (*) Set Kernel Fwd Fail : 0 (*) Down Add Pbss Drv : 0 Get Bss By Bssid Fail : 0 (*) SR Enable : 0 Get Pbss Node Fail : 0 (*) Add Pbss Drv Fail : 0 (*) Asyn Down Add Mob : 0 Create Add Mob Msg Fail : 0 (*) Link down Fail : 0 (*) Asyn Down add Mob Call Back : 0 Get Sta Info Fail : 0 (*) Sta is Deleting : 0 Link Down Result Fail : 0 (*) Add Mob Result Fail : 0 (*) Create stat interval timer Fail : 0 (*) Get Ap Pri Data Fail : 0 (*) Link Down Resp Fail : 0 (*) Hchy Rcv Up Add Mob : 0 Rcv Create Sta : 0 Proc Add Mob Fail : 0 (*) Sta is Deactiving : 0 Sta is Deleting : 0 Create Sta Info Fail : 0 (*) Create Sta Fail : 0 (*) Add Mac Addr Fail : 0 (*) Set Kernel Fwd Fail : 0 (*) Add Mob Call Back Fail : 0 (*) Asyn Up Fail : 0 (*) Roll Back Create Sta : 0 Sync Add Sta CFG No BSS Count : 0 (*) No Need to Sync Add Sta CFG Count : 0 Sync Del Sta CFG No BSS Count : 0 (*) Sync Del Sta CFG No AP Count : 0 (*) No Need to Sync Del Sta CFG Count : 0 Add Mac Address : 636 Get Bss Fail : 0 (*) Effect Vlan Mac Address Fail : 0 (*) Sta Vlan Invalid : 0 (*) Add Bss on Vlan Fail : 0 (*) Add New Mac Address Fail : 0 (*) Del Address Count : 631 Effect Vlan Invalid : 73 (*) Get Bss Fail : 0 (*) Del Vlan Address : 77 Del Address Fail : 0 (*) Srv Rcv LibMsg Revert Cnt : 0 Main Dsb LibMsg Revert Cnt : 0 Main Dsb LibMsg Less Than Srv Rcvd : 0 Main Discard Horizon LibMsg Cnt : 0 Main Discard Vertical LibMsg Cnt : 0 AMS Bkp Set Same SessionId Count : 0 (*) AMS Bkp Set Diff SessionId Count : 0 (*) AMS RhaDBM Set Same SessionId Count : 0 (*) AMS RhaDBM Set Diff SessionId Count : 0 (*) AMS Roamback Set Same SessionId Count : 0 (*) AMS Roamback Set Diff SessionId Count : 0 (*) AMS Rintra Set Same SessionId Count : 0 (*) AMS Rintra Set Diff SessionId Count : 0 (*) AMS StaDBM Set Same SessionId Count : 0 (*) AMS StaDBM Set Diff SessionId Count : 0 (*) ============================================================= ===============display system internal wlan service-template process statistics=============== Plgdmns Send Bind ST Count : 0 Plgdmns Recv Bind ST Resp Count : 0 ST Bind With Invalid Apid Count : 0 (*) ST Bind With No More Bind Count : 0 (*) ST Bind Send Msg to Srv Thread Success Count : 0 ST Bind Send Msg to Srv Thread Failed Count : 0 (*) ST Bind Send Msg to Srv Thread Callback Count : 0 ST Bind Create Hadle Failed Count : 0 (*) ST Bind Srv Thread Rcv Msg Count : 0 ST Bind Srv Thread Send Fail Resp to Cfg : 0 (*) ST Bind Srv Thread Send Success Resp to cfg : 0 ST Bind 4 New One Need WlanId Count : 0 ST Bind 4 A Inherit One Count : 0 ST Bind Already Exist No Need To Unbound : 0 ST Bind Already Exist Need to Unbound Count : 0 ST Bind Over Max Count Per Radio Count : 0 (*) ST Bind Get Ap Pri Data Failed Count : 0 (*) ST Bind Over Max Ssid Count Per Ap Count : 0 (*) ST Bind Req WlanId Create Handle Fail Count : 0 (*) ST Bind Assign Wlan Id Success Count : 0 ST Bind Assign Wlan Id Failed Count : 0 (*) ST Bind Alloc Wlan Id Success Count : 0 ST Bind Alloc Wlan Id Failed Count : 0 (*) ST Bind Req Wlan Id Callback Count : 0 ST Bind Req Wlan Id Callback Failed Count : 0 (*) ST Bind Req Wlan Id Callback Success Count : 0 ST Bind Req Wlan Id Callback Over Limit Count : 0 (*) ST Bind Roll Back Free Wlan Id Count : 0 ST Bind 2 Radio Private But Not Found : 0 (*) ST Bind Map Radio Node Malloc Failed Cout : 0 (*) ST Bind 2 Radio Private Merge list But Not Found : 0 (*) ST Bind Merge Node Malloc Fail Count : 0 (*) ST Bind Roll Back Map Node 4 Merge Failed Count : 0 (*) ST Bind Map 2 Radio Private Success Count : 0 ST Bind Map 2 Radio Private Failed Count : 0 (*) ST Bind Map 2 ST Node Success Count : 0 ST Bind Map 2 ST Node Failed Count : 0 (*) ST Bind Roll Back 4 Map 2 ST Node Failed Count : 0 (*) ST Bind Save DBM Count : 0 ST Bind Try 2 Create Bss Count : 0 ST Bind No Need 2 Create Bss Count : 0 ST Bind Create Bss Return Failed Count : 0 (*) ST Bind Active 4 Create Bss Failed Count : 0 (*) ST Bind Create Bss Return Success Count : 0 ST Bind Create Bss Callback Called Count : 0 ST Bind UnMerge Called Count : 0 ST Bind UnMerge But Not Found Radio Private : 0 (*) ST Bind UnMerge Free Wlan Id Count : 0 ST Bind UnMerge ST From Radio Count : 0 Plgdmns Send UnBind ST Count : 0 Plgdmns Recv UnBind ST Resp Count : 0 ST Unbind With Invalid Apid Count : 0 ST Unbind Create Handle Failed Count : 0 (*) ST Unbind Send Msg 2 Srv Thread Success Count : 0 ST Unbind Send Msg 2 Srv Thread Failed Count : 0 (*) ST Unbind Send Msg 2 Srv Thread Callback count : 0 ST Unbind Srv Thread Rcv Msg Count : 0 ST Unbind Del DBM Count : 0 ST Unbind But Not Found In Radio Count : 0 ST Unbind Srv Thread Send Failed Resp to Cfg Count: 0 (*) ST Unbind Srv Thread Send Success Resp 2 Cfg Count: 0 ST Unbind Get Radio Private But Not Found Count : 0 ST Unbind Get Radio Private Failed 4 Merge Node : 0 (*) ST Unbind Del Node From Radio And ST Count : 0 ST Unbind Del Bss Handle Malloc Failed Count : 0 (*) ST Unbind Del Bss Return Success Count : 0 ST Unbind Del Bss Return Failed Count : 0 (*) ST Unbind Del Bss Callback Count : 0 ST Unbind Free Wlan Id Count : 0 Get Invalid ApGroup Id 4 Merge ST Count : 0 (*) Get Ap Model Failed 4 Merge ST Count : 0 (*) Get ApGroup Radio Failed 4 Merge ST Count : 0 (*) Plgdmns Rcv ApGroup ST Bind Count : 0 Plgdmns Snd Apgroup ST Bind Resp Count : 0 ApGroup ST Bind Get Invalid ApGroup Id Count : 0 (*) ApGroup ST Bind Over Max Threshold Count : 0 (*) ApGroup ST Bind Get Radio Private Info Failed : 0 (*) ApGroup ST Bind Over Max Count Per Radio Count : 0 ApGroup ST Bind Snd 2 Srv Thread Success Count : 0 ApGroup ST Bind Snd 2 Srv Thread Failed Count : 0 (*) ApGroup ST Bind Snd 2 Srv Thread CallBack Count : 0 ApGroup ST Bind Snd 2 Srv Thread Malloc Failed : 0 (*) ApGroup ST Bind Add Nodes Count : 0 ApGroup ST Bind Add Nodes Malloc Failed Count : 0 (*) ApGroup ST Bind Add Avl Node Malloc Failed Count : 0 (*) ApGroup ST Bind Srv Rcv Msg Count : 0 ApGroup ST Bind Srv Snd Failed Resp 2 Cfg : 0 (*) ApGroup ST Bind Srv Snd Success Resp 2 Cfg : 0 ApGroup ST Bind Handle Malloc Failed Count : 0 (*) ApGroup ST Bind Srv Adapter Return Success Count : 0 ApGroup ST Bind Srv Adapter Return Failed Count : 0 (*) ApGroup ST Bind Srv Adapter Callback Count : 0 ApGroup MergeST Exclude Count : 0 ApGroup MergeST ST Exist Count : 0 ApGroup MergeST Req Wlan Id Handle Failed Count : 0 (*) ApGroup MergeST Not Allowed Count : 0 ApGroup MergeST Req Wlan Id Return Failed Count : 0 (*) ApGroup MergeST Req Wlan Id Called Count : 62 ApGroup MergeST Req Wlan Id CallBack Count : 62 ApGroup MergeST Req Wlan Id Failed In CB Count : 0 (*) ApGroup MergeST Not Allowed In CallBack Count : 0 ApGroup MergeST Add Node 2 Radio Failed Count : 0 (*) ApGroup MergeST Save Node 2 DBM Count : 62 ApGroup MergeST Roll Back Add Node 2 Radio Count : 0 ApGroup MergeST Try 2 Create BSS Count : 62 ApGroup MergeST Create Bss Return Success Count : 0 ApGroup MergeST Create Bss Return Failed Count : 0 (*) ApGroup MergeST Create Bss Handle Failed Count : 0 (*) ApGroup MergeST Create Bss Callback Count : 0 ApGroup MergeST Add Node 2 ST Success Count : 62 ApGroup MergeST Add Node 2 ST Failed Count : 0 (*) ApGroup MergeST No Need Create Bss Count : 62 ApGroup MergeST Srv Snd Msg 2 Cfg Count : 62 ApGroup MergeST Cfg Rcv Msg Count : 62 ApGroup MergeST Cfg List Malloc Failed Count : 0 (*) ApGroup MergeST Insert AVL Failed Count : 0 (*) ApGroup MergeST UnBind 4 plgdmns Count : 0 ApGroup ST Unbind Plgdmns Snd Resp Count : 0 ApGroup ST Unbind Get Invalid ApgroupId Count : 0 (*) ApGroup ST Unbind ST Not Exit Count : 0 ApGroup ST Unbind Radio Private Not Found count : 0 ApGroup ST Unbind Del Node And DBM Count : 0 ApGroup ST Unbind Del Node Failed Count : 0 (*) ApGroup ST Unbind Del AVL Node Failed Count : 0 (*) ApGroup ST Unbind Del Srv Thread Rcv Msg Count : 0 ST Enable Plgdmns Count : 0 ST Enable Plgdmns Snd Resp Count : 0 ST Enable Malloc Failed Count : 0 (*) ST Enable Get ST Failed Count : 0 (*) ST Enable Set ST Cfg Failed Count : 0 (*) ST Enable Snd 2 Srv Thread Success Count : 0 ST Enable Snd 2 Srv Thread Failed Count : 0 ST Enable Snd 2 Srv Thread CallBack Count : 0 ST Enable Srv Thread Rcv Msg Count : 0 ST Enable Srv Snd Resp 2 Cfg Count : 0 ST Enable Create Bss CallBack Count : 0 ST Enable No Need 2 Create Bss Count : 0 ST Enable Create Bss Handle Malloc Failed Count : 0 (*) ST Enable Create Bss Return Success Count : 0 ST Enable Create Bss Return Failed Count : 0 (*) ST Enable Create Bss Adapter Rcv Count : 0 ST Enable Create Bss Adapter Active Fail : 0 (*) ST Disable Plgdmns Count : 0 ST Disable Plgdmns Resp Count : 0 ST Disable Get ST Failed Count : 0 (*) ST Disable Snd 2 Srv Success Count : 0 ST Disable Snd 2 Srv Failed Count : 0 (*) ST Disable Snd 2 Srv CallBack Count : 0 ST Disable Srv Thread Rcv Msg Count : 0 ST Enable Adapter Handle Create Failed Count : 0 (*) ST Disable Del Bss Handle Malloc Failed Count : 0 (*) ST Disable Del Bss Return Success Count : 0 ST Disable Del Bss Return Failed Count : 0 (*) ST Disable Del Bss Adapter Rcv Count : 0 Add ST Bind Node 2 Radio Count : 0 Del ST Bind Node 2 Radio Count : 0 Add Merge ST Bind Node 2 Radio Count : 62 Del Merge ST Bind Node 2 Radio Count : 0 Add Merge ST Bind Concurrence Count : 0 Deactive Bss Del STa Success Count : 2 Deactive Bss Del Sta Failed Count : 0 (*) Deactive Bss Del Sta Notify Count : 2 Get Bss By Wlan Id No APCB Count : 0 (*) Deactive Bss Del Sta Notify No Bss Count : 0 Deactive Bss Del Sta Notify No Hadle Count : 0 Notify Deactive Bss Succeed Count : 0 Notify Deactive Bss Failed Count : 0 (*) Notify Deactive Bss Resp Count : 0 Notify Deactive Bss Resp No Bss Count : 0 Notify Deactive Bss Resp No Handle Count : 0 Ap Up Finish ST Disable Count : 0 Del Bss Link Down Ap Unreal Count : 0 Repeat Merger BindST Concurrence Count : 0 (*) Get Merger Node RadioCb Failed Count : 0 (*) Cfg Add BindST Avl Count : 62 Cfg Del BindST Avl Count : 0 DBM Save BindST Failed Count : 0 (*) DBM Save Merger BindST Failed Count : 0 (*) UnBind Del Dbm Bind Failed Count : 0 (*) UnBind Del Dbm Bind Merger Failed Count : 0 (*) ============================================================= ===============display system internal wlan client comsh-cache verbose=============== No cached command ============================================================= ===============display system internal wlan client thread all=============== Ap Create Count : 0 Ap Create Notify Count : 0 Ap Delete Count : 0 Ap Delete Notify Count : 0 Ap Up Count : 31 Ap Up Notify Count : 31 Ap Down Count : 1 Ap Down Notify Count : 1 Ap Rename Count : 0 Ap Modify Serial Count : 0 Ap Change To Mgr : 0 Ap Change To Mgr Notify : 0 Radio Up Count : 62 Radio Up Notify Count : 62 Radio Down Count : 2 Radio Down Notify Count : 2 ApGroup Add Count : 0 ApGroup Add Notify Count : 0 Srv Thread Add Ap Count : 0 Bkp Ap Create Count : 0 Bkp Ap Create Notify Count : 0 Bkp Ap Delete Count : 0 Bkp Ap Delete Notify Count : 0 Bkp Ap Batch Count : 0 Bkp Ap Batch Notify Count : 0 Bkp Ap Upgrade Count : 0 Bkp Ap Upgrade Notify Count : 0 Bkp Ap RT Fini Count : 0 Bkp Ap RT Fini Notify Count : 0 Assign WLAN ID Count : 0 Alloc WLAN ID Count : 62 Notify WLAN ID Count : 62 Free WLAN ID Count : 0 Create BSS IF Count : 62 Create BSS IF Callback Count : 62 Radio Rate Set Change Count : 0 Ap Uplink Down Count : 0 Ap Uplink Down Notify Count : 0 Ap Power Level Change Count : 0 Ap Power Level Change Notify Count : 0 ============================================================= ===============display system internal wlan client process statistics module 0=============== Apmgr IOCTL Down Fail Count : 0 Apmgr Link Up End Of Ioctl Count : 3192 Apmgr IOCTL UP Fail Count : 0 Bss Create Count : 62 Bss Delete Count : 2 Bss Smooth Delete Count : 0 Bss Roll Back Count : 0 Bss Roll Back Exist Sta Count : 0 Bss Delete Without Sta Count : 2 Bss Finish Count : 2 IF Create Count In Srv Thrd : 62 IF Save Count In Srv Thrd : 62 IF Roll Back Count In Srv Thrd : 0 IF Alloc Name ID Succeed Count : 62 IF Alloc Name ID Failed Count : 0 IF Dealloc Name ID Count : 2 IF Create Record Exist Count : 0 IF Create Record Conflict Count : 0 IF Create Record Add Count : 62 IF Create Record Del Count : 62 Get IF Create Record Conflict Count : 0 Get IF Create Record Conflict AP Down Count : 0 IF Roll Back Success Count In Work Thrd : 0 IF Create Msg In Work Thrd : 62 IF Delete Msg In Work Thrd : 0 IF Batch Delete Msg In Work Thrd : 1 IF Create Success In Work Thrd : 62 IF Create Failed In Work Thrd : 0 IF Create no resource In Work Thrd : 0 IF Delete Success In Work Thrd : 0 IF Delete Failed In Work Thrd : 0 IF Batch Delete Success In Work Thrd : 2 IF Batch Delete Failed In Work Thrd : 0 IF Count Of Ap Delete : 0 Without APCB Of Ap Down Call Back : 0 IF Delete Count Of Ap Delete : 0 Not Support Mgr Pkt Count : 0 Batch Create Bss IF Count : 0 Batch Create Bss IF 4 one Succeed Count : 0 Batch Create Bss IF 4 one Failed Count : 0 Batch Create Bss IF Get Node From List Count : 0 Smooth Create Bss Link Down Count : 0 Create Bss Link-Down Succeed Count : 62 Create Bss Link-Down Failed Count : 0 Create Bss Link-Down Respond Count : 62 Create Bss Receive Link-Down Message Count : 0 Create Bss Send Link-Down Resp Succeed Count : 0 Create Bss Send Link-Down Resp Failed Count : 0 Delete Bss AP down Link-Down Count : 2 Delete Bss Link-Down Succeed Count : 2 Delete Bss Link-Down Failed Count : 0 Delete Bss Link-Down Respond Count : 2 Delete Bss Receive Link-Down Message Count : 0 Delete Bss Send Link-Down Resp Succeed Count : 0 Delete Bss Send Link-Down Resp Failed Count : 0 Update Bss Link-Down Succeed Count : 203 Update Bss Link-Down Failed Count : 0 Update Bss Link-Down Respond Count : 203 Update Bss Receive Link-Down Message Count : 0 Update Bss Send Link-Down Resp Succeed Count : 0 Update Bss Send Link-Down Resp Failed Count : 0 Client Deactive Notify Srv Succeed Count : 5013 Client Deactive Notify Srv Failed Count : 0 Client Delete Notify Srv Succeed Count : 7128 Client Delete Notify Srv Failed Count : 0 Create Client Link-Down Succeed Count : 1926 Create Client Link-Down Failed Count : 0 Create Client Link-Down Respond Count : 1926 Create Client Receive Link-Down Message Count : 0 Create Client Send Link-Down Resp Succeed Count : 0 Create Client Send Link-Down Resp Failed Count : 0 Delete Client Link-Down Succeed Count : 631 Delete Client Link-Down Failed Count : 0 Delete Client Link-Down Respond Count : 631 Delete Client Receive Link-Down Message Count : 0 Delete Client Send Link-Down Resp Succeed Count : 0 Delete Client Send Link-Down Resp Failed Count : 0 Create Client Link-Up Succeed Count : 0 Create Client Link-Up Failed Count : 1926 Create Client Link-Up Respond Count : 0 Create Client Receive Link-Up Message Count : 0 Create Client Send Link-Up Resp Succeed Count : 0 Create Client Send Link-Up Resp Failed Count : 0 Delete Client Link-Up Succeed Count : 0 Delete Client Link-Up Failed Count : 631 Delete Client Link-Up Respond Count : 0 Delete Client Receive Link-Up Message Count : 0 Delete Client Send Link-Up Resp Succeed Count : 0 Delete Client Send Link-Up Resp Failed Count : 0 Client Kick Repeat Count : 0 Client Det after TE Count : 19 Client Kick Normal TE Count : 0 Client Deactive Convert Notify Count : 0 Client Deactive Convert Count : 0 Client Delete Convert Notify Count : 0 Client Delete Convert Count : 0 Client Add CallBack with Delete Timer : 0 Client Add CallBack with Deleting : 0 Wroam Client Active Count : 102 Wroam Client Active NOK Count : 0 Wroam Client Reactive : 0 Wroam Client Reactive NOK : 0 Wroam Client Delete Succeed Count : 41 Wroam Client Delete No Match Count : 22 Wroam Client Delete LPR No Match Count : 531 Wroam Client Smooth Delete Send Succeed Count : 0 Wroam Client Smooth Delete Send Failed Count : 0 Wroam Rgrlc Send Count : 1894 Wroam Rgrlc Send NOK Count : 0 Wroam Rgrlc Send Add Preroam Count : 102 Wroam Rgrlc Send Add Preroam NOK Count : 0 Wroam Rgrlc Send Del Preroam Count : 41 Wroam Rgrlc Send Del Preroam NOK Count : 0 Wroam Rgrlc Send RR Count : 516 Wroam Rgrlc Send RR NOK Count : 0 Wroam Rgrlc Send SR Count : 178 Wroam Rgrlc Send SR NOK Count : 0 Wroam Rgrlc Send Sta logon Count : 0 Wroam Rgrlc Send Sta Logon NOK Count : 0 Wroam Rgrlc Send Sta Logoff Count : 73 Wroam Rgrlc Send Sta Logoff NOK Count : 0 Wroam Rgrlc Send RL Count : 484 Wroam Rgrlc Send RL NOK Count : 0 Wroam Rgrlc Send MOR Data Count : 500 Wroam Rgrlc Send MOR Data NOK Count : 0 Wroam Rgrlc Send MOR Fail Count : 0 Wroam Rgrlc Send MOR Fail NOK Count : 0 Wroam Rgrlc Send MIR Count : 0 Wroam Rgrlc Send MIR NOK Count : 0 Wroam Rgrlc Send Upd Preroam Count : 0 Wroam Rgrlc Send Upd Preroam NOK Count : 0 Wroam Rgrlc Send Pri Data Count : 0 Wroam Rgrlc Send Pri Data NOK Count : 0 Wroam Rgrlc Send Ap Up Count : 0 Wroam Rgrlc Send Ap Up NOK Count : 0 Wroam Rgrlc Send Ap Down Count : 0 Wroam Rgrlc Send Ap Down NOK Count : 0 Wroam Rgrlc Send MCMA Count : 0 Wroam Rgrlc Send MCMA NOK Count : 0 Wroam DB LPR Add Count : 175 Wroam DB LPR Del Count : 82 Wroam DB LPR Free Count : 0 Wroam DB LPR Update Count : 0 Wroam DB Failed Vlan Del LPR : 0 Wroam DB Failed Vlan Del LPR NE : 0 Wroam Rgrlc Recv Count : 1235 Wroam Rgrlc Rcv Add PR Count : 0 Wroam Rgrlc Rcv MOR Count : 500 Wroam Rgrlc Rcv DPR Count : 41 Wroam Rgrlc Rcv DPR LPR NE Count : 0 Wroam Rgrlc Rcv DPR LPR Count : 41 Wroam Rgrlc Rcv Kick Sta Count : 0 Wroam Rgrlc Rcv Srch Resp Count : 178 Wroam Rgrlc Rcv Roam Left Count : 0 Wroam Rgrlc Rcv MIR Count : 0 Wroam Rgrlc Rcv PriData Count : 0 Wroam Rgrlc Rcv Upd Preroam Count : 0 Wroam Rcv MOR NOK Count : 0 Wroam DB LPR MOR Update BSSID Count : 500 Wroam Rcv MOR LPR Not Exists Count : 0 Wroam Rcv MOR Sta Not Exists Count : 0 Wroam Rcv MOR Get Info NOK Count : 0 Wroam Snd MOR Response NOK Count : 0 Wroam Rgrlc Rcv RRR Count : 516 Wroam RRR DB LPR Update BSSID Count : 516 Wroam RRR Sta No Exists Count : 0 Wroam RRR Sta RP Not Match Count : 0 Wroam RRR LPR No Exists Count : 0 Wroam RRR LR Not Exists Count : 0 Wroam RRR LR Not Exists Fix Count : 0 Wroam RRR LR Not Match Count : 0 Wroam RRR Roam Failed Del LPR Count : 0 Wroam RRR Roam Failed LPR Not Exists Count : 0 Wroam RRR BSSID Not Match : 0 Wroam DB LR Add Count : 694 Wroam DB LR Del Count : 694 Wroam DB LR Del Deative Count : 0 Wroam DB LR Free Count : 0 Wroam DB LR Update Count : 0 Wroam Rgrlc Snd RR Timeout : 0 Wroam RR Timeout Del LPR : 0 Wroam RR Timeout Del Sta : 0 Wroam Rgrlc Snd SR Timeout : 0 Wroam RSR LR Not Exists : 0 Wroam RSR LR Not Match Type : 0 Wroam RSR LR Not Match BSSID : 0 Wroam auth send search req fail count : 0 Wroam assoc send search req fail count : 0 Wroam iac send search req fail count : 0 Wroam send roam req fail count : 0 Wroam recv roam resp handoff fail count : 0 Wroam iac recv roam resp handoff fail count : 0 Wroam send move in req fail count : 0 Wroam recv move in resp data handoff fail count : 0 Wroam recv move in resp nack handoff fail count : 0 Wroam send move out resp data fail count : 0 Wroam send move out resp nack fail count : 0 Wroam recv inter MOReq fakesta no exists count : 0 Wroam del sta for intra move out success count : 500 Wroam del sta for inter move out success count : 0 Wroam notify wroam success bss bot exist count : 0 Roamback recv MOReq fakesta not exist count : 0 Roamback recv MOReq ldb not exist count : 0 Wroam rcv MOReq hand fail ldb not exist count : 0 Wroam send RR LR not exist count : 0 Wroam send move in req LR not exist count : 0 Auth State Without Timer And Create Count : 0 DB Client Add Count : 655 DB Client Delete Count : 594 Bss Add Hash Table Conflict Count : 0 DB BSS Add : 62 DB BSS Delete : 2 Up Delete Mobile With Timer Count : 0 Add ST bind for radio cnt : 0 Del ST bind for radio cnt : 0 Add merger ST bind for radio cnt : 62 Del merger ST bind for radio cnt : 0 Add merger ST bind concurrence cnt : 0 Radio Down Recv Up Add Sta Count : 0 Radio Down Recv Up Sync Sta status Count : 0 Radio Down Recv Down Add Sta Count : 0 Radio Down Recv Down Sync Sta status Count : 0 Deactive Bss Del All Sta Succeed Count : 2 Deactive Bss Del All Sta Failed Count : 0 Deactive Bss Del All Sta Notify Count : 2 Get Bss By WLAN ID Witout AP CB Count : 0 Deactive Bss Del Sta Resp Without Bss Count : 0 Deactive Bss Del Sta Resp Without Handle Count : 0 Notify Deactive Bss Succeed Count : 0 Notify Deactive Bss Failed Count : 0 Notify Deactive Bss Notify Count : 0 Notify Deactive Bss Resp Without Bss Count : 0 Notify Deactive Bss Resp Without Handle Count : 0 Recover Sta Run Data And Sta Is Null Count : 0 Recover Sta Get Ap From Stamgr Failed Cnt : 8193 Recover Sta Get Ap From Apmgr Failed Cnt : 0 Recover Sta Get Radio From Stamgr Failed Cnt : 47833 Recover Sta Get Radio From Apmgr Failed Cnt : 0 Recover Sta Get Bss Failed Cnt : 0 Recover Sta Run Data Success Count : 0 Recover Sta Run Data Fail Count : 0 Ap Up Fini ST disable Count : 0 Delete Bss Link-Down with AP unreal : 0 Delete Bss Kernel Get Location Type Failed Cnt : 0 Recv AP CFG Update With Invalid TLV Handle Cnt : 0 Recv Update WLAN With Invalid TLV Handle Cnt : 0 AP Inter Smooth Req Cnt : 0 Bss Inter Smooth Req Cnt : 0 Sta Inter Smooth Req Cnt : 0 Send Up AP Inter Smooth Req Cnt : 0 Recv Up AP Inter Smooth Req Cnt : 0 Send Down AP Inter Smooth Update CFG Cnt : 0 Send Down AP Inter Smooth Radio Bind Cnt : 0 Send Up Bss Inter Smooth Req Cnt : 0 Recv Up Bss Inter Smooth Req Cnt : 0 Send Down Bss Inter Smooth Req Cnt : 0 Recv Down Bss Inter Smooth Req Cnt : 0 Send Down Bss Inter Smooth End Cnt : 0 Recv Down Bss Inter Smooth End Cnt : 0 Send Up Sta Inter Smooth Req Cnt : 0 Recv Up Sta Inter Smooth Req Cnt : 0 Send Down Sta Inter Smooth Req Cnt : 0 Recv Down Sta Inter Smooth Req Cnt : 0 Send Up Sta Inter Smooth Packet Cnt : 0 Recv Up Sta Inter Smooth Packet Cnt : 0 Send Up Sta Inter Smooth End Cnt : 0 Recv Up Sta Inter Smooth End Cnt : 0 Send Down Sta Inter Smooth Packet Cnt : 0 Recv Down Sta Inter Smooth Packet Cnt : 0 Send Down Sta Inter Smooth End Cnt : 0 Recv Down Sta Inter Smooth End Cnt : 0 Recv Remote BSS IF Index Cnt : 0 Add Remote BSS IF Index 2 Cache Cnt : 0 Del Remote BSS IF Index From Cache Cnt : 0 Add Remote BSS IF Index Private Data Cnt : 0 Del Remote BSS IF Index Private Data Cnt : 0 Pop Remote BSS IF Index Cache Cnt : 0 Pop Remote BSS IF Index Private Data Cnt : 0 Ap Link-Up Sta statis success Count : 0 Ap Link-Up Sta statis fail Count : 0 Ac Recv Link-Up Sta statis Count : 3868 Ac Link-Up Sta statis fail Count : 0 Ap Link-Up Bss statis success Count : 0 Ap Link-Up Bss statis fail Count : 0 Ac Recv Link-Up Bss statis Count : 4027 Ac Link-Up Bss statis fail Count : 4027 Ap Link-Up Ap statis success Count : 0 Ap Link-Up Ap statis fail Count : 0 Ac Recv Link-Up Ap statis Count : 2014 Ac Link-Up Ap statis fail Count : 2014 Ap Link-Up Radio statis success Count : 0 Ap Link-Up Radio statis fail Count : 0 Ac Recv Link-Up Radio statis Count : 4027 Ac Link-Up Radio statis fail Count : 4027 Delete Remain Sta After up Statis : 0 Delete Remain Sta With Same Aid : 0 Ac Send to Ap Remain Sta Count : 0 Ap Recv Inter Smooth Del Remain Sta Count : 0 Ap Del Remain STA Count : 0 Create timer Count : 4766 Create timer fail Count : 0 Delete timer Count : 4551 Send to cloud Online/Offline"s client Count : 0 Send to cloud Run info"s client Count : 0 Send to cloud Smooth info"s client Count : 0 Send to cloud Failed info"s client Count : 0 Send to cloud Online/Offline"s package Count : 0 Send to cloud Run info"s package Count : 0 Send to cloud Smooth info"s package Count : 0 Send to cloud Failed info"s package Count : 0 Ap Link-Up Ap BssNum BssID Frame success Count : 0 Ac Recv Link-Up BssNum BssID Frame Count : 2016 Ap Link-Up BssNum BssID Frame fail Count : 0 Ac Link-Up BssNum BssID Frame fail Count : 0 Ap Reboot Summary Count : 0 BssID Not Match Count : 0 Ap Report Unknown Ioctl Up Cmd Count : 0 Ap Report Unknown Ioctl Down Cmd Count : 0 Ap Report Unknown Base Ioctl Down Async Cmd Cnt : 0 Add BYOD Vendor Node Count : 4 Del BYOD Vendor Node Count : 0 ============================================================= ===============display system internal wlan client process statistics module 4=============== ============================================================= ===============display system internal wlan client process statistics module 9=============== ============================================================= ===============display system internal wlan client process statistics module 10=============== Create wait Node : 0 Create Author Node : 0 Free Author Node : 0 Create Delete Node : 0 Free Delete Node : 0 Create Smooth Node : 0 Free Smooth Node : 0 Create ACL change Node : 0 Free ACL change Node : 0 Create User Profile Event Node : 0 Free User Profile Event Node : 0 Create QoS Event Node : 0 Free Qos Event Node : 0 Create OFC Event Node : 0 Free OFC Event Node : 0 Create Packet Filter Node : 0 Free Packet Filter Node : 0 Create Smooth User Profile Node : 0 Free Smooth User Profile Node : 0 Register ACL Event Success : 0 Register ACL Event Failed : 0 Deregister ACL Event : 0 Receive ACL Event : 0 Response ACL Event : 0 Add ACL Event Success : 0 Update ACL Event Success : 0 Delete ACL Event Success : 0 Register User Profile Event Success : 0 Register User Profile Event Fail : 0 Add User Profile Fail : 0 Deregister User Profile Event : 0 Receive User Profile Event : 0 Response User Profile Event : 0 Receive Packet Filter Event : 0 Receive Qos Event : 0 Receive OFC Event : 0 Wth Process Author Resource Not Enough : 0 Sth->Wth AuthorSucc Success : 0 Sth->Wth AuthorSucc Fail : 0 Sth->Wth ACLChange Success : 0 Sth->Wth ACLChange Fail : 0 Sth->Wth ACLDelete Success : 0 Sth->Wth ACLDelete Fail : 0 Sth->Wth Delete Success : 0 Sth->Wth Delete Fail : 0 Sth->Wth SmoothACL Success : 0 Sth->Wth SmoothACL Fail : 0 Sth->Wth UPCreate Success : 0 Sth->Wth UPCreate Fail : 0 Sth->Wth UPDelete Success : 0 Sth->Wth UPDelete Fail : 0 Sth->Wth SmoothUP Success : 0 Sth->Wth SmoothUP Fail : 0 Sth->Wth ISSUDelete Success : 0 Sth->Wth ISSUDelete Fail : 0 Wth->Sth AuthzReply Success : 0 Wth->Sth AuthzReply Fail : 0 Wth->Sth ISSUDelete Success : 0 Wth->Sth ISSUDelete Fail : 0 Proc Authz Reply Get User Fail : 0 Proc DoingNode Reslt Get DoingNode Fail : 0 Proc DoingNode Reslt NodeID Mismatching : 0 ISSU Del No BSS : 0 ISSU Del No BSS IF : 0 ISSU Del Authoring Node : 0 ISSU Del Authoring Node Already Done : 0 ISSU Del Author done Node : 0 Pre ISSU Del No CM User : 0 Pre ISSU Del No BSS : 0 Pre ISSU Del No BSS IF : 0 Pre ISSU Del Authoring Node : 0 Pre ISSU User Offline : 0 Proc ISSU User Fini : 0 Proc ISSU User Fini No Bss : 0 Proc ISSU User Fini No Bss IF : 0 Proc ISSU User Fini No User ID : 0 Proc ISSU Del AM Auth Info No Sta : 0 CM Add ACL Already Exist : 0 CM Add ACL Already Exist Fail : 0 CM Recover User ID Fail : 0 Add User Profile Table Full : 0 ============================================================= ===============display system internal wlan client process statistics module 19=============== Sta exit but no bss cnt : 0 IPv4 IPCIM remain cnt : 0 Free ARP Send IP 0 Target Mac F: 0 Free ARP Send IP 0 No Target Mac F: 0 ============================================================= =============================================== ===============display vlan all=============== VLAN ID: 1 VLAN type: Static Route interface: Configured IPv4 address: 192.168.0.100 IPv4 subnet mask: 255.255.248.0 Description: VLAN 0001 Name: VLAN 0001 Tagged ports: None Untagged ports: GigabitEthernet1/0/1 GigabitEthernet1/0/2 GigabitEthernet1/0/3 GigabitEthernet1/0/4 GigabitEthernet1/0/6 VLAN ID: 10 VLAN type: Static Route interface: Configured IPv4 address: 10.12.1.1 IPv4 subnet mask: 255.255.255.252 Description: HL-TP Name: VLAN 0010 Tagged ports: GigabitEthernet1/0/2 GigabitEthernet1/0/3 GigabitEthernet1/0/4 Untagged ports: GigabitEthernet1/0/5 VLAN ID: 100 VLAN type: Static Route interface: Configured IPv4 address: 172.16.100.1 IPv4 subnet mask: 255.255.252.0 Description: VLAN 0100 Name: VLAN 0100 Tagged ports: GigabitEthernet1/0/2 GigabitEthernet1/0/3 GigabitEthernet1/0/4 Untagged ports: WLAN-BSS1/0/1 WLAN-BSS1/0/3 WLAN-BSS1/0/4 WLAN-BSS1/0/5 WLAN-BSS1/0/6 WLAN-BSS1/0/7 WLAN-BSS1/0/8 WLAN-BSS1/0/10 WLAN-BSS1/0/12 WLAN-BSS1/0/15 WLAN-BSS1/0/16 WLAN-BSS1/0/18 WLAN-BSS1/0/20 WLAN-BSS1/0/22 WLAN-BSS1/0/23 WLAN-BSS1/0/27 WLAN-BSS1/0/34 WLAN-BSS1/0/42 WLAN-BSS1/0/43 WLAN-BSS1/0/44 WLAN-BSS1/0/45 WLAN-BSS1/0/46 WLAN-BSS1/0/51 WLAN-BSS1/0/52 WLAN-BSS1/0/53 WLAN-BSS1/0/58 WLAN-BSS1/0/62 ================================================= ===============display stp brief=============== STP is not configured. ================================================ ===============display stp=============== STP is not configured. =============================================================== ===============display stp abnormal-port=============== STP is not configured. ============================================================= ===============display stp history=============== STP is not configured. =================================================== ===============display stp tc=============== STP is not configured. ================================================================== ===============display link-aggregation summary=============== No link aggregation group exists. ================================================================== ===============display link-aggregation verbose=============== No link aggregation group exists. ====================================================== ===============display evi isis brief=============== ==================================================================== ===============display evi isis tunnel=============== ========================================================================= ===============display evi isis peer=============== ========================================================== ===============display evi isis local-mac dynamic=============== ========================================================== ===============display evi isis local-mac nOnadvertised=============== ========================================================== ===============display evi isis local-mac static=============== =========================================================== ===============display evi isis remote-mac=============== ==================================================================== ===============display mac-address=============== MAC Address VLAN ID State Port/NickName Aging 000e-c631-fcc9 1 Learned GE1/0/1 Y 001e-67c0-8339 1 Learned GE1/0/1 Y 00be-d5b3-9800 1 Learned GE1/0/3 Y 00be-d5b3-9880 1 Learned GE1/0/3 Y 00be-d5b3-98c0 1 Learned GE1/0/3 Y 00be-d5b3-9920 1 Learned GE1/0/3 Y 00be-d5b3-9ae0 1 Learned GE1/0/3 Y 00be-d5b3-a1a0 1 Learned GE1/0/3 Y 00be-d5b3-a480 1 Learned GE1/0/3 Y 00be-d5b3-a4a0 1 Learned GE1/0/3 Y 00be-d5b3-a640 1 Learned GE1/0/3 Y 00be-d5b3-ab80 1 Learned GE1/0/3 Y 00be-d5b3-ad40 1 Learned GE1/0/3 Y 00be-d5b3-af40 1 Learned GE1/0/3 Y 00be-d5b4-0000 1 Learned GE1/0/3 Y 00be-d5b4-0220 1 Learned GE1/0/3 Y 00be-d5b4-03c0 1 Learned GE1/0/3 Y 00d8-612c-8aaf 1 Learned GE1/0/1 Y 0c4b-543e-6a0b 1 Learned GE1/0/1 Y 0c9d-920f-b0ff 1 Learned GE1/0/1 Y 0c9d-9213-f78d 1 Learned GE1/0/1 Y 18c0-4d3f-f0f5 1 Learned GE1/0/1 Y 18c0-4d3f-f3eb 1 Learned GE1/0/1 Y 18c0-4d63-cc02 1 Learned GE1/0/1 Y 18c0-4d6c-ef0d 1 Learned GE1/0/1 Y 18c0-4d6d-214c 1 Learned GE1/0/1 Y 18c0-4dae-3760 1 Learned GE1/0/1 Y 1e6d-bece-b9b9 1 Learned GE1/0/1 Y 1e72-937a-fe7a 1 Learned GE1/0/1 Y 2cfd-a16f-41db 1 Learned GE1/0/1 Y 2cfd-a16f-41e0 1 Learned GE1/0/1 Y 2cfd-a16f-4223 1 Learned GE1/0/1 Y 2cfd-a16f-4225 1 Learned GE1/0/1 Y 300d-9ed7-3b74 1 Learned GE1/0/1 Y 309c-2359-083c 1 Learned GE1/0/1 Y 32df-e4e4-5086 1 Learned GE1/0/1 Y 3497-f625-6f03 1 Learned GE1/0/1 Y 3497-f625-739f 1 Learned GE1/0/1 Y 34f7-1631-3c6d 1 Learned GE1/0/1 Y 3c2a-f4f6-da44 1 Learned GE1/0/1 Y 4268-880c-2778 1 Learned GE1/0/1 Y 507b-9dc4-672b 1 Learned GE1/0/1 Y 6c4b-904d-5508 1 Learned GE1/0/1 Y 74d4-35fc-3baf 1 Learned GE1/0/1 Y 7cb5-9bec-9a86 1 Learned GE1/0/1 Y 808f-1d8f-16fe 1 Learned GE1/0/1 Y 88d7-f642-d302 1 Learned GE1/0/1 Y 943b-b051-1750 1 Learned GE1/0/1 Y 943b-b051-2320 1 Learned GE1/0/1 Y 943b-b051-2420 1 Learned GE1/0/2 Y 943b-b051-2520 1 Learned GE1/0/2 Y 943b-b051-67f0 1 Learned GE1/0/2 Y 943b-b051-c490 1 Learned GE1/0/2 Y 943b-b051-ca80 1 Learned GE1/0/2 Y 943b-b051-ce20 1 Learned GE1/0/2 Y 943b-b051-d200 1 Learned GE1/0/2 Y 943b-b051-d340 1 Learned GE1/0/2 Y 943b-b051-e670 1 Learned GE1/0/2 Y 943b-b052-1190 1 Learned GE1/0/2 Y 9490-34d5-bbe1 1 Learned GE1/0/1 Y 9490-34d5-bbef 1 Learned GE1/0/1 Y 9490-34d5-bbf1 1 Learned GE1/0/1 Y accb-51db-f6e7 1 Learned GE1/0/1 Y be96-b63f-dcae 1 Learned GE1/0/1 Y cc08-fbfd-e78f 1 Learned GE1/0/1 Y d45d-64ab-18a6 1 Learned GE1/0/1 Y d63d-b5f7-a319 1 Learned GE1/0/1 Y dc73-85eb-ac1f 1 Learned GE1/0/1 Y e0d5-5e92-6c4b 1 Learned GE1/0/1 Y e2dc-d04b-fa45 1 Learned GE1/0/1 Y f88c-2109-b9df 1 Learned GE1/0/1 Y fa8d-ec1f-1881 1 Learned GE1/0/1 Y 7cb5-9bec-9a86 10 Learned GE1/0/5 Y 7cb5-9bec-9a87 10 Learned GE1/0/5 Y 040e-3c62-b098 100 Client WLAN-BSS1/0/4 N 066c-f126-3549 100 Client WLAN-BSS1/0/8 N 0c93-8ff9-adc1 100 Client WLAN-BSS1/0/42 N 1413-3331-d0df 100 Client WLAN-BSS1/0/8 N 147d-dae1-63c6 100 Client WLAN-BSS1/0/5 N 14c6-975f-979b 100 Client WLAN-BSS1/0/8 N 1649-0bcf-31d3 100 Client WLAN-BSS1/0/5 N 2202-ef6c-7671 100 Client WLAN-BSS1/0/4 N 226e-9c98-ddd6 100 Client WLAN-BSS1/0/1 N 2276-84ee-7d89 100 Client WLAN-BSS1/0/7 N 22f3-9308-089e 100 Client WLAN-BSS1/0/53 N 2406-aa0c-f05d 100 Client WLAN-BSS1/0/5 N 2479-f380-d6eb 100 Client WLAN-BSS1/0/15 N 2cd9-74d2-2bc0 100 Client WLAN-BSS1/0/34 N 2e98-0262-94b2 100 Client WLAN-BSS1/0/3 N 304f-00a2-98c5 100 Client WLAN-BSS1/0/5 N 32c9-c109-1a7b 100 Client WLAN-BSS1/0/10 N 3e31-2537-8aa1 100 Client WLAN-BSS1/0/8 N 4466-fc9d-3327 100 Client WLAN-BSS1/0/46 N 4cea-ae1a-0353 100 Client WLAN-BSS1/0/15 N 4cea-aee6-fe13 100 Client WLAN-BSS1/0/58 N 5492-0972-18e0 100 Client WLAN-BSS1/0/8 N 6007-c4d7-7367 100 Client WLAN-BSS1/0/22 N 62e8-5d8a-c8de 100 Client WLAN-BSS1/0/52 N 66da-d947-0e6d 100 Client WLAN-BSS1/0/52 N 68a0-3e0f-a8a4 100 Client WLAN-BSS1/0/45 N 6c5c-14b7-4055 100 Client WLAN-BSS1/0/5 N 708f-4765-505d 100 Client WLAN-BSS1/0/42 N 725b-1b4a-f4f1 100 Client WLAN-BSS1/0/42 N 72b3-52e2-9393 100 Client WLAN-BSS1/0/8 N 72ed-14da-d135 100 Client WLAN-BSS1/0/5 N 7836-ccf3-41fb 100 Client WLAN-BSS1/0/62 N 7a06-25d1-854a 100 Client WLAN-BSS1/0/27 N 7a74-0c97-8223 100 Client WLAN-BSS1/0/51 N 8c7a-3dab-4c72 100 Client WLAN-BSS1/0/20 N a235-5b13-eaa5 100 Client WLAN-BSS1/0/12 N a2bc-542d-ce83 100 Client WLAN-BSS1/0/7 N a6e1-a489-f9e2 100 Client WLAN-BSS1/0/8 N a87d-12af-357d 100 Client WLAN-BSS1/0/7 N a8a7-95cb-1439 100 Client WLAN-BSS1/0/8 N aeed-b09d-3fb6 100 Client WLAN-BSS1/0/7 N b222-7f42-90fa 100 Client WLAN-BSS1/0/22 N b29d-c47f-bb20 100 Client WLAN-BSS1/0/52 N b4cb-5702-c08b 100 Client WLAN-BSS1/0/22 N c0a5-ddd2-6cc7 100 Client WLAN-BSS1/0/6 N c205-f70b-cadf 100 Client WLAN-BSS1/0/12 N c267-ceb0-2645 100 Client WLAN-BSS1/0/4 N c2ce-556e-1088 100 Client WLAN-BSS1/0/52 N cc81-2ab4-c711 100 Client WLAN-BSS1/0/18 N d097-fe2a-fe78 100 Client WLAN-BSS1/0/43 N d231-74b5-401f 100 Client WLAN-BSS1/0/8 N d460-75ef-9f18 100 Client WLAN-BSS1/0/44 N d613-ad03-015e 100 Client WLAN-BSS1/0/52 N e0cc-f8a4-a87f 100 Client WLAN-BSS1/0/5 N e0e0-fc27-eb31 100 Client WLAN-BSS1/0/52 N e213-84c1-5bb9 100 Client WLAN-BSS1/0/23 N e216-32f1-a6b3 100 Client WLAN-BSS1/0/7 N eab4-fbe9-7fbb 100 Client WLAN-BSS1/0/16 N f257-eb51-edca 100 Client WLAN-BSS1/0/15 N f8d0-277e-1375 100 Client WLAN-BSS1/0/6 N fcfc-482e-e15f 100 Client WLAN-BSS1/0/22 N ==================================================================== =============================================== ===============display fib=============== Destination count: 137 FIB entry count: 137 Flag: U:Useable G:Gateway H:Host B:Blackhole D:Dynamic S:Static R:Relay F:FRR Destination/Mask Nexthop Flag OutInterface/Token Label 0.0.0.0/0 61.138.113.169 USG GE1/0/7 Null 0.0.0.0/32 127.0.0.1 UH InLoop0 Null 10.12.1.0/30 10.12.1.1 U Vlan10 Null 10.12.1.0/32 10.12.1.1 UBH Vlan10 Null 10.12.1.1/32 127.0.0.1 UH InLoop0 Null 10.12.1.2/32 10.12.1.2 UH Vlan10 Null 10.12.1.3/32 10.12.1.1 UBH Vlan10 Null 61.138.113.168/29 61.138.113.174 U GE1/0/7 Null 61.138.113.168/32 61.138.113.174 UBH GE1/0/7 Null 61.138.113.169/32 61.138.113.169 UH GE1/0/7 Null 61.138.113.174/32 127.0.0.1 UH InLoop0 Null 61.138.113.175/32 61.138.113.174 UBH GE1/0/7 Null 127.0.0.0/8 127.0.0.1 U InLoop0 Null 127.0.0.0/32 127.0.0.1 UH InLoop0 Null 127.0.0.1/32 127.0.0.1 UH InLoop0 Null 127.255.255.255/32 127.0.0.1 UH InLoop0 Null 172.16.100.0/22 172.16.100.1 U Vlan100 Null 172.16.100.0/32 172.16.100.1 UBH Vlan100 Null 172.16.100.1/32 127.0.0.1 UH InLoop0 Null 172.16.100.2/32 172.16.100.2 UH Vlan100 Null 172.16.100.3/32 172.16.100.3 UH Vlan100 Null 172.16.100.4/32 172.16.100.4 UH Vlan100 Null 172.16.100.5/32 172.16.100.5 UH Vlan100 Null 172.16.100.6/32 172.16.100.6 UH Vlan100 Null 172.16.100.7/32 172.16.100.7 UH Vlan100 Null 172.16.100.8/32 172.16.100.8 UH Vlan100 Null 172.16.100.9/32 172.16.100.9 UH Vlan100 Null 172.16.100.10/32 172.16.100.10 UH Vlan100 Null 172.16.100.11/32 172.16.100.11 UH Vlan100 Null 172.16.100.12/32 172.16.100.12 UH Vlan100 Null 172.16.100.13/32 172.16.100.13 UH Vlan100 Null 172.16.100.14/32 172.16.100.14 UH Vlan100 Null 172.16.100.15/32 172.16.100.15 UH Vlan100 Null 172.16.100.16/32 172.16.100.16 UH Vlan100 Null 172.16.100.17/32 172.16.100.17 UH Vlan100 Null 172.16.100.18/32 172.16.100.18 UH Vlan100 Null 172.16.100.19/32 172.16.100.19 UH Vlan100 Null 172.16.100.20/32 172.16.100.20 UH Vlan100 Null 172.16.100.22/32 172.16.100.22 UH Vlan100 Null 172.16.100.23/32 172.16.100.23 UH Vlan100 Null 172.16.100.25/32 172.16.100.25 UH Vlan100 Null 172.16.100.26/32 172.16.100.26 UH Vlan100 Null 172.16.100.27/32 172.16.100.27 UH Vlan100 Null 172.16.100.29/32 172.16.100.29 UH Vlan100 Null 172.16.100.30/32 172.16.100.30 UH Vlan100 Null 172.16.100.31/32 172.16.100.31 UH Vlan100 Null 172.16.100.33/32 172.16.100.33 UH Vlan100 Null 172.16.100.34/32 172.16.100.34 UH Vlan100 Null 172.16.100.35/32 172.16.100.35 UH Vlan100 Null 172.16.100.36/32 172.16.100.36 UH Vlan100 Null 172.16.100.37/32 172.16.100.37 UH Vlan100 Null 172.16.100.38/32 172.16.100.38 UH Vlan100 Null 172.16.100.41/32 172.16.100.41 UH Vlan100 Null 172.16.100.42/32 172.16.100.42 UH Vlan100 Null 172.16.100.43/32 172.16.100.43 UH Vlan100 Null 172.16.100.44/32 172.16.100.44 UH Vlan100 Null 172.16.100.45/32 172.16.100.45 UH Vlan100 Null 172.16.100.46/32 172.16.100.46 UH Vlan100 Null 172.16.100.47/32 172.16.100.47 UH Vlan100 Null 172.16.100.48/32 172.16.100.48 UH Vlan100 Null 172.16.100.49/32 172.16.100.49 UH Vlan100 Null 172.16.100.50/32 172.16.100.50 UH Vlan100 Null 172.16.100.51/32 172.16.100.51 UH Vlan100 Null 172.16.100.52/32 172.16.100.52 UH Vlan100 Null 172.16.100.53/32 172.16.100.53 UH Vlan100 Null 172.16.100.54/32 172.16.100.54 UH Vlan100 Null 172.16.100.56/32 172.16.100.56 UH Vlan100 Null 172.16.100.57/32 172.16.100.57 UH Vlan100 Null 172.16.100.58/32 172.16.100.58 UH Vlan100 Null 172.16.100.59/32 172.16.100.59 UH Vlan100 Null 172.16.100.60/32 172.16.100.60 UH Vlan100 Null 172.16.100.61/32 172.16.100.61 UH Vlan100 Null 172.16.100.62/32 172.16.100.62 UH Vlan100 Null 172.16.100.63/32 172.16.100.63 UH Vlan100 Null 172.16.100.66/32 172.16.100.66 UH Vlan100 Null 172.16.100.87/32 172.16.100.87 UH Vlan100 Null 172.16.100.116/32 172.16.100.116 UH Vlan100 Null 172.16.100.120/32 172.16.100.120 UH Vlan100 Null 172.16.100.138/32 172.16.100.138 UH Vlan100 Null 172.16.100.139/32 172.16.100.139 UH Vlan100 Null 172.16.100.140/32 172.16.100.140 UH Vlan100 Null 172.16.100.147/32 172.16.100.147 UH Vlan100 Null 172.16.100.150/32 172.16.100.150 UH Vlan100 Null 172.16.103.255/32 172.16.100.1 UBH Vlan100 Null 192.168.0.0/21 192.168.0.100 U Vlan1 Null 192.168.0.0/32 192.168.0.100 UBH Vlan1 Null 192.168.0.1/32 192.168.0.1 UH Vlan1 Null 192.168.0.100/32 127.0.0.1 UH InLoop0 Null 192.168.1.1/32 192.168.1.1 UH Vlan1 Null 192.168.1.10/32 192.168.1.10 UH Vlan1 Null 192.168.1.11/32 192.168.1.11 UH Vlan1 Null 192.168.1.14/32 192.168.1.14 UH Vlan1 Null 192.168.1.15/32 192.168.1.15 UH Vlan1 Null 192.168.1.16/32 192.168.1.16 UH Vlan1 Null 192.168.1.20/32 192.168.1.20 UH Vlan1 Null 192.168.1.22/32 192.168.1.22 UH Vlan1 Null 192.168.1.23/32 192.168.1.23 UH Vlan1 Null 192.168.1.24/32 192.168.1.24 UH Vlan1 Null 192.168.1.25/32 192.168.1.25 UH Vlan1 Null 192.168.1.27/32 192.168.1.27 UH Vlan1 Null 192.168.1.30/32 192.168.1.30 UH Vlan1 Null 192.168.1.31/32 192.168.1.31 UH Vlan1 Null 192.168.1.32/32 192.168.1.32 UH Vlan1 Null 192.168.1.33/32 192.168.1.33 UH Vlan1 Null 192.168.1.34/32 192.168.1.34 UH Vlan1 Null 192.168.1.35/32 192.168.1.35 UH Vlan1 Null 192.168.1.36/32 192.168.1.36 UH Vlan1 Null 192.168.1.37/32 192.168.1.37 UH Vlan1 Null 192.168.1.39/32 192.168.1.39 UH Vlan1 Null 192.168.1.40/32 192.168.1.40 UH Vlan1 Null 192.168.1.41/32 192.168.1.41 UH Vlan1 Null 192.168.1.42/32 192.168.1.42 UH Vlan1 Null 192.168.1.43/32 192.168.1.43 UH Vlan1 Null 192.168.1.44/32 192.168.1.44 UH Vlan1 Null 192.168.1.45/32 192.168.1.45 UH Vlan1 Null 192.168.1.46/32 192.168.1.46 UH Vlan1 Null 192.168.1.47/32 192.168.1.47 UH Vlan1 Null 192.168.1.48/32 192.168.1.48 UH Vlan1 Null 192.168.1.50/32 192.168.1.50 UH Vlan1 Null 192.168.1.51/32 192.168.1.51 UH Vlan1 Null 192.168.1.52/32 192.168.1.52 UH Vlan1 Null 192.168.1.54/32 192.168.1.54 UH Vlan1 Null 192.168.1.56/32 192.168.1.56 UH Vlan1 Null 192.168.1.57/32 192.168.1.57 UH Vlan1 Null 192.168.1.58/32 192.168.1.58 UH Vlan1 Null 192.168.1.59/32 192.168.1.59 UH Vlan1 Null 192.168.1.60/32 192.168.1.60 UH Vlan1 Null 192.168.1.62/32 192.168.1.62 UH Vlan1 Null 192.168.1.65/32 192.168.1.65 UH Vlan1 Null 192.168.1.99/32 192.168.1.99 UH Vlan1 Null 192.168.1.101/32 192.168.1.101 UH Vlan1 Null 192.168.1.108/32 192.168.1.108 UH Vlan1 Null 192.168.1.109/32 192.168.1.109 UH Vlan1 Null 192.168.7.255/32 192.168.0.100 UBH Vlan1 Null 224.0.0.0/4 0.0.0.0 UB NULL0 Null 224.0.0.0/24 0.0.0.0 UB NULL0 Null 255.255.255.255/32 127.0.0.1 UH InLoop0 Null ================================================= ===============fib running-status=============== IPv4 FIB prefix public: hash[4] IPv4 FIB prefix VPN: radix IPv6 FIB prefix public: radix IPv6 FIB prefix VPN: radix DbgFlag: 0 MaxVrfIndex: 2047 ------IPv4 FIB prefix------ Tick: 0x1d1, FfTick: 0x3e8, DlinkCnt: 0, ReDrvCnt: 0, CurNode: 0, Epoch: 0x1 ------IPv6 FIB prefix------ Tick: 0, FfTick: 0, DlinkCnt: 0, ReDrvCnt: 0, CurNode: 0, Epoch: 0 ------VN------ Tick: 0x1f, FfTick: 0xa, DlinkCnt: 0, ReDrvCnt: 0, CurNode: 0, Epoch: 0x1,0,0,0,0 ================================================================= ===============fib statistic=============== *** FIB4PREFIX_DEAL INFO *** Refresh_MSG :19 Delete_MSG :0 Create_Node :465 Delete_Node :328 Add_Entry :26 Add_ArpHost :522 Del_Entry :1 Del_ArpHost :410 Del_NotFound :0 Invalid_ReDrv :0 Age_Num :0 Drv_Add :995 Drv_Delete :328 Drv_Refresh :534 *** FIB4PREFIX_ERR INFO *** Invalid_PreMsg:0 Invalid_ArpHost:0 Invalid_FWD :62 Invalid_Info :0 Invalid_FF :0 Invalid_LoadSh:0 Invalid_DrvRef:0 Invalid_Search:0 Err_Refresh :0 Err_Delete :0 Err_AddNode :0 Err_AgeMsg :0 Drv_NoRes :0 Drv_Other :0 Drv_DelErr :0 Que_Write :0 Mem_FIBEntry :0 Mem_ArpHost :0 Mem_L3Route :0 Mem_AsynMsg :0 Mem_DrvChg :0 SYNC_DrvInfo :0 SYNC_AgeInfo :0 BindVN :0 VNSearch :0 *** FIB6PREFIX_DEAL INFO *** Refresh_MSG :0 Delete_MSG :0 Create_Node :0 Delete_Node :0 Add_Entry :0 Add_NDHost :0 Del_Entry :0 Del_NDHost :0 Del_NotFound :0 Invalid_ReDrv :0 Age_Num :0 Drv_Add :0 Drv_Delete :0 Drv_Refresh :0 *** FIB6PREFIX_ERR INFO *** Invalid_PreMsg:0 Invalid_NDHost:0 Invalid_FWD :0 Invalid_Info :0 Invalid_FF :0 Invalid_LoadSh:0 Invalid_DrvRef:0 Invalid_Search:0 Err_Refresh :0 Err_Delete :0 Err_AddNode :0 Err_AgeMsg :0 Drv_NoRes :0 Drv_Other :0 Drv_DelErr :0 Que_Write :0 Mem_FIBEntry :0 Mem_NDHost :0 Mem_L3Route :0 Mem_AsynMsg :0 Mem_DrvChg :0 SYNC_DrvInfo :0 SYNC_AgeInfo :0 BindVN :0 VNSearch :0 *** VN_DEAL INFO *** Refresh_Msg :11 Delete_Msg :0 Create_VN :8 Delete_VN :0 Del_NotFound :0 Age_Num :0 Bind Nexthop :8 UnBind Nexthop:0 Drv_Add :8 Drv_Refresh :1 Drv_Del :0 Ref_Notify :1 Drv_NoneRouteAddSyn:0 *** VN_ERR INFO *** Invalid_NbrMsg:0 Err_Refresh :0 Err_Delete :0 Err_Create :0 Err_BindAdj :0 Err_BfdCreate :0 Err_AgeMsg :0 Drv_NoRes :0 Drv_Other :0 Drv_DelErr :0 Ref_Drv :0 Mem_ADJChg :0 Mem_L3ADJ :0 Mem_Asyn :0 Mem_RefInfo :0 Mem_Nexthop :0 Nbr_Proc :0 Ref_Notify :0 Write_Que :0 SYNC_DrvInfo :0 SYNC_AgeInfo :0 *** COM_ERR INFO *** QueGetFd :0 EpCtl :0 EpCtlAddQue :0 GetAdjInfo :0 Dactive :0 Active :0 SendSmooth :0 SocketFailed :0 SetSockOpt :0 ConnectFailed :0 SendUpgrade :0 SendDowngrade :0 AllocMsg :0 MsgContinue :0 malloc :0 Que_Write :0 SYNC_RTMsg :0 LastRTMsg :0 GetNhlfeInfo :0 ================================================================= ===============display arp all=============== Type: S-Static D-Dynamic O-Openflow R-Rule I-Invalid IP address MAC address SVID Interface Aging Type 61.138.113.169 b443-2652-2150 -- GE1/0/7 20 D 10.12.1.2 7cb5-9bec-9a87 10 GE1/0/5 1 D 192.168.1.22 943b-b051-2520 1 GE1/0/2 1 D 192.168.1.23 943b-b051-c490 1 GE1/0/2 1 D 192.168.1.30 943b-b051-67f0 1 GE1/0/2 2 D 192.168.1.32 943b-b051-ce20 1 GE1/0/2 2 D 192.168.1.34 943b-b051-d340 1 GE1/0/2 2 D 192.168.1.35 943b-b051-d200 1 GE1/0/2 2 D 192.168.1.37 943b-b051-2420 1 GE1/0/2 2 D 192.168.1.39 943b-b051-ca80 1 GE1/0/2 2 D 192.168.1.40 943b-b052-1190 1 GE1/0/2 2 D 192.168.1.59 943b-b051-e670 1 GE1/0/2 3 D 192.168.1.1 7cb5-9bec-9a86 1 GE1/0/1 20 D 192.168.1.10 808f-1d8f-16fe 1 GE1/0/1 18 D 192.168.1.11 32df-e4e4-5086 1 GE1/0/1 20 D 192.168.1.14 00d8-612c-8aaf 1 GE1/0/1 17 D 192.168.1.15 9490-34d5-bbf1 1 GE1/0/1 20 D 192.168.1.16 9490-34d5-bbef 1 GE1/0/1 20 D 192.168.1.20 9490-34d5-bbe1 1 GE1/0/1 20 D 192.168.1.24 943b-b051-1750 1 GE1/0/1 2 D 192.168.1.31 943b-b051-2370 1 GE1/0/1 2 D 192.168.1.33 943b-b051-5330 1 GE1/0/1 2 D 192.168.1.41 943b-b051-1740 1 GE1/0/1 2 D 192.168.1.43 3c2a-f4f6-da44 1 GE1/0/1 20 D 192.168.1.45 943b-b051-2320 1 GE1/0/1 2 D 192.168.1.52 0c9d-920f-b0ff 1 GE1/0/1 2 D 192.168.1.62 507b-9dc4-672b 1 GE1/0/1 20 D 192.168.1.65 18c0-4d6c-ef0d 1 GE1/0/1 20 D 192.168.1.99 5475-9580-314b 1 GE1/0/1 8 D 192.168.1.101 1e72-937a-fe7a 1 GE1/0/1 20 D 192.168.1.108 18c0-4d6d-214c 1 GE1/0/1 11 D 192.168.1.109 88d7-f642-d302 1 GE1/0/1 16 D 192.168.1.25 00be-d5b3-af40 1 GE1/0/3 2 D 192.168.1.27 00be-d5b4-03c0 1 GE1/0/3 2 D 192.168.1.36 00be-d5b3-9880 1 GE1/0/3 2 D 192.168.1.42 00be-d5b3-a4a0 1 GE1/0/3 2 D 192.168.1.44 00be-d5b3-9ae0 1 GE1/0/3 2 D 192.168.1.46 00be-d5b3-ad40 1 GE1/0/3 2 D 192.168.1.47 00be-d5b4-0000 1 GE1/0/3 2 D 192.168.1.48 00be-d5b3-a640 1 GE1/0/3 2 D 192.168.1.50 00be-d5b3-a480 1 GE1/0/3 2 D 192.168.1.51 00be-d5b3-98c0 1 GE1/0/3 2 D 192.168.1.54 00be-d5b3-ab80 1 GE1/0/3 2 D 192.168.1.56 00be-d5b3-a1a0 1 GE1/0/3 2 D 192.168.1.57 00be-d5b3-9920 1 GE1/0/3 3 D 192.168.1.58 00be-d5b4-0220 1 GE1/0/3 3 D 192.168.1.60 00be-d5b3-9800 1 GE1/0/3 3 D 172.16.100.25 2202-ef6c-7671 100 WLAN-BSS1/0/4 20 D 172.16.100.60 c267-ceb0-2645 100 WLAN-BSS1/0/4 20 D 172.16.100.147 040e-3c62-b098 100 WLAN-BSS1/0/4 13 D 172.16.100.9 aeed-b09d-3fb6 100 WLAN-BSS1/0/7 19 D 172.16.100.12 a87d-12af-357d 100 WLAN-BSS1/0/7 11 D 172.16.100.36 a2bc-542d-ce83 100 WLAN-BSS1/0/7 20 D 172.16.100.48 2276-84ee-7d89 100 WLAN-BSS1/0/7 20 D 172.16.100.54 e216-32f1-a6b3 100 WLAN-BSS1/0/7 20 D 172.16.100.6 226e-9c98-ddd6 100 WLAN-BSS1/0/1 14 D 172.16.100.116 f8d0-277e-1375 100 WLAN-BSS1/0/6 20 D 172.16.100.138 c0a5-ddd2-6cc7 100 WLAN-BSS1/0/6 20 D 172.16.100.7 1649-0bcf-31d3 100 WLAN-BSS1/0/5 11 D 172.16.100.10 6c5c-14b7-4055 100 WLAN-BSS1/0/5 20 D 172.16.100.13 72ed-14da-d135 100 WLAN-BSS1/0/5 20 D 172.16.100.17 147d-dae1-63c6 100 WLAN-BSS1/0/5 20 D 172.16.100.18 2406-aa0c-f05d 100 WLAN-BSS1/0/5 17 D 172.16.100.19 304f-00a2-98c5 100 WLAN-BSS1/0/5 11 D 172.16.100.26 e0cc-f8a4-a87f 100 WLAN-BSS1/0/5 11 D 172.16.100.15 8c7a-3dab-4c72 100 WLAN-BSS1/0/20 2 D 172.16.100.16 f257-eb51-edca 100 WLAN-BSS1/0/15 16 D 172.16.100.29 4cea-ae1a-0353 100 WLAN-BSS1/0/15 17 D 172.16.100.33 2479-f380-d6eb 100 WLAN-BSS1/0/15 14 D 172.16.100.2 d231-74b5-401f 100 WLAN-BSS1/0/8 19 D 172.16.100.5 a6e1-a489-f9e2 100 WLAN-BSS1/0/8 20 D 172.16.100.8 3e31-2537-8aa1 100 WLAN-BSS1/0/8 19 D 172.16.100.27 14c6-975f-979b 100 WLAN-BSS1/0/8 15 D 172.16.100.35 2218-ce9a-91fb 100 WLAN-BSS1/0/8 9 D 172.16.100.52 5492-0972-18e0 100 WLAN-BSS1/0/8 14 D 172.16.100.62 066c-f126-3549 100 WLAN-BSS1/0/8 20 D 172.16.100.87 a6e1-a489-f9e2 100 WLAN-BSS1/0/8 20 D 172.16.100.140 a8a7-95cb-1439 100 WLAN-BSS1/0/8 13 D 172.16.100.150 1413-3331-d0df 100 WLAN-BSS1/0/8 5 D 172.16.100.22 2cd9-74d2-2bc0 100 WLAN-BSS1/0/34 17 D 172.16.100.37 fcfc-482e-e15f 100 WLAN-BSS1/0/22 20 D 172.16.100.47 b222-7f42-90fa 100 WLAN-BSS1/0/22 5 D 172.16.100.53 b4cb-5702-c08b 100 WLAN-BSS1/0/22 20 D 172.16.100.31 4466-fc9d-3327 100 WLAN-BSS1/0/46 20 D 172.16.100.4 d460-75ef-9f18 100 WLAN-BSS1/0/44 19 D 172.16.100.20 e0e0-fc27-eb31 100 WLAN-BSS1/0/52 12 D 172.16.100.34 62e8-5d8a-c8de 100 WLAN-BSS1/0/52 20 D 172.16.100.42 c2ce-556e-1088 100 WLAN-BSS1/0/52 18 D 172.16.100.59 d613-ad03-015e 100 WLAN-BSS1/0/52 15 D 172.16.100.63 66da-d947-0e6d 100 WLAN-BSS1/0/52 17 D 172.16.100.45 68a0-3e0f-a8a4 100 WLAN-BSS1/0/45 4 D 172.16.100.46 22f3-9308-089e 100 WLAN-BSS1/0/53 17 D 172.16.100.38 e213-84c1-5bb9 100 WLAN-BSS1/0/23 20 D 172.16.100.50 7a74-0c97-8223 100 WLAN-BSS1/0/51 19 D 172.16.100.49 a235-5b13-eaa5 100 WLAN-BSS1/0/12 20 D 172.16.100.66 c205-f70b-cadf 100 WLAN-BSS1/0/12 19 D 172.16.100.120 c205-f70b-cadf 100 WLAN-BSS1/0/12 19 D 172.16.100.41 7836-ccf3-41fb 100 WLAN-BSS1/0/62 20 D 172.16.100.57 d097-fe2a-fe78 100 WLAN-BSS1/0/43 20 D 172.16.100.30 725b-1b4a-f4f1 100 WLAN-BSS1/0/42 20 D 172.16.100.51 0c93-8ff9-adc1 100 WLAN-BSS1/0/42 20 D 172.16.100.56 708f-4765-505d 100 WLAN-BSS1/0/42 8 D 172.16.100.14 4cea-aee6-fe13 100 WLAN-BSS1/0/58 20 D 172.16.100.11 cc81-2ab4-c711 100 WLAN-BSS1/0/18 7 D 172.16.100.44 eab4-fbe9-7fbb 100 WLAN-BSS1/0/16 9 D 172.16.100.23 2e98-0262-94b2 100 WLAN-BSS1/0/3 20 D 172.16.100.43 7a06-25d1-854a 100 WLAN-BSS1/0/27 20 D 172.16.100.58 32c9-c109-1a7b 100 WLAN-BSS1/0/10 20 D =============================================================== ===============arp statistics=============== Entry statistics: Valid = 108 Dummy = 0 Long static = 0 Short resolved = 0 Multiport = 0 L3 short = 0 Packet = 108 OpenFlow = 0 Rule = 0 ARP input = 28316 Resolved = 941 Static statistics: Short static = 0 Long static = 0 Multiport = 0 Disabled = 0 Error statistics: Memory = 0 Sync memory = 0 Packet = 56 Parameter = 5 IF = 0 Walk = 0 Add host route = 0 Del host route = 0 Local address = 0 Real time message = 0 Refresh rule = 0 Delete rule = 0 Smooth rule start = 0 Smooth rule end = 0 Running information: Max ARP = 4096 Max multiport = 0 Default blackhole = 1 Max blackhole = 4096 Timer queue = 0 Event queue = 0 Packet queue = 0 LIPC send queue = 256/0/2 ================================================================= ===============display ip routing-table=============== Destinations : 25 Routes : 25 Destination/Mask Proto Pre Cost NextHop Interface 0.0.0.0/0 Static 60 0 61.138.113.169 GE1/0/7 0.0.0.0/32 Direct 0 0 127.0.0.1 InLoop0 10.12.1.0/30 Direct 0 0 10.12.1.1 Vlan10 10.12.1.0/32 Direct 0 0 10.12.1.1 Vlan10 10.12.1.1/32 Direct 0 0 127.0.0.1 InLoop0 10.12.1.3/32 Direct 0 0 10.12.1.1 Vlan10 61.138.113.168/29 Direct 0 0 61.138.113.174 GE1/0/7 61.138.113.168/32 Direct 0 0 61.138.113.174 GE1/0/7 61.138.113.174/32 Direct 0 0 127.0.0.1 InLoop0 61.138.113.175/32 Direct 0 0 61.138.113.174 GE1/0/7 127.0.0.0/8 Direct 0 0 127.0.0.1 InLoop0 127.0.0.0/32 Direct 0 0 127.0.0.1 InLoop0 127.0.0.1/32 Direct 0 0 127.0.0.1 InLoop0 127.255.255.255/32 Direct 0 0 127.0.0.1 InLoop0 172.16.100.0/22 Direct 0 0 172.16.100.1 Vlan100 172.16.100.0/32 Direct 0 0 172.16.100.1 Vlan100 172.16.100.1/32 Direct 0 0 127.0.0.1 InLoop0 172.16.103.255/32 Direct 0 0 172.16.100.1 Vlan100 192.168.0.0/21 Direct 0 0 192.168.0.100 Vlan1 192.168.0.0/32 Direct 0 0 192.168.0.100 Vlan1 192.168.0.100/32 Direct 0 0 127.0.0.1 InLoop0 192.168.7.255/32 Direct 0 0 192.168.0.100 Vlan1 224.0.0.0/4 Direct 0 0 0.0.0.0 NULL0 224.0.0.0/24 Direct 0 0 0.0.0.0 NULL0 255.255.255.255/32 Direct 0 0 127.0.0.1 InLoop0 =================================================== ===============display ip routing-table statistics=============== Total prefixes: 25 Active prefixes: 25 Proto route active added deleted DIRECT 25 24 25 0 STATIC 1 1 1 0 RIP 0 0 0 0 OSPF 0 0 0 0 IS-IS 0 0 0 0 LISP 0 0 0 0 BGP 0 0 0 0 Total 26 25 26 0 =================================================== ===============display ipv6 fast-forwarding cache=============== IP6Stack is not configured. ========================================================== ===============display ipv6 fib=============== Destination count: 0 FIB entry count: 0 Flag: U:Useable G:Gateway H:Host B:Blackhole D:Dynamic S:Static R:Relay F:FRR ============================================= ===============display ipv6 neighbors all=============== IP6Stack is not configured. ====================================================== ===============display ipv6 routing-table=============== ROUTE6 is not configured. ======================================================= ===============display ipv6 routing-table statistics=============== ROUTE6 is not configured. ================================================= ===============display multicast forwarding-table=============== PIM, IPv6 PIM, IGMP snooping or MLD snooping is not configured. ====================================================== ===============display pim neighbor verbose=============== IGMP snooping is not configured. ====================================================== ===============display igmp group verbose=============== IGMP snooping is not configured. ====================================================== ===============display igmp-snooping group verbose=============== IGMP snooping is not configured. ====================================================== ===============display igmp-snooping router-port=============== IGMP snooping is not configured. ====================================================== ===============display l2-multicast ip forwarding=============== PIM, IPv6 PIM, IGMP snooping or MLD snooping is not configured. ====================================================== ===============display l2-multicast mac forwarding=============== PIM, IPv6 PIM, IGMP snooping or MLD snooping is not configured. ==================================================================== ===============display ipv6 multicast forwarding-table=============== PIM, IPv6 PIM, IGMP snooping or MLD snooping is not configured. ====================================================== ===============display ipv6 pim neighbor verbose=============== MLD snooping is not configured. ====================================================== ===============display mld group verbose=============== MLD snooping is not configured. ==================================================================== =============================================== ===============display showdrvdiag=============== ============fpl-diag showmem:============ Free-in OnChip Descriptors Count: FreeIn 00 Start:000 Descriptors:46 FreeIn 01 Start:032 Descriptors:46 FreeIn 02 Start:064 Descriptors:44 FreeIn 03 Start:096 Descriptors:46 FreeIn 04 Start:128 Descriptors:46 FreeIn 05 Start:160 Descriptors:46 FreeIn 06 Start:192 Descriptors:46 FreeIn 07 Start:224 Descriptors:46 Free-in OnSpill Descriptors Count: FreeIn 00 BaseSpill =0x34c00000, Descriptors:3216 FreeIn 01 BaseSpill =0x36a00000, Descriptors:3216 FreeIn 02 BaseSpill =0x34800000, Descriptors:3216 FreeIn 03 BaseSpill =0x34a00000, Descriptors:3216 FreeIn 04 BaseSpill =0x36c00000, Descriptors:3216 FreeIn 05 BaseSpill =0x36e00000, Descriptors:3216 FreeIn 06 BaseSpill =0x34000000, Descriptors:3216 FreeIn 07 BaseSpill =0x34200000, Descriptors:3216 ====================================== =============fpl-diag showdpstat:========= ********************fpl showdpstat: start **************************** idx item stat speed(pps) ---------------------------------------------------------------------- 1 Cpu0UsedRatio 0 0 2 Cpu1UsedRatio 0 0 3 Cpu2UsedRatio 0 0 4 Cpu3UsedRatio 0 0 5 Cpu4UsedRatio 0 0 6 Cpu5UsedRatio 0 0 7 Cpu6UsedRatio 0 0 8 Cpu7UsedRatio 0 0 9 GE1/0/1RxUnicast 7945137 1268 10 GE1/0/1RxBroadcast 36713 9 11 GE1/0/1RxMulticast 77698 31 12 GE1/0/1TxUnicast 3396193 383 13 GE1/0/1TxBroadcast 627 0 14 GE1/0/1TxMulticast 159 0 15 GE1/0/2RxUnicast 1921341 289 16 GE1/0/2RxBroadcast 2118 0 17 GE1/0/2RxMulticast 1260 0 18 GE1/0/2TxUnicast 3099262 949 19 GE1/0/2TxBroadcast 47232 12 20 GE1/0/2TxMulticast 87283 30 21 GE1/0/3RxUnicast 1474543 94 22 GE1/0/3RxBroadcast 3442 0 23 GE1/0/3RxMulticast 1865 0 24 GE1/0/3TxUnicast 4846655 319 25 GE1/0/3TxBroadcast 47175 12 26 GE1/0/3TxMulticast 87283 31 27 GE1/0/4RxUnicast 0 0 28 GE1/0/4RxBroadcast 0 0 29 GE1/0/4RxMulticast 0 0 30 GE1/0/4TxUnicast 0 0 31 GE1/0/4TxBroadcast 0 0 32 GE1/0/4TxMulticast 0 0 33 GE1/0/5RxUnicast 5127544 1313 34 GE1/0/5RxBroadcast 0 0 35 GE1/0/5RxMulticast 85 0 36 GE1/0/5TxUnicast 10825389 3242 37 GE1/0/5TxBroadcast 3 0 38 GE1/0/5TxMulticast 124 0 39 GE1/0/6RxUnicast 0 0 40 GE1/0/6RxBroadcast 0 0 41 GE1/0/6RxMulticast 0 0 42 GE1/0/6TxUnicast 0 0 43 GE1/0/6TxBroadcast 0 0 44 GE1/0/6TxMulticast 0 0 45 GE1/0/7RxUnicast 7916531 2287 46 GE1/0/7RxBroadcast 167 0 47 GE1/0/7RxMulticast 492 0 48 GE1/0/7TxUnicast 5542264 1431 49 GE1/0/7TxBroadcast 6 0 50 GE1/0/7TxMulticast 126 0 51 GE1/0/8RxUnicast 0 0 52 GE1/0/8RxBroadcast 0 0 53 GE1/0/8RxMulticast 0 0 54 GE1/0/8TxUnicast 0 0 55 GE1/0/8TxBroadcast 0 0 56 GE1/0/8TxMulticast 0 0 57 PoeDropPkt 98 0 58 SendRetry 0 0 59 SendFail 0 0 60 SendSwRetry 0 0 61 SendSwFail 0 0 ********************fpl showdpstat: end **************************** ====================================== ============fpl-diag showcpstat:========== ********************fpl showcpstat: start **************************** Idx Proto Rx Drop RxSpeed(pps) --------------------------------------------------------------------- 1 dot1x 0 0 0 2 dhcp 966 0 0 3 igmp 1035 0 0 4 ntp 15 0 0 5 arp 28328 0 4 6 snmp 0 0 0 7 telnet 499 0 0 8 icmp 2108 0 1 9 icmpv6_nd 0 0 0 10 icmpv6_other 0 0 0 11 iactp 0 0 0 12 acsei 0 0 0 13 http 532392 0 176 14 https 8962 0 5 15 openflow 8190 0 3 16 portal 0 0 0 17 udp 66600 0 10 18 tcp 117705 0 0 19 ip 0 0 0 20 ipv6 0 0 0 21 ethernet 3716 0 1 22 radius 0 0 0 23 vrrp 0 0 0 24 capwap_ctrl 95363 0 25 25 capwap_ctrl_dis 68 0 0 26 capwap_data 3561160 0 659 27 dot11_auth 841 0 0 28 dot11_assoc 200 0 0 29 dot11_reassoc 467 0 0 30 dot11_null 0 0 0 31 dot11_disassoc 18 0 0 32 dot11_deauth 81 0 0 33 dot11_action 2299 0 0 34 dot11_ctrl 1257 0 0 35 lacp 0 0 0 ********************fpl showcpstat: end **************************** ====================================== ===========fpl-diag showfelu2fdiag:======= fpl-diag showu2ferror: ---Drv U2f Fwd Error--- FIND_PHYID_FAILED : 0 FIND_CPTD_FUN_FAILED : 0 CPTD_PROC_FAILED : 0 CPTD_PROC_SUCCESS : 0 RCV_PKT_CREAT_MBUF_FAILED : 0 RCV_PKT_TO_PLAT_FAILED_A : 0 RCV_PKT_TO_PLAT_FAILED_B : 0 RCV_PKT_FUN_NULL_DROP_A : 0 RCV_PKT_FUN_NULL_DROP_B : 0 RCV_PKT_STM_PORT_DROP : 0 RCV_PKT_UNKNOWN_PRO_TYPE : 6352 RCV_PKT_STACKPORT_NONPRIVATE : 0 RCV_PKT_STACKPORT_PRI_UNKOWN : 0 RCV_PKT_STACKPORT_NONFORWRD : 0 SND_PKT_NULL_MBUF_A : 0 SND_PKT_NULL_MBUF_B : 0 SND_PKT_NULL_MBUF_C : 0 SND_PKT_INVALID_PHYID_A : 0 SND_PKT_INVALID_PHYID_B : 0 SND_PKT_INVALID_PHYID_C : 0 SND_PKT_INVALID_PHYID_D : 0 SND_PKT_STM_PORT_DROP_A : 0 SND_PKT_STM_PORT_DROP_B : 0 SND_PKT_STM_PORT_DROP_C : 0 SND_PKT_STM_PORT_DROP_D : 0 SND_PKT_STM_PORT_DROP_MBR_A : 0 SND_PKT_STM_PORT_DROP_MBR_B : 0 SND_PKT_STM_PORT_DROP_LIPC_A : 0 SND_PKT_STM_PORT_DROP_MBR_D : 0 SND_PKT_OVERMANY_BLOCK_ERROR_A : 0 SND_PKT_OVERMANY_BLOCK_ERROR_B : 0 SND_PKT_OVERMANY_BLOCK_ERROR_C : 0 SND_PKT_ZEROBYTE_BLOCK_ERROR_A : 0 SND_PKT_ZEROBYTE_BLOCK_ERROR_B : 0 SND_PKT_ZEROBYTE_BLOCK_ERROR_C : 0 SND_PKT_DROP_A : 0 SND_PKT_DROP_B : 0 SND_PKT_DROP_C : 0 RCV_PKT_CREAT_RAWBUF_FAILED : 0 SND_PKT_NULL_RAW : 0 SND_PKT_NULLMBUF_RAW : 173265 SND_PKT_NOT_DRVMEM_RAW : 4353881 SND_PKT_DRVMEM_RAW : 207402 SND_PKT_MANYBLOCK_RAW : 0 SND_PKT_SUCCESS_TD : 0 SND_PKT_FAILED_TD : 0 SND_PKT_PREHANDLE_FAILED : 0 fpl-diag showu2fportstat: ------------ phyport:0 ------------ Type(00):0000000000-0007945142 Type(01):0000000000-0000077698 Type(02):0000000000-0000036713 Type(03):0000000000-0008059553 Type(04):0000000001-2034543613 Type(05):0000000000-0000000000 Type(06):0000000000-0000000000 Type(07):0000000000-0000000000 Type(08):0000000000-0000000000 Type(09):0000000000-0003396247 Type(10):0000000000-0000000159 Type(11):0000000000-0000000627 Type(12):0000000000-0003397033 Type(13):0000000000-1803312577 Type(14):0000000000-0000000000 Type(15):0000000000-0000000000 Type(16):0000000000-0000000000 Type(17):0000000000-0000000000 Type(18):0000000000-0000000000 Type(19):0000000000-0000000000 Type(20):0000000000-0000000000 Type(21):0000000000-0000000000 Type(22):0000000000-0000000000 Type(23):0000000000-0000000000 Type(24):0000000000-0000000000 Type(25):0000000000-0000000000 Type(26):0000000000-0000000000 ------------ phyport:1 ------------ Type(00):0000000000-0001921342 Type(01):0000000000-0000001260 Type(02):0000000000-0000002118 Type(03):0000000000-0001924720 Type(04):0000000000-1315185960 Type(05):0000000000-0000000000 Type(06):0000000000-0000000000 Type(07):0000000000-0000000000 Type(08):0000000000-0000000000 Type(09):0000000000-0003099262 Type(10):0000000000-0000087283 Type(11):0000000000-0000047232 Type(12):0000000000-0003233777 Type(13):0000000000-2169288245 Type(14):0000000000-0000000000 Type(15):0000000000-0000000000 Type(16):0000000000-0000000000 Type(17):0000000000-0000000000 Type(18):0000000000-0000000000 Type(19):0000000000-0000000000 Type(20):0000000000-0000000000 Type(21):0000000000-0000000000 Type(22):0000000000-0000000000 Type(23):0000000000-0000000000 Type(24):0000000000-0000000000 Type(25):0000000000-0000000000 Type(26):0000000000-0000000000 ------------ phyport:2 ------------ Type(00):0000000000-0001474596 Type(01):0000000000-0000001865 Type(02):0000000000-0000003442 Type(03):0000000000-0001479903 Type(04):0000000000-0489547889 Type(05):0000000000-0000000000 Type(06):0000000000-0000000000 Type(07):0000000000-0000000000 Type(08):0000000000-0000000000 Type(09):0000000000-0004846660 Type(10):0000000000-0000087283 Type(11):0000000000-0000047175 Type(12):0000000000-0004981118 Type(13):0000000000-4190369211 Type(14):0000000000-0000000000 Type(15):0000000000-0000000000 Type(16):0000000000-0000000000 Type(17):0000000000-0000000000 Type(18):0000000000-0000000000 Type(19):0000000000-0000000000 Type(20):0000000000-0000000000 Type(21):0000000000-0000000000 Type(22):0000000000-0000000000 Type(23):0000000000-0000000000 Type(24):0000000000-0000000000 Type(25):0000000000-0000000000 Type(26):0000000000-0000000000 ------------ phyport:3 ------------ Type(00):0000000000-0000000000 Type(01):0000000000-0000000000 Type(02):0000000000-0000000000 Type(03):0000000000-0000000000 Type(04):0000000000-0000000000 Type(05):0000000000-0000000000 Type(06):0000000000-0000000000 Type(07):0000000000-0000000000 Type(08):0000000000-0000000000 Type(09):0000000000-0000000000 Type(10):0000000000-0000000000 Type(11):0000000000-0000000000 Type(12):0000000000-0000000000 Type(13):0000000000-0000000000 Type(14):0000000000-0000000000 Type(15):0000000000-0000000000 Type(16):0000000000-0000000000 Type(17):0000000000-0000000000 Type(18):0000000000-0000000000 Type(19):0000000000-0000000000 Type(20):0000000000-0000000000 Type(21):0000000000-0000000000 Type(22):0000000000-0000000000 Type(23):0000000000-0000000000 Type(24):0000000000-0000000000 Type(25):0000000000-0000000000 Type(26):0000000000-0000000000 ------------ phyport:4 ------------ Type(00):0000000000-0005127603 Type(01):0000000000-0000000085 Type(02):0000000000-0000000000 Type(03):0000000000-0005127688 Type(04):0000000000-2188454532 Type(05):0000000000-0000000000 Type(06):0000000000-0000000000 Type(07):0000000000-0000000000 Type(08):0000000000-0000000000 Type(09):0000000000-0010825402 Type(10):0000000000-0000000124 Type(11):0000000000-0000000003 Type(12):0000000000-0010825529 Type(13):0000000002-0470189078 Type(14):0000000000-0000000000 Type(15):0000000000-0000000000 Type(16):0000000000-0000000000 Type(17):0000000000-0000000000 Type(18):0000000000-0000000000 Type(19):0000000000-0000000000 Type(20):0000000000-0000000000 Type(21):0000000000-0000000000 Type(22):0000000000-0000000000 Type(23):0000000000-0000000000 Type(24):0000000000-0000000000 Type(25):0000000000-0000000000 Type(26):0000000000-0000000000 ------------ phyport:5 ------------ Type(00):0000000000-0000000000 Type(01):0000000000-0000000000 Type(02):0000000000-0000000000 Type(03):0000000000-0000000000 Type(04):0000000000-0000000000 Type(05):0000000000-0000000000 Type(06):0000000000-0000000000 Type(07):0000000000-0000000000 Type(08):0000000000-0000000000 Type(09):0000000000-0000000000 Type(10):0000000000-0000000000 Type(11):0000000000-0000000000 Type(12):0000000000-0000000000 Type(13):0000000000-0000000000 Type(14):0000000000-0000000000 Type(15):0000000000-0000000000 Type(16):0000000000-0000000000 Type(17):0000000000-0000000000 Type(18):0000000000-0000000000 Type(19):0000000000-0000000000 Type(20):0000000000-0000000000 Type(21):0000000000-0000000000 Type(22):0000000000-0000000000 Type(23):0000000000-0000000000 Type(24):0000000000-0000000000 Type(25):0000000000-0000000000 Type(26):0000000000-0000000000 ------------ phyport:6 ------------ Type(00):0000000000-0007916544 Type(01):0000000000-0000000492 Type(02):0000000000-0000000167 Type(03):0000000000-0007917203 Type(04):0000000001-4180055655 Type(05):0000000000-0000000000 Type(06):0000000000-0000000000 Type(07):0000000000-0000000000 Type(08):0000000000-0000000000 Type(09):0000000000-0005542325 Type(10):0000000000-0000000126 Type(11):0000000000-0000000006 Type(12):0000000000-0005542457 Type(13):0000000000-1922567400 Type(14):0000000000-0000000000 Type(15):0000000000-0000000000 Type(16):0000000000-0000000000 Type(17):0000000000-0000000000 Type(18):0000000000-0000000000 Type(19):0000000000-0000000000 Type(20):0000000000-0000000000 Type(21):0000000000-0000000000 Type(22):0000000000-0000000000 Type(23):0000000000-0000000000 Type(24):0000000000-0000000000 Type(25):0000000000-0000000000 Type(26):0000000000-0000000000 ------------ phyport:7 ------------ Type(00):0000000000-0000000000 Type(01):0000000000-0000000000 Type(02):0000000000-0000000000 Type(03):0000000000-0000000000 Type(04):0000000000-0000000000 Type(05):0000000000-0000000000 Type(06):0000000000-0000000000 Type(07):0000000000-0000000000 Type(08):0000000000-0000000000 Type(09):0000000000-0000000000 Type(10):0000000000-0000000000 Type(11):0000000000-0000000000 Type(12):0000000000-0000000000 Type(13):0000000000-0000000000 Type(14):0000000000-0000000000 Type(15):0000000000-0000000000 Type(16):0000000000-0000000000 Type(17):0000000000-0000000000 Type(18):0000000000-0000000000 Type(19):0000000000-0000000000 Type(20):0000000000-0000000000 Type(21):0000000000-0000000000 Type(22):0000000000-0000000000 Type(23):0000000000-0000000000 Type(24):0000000000-0000000000 Type(25):0000000000-0000000000 Type(26):0000000000-0000000000 fpl-diag showfwdthreadinfo: --------------------------------- CoreNum: 2, ulVcpuNum: 8, MaxCpuUsed: 12.50% FwdThreadStart: 3, FwdThreadNum: 5. --------------------------------- ====================================== ==========fpl-diag showsendfailed:======== g_ulSendretry=0 g_ulSendfailed=0 g_ulSendswretry=0 g_ulSendswfailed=0 ====================================== =====fpl-diag showhalfwdmbufreferr:======= g_ulHalFwdMbufRefErr[0] = 0 g_ulHalFwdMbufRefErr[1] = 0 g_ulHalFwdMbufRefErr[2] = 0 g_ulHalFwdMbufRefErr[3] = 0 g_ulHalFwdMbufRefErr[4] = 0 g_ulHalFwdMbufRefErr[5] = 0 g_ulHalFwdMbufRefErr[6] = 0 g_ulHalFwdMbufRefErr[7] = 0 g_ulHalFwdMbufRefErr[8] = 0 g_ulHalFwdMbufRefErr[9] = 0 g_ulHalFwdMbufRefErr[10] = 0 g_ulHalFwdMbufRefErr[11] = 0 g_ulHalFwdMbufRefErr[12] = 0 g_ulHalFwdMbufRefErr[13] = 0 g_ulHalFwdMbufRefErr[14] = 0 g_ulHalFwdMbufRefErr[15] = 0 g_ulHalFwdMbufRefErr[16] = 0 g_ulHalFwdMbufRefErr[17] = 0 g_ulHalFwdMbufRefErr[18] = 0 g_ulHalFwdMbufRefErr[19] = 0 g_ulHalFwdMbufRefErr[20] = 0 g_ulHalFwdMbufRefErr[21] = 0 g_ulHalFwdMbufRefErr[22] = 0 g_ulHalFwdMbufRefErr[23] = 0 g_ulHalFwdMbufRefErr[24] = 0 g_ulHalFwdMbufRefErr[25] = 0 g_ulHalFwdMbufRefErr[26] = 0 g_ulHalFwdMbufRefErr[27] = 0 g_ulHalFwdMbufRefErr[28] = 0 g_ulHalFwdMbufRefErr[29] = 0 g_ulHalFwdMbufRefErr[30] = 0 g_ulHalFwdMbufRefErr[31] = 0 ====================================== ========fpl-diag showbufrefree:=========== BufRefreeEnable = 1 BufInQueueNum = 0 BufRefreeSuccNum = 0 DequeueFailedNum = 0 BufDropNum = 0 BufTypeErrNum = 0 BufRefreeTimerCnt = 3604 MsgSendFailCnt = 0 MsgSendSucCnt = 901617 ====================================== =========diag log display:================ Not found saved log entrys. ====================================== =========fpl-diag showcputotalcount:====== ulPrcTotalPkt: 175fa8f ultotalpktcnt: 175fa8f ulLowOkTotalPkt: 172e26d ulHighOkTotalPkt: 31822 ulTopOkTotalPkt: 0 ulPrcDropTotalPkt: 0 ulPrcDropRxErrTotalPkt: 0 ulPrcPktStopTotalPkt: 0 ulPktToUpTotalPkt: 175e1bf ulPktToUpErrTotalPkt: 18d0 ====================================== =========fpl-diag showdrvpkterr:========= g_ulMsgFbErrorCnt = 0 g_ulBufInvalidCount = 0 g_ulInvalidBuf = 0 g_ulWhileRetryLimitCnt = 0 ====================================== =========fpl-diag dumpucoreinfoall:====== ------------------------------------------ start dumping ucore info --------------------------------------------- UCORE NO : 0 1 2 3 4 5 6 7 Total init : 1 1 1 1 1 1 1 1 8 ReceiveAll : 23908220 696747 5059 27 0 0 0 0 24610053 ParseError : 0 0 0 0 0 0 0 0 0 InterfaceError : 0 0 0 0 0 0 0 0 0 ForwardThreadDead : 0 0 0 0 0 0 0 0 0 ReceiveCorrect : 23908220 696747 5059 27 0 0 0 0 24610053 EthPacketHigh : 0 0 0 0 0 0 0 0 0 EthPacketLow : 29005 1525 20 0 0 0 0 0 30550 DataKeepAlive : 172079 1583 16 0 0 0 0 0 173678 IpcPacketTop : 0 0 0 0 0 0 0 0 0 IpcPacketHigh : 0 0 0 0 0 0 0 0 0 IpcPacketLow : 0 0 0 0 0 0 0 0 0 (null) : 0 0 0 0 0 0 0 0 0 ---------------------------------------- endof dumping ucore share ram ------------------------------------------ ====================================== ===============display system internal ddrb==================== Kernel exec cmd ok. ================================================================= ===============diag boot-info display=============== ****************************************************************************** PowerOn BootTimes : 46 Watchdog BootTimes : 1 Software BootTimes : 14 Hardware BootTimes : 0 MotherBoard BootTimes: 0 Backup BootTimes : 1 CardOut BootTimes : 0 Current Boot Type : Poweron-boot Current Running Time: 3480(s) Running Time : 575(d)12(h) *** Boot History(Startup Time and Reason) *** 2022-03-19 01:40:59 Power on 2022-03-19 01:29:42 Memory exhausted reboot 2022-03-19 01:23:55 Memory exhausted reboot 2022-03-17 08:33:52 Memory exhausted reboot 2022-03-05 17:28:32 Power on 2021-11-08 12:39:02 User soft reboot 2021-10-06 21:44:54 Power on 2021-08-08 01:34:48 Power on 2021-08-07 22:14:59 Power on 2021-08-06 08:39:43 Power on =============================================== ===============display vrrp verbose=============== ================================================ ===============display pki certificate request-status=============== ============================================================= ===============display public-key local dsa public=============== =================================================== ===============display public-key local ecdsa public=============== =================================================== ===============display public-key local rsa publicr=============== ============================================= Key name: hostkey(default) Key type: RSA Time when key pair created: 10:40:43 2022/03/19 Key code: 30819F300D06092A864886F70D010101050003818D0030818902818100C430F3A1E9C144EE 97311532DF74C92BABD7EE2A06B380547BC5B47B21F7942D3C5882B025D7F12AB4E6B0DD3D EB4C5CDA33FD9501EE5CD13020EE832039FAEFDB3C610711E4FFE44B0A3C81B4257EFD56D2 7BC1DA36346E06351E319B82D8ADF5690BEFFBBD644E9FA6DAF9B1C8A63ECA0CE9326CB0C4 3AEAB644FAF1C3DEE50203010001 ============================================= Key name: serverkey(default) Key type: RSA Time when key pair created: 10:40:43 2022/03/19 Key code: 307C300D06092A864886F70D0101010500036B0030680261009647C2ADA9961F764EA08B4B ED6475F1AAD88B5DDC1AA5E74719EFF8932A2545CEFEBCF7E651B3DB872B87C45300C0CD34 2880824F6DAF18FE26989B4C835353BDC5387F1AD4EEEF232B56E1365B1766813A7FBCECB9 687775B643976C5DB7670203010001 =================================================== ===============display public-key peer brief=============== =================================================== ===============display public-key peer=============== =================================================== ===============display crypto-engine statistics=============== Slot ID: 1 CPU ID: 0 Crypto engine ID: 0 Submitted sessions: 4 Failed sessions: 0 Symmetric operations: 4 Symmetric errors: 0 Asymmetric operations: 0 Asymmetric errors: 0 Get-random operations: 0 Get-random errors: 0 =================================================== ===============display crypto-engine=============== Crypto engine name: Software crypto engine Crypto engine state: Enabled Crypto engine type: Software Slot ID: 1 CPU ID: 0 Crypto engine ID: 0 Symmetric algorithms: des-cbc des-ecb 3des-cbc aes-cbc aes-ecb aes-ctr camellia_cbc md5 sha1 sha2-256 sha2-384 sha2-512 md5-hmac sha1-hmac sha2-256-hmac sha2-384-hmac sha2-512-hmac aes-xcbc aes-xcbc-hmac Asymmetric algorithms: Random number generation function: Supported =================================================== ===============display ipsec sa=============== IPsec is not configured. =================================================== ===============display ipsec sa brief=============== IPsec is not configured. =================================================== ===============display ipsec sa count=============== IPsec is not configured. =================================================== ===============display ipsec tunnel=============== IPsec is not configured. =================================================== ===============display ipsec tunnel brief=============== IPsec is not configured. =================================================== ===============display ipsec tunnel count=============== IPsec is not configured. =================================================== ===============display ipsec statistics=============== IPsec is not configured. =================================================== ===============display ike sa=============== IKE is not configured. =================================================== ===============display ike sa verbose=============== IKE is not configured. =================================================== ===============display domain=============== Total 3 domains Domain: system State: Active Default authentication scheme: Local Default authorization scheme: Local Default accounting scheme: Local Accounting start failure action: Online Accounting update failure action: Online Accounting quota out action: Offline Service type: HSI Session time: Exclude idle time DHCPv6-follow-IPv6CP timeout: 60 seconds Authorization attributes: Idle cut: Disabled Session timeout: Disabled IGMP access limit: 4 MLD access limit: 4 Domain: cloud State: Active Portal authentication scheme: None Portal authorization scheme: None Portal accounting scheme: None Default authentication scheme: Local Default authorization scheme: Local Default accounting scheme: Local Accounting start failure action: Online Accounting update failure action: Online Accounting quota out action: Offline Service type: HSI Session time: Exclude idle time DHCPv6-follow-IPv6CP timeout: 60 seconds Authorization attributes: Idle cut: Disabled Session timeout: Disabled IGMP access limit: 4 MLD access limit: 4 Domain: extend-auth State: Active Portal authentication scheme: None Portal authorization scheme: None Portal accounting scheme: None Default authentication scheme: Local Default authorization scheme: Local Default accounting scheme: Local Accounting start failure action: Online Accounting update failure action: Online Accounting quota out action: Offline Service type: HSI Session time: Exclude idle time DHCPv6-follow-IPv6CP timeout: 60 seconds Authorization attributes: Idle cut: Disabled Session timeout: Disabled IGMP access limit: 4 MLD access limit: 4 Default domain name: system ====================================================== ===============display local-user=============== Device management user admin: State: Active Service type: SSH/Telnet/Terminal/HTTP/HTTPS User group: system Bind attributes: Authorization attributes: Work directory: flash: User role list: network-admin Total 1 local users matched. ======================================================= ===============display radius statistics=============== Auth. Acct. SessCtrl. Request Packet: 0 0 0 Retry Packet: 0 0 - Timeout Packet: 0 0 - Access Challenge: 0 - - Account Start: - 0 - Account Update: - 0 - Account Stop: - 0 - Terminate Request: - - 0 Set Policy: - - 0 Packet With Response: 0 0 0 Packet Without Response: 0 0 - Access Rejects: 0 - - Dropped Packet: 0 0 0 Check Failures: 0 0 0 ================================================= ===============display radius scheme=============== Total 0 RADIUS schemes ================================================================== ===============display hwtacacs scheme=============== Total 0 HWTACACS schemes ============================================================ ===============display hwtacacs scheme statistics=============== The HWTACACS scheme does not exist. ================================================== ===============display password-control blacklist=============== Blacklist items matched: 0. ======================================================== ===============display system internal lipc stcp links all=============== MDC VRF PID [LAddr/LPort--RAddr/RPort] Sta SndPkt RcvPkt SndCc RcvCc Owner 1 0 133 8/10523<- 8/21993 2 1 4 0 0 (d)dbmd 1 0 1176 8/21993-> 8/10523 2 4 1 0 0 (d)xmlcfgd 1 0 243 8/10529<- 8/21992 2 0 d20 0 0 (s)xmlcfgd 1 0 277 8/21992-> 8/10529 2 d20 0 0 0 (s)httpd 1 0 133 8/10523<- 8/21959 2 6 6 0 0 (d)dbmd 1 0 1164 8/21959-> 8/10523 2 6 6 0 0 (d)comsh 1 0 133 8/10523<- 8/64852 2 2 2 0 0 (d)dbmd 1 0 1141 8/64852-> 8/10523 2 2 2 0 0 (d)comsh 1 0 133 8/10523<- 8/64851 2 12 12 0 0 (d)dbmd 1 0 1141 8/64851-> 8/10523 2 12 12 0 0 (d)comsh 1 0 133 8/10523<- 8/64839 2 1 4 0 0 (d)dbmd 1 0 1140 8/64839-> 8/10523 2 4 1 0 0 (d)xmlcfgd 1 0 243 8/10529<- 8/64838 2 0 4d8 0 0 (s)xmlcfgd 1 0 279 8/64838-> 8/10529 2 4d8 0 0 0 (s)httpd 1 0 1127 8/1654 ==32768/0 0 0 0 0 0 (d)sshd 1 0 133 8/10523<- 8/64632 2 2 2 0 0 (d)dbmd 1 0 1127 8/64632-> 8/10523 2 2 2 0 0 (d)sshd 1 0 133 8/10523<- 8/64631 2 8 8 0 0 (d)dbmd 1 0 1127 8/64631-> 8/10523 2 8 8 0 0 (d)sshd 1 0 113 8/10519<- 8/64628 2 0 2 0 0 (d)kevent 1 0 1127 8/64628-> 8/10519 2 2 0 0 0 (d)sshd 1 0 138 8/620 <- 8/64627 2 2 1 0 0 (d)had 1 0 1127 8/64627-> 8/620 2 1 2 0 0 (d)sshd 1 0 133 8/10523<- 8/40129 2 22 22 0 0 (d)dbmd 1 0 241 8/40129-> 8/10523 2 22 22 0 0 (d)telnetd 1 0 133 8/10523<- 8/24558 2 384 384 0 0 (d)dbmd 1 0 310 8/24558-> 8/10523 2 384 384 0 0 (d)dhcpd 1 0 133 8/10523<- 8/24472 2 8a2 8a2 0 0 (d)dbmd 1 0 179 8/24472-> 8/10523 2 8a2 8a2 0 0 (d)vland 1 0 133 8/10523<- 8/24371 2 3b 3b 0 0 (d)dbmd 1 0 246 8/24371-> 8/10523 2 3b 3b 0 0 (d)maintai 1 0 133 8/10523<- 8/24181 2 1a32 1a32 0 0 (d)dbmd 1 0 271 8/24181-> 8/10523 2 1a32 1a32 0 0 (d)lldpd 1 0 242 8/10524==32768/0 0 0 0 0 0 (s)telnetd 1 0 133 8/10523<- 8/24122 2 2 2 0 0 (d)dbmd 1 0 147 8/24122-> 8/10523 2 2 2 0 0 (d)drvciud 1 0 133 8/10523<- 8/24118 2 2 2 0 0 (d)dbmd 1 0 160 8/24118-> 8/10523 2 2 2 0 0 (d)sysmand 1 0 243 8/10529==32768/0 0 0 0 0 0 (s)xmlcfgd 1 0 243 8/10528==32768/0 0 0 0 0 0 (d)xmlcfgd 1 0 133 8/10523<- 8/24044 2 3 1 0 0 (d)dbmd 1 0 243 8/24044-> 8/10523 2 1 3 0 0 (d)xmlcfgd 1 0 221 8/1223 <- 8/24028 2 1 1 0 0 (d)cmtnlmg 1 0 227 8/24028-> 8/1223 2 1 1 0 0 (d)drsd 1 0 113 8/10519<- 8/22496 2 0 1 0 0 (d)kevent 1 0 226 8/22496-> 8/10519 2 1 0 0 0 (d)dpid 1 0 216 8/1717 <- 8/22285 2 0 0 0 0 (d)dnsd 1 0 175 8/22285-> 8/1717 2 0 0 0 0 (d)aclmgrd 1 0 224 8/1673 <- 8/21176 2 3 2 0 0 (d)dhcpd 1 0 218 8/21176-> 8/1673 2 2 3 0 0 (d)pppd 1 0 224 8/1673 <- 8/21175 2 0 0 0 0 (d)dhcpd 1 0 218 8/21175-> 8/1673 2 0 0 0 0 (d)pppd 1 0 193 8/11551<- 8/21171 2 0 1 0 0 (d)ipcimd 1 0 237 8/21171-> 8/11551 2 1 0 0 0 (d)portsec 1 0 253 8/2184 <- 8/21170 2 1 5 0 0 (d)staticr 1 0 218 8/21170-> 8/2184 2 5 1 0 0 (d)pppd 1 0 227 8/1230 <- 8/21169 2 0 8453 0 0 (d)drsd 1 0 127 8/21169-> 8/1230 2 8453 0 1 0 (d)kdrs 1 0 227 8/1230 <- 8/21168 2 0 40da3 0 0 (d)drsd 1 0 127 8/21168-> 8/1230 2 40da3 0 3 0 (d)kdrs 1 0 223 8/1728 <- 8/20939 2 2 1 0 0 (d)ddrd 1 0 190 8/20939-> 8/1728 2 1 2 0 0 (d)qosd 1 0 229 8/1653 <- 8/20928 2 0 2 0 0 (d)ipstack 1 0 224 8/20928-> 8/1653 2 2 0 0 0 (d)dhcpd 1 0 193 8/1659 <- 8/20927 2 0 3 0 0 (d)ipcimd 1 0 310 8/20927-> 8/1659 2 3 0 0 0 (d)dhcpd 1 0 193 8/1659 <- 8/20926 2 0 e3 0 0 (d)ipcimd 1 0 229 8/11547<- 8/20925 2 1 1 0 0 (d)ipstack 1 0 310 8/20926-> 8/1659 2 e3 0 0 0 (d)dhcpd 1 0 224 8/20925-> 8/11547 2 1 1 0 0 (d)dhcpd 1 0 133 8/10523<- 8/20918 2 7b 75 0 0 (d)dbmd 1 0 224 8/20918-> 8/10523 2 75 7b 0 0 (d)dhcpd 1 0 224 8/1673 <- 8/20917 2 e0 1 0 0 (d)dhcpd 1 0 235 8/20917-> 8/1673 2 1 e0 0 0 (d)portald 1 0 224 8/1673 <- 8/20916 2 0 0 0 0 (d)dhcpd 1 0 235 8/20916-> 8/1673 2 0 0 0 0 (d)portald 1 0 229 8/11547<- 8/20915 2 1 1 0 0 (d)ipstack 1 0 235 8/20915-> 8/11547 2 1 1 0 0 (d)portald 1 0 229 8/1653 <- 8/20914 2 0 0 0 0 (d)ipstack 1 0 235 8/20914-> 8/1653 2 0 0 0 0 (d)portald 1 0 216 8/1717 <- 8/20913 2 16 16 0 0 (d)dnsd 1 0 235 8/20913-> 8/1717 2 16 16 0 0 (d)portald 1 0 216 8/1717 <- 8/20911 2 2 4 0 0 (d)dnsd 1 0 235 8/20911-> 8/1717 2 4 2 0 0 (d)portald 1 0 161 8/3230 <- 8/20909 2 0 0 0 0 (d)lauthd 1 0 235 8/20909-> 8/3230 2 0 0 0 0 (d)portald 1 0 157 8/1215 <- 8/20906 2 3f 1 0 0 (d)ofcd 1 0 235 8/20906-> 8/1215 2 1 3f 0 0 (d)portald 1 0 221 8/1223 <- 8/20904 2 1 1 0 0 (d)cmtnlmg 1 0 235 8/20904-> 8/1223 2 1 1 0 0 (d)portald 1 0 213 8/4251 <- 8/20903 2 76 77 0 0 (d)maintai 1 0 235 8/20903-> 8/4251 2 77 76 0 0 (d)portald 1 0 193 8/11551<- 8/20901 2 26c 1 0 0 (d)ipcimd 1 0 235 8/20901-> 8/11551 2 1 26c 0 0 (d)portald 1 0 224 8/1673 ==32768/0 0 0 0 0 0 (d)dhcpd 1 0 113 8/10519<- 8/20894 2 0 3 0 0 (d)kevent 1 0 224 8/20894-> 8/10519 2 3 0 0 0 (d)dhcpd 1 0 229 8/1653 <- 8/20892 2 2 5 0 0 (d)ipstack 1 0 225 8/20892-> 8/1653 2 5 2 0 0 (d)dhcpcd 1 0 113 8/10519<- 8/20885 2 3 3 0 0 (d)kevent 1 0 225 8/20885-> 8/10519 2 3 3 0 0 (d)dhcpcd 1 0 225 8/1726 ==32768/0 0 0 0 0 0 (d)dhcpcd 1 0 133 8/10523<- 8/20884 2 8 8 0 0 (d)dbmd 1 0 225 8/20884-> 8/10523 2 8 8 0 0 (d)dhcpcd 1 0 190 8/11026<- 8/20880 2 0 3 0 0 (d)qosd 1 0 218 8/20880-> 8/11026 2 3 0 0 0 (d)pppd 1 0 190 8/11026<- 8/20879 2 0 0 0 0 (d)qosd 1 0 218 8/20879-> 8/11026 2 0 0 0 0 (d)pppd 1 0 223 8/1728 <- 8/20878 2 0 1 0 0 (d)ddrd 1 0 218 8/20878-> 8/1728 2 1 0 0 0 (d)pppd 1 0 229 8/1653 <- 8/20877 2 0 4 0 0 (d)ipstack 1 0 218 8/20877-> 8/1653 2 4 0 0 0 (d)pppd 1 0 163 8/3173 <- 8/20875 2 1 1 0 0 (d)aaad 1 0 304 8/20875-> 8/3173 2 1 1 0 0 (d)pppd 1 0 163 8/3173 <- 8/20874 2 1 1 0 0 (d)aaad 1 0 306 8/20874-> 8/3173 2 1 1 0 0 (d)pppd 1 0 163 8/3173 <- 8/20873 2 1 1 0 0 (d)aaad 1 0 305 8/20873-> 8/3173 2 1 1 0 0 (d)pppd 1 0 113 8/10519<- 8/20869 2 6 4 0 0 (d)kevent 1 0 218 8/20869-> 8/10519 2 4 6 0 0 (d)pppd 1 0 229 8/1740 ==32768/0 0 0 0 0 0 (d)ipstack 1 0 229 8/1739 ==32768/0 0 0 0 0 0 (d)ipstack 1 0 138 8/620 <- 8/20859 2 2 1 0 0 (d)had 1 0 229 8/20859-> 8/620 2 1 2 0 0 (d)ipstack 1 0 229 8/11547<- 8/20858 2 6 2 0 0 (d)ipstack 1 0 261 8/20858-> 8/11547 2 2 6 0 0 (d)staticr 1 0 229 8/11547<- 8/20857 2 3 2 0 0 (d)ipstack 1 0 231 8/20857-> 8/11547 2 2 3 0 0 (d)natd 1 0 229 8/11547<- 8/20856 2 1 1 0 0 (d)ipstack 1 0 223 8/20856-> 8/11547 2 1 1 0 0 (d)ddrd 1 0 229 8/11547<- 8/20855 2 1 1 0 0 (d)ipstack 1 0 158 8/20855-> 8/11547 2 1 1 0 0 (d)trackd 1 0 229 8/11547==32768/0 0 0 0 0 0 (d)ipstack 1 0 138 8/620 <- 8/20849 2 2 1 0 0 (d)had 1 0 243 8/20849-> 8/620 2 1 2 0 0 (d)xmlcfgd 1 0 243 8/10527==32768/0 0 0 0 0 0 (d)xmlcfgd 1 0 113 8/10519<- 8/20841 2 0 1 0 0 (d)kevent 1 0 229 8/20841-> 8/10519 2 1 0 0 0 (d)ipstack 1 0 235 8/1206 ==32768/0 0 0 0 0 0 (s)portald 1 0 229 8/1653 <- 8/20829 2 0 4 0 0 (d)ipstack 1 0 231 8/20829-> 8/1653 2 4 0 0 0 (d)natd 1 0 229 8/1653 ==32768/0 0 0 0 0 0 (d)ipstack 1 0 229 8/1650 ==32768/0 0 0 0 0 0 (d)ipstack 1 0 138 8/620 <- 8/20828 2 2 1 0 0 (d)had 1 0 229 8/20828-> 8/620 2 1 2 0 0 (d)ipstack 1 0 229 8/1699 ==32768/0 0 0 0 0 0 (d)ipstack 1 0 235 8/3199 <- 8/20825 2 0 0 0 0 (d)portald 1 0 235 8/20825-> 8/3199 2 0 0 0 0 (d)portald 1 0 138 8/620 <- 8/20824 2 2 1 0 0 (d)had 1 0 229 8/20824-> 8/620 2 1 2 0 0 (d)ipstack 1 0 229 8/1701 ==32768/0 0 0 0 0 0 (d)ipstack 1 0 229 8/1709 ==32768/0 0 0 0 0 0 (d)ipstack 1 0 229 8/1710 ==32768/0 0 0 0 0 0 (d)ipstack 1 0 138 8/620 <- 8/20822 2 2 1 0 0 (d)had 1 0 229 8/20822-> 8/620 2 1 2 0 0 (d)ipstack 1 0 159 8/1188 <- 8/20819 2 40 21 0 0 (d)apmgrd 1 0 235 8/20819-> 8/1188 2 21 40 0 0 (d)portald 1 0 229 8/1648 ==32768/0 0 0 0 0 0 (d)ipstack 1 0 229 8/11543==32768/0 0 0 0 0 0 (d)ipstack 1 0 138 8/620 <- 8/20815 2 2 1 0 0 (d)had 1 0 229 8/20815-> 8/620 2 1 2 0 0 (d)ipstack 1 0 229 8/1645 ==32768/0 0 0 0 0 0 (d)ipstack 1 0 138 8/620 <- 8/20799 2 2 1 0 0 (d)had 1 0 229 8/20799-> 8/620 2 1 2 0 0 (d)ipstack 1 0 133 8/10523<- 8/20798 2 1e 1e 0 0 (d)dbmd 1 0 229 8/20798-> 8/10523 2 1e 1e 0 0 (d)ipstack 1 0 229 8/1649 ==32768/0 0 0 0 0 0 (d)ipstack 1 0 138 8/620 <- 8/20796 2 2 1 0 0 (d)had 1 0 229 8/20796-> 8/620 2 1 2 0 0 (d)ipstack 1 0 204 8/1166 <- 8/20791 2 778 5 0 0 (d)stamgrd 1 0 235 8/20791-> 8/1166 2 5 778 0 0 (d)portald 1 0 133 8/10523<- 8/20778 2 1 1 0 0 (d)dbmd 1 0 229 8/20778-> 8/10523 2 1 1 0 0 (d)ipstack 1 0 190 8/11026<- 8/20772 2 0 6 0 0 (d)qosd 1 0 237 8/20772-> 8/11026 2 6 0 0 0 (d)portsec 1 0 190 8/11026<- 8/20771 2 0 0 0 0 (d)qosd 1 0 237 8/20771-> 8/11026 2 0 0 0 0 (d)portsec 1 0 175 8/11025<- 8/20769 2 0 0 0 0 (d)aclmgrd 1 0 237 8/20769-> 8/11025 2 0 0 0 0 (d)portsec 1 0 257 8/11537<- 8/20766 2 0 0 0 0 (d)karp/1 1 0 235 8/20766-> 8/11537 2 0 0 0 0 (d)portald 1 0 235 8/3199 ==32768/0 0 0 0 0 0 (d)portald 1 0 163 8/3173 <- 8/20762 2 1 1 0 0 (d)aaad 1 0 235 8/20762-> 8/3173 2 1 1 0 0 (d)portald 1 0 133 8/10523<- 8/20754 2 a 9 0 0 (d)dbmd 1 0 283 8/20754-> 8/10523 2 9 a 0 0 (d)portsec 1 0 283 8/1153 ==32768/0 0 0 0 0 0 (d)portsec 1 0 163 8/3173 <- 8/20752 2 0 1 0 0 (d)aaad 1 0 283 8/20752-> 8/3173 2 1 0 0 0 (d)portsec 1 0 163 8/3173 <- 8/20751 2 1 1 0 0 (d)aaad 1 0 283 8/20751-> 8/3173 2 1 1 0 0 (d)portsec 1 0 133 8/10523<- 8/20750 2 9 9 0 0 (d)dbmd 1 0 283 8/20750-> 8/10523 2 9 9 0 0 (d)portsec 1 0 133 8/10523<- 8/20731 2 d c 0 0 (d)dbmd 1 0 264 8/20731-> 8/10523 2 c d 0 0 (d)portsec 1 0 264 8/1151 ==32768/0 0 0 0 0 0 (d)portsec 1 0 264 8/11079==32768/0 0 0 0 0 0 (d)portsec 1 0 163 8/3173 <- 8/20729 2 0 1 0 0 (d)aaad 1 0 264 8/20729-> 8/3173 2 1 0 0 0 (d)portsec 1 0 163 8/3173 <- 8/20719 2 14 2 0 0 (d)aaad 1 0 278 8/20719-> 8/3173 2 2 14 0 0 (d)portald 1 0 163 8/3173 <- 8/20681 2 14 2 0 0 (d)aaad 1 0 274 8/20681-> 8/3173 2 2 14 0 0 (d)xmlcfgd 1 0 163 8/3173 <- 8/20680 2 14 2 0 0 (d)aaad 1 0 265 8/20680-> 8/3173 2 2 14 0 0 (d)portsec 1 0 239 8/1194 ==32768/0 0 0 0 0 0 (d)rrmd 1 0 226 8/3247 ==32768/0 0 0 0 0 0 (d)dpid 1 0 257 8/11537<- 8/20646 2 0 2 0 0 (d)karp/1 1 0 230 8/20646-> 8/11537 2 2 0 0 0 (d)lldpd 1 0 133 8/10523<- 8/20641 2 88 88 0 0 (d)dbmd 1 0 228 8/20641-> 8/10523 2 88 88 0 0 (d)httpd 1 0 219 8/3221 <- 8/20640 2 0 1 0 0 (d)appprof 1 0 226 8/20640-> 8/3221 202 1 0 0 0 (d)dpid 1 0 228 8/1668 ==32768/0 0 0 0 0 0 (d)httpd 1 0 226 8/3236 ==32768/0 0 0 0 0 0 (d)dpid 1 0 133 8/10523<- 8/20637 2 1c 1c 0 0 (d)dbmd 1 0 235 8/20637-> 8/10523 2 1c 1c 0 0 (d)portald 1 0 175 8/11025<- 8/20634 2 0 0 0 0 (d)aclmgrd 1 0 235 8/20634-> 8/11025 2 0 0 0 0 (d)portald 1 0 226 8/3237 ==32768/0 0 0 0 0 0 (d)dpid 1 0 113 8/10521<- 8/20632 2 1ed 1 0 0 (d)kevent 1 0 235 8/20632-> 8/10521 2 1 1ed 0 0 (d)portald 1 0 113 8/10519<- 8/20627 2 5 5 0 0 (d)kevent 1 0 235 8/20627-> 8/10519 2 5 5 0 0 (d)portald 1 0 190 8/11026<- 8/20626 2 0 3 0 0 (d)qosd 1 0 235 8/20626-> 8/11026 2 3 0 0 0 (d)portald 1 0 190 8/11026<- 8/20625 2 0 0 0 0 (d)qosd 1 0 235 8/20625-> 8/11026 2 0 0 0 0 (d)portald 1 0 220 8/13073<- 8/20624 2 1 1 0 0 (d)aprd 1 0 240 8/20624-> 8/13073 2 1 1 0 0 (d)session 1 0 226 8/4255 ==32768/0 0 0 0 0 0 (d)dpid 1 0 226 8/4256 ==32768/0 0 0 0 0 0 (d)dpid 1 0 133 8/10523<- 8/20621 2 4c 48 0 0 (d)dbmd 1 0 235 8/20621-> 8/10523 2 48 4c 0 0 (d)portald 1 0 133 8/10523<- 8/20620 2 7 7 0 0 (d)dbmd 1 0 226 8/20620-> 8/10523 2 7 7 0 0 (d)dpid 1 0 235 8/3202 ==32768/0 0 0 0 0 0 (d)portald 1 0 226 8/3224 ==32768/0 0 0 0 0 0 (d)dpid 1 0 138 8/620 <- 8/20615 2 2 1 0 0 (d)had 1 0 133 8/10523<- 8/20614 2 247 28f 0 0 (d)dbmd 1 0 243 8/20614-> 8/10523 2 28f 247 0 0 (d)xmlcfgd 1 0 219 8/3221 <- 8/20613 2 0 1 0 0 (d)appprof 1 0 226 8/20613-> 8/3221 202 1 0 0 0 (d)dpid 1 0 226 8/3417 ==32768/0 0 0 0 0 0 (d)dpid 1 0 226 8/3225 ==32768/0 0 0 0 0 0 (d)dpid 1 0 133 8/10523<- 8/20611 2 2c 27 0 0 (d)dbmd 1 0 226 8/20611-> 8/10523 2 27 2c 0 0 (d)dpid 1 0 235 8/20615-> 8/620 2 1 2 0 0 (d)portald 1 0 240 8/3185 ==32768/0 0 0 0 0 0 (d)session 1 0 240 8/3198 ==32768/0 0 0 0 0 0 (d)session 1 0 133 8/10523<- 8/20606 2 2 1 0 0 (d)dbmd 1 0 230 8/20606-> 8/10523 2 1 2 0 0 (d)lldpd 1 0 159 8/1188 <- 8/20601 2 12b5b 19d 0 0 (d)apmgrd 1 0 239 8/20601-> 8/1188 2 19d 12b5b 0 0 (d)rrmd 1 0 165 8/1138 <- 8/20600 2 0 0 0 0 (d)tranged 1 0 239 8/20600-> 8/1138 2 0 0 0 0 (d)rrmd 1 0 138 8/620 <- 8/20598 2 2 1 0 0 (d)had 1 0 239 8/20598-> 8/620 2 1 2 0 0 (d)rrmd 1 0 227 8/1230 ==32768/0 0 0 0 0 0 (d)drsd 1 0 204 8/1166 <- 8/20597 2 712 2 0 0 (d)stamgrd 1 0 227 8/20597-> 8/1166 2 2 712 0 0 (d)drsd 1 0 227 8/1237 ==32768/0 0 0 0 0 0 (d)drsd 1 0 240 8/3197 ==32768/0 0 0 0 0 0 (d)session 1 0 240 8/3184 ==32768/0 0 0 0 0 0 (d)session 1 0 133 8/10523<- 8/20594 2 39 38 0 0 (d)dbmd 1 0 240 8/20594-> 8/10523 2 38 39 0 0 (d)session 1 0 138 8/620 <- 8/20593 2 2 1 0 0 (d)had 1 0 227 8/20593-> 8/620 2 1 2 0 0 (d)drsd 1 0 163 8/3173 <- 8/20587 2 1 1 0 0 (d)aaad 1 0 264 8/20587-> 8/3173 2 1 1 0 0 (d)portsec 1 0 133 8/10523<- 8/20585 2 d d 0 0 (d)dbmd 1 0 264 8/20585-> 8/10523 2 d d 0 0 (d)portsec 1 0 230 8/1137 ==32768/0 0 0 0 0 0 (d)lldpd 1 0 258 8/1641 <- 8/20582 2 1 1 0 0 (d)kwadj/1 1 0 261 8/20582-> 8/1641 2 1 1 0 0 (d)staticr 1 0 133 8/10523<- 8/20581 2 9b 97 0 0 (d)dbmd 1 0 239 8/20581-> 8/10523 2 97 9b 0 0 (d)rrmd 1 0 133 8/10523<- 8/20580 2 1 1 0 0 (d)dbmd 1 0 239 8/20580-> 8/10523 2 1 1 0 0 (d)rrmd 1 0 133 8/10523<- 8/20577 2 2e 2e 0 0 (d)dbmd 1 0 237 8/20577-> 8/10523 2 2e 2e 0 0 (d)portsec 1 0 237 8/1189 <- 8/20576 2 3 1 0 0 (d)portsec 1 0 206 8/20576-> 8/1189 2 1 3 0 0 (d)stamgrd 1 0 133 8/10523<- 8/20575 2 1 1 0 0 (d)dbmd 1 0 237 8/20575-> 8/10523 2 1 1 0 0 (d)portsec 1 0 237 8/1189 ==32768/0 0 0 0 0 0 (d)portsec 1 0 237 8/1152 ==32768/0 0 0 0 0 0 (d)portsec 1 0 138 8/620 <- 8/20574 2 2 1 0 0 (d)had 1 0 237 8/20574-> 8/620 2 1 2 0 0 (d)portsec 1 0 237 8/11080==32768/0 0 0 0 0 0 (d)portsec 1 0 253 8/2184 ==32768/0 0 0 0 0 0 (d)staticr 1 0 252 8/2149 <- 8/20572 2 7 b 0 0 (d)routed 1 0 253 8/20572-> 8/2149 2 b 7 0 0 (d)staticr 1 0 133 8/10523<- 8/20571 2 6 6 0 0 (d)dbmd 1 0 237 8/20571-> 8/10523 2 6 6 0 0 (d)portsec 1 0 252 8/2149 <- 8/20570 2 6 24 0 0 (d)routed 1 0 261 8/20570-> 8/2149 2 24 6 0 0 (d)staticr 1 0 138 8/620 <- 8/20569 2 2 1 0 0 (d)had 1 0 261 8/20569-> 8/620 2 1 2 0 0 (d)staticr 1 0 133 8/10523<- 8/20568 2 8 8 0 0 (d)dbmd 1 0 261 8/20568-> 8/10523 2 8 8 0 0 (d)staticr 1 0 133 8/10523<- 8/20567 2 224 221 0 0 (d)dbmd 1 0 229 8/20567-> 8/10523 2 221 224 0 0 (d)ipstack 1 0 257 8/11537<- 8/20566 2 1 1 0 0 (d)karp/1 1 0 261 8/20566-> 8/11537 2 1 1 0 0 (d)staticr 1 0 229 8/1639 ==32768/0 0 0 0 0 0 (d)ipstack 1 0 257 8/11537<- 8/20562 2 5 7 0 0 (d)karp/1 1 0 229 8/20562-> 8/11537 2 7 5 0 0 (d)ipstack 1 0 113 8/10519<- 8/20561 2 7 3 0 0 (d)kevent 1 0 261 8/20561-> 8/10519 2 3 7 0 0 (d)staticr 1 0 113 8/10519<- 8/20556 2 0 1 0 0 (d)kevent 1 0 240 8/20556-> 8/10519 2 1 0 0 0 (d)session 1 0 175 8/11025<- 8/20555 2 0 0 0 0 (d)aclmgrd 1 0 240 8/20555-> 8/11025 2 0 0 0 0 (d)session 1 0 113 8/10519<- 8/20554 2 0 2 0 0 (d)kevent 1 0 240 8/20554-> 8/10519 2 2 0 0 0 (d)session 1 0 113 8/10519<- 8/20553 2 a c 0 0 (d)kevent 1 0 240 8/20553-> 8/10519 2 c a 0 0 (d)session 1 0 138 8/620 <- 8/20552 2 2 1 0 0 (d)had 1 0 240 8/20552-> 8/620 2 1 2 0 0 (d)session 1 0 113 8/10521<- 8/20550 2 e6 1 0 0 (d)kevent 1 0 237 8/20550-> 8/10521 2 1 e6 0 0 (d)portsec 1 0 138 8/620 <- 8/20548 2 2 1 0 0 (d)had 1 0 113 8/10519<- 8/20545 2 4 2 0 0 (d)kevent 1 0 237 8/20545-> 8/10519 2 2 4 0 0 (d)portsec 1 0 116 8/11553<- 8/20544 2 0 1 0 0 (d)kmac/1 1 0 237 8/20544-> 8/11553 2 1 0 0 0 (d)portsec 1 0 253 8/20548-> 8/620 2 1 2 0 0 (d)staticr 1 0 133 8/10523<- 8/20541 2 27 26 0 0 (d)dbmd 1 0 253 8/20541-> 8/10523 2 26 27 0 0 (d)staticr 1 0 138 8/620 <- 8/20540 2 2 1 0 0 (d)had 1 0 218 8/20540-> 8/620 2 1 2 0 0 (d)pppd 1 0 138 8/620 <- 8/20538 2 2 1 0 0 (d)had 1 0 229 8/20538-> 8/620 2 1 2 0 0 (d)ipstack 1 0 252 8/2149 ==32768/0 0 0 0 0 0 (d)routed 1 0 259 8/1655 <- 8/20537 2 0 20 0 0 (d)kfib/1 1 0 251 8/20537-> 8/1655 2 20 0 0 0 (d)routed 1 0 229 8/1646 ==32768/0 0 0 0 0 0 (d)ipstack 1 0 229 8/11541==32768/0 0 0 0 0 0 (d)ipstack 1 0 229 8/1655 ==32768/0 0 0 0 0 0 (d)ipstack 1 0 229 8/11538==32768/0 0 0 0 0 0 (d)ipstack 1 0 229 8/1641 ==32768/0 0 0 0 0 0 (d)ipstack 1 0 229 8/1640 ==32768/0 0 0 0 0 0 (d)ipstack 1 0 163 8/3173 <- 8/20536 2 14 2 0 0 (d)aaad 1 0 247 8/20536-> 8/3173 2 2 14 0 0 (d)pppd 1 0 229 8/11537==32768/0 0 0 0 0 0 (d)ipstack 1 0 229 8/1638 ==32768/0 0 0 0 0 0 (d)ipstack 1 0 229 8/1637 ==32768/0 0 0 0 0 0 (d)ipstack 1 0 133 8/10523<- 8/20535 2 14 10 0 0 (d)dbmd 1 0 232 8/20535-> 8/10523 2 10 14 0 0 (d)nqad 1 0 175 8/11025<- 8/20533 2 0 0 0 0 (d)aclmgrd 1 0 229 8/20533-> 8/11025 2 0 0 0 0 (d)ipstack 1 0 113 8/10521<- 8/20531 2 1e7 1 0 0 (d)kevent 1 0 229 8/20531-> 8/10521 2 1 1e7 0 0 (d)ipstack 1 0 113 8/10519<- 8/20530 2 d8 97 0 0 (d)kevent 1 0 229 8/20530-> 8/10519 2 97 d8 0 0 (d)ipstack 1 0 133 8/10523<- 8/20529 2 2 2 0 0 (d)dbmd 1 0 234 8/20529-> 8/10523 2 2 2 0 0 (d)ntpd 1 0 216 8/1717 <- 8/20526 2 57c 57c 0 0 (d)dnsd 1 0 255 8/20526-> 8/1717 2 57c 57c 0 0 (d)nqad 1 0 133 8/10523<- 8/20520 2 22 21 0 0 (d)dbmd 1 0 113 8/10519<- 8/20519 2 0 1 0 0 (d)kevent 1 0 232 8/20519-> 8/10519 2 1 0 0 0 (d)nqad 1 0 232 8/1716 ==32768/0 0 0 0 0 0 (d)nqad 1 0 133 8/10523<- 8/20518 2 71 6f 0 0 (d)dbmd 1 0 234 8/20518-> 8/10523 2 6f 71 0 0 (d)ntpd 1 0 227 8/20520-> 8/10523 2 21 22 0 0 (d)drsd 1 0 234 8/1720 ==32768/0 0 0 0 0 0 (d)ntpd 1 0 216 8/1717 <- 8/20517 2 1 1 0 0 (d)dnsd 1 0 234 8/20517-> 8/1717 2 1 1 0 0 (d)ntpd 1 0 113 8/10519<- 8/20514 2 0 1 0 0 (d)kevent 1 0 234 8/20514-> 8/10519 2 1 0 0 0 (d)ntpd 1 0 113 8/10519<- 8/20512 2 4 4 0 0 (d)kevent 1 0 234 8/20512-> 8/10519 2 4 4 0 0 (d)ntpd 1 0 133 8/10523<- 8/20509 2 1 1 0 0 (d)dbmd 1 0 238 8/20509-> 8/10523 2 1 1 0 0 (d)routed 1 0 231 8/13075==32768/0 0 0 0 0 0 (d)natd 1 0 238 8/2170 ==32768/0 0 0 0 0 0 (d)routed 1 0 238 8/12058==32768/0 0 0 0 0 0 (d)routed 1 0 230 8/1136 ==32768/0 0 0 0 0 0 (d)lldpd 1 0 133 8/10523<- 8/20507 2 a 9 0 0 (d)dbmd 1 0 252 8/20507-> 8/10523 2 9 a 0 0 (d)routed 1 0 133 8/10523<- 8/20506 2 455e 455e 0 0 (d)dbmd 1 0 230 8/20506-> 8/10523 2 455e 455e 0 0 (d)lldpd 1 0 133 8/10523<- 8/20505 2 552 552 0 0 (d)dbmd 1 0 230 8/20505-> 8/10523 2 552 552 0 0 (d)lldpd 1 0 133 8/10523<- 8/20504 2 7 7 0 0 (d)dbmd 1 0 238 8/20504-> 8/10523 2 7 7 0 0 (d)routed 1 0 138 8/620 <- 8/20503 2 2 1 0 0 (d)had 1 0 230 8/20503-> 8/620 2 1 2 0 0 (d)lldpd 1 0 242 8/11570==32768/0 0 0 0 0 0 (d)telnetd 1 0 133 8/10523<- 8/20501 2 5 5 0 0 (d)dbmd 1 0 175 8/11025<- 8/20498 2 0 0 0 0 (d)aclmgrd 1 0 231 8/20498-> 8/11025 2 0 0 0 0 (d)natd 1 0 242 8/20501-> 8/10523 2 5 5 0 0 (d)telnetd 1 0 241 8/1569 ==32768/0 0 0 0 0 0 (d)telnetd 1 0 113 8/10519<- 8/20493 2 0 3 0 0 (d)kevent 1 0 231 8/20493-> 8/10519 2 3 0 0 0 (d)natd 1 0 138 8/620 <- 8/20492 2 2 1 0 0 (d)had 1 0 238 8/20492-> 8/620 2 1 2 0 0 (d)routed 1 0 231 8/3191 ==32768/0 0 0 0 0 0 (d)natd 1 0 230 8/11029==32768/0 0 0 0 0 0 (d)lldpd 1 0 133 8/10523<- 8/20488 2 14 12 0 0 (d)dbmd 1 0 113 8/10519<- 8/20486 2 0 1 0 0 (d)kevent 1 0 230 8/20486-> 8/10519 2 1 0 0 0 (d)lldpd 1 0 244 8/20488-> 8/10523 2 12 14 0 0 (d)schedul 1 0 244 8/626 ==32768/0 0 0 0 0 0 (d)schedul 1 0 216 8/1717 <- 8/20483 2 15e 15e 0 0 (d)dnsd 1 0 221 8/20483-> 8/1717 2 15e 15e 0 0 (d)cmtnlmg 1 0 133 8/10523<- 8/20479 2 7 6 0 0 (d)dbmd 1 0 241 8/20479-> 8/10523 2 6 7 0 0 (d)telnetd 1 0 113 8/10519<- 8/20476 2 0 2 0 0 (d)kevent 1 0 241 8/20476-> 8/10519 2 2 0 0 0 (d)telnetd 1 0 175 8/11025<- 8/20474 2 0 0 0 0 (d)aclmgrd 1 0 231 8/20474-> 8/11025 2 0 0 0 0 (d)natd 1 0 113 8/10519<- 8/20469 2 0 4 0 0 (d)kevent 1 0 231 8/20469-> 8/10519 2 4 0 0 0 (d)natd 1 0 231 8/3190 ==32768/0 0 0 0 0 0 (d)natd 1 0 133 8/10523<- 8/20468 2 60 5d 0 0 (d)dbmd 1 0 231 8/20468-> 8/10523 2 5d 60 0 0 (d)natd 1 0 133 8/10523<- 8/20467 2 1 1 0 0 (d)dbmd 1 0 231 8/20467-> 8/10523 2 1 1 0 0 (d)natd 1 0 133 8/10523<- 8/20466 2 44 41 0 0 (d)dbmd 1 0 223 8/20466-> 8/10523 2 41 44 0 0 (d)ddrd 1 0 223 8/1728 ==32768/0 0 0 0 0 0 (d)ddrd 1 0 221 8/1223 <- 8/20465 2 1 1 0 0 (d)cmtnlmg 1 0 159 8/20465-> 8/1223 2 1 1 0 0 (d)apmgrd 1 0 221 8/1223 <- 8/20464 2 1 1 0 0 (d)cmtnlmg 1 0 206 8/20464-> 8/1223 2 1 1 0 0 (d)stamgrd 1 0 221 8/1223 <- 8/20463 2 1 1 0 0 (d)cmtnlmg 1 0 156 8/20463-> 8/1223 2 1 1 0 0 (d)modulep 1 0 221 8/1223 ==32768/0 0 0 0 0 0 (d)cmtnlmg 1 0 220 8/3192 ==32768/0 0 0 0 0 0 (d)aprd 1 0 133 8/10523<- 8/20462 2 9 8 0 0 (d)dbmd 1 0 221 8/20462-> 8/10523 2 8 9 0 0 (d)cmtnlmg 1 0 221 8/1222 ==32768/0 0 0 0 0 0 (d)cmtnlmg 1 0 220 8/3193 ==32768/0 0 0 0 0 0 (d)aprd 1 0 113 8/10519<- 8/20454 2 5 7 0 0 (d)kevent 1 0 220 8/20454-> 8/10519 2 7 5 0 0 (d)aprd 1 0 138 8/620 <- 8/20453 2 2 1 0 0 (d)had 1 0 220 8/3186 ==32768/0 0 0 0 0 0 (d)aprd 1 0 220 8/13073<- 8/20452 2 1 1 0 0 (d)aprd 1 0 190 8/20452-> 8/13073 2 1 1 0 0 (d)qosd 1 0 220 8/13073==32768/0 0 0 0 0 0 (d)aprd 1 0 241 8/20453-> 8/620 2 1 2 0 0 (d)telnetd 1 0 133 8/10523<- 8/20451 2 14 14 0 0 (d)dbmd 1 0 220 8/20451-> 8/10523 2 14 14 0 0 (d)aprd 1 0 213 8/4251 <- 8/20450 2 76 77 0 0 (d)maintai 1 0 186 8/20450-> 8/4251 2 77 76 0 0 (d)apmgrd 1 0 213 8/4251 <- 8/20449 2 76 77 0 0 (d)maintai 1 0 183 8/20449-> 8/4251 2 77 76 0 0 (d)apmgrd 1 0 213 8/4251 <- 8/20448 2 76 77 0 0 (d)maintai 1 0 159 8/20448-> 8/4251 2 77 76 0 0 (d)apmgrd 1 0 213 8/4251 <- 8/20447 2 76 77 0 0 (d)maintai 1 0 182 8/20447-> 8/4251 2 77 76 0 0 (d)apmgrd 1 0 213 8/4251 <- 8/20446 2 76 77 0 0 (d)maintai 1 0 206 8/20446-> 8/4251 2 77 76 0 0 (d)stamgrd 1 0 213 8/4251 <- 8/20445 2 76 77 0 0 (d)maintai 1 0 208 8/20445-> 8/4251 2 77 76 0 0 (d)stamgrd 1 0 213 8/4251 <- 8/20444 2 76 77 0 0 (d)maintai 1 0 184 8/20444-> 8/4251 2 77 76 0 0 (d)apmgrd 1 0 213 8/4251 <- 8/20443 2 76 77 0 0 (d)maintai 1 0 207 8/20443-> 8/4251 2 77 76 0 0 (d)stamgrd 1 0 213 8/4251 <- 8/20442 2 76 77 0 0 (d)maintai 1 0 209 8/20442-> 8/4251 2 77 76 0 0 (d)stamgrd 1 0 133 8/10523<- 8/20441 2 4 4 0 0 (d)dbmd 1 0 213 8/20441-> 8/10523 2 4 4 0 0 (d)maintai 1 0 213 8/4251 ==32768/0 0 0 0 0 0 (d)maintai 1 0 113 8/10519<- 8/20437 2 99 4d 0 0 (d)kevent 1 0 230 8/20437-> 8/10519 2 4d 99 0 0 (d)lldpd 1 0 138 8/620 <- 8/20436 2 2 1 0 0 (d)had 1 0 226 8/20436-> 8/620 2 1 2 0 0 (d)dpid 1 0 113 8/10519<- 8/20433 2 0 1 0 0 (d)kevent 1 0 233 8/20433-> 8/10519 2 1 0 0 0 (d)nqasd 1 0 138 8/620 <- 8/20432 2 2 1 0 0 (d)had 1 0 231 8/20432-> 8/620 2 1 2 0 0 (d)natd 1 0 138 8/620 <- 8/20431 2 2 1 0 0 (d)had 1 0 223 8/20431-> 8/620 2 1 2 0 0 (d)ddrd 1 0 113 8/10519<- 8/20429 2 0 1 0 0 (d)kevent 1 0 233 8/20429-> 8/10519 2 1 0 0 0 (d)nqasd 1 0 233 8/1743 ==32768/0 0 0 0 0 0 (d)nqasd 1 0 133 8/10523<- 8/20428 2 a 9 0 0 (d)dbmd 1 0 233 8/20428-> 8/10523 2 9 a 0 0 (d)nqasd 1 0 133 8/10523<- 8/20424 2 3 3 0 0 (d)dbmd 1 0 218 8/20424-> 8/10523 2 3 3 0 0 (d)pppd 1 0 113 8/10519<- 8/20421 2 2 4 0 0 (d)kevent 1 0 223 8/20421-> 8/10519 2 4 2 0 0 (d)ddrd 1 0 133 8/10523<- 8/20420 2 3b 2a 0 0 (d)dbmd 1 0 218 8/20420-> 8/10523 2 2a 3b 0 0 (d)pppd 1 0 218 8/11565==32768/0 0 0 0 0 0 (d)pppd 1 0 218 8/1722 ==32768/0 0 0 0 0 0 (d)pppd 1 0 218 8/1723 ==32768/0 0 0 0 0 0 (d)pppd 1 0 138 8/620 <- 8/20419 2 2 1 0 0 (d)had 1 0 221 8/20419-> 8/620 2 1 2 0 0 (d)cmtnlmg 1 0 138 8/620 <- 8/20418 2 2 1 0 0 (d)had 1 0 220 8/20418-> 8/620 2 1 2 0 0 (d)aprd 1 0 113 8/10519<- 8/20414 2 0 1 0 0 (d)kevent 1 0 216 8/20414-> 8/10519 2 1 0 0 0 (d)dnsd 1 0 138 8/620 <- 8/20413 2 2 1 0 0 (d)had 1 0 216 8/1717 ==32768/0 0 0 0 0 0 (d)dnsd 1 0 213 8/20413-> 8/620 2 1 2 0 0 (d)maintai 1 0 216 8/1718 ==32768/0 0 0 0 0 0 (d)dnsd 1 0 133 8/10523<- 8/20412 2 58 4b 0 0 (d)dbmd 1 0 216 8/20412-> 8/10523 2 4b 58 0 0 (d)dnsd 1 0 133 8/10523<- 8/20410 2 4 3 0 0 (d)dbmd 1 0 219 8/20410-> 8/10523 2 3 4 0 0 (d)appprof 1 0 219 8/3221 ==32768/0 0 0 0 0 0 (d)appprof 1 0 133 8/10523<- 8/20407 2 aa aa 0 0 (d)dbmd 1 0 1 8/20407-> 8/10523 2 aa aa 0 0 (d)scmd 1 0 161 8/3230 <- 8/20405 2 269 269 0 0 (d)lauthd 1 0 204 8/20405-> 8/3230 2 269 269 0 0 (d)stamgrd 1 0 161 8/3230 ==32768/0 0 0 0 0 0 (d)lauthd 1 0 161 8/3181 ==32768/0 0 0 0 0 0 (d)lauthd 1 0 161 8/3178 ==32768/0 0 0 0 0 0 (d)lauthd 1 0 199 8/614 ==32768/0 0 0 0 0 0 (d)comsh 1 0 138 8/620 <- 8/20379 2 2 1 0 0 (d)had 1 0 199 8/20379-> 8/620 2 1 2 0 0 (d)comsh 1 0 163 8/3173 <- 8/20359 2 0 1 0 0 (d)aaad 1 0 207 8/20359-> 8/3173 2 1 0 0 0 (d)stamgrd 1 0 163 8/3173 <- 8/20358 2 1 1 0 0 (d)aaad 1 0 207 8/20358-> 8/3173 2 1 1 0 0 (d)stamgrd 1 0 175 8/11025<- 8/20357 2 0 1 0 0 (d)aclmgrd 1 0 163 8/3173 <- 8/20356 2 0 1 0 0 (d)aaad 1 0 209 8/20356-> 8/3173 2 1 0 0 0 (d)stamgrd 1 0 163 8/3173 <- 8/20355 2 1 1 0 0 (d)aaad 1 0 209 8/20355-> 8/3173 2 1 1 0 0 (d)stamgrd 1 0 204 8/20357-> 8/11025 2 1 0 0 0 (d)stamgrd 1 0 163 8/3173 <- 8/20354 2 0 1 0 0 (d)aaad 1 0 208 8/20354-> 8/3173 2 1 0 0 0 (d)stamgrd 1 0 163 8/3173 <- 8/20353 2 1 1 0 0 (d)aaad 1 0 208 8/20353-> 8/3173 2 1 1 0 0 (d)stamgrd 1 0 175 8/11025<- 8/20352 2 0 3 0 0 (d)aclmgrd 1 0 204 8/20352-> 8/11025 2 3 0 0 0 (d)stamgrd 1 0 190 8/11026<- 8/20351 2 2 2 0 0 (d)qosd 1 0 204 8/20351-> 8/11026 2 2 2 0 0 (d)stamgrd 1 0 175 8/11025<- 8/20350 2 0 0 0 0 (d)aclmgrd 1 0 204 8/20350-> 8/11025 2 0 0 0 0 (d)stamgrd 1 0 157 8/1215 <- 8/20347 2 3f 1 0 0 (d)ofcd 1 0 204 8/20347-> 8/1215 2 1 3f 0 0 (d)stamgrd 1 0 113 8/10521<- 8/20344 2 1e8 1 0 0 (d)kevent 1 0 204 8/20344-> 8/10521 2 1 1e8 0 0 (d)stamgrd 1 0 159 8/1198 <- 8/20343 2 0 1 0 0 (d)apmgrd 1 0 204 8/20343-> 8/1198 2 1 0 0 0 (d)stamgrd 1 0 193 8/11551<- 8/20342 2 0 4b2 0 0 (d)ipcimd 1 0 204 8/20342-> 8/11551 2 4b2 0 0 0 (d)stamgrd 1 0 190 8/11026<- 8/20340 2 0 3 0 0 (d)qosd 1 0 204 8/20340-> 8/11026 2 3 0 0 0 (d)stamgrd 1 0 190 8/11026<- 8/20339 2 0 0 0 0 (d)qosd 1 0 204 8/20339-> 8/11026 2 0 0 0 0 (d)stamgrd 1 0 193 8/11551<- 8/20338 2 26c 1 0 0 (d)ipcimd 1 0 204 8/20338-> 8/11551 2 1 26c 0 0 (d)stamgrd 1 0 133 8/10523<- 8/20336 2 19b 1db 0 0 (d)dbmd 1 0 184 8/20336-> 8/10523 2 1db 19b 0 0 (d)apmgrd 1 0 133 8/10523<- 8/20335 2 62 62 0 0 (d)dbmd 1 0 209 8/20335-> 8/10523 2 62 62 0 0 (d)stamgrd 1 0 133 8/10523<- 8/20334 2 62 62 0 0 (d)dbmd 1 0 133 8/10523<- 8/20333 2 6b 6b 0 0 (d)dbmd 1 0 207 8/20334-> 8/10523 2 62 62 0 0 (d)stamgrd 1 0 208 8/20333-> 8/10523 2 6b 6b 0 0 (d)stamgrd 1 0 210 8/1195 <- 8/20332 2 163 20e 0 0 (d)stamgrd 1 0 209 8/20332-> 8/1195 2 20e 163 0 0 (d)stamgrd 1 0 210 8/1195 <- 8/20331 2 256 3bc 0 0 (d)stamgrd 1 0 208 8/20331-> 8/1195 2 3bc 256 0 0 (d)stamgrd 1 0 210 8/1195 <- 8/20330 2 11a 19c 0 0 (d)stamgrd 1 0 207 8/20330-> 8/1195 2 19c 11a 0 0 (d)stamgrd 1 0 133 8/10523<- 8/20329 2 8 8 0 0 (d)dbmd 1 0 210 8/20329-> 8/10523 2 8 8 0 0 (d)stamgrd 1 0 204 8/1164 ==32768/0 0 0 0 0 0 (d)stamgrd 1 0 204 8/11048==32768/0 0 0 0 0 0 (d)stamgrd 1 0 204 8/1218 ==32768/0 0 0 0 0 0 (d)stamgrd 1 0 204 8/1217 ==32768/0 0 0 0 0 0 (d)stamgrd 1 0 204 8/1166 ==32768/0 0 0 0 0 0 (d)stamgrd 1 0 204 8/1165 ==32768/0 0 0 0 0 0 (d)stamgrd 1 0 113 8/10519<- 8/20326 2 80 6 0 0 (d)kevent 1 0 204 8/20326-> 8/10519 2 6 80 0 0 (d)stamgrd 1 0 163 8/3173 <- 8/20325 2 14 2 0 0 (d)aaad 1 0 212 8/20325-> 8/3173 2 2 14 0 0 (d)stamgrd 1 0 206 8/11052==32768/0 0 0 0 0 0 (d)stamgrd 1 0 206 8/1163 ==32768/0 0 0 0 0 0 (d)stamgrd 1 0 159 8/11045<- 8/20319 2 18a67 137e 0 0 (d)apmgrd 1 0 204 8/20319-> 8/11045 2 137e 18a67 0 0 (d)stamgrd 1 0 210 8/1195 ==32768/0 0 0 0 0 0 (d)stamgrd 1 0 133 8/10523<- 8/20318 2 42d d4b 0 0 (d)dbmd 1 0 209 8/20318-> 8/10523 2 d4b 42d 0 0 (d)stamgrd 1 0 133 8/10523<- 8/20317 2 6b8 17e6 0 0 (d)dbmd 1 0 208 8/20317-> 8/10523 2 17e6 6b8 0 0 (d)stamgrd 1 0 133 8/10523<- 8/20316 2 d3 ce 0 0 (d)dbmd 1 0 206 8/20316-> 8/10523 2 ce d3 0 0 (d)stamgrd 1 0 133 8/10523<- 8/20315 2 3 3 0 0 (d)dbmd 1 0 206 8/20315-> 8/10523 2 3 3 0 0 (d)stamgrd 1 0 133 8/10523<- 8/20312 2 382 ac8 0 0 (d)dbmd 1 0 207 8/20312-> 8/10523 2 ac8 382 0 0 (d)stamgrd 1 0 133 8/10523<- 8/20311 2 2 2 0 0 (d)dbmd 1 0 199 8/20311-> 8/10523 2 2 2 0 0 (d)comsh 1 0 133 8/10523<- 8/20310 2 1 1 0 0 (d)dbmd 1 0 204 8/20310-> 8/10523 2 1 1 0 0 (d)stamgrd 1 0 133 8/10523<- 8/20307 2 c a 0 0 (d)dbmd 1 0 204 8/20307-> 8/10523 2 a c 0 0 (d)stamgrd 1 0 138 8/620 <- 8/20306 2 2 1 0 0 (d)had 1 0 204 8/20306-> 8/620 2 1 2 0 0 (d)stamgrd 1 0 133 8/10523<- 8/20304 2 f0 f0 0 0 (d)dbmd 1 0 204 8/20304-> 8/10523 2 f0 f0 0 0 (d)stamgrd 1 0 133 8/10523<- 8/20303 2 1 1 0 0 (d)dbmd 1 0 204 8/20303-> 8/10523 2 1 1 0 0 (d)stamgrd 1 0 133 8/10523<- 8/20302 2 f3 f3 0 0 (d)dbmd 1 0 199 8/20302-> 8/10523 2 f3 f3 0 0 (d)comsh 1 0 133 8/10523<- 8/20273 2 7b dc 0 0 (d)dbmd 1 0 186 8/20273-> 8/10523 2 dc 7b 0 0 (d)apmgrd 1 0 133 8/10523<- 8/20272 2 46 5c 0 0 (d)dbmd 1 0 186 8/20272-> 8/10523 2 5c 46 0 0 (d)apmgrd 1 0 133 8/10523<- 8/20271 2 1d2 1f1 0 0 (d)dbmd 1 0 184 8/20271-> 8/10523 2 1f1 1d2 0 0 (d)apmgrd 1 0 133 8/10523<- 8/20268 2 1a0 1a0 0 0 (d)dbmd 1 0 200 8/20268-> 8/10523 2 1a0 1a0 0 0 (d)qosd 1 0 157 8/1215 <- 8/20267 2 3f 1 0 0 (d)ofcd 1 0 190 8/20267-> 8/1215 2 1 3f 0 0 (d)qosd 1 0 133 8/10523<- 8/20265 2 19 19 0 0 (d)dbmd 1 0 200 8/20265-> 8/10523 2 19 19 0 0 (d)qosd 1 0 113 8/10519<- 8/20260 2 0 1 0 0 (d)kevent 1 0 190 8/20260-> 8/10519 2 1 0 0 0 (d)qosd 1 0 175 8/11025<- 8/20258 2 0 0 0 0 (d)aclmgrd 1 0 190 8/20258-> 8/11025 2 0 0 0 0 (d)qosd 1 0 165 8/1138 <- 8/20257 2 0 0 0 0 (d)tranged 1 0 190 8/20257-> 8/1138 2 0 0 0 0 (d)qosd 1 0 133 8/10523<- 8/20246 2 4e 4e 0 0 (d)dbmd 1 0 190 8/20246-> 8/10523 2 4e 4e 0 0 (d)qosd 1 0 190 8/1128 ==32768/0 0 0 0 0 0 (d)qosd 1 0 190 8/1127 ==32768/0 0 0 0 0 0 (d)qosd 1 0 138 8/620 <- 8/20243 2 2 1 0 0 (d)had 1 0 190 8/20243-> 8/620 2 1 2 0 0 (d)qosd 1 0 133 8/10523<- 8/20242 2 2a 2a 0 0 (d)dbmd 1 0 190 8/20242-> 8/10523 2 2a 2a 0 0 (d)qosd 1 0 133 8/10523<- 8/20240 2 1 1 0 0 (d)dbmd 1 0 194 8/20240-> 8/10523 2 1 1 0 0 (d)ethd 1 0 116 8/11553<- 8/20239 2 0 32 0 0 (d)kmac/1 1 0 194 8/20239-> 8/11553 2 32 0 0 0 (d)ethd 1 0 194 8/1672 ==32768/0 0 0 0 0 0 (d)ethd 1 0 138 8/620 <- 8/20234 2 2 1 0 0 (d)had 1 0 194 8/20234-> 8/620 2 1 2 0 0 (d)ethd 1 0 113 8/10519<- 8/20231 2 0 1 0 0 (d)kevent 1 0 163 8/20231-> 8/10519 2 1 0 0 0 (d)aaad 1 0 133 8/10523<- 8/20230 2 1 1 0 0 (d)dbmd 1 0 163 8/20230-> 8/10523 2 1 1 0 0 (d)aaad 1 0 163 8/3173 ==32768/0 0 0 0 0 0 (d)aaad 1 0 163 8/3174 ==32768/0 0 0 0 0 0 (d)aaad 1 0 163 8/3177 ==32768/0 0 0 0 0 0 (d)aaad 1 0 163 8/3175 ==32768/0 0 0 0 0 0 (d)aaad 1 0 163 8/3176 ==32768/0 0 0 0 0 0 (d)aaad 1 0 133 8/10523<- 8/20228 2 1e3 1e2 0 0 (d)dbmd 1 0 194 8/20228-> 8/10523 2 1e2 1e3 0 0 (d)ethd 1 0 159 8/1188 <- 8/20226 2 53 34 0 0 (d)apmgrd 1 0 157 8/20226-> 8/1188 2 34 53 0 0 (d)ofcd 1 0 138 8/620 <- 8/20225 2 2 1 0 0 (d)had 1 0 194 8/20225-> 8/620 2 1 2 0 0 (d)ethd 1 0 194 8/1779 <- 8/20222 2 0 1 0 0 (d)ethd 1 0 164 8/20222-> 8/1779 2 1 0 0 0 (d)laggd 1 0 194 8/1779 ==32768/0 0 0 0 0 0 (d)ethd 1 0 194 8/1656 ==32768/0 0 0 0 0 0 (d)ethd 1 0 138 8/620 <- 8/20219 2 2 1 0 0 (d)had 1 0 194 8/20219-> 8/620 2 1 2 0 0 (d)ethd 1 0 113 8/10521<- 8/20218 2 1e7 1 0 0 (d)kevent 1 0 194 8/20218-> 8/10521 2 1 1e7 0 0 (d)ethd 1 0 113 8/10519<- 8/20217 2 105 86 0 0 (d)kevent 1 0 194 8/20217-> 8/10519 2 86 105 0 0 (d)ethd 1 0 113 8/10519<- 8/20216 2 0 1 0 0 (d)kevent 1 0 194 8/20216-> 8/10519 2 1 0 0 0 (d)ethd 1 0 195 8/1680 ==32768/0 0 0 0 0 0 (d)coppd 1 0 195 8/11557==32768/0 0 0 0 0 0 (d)coppd 1 0 195 8/1679 ==32768/0 0 0 0 0 0 (d)coppd 1 0 138 8/620 <- 8/20213 2 2 1 0 0 (d)had 1 0 195 8/20213-> 8/620 2 1 2 0 0 (d)coppd 1 0 133 8/10523<- 8/20212 2 e e 0 0 (d)dbmd 1 0 193 8/20212-> 8/10523 2 e e 0 0 (d)ipcimd 1 0 193 8/1658 ==32768/0 0 0 0 0 0 (d)ipcimd 1 0 193 8/1711 ==32768/0 0 0 0 0 0 (d)ipcimd 1 0 193 8/1659 ==32768/0 0 0 0 0 0 (d)ipcimd 1 0 193 8/11551==32768/0 0 0 0 0 0 (d)ipcimd 1 0 159 8/11050==32768/0 0 0 0 0 0 (d)apmgrd 1 0 159 8/1188 ==32768/0 0 0 0 0 0 (d)apmgrd 1 0 159 8/1161 ==32768/0 0 0 0 0 0 (d)apmgrd 1 0 159 8/1162 ==32768/0 0 0 0 0 0 (d)apmgrd 1 0 159 8/1160 ==32768/0 0 0 0 0 0 (d)apmgrd 1 0 159 8/11045==32768/0 0 0 0 0 0 (d)apmgrd 1 0 138 8/620 <- 8/20211 2 2 1 0 0 (d)had 1 0 193 8/20211-> 8/620 2 1 2 0 0 (d)ipcimd 1 0 113 8/10519<- 8/20208 2 0 2 0 0 (d)kevent 1 0 193 8/20208-> 8/10519 2 2 0 0 0 (d)ipcimd 1 0 113 8/10519<- 8/20205 2 0 1 0 0 (d)kevent 1 0 159 8/20205-> 8/10519 2 1 0 0 0 (d)apmgrd 1 0 113 8/10521<- 8/20203 2 0 0 0 0 (d)kevent 1 0 190 8/20203-> 8/10521 2 0 0 0 0 (d)qosd 1 0 113 8/10519<- 8/20201 2 54 49 0 0 (d)kevent 1 0 190 8/20201-> 8/10519 2 49 54 0 0 (d)qosd 1 0 175 8/11025<- 8/20200 2 0 0 0 0 (d)aclmgrd 1 0 190 8/20200-> 8/11025 2 0 0 0 0 (d)qosd 1 0 164 8/1131 <- 8/20199 2 0 1 0 0 (d)laggd 1 0 166 8/20199-> 8/1131 2 1 0 0 0 (d)vland 1 0 190 8/11026==32768/0 0 0 0 0 0 (d)qosd 1 0 159 8/1198 ==32768/0 0 0 0 0 0 (d)apmgrd 1 0 133 8/10523<- 8/20196 2 4c 4c 0 0 (d)dbmd 1 0 187 8/20196-> 8/10523 2 4c 4c 0 0 (d)aclmgrd 1 0 157 8/1215 <- 8/20193 2 3f 1 0 0 (d)ofcd 1 0 175 8/20193-> 8/1215 2 1 3f 0 0 (d)aclmgrd 1 0 133 8/10523<- 8/20187 2 82 a6 0 0 (d)dbmd 1 0 159 8/20187-> 8/10523 2 a6 82 0 0 (d)apmgrd 1 0 113 8/10519<- 8/20183 2 5 5 0 0 (d)kevent 1 0 175 8/20183-> 8/10519 2 5 5 0 0 (d)aclmgrd 1 0 113 8/10519<- 8/20181 2 0 1 0 0 (d)kevent 1 0 175 8/20181-> 8/10519 2 1 0 0 0 (d)aclmgrd 1 0 132 8/10533<- 8/20179 2 1 1 0 0 (d)licd 1 0 159 8/20179-> 8/10533 2 1 1 0 0 (d)apmgrd 1 0 175 8/11025==32768/0 0 0 0 0 0 (d)aclmgrd 1 0 175 8/1126 ==32768/0 0 0 0 0 0 (d)aclmgrd 1 0 133 8/10523<- 8/20177 2 10 10 0 0 (d)dbmd 1 0 175 8/20177-> 8/10523 2 10 10 0 0 (d)aclmgrd 1 0 165 8/1138 <- 8/20176 2 0 0 0 0 (d)tranged 1 0 175 8/20176-> 8/1138 2 0 0 0 0 (d)aclmgrd 1 0 113 8/10519<- 8/20174 2 0 1 0 0 (d)kevent 1 0 175 8/20174-> 8/10519 2 1 0 0 0 (d)aclmgrd 1 0 175 8/1125 ==32768/0 0 0 0 0 0 (d)aclmgrd 1 0 138 8/620 <- 8/20173 2 2 1 0 0 (d)had 1 0 175 8/20173-> 8/620 2 1 2 0 0 (d)aclmgrd 1 0 138 8/620 <- 8/20172 2 2 1 0 0 (d)had 1 0 159 8/20172-> 8/620 2 1 2 0 0 (d)apmgrd 1 0 113 8/10519<- 8/20170 2 9 8 0 0 (d)kevent 1 0 159 8/20170-> 8/10519 2 8 9 0 0 (d)apmgrd 1 0 133 8/10523<- 8/20169 2 24 23 0 0 (d)dbmd 1 0 175 8/20169-> 8/10523 2 23 24 0 0 (d)aclmgrd 1 0 133 8/10523<- 8/20167 2 3b3 2fc 0 0 (d)dbmd 1 0 159 8/20167-> 8/10523 2 2fc 3b3 0 0 (d)apmgrd 1 0 133 8/10523<- 8/20166 2 1 1 0 0 (d)dbmd 1 0 159 8/20166-> 8/10523 2 1 1 0 0 (d)apmgrd 1 0 113 8/10519<- 8/20163 2 7e 42 0 0 (d)kevent 1 0 166 8/20163-> 8/10519 2 42 7e 0 0 (d)vland 1 0 166 8/621 ==32768/0 0 0 0 0 0 (d)vland 1 0 133 8/10523<- 8/20162 2 3 3 0 0 (d)dbmd 1 0 166 8/20162-> 8/10523 2 3 3 0 0 (d)vland 1 0 133 8/10523<- 8/20160 2 649 649 0 0 (d)dbmd 1 0 156 8/20160-> 8/10523 2 649 649 0 0 (d)modulep 1 0 156 8/1219 ==32768/0 0 0 0 0 0 (d)modulep 1 0 138 8/620 <- 8/20159 2 2 1 0 0 (d)had 1 0 161 8/20159-> 8/620 2 1 2 0 0 (d)lauthd 1 0 133 8/10523<- 8/20158 2 6c 6c 0 0 (d)dbmd 1 0 161 8/20158-> 8/10523 2 6c 6c 0 0 (d)lauthd 1 0 133 8/10523<- 8/20155 2 434 42b 0 0 (d)dbmd 1 0 163 8/20155-> 8/10523 2 42b 434 0 0 (d)aaad 1 0 133 8/10523<- 8/20154 2 28 28 0 0 (d)dbmd 1 0 163 8/20154-> 8/10523 2 28 28 0 0 (d)aaad 1 0 133 8/10523<- 8/20153 2 54 51 0 0 (d)dbmd 1 0 161 8/20153-> 8/10523 2 51 54 0 0 (d)lauthd 1 0 138 8/620 <- 8/20152 2 2 1 0 0 (d)had 1 0 163 8/20152-> 8/620 2 1 2 0 0 (d)aaad 1 0 133 8/10523<- 8/20151 2 e0 db 0 0 (d)dbmd 1 0 166 8/20151-> 8/10523 2 db e0 0 0 (d)vland 1 0 167 8/3229 ==32768/0 0 0 0 0 0 (d)cryptom 1 0 113 8/10519<- 8/20144 2 0 1 0 0 (d)kevent 1 0 167 8/20144-> 8/10519 2 1 0 0 0 (d)cryptom 1 0 167 8/3246 ==32768/0 0 0 0 0 0 (d)cryptom 1 0 167 8/3212 ==32768/0 0 0 0 0 0 (d)cryptom 1 0 138 8/620 <- 8/20143 2 2 1 0 0 (d)had 1 0 167 8/20143-> 8/620 2 1 2 0 0 (d)cryptom 1 0 133 8/10523<- 8/20138 2 24 24 0 0 (d)dbmd 1 0 164 8/20138-> 8/10523 2 24 24 0 0 (d)laggd 1 0 157 8/1215 ==32768/0 0 0 0 0 0 (d)ofcd 1 0 164 8/11033==32768/0 0 0 0 0 0 (d)laggd 1 0 113 8/10519<- 8/20135 2 15 9 0 0 (d)kevent 1 0 164 8/20135-> 8/10519 2 9 15 0 0 (d)laggd 1 0 113 8/10519<- 8/20133 2 0 1 0 0 (d)kevent 1 0 164 8/20133-> 8/10519 2 1 0 0 0 (d)laggd 1 0 164 8/1131 <- 8/20131 2 0 1 0 0 (d)laggd 1 0 145 8/20131-> 8/1131 2 1 0 0 0 (d)ifmgr 1 0 164 8/11027==32768/0 0 0 0 0 0 (d)laggd 1 0 164 8/1132 ==32768/0 0 0 0 0 0 (d)laggd 1 0 164 8/1131 ==32768/0 0 0 0 0 0 (d)laggd 1 0 138 8/620 <- 8/20130 2 2 1 0 0 (d)had 1 0 164 8/20130-> 8/620 2 1 2 0 0 (d)laggd 1 0 133 8/10523<- 8/20128 2 f f 0 0 (d)dbmd 1 0 164 8/20128-> 8/10523 2 f f 0 0 (d)laggd 1 0 133 8/10523<- 8/20127 2 9 7 0 0 (d)dbmd 1 0 165 8/20127-> 8/10523 2 7 9 0 0 (d)tranged 1 0 165 8/1138 ==32768/0 0 0 0 0 0 (d)tranged 1 0 113 8/10519<- 8/20125 2 0 1 0 0 (d)kevent 1 0 162 8/20125-> 8/10519 2 1 0 0 0 (d)ttymgrd 1 0 113 8/10519<- 8/20121 2 0 1 0 0 (d)kevent 1 0 160 8/20121-> 8/10519 2 1 0 0 0 (d)sysmand 1 0 138 8/620 <- 8/20120 2 2 1 0 0 (d)had 1 0 160 8/10532==32768/0 0 0 0 0 0 (d)sysmand 1 0 165 8/20120-> 8/620 2 1 2 0 0 (d)tranged 1 0 113 8/10519<- 8/20118 2 0 1 0 0 (d)kevent 1 0 165 8/20118-> 8/10519 2 1 0 0 0 (d)tranged 1 0 133 8/10523<- 8/20117 2 55 55 0 0 (d)dbmd 1 0 162 8/20117-> 8/10523 2 55 55 0 0 (d)ttymgrd 1 0 133 8/10523<- 8/20116 2 14 14 0 0 (d)dbmd 1 0 160 8/20116-> 8/10523 2 14 14 0 0 (d)sysmand 1 0 133 8/10523<- 8/20115 2 89 89 0 0 (d)dbmd 1 0 162 8/20115-> 8/10523 2 89 89 0 0 (d)ttymgrd 1 0 162 8/10534==32768/0 0 0 0 0 0 (d)ttymgrd 1 0 138 8/620 <- 8/20114 2 2 1 0 0 (d)had 1 0 157 8/20114-> 8/620 2 1 2 0 0 (d)ofcd 1 0 158 8/1688 ==32768/0 0 0 0 0 0 (d)trackd 1 0 133 8/10523<- 8/20112 2 e d 0 0 (d)dbmd 1 0 158 8/20112-> 8/10523 2 d e 0 0 (d)trackd 1 0 113 8/10519<- 8/20106 2 61 49 0 0 (d)kevent 1 0 158 8/20106-> 8/10519 2 49 61 0 0 (d)trackd 1 0 138 8/620 <- 8/20105 2 2 1 0 0 (d)had 1 0 156 8/20105-> 8/620 2 1 2 0 0 (d)modulep 1 0 113 8/10519<- 8/20103 2 0 1 0 0 (d)kevent 1 0 1 8/20103-> 8/10519 2 1 0 0 0 (d)scmd 1 0 145 8/616 <- 8/20078 2 b c 0 0 (d)ifmgr 1 0 150 8/20078-> 8/616 2 c b 0 0 (d)ifmgr 1 0 113 8/10519<- 8/20072 2 0 2 0 0 (d)kevent 1 0 143 8/20072-> 8/10519 2 2 0 0 0 (d)ifmgr 1 0 147 8/14128==32768/0 0 0 0 0 0 (d)drvciud 1 0 133 8/10523<- 8/20061 2 21d9 21d9 0 0 (d)dbmd 1 0 146 8/20061-> 8/10523 2 21d9 21d9 0 0 (d)syslogd 1 0 113 8/10519<- 8/20049 2 0 3 0 0 (d)kevent 1 0 144 8/20049-> 8/10519 2 3 0 0 0 (d)edev 1 0 113 8/10519<- 8/20048 2 0 2 0 0 (d)kevent 1 0 144 8/20048-> 8/10519 2 2 0 0 0 (d)edev 1 0 133 8/10523<- 8/20047 2 2b 2b 0 0 (d)dbmd 1 0 144 8/20047-> 8/10523 2 2b 2b 0 0 (d)edev 1 0 144 8/10526==32768/0 0 0 0 0 0 (d)edev 1 0 143 8/616 ==32768/0 0 0 0 0 0 (d)ifmgr 1 0 133 8/10523<- 8/20041 2 1 1 0 0 (d)dbmd 1 0 139 8/20041-> 8/10523 2 1 1 0 0 (d)syslogd 1 0 133 8/10523<- 8/20040 2 2a 2a 0 0 (d)dbmd 1 0 143 8/20040-> 8/10523 2 2a 2a 0 0 (d)ifmgr 1 0 133 8/10523<- 8/20039 2 1 1 0 0 (d)dbmd 1 0 143 8/20039-> 8/10523 2 1 1 0 0 (d)ifmgr 1 0 143 8/10552==32768/0 0 0 0 0 0 (d)ifmgr 1 0 113 8/10519<- 8/20037 2 2b0 f8 0 0 (d)kevent 1 0 143 8/20037-> 8/10519 2 f8 2b0 0 0 (d)ifmgr 1 0 138 8/620 <- 8/20034 2 3 1 0 0 (d)had 1 0 133 8/10523<- 8/20033 2 1 1 0 0 (d)dbmd 1 0 140 8/20033-> 8/10523 2 1 1 0 0 (d)devd 1 0 113 8/10519<- 8/20030 2 0 1 0 0 (d)kevent 1 0 140 8/20030-> 8/10519 2 1 0 0 0 (d)devd 1 0 133 8/10523<- 8/20029 2 30 30 0 0 (d)dbmd 1 0 140 8/20029-> 8/10523 2 30 30 0 0 (d)devd 1 0 140 8/10518==32768/0 0 0 0 0 0 (d)devd 1 0 113 8/10519<- 8/20027 2 c d 0 0 (d)kevent 1 0 139 8/20027-> 8/10519 2 d c 0 0 (d)syslogd 1 0 133 8/10523<- 8/20025 2 4 4 0 0 (d)dbmd 1 0 139 8/20025-> 8/10523 2 4 4 0 0 (d)syslogd 1 0 133 8/10523<- 8/20024 2 12f 12f 0 0 (d)dbmd 1 0 139 8/20024-> 8/10523 2 12f 12f 0 0 (d)syslogd 1 0 139 8/623 ==32768/0 0 0 0 0 0 (d)syslogd 1 0 138 8/620 <- 8/20023 2 2 1 0 0 (d)had 1 0 139 8/20023-> 8/620 2 1 2 0 0 (d)syslogd 1 0 113 8/10519<- 8/20020 2 0 1 0 0 (d)kevent 1 0 136 8/20020-> 8/10519 2 1 0 0 0 (d)diagd 1 0 133 8/10523<- 8/20019 2 16 16 0 0 (d)dbmd 1 0 136 8/20019-> 8/10523 2 16 16 0 0 (d)diagd 1 0 133 8/10523<- 8/20018 2 1 1 0 0 (d)dbmd 1 0 136 8/20018-> 8/10523 2 1 1 0 0 (d)diagd 1 0 133 8/10523<- 8/20013 2 106 106 0 0 (d)dbmd 1 0 138 8/20013-> 8/10523 2 106 106 0 0 (d)had 1 0 138 8/620 ==32768/0 0 0 0 0 0 (d)had 1 0 136 8/10525==32768/0 0 0 0 0 0 (d)diagd 1 0 135 8/20034-> 8/620 2 1 3 0 0 (d)drvdiag 1 0 135 8/14121==32768/0 0 0 0 0 0 (d)drvdiag 1 0 133 8/10523<- 8/20010 2 a a 0 0 (d)dbmd 1 0 135 8/20010-> 8/10523 2 a a 0 0 (d)drvdiag 1 0 132 8/10533==32768/0 0 0 0 0 0 (d)licd 1 0 133 8/10523==32768/0 0 0 0 0 0 (d)dbmd 1 0 130 8/619 ==32768/0 0 0 0 0 0 (d)fsd 1 0 131 8/10515==32768/0 0 0 0 0 0 (d)fsd 1 0 129 8/11552==32768/0 0 0 0 0 0 (d)cioctld 1 0 129 8/11550==32768/0 0 0 0 0 0 (d)cioctld 1 0 1 8/10517==32768/0 0 0 0 0 0 (d)scmd 1 0 1 8/1664 ==32768/0 0 0 0 0 0 (d)scmd 1 0 1 8/1663 ==32768/0 0 0 0 0 0 (d)scmd 1 0 1 8/11553==32768/0 0 0 0 0 0 (d)scmd 1 0 125 8/1644 ==32768/0 0 0 0 0 0 (d)sock/1 1 0 1 8/11569==32768/0 0 0 0 0 0 (d)scmd 1 0 125 8/1643 ==32768/0 0 0 0 0 0 (d)sock/1 1 0 125 8/11539==32768/0 0 0 0 0 0 (d)sock/1 1 0 1 8/11544==32768/0 0 0 0 0 0 (d)scmd 1 0 1 8/10521==32768/0 0 0 0 0 0 (d)scmd 1 0 1 8/10519==32768/0 0 0 0 0 0 (d)scmd Total PCB num: 880 ======================================================== ===============display system internal lipc stcp links local 11045=============== MDC VRF PID [LAddr/LPort--RAddr/RPort] Sta SndPkt RcvPkt SndCc RcvCc Owner 1 0 159 8/11045<- 8/20319 2 18a68 137e 1 0 (d)apmgrd 1 0 204 8/20319-> 8/11045 2 137e 18a68 0 0 (d)stamgrd 1 0 159 8/11045==32768/0 0 0 0 0 0 (d)apmgrd Total PCB num: 3 ======================================================== ===============display system internal lipc stcp links global 1188=============== MDC VRF PID [LAddr/LPort--RAddr/RPort] Sta SndPkt RcvPkt SndCc RcvCc Owner 1 0 159 8/1188 <- 8/20819 2 40 21 0 0 (d)apmgrd 1 0 235 8/20819-> 8/1188 2 21 40 0 0 (d)portald 1 0 159 8/1188 <- 8/20601 2 12b5c 19d 1 0 (d)apmgrd 1 0 239 8/20601-> 8/1188 2 19d 12b5c 0 0 (d)rrmd 1 0 159 8/1188 <- 8/20226 2 53 34 0 0 (d)apmgrd 1 0 157 8/20226-> 8/1188 2 34 53 0 0 (d)ofcd 1 0 159 8/1188 ==32768/0 0 0 0 0 0 (d)apmgrd Total PCB num: 7 ======================================================== ============================= logfile save ============================= The contents in the log file buffer have been saved to the file flash:/logfile/logfile.log. ==================================================================== ======================= diagnostic-logfile save ======================= The contents in the diagnostic log file buffer have been saved to the file flash:/diagfile/diagfile.log. ==================================================================== ==================================================================== ===============display system internal kernel memory pool=============== Active Number Size Align Slab Pg/Slab ASlabs NSlabs Name 0 0 60 0 36 1 0 0 blkdev_ioc 0 0 132 0 22 1 0 0 lbsticky_6_bothipport 0 0 12 0 64 1 0 0 mfib_source_rp_cache 0 0 64 0 32 1 0 0 vz_quota_ugid 0 0 17861 0 1 8 0 0 kssl_buf_cache 0 0 188 0 34 2 0 0 memSESSION_TCPSEQ_CHECK 1 32 40 0 32 1 1 1 uid_cache 0 0 68 0 34 1 0 0 PBR_MAP_cachep 0 0 72 0 34 1 0 0 L3VPN_VRF 0 0 48 0 42 1 0 0 memSESS_SERVICE_12 0 0 64 0 36 1 0 0 ND_Static_Cache 15 26 2304 0 13 8 2 2 IP_IFCB_cache 42255 44016 48 0 42 1 1048 1048 NAT_SESSION_EXT_INFO 2603 4900 112 0 25 1 196 196 dim_lseries_sess 0 0 76 0 32 1 0 0 mfib_drv_oif_cache 0 0 544 0 27 4 0 0 jffs2_i 72 250 256 0 25 2 9 10 files_cache 0 0 92 0 28 1 0 0 memSESS_ALG_HTTP 0 0 52 4 39 1 0 0 TnlPcb 5 6 2097104 0 1 512 5 6 kmalloc-2097104 0 0 512 0 29 4 0 0 lb_pool 24 63 128 0 21 1 3 3 NETLINK 121 315 408 4 35 4 9 9 tcpinp 0 0 136 0 22 1 0 0 mcfs_mapped_oif4 0 0 104 0 26 1 0 0 scsi_io_context 12 84 2560 0 12 8 5 7 mbuf_db 0 0 32 0 51 1 0 0 mfib_supervlan_oif_cache 0 0 544 0 27 4 0 0 fat_inode_cache 7878 8001 144 4 21 1 381 381 dentry 0 0 104 0 26 1 0 0 lbsticky_4_srcipport 0 0 20 0 56 1 0 0 TCP_Reassemble_Latter_Frag_Node_Info 0 0 1056 4 29 8 0 0 pid_namespace 32 50 236 0 25 2 2 2 CCF_JOBDESC 0 0 72 0 34 1 0 0 ND_OpenFlow_Entry_Cachep 137 230 36 0 46 1 5 5 FIB_PrefixBase_cache 0 0 12 0 64 1 0 0 lb_se_cache_udp4 0 0 28 0 51 1 0 0 mfib_rp_cache 0 0 32 0 51 1 0 0 jffs2_tmp_dnode 23 153 32 0 51 1 3 3 SYNC_Chn_Object 60 96 208 0 32 2 3 3 STAMGR_KSERVICEBSS_CACHE 121 150 108 0 25 1 6 6 ADJ4_Ext_Cachep 0 0 24 0 56 1 0 0 memTopHisTickInfo 0 0 20 4 56 1 0 0 tcpreass:1 1 1 33554384 0 1 8192 1 1 kmalloc-33554384 0 0 40 0 46 1 0 0 lb_body_ctx 0 0 52 4 39 1 0 0 pktppppcb 2 180 60 4 36 1 2 5 tcptw 0 0 172 0 36 2 0 0 mcfs_reg_oif6 2 39 768 0 39 8 1 1 sgpool-32 0 75 2048 0 15 8 0 5 mbuf_vdb4 0 0 40 0 46 1 0 0 mfib_l2m_group_cache 7 69 616 0 23 4 3 3 bdev_cache 2 32 48 0 32 1 1 1 biovec-4 0 0 104 0 26 1 0 0 lbsticky_4_dstipport 0 0 92 0 28 1 0 0 memAVC_LIST_IPV6_NODE 0 0 196 4 32 2 0 0 kioctx 0 0 572 0 26 4 0 0 tp_cb_local 0 0 40 0 46 1 0 0 LOG_SESSION_EXT_INFO 1420 1504 80 0 32 1 47 47 eventpoll_epi 0 0 36 0 46 1 0 0 FIB6_PrefixBase_cache 14 126 144 0 21 1 4 6 memSESS_EXT 0 0 60 0 36 1 0 0 ARP_Static_Entry_Cachep 0 102 68 0 34 1 0 3 DIM_KSIPCTX_S 0 0 52 0 39 1 0 0 mfib_subvlan_cache 377 420 4096 8 7 8 58 60 kmalloc-4096 0 0 576 0 25 4 0 0 fuse_inode 0 0 24 0 56 1 0 0 dim_detect_filter_ipv4_age 0 0 148 0 20 1 0 0 l2mcfs_port6 2051 2072 96 0 28 1 74 74 ADJ6_COMBASE_Cache 231 320 44 4 32 1 10 10 pid 0 0 140 0 21 1 0 0 lb_proximity_entry_ip6 75 80 65488 0 1 16 75 80 kmalloc-65488 20 96 72 0 32 1 2 3 Lipc_TranCache 0 0 28 0 51 1 0 0 OSI_PCB_cachep 1395 1551 440 4 33 4 47 47 socket 0 0 8 0 73 1 0 0 mfib_l2m_port_pdt_cache 80955 81312 24 4 56 1 1448 1452 page_cgroup 2 10 3072 0 10 8 1 1 biovec-256 0 0 108 0 25 1 0 0 lbsticky_4_bothipport 0 0 192 0 32 2 0 0 vz_quota_master 0 0 60 0 36 1 0 0 khttp_trans 0 0 136 0 22 1 0 0 Connlmt_Stat_Nodes_IPv4 570 645 2048 8 15 8 42 43 kmalloc-2048 0 0 100 0 26 1 0 0 memDSLITE 9 112 24 0 56 1 2 2 FIB_VNEntryBase_cache 0 0 24 0 56 1 0 0 memSESS_SERVICE_6 0 0 32 0 51 1 0 0 ND_Vlan_Cache 0 0 68 0 34 1 0 0 dim_lsip_hnode 0 0 20 0 56 1 0 0 LOG_NAT_EXT_INFO 0 0 352 0 20 2 0 0 IP6FS_FCacheHash_cachep 0 0 128 0 23 1 0 0 DIM_KOPT_FLOWBITS 165 352 424 0 32 4 11 11 signal_cache 8 8 1048528 0 1 256 8 8 kmalloc-1048528 9 60 224 4 30 2 2 2 ethcb 0 0 16 0 64 1 0 0 lb_mbuf_que 5 78 104 4 26 1 3 3 unpcb 75 140 408 4 35 4 4 4 udpcb 0 0 132 0 22 1 0 0 mcfs_reg_oif4 0 210 24 0 42 1 0 5 mbuf_dbinfo 3347 3570 1024 8 30 8 116 119 kmalloc-1024 0 0 20 0 56 1 0 0 fat_cache 0 0 52 0 39 1 0 0 mfib_supervlan_iif_cache 4553 4672 176 0 32 2 146 146 filp 0 0 112 0 25 1 0 0 lbsticky_6_srcip 0 0 48 0 42 1 0 0 TCP_Reassemble_Node_Info 0 0 320 0 22 2 0 0 PBR_INSTANCENODE_cachep 0 0 76 0 32 1 0 0 PBR_NHRADIX_cachep 0 0 200 0 33 2 0 0 memRELA6 0 0 28 0 51 1 0 0 ND_MACInfo_Cache 112 184 40 0 46 1 4 4 FIB_ARPHost_cache 0 0 16 0 64 1 0 0 lb_se_cache_tack 0 0 68 0 34 1 0 0 jffs2_raw_inode 0 0 72 0 34 1 0 0 mfib_oif_cache 5 48 116 0 24 1 2 2 SYNC_MIX_Object 60 96 80 0 32 1 3 3 STAMGR_KBSS_CACHE 2176 2205 140 0 21 1 105 105 ADJ4_Entry_Cachep 68 175 552 0 25 4 6 7 mm_struct 0 0 48 0 42 1 0 0 memTopHisIPv6 1 1 16777168 0 1 4096 1 1 kmalloc-16777168 9 160 80 4 32 1 5 5 hostcache:1 0 0 28 0 51 1 0 0 lb_html_ctx 9 75 108 4 25 1 3 3 dot11cb 1072 1204 512 8 28 4 42 43 kmalloc-512 0 0 20 0 56 1 0 0 TCPNSR_SYNCCache 0 0 160 0 39 2 0 0 mcfs_supervlan_oif6 2 36 384 0 36 4 1 1 sgpool-16 0 150 1024 0 30 8 0 5 mbuf_vdb3 0 0 40 0 46 1 0 0 mfib_nbma_if_cache 13277 13398 44 0 42 1 319 319 sysfs_dir_cache 2 256 12 0 64 1 1 4 biovec-1 0 0 112 0 25 1 0 0 lbsticky_6_dstip 0 0 80 0 32 1 0 0 memAVC_LIST_IPV4_NODE 0 0 144 8 21 1 0 0 kiocb 0 0 568 0 26 4 0 0 tp_cb_accept 0 0 64 0 36 1 0 0 memSESS_TRAFFICLOG_IPV6_NODE 0 0 32 0 51 1 0 0 WADJ6_PHY_Cachep 0 0 52 0 39 1 0 0 FIB6_NDHost_Cache 108 224 20 0 56 1 4 4 ARP_Vlan_Cachep 0 0 64 0 36 1 0 0 DIM_KMAILCTX_S 5679 7956 104 0 26 1 306 306 memSESS_NORM 0 0 24 0 56 1 0 0 jffs2_inode_cache 0 0 208 0 32 2 0 0 mfib_source_route_cache 0 0 100 0 26 1 0 0 lbsticky_uint 0 0 140 0 21 1 0 0 l2mcfs_cache6 186 357 28 0 51 1 7 7 dim_opt_content_cache 0 0 108 0 25 1 0 0 ADJ6_Ext_Cache 189 286 136 0 22 1 11 13 idr_layer_cache 0 0 128 0 23 1 0 0 lb_proximity_entry_ip4 513 675 256 8 25 2 26 27 kmalloc-256 99 100 32720 0 1 8 99 100 kmalloc-32720 0 126 20 0 42 1 0 3 Lipc_QEntCache 1 35 408 4 35 4 1 1 ripcb 0 0 12 0 64 1 0 0 l2mcfs_slot 0 0 28 0 51 1 0 0 mfib_l2m_port_cache 4003 4080 496 0 30 4 135 136 proc_inode_cache 2 20 1536 0 20 8 1 1 biovec-128 0 0 128 0 23 1 0 0 lbsticky_6_bothip 0 0 168 16 32 2 0 0 dquot 0 0 16 0 64 1 0 0 khttp_conn_mbufque 0 0 160 0 39 2 0 0 Connlmt_Stat_Nodes_IPv6 0 87 1080 0 29 8 0 3 IPCIM_ENTRY_EXT_cachep 282 368 36 0 46 1 8 8 kepoll_pwq 21 51 28 0 51 1 1 1 memalert_notifier 10 78 160 0 39 2 2 2 FIB_VNEntry_cache 0 0 40 0 46 1 0 0 ND_Private_Cache 0 0 16 0 64 1 0 0 memSESS_SERVICE_4 0 0 96 8 28 1 0 0 cfq_io_context 1 39 56 0 39 1 1 1 ADJ_Ref_Cachep 0 0 16 0 64 1 0 0 memPFLT_Cache 0 0 3584 0 9 8 0 0 dim_mime_ctx 0 96 116 0 24 1 0 4 IP6FS_CacheHash_cachep 14709 14847 128 8 21 1 704 707 kmalloc-128 0 0 44 0 42 1 0 0 DIM_KFTPCTX_S 165 230 3116 0 10 8 23 23 sighand_cache 11 11 524240 0 1 128 11 11 kmalloc-524240 9 78 52 4 39 1 2 2 pktpcb 0 0 176 0 36 2 0 0 lb_trans 0 0 24 0 56 1 0 0 LPS_IFNODE_cachep 0 0 132 0 22 1 0 0 mcfs_supervlan_oif4 25 27 1144 0 27 8 1 1 blkdev_queue 0 0 20 0 56 1 0 0 dnotify_cache 174 468 360 0 36 4 13 13 mbuf_ctlhdr 0 0 20 0 56 1 0 0 mfib_vlan_oif_cache 0 49 4096 0 7 8 0 7 names_cache 0 0 100 0 26 1 0 0 lbsticky_4_srcip 0 0 72 0 34 1 0 0 TCP_Reassemble_Control_block_Info 0 0 72 0 34 1 0 0 PBR_INSTANCE_cachep 0 0 28 4 51 1 0 0 nsproxy 0 0 60 0 36 1 0 0 ND_MACHash_Cache 0 140 180 0 35 2 0 4 memRELA 14891 15040 64 8 32 1 467 470 kmalloc-64 15 18 4672 0 6 8 3 3 IP6_IFCB_cache 0 0 88 0 30 1 0 0 lb_se_cache_ext 0 0 40 0 46 1 0 0 jffs2_raw_dirent 15 180 60 0 36 1 3 5 DIM_KDECOMPRESS_STATE_S 0 0 148 0 20 1 0 0 mfib_source_cache 10 64 76 0 32 1 2 2 SYNC_UC_Object 138 161 128 0 23 1 7 7 MAC_Entry_Cachep 10367 10530 84 0 30 1 351 351 vm_area_struct 0 0 36 0 46 1 0 0 memTopHisIPv4 3 3 8388560 0 1 2048 3 3 kmalloc-8388560 4 175 184 4 35 2 3 5 syncache:1 0 0 76 0 32 1 0 0 lb_comp_ctx 0 0 152 0 20 1 0 0 NAT_STATICPORTBLOCK 9 117 52 4 39 1 3 3 pktdot11pcb 0 56 20 4 56 1 0 1 sackhole 0 0 152 0 20 1 0 0 mcfs_oif6 2 32 192 0 32 2 1 1 sgpool-8 2 140 512 0 28 4 1 5 mbuf_vdb2 0 0 40 0 46 1 0 0 mfib_mapped_iif_cache 24 126 128 0 21 1 6 6 mnt_cache 2 128 64 4 32 1 1 4 bio 0 0 100 0 26 1 0 0 lbsticky_4_dstip 0 0 184 0 35 2 0 0 memAVC_LIST_USER_NODE 0 0 16 0 64 1 0 0 fasync_cache 12634 12810 32 8 42 1 305 305 kmalloc-32 1 46 128 0 23 1 1 2 memNAT_IFCB 0 0 52 0 39 1 0 0 memSESS_TRAFFICLOG_IPV4_NODE 0 0 116 0 24 1 0 0 FIB_RADIX_cache 0 0 24 0 56 1 0 0 lb_se_cache_sticky 0 0 24 0 56 1 0 0 jffs2_node_frag 109 184 40 0 46 1 4 4 ARP_Private_Cachep 13 280 20 0 56 1 4 5 DIM_KHTTP_TRANS 0 0 12 0 64 1 0 0 mfib_slot_bitmap_cache 8 14 2168 0 14 8 1 1 PPP_LINKCB_Cache 0 0 120 0 24 1 0 0 l2mcfs_port4 0 0 28 0 51 1 0 0 dim_byte_extract_cache 2051 2060 152 0 20 1 103 103 ADJ6_Entry_Cache 0 0 1342176800 1 32768 0 0 kmalloc-134217680 0 0 88 0 30 1 0 0 lblimit_stat6 98 108 16336 0 2 8 51 54 kmalloc-16336 1152 1281 104 0 21 1 61 61 Lipc_PcbCache 0 0 156 0 39 2 0 0 mcfs_mti_oif6 2 10 3072 0 10 8 1 1 sgpool-128 0 0 176 0 32 2 0 0 skbuff_head_cache 0 15 8192 0 3 8 0 5 mbuf_vdb6 0 0 48 0 42 1 0 0 mfib_l2m_mac_cache 7717 7872 16 8 64 1 123 123 kmalloc-16 0 105 144 4 21 1 0 5 sigqueue 2 39 768 0 39 8 1 1 biovec-64 0 0 104 0 26 1 0 0 lbsticky_4_bothip 0 0 104 0 26 1 0 0 memAVC_CONNLMT_RULE_NODE 0 153 28 0 51 1 0 3 inotify_event_cache 0 0 260 0 26 2 0 0 IPCIM_ENTRY_IPV6_cachep 0 0 84 0 30 1 0 0 khttp_conn 0 0 40 0 46 1 0 0 Connlmt_Ext_Info 182 256 80 0 32 1 8 8 kepoll_kepi 25 112 24 0 56 1 2 2 FIB_REF_cache 2255 4015 8 0 73 1 55 55 memSESS_SERVICE_2 0 0 88 4 30 1 0 0 cfq_queue 0 0 64 0 36 1 0 0 ARP_OpenFlow_Entry_Cachep 0 0 20 0 56 1 0 0 memPFLT_FSW 2 36 60 0 36 1 1 1 dim_lseries_negiate_ipv4 1 105 328 0 21 2 1 5 IPFS_FCacheHash_cachep 236 380 1616 8 19 8 20 20 task_struct 0 0 68 0 34 1 0 0 Connlmt_Pkt_Nodes 8 9 262096 0 1 64 8 9 kmalloc-262096 876 1050 256 0 25 2 42 42 Lipc_StcpCache 0 0 128 0 23 1 0 0 lbsticky_ssl 0 0 32 0 51 1 0 0 LPS_PCB_cachep 4610 5110 8 8 73 1 69 70 kmalloc-8 0 0 124 0 23 1 0 0 mcfs_oif4 4 34 188 0 34 2 1 1 blkdev_requests 0 0 112 0 25 1 0 0 lbsticky_md5 0 0 16 0 64 1 0 0 mfib_if_product_info_cache 487 546 52 0 39 1 14 14 buffer_head 1 75 112 0 25 1 1 3 file_lock_cache 0 0 96 0 28 1 0 0 PBR_MAPNODE_cachep 0 0 28 0 51 1 0 0 PORTAL_CACHE_S 0 0 120 0 24 1 0 0 posix_timers_cache 0 0 84 0 30 1 0 0 memSESS_FDB 0 0 88 0 30 1 0 0 ND_Rule_Cachep 0 0 32 0 51 1 0 0 lb_se_cache_base 0 0 16 0 64 1 0 0 jffs2_full_dnode 169 322 36 0 46 1 7 7 dim_regex_filter 0 0 48 0 42 1 0 0 mfib_group_cache 0 0 80 0 32 1 0 0 memAVC_EXT_INFO 162 352 48 0 32 1 10 11 fs_cache 2 2 4194256 0 1 1024 2 2 kmalloc-4194256 0 0 24 4 56 1 0 0 Tnllinkcb 3418 3648 192 8 32 2 111 114 kmalloc-192 0 0 68 0 34 1 0 0 lb_conn 0 0 176 0 36 2 0 0 NAT_DYNAMICPORTBLOCK 119 220 688 4 22 4 10 10 tcpcb 0 0 148 0 20 1 0 0 mcfs_cache6 0 0 20 0 56 1 0 0 scsi_bidi_sdb 0 125 256 0 25 2 0 5 mbuf_ldb 0 0 20 0 56 1 0 0 mfib_va_iif_cache 0 0 552 0 27 4 0 0 pram_inode_cache 2104 2201 472 0 31 4 71 71 inode_cache 0 0 116 0 24 1 0 0 lbsticky_6_srcipport 5694 8024 188 0 34 2 236 236 DIM_EXT_INFO 1 25 584 0 25 4 1 1 shmem_inode_cache 8 56 20 0 56 1 1 1 WADJ_PHY_Cachep 137 192 76 0 32 1 6 6 FIB_Hash_cache 0 0 36 0 46 1 0 0 lb_se_cache_udp6 0 0 248 0 27 2 0 0 jffs2_refblock 0 0 48 0 42 1 0 0 L3VPN_IFCB 3179 3300 112 0 25 1 132 132 DIM_KHTTP_CTX 16 73 9 0 73 1 1 1 mfib_bitmap_cache 0 0 112 0 25 1 0 0 l2mcfs_cache4 61 96 624 0 24 4 4 4 STAMGR_KSTA_CACHE 2176 2240 96 0 28 1 80 80 ADJ4_COMBASE_Cachep 2553 2625 96 8 21 1 123 125 kmalloc-96 0 0 156 0 39 2 0 0 L2TPV2_KSESSION_CACHE 1 1 67108816 0 1 16384 1 1 kmalloc-67108816 0 0 64 0 36 1 0 0 lblimit_stat4 0 0 32 4 51 1 0 0 pppcb 336 346 8144 0 2 4 170 173 kmalloc-8144 0 0 164 0 37 2 0 0 mcfs_mapped_oif6 2 20 1536 0 20 8 1 1 sgpool-64 96 126 4096 0 7 8 14 18 mbuf_vdb5 0 0 72 0 34 1 0 0 mfib_l2m_source_cache 1855 1920 288 0 24 2 80 80 radix_tree_node 2 32 192 0 32 2 1 1 biovec-16 0 0 116 0 24 1 0 0 lbsticky_6_dstipport 0 0 80 0 32 1 0 0 memAVC_CONNLMT_NODE 8 84 48 0 42 1 2 2 inotify_watch_cache 0 0 512 0 29 4 0 0 khttp_pool 0 0 56 0 39 1 0 0 TRAFFICLOG_SESSION_EXT_INFO 2444 2622 36 0 46 1 57 57 eventpoll_pwq 129 162 248 0 27 2 6 6 IPCIM_ENTRY_IPV4_cachep 0 0 148 0 20 1 0 0 FIB6_RADIX_Cache 1 230 36 0 46 1 1 5 memSESS_AGING 0 0 392 0 37 4 0 0 fuse_request 0 0 76 0 32 1 0 0 ARP_Rule_Cachep 0 0 48 0 42 1 0 0 mfib_source_df_cache 0 0 40 0 46 1 0 0 dim_detect_filter_ipv4 5669 10680 88 0 30 1 356 356 IPFS_CacheHash_cachep 3356 3640 24 0 56 1 62 65 anon_vma 0 0 48 0 42 1 0 0 lb_proximity_proberet 522 630 24 0 42 1 15 15 Lipc_SegInfoCache 36 38 131024 0 1 32 36 38 kmalloc-131024 0 0 56 0 39 1 0 0 OSI_IFNODE_cachep 1280 1372 472 0 28 4 49 49 sock_inode_cache 0 0 120 0 24 1 0 0 mcfs_cache4 ==================================================================== ===============display system internal kernel memory pool tag=============== Tag MemoryPool Actives Bytes 0x6170015 1 1 96 0x6370015 6 5754 2984944 0x1570000 2 2 24 0x11b0000 1 1 32 0x1060000 1 17 544 0x1560000 2 17 640 0x10e0000 3 27 496 0x1180000 1 1 128 0x10a0000 2 3 1040 0x1230000 4 5 688 0x1090000 7 49 4224 0x1080000 12 932 163136 0x1590000 2 6 9216 0x1120000 7 1269 114760 0x1140000 9 207 199200 0x1160000 3 5 135264 0x10b0000 18 4350 1355360 0x2070000 5 21 648 0x2060000 2 9 520 0x23f0000 2 196 15680 0x2010000 3 13 1024 0x2050000 6 101 116552 0x2350000 2 2 8152 0x2230000 2 3 16384 0x2080000 1 1 16336 0x2300000 7 30 87568 0x22c0000 6 135 891280 0x2090000 4 6 147408 0x2020000 8 103 189200 0x2030000 4 49 94208 0x2040000 4 36 786848 0x2a20000 2 2 131056 0x22d0000 7 188 186256 0x3630000 1 1 192 0x62c0037 1 4 128 0x39b0000 1 3 192 0x3960000 2 181 2944 0x3000000 2 21 704 0x30d0000 2 108 4560 0x3110000 3 6 184 0x38c0000 1 5 320 0x33c0000 1 1 128 0x30a0000 2 2 544 0x3660000 2 3 640 0x30b0000 2 15 3712 0x33b0000 3 5 2432 0x3670000 2 2 2056 0x34c0000 1 1 2048 0x34b0000 2 2 2560 0x37f0000 2 2 5120 0x3950000 3 182 25432 0x32f0000 2 14 61392 0x3620000 3 4 16608 0x3690000 1 1 8144 0x3270000 3 7 24672 0x34a0000 4 5 16480 0x3120000 2 2 8208 0x3500000 3 4 32720 0x34f0000 3 4 32720 0x3240000 3 40 86096 0x6170037 1 1 16336 0x30e0000 1 4 130880 0x3160000 6 28 46928 0x32b0000 5 5 42960 0x32c0000 10 102 154416 0x3380000 8 26 162544 0x3220000 7 90 101952 0x3850000 9 251 649216 0x3600000 2 3 131040 0x35c0000 6 20 68528 0x31a0000 5 14 1052496 0x39d0000 7 20 579552 0x3010000 2 33 11616 0x3090000 2 2 872 0x3080000 4 10 118176 0x3610000 4 99 273984 0x3070000 6 1325 616016 0x30f0000 7 259 34256 0x3060000 18 1810 939052 0x31c0000 4 39 2268 0x35a0000 4 13 150608 0x32e0000 9 59 84872 0x3180000 5 23 117056 0x32a0000 3 17 151904 0x31b0000 16 526 1045216 0x3030000 17 761 320912 0x3040000 6 38 18016 0x3250000 10 270 178680 0x3290000 9 293 97904 0x3050000 6 4477 624828 0x32d0000 5 4106 608856 0x3190000 9 5753 555160 0x6090000 1 1 8 0x62f0000 2 2 104 0x60e0000 2 2 24 0x60d0000 2 2 24 0x63a0000 2 2 24 0x6410000 4 14 21448 0x61c0000 1 1 8144 0x6010000 2 5 130896 0x63c0000 4 8 110712 0x6500000 3 4 65480 0x62c0000 1 4 130880 0x6080000 6 7 86072 0x63e0000 8 12 307280 0x6130000 8 14232 1125392 0x6140000 5 7 1312616 0x6380000 22 101 106397408 0x6370000 9 2968 2667156 0x6170000 8 42300 23276736 0x6110000 5 7991 629524 0x8000000 7 401 69056 0x81c0000 4 58 45456 0x81d0000 9 174 161048 0x80e0000 13 164 4717536 0x81b0000 12 2901 339912 0x108000d 1 2 32 0x6170022 1 1 16 0x6110022 1 3 96 0x6370022 1 1 65488 0x22d000d 1 1 65488 0x392000d 1 30 3840 0x6170044 1 1 512 0xe1b0000 1 1 128 0xe310000 4 8 512 0xf090000 2 2 200 0xf1f0000 1 2 32 0xf180000 1 1 32 0xf2e0000 1 1 32 0xf1a0000 1 1 32 0xf350000 3 5 176 0xf040000 3 16 1472 0xf060000 5 59 4160 0xf2f0000 3 3 8304 0xf310000 5 33 71168 0xf380000 2 2 10192 0xf070000 4 4 41920 0xf050000 10 81 335080 0xf0b0000 10 59 944784 0xf5a0000 4 5 786408 0xf000000 2 2 4259744 0xf010000 3 3 34078688 0xf360000 1 1 360 0x6370066 1 14 840 0x108001a 2 9 800 0x637002f 3 7 2117488 0x637001a 2 3 384 0x6420005 1 352 11264 0x637005e 9 156 981184 0x6110027 2 4 65632 0x3920012 1 1 128 0x4302d04 1 2 128 0x637001f 1 1 32720 0x6110078 7 21 415680 0x22d000a 1 1 16 0x3920017 1 60 7680 0x6370017 1 401 25664 0x3290002 1 3 96 0x3530002 2 2 34768 0x3920002 1 61 1952 0x6370039 1 4 4096 0x637005b 1 241 3856 0x6370046 1 2 16288 0x4300809 1 2 64 0x6110068 1 1 16336 0x637001c 1 1 512 0x6110105 1 1 16336 0x6110007 1 1 8 0x6120007 1 1 8 0x6420007 1 352 2816 0x6110029 3 4 1088 0x6110082 1 1 8144 0x637004b 1 2 16 0x6370014 1 2877 552384 0x6170036 1 1 1024 0x6370036 1 8 523904 0x6370021 3 8 1120 0x6110021 3 3 5632 0x22d000c 1 1 32720 0x329000c 1 135 8640 0x392000c 1 30 490080 0x6250043 1 1 65488 0x616000c 1 1 8 0x61c000c 1 3 1536 0x22d0019 1 1 65488 0x6170019 1 1 96 0x6110102 1 38 1216 0x6110019 4 6 794432 0x6110072 2 7 523952 0x32c0004 1 1 16336 0x6080004 1 1 192 0x6110004 1 1 192 0x6420004 1 3 49008 0x80000000 8 12 56864 0x6110026 3 3 2816 0x22d0011 1 1 8 0x6370048 1 1 8 0x6160011 3 3 40928 0x6370011 1 1 32720 0x6170033 1 1 16 0x6370033 1 13 260 0x392001e 1 32 131072 0x6110009 1 4 64 0x6370009 2 22 8816 0x4300803 1 16 144 0x6110062 1 1 16 0x3920016 1 1 32 0x6170016 1 1 32 0x39c0001 1 1 32 0x4302702 1 1 64 0x3220001 3 14 800 0x3920001 1 60 7680 0x33c0001 3 4 1104 0x3530001 1 1 1024 0x32a0001 2 3 5120 0x3180001 2 5 9216 0x31b0001 3 4099 534608 0x30f0001 2 1455 88752 0x6170038 1 1 2048 0x6370038 1 1 65488 0x6370001 1 7720 494080 0x6110001 1 2 512 0x63e0001 4 548 41376 0x6160001 2 4 8256 0x6010001 1 1 32720 0x6420001 1 3 393072 0x637005a 1 241 15424 0x80e0001 3 34 33288 0x6110023 2 3 320 0x6370023 2 2 2176 0x4302a01 1 1 16 0x22d000e 1 1 65488 0x6170045 1 1 8 0x6370045 1 3 192 0x6370067 1 14 916832 0x6110030 1 4 128 0x62c0030 1 4 65344 0x6110104 1 1 32720 0x1080006 1 9 144 0x6110006 1 1 96 0x6420006 1 352 11264 0x6140006 1 1 64 0x61c0006 4 5 448 0x6120006 1 1 512 0x6170028 1 1 4096 0x6110028 3 4 294720 0x6150013 1 1 512 0x6160013 3 3 163776 0x6370035 2 2 520 0x6170057 1 1 2048 0x6370020 1 20 320 0x329000b 1 135 4320 0x392000b 1 30 61440 0x6250042 1 1 8 0x616000b 1 1 16336 0x4300c02 1 1 8 0x637002d 2 5015 1166032 0x22d0018 1 1 32720 0x4302802 1 1 64 0x3920018 1 1 256 0x6110101 1 38 1216 0x6170018 1 1 256 0x3290003 1 68 2176 0x3920003 1 1 1024 0x6110003 1 1 192 0x6090003 1 1 32 0x6160003 1 1 512 0x6420003 1 11 45056 0x6370047 1 1 32 0x6170047 1 1 65488 0x6110069 1 1 8 0x430080a 1 2 64 0x6370032 1 3174 355488 0x637001d 2 2 65504 0x6110008 1 1 32 0x6160008 5 5 2672 0x6370008 5 327 35104 0x4300802 1 16 1536 0x637002a 1 5702 1071976 0x30800fe 1 1 4096 0x637004c 1 2 32 ========================================================= ===============display qos-acl resource=============== ========================================================================= ===============display transceiver diagnosis interface=============== ===================================================================== ===============display transceiver alarm interface=============== ======================================================================== ===============display transceiver manuinfo interface=============== =============================================================== ===============display transceiver interface=============== ===============================================================
