6520irf后二层不通
2022-03-19提问
  • 1收藏,641浏览
两台6520做irf后,两边各接一台pc,同一个vlan互相ping不通。交换机上两台pc都能ping通,pc也能ping通网关,但是pc互相ping不通。
粉丝:11人 关注:1人
堆叠后二层流量就是无法跨框
4 个回答
两pc防火墙有没有关
都关了
与秋逐鹿 发表时间:2022-03-19
PC的防火墙是不是打开的
都关的
知了小白
粉丝: 关注:
检查一下IRF是否成功
irf状态正常
把配置粘贴出来吧
发表时间:2022-03-19
[H3C-S6520-堆叠交换机-irf-port1/1]dsi cu ^ % Unrecognized command found at '^' position. [H3C-S6520-堆叠交换机-irf-port1/1]dis cu # version 7.1.045, Release 2429 # sysname H3C-S6520-堆叠交换机 # clock protocol none # telnet server enable # irf mac-address persistent timer irf auto-update enable undo irf link-delay irf member 1 priority 1 irf member 2 priority 1 irf mode normal # ip unreachables enable ip ttl-expires enable # lldp global enable # system-working-mode standard fan prefer-direction slot 1 port-to-power fan prefer-direction slot 2 port-to-power password-recovery enable # vlan 1 # vlan 5 # vlan 9 # vlan 102 to 103 # vlan 111 # vlan 4000 to 4003 # irf-port 1/1 port group interface Ten-GigabitEthernet1/0/45 port group interface Ten-GigabitEthernet1/0/46 port group interface Ten-GigabitEthernet1/0/47 port group interface Ten-GigabitEthernet1/0/48 # irf-port 2/2 port group interface Ten-GigabitEthernet2/0/45 port group interface Ten-GigabitEthernet2/0/46 port group interface Ten-GigabitEthernet2/0/47 port group interface Ten-GigabitEthernet2/0/48 # stp global enable # interface Bridge-Aggregation1 port link-type trunk undo port trunk permit vlan 1 port trunk permit vlan 5 9 102 to 103 111 4001 to 4002 # interface Bridge-Aggregation10 description to 华为存储18500-A框P0P1 port access vlan 4001 link-aggregation mode dynamic # interface Bridge-Aggregation20 description to 华为存储18500-B框P0P1 port access vlan 4002 link-aggregation mode dynamic # interface Bridge-Aggregation30 description to 华为存储18500-A框P2P3 port access vlan 102 link-aggregation mode dynamic # interface Bridge-Aggregation40 description to 华为存储18500-B框P2P3 port access vlan 102 link-aggregation mode dynamic # interface Bridge-Aggregation51 port access vlan 5 # interface Bridge-Aggregation52 port access vlan 5 # interface Bridge-Aggregation53 port access vlan 5 # interface NULL0 # interface Vlan-interface5 # interface Vlan-interface103 ip address 141.72.100.13 255.255.255.0 # interface Vlan-interface4001 ip address 172.16.1.254 255.255.255.0 # interface Vlan-interface4002 ip address 172.16.2.254 255.255.255.0 # interface Vlan-interface4003 ip address 172.16.3.1 255.255.255.0 # interface M-GigabitEthernet0/0/0 # interface Ten-GigabitEthernet1/0/1 port link-mode bridge port access vlan 102 port link-aggregation group 30 # interface Ten-GigabitEthernet1/0/2 port link-mode bridge port access vlan 102 port link-aggregation group 30 # interface Ten-GigabitEthernet1/0/3 port link-mode bridge port access vlan 102 port link-aggregation group 40 # interface Ten-GigabitEthernet1/0/4 port link-mode bridge port access vlan 102 port link-aggregation group 40 # interface Ten-GigabitEthernet1/0/5 port link-mode bridge port access vlan 5 port link-aggregation group 51 # interface Ten-GigabitEthernet1/0/6 port link-mode bridge port access vlan 5 port link-aggregation group 52 # interface Ten-GigabitEthernet1/0/7 port link-mode bridge port access vlan 4002 # interface Ten-GigabitEthernet1/0/8 port link-mode bridge port access vlan 4002 # interface Ten-GigabitEthernet1/0/9 port link-mode bridge port access vlan 4002 # interface Ten-GigabitEthernet1/0/10 port link-mode bridge port access vlan 4002 # interface Ten-GigabitEthernet1/0/11 port link-mode bridge port access vlan 4002 # interface Ten-GigabitEthernet1/0/12 port link-mode bridge port access vlan 4002 # interface Ten-GigabitEthernet1/0/13 port link-mode bridge port access vlan 4002 # interface Ten-GigabitEthernet1/0/14 port link-mode bridge port access vlan 4002 # interface Ten-GigabitEthernet1/0/15 port link-mode bridge port access vlan 4002 # interface Ten-GigabitEthernet1/0/16 port link-mode bridge port access vlan 4002 # interface Ten-GigabitEthernet1/0/17 port link-mode bridge port access vlan 4002 # interface Ten-GigabitEthernet1/0/18 port link-mode bridge port access vlan 4001 # interface Ten-GigabitEthernet1/0/19 port link-mode bridge port access vlan 102 # interface Ten-GigabitEthernet1/0/20 port link-mode bridge port access vlan 102 # interface Ten-GigabitEthernet1/0/21 port link-mode bridge port access vlan 102 # interface Ten-GigabitEthernet1/0/22 port link-mode bridge port access vlan 102 # interface Ten-GigabitEthernet1/0/23 port link-mode bridge port access vlan 102 # interface Ten-GigabitEthernet1/0/24 port link-mode bridge port access vlan 102 # interface Ten-GigabitEthernet1/0/25 port link-mode bridge port access vlan 102 # interface Ten-GigabitEthernet1/0/26 port link-mode bridge port access vlan 102 # interface Ten-GigabitEthernet1/0/27 port link-mode bridge port access vlan 102 # interface Ten-GigabitEthernet1/0/28 port link-mode bridge port access vlan 102 # interface Ten-GigabitEthernet1/0/29 port link-mode bridge port access vlan 5 port link-aggregation group 53 # interface Ten-GigabitEthernet1/0/30 port link-mode bridge port access vlan 4001 # interface Ten-GigabitEthernet1/0/31 port link-mode bridge port access vlan 4001 undo stp enable # interface Ten-GigabitEthernet1/0/32 port link-mode bridge port access vlan 4001 undo stp enable # interface Ten-GigabitEthernet1/0/33 port link-mode bridge description KL port access vlan 5 # interface Ten-GigabitEthernet1/0/34 port link-mode bridge description KL port access vlan 5 # interface Ten-GigabitEthernet1/0/35 port link-mode bridge description KL port access vlan 9 # interface Ten-GigabitEthernet1/0/36 port link-mode bridge description KL port access vlan 9 # interface Ten-GigabitEthernet1/0/37 port link-mode bridge description dashuju port access vlan 9 # interface Ten-GigabitEthernet1/0/38 port link-mode bridge description dashuju port access vlan 9 # interface Ten-GigabitEthernet1/0/39 port link-mode bridge port access vlan 9 # interface Ten-GigabitEthernet1/0/40 port link-mode bridge port access vlan 9 # interface Ten-GigabitEthernet1/0/41 port link-mode bridge port access vlan 4001 stp edged-port # interface Ten-GigabitEthernet1/0/42 port link-mode bridge port access vlan 5 # interface Ten-GigabitEthernet1/0/43 port link-mode bridge port access vlan 5 # interface Ten-GigabitEthernet1/0/44 port link-mode bridge port link-type trunk undo port trunk permit vlan 1 port trunk permit vlan 5 9 102 to 103 111 4001 to 4002 port link-aggregation group 1 # interface Ten-GigabitEthernet2/0/1 port link-mode bridge port access vlan 4001 # interface Ten-GigabitEthernet2/0/2 port link-mode bridge port access vlan 4002 # interface Ten-GigabitEthernet2/0/3 port link-mode bridge port access vlan 4001 # interface Ten-GigabitEthernet2/0/4 port link-mode bridge port access vlan 4002 # interface Ten-GigabitEthernet2/0/5 port link-mode bridge port access vlan 5 port link-aggregation group 51 # interface Ten-GigabitEthernet2/0/6 port link-mode bridge port access vlan 5 port link-aggregation group 52 # interface Ten-GigabitEthernet2/0/7 port link-mode bridge port access vlan 4001 # interface Ten-GigabitEthernet2/0/8 port link-mode bridge port access vlan 4001 # interface Ten-GigabitEthernet2/0/9 port link-mode bridge port access vlan 4001 # interface Ten-GigabitEthernet2/0/10 port link-mode bridge port access vlan 4001 # interface Ten-GigabitEthernet2/0/11 port link-mode bridge port access vlan 4001 # interface Ten-GigabitEthernet2/0/12 port link-mode bridge port access vlan 4001 # interface Ten-GigabitEthernet2/0/13 port link-mode bridge port access vlan 4001 # interface Ten-GigabitEthernet2/0/14 port link-mode bridge port access vlan 4001 # interface Ten-GigabitEthernet2/0/15 port link-mode bridge port access vlan 4001 # interface Ten-GigabitEthernet2/0/16 port link-mode bridge port access vlan 4001 # interface Ten-GigabitEthernet2/0/17 port link-mode bridge port access vlan 4001 # interface Ten-GigabitEthernet2/0/18 port link-mode bridge port access vlan 4001 # interface Ten-GigabitEthernet2/0/19 port link-mode bridge port access vlan 4001 # interface Ten-GigabitEthernet2/0/20 port link-mode bridge port access vlan 4001 # interface Ten-GigabitEthernet2/0/21 port link-mode bridge # interface Ten-GigabitEthernet2/0/22 port link-mode bridge # interface Ten-GigabitEthernet2/0/23 port link-mode bridge port access vlan 102 # interface Ten-GigabitEthernet2/0/24 port link-mode bridge # interface Ten-GigabitEthernet2/0/25 port link-mode bridge # interface Ten-GigabitEthernet2/0/26 port link-mode bridge port access vlan 5 # interface Ten-GigabitEthernet2/0/27 port link-mode bridge # interface Ten-GigabitEthernet2/0/28 port link-mode bridge port access vlan 5 undo stp enable # interface Ten-GigabitEthernet2/0/29 port link-mode bridge port access vlan 5 port link-aggregation group 53 # interface Ten-GigabitEthernet2/0/30 port link-mode bridge # interface Ten-GigabitEthernet2/0/31 port link-mode bridge port access vlan 5 undo stp enable # interface Ten-GigabitEthernet2/0/32 port link-mode bridge port access vlan 5 undo stp enable # interface Ten-GigabitEthernet2/0/33 port link-mode bridge description KL port access vlan 5 # interface Ten-GigabitEthernet2/0/34 port link-mode bridge description KL port access vlan 5 # interface Ten-GigabitEthernet2/0/35 port link-mode bridge description KL port access vlan 9 # interface Ten-GigabitEthernet2/0/36 port link-mode bridge description KL port access vlan 9 # interface Ten-GigabitEthernet2/0/37 port link-mode bridge description share-intelligent port access vlan 9 # interface Ten-GigabitEthernet2/0/38 port link-mode bridge description share-intelligent port access vlan 9 # interface Ten-GigabitEthernet2/0/39 port link-mode bridge description share-intelligent port access vlan 9 # interface Ten-GigabitEthernet2/0/40 port link-mode bridge description share-intelligent port access vlan 9 # interface Ten-GigabitEthernet2/0/41 port link-mode bridge port access vlan 4002 # interface Ten-GigabitEthernet2/0/42 port link-mode bridge port access vlan 4002 # interface Ten-GigabitEthernet2/0/43 port link-mode bridge port access vlan 4001 # interface Ten-GigabitEthernet2/0/44 port link-mode bridge port link-type trunk undo port trunk permit vlan 1 port trunk permit vlan 5 9 102 to 103 111 4001 to 4002 port link-aggregation group 1 # interface Ten-GigabitEthernet1/0/45 # interface Ten-GigabitEthernet1/0/46 # interface Ten-GigabitEthernet1/0/47 # interface Ten-GigabitEthernet1/0/48 # interface Ten-GigabitEthernet2/0/45 # interface Ten-GigabitEthernet2/0/46 # interface Ten-GigabitEthernet2/0/47 # interface Ten-GigabitEthernet2/0/48 # scheduler logfile size 16 # line class aux user-role network-admin # line class vty user-role network-operator # line aux 0 1 user-role network-admin # line vty 0 4 authentication-mode scheme user-role level-15 user-role network-admin user-role network-operator # line vty 5 63 user-role network-operator # ip route-static 0.0.0.0 0 141.72.100.1 # radius scheme system user-name-format without-domain # domain system # domain default enable system # role name level-0 description Predefined level-0 role # role name level-1 description Predefined level-1 role # role name level-2 description Predefined level-2 role # role name level-3 description Predefined level-3 role # role name level-4 description Predefined level-4 role # role name level-5 description Predefined level-5 role # role name level-6 description Predefined level-6 role # role name level-7 description Predefined level-7 role # role name level-8 description Predefined level-8 role # role name level-9 description Predefined level-9 role # role name level-10 description Predefined level-10 role # role name level-11 description Predefined level-11 role # role name level-12 description Predefined level-12 role # role name level-13 description Predefined level-13 role # role name level-14 description Predefined level-14 role # user-group system # local-user admin1 class manage password hash $h$6$6cNRFXbrmuKlckhu$1tEVTA2ZN+njRzx4EODU4PVvAImFSkbfv11YvEHqgL/i+LMpqYhzumnqfILLjWCI4Sm91NRAWN+Nnq0cDb1VVg== service-type telnet terminal authorization-attribute user-role level-15 authorization-attribute user-role network-operator # local-user admin2 class manage password hash $h$6$RPVoH1kD1jV/stIL$LilLJhHPTHLp1lQfISLFi/qmu5zgJxG4kP2O80m2jM8WJ+Gthh8dURnwHllPEfZMpiPGs+P9/OeYnZR5gl2BDQ== service-type telnet authorization-attribute user-role level-15 authorization-attribute user-role network-operator # return [H3C-S6520-堆叠交换机-irf-port1/1]
请看评论,45和46口没有接线,但是接入了irf-port 这个会不会有影响呢
你把你的聚合网线拔掉一下试试吧 ,可能是你的链路聚合影响的,或者是在核心上看一下stp 端口状态,dis stp bri,看是否有阻塞端口
发表时间:2022-03-19
clock protocol none
undo irf link-delay
irf mode normal
lldp global enable
vlan 1
vlan 5
vlan 9
vlan 102 to 103
vlan 111
vlan 4000 to 4003
irf-port 1/1
irf-port 2/2
stp global enable
port access vlan 5
port access vlan 5
port access vlan 5
interface NULL0
port access vlan 5
port access vlan 5
port access vlan 5
undo stp enable
undo stp enable
description KL
port access vlan 5
description KL
port access vlan 5
description KL
port access vlan 9
description KL
port access vlan 9
description dashuju
port access vlan 9
description dashuju
port access vlan 9
port access vlan 9
port access vlan 9
stp edged-port
port access vlan 5
port access vlan 5
port access vlan 5
port access vlan 5
port access vlan 5
port access vlan 5
undo stp enable
port access vlan 5
port access vlan 5
undo stp enable
port access vlan 5
undo stp enable
description KL
port access vlan 5
description KL
port access vlan 5
description KL
port access vlan 9
description KL
port access vlan 9
port access vlan 9
port access vlan 9
port access vlan 9
port access vlan 9
line class aux
line class vty
line aux 0 1
line vty 0 4
user-role level-15
line vty 5 63
domain system
role name level-0
role name level-1
role name level-2
role name level-3
role name level-4
role name level-5
role name level-6
role name level-7
role name level-8
role name level-9
role name level-10
role name level-11
role name level-12
role name level-13
role name level-14
user-group system
service-type telnet
return
