wa6320 胖ap
2022-03-23提问
  • 1收藏,586浏览
ssh 登陆失败
胖ap 日志报错 %Aug 25 22:54:57:070 2020 H3C SSHS/6/SSHS_LOG: Authentication failed for h3cap from 172.16.156.15 port 64604 because of invalid username or wrong password .
账号密码都是正确的
telnet http https都是失败
粉丝:119人 关注:1人
1、console进去重新配置下用户名密码
2、配置也发出来看看
local-user admin class manage password hash $h$6$zyTjnHFLIpEViOgP$PNETQjCkecjk67D/50brgc7llIrh2Un+ftAyVY3vfUu6tgfgTpeI/eTDjkPzwVPjKEU6CimIzQOjvqMgfXJXkQ== service-type ssh telnet terminal http https authorization-attribute user-role level-3 authorization-attribute user-role network-admin authorization-attribute user-role network-operator # local-user h3cap class manage password hash $h$6$nqdTOHbqzXCeyb99$GSg43PHNt1ZqiL0ZcKxVLunbNSeJQmlE/PDshHINhvEDwHyNdvXAuNRqVR/WGs5yP+mpkX/JY/LMiR5O9m2jtw== service-type ssh telnet terminal http https authorization-attribute user-role level-15 authorization-attribute user-role network-operator #
尘缘尘缘 发表时间:2022-03-23
创建了新的账号了 也不行报错是一样的
参考这个配置再检查检查: https://www.h3c.com/cn/d_202201/1524247_30005_0.htm
叫我靓仔 发表时间:2022-03-23
回复叫我靓仔:
密钥从新配置后 %Aug 25 23:19:55:002 2020 H3C SSHS/6/SSHS_DISCONNECT: SSH user (null) (IP: 172.16.156.15) disconnected from the server. %Aug 25 23:20:18:516 2020 H3C SSHS/6/SSHS_LOG: Authentication failed for h3cap from 172.16.156.15 port 65224 because of invalid username or wrong password . 还是一样
回复叫我靓仔:
Vlan1 UP UP 172.16.8.50 ssh server enable netconf soap http enable netconf soap https enable netconf ssh server enable line con 0 user-role network-admin # line vty 0 63 authentication-mode scheme user-role network-admin user-role network-operator idle-timeout 0 0 #
相关配置都有啊看着
回复尘缘尘缘:
我换衣还是你的配置密码的时候,password那里检查有没有空格,pass sword simple abc123
回复叫我靓仔:
我看日志里没有pass word 这个问题
回复叫我靓仔:
[H3C-luser-manage-h3cap]display logbuffer | in pass %Aug 25 21:54:35:419 2020 H3C SHELL/6/SHELL_CMD: -Line=con0-IPAddr=**-User=**; Command is password simple ****** %Aug 25 21:55:07:260 2020 H3C SSHS/6/SSHS_LOG: Authentication failed for admin from 172.16.156.15 port 63447 because of invalid username or wrong password . %Aug 25 21:58:36:099 2020 H3C SHELL/6/SHELL_CMD: -Line=con0-IPAddr=**-User=**; Command is password simple ****** %Aug 25 21:58:44:488 2020 H3C SHELL/6/SHELL_CMD: -Line=con0-IPAddr=**-User=**; Command is password simple ****** %Aug 25 21:59:03:322 2020 H3C SHELL/6/SHELL_CMD: -Line=con0-IPAddr=**-User=**; Command is password simple ****** %Aug 25 21:59:28:713 2020 H3C SHELL/6/SHELL_CMD: -Line=con0-IPAddr=**-User=**; Command is password simple ****** %Aug 25 21:59:52:347 2020 H3C SSHS/6/SSHS_LOG: Authentication failed for admin from 172.16.156.15 port 63524 because of invalid username or wrong password . %Aug 25 22:00:32:347 2020 H3C SSHS/6/SSHS_LOG: Authentication failed for admin from 172.16.156.15 port 63524 because of invalid username or wrong password . %Aug 25 22:01:25:572 2020 H3C SSHS/6/SSHS_LOG: Authentication failed for admin from 172.16.156.15 port 63547 because of invalid username or wrong password . %Aug 25 22:49:51:733 2020 H3C SHELL/6/SHELL_CMD: -Line=con0-IPAddr=**-User=**; Command is password simple ****** %Aug 25 22:50:07:231 2020 H3C SHELL/6/SHELL_CMD: -Line=con0-IPAddr=**-User=**; Command is password simple ****** %Aug 25 22:51:23:810 2020 H3C SSHS/6/SSHS_LOG: Authentication failed for h3cap from 172.16.156.15 port 64534 because of invalid username or wrong password . %Aug 25 22:52:46:337 2020 H3C SHELL/6/SHELL_CMD: -Line=con0-IPAddr=**-User=**; Command is password simple ****** %Aug 25 22:54:57:070 2020 H3C SSHS/6/SSHS_LOG: Authentication failed for h3cap from 172.16.156.15 port 64604 because of invalid username or wrong password . %Aug 25 23:20:18:516 2020 H3C SSHS/6/SSHS_LOG: Authentication failed for h3cap from 172.16.156.15 port 65224 because of invalid username or wrong password . %Aug 25 23:43:27:036 2020 H3C SHELL/6/SHELL_CMD: -Line=con0-IPAddr=**-User=**; Command is password simple ******
because of invalid username or wrong password 这个就是
