3PAR AO开启后,指定的策略T0为SSD,T1为FC,客户VMware环境挂载使用的SSD的VV,经AO判断该VV上部分数据为冷数据,是否会往FC硬盘上迁移
“数据先回落入卷的Base cpg,然后再通过Sched 的AO策略,将region移动到其他的CPG”,是不是就意味着Basecpg为FC的热数据会自动迁移到SSD,而Basecpg为SSD的冷数据会自动迁移到FC
3par8400 cli% showaocfg AO ------CPG------- ----Min(MB)---- -----Max(MB)----- -Warn(MB)-- -Limit(MB)- Id Name T0 T1 T2 T0 T1 T2 T0 T1 T2 T0 T1 T2 T0 T1 T2 Mode 1 AO SSD_r5 FC_r5 --- 32768 32768 --- 512000 512000 --- --- --- --- --- --- --- Balanced -------------------------------------------------------------------------------------------- 1 total
3par8400 cli% showsched ------ Schedule ------ SchedName File/Command Min Hour DOM Month DOW CreatedBy Status Alert NextRunTime sunday startao -btsecs -43200 -etsecs 0 -maxrunh 6 -compact auto -min_iops 50 AO 0 15 * * 0 3paradm active Y 2022-03-20 15:00:00 CST --------------------------------------------------------------------------------------------------------------------------------------------------------- 1 total
谢谢支持!
(0)
系统判定近期内访问热度较高的热数据会从FC提升到SSD,若访问热度低则会降落到FC,
sraomove输出可以看到迁移的情况
(0)
(0)
确定你的邮箱还未认证,请认证邮箱或绑定手机后进行当前操作
该命令已收集,未见明显迁移情况 3par8400 cli% sraomoves Start Time: 2022-03-17 05:20:35 CST (1647465635) End Time: 2022-03-17 17:20:35 CST (1647508835) Id AOCFG SrcTier DstTier Space MovedMB
你这个命令是最基础的只是显示最近一天的记录,后面需要跟上时间才会显示出来其他时间段数据冷热迁移的情况。 sraomoves -btsecs 2021-01-01 -etsecs 2022-03-23
两条命令的连续输出,只见迁移情况的标题“3par8400 cli% sraomoves Start Time: 2022-03-17 05:20:35 CST (1647465635) End Time: 2022-03-17 17:20:35 CST (1647508835) Id AOCFG SrcTier DstTier Space MovedMB 3par8400 cli% sraomoves Start Time: 2022-03-17 05:20:40 CST (1647465640) End Time: 2022-03-17 17:20:41 CST (1647508841) Id AOCFG SrcTier DstTier Space MovedMB”,未见下方具体迁移内容 3par8400 cli% sraomoves Start Time: 2022-03-17 05:20:35 CST (1647465635) End Time: 2022-03-17 17:20:35 CST (1647508835) Id AOCFG SrcTier DstTier Space MovedMB 3par8400 cli% sraomoves Start Time: 2022-03-17 05:20:40 CST (1647465640) End Time: 2022-03-17 17:20:41 CST (1647508841) Id AOCFG SrcTier DstTier Space MovedMB 而showsched查看AOCFG为active状态
OK,理解了,感谢回复,谢谢
