7503升级
2022-03-31提问
  • 1收藏,741浏览
升级7503E的软件
[SKLMG-7503]display version H3C Comware Platform Software Comware Software, Version 5.20, Release 6708P09 Copyright (c) 2004-2014 Hangzhou H3C Tech. Co., Ltd. All rights reserved. H3C S7503E-S uptime is 22 weeks, 4 days, 5 hours, 57 minutes MPU(M) 0: Uptime is 22 weeks,4 days,5 hours,57 minutes H3C S7503E-S MPU(M) with 1 BCM1122 Processor BOARD TYPE: LSQ1CGV24PSC DRAM: 512M bytes FLASH: 64M bytes NVRAM: 512K bytes PCB 1 Version: VER.A Bootrom Version: 500 CPLD 1 Version: 001 CPLD 2 Version: 001 Release Version: H3C S7503E-S-6708P09 Patch Version : None LPU 1: Uptime is 22 weeks,4 days,5 hours,56 minutes H3C S7503E-S LPU with 1 BCM1122 Processor BOARD TYPE: LSQ1TGX2SA DRAM: 512M bytes FLASH: 0M bytes NVRAM:       0K bytes PCB 1 Version: VER.C PCB 2 Version: VER.B Bootware Version: 306 CPLD 1 Version: 004 CPLD 2 Version: 004 Release Version: H3C S7503E-S-6708P09 Patch Version : None Slot 2 Without Board 我想问下,如果这个机器要升级软件,可以升级到什么版本,能给下软件的下载吗,或者还要别的资料才能判断?
没有组网,就是想升级
知了小白
粉丝: 关注:
http://www.h3c.com.cn/cn/Service/Document_Software/Software_Download/Switches/Catalog/H3C_S7500E/H3C_S7500E/?CHID=53919&v=612
账号:yx800
密码:01230123
可以升级到最新的那个版本
可以直接升还是要挑版本升级~
zhiliao_TTuzz 发表时间:2022-03-31
直接升级就好了
发表时间:2022-03-31
版本链接:https://www.h3c.com/cn/Service/Document_Software/Software_Download/Switches/Catalog/H3C_S7500E/H3C_S7500E/?CHID=53919&v=612
账号 yx800  密码  01230123
升级会有什么不可逆转的损害,或者失败有啥问题,还有卡板是不是也要升级?
可以参考下版本注意事项:https://www.h3c.com/cn/d_202201/1535085_30005_40.htm#_Toc92753967
zhiliao_KhayGi 发表时间:2022-03-31
最高可以升级到什么版本?再次请教
