H3C MSR930
2017-08-03提问
  • 1收藏,2944浏览
Crixus 零段
想做1个端对点的L2TP VPN,用于出差员工远程访问公司内部服务器,请教大神,我这样配置的对不对。
 version 5.20, Release 2514P10
 sysname H3C
 l2tp enable
 domain default enable system
 dns proxy enable
 telnet server enable
 dar p2p signature-file flash:/p2p_default.mtd
 ndp enable
 ntdp enable
 cluster enable
 port-security enable
 password-recovery enable
vlan 1
domain system
 access-limit disable
 state active
 idle-cut disable
 self-service-url disable
domain system
 authentication ppp local
 authorization ppp local
 accounting ppp local
 state active
 idle-cut disable
 ip pool 1 10.58.0.2 10.58.0.254
 ip pool 10 192.168.20.50 192.168.20.250
dhcp server ip-pool vlan1 extended
 network ip range 192.168.1.1 192.168.1.200
 network mask 255.255.255.0
 gateway-list 192.168.1.1
 dns-list 192.168.1.1
user-group system
 group-attribute allow-guest
local-user admin
 password cipher $c$3$59Bk7smcOaLgzOD9TEbXSx9y7D/ymeCQwhbACSJ2
 authorization-attribute level 3
 service-type telnet
 service-type web
local-user haplox
 password cipher $c$3$b4pGID+9tcvXoC3iTkoEGCX5ARARE063QUnsAYhv
 service-type ppp
cwmp
 undo cwmp enable
l2tp-group 1
 undo tunnel authentication
 allow l2tp virtual-template 1
 tunnel name h3c
interface Aux0
 async mode flow
 link-protocol ppp
interface Cellular0/0
 async mode protocol
 link-protocol ppp
 tcp mss 1024
 nat outbound
interface Dialer10
 nat outbound
 link-protocol ppp
 ppp chap user 0793010258695
 ppp chap password cipher $c$3$tcc8O+uGkUKENgzBqe8F7lStQbURJ0F4S3kU
 ppp pap local-user 0793010258695 password cipher $c$3$IrW3JRd8LqUhN7o1ZfKKw20cELWTJsuyIEiO
 ppp ipcp dns admit-any
 ppp ipcp dns request
 mtu 1492
 ip address ppp-negotiate
 tcp mss 1024
 dialer user username
 dialer-group 10
 dialer bundle 10
interface Virtual-Template1
 description isthis
 ppp authentication-mode chap domain system
 remote address pool 10
 ip address 192.168.20.254 255.255.255.0
interface NULL0
interface Vlan-interface1
 tcp mss 1024
 dhcp server apply ip-pool vlan1
interface GigabitEthernet0/0
 port link-mode route
 nat outbound
 pppoe-client dial-bundle-number 10
interface GigabitEthernet0/1
 port link-mode bridge
interface GigabitEthernet0/2
interface GigabitEthernet0/3
interface GigabitEthernet0/4
 ip route-static 0.0.0.0 0.0.0.0 Dialer10
 dhcp enable
 ssh server enable
 dialer-rule 10 ip permit
 nms primary monitor-interface Dialer10
 load xml-configuration
 load tr069-configuration
user-interface tty 12
user-interface aux 0
user-interface vty 0 4
 authentication-mode scheme
return
配置上没有问题,只是你的这个外网的线路是PPPOE的,没有一个固定 的IP地址来给出差用户做拨号地址使用。。建议内网弄个DDNS做个域名 绑定。
大神,我是新手,目前VPN搭建完成,但IP不是固定的,请问DDNS域名绑定该这么操作,可否留个QQ指导下我。
Crixus 发表时间:2017-08-03
这个你只要上百度搜索一下DDNS或者 花生壳
饭桶98 发表时间:2017-08-25
粉丝:2人 关注:0人
L2TP是目前使用最为广泛的是VPDN隧道协议,在公共网络上为企业建立安全的虚拟专网。企业驻外机构和出差人员可从远程经由公共网络,通过虚拟隧道实现和企业总部之间的网络连接。
Comware V5平台MSR路由器L2TP VPN(命令行)配置http://help.h3c.com/robot/p4data/375072bcaf8c47f18dd97e82504f39d6/
Comware V5平台MSR路由器L2TP VPN(WEB)配置http://help.h3c.com/robot/p4data/4b96a971d4214df499617d606ed26eb5/
Comware V7平台MSR路由器L2TP VPN(命令行)配置http://help.h3c.com/robot/p4data/e45c89e11c774c0cabf950fba4285dc4/
Comware V7平台MSR路由器L2TP VPN(WEB)配置http://help.h3c.com/robot/p4data/8c466674157c473aa9e15a586c49534b/
WIN7系统L2TP VPN拨号设置http://help.h3c.com/robot/p4data/c997fd72061e4e4d96f0e8d099e55244/
