H3C S7503E经常自动重启
2018-08-13提问
  • 1收藏,1188浏览
H3C S7503E经常自动重启,是什么原因啊
在线求帮助!
溪风 二段
设备固件包丢失了!
粉丝:4人 关注:1人
现网设备是否版本较低,版本较低的话建议升级版本继续观察
zhiliao_YjzrE 知了小白
[22:31:30]Starting......
[22:31:33]RAMLine.....OK
[22:31:34]System is booting................
[22:31:34]
[22:31:34] ******************************************
[22:31:34] * *
[22:31:34] * H3C S7500E BOOTROM, Version 207 *
[22:31:34] * *
[22:31:34]
[22:31:34] Copyright(c) 2004-2008 Hangzhou H3C Technologies Co., Ltd.
[22:31:35] Creation date : May 5 2008, 15:16:44
[22:31:35] CPU type : BCM1125H
[22:31:35] CPU Clock Speed : 600Mhz
[22:31:35] BUS Clock Speed : 66Mhz
[22:31:35] BOOT_FLASH type : AMD29LV040B
[22:31:35] Flash Size : 64MB
[22:31:35] Memory Size : 512MB
[22:31:35]
[22:31:35]
[22:31:35]
[22:31:35]Main board slot 0 self testing............................
[22:31:35]SDRAM Data lines selftest.................................OK!
[22:31:35]SDRAM Address lines selftest..............................OK!
[22:31:35]SDRAM fast selftest.......................................OK!
[22:31:35]CPLD selftest.............................................OK!
[22:31:35]FPGA selftest.............................................OK!
[22:31:35]The switch Mac address is .....................000F.E22E.DA02
[22:31:35]
[22:31:35]
[22:31:37]Press Ctrl+B to enter Boot Menu... 4
[22:31:37]
[22:31:37]
[22:31:37]
[22:31:38]Start
[22:31:38]
[22:31:38]
[22:31:38]
[22:31:38]Starting......
[22:31:39]RAMLine.....OK
[22:31:39]
[22:31:39]
[22:31:39
[22:31:39]Starting......
[22:31:40]RAMLinå
[22:31:40]
[22:31:40]
[22:31:40]
[22:31:40]Starting......
[22:31:43]RAMLine.....OK
[22:31:43]
[22:31:43]
[22:31:43]
[22:31:43]Starting......
[22:31:43]
[22:31:43]
[22:31:43]
[22:31:45]RAMLine.....OK
[22:31:45]
[22:31:45]
[22:31:45]
[22:31:45]Starting......
[22:31:49]RAMLine.....OK
[22:31:49]System is booting................
[22:31:49]
[22:31:49] ******************************************
[22:31:50] * *
[22:31:50] * H3C S7500E BOOTROM, Version 207 *
[22:31:50] * *
[22:31:50] ******************************************
[22:31:50]
[22:31:50] Copyright(c) 2004-2008 Hangzhou H3C Technologies Co., Ltd.
[22:31:50] Creation date : May 5 2008, 15:16:44
[22:31:50] CPU type : BCM1125H
[22:31:50] CPU Clock Speed : 600Mhz
[22:31:50] BUS Clock Speed : 66Mhz
[22:31:50] BOOT_FLASH type : AMD29LV040B
[22:31:50] Flash Size : 64MB
[22:31:50] Memory Size : 512MB
[22:31:50]
[22:31:50]
[22:31:50]
[22:31:50]Main board slot 0 self testing............................
[22:31:50]SDRAM Data lines selftest.................................OK!
[22:31:50]SDRAM Address lines selftest..............................OK!
[22:31:50]SDRAM fast selftest.......................................OK!
[22:31:50]CPLD selftest.............................................OK!
[22:31:50]FPGA selftest.............................................OK!
[22:31:50]The switch Mac address is .....................000F.E22E.DA02
[22:31:51]
[22:31:51]
[22:31:56]Press Ctrl+B to enter Boot Menu... 0
[22:31:56]Auto-booting....................
[22:31:56]
[22:31:56]
[22:32:02]Auto booting file is flash:/s7500e-cmw520-r6616p05.app...OK
[22:32:09]Decompress Image...................................................................................................................................................................................................................................................................................OK! [22:32:26]Starting at 0x80020000...
[22:32:26]
[22:33:22]
[22:33:22]Starting......
[22:33:25]RAMLine.....OK
[22:33:26]System is booting................
[22:33:26]
[22:33:26] ******************************************
[22:33:26] * *
[22:33:26] * H3C S7500E BOOTROM, Version 207 *
[22:33:27] * *
[22:33:27] ******************************************
[22:33:27]
[22:33:27] Copyright(c) 2004-2008 Hangzhou H3C Technologies Co., Ltd.
[22:33:27] Creation date : May 5 2008, 15:16:44
[22:33:27] CPU type : BCM1125H
[22:33:27] CPU Clock Speed : 600Mhz
[22:33:27] BUS Clock Speed : 66Mhz
[22:33:27] BOOT_FLASH type : AMD29LV040B
[22:33:27] Flash Size : 64MB
[22:33:27] Memory Size : 512MB
[22:33:27]
[22:33:27]
[22:33:27]
[22:33:27]Main board slot 0 self testing............................
[22:33:27]SDRAM Data lines selftest.................................OK!
就是像这样不停重启,求助是啥原因?
