三层交换机如何当做路由器使用?需要如何配置?
  • 2关注
  • 1收藏,1464浏览
上连网络VLAN613能上互联网,现三层交换机配置好了DHCP池192.168.189.0和192.168.188.0段,如何实现两段ip通过vlan613上互联网呢?其中VLAN401是管理VLAN
undo info-center enable
vlan batch 188 to 189 401 613
telnet server enable
telnet server-source all-interface
dhcp enable
acl number 2000
 rule 5 permit source 192.168.189.0 0.0.0.255
ip pool a1
 gateway-list 192.168.189.1
 network 192.168.189.0 mask 255.255.255.0
 dns-list 202.96.128.166 202.96.134.133
ip pool a2
 network 192.168.188.0 mask 255.255.255.0
interface Vlanif188
 ip address 192.168.188.1 255.255.255.0
 dhcp select global
interface Vlanif189
 ip address 192.168.189.1 255.255.255.0
 dhcp select global
interface Vlanif401
 ip address 172.16.6.203 255.255.255.128
interface Vlanif613
 ip address 10.28.19.214 255.255.254.0
interface GigabitEthernet0/0/1
 port link-type access
 port default vlan 401
interface GigabitEthernet0/0/2
 port link-type trunk
 port trunk allow-pass vlan 401 613
interface GigabitEthernet0/0/3
 port default vlan 189
interface GigabitEthernet0/0/4
interface GigabitEthernet0/0/5
interface GigabitEthernet0/0/6
interface GigabitEthernet0/0/7
interface GigabitEthernet0/0/8
interface GigabitEthernet0/0/9
interface GigabitEthernet0/0/10
interface GigabitEthernet0/0/11
interface GigabitEthernet0/0/12
interface GigabitEthernet0/0/13
interface GigabitEthernet0/0/14
interface GigabitEthernet0/0/15
interface GigabitEthernet0/0/16
interface GigabitEthernet0/0/17
interface GigabitEthernet0/0/18
interface GigabitEthernet0/0/19
interface GigabitEthernet0/0/20
interface GigabitEthernet0/0/21
interface GigabitEthernet0/0/22
interface GigabitEthernet0/0/23
interface GigabitEthernet0/0/24
interface GigabitEthernet0/0/25
interface GigabitEthernet0/0/26
interface GigabitEthernet0/0/27
interface GigabitEthernet0/0/28
ip route-static 0.0.0.0 0.0.0.0 172.16.6.129
user-interface con 0
 authentication-mode password
 set authentication password
知了小白
粉丝: 关注:
充当不了路由器,因为交换机没有NAT功能
1、ip route-static 0.0.0.0 0.0.0.0 172.16.6.129   172.16.6.129   这个默认路由对端设备地址吗?
如果是,对端在给你回指两条路由,到你网段就行了
2、或者是在另一个设备上创建188 189 的vlan  vlanif 地址
  在互联口允许vlan 188 189 通过就行了
粉丝:4人 关注:1人
在VLAN613里面开启nat outbound?这个配置看起来是华为交换机的配置啊,普通三层交换机是不是需要有能支持NAT的芯片,才能做NAT功能,上互联网啊
