H3C S5120-28P-SI 交换机光模块不发光
  • 1收藏,4569浏览
光模块是华三的,而且确定好的, S5120-28P-SI 交换机1-24口是电口,25-28口是光口,我在1口上插上网线,25口插上光模块,并在G1/0/25口里敲了undo shutdown,但是25口还是DOWN起的,光模块无光发出。我又试了下combo enable fiber命令,显示错误,压根没这个命令,求大神帮帮,谢谢,下面是26口的状态。
GigabitEthernet1/0/26 current state: DOWN IP Packet Frame Type: PKTFMT_ETHNT_2, Hardware Address: 5866-bac6-c130 Description: GigabitEthernet1/0/26 Interface Loopback is not set Media type is optical fiber, Port hardware type is 100_BASE_LX_SFP Unknown-speed mode, unknown-duplex mode Link speed type is autonegotiation, link duplex type is autonegotiation Flow-control is not enabled The Maximum Frame Length is 10240 Broadcast MAX-ratio: 100% Unicast MAX-ratio: 100% Multicast MAX-ratio: 100% PVID: 1 Port link-type: access Tagged VLAN ID : none Untagged VLAN ID : 1 Port priority: 0 Last clearing of counters: Never Peak value of input: 0 bytes/sec, at 00-00-00 00:00:00 Peak value of output: 0 bytes/sec, at 00-00-00 00:00:00 Last 300 seconds input: 0 packets/sec 0 bytes/sec -% Last 300 seconds output: 0 packets/sec 0 bytes/sec -% Input (total): 0 packets, 0 bytes 0 unicasts, 0 broadcasts, 0 multicasts, 0 pauses Input (normal): 0 packets, 0 bytes 0 unicasts, 0 broadcasts, 0 multicasts, 0 pauses Input: 0 input errors, 0 runts, 0 giants, - throttles 0 CRC, 0 frame, 0 overruns, 0 aborts - ignored, - parity errors Output (total): 0 packets, 0 bytes 0 unicasts, 0 broadcasts, 0 multicasts, 0 pauses Output (normal): 0 packets, 0 bytes 0 unicasts, 0 broadcasts, 0 multicasts, 0 pauses Output: 0 output errors, - underruns, - buffer failures 0 aborts, 0 deferred, 0 collisions, 0 late collisions - lost carrier, - no carrier
粉丝:1人 关注:1人
1.在确认光模块的型号,是否是华三的
2.看下是否是因为熔纤的原因,找光笔测一下
3.把光模块插在其他亮了的交换机上,看是否是光模块的问题
4.找另一台交换机,测试是否是交换机的问题
5.看下端口速率是否一样,双方光模块端口是否一样
这种多半是光模块和熔纤 的问题,或是不匹配的问题,我也遇到过
4 个回答
这种问题应该最好搞了把 替换测试了 看看是接口有问题还是光膜块有问题
光膜块替换过的,能替换的都替换了,我觉得是配置哪里不对,不是硬件问题了
十方普贤 发表时间:2017-08-04
粉丝:18人 关注:11人
没看懂 为什么测试了这么久的 25口……然后给26口的信息收集
不好意思,后来我又替换到26口了,问题还是这样,不发光,能替换的硬件我都替换了,我怀疑是哪里配置没对,交换机是新的
十方普贤 知了小白
一楼,能替换的硬件我都替换,还是这样,我想应该是哪里没配置对。 二楼,后来我又试了试26口还是不行。
HCNP 五段
你是怎么看出来光模块不发光的?
