UC2.0数据库登录
2022-04-22提问
  • 1收藏,838浏览
这个UC2.0plat0612的数据库默认登录账号和密码默认是多少?
paner 九段
粉丝:33人 关注:3人
root/DB-pwd@123
试试
不对 报错为ERROR 2002 (HY000): Can't connect to local MySQL server through socket '/var/lib/mysql/mysql.sock' (2)
zhiliao_dPfNM0 发表时间:2022-04-22
这报错不是密码不对的意思吧?
[root@ucenter01 ~]# kubectl get svc -n service-software | grep mha mha-mysql ClusterIP 10.96.111.34 <none> 3306/TCP,3307/TCP 91d mha-mysql-deploy ClusterIP 10.96.89.232 <none> 3306/TCP 3d14h mhanta-mysql ClusterIP 10.96.138.248 <none> 3306/TCP,3307/TCP 2d23h mhanta-mysql-deploy ClusterIP 10.96.244.53 <none> 3306/TCP 2d23h [root@ucenter01 ~]# mysql -h 10.96.89.232 -u root -P 3306 -p Enter password: Welcome to the MariaDB monitor. Commands end with ; or \g. Your MySQL connection id is 1019823 Server version: 5.7.29-32-57-log Percona XtraDB Cluster (GPL), Release rel31.43, Revision 56bce88, WSREP version 31.43, wsrep_31.43 Copyright (c) 2000, 2018, Oracle, MariaDB Corporation Ab and others. Type 'help;' or '\h' for help. Type '\c' to clear the current input statement. MySQL [(none)]> 这么连试试
paner 发表时间:2022-04-22
上面这条kubectl是干嘛的
