h3c s7503 各VLAN之间PC机不能跨段访问
2018-08-16提问
  • 1收藏,1891浏览
h3c s7503 各VLAN之间PC机不能跨段访问,PING也PING不通,好像独立一个网段,但都可以上网。
<324-1004(S7503)>sys
[324-1004(S7503)]dis cu
 sysname 324-1004(S7503)
 super password level 3 simple huawei
 domain default enable system
 ip host FuL-7503 10.10.10.1
 dhcp-server 1 ip  192.168.1.2
 temperature-limit 0 10 70
 temperature-limit 1 10 70
 temperature-limit 2 10 70
 poe power max-value 2400
 gvrp
radius scheme system
 primary authentication 127.0.0.1 1645
 primary accounting 127.0.0.1 1646
 user-name-format without-domain
domain system
 vlan-assignment-mode integer
 access-limit disable
 state active
 idle-cut disable
 self-service-url disable
 messenger time disable
 stp TC-protection enable
vlan 1
 description manager
vlan 11
 description Server
vlan 12
 description Executive
vlan 13
 description Teacher
vlan 14
 description Class
vlan 15
 description Dorm
vlan 16
 description ComputerLab
interface Vlan-interface1
 ip address 10.10.10.1 255.255.255.0
interface Vlan-interface11
 ip address 192.168.1.254 255.255.255.0
 dhcp-server 1
interface Vlan-interface12
 ip address 192.168.2.254 255.255.255.0
 dhcp-server 1
interface Vlan-interface13
 ip address 192.168.3.254 255.255.255.0
 dhcp-server 1
interface Vlan-interface14
 ip address 192.168.4.254 255.255.255.0
 dhcp-server 1
interface Vlan-interface15
 ip address 192.168.5.254 255.255.255.0
 dhcp-server 1
interface Vlan-interface16
 ip address 192.168.6.254 255.255.255.0
 dhcp-server 1
interface Aux0/0/0
interface M-Ethernet0/0/0
interface GigabitEthernet0/0/1
interface GigabitEthernet0/0/2
interface GigabitEthernet0/0/3
interface GigabitEthernet0/0/4
 port link-type trunk
 port trunk permit vlan all
 gvrp
 gvrp
 qos
 line-rate kbps 3072
 gvrp
interface GigabitEthernet1/0/4
interface GigabitEthernet1/0/5
interface GigabitEthernet1/0/6
interface GigabitEthernet1/0/7
interface GigabitEthernet1/0/8
interface GigabitEthernet2/0/1
interface GigabitEthernet2/0/2
interface GigabitEthernet2/0/3
interface GigabitEthernet2/0/4
interface GigabitEthernet2/0/5
interface GigabitEthernet2/0/6
interface GigabitEthernet2/0/7
 port access vlan 11
interface GigabitEthernet2/0/8
 port access vlan 12
interface GigabitEthernet2/0/9
 port access vlan 13
interface GigabitEthernet2/0/10
 port access vlan 14
interface GigabitEthernet2/0/11
 port access vlan 15
interface GigabitEthernet2/0/12
 port access vlan 16
interface GigabitEthernet2/0/13
 port access vlan 11
interface GigabitEthernet2/0/14
 port access vlan 11
interface GigabitEthernet2/0/15
 port access vlan 11
interface GigabitEthernet2/0/16
 port access vlan 11
interface GigabitEthernet2/0/17
 port access vlan 11
interface GigabitEthernet2/0/18
 port access vlan 11
interface GigabitEthernet2/0/19
 port access vlan 11
interface GigabitEthernet2/0/20
 port access vlan 11
interface NULL0
 dhcp server detect
 ip route-static 0.0.0.0 0.0.0.0 10.10.10.2 preference 60
 snmp-agent
 snmp-agent local-engineid 800063A2000FE24B485E6877
 snmp-agent community read pubilc
 snmp-agent community write public
 snmp-agent sys-info location FuL
 snmp-agent sys-info version all
 snmp-agent target-host trap address udp-domain 10.10.10.1 params securityname p
ublic
user-interface aux 0
user-interface vty 0 4
 user privilege level 3
 set authentication password simple huawei
return
[324-1004(S7503)]
粉丝:50人 关注:5人
看配置没问题,流统下吧,看看是不是交换机的问题
粉丝:50人 关注:5人
zhiliao_uEnva 知了小白
请问是不是中间做了限制,不能相互访问,我在三层所有的网线都拔掉,都是这种情况,应该不存在软件控制的情况吧
