h3c s2110交换机的远程telnet配置
2017-08-04提问
  • 1收藏,4724浏览
买的这款 h3c 的s2110 交换机没有说明书,想配个远程telnet管理老是不成功,麻烦哪位大神帮忙看下,附上我的配置:
                80vlan是网管vlan,与上联设备联接,双方互相可以ping通,但无法telnet到s2110上来
<H3C>dis cur
 version 5.20.99, Release 1105
 sysname H3C
 domain default enable system
 ipv6
 management-vlan 80
 password-recovery enable
vlan 1
vlan 2
vlan 6
vlan 50
vlan 80
vlan 3560
domain system
 access-limit disable
 state active
 idle-cut disable
 self-service-url disable
user-group system
 group-attribute allow-guest
local-user lytv
 password cipher $c$3$s8eD6/LCQEFBOJdvEpTk/z/QRrq6ebMZbP0=
 service-type telnet
interface NULL0
interface Vlan-interface80
 ip address 10.20.80.190 255.255.255.0
interface Ethernet1/0/1
 port link-type trunk
 port trunk permit vlan all
interface Ethernet1/0/2
interface Ethernet1/0/3
interface Ethernet1/0/4
interface Ethernet1/0/5
interface Ethernet1/0/6
interface Ethernet1/0/7
 port access vlan 6
interface Ethernet1/0/8
 port access vlan 50
interface GigabitEthernet1/0/9
 combo enable copper
interface GigabitEthernet1/0/10
 port link-type hybrid
 port hybrid vlan 2 6 50 80 3560 tagged
 port hybrid vlan 1 untagged
 ip route-static 0.0.0.0 0.0.0.0 10.20.80.250
 load xml-configuration
 load tr069-configuration
user-interface aux 0
user-interface vty 0 15
 authentication-mode scheme
return
粉丝:18人 关注:11人
http://www.h3c.com/cn/Service/Document_Center/Switches/Catalog/S2100/S2110/Configure/Operation_Manual/H3C_S2100_CG-6W103/00/
配置这都去官网找  这是下载链接
你没开 telnet  没配用户级别等等 ,按这个步骤来
交换机配置telnet命令有四步:
1、配置交换机的管理地址,确保终端可以ping通交换机管理地址;
2、开启telnet服务,命令:telnet server enable;
3、配置VTY用户线,命令:
user-interface vty 0 4
authentication-mode scheme;
4、配置登陆用户名密码,命令:
local-user admin
password simple admin
service-type telnet
authorization-attribute level 3
zhiliao_80840 知了小白
谢谢,我不知道还有telnet server enable 这个命令啊!!收到学习了。设备已经可以管理了。
