HCL无法启动
2018-08-17提问
  • 1收藏,1786浏览
Traceback (most recent call last): File "HCLUpdate.py", line 9, in <module> File "Ui_PopUp.pyc", line 10, in <module> File "PyQt4\QtGui.pyc", line 12, in <module> File "PyQt4\QtGui.pyc", line 10, in __load ImportError: DLL load failed: 操作系统无法运行 %1。 Traceback (most recent call last): File "HCLUpdate.py", line 9, in <module> File "Ui_PopUp.pyc", line 10, in <module> File "PyQt4\QtGui.pyc", line 12, in <module> File "PyQt4\QtGui.pyc", line 10, in __load ImportError: DLL load failed: 操作系统无法运行 %1。 Traceback (most recent call last): File "HCLUpdate.py", line 9, in <module> File "Ui_PopUp.pyc", line 10, in <module> File "PyQt4\QtGui.pyc", line 12, in <module> File "PyQt4\QtGui.pyc", line 10, in __load ImportError: DLL load failed: 操作系统无法运行 %1。 Traceback (most recent call last): File "HCLUpdate.py", line 9, in <module> File "Ui_PopUp.pyc", line 10, in <module> File "PyQt4\QtGui.pyc", line 12, in <module> File "PyQt4\QtGui.pyc", line 10, in __load ImportError: DLL load failed: 操作系统无法运行 %1。
这个是报错记录
ahooh 七段
粉丝:5人 关注:0人
win 10 系统中运行的话需要将HCL 和 virtual box 都设置为兼容性运行(兼容win 7)
还有个问题,进去之后添加的交换机无法启动
zhiliao_H8VPJ 发表时间:2018-08-17
这种情况就需要更换virtual box 版本了,试试4.2.24或者5.1.30版本,别的可能也行但我没试过,有人试过5.2.6也可以
ahooh 发表时间:2018-08-17
粉丝:10人 关注:0人
安装完成就是如此,有尝试过重启操作系统吗?不行,建议卸载重新安装
Yl0j8k 知了小白
果然是兼容性问题 谢谢啦
