S5024PV2-EI-PWR 设备启动过程中报错
2018-08-17提问
  • 1收藏,1708浏览
粉丝:9人 关注:1人
现场设备启动过程中报大量驱动错误,这是已经升级最新版本后的报错,请各位大神帮忙看下什么问题,是否硬件故障:
 Drv_InternalSetStpPort: call Hal_GetStpPortState fail!
 Drv_Port_SetMstpStateByInstance: call Drv_InternalSetStpPort(4,20)fail!
 Drv_Set_MstpPortState: call Drv_Port_SetMstpStateByInstance(3,20,3)fail!
<H3C>rebo
<H3C>reboot
#Apr 26 12:13:15:726 2000 H3C DEVM/1/REBOOT:
 Reboot device by command.
%Apr 26 12:13:15:814 2000 H3C DEVM/5/SYSTEM_REBOOT: System is rebooting now.
 Now rebooting, please wait...
<H3C>
System is starting...
Press Ctrl+D to access BASIC-BOOTWARE MENU
Booting Normal Extend BootWare
The Extend BootWare is self-decompressing..........................Done!
*               H3C S5024PV2-EI-PWR BootWare, Version 1.22                 *
Copyright (c) 2004-2017 New H3C Technologies Co., Ltd.
Compiled Date       : Apr 14 2017 15:05:19
CPU Type            : MIPS4kec
CPU L1 Cache        : 16KB
CPU Clock Speed     : 500MHz
Memory Type         : DDR3 SDRAM
Memory Size         : 128MB
Memory Speed        : 300MHz
BootWare Size       : 3MB
Flash Size          : 32MB
BootWare Validating...
Press Ctrl+B to enter extended boot menu...
Starting to get the main application
file--flash:/S5024PV2_EI_PWR-CMW520-R1111.bin!..............................
The main application file is self-decompressing.............................
.............................Done!
System application is starting...
 Drv_Port_SetMstpStateByInstance: call Drv_InternalSetStpPort(4,16)fail!
 Drv_Set_MstpPortState: call Drv_Port_SetMstpStateByInstance(3,16,3)fail!
 Drv_PortSetStpStateInAllInstances: call Drv_InternalSetStpPort(4,16,0) fail!
 Drv_STP_BlockPort: call Drv_PortSetStpStateInAllInstances fail!
 Drv_Set_AggrPortBlock: call Drv_STP_BlockPort(PortIndex:16, State:2) fail!
 Drv_Port_SetMstpStateByInstance: call Drv_InternalSetStpPort(4,17)fail!
 Drv_Set_MstpPortState: call Drv_Port_SetMstpStateByInstance(3,17,3)fail!
 Drv_PortSetStpStateInAllInstances: call Drv_InternalSetStpPort(4,17,0) fail!
 Drv_Set_AggrPortBlock: call Drv_STP_BlockPort(PortIndex:17, State:2) fail!
 Drv_Port_SetMstpStateByInstance: call Drv_InternalSetStpPort(4,18)fail!
 Drv_Set_MstpPortState: call Drv_Port_SetMstpStateByInstance(3,18,3)fail!
 Drv_PortSetStpStateInAllInstances: call Drv_InternalSetStpPort(4,18,0) fail!
 Drv_Set_AggrPortBlock: call Drv_STP_BlockPort(PortIndex:18, State:2) fail!
 Drv_Port_SetMstpStateByInstance: call Drv_InternalSetStpPort(4,19)fail!
 Drv_Set_MstpPortState: call Drv_Port_SetMstpStateByInstance(3,19,3)fail!
 Drv_PortSetStpStateInAllInstances: call Drv_InternalSetStpPort(4,19,0) fail!
 Drv_Set_AggrPortBlock: call Drv_STP_BlockPort(PortIndex:19, State:2) fail!
 Drv_PortSetStpStateInAllInstances: call Drv_InternalSetStpPort(4,20,0) fail!
 Drv_Set_AggrPortBlock: call Drv_STP_BlockPort(PortIndex:20, State:2) fail!
 Drv_Port_SetMstpStateByInstance: call Drv_InternalSetStpPort(4,21)fail!
 Drv_Set_MstpPortState: call Drv_Port_SetMstpStateByInstance(3,21,3)fail!
 Drv_PortSetStpStateInAllInstances: call Drv_InternalSetStpPort(4,21,0) fail!
 Drv_Set_AggrPortBlock: call Drv_STP_BlockPort(PortIndex:21, State:2) fail!
 Drv_Port_SetMstpStateByInstance: call Drv_InternalSetStpPort(4,22)fail!
 Drv_Set_MstpPortState: call Drv_Port_SetMstpStateByInstance(3,22,3)fail!
 Drv_PortSetStpStateInAllInstances: call Drv_InternalSetStpPort(4,22,0) fail!
 Drv_Set_AggrPortBlock: call Drv_STP_BlockPort(PortIndex:22, State:2) fail!
 Drv_Port_SetMstpStateByInstance: call Drv_InternalSetStpPort(4,23)fail!
 Drv_Set_MstpPortState: call Drv_Port_SetMstpStateByInstance(3,23,3)fail!
 Drv_PortSetStpStateInAllInstances: call Drv_InternalSetStpPort(4,23,0) fail!
 Drv_Set_AggrPortBlock: call Drv_STP_BlockPort(PortIndex:23, State:2) fail!
User interface aux0 is available.
Press ENTER to get started.
<H3C>
#Apr 26 12:00:31:144 2000 H3C SHELL/4/LOGIN:
 Trap 1.3.6.1.4.1.25506.2.2.1.1.3.0.1<hh3cLogIn>: login from Console
%Apr 26 12:00:31:284 2000 H3C SHELL/5/SHELL_LOGIN: Console logged in from aux0.
粉丝:50人 关注:5人
硬件问题,返修吧
粉丝:12人 关注:7人
重新导入版本试试,不行就只能走备件了。
