S5120上划分VLAN 30 无法上网的故障解决
2022-04-30提问
  • 1收藏,936浏览
各位好,组网方式如下:
核心路由MSR3610 ,VLAN1的IP为10.10.20.1-254 网关10.10.20.1,目前IP为10.10.20.0端的IP都能上网。
核心交换S5120,VLAN 30的IP为10.10.30.1-10.10.30.254  网关10.10.30.1  ,通过GI 1/0/2和核心路由连,目前VLAN 30无法上网,VLAN1可以上网
现在核心交换上的划分了VLAN 30 的端口都无法上网,默认VLAN1可以上网,请问是什么问题,我是新手。
详细配置如下:
核心路由配置如下:
<Router>
<Router>
<Router>
<Router>dis
<Router>display curr
<Router>display current-configuration
 version 7.1.064, Release 0615P10
 sysname Router
 dhcp enable
 dhcp server always-broadcast
 dns proxy enable
 password-recovery enable
vlan 1
vlan 30
dhcp server ip-pool lan1
 gateway-list 10.10.20.1
 network 10.10.20.0 mask 255.255.255.0
 address range 10.10.20.2 10.10.20.254
 dns-list 114.114.114.114 223.5.5.5
controller Cellular0/0
controller Cellular0/1
interface Aux0
interface NULL0
interface Vlan-interface30
 ip address 10.10.30.250 255.255.255.0
interface GigabitEthernet0/0
 port link-mode route
 combo enable copper
 ip address 10.10.20.1 255.255.255.0
interface GigabitEthernet0/1
 description Multiple_Line
 bandwidth 1000000
 ip address 192.168.88.240 255.255.255.0
 dns server 114.114.114.114
 dns server 223.6.6.6
 nat outbound
interface GigabitEthernet0/2
 scheduler logfile size 16
line class aux
 user-role network-admin
line class tty
 user-role network-operator
line class usb
line class vty
line aux 0
line vty 0 63
 authentication-mode scheme
 ip route-static 0.0.0.0 0 GigabitEthernet0/1 192.168.88.1
 password-control enable
 undo password-control aging enable
 undo password-control history enable
 password-control length 6
 password-control login-attempt 3 exceed lock-time 10
 password-control update-interval 0
 password-control login idle-time 0
 password-control complexity user-name check
domain system
 domain default enable system
role name level-0
 description Predefined level-0 role
role name level-1
核心交换配置如下:
<Switch>
<Switch>
<Switch>
<Switch>
<Switch>dis
<Switch>display curr
<Switch>display current-configuration
 version 5.20, Release 1519P06
 sysname Switch
 irf mac-address persistent timer
 irf auto-update enable
 undo irf link-delay
 telnet server enable
vlan 1
vlan 30
domain system
 access-limit disable
 state active
 idle-cut disable
 self-service-url disable
dhcp server ip-pool vlan30
 network 10.10.30.0 mask 255.255.255.0
 gateway-list 10.10.30.1
 dns-list 114.114.114.114 223.6.6.6
user-group system
interface NULL0
interface Vlan-interface1
 ip address 10.10.20.250 255.255.255.0
 ip address 10.10.30.1 255.255.255.0
interface GigabitEthernet1/0/1
 port link-type trunk
 port trunk permit vlan all
 poe enable
interface GigabitEthernet1/0/2
 port access vlan 30
interface GigabitEthernet1/0/3
interface GigabitEthernet1/0/4
interface GigabitEthernet1/0/5
interface GigabitEthernet1/0/6
interface GigabitEthernet1/0/7
interface GigabitEthernet1/0/8
interface GigabitEthernet1/0/9
interface GigabitEthernet1/0/10
interface GigabitEthernet1/0/11
interface GigabitEthernet1/0/12
interface GigabitEthernet1/0/13
interface GigabitEthernet1/0/14
interface GigabitEthernet1/0/15
interface GigabitEthernet1/0/16
interface GigabitEthernet1/0/17
interface GigabitEthernet1/0/18
interface GigabitEthernet1/0/19
interface GigabitEthernet1/0/20
interface GigabitEthernet1/0/21
interface GigabitEthernet1/0/22
interface GigabitEthernet1/0/23
interface GigabitEthernet1/0/24
interface GigabitEthernet1/0/25
interface GigabitEthernet1/0/26
interface GigabitEthernet1/0/27
interface GigabitEthernet1/0/28
 ip route-static 0.0.0.0 0.0.0.0 10.10.20.1
 dhcp enable
 load tr069-configuration
user-interface aux 0
user-interface vty 0 15
return
<Switch>
<Switch>
粉丝:111人 关注:0人
配置逻辑错了,路由器上删除interface Vlan-interface30
 ,再新增一条路由 ip route-static  10.10.30 .0 24  10.10.20.250
zhiliao_zQoNB 知了小白
好了 ,太感谢您了。
粉丝:94人 关注:0人
配置问题
