AP4330 使用ap-mode fat命令后出现
2022-05-03提问
  • 1收藏,835浏览
粉丝:0人 关注:7人
 Loading...Failed! System is starting... Press Ctrl+D to access BASIC-BOOTWARE MENU Booting Normal Extend BootWare The Extend BootWare is self-decompressing....................Done! **************************************************************************** * * * H3C WA4330-ACN BootWare, Version 1.15 * * * **************************************************************************** Copyright (c) 2004-2017 New H3C Technologies Co., Ltd. Compiled Date : Mar 27 2017 CPU Type : ATHEROS AR9557 CPU L1 Cache : 32KB CPU Clock Speed : 720MHz Memory Type : SDRAM Memory Size : 256MB Memory Speed : 560MHz BootWare Size : 512KB Flash Size : 32MB PCB Version : Ver.B BootWare Validating... Press Ctrl+B to enter extended boot menu... Starting to get the main application file--flash:/wa4300_fat.bin! The main application file does not exist--flash:/wa4300_fat.bin! Starting to get the backup application file--flash:/backup.bin! The backup application file does not exist--flash:/backup.bin! Starting to get the secure application file--flash:/secure.bin! The secure application file does not exist--flash:/secure.bin! Booting App fails! Protocol (FTP or TFTP) : ftp Load File Name : wa4300_fat.bin Target File Name : wa4300_fat.bin Server IP Address : 192.168.1.1 Local IP Address : 192.168.1.50 Gateway IP Address : 0.0.0.0 FTP User Name : admin FTP User Password : password Loading...Failed! System is starting... Press Ctrl+D to access BASIC-BOOTWARE MENU Booting Normal Extend BootWare The Extend BootWare is self-decompressing....................Done! **************************************************************************** * * * H3C WA4330-ACN BootWare, Version 1.15 * * * **************************************************************************** Copyright (c) 2004-2017 New H3C Technologies Co., Ltd. Compiled Date : Mar 27 2017 CPU Type : ATHEROS AR9557 CPU L1 Cache : 32KB CPU Clock Speed : 720MHz Memory Type : SDRAM Memory Size : 256MB Memory Speed : 560MHz BootWare Size : 512KB Flash Size : 32MB PCB Version : Ver.B BootWare Validating... Press Ctrl+B to enter extended boot menu... Starting to get the main application file--flash:/wa4300_fat.bin! The main application file does not exist--flash:/wa4300_fat.bin! Starting to get the backup application file--flash:/backup.bin! The backup application file does not exist--flash:/backup.bin! Starting to get the secure application file--flash:/secure.bin! The secure application file does not exist--flash:/secure.bin! Booting App fails! Protocol (FTP or TFTP) : ftp Load File Name : wa4300_fat.bin Target File Name : wa4300_fat.bin Server IP Address : 192.168.1.1 Local IP Address : 192.168.1.50 Gateway IP Address : 0.0.0.0 FTP User Name : admin FTP User Password : password Loading...Failed! System is starting... Press Ctrl+D to access BASIC-BOOTWARE MENU Booting Normal Extend BootWare The Extend BootWare is self-decompressing....................Done!
粉丝:144人 关注:0人
您好,瘦转胖需要后台指定启动文件,不能使用此命令
您好,现在一直重启中了,怎么搞
NICOSDTAZGD 发表时间:2022-05-03
5 个回答
知了小白
粉丝: 关注:
你是不是没刷成功?
https://www.h3c.com/cn/d_202201/1535586_30005_40.htm#_Toc93568550 你按照这个升级步骤 通过以太网口使用TFTP/FTP协议进行软件升级 ,至于你说的ctrl+b 或者+D ,不好使,是不是你在crt 上勾选了流控了
没有刷,看到问答里有这个命令就试了一下,结果完了一直重启了,按AP后的RST没有效果。不知怎么搞了
粉丝:4人 关注:0人
应该是没找到WA4300_FAT.BIN文件,最简单的办法就是系统重新导一下,几分钟就搞定的。
有步骤吗亲我不会整了
联系400根据提示分析下吧
出保了新华三一键接入不行了
寂东 九段
粉丝:225人 关注:3人
胖转瘦可以使用ap-mode fit命令,瘦转胖,需要上传胖版本软件
胖版本软件下载链接和操作文档
https://www.h3c.com/cn/Service/Document_Software/Software_Download/IP_Wlan/AP/H3C_WA4300/?CHID=189389&v=612
账号:yx800
密码:01230123
这种状况下怎么搞呢亲
回复NICOSDTAZGD:
按照上边发的链接下载软件版本和操作说明来操作即可
寂东 发表时间:2022-05-03
粉丝:25人 关注:7人
你要刷成fat的么?
官网没找到4330(不带任何后缀)型号的软件版本。
你看看开机进入bootrom(就是画面提示的ctrl+B ctrl+D两个界面)那里有没有切回fit的选项。
有提示这两个按键,按了后没反映,他还是重启他的 也没有切回的选项
CTRL+Z也没反映
NICOSDTAZGD 发表时间:2022-05-06
