交换机出现STP告警,业务中断
2022-05-05提问
  • 1收藏,2178浏览
交换机出现了这个告警,关闭STP业务也不通,开启后写了静态路由、拔插网线后业务正常,不知道这是什么原因导致的,这是告警信息
%Aug 6 21:26:18:566 2013 -ASZD-LiangSuoTunBian IFNET/5/LINK_UPDOWN: Line protocol state on the interface Vlan-interface2 changed to down.
%Aug 6 21:26:19:546 2013 -ASZD-LiangSuoTunBian STP/6/STP_NOTIFIED_TC: Instance 0's port GigabitEthernet1/0/5 was notified a topology change.
%Aug 6 21:26:21:547 2013 -ASZD-LiangSuoTunBian STP/6/STP_NOTIFIED_TC: Instance 0's port GigabitEthernet1/0/5 was notified a topology change.
%Aug 6 21:26:23:547 2013 -ASZD-LiangSuoTunBian STP/6/STP_NOTIFIED_TC: Instance 0's port GigabitEthernet1/0/5 was notified a topology change.
%Aug 6 21:26:25:070 2013 -ASZD-LiangSuoTunBian IFNET/3/PHY_UPDOWN: Physical state on the interface GigabitEthernet1/0/1 changed to up.
%Aug 6 21:26:25:073 2013 -ASZD-LiangSuoTunBian IFNET/5/LINK_UPDOWN: Line protocol state on the interface GigabitEthernet1/0/1 changed to up.
%Aug 6 21:26:25:084 2013 -ASZD-LiangSuoTunBian IFNET/3/PHY_UPDOWN: Physical state on the interface Vlan-interface2 changed to up.
%Aug 6 21:26:25:087 2013 -ASZD-LiangSuoTunBian IFNET/5/LINK_UPDOWN: Line protocol state on the interface Vlan-interface2 changed to up.
粉丝:26人 关注:7人
这个消息就是5口下发生拓扑变化。
如果5口接的是终端,建议配置stp的边缘端口。
粉丝:46人 关注:1人
发生拓扑改变,重新计算生成树导致的,
5口和1口连接的是终端还是交换机,终端的话开启边缘端口,接口下stp edged-port,如果接的是交换机, dis stp br 看一下哪些端口是阻塞的.之后沿着阻塞端口往下排查是否有环路。
dis stp tc 可以通过这个命令查询TC报文是从哪个口发出来,沿着发送口往下去排查
粉丝:11人 关注:0人
stp的tc置位报文不影响网络。vlan2是你的业务vlan?排查下vlan2为什么会down
