s5110交换机不能正常启动
2022-05-05提问
  • 1收藏,648浏览
System is starting... Press Ctrl+D to access BASIC-BOOTWARE MENU ======================<BASIC-BOOTWARE MENU(Ver 1.11)>======================= |<1> Modify Serial Interface Parameter | |<2> Update Extend BootWare | |<3> Update Full BootWare | |<4> Boot Extend BootWare | |<5> Boot Backup Extend BootWare | |<0> Reboot | ============================================================================ Enter your choice(0-5): 5 Booting Backup Extend BootWare The Extend BootWare is self-decompressing....................Done! **************************************************************************** * * * H3C S5110-52P BootWare, Version 1.11 * * * **************************************************************************** Copyright (c) 2004-2014 Hangzhou H3C Technologies Co., Ltd. Compiled Date : Jul 11 2014 17:08:02 CPU Type : MIPS34kc CPU L1 Cache : 32KB CPU Clock Speed : 650MHz Memory Type : DDR3 SDRAM Memory Size : 128MB Memory Speed : 200MHz BootWare Size : 3MB Flash Size : 32MB BootWare Validating... Press Ctrl+B to enter extended boot menu... Starting to get the main application file--flash:/S5110_52P-CMW520-R1106. bin!........................................................................ ........................ The main application file is self-decompressing............................. ............................................................................ ............................................................................ ............................................................................ ............................................................................ ............................................................................ ............................................................................ ............................................................................ ............................................................................ ............................................................................ ............................................................................ ............................................................................ ............................................................................ ............................................................................ ............................................................................ ............................................................................ ............................................................................ ............................................................................ ............................................................................ ............................................................................ ............................................................................ ..............Done! System application is starting...RTK API error = 3, file hal/switch/realtek/rtk_drv_acl_839x.c, line = 3613 RTK API error = 3, file hal/switch/realtek/rtk_drv_mac.c, line = 200 Hal_SetMacInit failed rv = 193! Hal_SetIPMCInit failed rv = 193! RTK API error = 3, file hal/switch/realtek/rtk_drv_vlan.c, line = 146 Hal_SetVlanInit failed rv = 386! Hal_Dot1xInit failed rv = 386! RTK API error = 3, file hal/switch/realtek/rtk_drv_ratelimit.c, line = 177 Hal_SetRatelimitInit failed rv = 579! RTK API error = 3, file hal/switch/realtek/rtk_drv_qos.c, line = 155 Hal_SetQosInit failed rv = 772! Hal_StpInit failed rv = 772! Hal_I2cFiberInit failed rv = 772! Hal_GetBoardIdByGpio failed rv = 772! Hal_PhyRegInit failed rv = 772! RTK API error = 3, file hal/switch/realtek/rtk_drv_ratelimit.c, line = 1002 Hal_StormCtl_Init failed rv = 965! Hal_SetTrapInit failed rv = 965! Hal_AggrInit failed rv = 965! RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1651 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1918 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 808 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 904 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1918 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 298 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 347 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 396 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1651 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1918 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 808 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 904 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1918 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 298 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 347 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 396 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1651 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1918 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 808 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 904 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1918 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 298 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 347 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 396 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1651 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1918 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 808 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 904 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1918 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 298 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 347 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 396 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1651 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1918 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 808 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 904 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1918 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 298 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 347 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 396 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1651 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1918 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 808 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 904 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1918 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 298 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 347 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 396 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1651 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1918 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 808 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 904 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1918 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 298 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 347 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 396 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1651 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1918 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 808 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 904 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1918 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 298 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 347 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 396 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1225 RTK API error = 3, file hal/switch/realtek/rtk_drv_ratelimit.c, line = 358 RTK API error = 3, file hal/switch/realtek/rtk_drv_ratelimit.c, line = 354 RTK API error = 3, file hal/switch/realtek/rtk_drv_ratelimit.c, line = 358 RTK API error = 3, file hal/switch/realtek/rtk_drv_ratelimit.c, line = 354 RTK API error = 3, file hal/switch/realtek/rtk_drv_ratelimit.c, line = 358 RTK API error = 3, file hal/switch/realtek/rtk_drv_ratelimit.c, line = 354 RTK API error = 3, file hal/switch/realtek/rtk_drv_ratelimit.c, line = 358 RTK API error = 3, file hal/switch/realtek/rtk_drv_ratelimit.c, line = 354 RTK API error = 3, file hal/switch/realtek/rtk_drv_ratelimit.c, line = 358 RTK API error = 3, file hal/switch/realtek/rtk_drv_ratelimit.c, line = 354 RTK API error = 3, file hal/switch/realtek/rtk_drv_ratelimit.c, line = 358 RTK API error = 3, file hal/switch/realtek/rtk_drv_ratelimit.c, line = 354 RTK API error = 3, file hal/switch/realtek/rtk_drv_ratelimit.c, line = 358 RTK API error = 3, file hal/switch/realtek/rtk_drv_ratelimit.c, line = 354 RTK API error = 3, file hal/switch/realtek/rtk_drv_ratelimit.c, line = 358 RTK API error = 3, file hal/switch/realtek/rtk_drv_ratelimit.c, line = 354 RTK API error = 3, file hal/switch/realtek/rtk_drv_ratelimit.c, line = 706 RTK API error = 3, file hal/switch/realtek/rtk_drv_ratelimit.c, line = 761 RTK API error = 3, file hal/switch/realtek/rtk_drv_ratelimit.c, line = 816 RTK API error = 3, file hal/switch/realtek/rtk_drv_ratelimit.c, line = 706 RTK API error = 3, file hal/switch/realtek/rtk_drv_ratelimit.c, line = 761 RTK API error = 3, file hal/switch/realtek/rtk_drv_ratelimit.c, line = 816 RTK API error = 3, file hal/switch/realtek/rtk_drv_ratelimit.c, line = 706 RTK API error = 3, file hal/switch/realtek/rtk_drv_ratelimit.c, line = 761 RTK API error = 3, file hal/switch/realtek/rtk_drv_ratelimit.c, line = 816 RTK API error = 3, file hal/switch/realtek/rtk_drv_ratelimit.c, line = 706 RTK API error = 3, file hal/switch/realtek/rtk_drv_ratelimit.c, line = 761 RTK API error = 3, file hal/switch/realtek/rtk_drv_ratelimit.c, line = 816 RTK API error = 3, file hal/switch/realtek/rtk_drv_ratelimit.c, line = 706 RTK API error = 3, file hal/switch/realtek/rtk_drv_ratelimit.c, line = 761 RTK API error = 3, file hal/switch/realtek/rtk_drv_ratelimit.c, line = 816 RTK API error = 3, file hal/switch/realtek/rtk_drv_ratelimit.c, line = 706 RTK API error = 3, file hal/switch/realtek/rtk_drv_ratelimit.c, line = 761 RTK API error = 3, file hal/switch/realtek/rtk_drv_ratelimit.c, line = 816 RTK API error = 3, file hal/switch/realtek/rtk_drv_ratelimit.c, line = 706 RTK API error = 3, file hal/switch/realtek/rtk_drv_ratelimit.c, line = 761 RTK API error = 3, file hal/switch/realtek/rtk_drv_ratelimit.c, line = 816 RTK API error = 3, file hal/switch/realtek/rtk_drv_ratelimit.c, line = 706 RTK API error = 3, file hal/switch/realtek/rtk_drv_ratelimit.c, line = 761 RTK API error = 3, file hal/switch/realtek/rtk_drv_ratelimit.c, line = 816 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1651 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 3944 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1651 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 3944 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1651 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 3944 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1651 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 3944 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1651 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 3944 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1651 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 3944 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1651 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 3944 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1651 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 3944 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1651 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1651 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1651 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1651 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1651 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1702 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1651 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1651 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1702 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1651 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1651 RTK API error = 3, file hal/switch/realtek/rtk_drv_stp.c, line = 662 Drv_InternalSetStpPort: call Hal_GetStpPortState fail! Drv_Port_SetMstpStateByInstance: call Drv_InternalSetStpPort(1,32)fail! Drv_Set_MstpPortState: call Drv_Port_SetMstpStateByInstance(0,32,3)fail!RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1651 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1651 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1651 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1651 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1651 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1651 RTK API error = 3, file hal/switch/realtek/rtk_drv_vlan.c, line = 691 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1651 RTK API error = 3, file hal/switch/realtek/rtk_drv_stp.c, line = 662 Drv_InternalSetStpPort: call Hal_GetStpPortState fail! Drv_PortSetStpStateInAllInstances: call Drv_InternalSetStpPort(1,32,0) fail! Drv_STP_BlockPort: call Drv_PortSetStpStateInAllInstances fail! Drv_Set_AggrPortBlock: call Drv_STP_BlockPort(PortIndex:32, State:2) fail! RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1651 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1651 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1651 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1651 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1651 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1651 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1702 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1651 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1651 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1702 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1651 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1651 RTK API error = 3, file hal/switch/realtek/rtk_drv_stp.c, line = 662 Drv_InternalSetStpPort: call Hal_GetStpPortState fail! Drv_Port_SetMstpStateByInstance: call Drv_InternalSetStpPort(1,33)fail! Drv_Set_MstpPortState: call Drv_Port_SetMstpStateByInstance(0,33,3)fail!RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1651 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1651 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1651 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1651 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1651 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1651 RTK API error = 3, file hal/switch/realtek/rtk_drv_vlan.c, line = 691 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1651 RTK API error = 3, file hal/switch/realtek/rtk_drv_stp.c, line = 662 Drv_InternalSetStpPort: call Hal_GetStpPortState fail! Drv_PortSetStpStateInAllInstances: call Drv_InternalSetStpPort(1,33,0) fail! Drv_STP_BlockPort: call Drv_PortSetStpStateInAllInstances fail! Drv_Set_AggrPortBlock: call Drv_STP_BlockPort(PortIndex:33, State:2) fail! RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1651 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1651 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1651 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1651 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1651 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1651 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1702 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1651 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1651 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1702 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1651 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1651 RTK API error = 3, file hal/switch/realtek/rtk_drv_stp.c, line = 662 Drv_InternalSetStpPort: call Hal_GetStpPortState fail! Drv_Port_SetMstpStateByInstance: call Drv_InternalSetStpPort(1,34)fail! Drv_Set_MstpPortState: call Drv_Port_SetMstpStateByInstance(0,34,3)fail!RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1651 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1651 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1651 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1651 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1651 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1651 RTK API error = 3, file hal/switch/realtek/rtk_drv_vlan.c, line = 691 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1651 RTK API error = 3, file hal/switch/realtek/rtk_drv_stp.c, line = 662 Drv_InternalSetStpPort: call Hal_GetStpPortState fail! Drv_PortSetStpStateInAllInstances: call Drv_InternalSetStpPort(1,34,0) fail! Drv_STP_BlockPort: call Drv_PortSetStpStateInAllInstances fail! Drv_Set_AggrPortBlock: call Drv_STP_BlockPort(PortIndex:34, State:2) fail! RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1651 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1651 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1651 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1651 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1651 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1651 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1702 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1651 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1651 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1702 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1651 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1651 RTK API error = 3, file hal/switch/realtek/rtk_drv_stp.c, line = 662 Drv_InternalSetStpPort: call Hal_GetStpPortState fail! Drv_Port_SetMstpStateByInstance: call Drv_InternalSetStpPort(1,35)fail! Drv_Set_MstpPortState: call Drv_Port_SetMstpStateByInstance(0,35,3)fail!RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1651 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1651 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1651 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1651 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1651 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1651 RTK API error = 3, file hal/switch/realtek/rtk_drv_vlan.c, line = 691 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1651 RTK API error = 3, file hal/switch/realtek/rtk_drv_stp.c, line = 662 Drv_InternalSetStpPort: call Hal_GetStpPortState fail! Drv_PortSetStpStateInAllInstances: call Drv_InternalSetStpPort(1,35,0) fail! Drv_STP_BlockPort: call Drv_PortSetStpStateInAllInstances fail! Drv_Set_AggrPortBlock: call Drv_STP_BlockPort(PortIndex:35, State:2) fail! RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1651 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1651 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1651 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1651 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1651 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1651 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1702 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1651 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1651 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1702 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1651 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1651 RTK API error = 3, file hal/switch/realtek/rtk_drv_stp.c, line = 662 Drv_InternalSetStpPort: call Hal_GetStpPortState fail! Drv_Port_SetMstpStateByInstance: call Drv_InternalSetStpPort(1,36)fail! Drv_Set_MstpPortState: call Drv_Port_SetMstpStateByInstance(0,36,3)fail!RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1651 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1651 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1651 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1651 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1651 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1651 RTK API error = 3, file hal/switch/realtek/rtk_drv_vlan.c, line = 691 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1651 RTK API error = 3, file hal/switch/realtek/rtk_drv_stp.c, line = 662 Drv_InternalSetStpPort: call Hal_GetStpPortState fail! Drv_PortSetStpStateInAllInstances: call Drv_InternalSetStpPort(1,36,0) fail! Drv_STP_BlockPort: call Drv_PortSetStpStateInAllInstances fail! Drv_Set_AggrPortBlock: call Drv_STP_BlockPort(PortIndex:36, State:2) fail! RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1651 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1651 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1651 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1651 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1651 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1651 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1702 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1651 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1651 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1702 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1651 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1651 RTK API error = 3, file hal/switch/realtek/rtk_drv_stp.c, line = 662 Drv_InternalSetStpPort: call Hal_GetStpPortState fail! Drv_Port_SetMstpStateByInstance: call Drv_InternalSetStpPort(1,37)fail! Drv_Set_MstpPortState: call Drv_Port_SetMstpStateByInstance(0,37,3)fail!RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1651 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1651 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1651 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1651 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1651 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1651 RTK API error = 3, file hal/switch/realtek/rtk_drv_vlan.c, line = 691 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1651 RTK API error = 3, file hal/switch/realtek/rtk_drv_stp.c, line = 662 Drv_InternalSetStpPort: call Hal_GetStpPortState fail! Drv_PortSetStpStateInAllInstances: call Drv_InternalSetStpPort(1,37,0) fail! Drv_STP_BlockPort: call Drv_PortSetStpStateInAllInstances fail! Drv_Set_AggrPortBlock: call Drv_STP_BlockPort(PortIndex:37, State:2) fail! RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1651 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1651 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1651 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1651 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1651 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1651 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1702 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1651 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1651 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1702 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1651 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1651 RTK API error = 3, file hal/switch/realtek/rtk_drv_stp.c, line = 662 Drv_InternalSetStpPort: call Hal_GetStpPortState fail! Drv_Port_SetMstpStateByInstance: call Drv_InternalSetStpPort(1,38)fail! Drv_Set_MstpPortState: call Drv_Port_SetMstpStateByInstance(0,38,3)fail!RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1651 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1651 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1651 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1651 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1651 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1651 RTK API error = 3, file hal/switch/realtek/rtk_drv_vlan.c, line = 691 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1651 RTK API error = 3, file hal/switch/realtek/rtk_drv_stp.c, line = 662 Drv_InternalSetStpPort: call Hal_GetStpPortState fail! Drv_PortSetStpStateInAllInstances: call Drv_InternalSetStpPort(1,38,0) fail! Drv_STP_BlockPort: call Drv_PortSetStpStateInAllInstances fail! Drv_Set_AggrPortBlock: call Drv_STP_BlockPort(PortIndex:38, State:2) fail! RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1651 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1651 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1651 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1651 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1651 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1651 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1702 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1651 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1651 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1702 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1651 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1651 RTK API error = 3, file hal/switch/realtek/rtk_drv_stp.c, line = 662 Drv_InternalSetStpPort: call Hal_GetStpPortState fail! Drv_Port_SetMstpStateByInstance: call Drv_InternalSetStpPort(1,39)fail! Drv_Set_MstpPortState: call Drv_Port_SetMstpStateByInstance(0,39,3)fail!RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1651 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1651 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1651 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1651 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1651 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1651 RTK API error = 3, file hal/switch/realtek/rtk_drv_vlan.c, line = 691 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1651 RTK API error = 3, file hal/switch/realtek/rtk_drv_stp.c, line = 662 Drv_InternalSetStpPort: call Hal_GetStpPortState fail! Drv_PortSetStpStateInAllInstances: call Drv_InternalSetStpPort(1,39,0) fail! Drv_STP_BlockPort: call Drv_PortSetStpStateInAllInstances fail! Drv_Set_AggrPortBlock: call Drv_STP_BlockPort(PortIndex:39, State:2) fail! RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1651 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1702 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1702 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1702 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1702 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1702 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1702 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1702 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1702 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1702 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1702 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1702 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1702 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1702 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1702 RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1702
粉丝:24人 关注:3人
RTK API error = 3, file hal/switch/realtek/rtk_drv_port.c, line = 1702  硬件故障了,如果设备还在保打 400 810 0504 报修换备件吧
粉丝:154人 关注:1人
提示这个的时候,Press Ctrl+B to enter extended boot menu
进入boot重新刷个版本,如果还不行就400返厂
