mstp+vrrp配置完成丢包
2017-08-05提问
  • 1收藏,2762浏览
MSTP+VRRP配置完成丢包严重
dis cur
 version 5.20, Release 2208
 sysname hexinzhu
 irf mac-address persistent timer
 irf auto-update enable
 undo irf link-delay
 domain default enable system
 telnet server enable
vlan 1
vlan 100 to 130
vlan 500
domain system
 access-limit disable
 state active
 idle-cut disable
 self-service-url disable
user-group system
local-user admin
 password cipher ^VL!HLV]BSAR)V$QU^SS)A!!
 authorization-attribute level 3
 service-type telnet terminal
 stp instance 1 root primary
 stp instance 2 root secondary
 stp pathcost-standard dot1d-1998
 stp enable
stp region-configuration
 region-name RG1
 instance 1 vlan 100 to 104
 instance 2 vlan 105 to 109
 active region-configuration
interface NULL0
interface Vlan-interface100
 ip address 174.16.100.2 255.255.255.0
 vrrp vrid 100 virtual-ip 174.16.100.1
 vrrp vrid 100 priority 120
 vrrp vrid 100 preempt-mode timer delay 20
interface Vlan-interface101
 ip address 174.16.101.2 255.255.255.0
 vrrp vrid 101 virtual-ip 174.16.101.1
 vrrp vrid 101 priority 120
 vrrp vrid 101 preempt-mode timer delay 20
interface Vlan-interface102
 ip address 174.16.102.2 255.255.255.0
 vrrp vrid 102 virtual-ip 174.16.102.1
 vrrp vrid 102 priority 120
 vrrp vrid 102 preempt-mode timer delay 20
interface Vlan-interface103
 ip address 174.16.103.2 255.255.255.0
 vrrp vrid 103 virtual-ip 174.16.103.1
 vrrp vrid 103 priority 120
 vrrp vrid 103 preempt-mode timer delay 20
interface Vlan-interface104
 ip address 174.16.104.2 255.255.255.0
 vrrp vrid 104 virtual-ip 174.16.104.1
 vrrp vrid 104 priority 120
 vrrp vrid 104 preempt-mode timer delay 20
interface Vlan-interface105
 ip address 174.16.105.3 255.255.255.0
 vrrp vrid 105 virtual-ip 174.16.105.1
interface Vlan-interface106
 ip address 174.16.106.3 255.255.255.0
 vrrp vrid 106 virtual-ip 174.16.106.1
interface Vlan-interface107
 ip address 174.16.107.3 255.255.255.0
 vrrp vrid 107 virtual-ip 174.16.107.1
interface Vlan-interface108
 ip address 174.16.108.3 255.255.255.0
 vrrp vrid 108 virtual-ip 174.16.108.1
interface Vlan-interface109
 ip address 174.16.109.3 255.255.255.0
 vrrp vrid 109 virtual-ip 174.16.109.1
interface Vlan-interface500
 ip address 192.168.253.62 255.255.255.0
 port link-mode bridge
 description tohexinbei
 port link-type trunk
 port trunk permit vlan all
 port access vlan 103
 port access vlan 100
interface GigabitEthernet1/0/4
 port access vlan 101
interface GigabitEthernet1/0/5
 port access vlan 102
interface GigabitEthernet1/0/6
interface GigabitEthernet1/0/7
 port access vlan 104
interface GigabitEthernet1/0/8
 port access vlan 105
interface GigabitEthernet1/0/9
 port access vlan 106
interface GigabitEthernet1/0/10
 port access vlan 107
interface GigabitEthernet1/0/11
 port access vlan 108
interface GigabitEthernet1/0/12
 port access vlan 109
interface GigabitEthernet1/0/13
interface GigabitEthernet1/0/14
interface GigabitEthernet1/0/15
interface GigabitEthernet1/0/16
interface GigabitEthernet1/0/17
interface GigabitEthernet1/0/18
interface GigabitEthernet1/0/19
interface GigabitEthernet1/0/20
interface GigabitEthernet1/0/21
interface GigabitEthernet1/0/22
 shutdown
interface GigabitEthernet1/0/23
interface GigabitEthernet1/0/24
 description tojieru
 stp root-protection
interface GigabitEthernet1/0/25
interface GigabitEthernet1/0/26
 shutdown
interface GigabitEthernet1/0/27
 shutdown
interface GigabitEthernet1/0/28
 shutdown
nqa entry imclinktopologypleaseignore ping
 type icmp-echo
  destination ip 192.168.253.254
  frequency 270000
 snmp-agent
 snmp-agent local-engineid 800063A20374258A67F4C9
 snmp-agent community read szsjj123r
 snmp-agent community write szsjj123w
 snmp-agent sys-info version all
 snmp-agent target-host trap address udp-domain 192.168.253.1 params securityname SZSJJZDR
 snmp-agent trap queue-size 500
 snmp-agent trap life 600
 nqa schedule imclinktopologypleaseignore ping start-time now lifetime 630720000
 load xml-configuration
user-interface aux 0
user-interface vty 0 4
 authentication-mode scheme
user-interface vty 5 15
return
<hexinzhu>
dis cur
 sysname hexinbei
 undo irf link-delay
vlan 1
vlan 100 to 130
vlan 500
domain system
 state active
 idle-cut disable
user-group system
local-user admin
 stp instance 1 root secondary
 stp instance 2 root primary
 stp enable
 region-name RG1
interface NULL0
 ip address 174.16.100.3 255.255.255.0
 ip address 174.16.101.3 255.255.255.0
 ip address 174.16.102.3 255.255.255.0
 ip address 174.16.103.3 255.255.255.0
 ip address 174.16.104.3 255.255.255.0
 ip address 174.16.105.2 255.255.255.0
 vrrp vrid 105 priority 120
 vrrp vrid 105 preempt-mode timer delay 20
 ip address 174.16.106.2 255.255.255.0
 vrrp vrid 106 priority 120
 vrrp vrid 106 preempt-mode timer delay 20
 ip address 174.16.107.2 255.255.255.0
 vrrp vrid 107 priority 120
 vrrp vrid 107 preempt-mode timer delay 20
 ip address 174.16.108.2 255.255.255.0
 vrrp vrid 108 priority 120
 vrrp vrid 108 preempt-mode timer delay 20
 ip address 174.16.109.2 255.255.255.0
 vrrp vrid 109 priority 120
 vrrp vrid 109 preempt-mode timer delay 20
 ip address 192.168.253.61 255.255.255.0
 description tohexinzhu
 stp disable
 stp disable
 stp disable
 stp disable
 stp disable
 stp disable
 stp disable
 stp disable
 stp disable
 stp disable
 stp disable
 stp disable
 stp disable
 stp disable
 stp disable
 stp disable
 stp disable
 stp disable
 stp disable
 stp disable
 shutdown
 description tojieru
 stp root-protection
 shutdown
 shutdown
 shutdown
 type icmp-echo
  frequency 270000
 snmp-agent
 snmp-agent target-host trap address udp-domain 192.168.253.1 params securityname szsjj123r v2c
return
<hexinbei>
dis cur
 sysname jieru
 vlan batch 1 100 to 109
 stp enable
 cluster enable
 ntdp enable
 ntdp hop 16
 ndp enable
 undo http server enable
 region-name RG1
interface MEth0/0/1
interface GigabitEthernet0/0/1
 port link-type access
 port default vlan 103
 stp disable
interface GigabitEthernet0/0/2
 port default vlan 108
 stp disable
interface GigabitEthernet0/0/3
 port default vlan 100
 bpdu enable
 ntdp enable
 ndp enable
interface GigabitEthernet0/0/4
 bpdu enable
 ntdp enable
 ndp enable
interface GigabitEthernet0/0/5
 bpdu enable
 ntdp enable
 ndp enable
interface GigabitEthernet0/0/6
 bpdu enable
 ntdp enable
 ndp enable
interface GigabitEthernet0/0/7
 bpdu enable
 ntdp enable
 ndp enable
interface GigabitEthernet0/0/8
 bpdu enable
 ntdp enable
 ndp enable
interface GigabitEthernet0/0/9
 bpdu enable
 ntdp enable
 ndp enable
interface GigabitEthernet0/0/10
 bpdu enable
 ntdp enable
 ndp enable
interface GigabitEthernet0/0/11
 bpdu enable
 ntdp enable
 ndp enable
interface GigabitEthernet0/0/12
 bpdu enable
 ntdp enable
 ndp enable
interface GigabitEthernet0/0/13
 bpdu enable
 ntdp enable
 ndp enable
interface GigabitEthernet0/0/14
 bpdu enable
 ntdp enable
 ndp enable
interface GigabitEthernet0/0/15
 bpdu enable
 ntdp enable
 ndp enable
interface GigabitEthernet0/0/16
 bpdu enable
 ntdp enable
 ndp enable
interface GigabitEthernet0/0/17
 bpdu enable
 ntdp enable
 ndp enable
interface GigabitEthernet0/0/18
 bpdu enable
 ntdp enable
 ndp enable
interface GigabitEthernet0/0/19
 port trunk allow-pass vlan 1 to 4094
 stp instance 1 cost 20000
interface GigabitEthernet0/0/20
 stp instance 2 cost 20000
interface GigabitEthernet0/0/21
 combo-port media type
   combo-port fiber
 bpdu enable
 ntdp enable
 ndp enable
interface GigabitEthernet0/0/22
 bpdu enable
 ntdp enable
 ndp enable
interface GigabitEthernet0/0/23
 broadcast-suppression 1
 port trunk allow-pass vlan 100
   combo-port fiber
 bpdu enable
 ntdp enable
 ndp enable
interface GigabitEthernet0/0/24
 port default vlan 1
   combo-port auto
 bpdu enable
 ntdp enable
 ndp enable
interface NULL0
aaa
 authentication-scheme default
 authorization-scheme default
 accounting-scheme default
 domain default
 domain default_admin
user-interface con 0
return
<jieru>
QQ图片20170805175507
墨峰 九段
粉丝:51人 关注:6人
看一下VRRP状态是否正常,生成树的选举是否正常,主备根状态是否正常。确认VRRP状态,生成树状态和选举情况没有问题的话,可以收集信息
看一下VRRP状态是否正常,多实例情况下,生成树的选举是否正常,主备根状态是否正常。阻塞口是否在业务链路上?
丢包的话,是某个vlan内存在丢包还是所有vlan都存在丢包,到网关是否存在丢包?可以做流统测试一下,丢包丢在哪一段。
如果确认VRRP状态,生成树状态和选举情况没有问题的话,可以收集信息。反馈400协助吧
zhiliao_33634 知了小白
<jieru>dis stp brief
 MSTID      Port                  Role  STP State     Protection
   0        GigabitEthernet0/0/19 DESI  FORWARDING      NONE
   0        GigabitEthernet0/0/20 DESI  FORWARDING      NONE
   1        GigabitEthernet0/0/19 DESI  FORWARDING      NONE
   1        GigabitEthernet0/0/20 DESI  FORWARDING      NONE
   2        GigabitEthernet0/0/19 DESI  FORWARDING      NONE
   2        GigabitEthernet0/0/20 DESI  FORWARDING      NONE
非根网桥不会出现所有接口都是指定端口的情况的,建议排查一下生成树
Erosion 发表时间:2017-08-05
