imc+EIA+AC+portal
2018-08-19提问
  • 1收藏,1831浏览
粉丝:0人 关注:2人
IMC中使用EIA组件做PORTAL认证,要求不同的用户业务VLAN走不同的认证界面,用户VLAN是在别的路由上,这个而应该怎么做,求一份详细的配置案例,AC和IMC的都需要。
知了小白
粉丝: 关注:
功能需求
Portal网页认证方式简单,无需客户端,且适用于各种终端如PC、手机、pad等。很多客户的需求是需要根据不同的终端类型推送不同的portal认证界面并下发不同的权限策略,实现灵活控制。
组网信息及描述
 PC iPhone---apwireless---MSR920-----apwireless--------iMC
配置步骤
一.设备配置:
portal server portal21 ip 192.168.15.6 key cipher $c$3$CLWGrRPHS7r5ZEF4y7gKaR/MNK9smg== url http://192.168.15.6:8080/portal server-type imc   //配置portal server ,密码h3c
 portal free-rule 1 source ip any destination ip 8.8.8.8 mask 255.255.255.255  //放通到dns地址
 portal free-rule 2 source ip any destination ip 114.64.255.148 mask 255.255.255.255
 portal free-rule 3 source ip any destination ip 114.64.255.0 mask 255.255.255.0
 portal free-rule 4 source ip any destination ip 192.169.199.1 mask 255.255.255.255
 portal free-rule 5 source ip any destination ip 192.168.20.1 mask 255.255.255.255
domain default enable portal21
acl number 3000    //用于下发不同的策略的acl
 rule 0 deny ip destination 111.1.1.1 0
 rule 5 permit ip
acl number 3001    //用于下发不同的策略的acl
 rule 0 deny ip destination 111.1.1.2 0
 rule 5 permit ip
vlan 15
vlan 20 to 22
radius scheme portal21
 primary authentication 192.168.15.6 key cipher $c$3$i+VDTbQz76KaYNVGCLgjxeW5hzuU/A==  //密钥h3c
 primary accounting 192.168.15.6 key cipher $c$3$ESLodi1ding/kohgcCABb+W78ehsrg==
 user-name-format without-domain
 nas-ip 192.168.15.1
domain portal21
 authentication portal radius-scheme portal21
 authorization portal radius-scheme portal21
 accounting portal radius-scheme portal21
 access-limit disable
 state active
 idle-cut disable
 self-service-url disable
interface LoopBack1   //用于测试策略的地址
 ip address 111.1.1.1 255.255.255.255
interface LoopBack2    //用于测试策略的地址
 ip address 111.1.1.2 255.255.255.255
interface Vlan-interface15   //链接iMC的接口
 description ssid-imc-portal-test
 ip address 192.168.15.1 255.255.255.0
interface Vlan-interface20      //连接认证客户端的接口
 description ssid-6234
 ip address 192.168.20.1 255.255.255.0
 portal server portal21 method direct
snmp-agent    //配置SNMP参数
 snmp-agent local-engineid 800063A203B8AF67F778FC
 snmp-agent community read public
 snmp-agent community write private
 snmp-agent sys-info location Location:shenzhen
 snmp-agent sys-info version all
二.iMC配置
1.       配置接入设备
2.配置portalip地址组
3.   配置portal设备
   4.    定制页面
    选择一个模板,点击增加
5.配置页面推送策略
配置两个子策略,分别如下
通过在iMC服务器上抓包iPhone 5发过来的IOS8.3系统的http报文 user-agent字段是CPU iPhone OS
6.端口组信息管理里面调用IP地址组和页面推送策略
不同终端推送不同的portal页面配置好了,接着配置不同终端下发不同的侧策略
7.  接入条件里面增加终端类型分组
 8.  配置接入策略,不同的策略调用不同的acl,实现不同的权限控制
9.   配置接入服务,不同的终端类型调用不同的接入策略
10.   配置接入用户绑定此接入服务
配置完成
三.认证效果
  PC端登陆:
Ping的时候到设备上查看acl
 <cy15>dis acl 3000
Advanced ACL  3000, named -none-, 2 rules,
ACL's step is 5
 rule 0 deny ip destination 111.1.1.1 0 (9 times matched)
 rule 5 permit ip (5131 times matched)
iPhone客户端登陆:
设备上查看acl匹配情况
<cy15>dis acl 3001
Advanced ACL  3001, named -none-, 2 rules,
ACL's step is 5
 rule 0 deny ip destination 111.1.1.2 0 (23 times matched)
 rule 5 permit ip (7541 times matched)
认证客户端端口,在AC上直接透传的VLAN,这个intvlan20 没有办法配置
呀哈哈 发表时间:2018-08-19
