防火墙F1020 日志求解
2022-05-09提问
  • 1收藏,943浏览
防火墙上没有开启VPN 但是我的设备上每天都收到VPN的请求日志,麻烦各位大神帮忙看看,这是怎么回事,能不能屏蔽掉对方发来的VPN请求?
[FW-1020]
[FW-1020]%May 9 17:12:24:696 2022 FW-1020 IKE/6/IKE_P1_SA_ESTABLISH_FAIL: -COntext=1; Failed to establish phase 1 in Aggressive mode IKE_P1_STATE_INIT state.
Reason: No acceptable transform.
SA information:
Role: responder
Local IP: 58.16.134.46
Local ID type: Unknown
Local ID:
 Local port: 500
Retransmissions: 0
Remote IP: 222.85.183.4
Remote ID type: FQDN
Remote ID: kxt1
Remote port: 44864
Recived retransmissions: 0
Inside VPN instance:
Outside VPN instance:
 Initiator COOKIE: 8d45380c3f5591c1
Responder COOKIE: 063fa7f7957df44a
Connection ID: 1766830
Tunnel ID: 4294967295
IKE profile name:
[FW-1020] int g 1/0/14
 port link-mode route
 ip address 58.16.134.46 255.255.255.252
 ip last-hop hold
 nat outbound 3999 counting
 nat server global 58.16.134.46 inside 192.168.1.222 acl 3300 rule ServerRule_190
粉丝:26人 关注:7人
dis udp看看500和4500端口是不是开着。
如果开着,写一下安全策略,禁止外网访问Local的udp 500和4500端口。
粉丝:154人 关注:1人
把VPN的配置删除
防火墙上我没有配置VPN 哦
雪寒yml 发表时间:2022-05-10
回复雪寒yml:
不可能,dis cu发出来
叫我靓仔 发表时间:2022-05-10
